2005 Audi A8L Basic settings help
AndriyS197
Canada
C?ID=374446
Hello all, I'm new here. My basic settings for MMI got deleted because car battery voltage was insufficient. My MMI buttons don't do anything. How do I reprogram basic settings to make it work? The button "Basic settings" when I go into head control is locked and I can't press it. Thank you.
Hi and welcome.
Please post an Auto-Scan so we can see what your car knows/thinks that might be relevant to the problem you're experiencing.
AndriyS197
Canada
C?ID=374446
Just a little back story first. My car was absolutely flawless except for a abs light due to a sensor on a back right wheel, and because of that my traction light was on and couldn't use ebrake. Then battery died and this happened and so I went to a dealer and they reprogrammed it and everything was perfectly fine again. Until this happened again and so I just bought vcds to do this myself instead of paying the dealer. I didn't change any values just looked around and did a bunch of scans and now not only does the mmi not work but also on the scan list theres a ton more malfunctions and the drivers side of the car is sitting half an inch higher than the passenger side. I just need to reprogram basic settings for the mmi and hopefully everything else will fix itself after that.
Here is the scan.
https://www.dropbox.com/s/dhigf4etm0nppzq/audiScan.pdf?dl=0
Please post the text of the scan here as described in the link I provided. A PDF print-out hosted elsewhere is less than optimal. If you look in the Scans sub-folder you will find a file with the original text of that scan.
I'll say this: The voltage in shown in your scan (11.7V/11.7V) is quite low and some modules are likely to refuse basic settings or adaptations as a result.
How long ago was this car's battery changed? Do you have a battery charger?
NostraJackAss
Yeah nein links, post data here & indeed if voltage is insufficient the wake maybe purposely prevented to keep essential components alive.
AndriyS197
Canada
C?ID=374446
I have no idea when it was last changed. I can change it out if need be. But when I do get a new battery, how do I go about fixing this issue? & Do you need me to repost the file but in a text format or is that link sufficient for now?
I would charge the battery to see what happens.
Posting the text would be appreciated.
AndriyS197
Canada
C?ID=374446
I will try that & I'll get back with an update in a day or two. Thank you.
AndriyS197
Canada
C?ID=374446
I unplugged the battery for 15 minutes and then had it on with a battery booster to pretend that I have a new battery. Did the scan and here are the results. I also tried going into adaptation for control head and the leveling and read channel 00 and pressed save which is supposed to reset all adaptations to default values and still nothing. Also still cant press Basic Settings button for the control head. In the scan it says that control head button is stuck but I have no idea what that means because it doesn't specify which buttons and I pressed every button to make sure nothing is stuck. I'm super lost.
Here is the text version of the scan:
Monday,15,July,2019,17:27:12:17457
VIN: WAUML44E65N015437   License Plate:
Mileage: 375800km-233511mi   Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
          47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAUML44E65N015437   Mileage: 375800km-233511miles
0E-Media Player 1 -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 077-910-560-BFM.clb
   Part No SW: 4E0 910 560 J    HW: 4E0 907 560
   Component: 4.2L V8/5V      G   0010
   Revision: --H01---    Serial number: AUX3Z0E1759150
   Coding: 0007773
   Shop #: WSC 02313 785 00200
   VCID: 2809F89C8EF75857A29-807C
18061 - Please check DTC Memory of ABS Controller
            P1653 - 008 -
18010 - Power Supply Terminal 30
            P1602 - 002 - Voltage too Low
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E0 910 156 S    HW: 09E 927 156 A
   Component: AG6 09E 4,2L5V USA  0020
   Revision: --H01---    Serial number:        0053789
   Coding: 0000002
   VCID: 323D1AF4B82B22870CD-8066
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
   Component: ESP 5.7 allrad  H44 0510
   Coding: 0007597
   VCID: 221DEAB4E8CBB207FCD-8076
00003 - Control Module
            014 - Defective
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 D
   Component:     FBS AUDID3  H04 0140
   Revision: 01404004    Serial number: AUX3Z0E1759150
   Coding: 0410624
   Shop #: WSC 02311 785 00200
   VCID: 58E9885CFE1728D7D29-800C
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
            001 - Upper Limit Exceeded
                    Fault Status: 01100001
                    Fault Frequency: 0
                    Reset counter: 28
                    Mileage: 375744 km
                    Date: 2019.07.12
                    Time: 18:54:48
00183 - Interior Access/Start Authorization Antenna 1 (R138)
                    Fault Frequency: 0
                    Reset counter: 28
                    Mileage: 375744 km
                    Date: 2019.07.12
                    Time: 18:54:48
00191 - Passenger's Door Handle Touch Sensor (G416)
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 31
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 C    HW: 4E0 959 760
   Component: Sitzmemory BFS H08  0060
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 3940576
   VCID: 2313EFB0F7D1BB0FF7B-8076
Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
   Part No SW: 4E0 910 730 G    HW: 4E0 035 729
   Component: Interfacebox    H43 1070
   Revision: 00000000    Serial number: 346BL057520375
   Coding: 0000003
   Shop #: WSC 47344 001 104857
   VCID: 2411ECACF2DFBC378E1-8070
   Subsystem 1 - Part No: 4E0 910 609 C
   Component: Bedienteil MMI  H42 0100
   Subsystem 2 - Serial number: 390B9057502202
   Subsystem 3 - Serial number: 7416.02.0500000000290B0145ÿ
   Subsystem 4 - Serial number: 0B0145ÿ
02244 - Button in Control Head is Stuck
                    Reset counter: 28
                    Mileage: 375757 km
                    Date: 2019.07.12
                    Time: 18:15:49
                    Bin. Bits: 00000000
                    Bin. Bits:  0000000
                    Bin. Bits:      100
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 E
   Component: KLIMAAUTOMAT    016 0400
   Revision: 00000030    Serial number: 00000000062010
   Coding: 1052993
   VCID: 1C61D44CCAAF84F7361-8048
   Subsystem 1 - Part No: 4E0 910 772 A
   Component: Sitzluefter  FS H02  010
   Subsystem 2 - Part No: 4E0 910 772 A
   Component: Sitzluefter BFS H02  010
   Subsystem 3 - Serial number: 898053000
   Subsystem 4 - Serial number: HO20122004065A000000000404ÿ†89
   Subsystem 5 - Serial number: 000404ÿ†898053000      000-SHO
   Subsystem 6 - Serial number:     000-SHO20122004065A00000000
   Subsystem 7 - Serial number: 65A000000000435ÿ
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 29
                    Mileage: 375778 km
                    Date: 2019.07.14
                    Time: 12:07:37
                    Temperature: 29.0°C
Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
   Part No SW: 4E0 910 279 L    HW: 4E0 907 279 L
   Component: ILM Fahrer      H12 0210
   Coding: 0123104
   VCID: 313F15F8BD2D199F757-8064
   Subsystem 1 - Part No: 4E1 910 113 B
   Component: Wischer WWS D3  H50 0400
   Coding: 00000036
   Shop #: WSC 02313
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00139548
   Shop #: WSC 02313
00908 - Control Module for Wiper Motor
                    Reset counter: 71
   Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0430
   Revision: 00000000    Serial number: AUZ5ZBE7115454
   VCID: 1B63D750CFA183CF3FB-804E
                    Reset counter: 61
                    Mileage: 375666 km
                    Date: 2019.07.10
                    Time: 16:55:17
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
   Component: Airbag 8.4E+    H10 0920
   Coding: 0530707
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549
   Component: Lenksäulenmodul H13 0040
   Coding: 0012141
   VCID: 6597B1A8B965853F59F-8030
   Component: Lenkradmodul    H05 0080
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 900 J    HW: 4E0 920 900 J
   Component: KOMBIINSTR. VDO H53 0200
   Revision: D05         Serial number: AUDID3E1004146
   Coding: 0016333
   Shop #: WSC 91550 999 95537
   VCID: 2615F6A484E34E27905-8072
Address 19: CAN Gateway        Labels:. 4E0-910-468.clb
   Part No SW: 4E0 910 468 B    HW: 4E0 907 468 E
   Component: Gateway         H10 0080
   Revision: 10          Serial number: 1900304B290051
   Coding: FCFE7BDD1B7104
   VCID: 270BFBA083E9572FAB3-8072
                    Reset counter: 69
                    Mileage: 375757 km
                    Date: 2019.07.12
                    Time: 18:03:08
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0410624
   XXXXXXXXXXX ELV                 XXXX
                    Fault Frequency: 0
                    Reset counter: 28
                    Mileage: 375744 km
                    Date: 2019.07.12
                    Time: 18:54:48
                    Fault Frequency: 0
                    Reset counter: 28
                    Mileage: 375744 km
                    Date: 2019.07.12
                    Time: 18:54:48
                    Reset counter: 31
Address 34: Level Control        Labels: 4E0-910-553.clb
   Part No SW: 4E0 910 553 H    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 4480
   Coding: 0013310
01437 - Control Position not Learned
                    Fault Status: 11100101
                    Reset counter: 29
                    Mileage: 375778 km
                    Date: 2019.07.13
                    Time: 16:33:22
   Component: Sitzmemory FS  H08  0060
   Coding: 4071658
   Part No SW: 4E0 910 887 K    HW: 4E0 919 887 C
   Component: MNS US          H44 0570
   Revision: 00000000    Serial number: 378B.057517767
   VCID: 353721E8494535BF29F-8060
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135
   Component: Dachknoten D3   H02 0090
   Serial number: 00000435200088
   Coding: 0003477
   VCID: 1D67D948D1B58DFFC1F-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 801 B
   Component: Türsteuer.FS BRM002 0060
   Coding: 0032364
   VCID: 2019E0BCE6C7A017EA9-8074
02110 - Window Regulator Switch
                    Fault Frequency: 14
                    Reset counter: 70
                    Mileage: 375648 km
                    Date: 2019.07.09
                    Time: 18:12:08
00913 - Window Regulator Switch; Front Right Driver (E81)
                    Reset counter: 67
                    Mileage: 375664 km
                    Date: 2019.07.10
                    Time: 13:03:54
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H04 0040
   Revision: 00400004    Serial number:  W040502280115
   Coding: 0065086
   Subsystem 1 - Part No: 4E0 910 853
   Component: Heckdeckel      H06 0050
   Subsystem 2 - Part No: 4E0 907 719
   Component: Neigungssensor  H03 0020
                    Fault Status: 01101100
                    Reset counter: 31
                    Mileage: 320417 km
                    Date: 2004.04.30
                    Time: 05:10:53
00984 - Left Tail Light (M4)
                    Reset counter: 31
                    Mileage: 375802 km
                    Date: 2004.03.25
                    Time: 00:04:21
00985 - Right Tail Light (M2)
                    Reset counter: 31
                    Mileage: 375802 km
                    Date: 2004.03.25
                    Time: 00:04:21
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 P    HW: 4E0 035 223 A
   Component: DSP-Amp.-High   H13 0460
   Revision: PROD_01     Serial number: 00000000011504
   Coding: 0000016
   VCID: 2A0D029490FB6A47B4D-807E
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H09 0040
   Revision:             Serial number: 00000000055177
   Coding: 0010111
   VCID: 1E65DE44DCB396E7D85-804A
02258 - Door Opener Transmitter
                    Fault Frequency: 17
                    Reset counter: 31
                    Mileage: 262136 km
                    Date: 2019.07.12
                    Time: 18:01:00
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 802 B
   Component: Türsteuer.BF BRM002 0060
   Coding: 0032364
                    Fault Status: 01101000
                    Fault Frequency: 0
                    Reset counter: 155
                    Mileage: 373392 km
                    Date: 2004.04.06
                    Time: 21:59:08
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 A    HW: 4E0 907 801
   Component: EPB  AV1C1010   H01 1010
   Revision: AV1C1010
   Coding: 0000532
   Shop #: WSC 25984 067 57207
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 31
                    Mileage: 372224 km
                    Date: 2019.02.07
                    Time: 17:10:39
                    Voltage: 10.56 V
                    Count: 231
Address 55: Headlight Range        Labels: 4E0-910-357.lbl
   Part No SW: 4E0 910 357     HW: 4E0 907 357
   Component: Pre-AFS         H01 0040
   Coding: 0000001
   VCID: 629DAAB4A84BF207BCD-8036
                    Fault Status: 11101101
                    Reset counter: 31
                    Mileage: 375752 km
                    Date: 2019.07.12
                    Time: 18:01:44
01310 - Level Control System Control Module (J197)
                    Reset counter: 31
                    Mileage: 375784 km
                    Date: 2019.07.15
                    Time: 07:11:59
   Part No SW: 4E0 910 541 F    HW: 4E0 035 541 E
   Component: TUNER EU/US/RDW H42 0480
   Revision: 00000000    Serial number: 396BS057504753
   Coding: 0000002
   Shop #: WSC 47344 001 1048576
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: ENERGIEMANAGER  H12 0390
   Revision: 00000000    Serial number: 00000000001457
   Shop #: WSC 93285 999 00235
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  1502240141
   Coding: 344530393135313035412056413031353032323430313431
   Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
   Component: Türsteuer.HL BRM002 0060
   Coding: 0032364
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273     HW: 4E0 907 273
   Component: Reifendruck 2   H01
   Revision: 00010028    Serial number: 00000700030883
   Coding: 0202127
   VCID: 5F9BA3409B39DFEF933-800A
01477 - System Switched Off
                    Fault Frequency: 253
                    Reset counter: 31
                    Mileage: 373403 km
                    Date: 2004.04.06
                    Time: 21:59:22
                    Temperature: 19.0°C
                    Error Code: 128
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Fault Status: 11100100
                    Reset counter: 158
                    Mileage: 373428 km
                    Date: 2019.05.03
                    Time: 19:57:28
                    Speed: 47.0 km/h
                    Temperature: 4.0°C
                    Error Code: 128
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Part No SW: 4E0 910 753 S    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0550
   Revision: 00000000    Serial number: 00000502160426
   Shop #: WSC 12336 024 394758
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 C
   Component: Türsteuer.HR BRM002 0060
   Coding: 0032364
                    Fault Frequency: 0
                    Reset counter: 155
                    Mileage: 373392 km
                    Date: 2004.04.06
                    Time: 21:59:00
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
   Component: Parkhilfe 8-Kan H12 0020
   Revision: --.--.--    Serial number: 08720504000086
   Coding: 0001208
   VCID: 211FE5B8EDCDA91FE57-8074
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 28
                    Mileage: 375757 km
                    Date: 2019.07.12
                    Time: 19:28:08
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
                    Reset counter: 28
                    Mileage: 375757 km
                    Date: 2019.07.12
                    Time: 19:28:09
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
                    Reset counter: 28
                    Mileage: 375767 km
                    Date: 2019.07.12
                    Time: 19:37:05
                    Reset counter: 68
                    Mileage: 375757 km
                    Date: 2019.07.12
                    Time: 19:28:07
Address 77: Telephone
End----------(Elapsed Time: 02:33, VBatt start/end: 13.5V/14.0V)-----------
Look at MVBs 017 and 018 in 07-Control Head.
017.1 is a bit field with the following meanings:
xxxxxxx? = RADIO
xxxxxx?x = CD/TV
xxxxx?xx = NAME
xxxx?xxx = TEL
xxx?xxxx = NAV
xx?xxxxx = INFO
x?xxxxxx = CAR
?xxxxxxx = SETUP
017.2 is a bit field with the following meanings:
0xxxxxx? = Left Upper Control Button
0xxxxx?x = Left Lower Control Button
0xxxx?xx = Right Upper Control Button
0xxx?xxx = Right Lower Control Button
0xx?xxxx = Return Button
0x?xxxxx = Left Arrow Button
0?xxxxxx = Right Arrow Button
018.1 is a bit field with the following meanings
000000x? = Control Button
000000?x = ON/OFF Knob
018.2 = Control Knob,Rotation, Range: -127.0...+127.0
018.3 = ON/OFF Knob,Rotation,Range: -127.0...+127.0
Fiddle with all the buttons one at a time while watching these values. One (or more) will produce no change when pressed and released. That's the one that's stuck.
AndriyS197
Canada
C?ID=374446
Will do, very appreciated for the help. Will get back with an update in a day.
mattylondon
United Kingdom
C?ID=219022
Telephone can not be reached, this module is on most loop so maybe the whole mmi is down. Get an optical loop connector to by - pass the telephone. Also perform an optical test with vcds.
AndriyS197
Canada
C?ID=374446
Can I just disable the phone in MMI settings?
NostraJackAss
Did you spill your tasty beverage into the MMI? if so take apart and clean with TV tuner cleaner and dry out.
If not do get a loop bypass to isolate systems for diagnosis path aforementioned or using RTFB.
Nah, all the stuff on the whole ring would show "Cannot be Reached" if that was the problem.
