Audi RS4 4.2 Avant Quattro. J792 No signal/communications. And yes there is autoscan.
vcds75
Denmark
C?ID=239025
Hello new user here.
This Audi RS4 B8 Production year 2014 belongs to a friend. Imported from another european country, however the instrument and autoscan show plenty of errors. Do mind i have no service history nor any idea which madman has conjured all these errors. Just as usual.
The primary issue is multiple J792 No signal/communications, errors. This control unit seems to be related to the Dynamic Steering feature.
Steps i have taken:
1. Check fuses. There is no fuse on ST1 SC1 (or ST3 SC4), which the wiring diagrams suggest. No wires either. Bummer.
2. According to workshop manual, the J792 units is supposed to reside under the drivers seat, beneath the carpet in front of the crossmember. I had to check, and there was no J792 unit/wires.
3. Check PR codes. Of course the PR sticker was missing, however i checked the VIN using this shady site https://carinfo.kiev.ua/cars/vin/audi
According to the ukranian site the car is fitted with 1N8, which corresponds to "Steering: Power steering (dynamic steering)"
4. In VCDS i tried disabling Dynamic Steering in 09 Central Elec. Byte 7 bit 4. (Using information from this page http://www.audienthusiasts.com/VagCom_FL_ADS.html).
5. I tried enabling Adress 1B in the gateway installation list. No dice.
Can the J792 be located in another spot because of RS designation?
Can this J792 function be delegated to another control unit in some configurations?
Maybe this car doesn't have Dynamic Steering, and this is a coding matter?
2. Secondary problem the J428 sensor/control unit is in Component Protection mode, i believe local Audi can code the module, matching it to the VIN of the car yes?
3. The fuse for the alarm system is missing, probably because of the broken glass sensor error. However the window is not broken. Bad wires perhaps.
2 &3 i will fix myself.
Now here's what you really came for :)
Saturday,13,July,2019,13:20:21:10970
VCDS Version: 19.6.1.0 (x64)
VIN: WUAZZZ8K9EAxxxxxx   License Plate:
Mileage: 114530km-71165miRS4nyefter   Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 22 36 42 44 46 47 52 53
          56 5C 5F 62 6C 6D 72
VIN: WUAZZZ8K9EAxxxxxx   Mileage: 114530km-71165miles
13-Auto Dist. Reg -- Status: Cannot be reached 1100
5C-Lane Maintain. -- Status: Malfunction 0010
Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
   Part No SW: 8T2 907 560     HW: 8T1 907 560
   Component: 4.2l V8HDZ /  H04 0003
   Revision: NAH04---
   Coding: 1225003225C6000A3000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM42FSI0118T2907560 001006
   ROD: EV_ECM42FSI0118T2907560.rod
   VCID: 79F9D5BCF8F38887DE-802C
4327 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:04
                    Engine speed: 0.00 /min
                    Coolant temperature: 19 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 11.850 V
                    AFS dm: 0.0 kg/h
                    Median injection timing: 0.000 ms
                    Engine operating condition-Channel 87: Idling
                    Relative load value: 59.77 %
                    Tumg: 20.3 °C
                    Psr w: 1006.02 hPa
                    Engine torque: 0.0 Nm
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:04
                    AFS dm: 0.0 kg/h
                    Tumg: 20.3 °C
                    Psr w: 1006.02 hPa
4729 - Steering Effort Control Module
          U0130 00 [039] - No Communications
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:04
                    CAN status - engine control module-Bits 0-7: 00000000
                    CAN status - transmission control module-Bits 0-7: 00000000
                    CAN status - brake control module 1-Bits 0-7: 00000000
                    CAN status - brake control module 2-Bits 0-7: 00000000
                    selected gear-Bits 0-7: 00000000
                    Cruise control switch actuation-Bits 0-7: 00000000
Readiness: 1110 1101
   Part No SW: 8K5 927 156     HW: 0B5 927 156 J
   Component: 0B5 42 FSIRdW H01 0005
   Revision: --H01---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001010
   ROD: EV_TCMDL501021.rod
   VCID: 76E3DE80C9EDE7FFB3-8022
   Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
   Component: ESP8 quattro  H09 0100
   Coding: 346D4A
   Shop #: WSC 45463 002 1048576
   VCID: 4581694CCC8B3C67EA-8010
   Part No SW: 8K0 907 064 GH    HW: 8K0 907 064 FH
   Component: BCM2 2.0      H11 0621
   Coding: 05824000000000000000
   VCID: 7CF7CCA8FFC1BDAFC5-8028
   Subsystem 1 - Part No SW: 4H0 959 754 DD    HW: 4H0 959 754 DD
   Component: FBSAUDID4 IDG  H71 0083
   Serial number: 0813000008566002
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01071120121443
   Coding: 4800000000
   VCID: 397915BCB07348879E-806C
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:03
                    Temperature: 25.0°C
                    Temperature: 19.0°C
                    Absolute Pres.: 1.0 bar
                    Current: 0.000 A
                    Temperature: 31.0°C
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000510001001
   Coding: 0600001000349FF0358140C3000019090F9CC70822090201000008004401030100000024000000
   VCID: 78FFD0B8CBF9918FA1-802C
   Component: WWS 091112  H07 0080
   Serial number: SWF12110095625
   Coding: 00FD11
   Serial number: 20718148
   Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002910120199
   Serial number: 29284856000000000001
03110 - Active Steering Control Module (J792)
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:04
Address 13: Auto Dist. Reg
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD96LUB%
   Coding: 30524435363030303030554A304C384B3053
   Shop #: WSC 37351 001 1048576
   VCID: 489F6078F399210F11-801C
   Serial number: 6334MSME720354723
   Serial number: 6344MSME720532261
   Serial number: 6352QSME5324216EE
   Serial number: 6362QSME4F224B64Q
   Serial number: 63732SME6D3A0868A
   Serial number: 63832SME4D3754621
12660736 - Steering Effort Control Module
          U0130 00 [009] - No Communications
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:04
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372LK2000L2
   Coding: 0000BF
   Shop #: WSC 21471 003 104857
   VCID: 44877448C7B1056FFD-8010
02795 - Steering Wheel Vibration Motor (V331)
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:03
   Part No SW: 8K0 920 931 G    HW: 8K0 920 931 G
   Component: KOMBIINSTR.   H35 0556
   Revision: 00000000    Serial number: UW32DCZAD
   Coding: 13EF1100CF010008010000
   Shop #: WSC 06325 123 12345
   VCID: 326B22906D05BBDF5F-8066
01319 - Control Module for Distance Control (J428)
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:05
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0055
   Revision: 1Z100027    Serial number: 2741Z12A18012A
   Coding: 80E3031600
   VCID: 4C975C68EFE1CD2F35-8018
   Serial number: 1247678501
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:04
                    Bin. Bits:    10111
                    Voltage: 11.80 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02019164747464545425363E00
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H13 0100
   Serial number: 002210120001153
   VCID: 2F6D2BE47637963730-807A
0308 - System Function Test
          C102A F0 [137] - Could not be Performed
                    Reset counter: 0
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:04
0059 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [137] - -
                    Reset counter: 0
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:04
0226 - Steering Effort Control Module
          U0130 00 [137] - No Communications
                    Reset counter: 0
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:04
0261 - No Basic Setting
          B2010 00 [137] - -
                    Reset counter: 0
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:04
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000042045438
   Coding: 00581B00000000000000
   VCID: 3B750FB4BA4F7A978C-806E
   Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000043737671
   Coding: 011C12205E00410001
   VCID: 4D91516C14FBC42722-8018
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0018980022
   Coding: 100001010001
   Shop #: WSC 06324 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 346724889F11B5EF4D-8060
   Revision: 00002001    Serial number: 0186298783
   Coding: 013A0E20A0B930958030023280000000
   Subsystem 1 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS150  H08 0043
   Subsystem 2 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J394 PS240  H08 0043
01403 - Glass-Break Sensors; Rear
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:03
03156 - Sensor for Anti-Theft System (G578)
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:07
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:07
   Revision: 00005001    Serial number: 94813007725702
   VCID: 2D5131EC743BE42702-8078
   Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000043543765
   Shop #: WSC 06342 000 00000
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 10000000122375
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 387F10B88379518F61-806C
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:04
                    Voltage terminal 30: 11.9 V
                    Internal Fault ID: 188
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Set
                    Status ParkingBrake right: Set
   Part No SW: 4G1 035 053 G    HW: 4G1 035 053
   Component: Radio U Basic H41 0121
   Revision: AB001007    Serial number: 227K+0C7660741
   Coding: 010003010000000001
   VCID: 2345D7D422FF2257A4-8076
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 600212B0600102
   Coding: 0022001
   VCID: 377D138446675EF768-8062
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:03
02797 - Control Module for Directional Stabilization Assistance (J759)
                    Fault Status: 01100101
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:03
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:03
   Part No SW: 8R1 035 666 B    HW: 8R1 035 666 C
   Component: H-BN-EU       H45 0639
   Revision: --------    Serial number: 205K%0C7556652
   Coding: 12010001030689EF6D80CB5E00000403E40000020000000000
   VCID: 377D138486675EF768-8062
   Subsystem 1 - Part No: 8R0 060 884 AR
   Component: ECE 2013  1505
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130K-0C2579226
   Subsystem 3 - Part No SW: 8T0 919 611 N    HW: 8T0 919 611 J
   Serial number: 00000001321212
   Component: CD-Database  4949
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.13
                    Time: 13:15:11
                    Bin. Bits: 00000000 00100000
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000043819431
   Coding: 010C12204000210001
   VCID: 46836E40F18D377FE3-8012
   Revision: --H07---    Serial number: 525PA8-J28947C
   Coding: 1020007
   VCID: 387F10B84B79518F61-806C
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8K9827851A
   VCID: 3C770CA8BF417DAF85-8068
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
   Component: J756  Slave  H52 0330
   Serial number: 8K9827852A
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000043817134
End-------------------------(Elapsed Time: 04:08)--------------------------
NostraJackAss
Hello OP nice first post and welcome to the VCDS forum!
Are you sure correct WSM?
Please provide a VIN number.
What did RTFB say & when searching WD for J792 or component locations?
JPPSG
vcds75
Denmark
C?ID=239025
Thank you!
WSM would be workshop manual? In that case yes, elsawin 4.0, and the correct car is selected. Everything match the car, engine, gearbox.
Why do you need the full VIN?
The last 6 digits are 900021.
Well Elsawin says it resides under the drivers seat, under the carpet. I had the entire side of the carpet of, and there is nothing but a coupling station for the seat.
This is not the manual i use, but the pages are the exact same: https://workshop-manuals.com/audi/a..._installing_active_steering_control_unitj792/
South Molton, UK
Is the car LHD or RHD? Sometimes Elsawin assumes LHD which means on a RHD car it could be under the passenger seat?
vcds75
Denmark
C?ID=239025
#Jack
Yes also very practical when you have to get to the unit. Remove seat, remove all kinds of trim, pry up the carpet, hold it with a piece of lumber. Yes! The manual says to use an appropriate piece of wood! :)
Which i did, and there was no unit and no signs of removal.
The J428 controller is a sensor and computer in one. Its located in the front bumper right side. This is the only visible problem on this car, someone tried to solder on yellow repair wires. I have never seen worse soldering in my life. Big blops of solder the size of peppercorns. Electrical tape to water "proof" it.
And a bad battery. I changed it.
Poor car...
#PetrolDave
LHD. And there is even RHD instructions too.
Edit:
And the cars runs fine, power steering works. Everything mechanical seems to work.
vcds75
Denmark
C?ID=239025
Pictures tomorrow, promise.
The unit is unharmed, it's just the wires.
Meanwhile, shoutout to anyone with knowledge on the PR-1N8/1N8 configuration.
According to the WSM both hydraulic and electromechanical power steering can be fitted. I think Dynamic Steering is only electromechanical but i am not sure.
My head is spinning now, i'm heading for bed.
vcds75
Denmark
C?ID=239025
Update time!
#Jack
Use the micro-what? :)
Here are the pictures of the bodged wire repair:
https://imgur.com/a/65fM4Tg
Now, today i fixed a part of the problem. I believe this car is NOT fitted with Dynamic Steering. In some control modules Dynamic Steering is checked, in others unchecked. In 09 Central, byte 08 bit 3 was set (see pictures), and clearly the car does not have magnetic ride suspension.
Conclusion, someone fucked the coding up, maybe in the Hidden Green Menu?
Unflagging byte 7 bit 4 was not enough for the 09 Central module to forget the J792, but when i also unflagged the byte 08 bit 1, AND enabled bit 4, 09 CECM is now error free.
I hoped this would fix all J792 errors, but apparently there are other control units calling for it.
06C Backup cam does not invoke J792 no communications, but in other forum posts i have seen this happen. More proof this is coding error.
https://imgur.com/a/6OHnRC9
Furthermore disabled byte 4 bit 5 in 17 Instrument, didn't seem to help.'
Also a bit in 44 Steering was unchecked called Dynamic Setting installed (PR-1N7/1N8). What is this supposed to be i wonder?
https://imgur.com/a/bElAcr4
vcds75
Denmark
C?ID=239025
And here is new autoscan:
Monday,15,July,2019,15:24:05:10970
Mileage: 114530km-71165miRS410   Repair Order:
VIN: WUAZZZ8K9EA900021   Mileage: 114530km-71165miles
   Revision: NAH04---
          U1113 00 [039] - -
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:08
                    Coolant temperature: 15 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 11.355 V
                    AFS dm: 0.0 kg/h
                    Relative load value: 60.61 %
                    Tumg: 19.5 °C
                    Psr w: 1003.59 hPa
          U0235 00 [039] - -
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:08
                    Voltage terminal 30: 11.379 V
                    AFS dm: 0.0 kg/h
                    Tumg: 19.5 °C
                    Psr w: 1003.59 hPa
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:08
   Revision: --H01---
   Coding: 346D4A
   Coding: 4800000000
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:07
                    Temperature: 19.0°C
                    Temperature: 15.0°C
                    Current: 0.000 A
                    Temperature: 22.0°C
   Coding: 0600001000349FE0358140C3000019090F9CC70822090201000008004401030100000024000000
   Coding: 00FD11
   Coding: 02005D
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:08
   Coding: 0000BF
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:07
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:08
   Coding: 80E3031600
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:08
                    Bin. Bits:    10111
                    Voltage: 11.40 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Revision: AA001002
                    Reset counter: 0
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:07
          U1017 00 [137] - -
                    Reset counter: 0
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:07
                    Reset counter: 0
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:07
          B2010 00 [137] - -
                    Reset counter: 0
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:07
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:07
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:11
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:11
          U1113 00 [009] - -
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:07
                    Voltage terminal 30: 11.5 V
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Coding: 0022001
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:06
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:07
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:07
                    Reset counter: 139
                    Mileage: 114534 km
                    Date: 2019.07.15
                    Time: 15:19:15
   Coding: 1020007
End-------------------------(Elapsed Time: 04:09)--------------------------
Larry Manton
C?ID=112505
Vcds75, yeah seen battery at 11.9 at idle so prudent you changed.
Not having wiring in front of me dont know if replaced wiring involve twisted pairs or can bus. Just saying cant just add on as you like in some circuits.
Good luck.
LARIMORE
