2018 Audi Q5 - SilverCar Scans and maps
DrPeter
16.4905° S, 151.7375° W
The following information is from a 2018 Q5 SilverCar
ref:
Vehicle Identification No. WA1ANAFY9J2192916
Model Audi Q5 qu. 2.0 AQ5
Date of production 25.05.2018
Model year 2018
Sales type FYB5NY
Engine Code DAYB
Transmission Code SUX
Axle drive 7A
Equipment YM
Roof color L5
Carpet color code
Exterior color / Paint Code L5 / Z7G
Auto-Scan before drive and what a surprise, full of fault codes.
Thursday,11,July,2019,06:50:06:30091
VCDS Version: 19.6.0.9 (x64)  HEX-V2 CB: 0.4507.4
VIN: WA1ANAFY9J2192916   License Plate: SILVERCAR-CLT
Mileage: 33714km-20948mi   Repair Order: drpeter
Chassis Type: FY-AU49 (8W6)
Scan: 01 02 03 08 09 15 16 17 19 22 29 36 39 42 44 46 52 5F 6C 6D
          81 A5 BB BC
VIN: WA1ANAFY9J2192916   Mileage: 33714km-20948miles
39-Right Light -- Status: Malfunction 0010
Address 01: Engine (J623-DAYB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 80A 906 259 A    HW: 06L 907 425 C
   Component: 2.0l R4 TFSI  H15 0003
   Revision: --H15---
   Coding: 2A6500122526012E74080000000000000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TFS02080A906259A 001004
   ROD: EV_ECM20TFS02080A906259A.rod
   VCID: 290CF7CCD97E7AFFBD4-807C
20634 - Oxygen (Lambda) Sensor B1 S2
          P0137 00 [032] - Signal too Low
20276 - Terminal 15 Voltage
          P151B 00 [032] - Implausible
19862 - Body Control Module (Central Electric 2)
          U0141 00 [032] - No Communications
23126 - Fuel Level Sensor Circuit
          P0461 00 [096] - Implausible Signal
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 80A 927 155 AJ    HW: 0CJ 927 156
   Component: 0CJ 20TFSINAR H05 0001
   Revision: --H05---    Serial number: 0000000009
   ASAM Dataset: EV_TCMDL382021 002027
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 71BCDFAC312E423F354-8024
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041180074000747
20918 - System Voltage
          P0562 00 [032] - Too Low
21026 - Body Control Module (Central Electric 2)
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 80A 907 379 J    HW: 80A 907 379
   Component: ESP9 Plus     H11 0775
   Coding: 4CAA40BE28AB0A9891A7489220834292E53592320214508912044249A7AC49
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 36362CB018C02507206-8062
11 Faults Found:
475904 - Databus
          U1121 00 [032] - Missing Message
          [ComScl:_PDU_Licht_hinten_01-_Timeout_error]
15385344 - Databus
          U1122 00 [032] - Implausible Message
          [ComScl:_Signal_Group_SG_Klemmen_Status_01-_Checksum_error]
277248 - Databus
          [ComScl:_Signal_Group_SG_Klemmen_Status_01-_Timeout_error]
352772 - System Voltage
352771 - Supply voltage
          U1011 00 [032] - Voltage too Low
          [ESC_undervoltage_replacement_fault_for_non_OBD_relevant_undervoltage_faults]
494080 - Comfort Control Module
          C1254 F0 [032] - Brake Light Signal Implausible
143360 - Function Restricted due to Insufficient Voltage
          U1400 00 [032] - -
          [Undervoltage_dectected_in_network]
420352 - TPMS Warning; Front Left Tire
          C1054 00 [032] - Pressure too Low
416768 - TPMS Warning; Front Right Tire
          C1056 00 [032] - Pressure too Low
420096 - TPMS Warning; Rear Left Tire
          C1058 00 [032] - Pressure too Low
417024 - TPMS Warning; Rear Right Tire
          C105A 00 [032] - Pressure too Low
   Part No SW: 80A 820 043 K    HW: 80A 820 043 K
   Component: Klima Zone 3  H60 0210
   Coding: 640801095544000D10000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 2514FBFCB5665E9F99C-8070
   Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002259995
   Serial number: 77229E1900PAG0MUFU02
   Subsystem 3 - Part No SW: 80A 919 158     HW: 80A 919 158
   Component: E265 Kli Fond  H40 0080
459015 - Databus
                    Reset counter: 215
                    Mileage: 23360 km
                    Date: 2019.03.06
                    Time: 14:25:40
   Part No SW: 8W0 907 063 CE    HW: 8W0 907 063 BE
   Component: BCM1 MLBevo   H13 0267
   Coding: C2500362C0081CCD051587149CAE98B9100B3D08000000000000000000001A0001610002001204
   VCID: 005A8A680A845BB7CAA-8054
   Subsystem 1 - Part No SW: 80B 955 119     HW: 80B 955 119
   Component: 426 LL 180420  040 0570
   Serial number: 00000001804202274913
   Coding: 5FC7F7
   Serial number: 21326417X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
   Component: E1 - LDS  H06 0008
   Serial number: 17 05 2018  81370485
   Subsystem 4 - Part No SW: 4N0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600350Z00R202
   Coding: 350000
   Garage Door Opener Operating Unit:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20180510212516 01292
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE103051823511263
   Coding: 030000
   Interior Light Module:
   Subsystem 7 - Part No SW: 80A 947 135 Q    HW: 80A 947 135
   Component: Dachmodul Q5  H31 0310
   Serial number: Q00001767
   Coding: 0D0104
   Subsystem 8 - Part No SW: 8W0 925 301 BA    HW: 8W0 925 301 BA
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2818000072650003
   Part No SW: 80A 959 655 L    HW: 80A 959 655 L
   Component: AirbagVW30    023 0513
   Serial number: 003W1M02HRHZ
   Coding: AECCFCC000800000A000003FF20C40000065
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
   ROD: EV_AirbaVW31SMEAU65x_AU49.rod
   VCID: 3C223E9826ECFF57D62-8068
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2033
   Serial number: 80A857705H0069S01556
   Coding: 80000D
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2033
   Serial number: 80A857706H0081S00429
   Coding: 80000D
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J1800094FOK0H
   Coding: 303033
   Subsystem 4 - Part No SW: -----------    HW: 480 001 903 18
   Serial number: 35700000000D1C64AC2W
   Subsystem 5 - Part No SW: -----------    HW: 480 001 603 18
   Serial number: 358000000004C0DC0C2S
   Subsystem 6 - Part No SW: -----------    HW: 480 030 304 18
   Serial number: 351001C0C73AB4B14BBL
   Subsystem 7 - Part No SW: -----------    HW: 480 030 304 18
   Serial number: 352001C0CB42B9E0887N
   Subsystem 8 - Part No SW: -----------    HW: 480 030 504 18
   Serial number: 355001C103088620CC3
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 030 504 18
   Serial number: 356001C103088CE158EF
   Central Sensor XY:
   Subsystem 10 - Part No SW: -----------    HW: 480 021 603 18
   Component: CentrSensorXY  000 0108
   Serial number: I0O0001C3286E2F307F1
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 80A 907 129 BR    HW: 80A 907 129 BR
   Component: Lenks.Modul   H02 0005
   VCID: 79ACE78C695E0A7F8D4-802C
   Part No SW: 8W5 920 890 D    HW: 8W5 920 890 D
   Component: FBenUSA       H18 0373
   Coding: 09E68EC5A080CF050203E9601800000008000000
   VCID: 44D246785E1C8797AE2-8010
   Part No SW: 8W6 907 468 F    HW: 8W6 907 468 E
   Component: Gateway       H43 0123
   Revision: 7B000002    Serial number: 0287B835418410
   Coding: 030100010000064029070000005900324C3A0007100000000175078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003111
   VCID: 4DC4635C8D5646DF71C-8018
   Subsystem 1 - Part No SW: 80A 951 523 D    HW: 80A 951 523 D
   Component: J453 MFL  H06 0004
   Serial number: 20180514150845 00853
   Serial number: 7083305800
9457922 - Backup Battery
          B1916 F1 [008] - Not Recognized
                    Mileage: 20349 km
                    Date: 2019.01.31
                    Time: 01:47:56
                    H-V activ. restriction-Airbag control module: not active
                    H-V activ. restriction-Thermal management: not active
                    H-V activ. restriction-Engine Electronics: not active
                    H-V activ. restriction-Transformer for electrical drive: not active
                    H-V activ. restriction-Hybrid Battery Management: not active
                    H-V activ. restriction-Ctrl. mod. for contactless charging: not active
                    H-V activ. restriction-High-voltage battery charger: not active
                    H-V activ. restriction-HV activation prohibited due to accident: not active
                    H-V activ. restriction-HV activation prohibited due to de-activation: not active
                    H-V activ. restriction-HV activation prohibited due to blocking: not active
                    H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 1: not active
                    H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 2: not active
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Electric_current_Upper_Limit_Value_Exceeded]
                    Reset counter: 107
                    Mileage: 30478 km
                    Date: 2019.06.02
                    Time: 05:04:42
                    Total static current-current total quiescent current: 98 mA
                    Total static current-Total time quiescent current exceeded: 1.0 H
                    EM_vehicle_state: 00 00
Address 22: AWD (J492)       Labels:* None
   Part No SW: 80A 927 755     HW: 0CJ 927 749 A
   Component: Q5_DL3_N_SD4  H01 0004
   Serial number: 18059A1881
   Coding: 11070000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
   VCID: 6C82CED8160CAFD7062-8038
29776 - Function Restricted due to Excessive Voltage
          U1401 00 [032] - -
          [Function restrictiondue to excessive voltage]
30032 - Terminal 15
          U1405 00 [032] - Implausible signal
          [Terminal 15Implausible signal]
33190 - Body Control Module (Central Electric 2)
33483 - Function Restricted due to Insufficient Voltage
          U1400 00 [032] - -
          [Function restrictiondue to insufficient voltage]
Address 29: Left Light (J1018)       Labels: None
   Part No SW: 80A 907 397 A    HW: 80A 907 397 A
   Component: LCM_MLBevo    H07 0022
   VCID: 2D0403DCED9666DF51C-8078
   Part No SW: 4M1 959 760     HW: 4M1 959 760
   Component: MEM-FS        008 0031
   Serial number: 11A14811702134
   Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
   VCID: 76B6ECB058406507E06-8022
Address 39: Right Light (J1023)       Labels: None
0304 - Bulb for Turn Signal
          C11A4 15 [008] - Open or Short to Plus
                    Reset counter: 121
                    Mileage: 31965 km
                    Date: 2019.07.02
                    Time: 11:54:04
   Part No SW: 8W1 959 593     HW: 8W1 959 593
   Component: TSG FS001 0737
   Serial number: CLSM1RE400E4P
   Coding: 001F0B005E00148000010002
   VCID: 084A924822B463F782A-805C
196882 - Function Lighting for Interior Monitoring
          B1782 01 [008] - Electrical Failure
                    Reset counter: 129
                    Mileage: 30288 km
                    Date: 2019.06.01
                    Time: 14:55:21
196873 - Function Lighting for Child Safety
          B1779 01 [008] - Electrical Failure
                    Reset counter: 129
                    Mileage: 30288 km
                    Date: 2019.06.01
                    Time: 14:55:40
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H22 0005
   Serial number: 0000593704
   Coding: 90002001000100
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 343216B80EBC37171E2-8060
   Part No SW: 4N0 907 064 AP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H14 0128
   Coding: 013400004FB100C0650BA0000C01980233004000810026502F0000000F04803F001E0001000000
   ASAM Dataset: EV_BCM2CONTIAU651 007005
   ROD: EV_BCM2CONTIAU651_007_AU49.rod
   VCID: 7DA4F39C7D76365FA1C-8028
   Ignition key:
   Serial number: 000000000ZY180084F51
   Serial number: 00000000000099755689
   Subsystem 4 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58403568
   Rear Spoiler Adjustment:
131086 - Antenna for Keyless Entry System; Interior Antenna 1
          B1172 13 [008] - Open Circuit
                    Fault Frequency: 26
                    Reset counter: 106
                    Mileage: 11131 km
                    Supply voltages-Supply voltage: Terminal 30: 12.569 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.562 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.478 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 02 00
                    antenna_freeze_frame: 00011001 00000000 00000000 01011100
   Part No SW: 8W1 959 592     HW: 8W1 959 592
   Component: TSG BFS001 0737
   Serial number: CLSM1REF008D5
   Coding: 001F0B005E00148000010000
   VCID: 074891742FAA6C8F8B0-8052
196886 - Function Lighting for Seat Memory LED
          B1790 01 [008] - Electrical Failure
                    Reset counter: 129
                    Mileage: 26992 km
                    Date: 2019.03.28
                    Time: 14:47:15
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 880 D    HW: 8W5 035 880
   Component: MU-P-LNS-US   034 1320
   Serial number: A798E0J9002041
   Coding: 01240602FF0A000053220001041A00102F0015E501700904FE
   VCID: 40DA4A684A049BB78AA-8014
   Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
   Component: AU426_DU_HIGH  H42 0008
   Serial number: AUZ8Z9JBL04DKY
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
   Component: ControlUnit_P  H15 0209
   Serial number: 29031800000000000487
   Compact Disc Database:
   Component: Gracenote2  --- 3012
   Component: RVC Compact   H12 0250
   Coding: 0224060100002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: 333015A40BB2302F078-8066
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: A2-C748-5750-5
   Coding: 0730
   VCID: 48CA52486234A3F742A-801C
   Part No SW: 80B 713 041 G    HW: 80B 713 041 G
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 20180428000662
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 211CEFECA14EB2BFE54-8074
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217 A    HW: 80A 907 217 A
   Component: BVS           H16 0050
   Coding: 0404020600000201022023A0810000FE00F0C010C000
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 2412E6F8BE5CA7978E2-8070
1122624 - Databus
          [TIMEOUT_Licht_hinten_01]
                    Mileage: 23360 km
                    Date: 2019.03.06
                    Time: 14:25:40
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 15.10 V
1123986 - Dynamic Calibration
          C1106 F1 [008] - Function Restriction due to Limitation Exceeded
          [Online_calibration_safe-state_active]
                    Reset counter: 120
                    Mileage: 32656 km
                    Date: 2019.07.07
                    Time: 13:01:41
                    Control Module temperature: 56 °C
                    Voltage terminal 15: 14.20 V
   Part No SW: 8W1 959 595     HW: 8W1 959 595
   Component: TSG HFS001 0737
   Serial number: CLSM1RE800OD0
   Coding: 000F0B000000148040000000
   VCID: 0A4EA8403CB811E794E-805E
   Component: TSG HBFS001 0737
   Serial number: CLSM1RE800OCU
End----------(Elapsed Time: 02:06, VBatt start/end: 13.1V/13.1V)-----------
Maps..................
blockmap-17-8W5-920-890-D
;SW:8W5-920-890-D   HW:8W5-920-890-D ---  Instruments
;Component:FBenUSA       H18 0373, Coding:09E68EC5A080CF050203E9601800000008000000
;EV_DashBoardAU736,001027,EV_DashBoardAU736_AU49.rod
;Friday,12,July,2019,15:54:31:64285
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: C4CB4F504F60426F7D-8090
Group,Description,Actual
IDE00019,Voltage terminal 30,14.30, V
IDE00021,Engine speed,801, /min
IDE00025,Coolant temperature,90.00, °C
IDE00196,Engine oil temperature,89, °C
IDE00301,Distance,34677, km
IDE00310,Outside air temperature,29.00, °C
IDE00316-IDE00500,Time-Hour,15, H
IDE00316-IDE00501,Time-Minute,54, min
IDE00316-MAS00111,Time-Seconds,28, s
IDE00317-IDE00502,Date-Year,2019, yr
IDE00317-IDE00503,Date-Month,7, mon
IDE00317-IDE00504,Date-Day,12, d
IDE00510,ESI: distance driven from inspection,1800, km
IDE00511,ESI: time from inspection,4, d
IDE00512,ESI: minimum value km-driving distance/inspection,14500, km
IDE00513,ESI: maximum value km-driving distance/inspection,14500, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,poor oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,2700, km
IDE00520,Phototransistor,209,
IDE00695,ESI: service exceedance in km,Not available,
IDE00696,ESI: service exceedance in days,Not available,
IDE00697,ESI: remaining distance,14120, km
IDE00698,ESI: remaining running time,361, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,397, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00845-MAS03213,Wheel circ.-Average wheel circumference for trip distance,2251, mm
IDE00845-MAS03214,Wheel circ.-Maximum wheel circumference for speed,2295, mm
IDE00935,ESI: Theoretical service interval,20100, km
IDE01076,Time since ignition off,904, s
IDE01153,SIA: maximum value of distance to service,16000, km
IDE01154,SIA: maximum value of time to service,365, d
IDE01985-ENG101043,FAZIT identification test sum-Checksum,A0 26 E7 9F,
IDE01985-ENG99027,FAZIT identification test sum-Version,81,
IDE02642,Outside temp.: displayed value,25.00, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,D4,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,0A,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,207,
IDE03349,FIX: Max. distance until next mileage-related inspection,32032, km
IDE03350,FIX: Maximum time until next time-dependent inspection,730, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,17500, km
IDE03352,FIX: Time since last time-dependent inspection,191, d
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Dampening Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire pressure monitoring display,Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring,Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assistant,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Lock Electronics,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer positioning assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-ENG126401,Vehicle configuration-intelligent_park_assist,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,15.20, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,70.00, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,73.80, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,16.40, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,53.70, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,70.00, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,70.90, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,53.40, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,6.10, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,70.00, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,75.40, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,7.00, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,55.30, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,70.00, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,73.90, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,57.90, l
IDE03472-MAS03822,Volume after refueling-Last error status,00,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,00,
IDE03472-MAS03824,Volume after refueling-Third-last error status,00,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,00,
IDE03472-MAS06153,Volume after refueling-Last distance,34340, km
IDE03472-MAS06154,Volume after refueling-Penultimate distance,33690, km
IDE03472-MAS06155,Volume after refueling-Third to last distance,33500, km
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,32770, km
IDE03474-IDE00304,Calculated volume-Fuel level,38.60, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,61, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,253, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,not_available,
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,not_available,
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,41.00, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.70, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,not_available,
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,not_available,
IDE03474-IDE00802,Calculated volume-Full volume,70.00, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,10,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,41.90, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,0.70, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,not_available,
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,not_available,
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.00,
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.00,
IDE03474-ENG102894,Calculated volume-averaged_volume,41.70, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,41.70, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,41.70, l
IDE03474-ENG126318,Calculated volume-gas_based_linking,1.00,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.00, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,0.78, m/s
IDE03474-ENG101623,Calculated volume-reference_volume,37.60, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.00,
IDE03474-ENG99683,Calculated volume-version_of_application,42,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0008316,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03475-MAS12387,Control button in instrument cluster-Button for daily distance driven,not active,
IDE03477-IDE00500,GPS time-Hour,15, H
IDE03477-IDE00501,GPS time-Minute,46, min
IDE03477-IDE00501,GPS time-Minute,54, min
IDE03477-IDE00502,GPS time-Year,2019, yr
IDE03477-IDE00503,GPS time-Month,7, mon
IDE03477-IDE00504,GPS time-Day,12, d
IDE03477-MAS00111,GPS time-Seconds,34, s
IDE03477-MAS00111,GPS time-Seconds,20, s
IDE03477-MAS03493,GPS time-last synchronization year,2019, yr
IDE03506,Distance: high resolution,02 11 23 22,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,17,
IDE03880-MAS03425,MOST address-Physical address,04 01,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 31,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 0B,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 0B,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 31,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,6F F0 00 31,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,2F F0 00 0B,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,3F F0 3E 8B,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,0F F0 42 BB,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,4F F0 00 CE,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,8F F0 42 BB,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,CF F0 00 CE,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,2F F0 80 18,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,6F F0 01 89,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
IDE04649-ENG128738,Activation for housing fan-PWM_FAN,0, %
IDE04649-ENG128737,Activation for housing fan-source_max_PWM_requested,none,
IDE04649-ENG98933,Activation for housing fan-Status,OFF,
IDE04649-ENG128733,Activation for housing fan-temperature_Boost,56, °C
IDE04649-ENG128734,Activation for housing fan-temperature_chipled,81, °C
IDE04649-ENG128736,Activation for housing fan-temperature_GPU,59, °C
IDE04649-ENG128735,Activation for housing fan-temperature_KI,56, °C
IDE05931,FIX: Reset value for next mileage-dependent inspection,30000, km
IDE05932,FIX: Reset value for next time-dependent inspections,1095, d
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-IDE06026,Roller test bench mode: functional-Adaptation of brake pedal path sensor,not activated,
IDE06924,Performance display,0,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE07159-MAS01155,Control module switch-off: counter-Control module,0, min
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0, min
IDE07578-MAS00138,Operating range consumption with electric drive-1,0.00,
IDE07578-MAS00139,Operating range consumption with electric drive-2,65534,
IDE07578-ENG04221,Operating range consumption with electric drive-ERW_Energieinhalt,0.00,
IDE07578-ENG114651,Operating range consumption with electric drive-s_erw_rw_batterie,65534, km
IDE07578-ENG114652,Operating range consumption with electric drive-s_erw_rw_batterie_anz,65534, km
IDE07578-ENG114648,Operating range consumption with electric drive-s_erw_rwds,0.00, A
IDE07578-ENG114640,Operating range consumption with electric drive-s_erw_rwds_high,10.00, A
IDE07578-ENG114644,Operating range consumption with electric drive-s_erw_rwds_low,10.00, A
IDE07578-ENG114637,Operating range consumption with electric drive-s_erw_rwdv_antrieb_high_unclass,2.50, kWh/100 km
IDE07578-ENG114641,Operating range consumption with electric drive-s_erw_rwdv_antrieb_low_unclass,25.00,
IDE07578-ENG114645,Operating range consumption with electric drive-s_erw_rwdv_antrieb_unclass,0.00,
IDE07578-ENG114638,Operating range consumption with electric drive-s_erw_rwdv_dcdc_high_unclass,0.20, kWh/100 km
IDE07578-ENG114642,Operating range consumption with electric drive-s_erw_rwdv_dcdc_low_unclass,0.20,
IDE07578-ENG114646,Operating range consumption with electric drive-s_erw_rwdv_dcdc_unclass,0.00,
IDE07578-ENG114639,Operating range consumption with electric drive-s_erw_rwdv_tme_high_unclass,0.50,
IDE07578-ENG114643,Operating range consumption with electric drive-s_erw_rwdv_tme_low_unclass,0.50,
IDE07578-ENG114647,Operating range consumption with electric drive-s_erw_rwdv_tme_unclass,0.00,
IDE07578-ENG114649,Operating range consumption with electric drive-s_erw_rwdv_unclass,0.00,
IDE07646-ENG114675,Consumption for road-specif. range with electric drive-s_erw_endsteigung,0.00, %
IDE07646-ENG114667,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_0,0.00, kWh/100 km
IDE07646-ENG114668,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_1,0.00, kWh/100 km
IDE07646-ENG114669,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_2,0.00, kWh/100 km
IDE07646-ENG114670,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_3,0.00, kWh/100 km
IDE07646-ENG114671,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_4,0.00, kWh/100 km
IDE07646-ENG114672,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_5,0.00, kWh/100 km
IDE07646-ENG114673,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_6,0.00, kWh/100 km
IDE07646-ENG114653,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_0,25.00, kWh/100 km
IDE07646-ENG114654,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_1,25.00, kWh/100 km
IDE07646-ENG114655,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_2,25.00, kWh/100 km
IDE07646-ENG114656,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_3,25.00, kWh/100 km
IDE07646-ENG114657,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_4,25.00, kWh/100 km
IDE07646-ENG114658,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_5,25.00, kWh/100 km
IDE07646-ENG114659,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_6,25.00, kWh/100 km
IDE07646-ENG04222,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_low_class,25.00, kWh/100 km
IDE07646-ENG114674,Consumption for road-specif. range with electric drive-s_erw_str_klasse,0,
IDE08343,Immobilizer Challenge,CD BD 22 25,
IDE08701-MAS07266,ESI: Status-Oil change: unit of dist. travelled,miles,
IDE08701-MAS07267,ESI: Status-Oil change: dist. travelled,8800,
IDE08701-MAS07268,ESI: Status-Oil change: stat. of dist. travelled,Service in,
IDE08701-MAS07269,ESI: Status-Oil change: stat. of time,Service in,
IDE08701-MAS07270,ESI: Status-Inspection: stat. of dist. travelled,Service in,
IDE08701-MAS07271,ESI: Status-Inspection: unit of dist. travelled,miles,
IDE08701-MAS07272,ESI: Status-Inspection: dist. travelled,9100,
IDE08701-MAS07273,ESI: Status-Inspection: time,539,
IDE08701-MAS07274,ESI: Status-Oil change warning,no warning,
IDE08701-MAS07277,ESI: Status-Inspections warning,no warning,
IDE08701-MAS07305,ESI: Status-Oil change: time,361,
IDE08701-MAS07308,ESI: Status-Inspection: status time,Service in,
IDE08701-MAS10768,ESI: Status-Daily mileage,84,
IDE08775-MAS01390,Active driver info.-Block 1,DF 00 A4 44,
IDE08775-MAS01391,Active driver info.-Block 2,00 00 00 00,
IDE08775-MAS01392,Active driver info.-Block 3,00 00 00 00,
IDE08775-MAS01393,Active driver info.-Block 4,00 00 00 00,
IDE08775-MAS01394,Active driver info.-Block 5,00 00 00 00,
IDE08775-MAS01395,Active driver info.-Block 6,00 00 00 00,
IDE08775-MAS01396,Active driver info.-Block 7,00 00 00 00,
IDE08775-MAS01397,Active driver info.-Block 8,00 00 00 00,
IDE08775-MAS01398,Active driver info.-Block 9,00 00 00 00,
IDE08775-MAS01399,Active driver info.-Block 10,00 00 00 00,
IDE08775-MAS01400,Active driver info.-Block 11,00 00 00 00,
IDE08775-MAS01401,Active driver info.-Block 12,00 00 00 00,
IDE08775-MAS01402,Active driver info.-Block 13,00 00 00 00,
IDE08775-MAS01403,Active driver info.-Block 14,00 00 00 00,
IDE08775-MAS01404,Active driver info.-Block 15,00 00 00 00,
IDE08775-MAS01405,Active driver info.-Block 16,00 00 00 00,
IDE08775-MAS01406,Active driver info.-Block 17,00 00 00 00,
IDE08775-MAS01407,Active driver info.-Block 18,00 00 00 00,
IDE08775-MAS01408,Active driver info.-Block 19,00 00 00 00,
IDE08775-MAS01409,Active driver info.-Block 20,00 00 00 00,
IDE08776-MAS01390,Key-relevant driver information-Block 1,A4 44 00 00,
IDE08776-MAS01391,Key-relevant driver information-Block 2,00 00 00 00,
IDE08776-MAS01392,Key-relevant driver information-Block 3,00 00 00 00,
IDE08776-MAS01393,Key-relevant driver information-Block 4,00 00 00 00,
IDE08776-MAS01394,Key-relevant driver information-Block 5,00 00 00 00,
IDE08776-MAS01395,Key-relevant driver information-Block 6,00 00 00 00,
IDE08776-MAS01396,Key-relevant driver information-Block 7,00 00 00 00,
IDE08776-MAS01397,Key-relevant driver information-Block 8,00 00 00 00,
IDE08776-MAS01398,Key-relevant driver information-Block 9,00 00 00 00,
IDE08776-MAS01399,Key-relevant driver information-Block 10,00 00 00 00,
IDE08777-MAS00106,History memory: driver info.-Year,2019,
IDE08777-MAS00107,History memory: driver info.-Month,7,
IDE08777-MAS00108,History memory: driver info.-Day,12,
IDE08777-MAS00109,History memory: driver info.-Hours,15,
IDE08777-MAS00110,History memory: driver info.-Minutes,46,
IDE08777-MAS00111,History memory: driver info.-Seconds,13,
IDE08777-MAS01390,History memory: driver info.-Block 1,A2 1F,
IDE10117-MAS11870,Uncalibrated volume including fuel gauge sending unit offset-uncalibrated volume including offset sensor 1,41.00, l
IDE10117-MAS11871,Uncalibrated volume including fuel gauge sending unit offset-uncalibrated volume including offset sensor 2,0.80, l
IDE10117-MAS11872,Uncalibrated volume including fuel gauge sending unit offset-uncalibrated volume including offset sensor 3,not_available,
IDE10117-MAS11873,Uncalibrated volume including fuel gauge sending unit offset-uncalibrated volume including offset sensor 4,not_available,
IDE10347-ENG118215,Trip distance challenge-Challenge,32 00 00 00 00 87 35 47 7E 00 17 01 00 00 00 57 41 31 41 4E 41 46 59 39 4A 32 31 39 32 39 31 36 2B 54 5F 3C B7 88 CF F4 00 00,
IDE10348-ENG98502,Trip distance data-Data,32 00 00 00 00 00 00 00 00 00 17 01 00 00 00 57 41 31 41 4E 41 46 59 39 4A 32 31 39 32 39 31 36 B7 9B 7E 0F F2 55 E2 90 00 14 00 03 00 75 87 00 82 87 00 00 00 00 00 00 00 00 00 00 00 00,
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG126262-ENG114675,Consumption_for_distance_on_map-s_erw_endsteigung,0.00, %
ENG126262-ENG114674,Consumption_for_distance_on_map-s_erw_str_klasse,0,
ENG126262-ENG128739,Consumption_for_distance_on_map-s_vkmrw_rwdv_antrieb_low_class,6.90, l/100km
ENG126262-ENG126309,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_0,7.50, l/100km
ENG126262-ENG126310,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_1,9.70, l/100km
ENG126262-ENG126311,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_2,9.70, l/100km
ENG126262-ENG126312,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_3,9.70, l/100km
ENG126262-ENG126313,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_4,9.70, l/100km
ENG126262-ENG126314,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_5,9.70, l/100km
ENG126262-ENG126315,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_6,9.70, l/100km
ENG126262-ENG126302,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_0,7.60, l/100km
ENG126262-ENG126303,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_1,10.00, l/100km
ENG126262-ENG126304,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_2,10.00, l/100km
ENG126262-ENG126305,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_3,10.00, l/100km
ENG126262-ENG126306,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_4,10.00, l/100km
ENG126262-ENG126307,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_5,10.00, l/100km
ENG126262-ENG126308,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_6,10.00, l/100km
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,88, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,80, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,75, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,75, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,75, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,not active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,84, km
ENG107920-ENG98868,onboard_computer-Range,478, km
ENG107920-ENG119788,onboard_computer-range_average_consumption,7.40, l/100km
ENG107920-ENG126296,onboard_computer-range_average_consumption_cng,0.00, kg/100 km
ENG107920-ENG126292,onboard_computer-range_average_consumption_cng_high,0.00, kg/100 km
ENG107920-ENG126294,onboard_computer-range_average_consumption_cng_low,0.00, kg/100 km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,7.50, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,6.70, l/100km
ENG107920-ENG126297,onboard_computer-range_average_consumption_lpg,0.00, kg/100 km
ENG107920-ENG126293,onboard_computer-range_average_consumption_lpg_high,0.00, kg/100 km
ENG107920-ENG126295,onboard_computer-range_average_consumption_lpg_low,0.00, kg/100 km
ENG107920-ENG126298,onboard_computer-range_cng,65534, km
ENG107920-ENG126300,onboard_computer-range_cng_display_value,65534, km
ENG107920-ENG119791,onboard_computer-range_display_value,478, km
ENG107920-ENG126299,onboard_computer-range_lpg,65534, km
ENG107920-ENG126301,onboard_computer-range_lpg_display_value,65534, km
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,150,
ENG109340-ENG104056,tank_validation-s_vali_abs_active,not active,
ENG109340-ENG102652,tank_validation-s_vali_abs_display_0,not active,
ENG109340-ENG102994,tank_validation-s_vali_abs_distance/mileage,not active,
ENG109340-ENG101149,tank_validation-s_vali_abs_rough,not active,
ENG109340-ENG101740,tank_validation-s_vali_active,not active,
ENG109340-ENG101355,tank_validation-s_vali_consumption_deq,3276.80, l
ENG109340-ENG100596,tank_validation-s_vali_consumption_deq_abs,3276.80, l
ENG109340-ENG102770,tank_validation-s_vali_display_0,not active,
ENG109340-ENG99133,tank_validation-s_vali_needle_vol_ref,not active,
ENG109340-ENG99562,tank_validation-s_vali_rough,not active,
ENG109340-ENG100160,tank_validation-s_vali_status,2, l
ENG109340-ENG103691,tank_validation-s_vali_vol_delta_gef,3276.80, l
ENG109340-ENG100615,tank_validation-s_vali_vol_delta_roh,3280.30, l
ENG109340-ENG99506,tank_validation-s_vali_vol_g1_vg,3317.80, l
ENG109340-ENG103928,tank_validation-s_vali_vol_g2_vg,3277.50, l
ENG109340-ENG101476,tank_validation-s_vali_vol_g3_vg,3276.80, l
ENG109340-ENG101237,tank_validation-s_vali_vol_g4_vg,3276.80, l
ENG109340-ENG101103,tank_validation-s_vali_vol_ref_gew,3315.00, l
ENG109340-ENG100543,tank_validation-s_vali_vol_ref_vg,3323.20, l
ENG109340-ENG100079,tank_validation-s_vali_vol_total_vg,3318.50, l
Elapsed Time: 00:24
adpmap-17-8W5-920-890-D
;Friday,12,July,2019,15:54:55:64285
IDE00301-Distance,34677 km,3
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,US English ,1
IDE00500-Hour,15 H,1
IDE00501-Minute,54 min,1
IDE00502-Year,2019 yr,2
IDE00503-Month,7 mon,1
IDE00504-Day,12 d,1
IDE00510-ESI: distance driven from inspection,1800 km,3
IDE00511-ESI: time from inspection,4 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,14500 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,14500 km,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00518-ESI: thermal load,2700 km,2
IDE00819-Day counter,397 d,2
IDE01153-SIA: maximum value of distance to service,16000 km,2
IDE02489-Display depiction,Version 1 ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,0.00 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-0.90 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,0.00 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.70 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.70 l,5
IDE03329-Driving profiled for range remaining,7.50 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,miles ,3
IDE03346-MAS01230-Units adjusted-Date,mm_dd_yy ,3
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature,°F ,3
IDE03346-MAS03032-Units adjusted-Volume,gallons (US) ,3
IDE03346-MAS03034-Units adjusted-Pressure,psi ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,3
IDE03348-MAS01456-Speed warning-Speed,0 ,2
IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,32032 km,3
IDE03351-FIX: Distance covered since last mileage-dependent inspection,17500 km,3
IDE03352-FIX: Time since last time-dependent inspection,191 d,2
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,1095 d,2
IDE06588-Ignition active message: actuator,Driver door ,1
IDE07221-Cylinder shut-off,No display ,1
IDE07579-MAS05872-Driving profile for operating range consump.with electric drive-Operating range average voltage,10.00 A,8
IDE07579-MAS05875-Driving profile for operating range consump.with electric drive-Average consumption: electric drive,25 ,8
IDE07579-MAS05876-Driving profile for operating range consump.with electric drive-Average consumption: low voltage auxiliary consumer,0.20 ,8
IDE07579-MAS05877-Driving profile for operating range consump.with electric drive-Average consumption: high voltage auxiliary consumer,0.50 ,8
IDE07600-ENG114653-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_0,25.00 ,14
IDE07600-ENG114654-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_1,25.00 ,14
IDE07600-ENG114655-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_2,25.00 ,14
IDE07600-ENG114656-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_3,25.00 ,14
IDE07600-ENG114657-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_4,25.00 ,14
IDE07600-ENG114658-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_5,25.00 ,14
IDE07600-ENG114659-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_6,25.00 ,14
IDE08140-Driving profiled for range remaining CNG,0.00 kg/100 km,2
IDE08247-Driving profile for range remaining LPG,0.00 l/100km,2
IDE10208-Display correct. of consump. and operating range: elec.,100 %,1
IDE10694-ENG126302-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_0,7.60 l/100km,14
IDE10694-ENG126303-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_1,10.00 l/100km,14
IDE10694-ENG126304-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_2,10.00 l/100km,14
IDE10694-ENG126305-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_3,10.00 l/100km,14
IDE10694-ENG126306-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_4,10.00 l/100km,14
IDE10694-ENG126307-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_5,10.00 l/100km,14
IDE10694-ENG126308-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_6,10.00 l/100km,14
IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,No display ,4
IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
IDE11472-MAS12789-Configuration of displayable contents-Display: engine running required,No display ,4
IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,No display ,4
IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,No display ,4
IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Standard ,4
IDE12050-Acoustic: drive position R,active ,1
MAS03555-Lap counter,No display ,1
MAS03685-Digital speedometer,Display ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,21
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,21
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,21
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,21
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,21
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,21
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,21
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,500ms ,21
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,50ms ,21
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,50ms ,21
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,21
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,21
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,21
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,21
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,100ms ,21
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,21
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,21
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,21
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,21
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,21
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,21
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,21
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,21
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,21
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,21
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,21
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,21
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,21
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,21
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,21
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,21
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,21
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,21
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,21
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,21
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,500ms ,21
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,500ms ,21
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,21
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,100ms ,21
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,100ms ,21
ENG128731-MAS01129-designvariant_activation-Version 1,not active ,2
ENG128731-MAS01130-designvariant_activation-Version 2,not active ,2
ENG128731-MAS01131-designvariant_activation-Version 3,not active ,2
ENG128731-MAS03101-designvariant_activation-Version 4,not active ,2
ENG128731-MAS03102-designvariant_activation-Version 5,not active ,2
ENG128731-MAS03103-designvariant_activation-Version 6,not active ,2
ENG128731-MAS03104-designvariant_activation-Version 7,not active ,2
ENG128731-MAS03105-designvariant_activation-Version 8,not active ,2
ENG99320-Developers_menu,not active ,1
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64 ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,02 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,02 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,06 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,0A ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,50 ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96 ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,02 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,02 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,0E ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,1E ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,32 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32 ,12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00 ,12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,14 ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,1E ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,32 ,12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,46 ,12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,64 ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,00 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,14 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,1E ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,32 ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,46 ,12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64 ,12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00 ,12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC ,12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,02 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,02 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,06 ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,0A ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,50 ,12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64 ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 96 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 32 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 64 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00 ,12
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A ,12
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC ,12
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,02 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,02 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,06 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0A ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,50 ,12
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64 ,12
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xs_bus ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,lds ,1
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.00 km,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.00 °C,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.00 ,16
ENG126283-parameter_hmi,41 43 56 03 05 FF 1E 03 00 01 00 FA 02 00 FF 00 00 FF FF 00 00 F3 00 00 FF 00 24 00 FF 43 14 28 00 00 5A 00 E1 00 19 FF B4 00 1E 8C AA 64 AA 00 BF 4B 68 A2 91 6D 6D 97 A2 73 9B 75 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,100
ENG135292-phev_stat_intervall-,5.00 ,3
ENG135292-phev_stat_intervall-,100 m,3
ENG135292-phev_stat_intervall-,0 min,3
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,1.40 ,4
ENG112418-ENG99298-total_range_gas-State,active ,4
Elapsed Time: 00:27
blockmap-19-8W6-907-468-F
;SW:8W6-907-468-F   HW:8W6-907-468-E ---  CAN Gateway
;Component:Gateway       H43 0123, Coding:030100010000064029070000005900324C3A0007100000000175078E10000000
;EV_CGateCONTIAU491,003111,EV_CGateCONTIAU491_003_AU49.rod
;Friday,12,July,2019,15:55:28:64285
;VCID: CDDD6A749C2A8327A2-8098
IDE00009,Date of manufacture,18 04 10,
IDE00010,Serial number,0287B835418410,
IDE00019,Voltage terminal 30,14.20, V
IDE00020-MAS00044,Terminal 15 status-Supply voltage: Terminal 15,14.30, V
IDE00020-MAS03680,Terminal 15 status-Terminal 15 status measured,On,
IDE00020-MAS05562,Terminal 15 status-Terminal 15 resulting,On,
IDE00020-MAS07720,Terminal 15 status-Terminal 15 via CAN,On,
IDE00020-MAS08946,Terminal 15 status-Terminal 15 via comparator,On,
IDE00056,History data 1,000*2019-06-28-09:11*03.2*01**,
IDE00056,History data 1,000*2000-01-01-00:00*00.0*00**,
IDE00056,History data 1,000*2000-01-01-00:00*00.0*00*00000**,
IDE00056,History data 1,000*2019-06-30-13:10*02.4*01*00054**,
IDE00056,History data 1,000*2019-06-01-14:10*00.4*01**,
IDE00056,History data 1,000*2019-06-01-00:34*04.3*01**,
IDE00056,History data 1,000*2019-06-28-01:38*00.8*01**,
IDE00056,History data 1,000*2019-06-29-12:23*03.0*01**,
IDE00057,History data 2,000*2000-01-01-00:00*0000.0*000*00000*0000*00**,
IDE00057,History data 2,240*2019-06-27-03:24*0001.0*036*00101*0000*01*00017**,
IDE00057,History data 2,022*2018-09-03-11:17*0001.0*065*00087*0000*01**,
IDE00057,History data 2,122*2019-06-02-05:04*0003.0*052*00098*0000*01**,
IDE00058,History data 3,015*2018-07-11-06:49*T*0*0*074*055*0010*0*00.0*00.0**,
IDE00058,History data 3,090*2019-05-08-14:18*2*0*0*025*000*0400*0*00.0*00.0**,
IDE00058,History data 3,089*2019-04-21-20:41*3*0*0*017*000*0000*0*00.0*20.8**,
IDE00058,History data 3,089*2019-04-21-19:48*1*0*0*021*006*0000*0*00.0*19.9**,
IDE00058,History data 3,090*2019-05-08-14:15*1*0*1*026*000*0010*0*00.0*00.0**,
IDE00058,History data 3,090*2019-05-08-14:18*3*0*0*025*000*0400*0*00.0*00.0**,
IDE00058,History data 3,089*2019-04-21-20:41*2*0*0*017*000*0000*0*00.0*20.8**,
IDE00059,History data 4,000*2000-01-01-00:00*00*000*00*000*0000000000*00000*00000*000.0*000.0*000.0**,
IDE00059,History data 4,013*2018-05-24-17:57*01*075*01*JCB*280327R1X2*10008*03299*001.7*000.0*000.0**,
IDE00060,History data 5,089*2019-04-21-20:39*1*029851*0000*11.3*000*08*-56.6*02964*09949*0000*00030029*004*00.0*20.8*0023.1**,
IDE00060,History data 5,000*2000-01-01-00:00*0*000000*0000*00.0*000*00*-00.0*00000*00000*0000*00000000*000*00.0*00.0*0000.0**,
IDE00061,History data 6,073*2019-07-12-14:51*045*+27*+000.4*0000*00*00.03**,
IDE00061,History data 6,064*2019-07-11-19:45*054*+35*+000.4*0000*00*00.16**,
IDE00061,History data 6,067*2019-07-12-09:48*057*+24*+001.3*0000*00*00.73**,
IDE00061,History data 6,069*2019-07-12-11:55*051*+25*+000.3*0000*00*00.05**,
IDE00061,History data 6,067*2019-07-12-10:48*055*+24*+000.8*0022*01*00.33**,
IDE00061,History data 6,061*2019-07-11-14:26*059*+35*+002.7*0000*00*02.25**,
IDE00061,History data 6,071*2019-07-12-13:39*048*+26*+001.0*0000*00*00.65**,
IDE00061,History data 6,070*2019-07-12-12:24*050*+25*+001.1*0003*01*00.23**,
IDE00061,History data 6,062*2019-07-11-18:29*053*+35*+000.7*0000*00*00.05**,
IDE00061,History data 6,074*2019-07-12-15:28*046*+27*+000.5*0007*01*00.06**,
IDE00061,History data 6,062*2019-07-11-17:53*055*+35*+000.3*0000*00*00.03**,
IDE00061,History data 6,059*2019-07-11-11:40*059*+34*+000.0*0004*02*02.65**,
IDE00061,History data 6,072*2019-07-12-14:44*045*+27*+000.4*0000*00*00.05**,
IDE00061,History data 6,063*2019-07-11-18:39*054*+35*+002.4*0000*00*01.01**,
IDE00061,History data 6,066*2019-07-11-21:04*052*+35*+000.2*0000*00*00.05**,
IDE00062,History data 7,072*2019-07-12-14:47*045*-000.3*00.0*00.0*0000.0**,
IDE00062,History data 7,064*2019-07-11-19:41*054*-000.4*00.0*00.0*0000.0**,
IDE00062,History data 7,061*2019-07-11-16:41*055*-001.8*00.0*00.1*0000.9**,
IDE00062,History data 7,067*2019-07-12-10:32*056*-001.0*00.0*00.0*0000.2**,
IDE00062,History data 7,065*2019-07-11-19:55*051*-000.6*00.0*00.0*0000.0**,
IDE00062,History data 7,074*2019-07-12-15:32*043*-001.0*00.0*00.0*0000.1**,
IDE00062,History data 7,071*2019-07-12-14:18*046*-000.7*00.0*00.0*0000.3**,
IDE00062,History data 7,069*2019-07-12-11:59*050*-000.6*00.0*00.0*0000.0**,
IDE00062,History data 7,073*2019-07-12-14:53*044*-000.8*00.0*00.0*0000.3**,
IDE00062,History data 7,068*2019-07-12-11:09*051*-000.7*00.0*00.0*0000.0**,
IDE00062,History data 7,066*2019-07-11-21:07*056*-001.8*00.0*00.0*0011.0**,
IDE00062,History data 7,070*2019-07-12-12:39*048*-000.6*00.0*00.0*0000.9**,
IDE00062,History data 7,063*2019-07-11-18:32*052*-000.6*00.0*00.0*0000.0**,
IDE00062,History data 7,062*2019-07-11-17:55*052*-000.6*00.0*00.0*0000.0**,
IDE00062,History data 7,060*2019-07-11-14:20*057*-001.2*00.0*00.0*0000.0**,
IDE00063,History data 8,000*2019-04-22-00:00*4*+53.3*10.8*100*+16**,
IDE00063,History data 8,018*2018-05-24-19:34*1*+28.6*13.6*089*+25**,
IDE00063,History data 8,000*2019-04-22-00:00*4*-04.6*12.3*100*+30*04*00*00*07*00*00*000*000*00**,
IDE00063,History data 8,089*2019-04-21-09:54*1*+25.5*13.4*055*+12**,
IDE00063,History data 8,089*2019-04-22-08:45*1*-09.7*07.6*100*+16**,
IDE00063,History data 8,050*2018-05-25-00:35*1*+13.2*13.9*091*+28**,
IDE00064,History data 9,000*2019-03-15-10:53*100*086*080*051*02495*03.6*+08*09.6*03.1*00300*01839**,
IDE00064,History data 9,000*2018-08-31-03:59*100*096*079*061*00579*03.4*+26*09.8*02.8*00030*00166**,
IDE00064,History data 9,000*2019-04-16-00:01*093*089*084*055*02810*03.4*+17*09.6*03.0*00357*02202**,
IDE00064,History data 9,000*2019-01-09-05:33*098*091*077*052*01965*03.6*+13*09.4*03.0*00209*01301**,
IDE00064,History data 9,000*2019-02-10-14:13*089*083*076*044*02181*04.0*+11*09.1*03.0*00246*01511**,
IDE00064,History data 9,000*2018-07-29-18:08*100*097*068*050*00046*03.4*+26*09.8*02.7*00000*00000**,
IDE00064,History data 9,000*2018-10-03-04:46*096*093*071*049*00999*03.2*+21*09.5*03.1*00047*00294**,
IDE00064,History data 9,000*2018-12-08-15:48*089*088*093*056*01762*03.6*+08*09.0*02.9*00185*01132**,
IDE00064,History data 9,000*2019-06-04-15:51*100*092*079*061*03025*03.2*+28*09.8*02.8*00380*02303**,
IDE00064,History data 9,000*2000-01-01-00:00*000*000*000*000*00000*00.0*+00*02.0*00.0*00000*00000**,
IDE00064,History data 9,000*2018-11-05-03:18*093*087*067*038*01362*03.6*+10*09.2*03.0*00119*00729**,
IDE00064,History data 9,000*2019-07-06-17:52*098*091*063*042*03183*03.4*+31*09.8*02.9*00384*02333**,
IDE00065,History data 10,000*2000-01-01-00:00*00**,
IDE00065,History data 10,179*2019-06-11-19:40*2*067*043*+28*03*30*-28*10.9*6*00001*00017*00000**,
IDE00065,History data 10,019*2019-07-06-18:20*80*00451*00000*00000*00198*00000*00000*00000*00356**,
IDE00065,History data 10,035*2019-02-17-12:59*08*00000*00000*00000*00001*00000*00000*00000*00000**,
IDE00065,History data 10,131*2019-03-09-18:29*2*060*026*+06*04*30*-95*11.2*6**,
IDE00065,History data 10,095*2019-02-25-19:38*2*089*050*+11*03*30*-28*10.7*6**,
IDE00065,History data 10,019*2019-07-06-18:14*80**,
IDE00065,History data 10,157*2019-06-08-13:25*2*070*053*+26*03*30*-09*12.5*6**,
IDE00065,History data 10,123*2019-03-07-07:29*1*069*028*-03*04*30*-44*11.4*6**,
IDE00065,History data 10,019*2019-07-06-18:15*80**,
IDE00065,History data 10,019*2019-07-06-18:18*80**,
IDE00065,History data 10,018*2019-07-06-18:07*80**,
IDE00066,History data 11,070*2019-07-12-12:24*000*000*000*000*0000*014*00.0*00.0*070*050*070*050*00*00375*00646*01342*01902*00000**,
IDE00066,History data 11,064*2019-07-11-19:45*000*000*000*000*0091*010*00.3*00.7*074*054*074*054*00**,
IDE00066,History data 11,067*2019-07-12-09:48*000*000*000*000*0246*044*00.2*01.5*076*056*077*057*00**,
IDE00066,History data 11,067*2019-07-12-10:48*000*000*000*000*0197*020*00.7*01.5*075*056*075*055*00**,
IDE00066,History data 11,069*2019-07-12-11:55*000*000*000*000*0025*003*00.2*00.5*072*051*072*051*00**,
IDE00066,History data 11,066*2019-07-11-21:04*000*000*000*000*0025*003*00.2*00.4*072*051*072*052*00**,
IDE00067,History data 12,248*2019-07-02-09:01*0002*14*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,114*2019-05-28-19:11*0009*03*00*0046*03*00*0044*03*00**,
IDE00067,History data 12,030*2019-07-08-11:59*0009*04*00*0046*04*00*0044*04*00**,
IDE00067,History data 12,251*2019-03-22-16:20*0002*12*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,153*2019-01-28-10:05*0009*02*00*0046*02*00*0044*02*00**,
IDE00068,History data 13,070*2019-07-12-12:35*2*00.10*000*255*000*000*000*000*017**,
IDE00068,History data 13,068*2019-07-12-10:52*2*00.00*000*255*000*000*000*000*017**,
IDE00068,History data 13,060*2019-07-11-14:02*2*02.30*000*255*000*000*000*000*017**,
IDE00068,History data 13,074*2019-07-12-15:32*2*00.00*000*255*000*000*000*000*017**,
IDE00068,History data 13,057*2019-07-11-07:14*2*00.50*000*255*000*000*000*000*017**,
IDE00069,History data 14,000*2000-01-01-00:00*0*00.00*000*000*000*000*000*000*000**,
IDE00070,History data 15,000*2000-01-01-00:00*0*000*00.00*000*000*000**,
IDE00071,History data 16,000*2000-01-01-00:00*000*000*000*00.00*000*000*000**,
IDE00102,Control Module temperature,46, °C
IDE00667,Microphone status,Electrical OK,
IDE00668,Microphone current consumption,6.10, mA
IDE00672,Roadside Assistance Button,Not available,
IDE00673,Information Service Button,Not available,
IDE00725,Manufacturer's test stand number,0032,
IDE00726,Subassembly and series number,0854,
IDE00767-ENG05080,No. of unscheduled ECU resets-KL30_Reset_Counter,7,
IDE00767-ENG05081,No. of unscheduled ECU resets-Last_Main_Controller_Reset_Reason,00 04,
IDE00767-ENG05078,No. of unscheduled ECU resets-Last_WD_Reset_Reason,00,
IDE00767-ENG05082,No. of unscheduled ECU resets-Main_Controller_Reset_Counter,1,
IDE00767-ENG05079,No. of unscheduled ECU resets-Wd_Reset_Counter,0,
IDE00767-ENG33384,No. of unscheduled ECU resets-Z0_Reset_Counter,0,
IDE01215,Terminal 58d dimmer,86.55, %
IDE01625,Muting of radio/radio navigation system via control wire,not active,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS01779,GPS Position-Length,-81144783,
IDE01712-MAS01780,GPS Position-Width,41310045,
IDE01712-MAS02230,GPS Position-Height,382, m
IDE01713-MAS01632,Status GPS reception-Status,Not available,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,0,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,0,
IDE01718,Crash signal,No crash recognized,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,0, mA
IDE01803,History data 17,000*2000-01-01-00:00*000*000*000*00.00*000*000*000**,
IDE01804,History data 18,074*2019-07-12-15:29*1*001*00.05*000080*999*815*924**,
IDE01804,History data 18,072*2019-07-12-14:47*1*000*00.05*000400*999*814*924**,
IDE01804,History data 18,074*2019-07-12-15:31*2*000*00.06*000420*999*816*924**,
IDE01804,History data 18,074*2019-07-12-15:28*2*000*00.00*000420*999*815*924**,
IDE01804,History data 18,073*2019-07-12-14:53*1*000*00.03*000480*999*814*924**,
IDE01805,History data 19,000*2000-01-01-00:00*0000*0000.0*0000.0*0000.0*0000*00000000*000*000*000**,
IDE01805,History data 19,059*2018-05-25-01:51*0011*0053.1*0002.2*0044.1*0000*0103003D*000*000*001**,
IDE01806,History data 20,000*2000-01-01-00:00*0000*000*000*+0000000*+0000000**,
IDE01807,History data 21,02344*05376*00119*00000**,
IDE01807,History data 21,01191*00195*00139**,
IDE01807,History data 21,00000*00000*00000*00000*00000**,
IDE01807,History data 21,00085*00003*00001**,
IDE01807,History data 21,034677**,
IDE01807,History data 21,01893*00019*00006*00000**,
IDE01807,History data 21,00153*00489*01257*00015*00006**,
IDE01807,History data 21,00002*00002*00007*00122**,
IDE01807,History data 21,00748*00399*00212*00178*00123*00099*00257*00123*00061*00154*00000**,
IDE01807,History data 21,01037*00436*00368**,
IDE01807,History data 21,00000*00000*00000*00000**,
IDE01807,History data 21,00555*00520*00223*00543**,
IDE01807,History data 21,00000*00000*00000**,
IDE01807,History data 21,,
IDE01808,History data 22,033*2019-07-08-12:33*2*0*013*001*071*071*0*02817*00197**,
IDE01808,History data 22,248*2019-07-02-09:04*2*0*000*000*075*075*0**,
IDE01808,History data 22,020*2019-07-07-10:44*2*0*002*000*075*075*0**,
IDE01808,History data 22,010*2019-07-06-07:07*2*0*000*000*065*065*0**,
IDE01808,History data 22,027*2019-07-07-17:00*2*0*012*000*071*068*0**,
IDE01809,History data 23,000*2000-01-01-00:00*0*00000*00000**,
IDE01810,History data 24,000*2000-01-01-00:00*0*0000*0000*0000*00000*00000*00000**,
IDE01811,History data 25,001*2000-00-00-00:00*000.1*001*000*000**,
IDE01811,History data 25,000*2000-01-01-00:00*000.0*000*000*001*00000*000.0*000*000*000**,
IDE01811,History data 25,000*2000-00-00-01:01*000.0*000*000*000**,
IDE01812,History data 26,000*2000-01-01-00:00*0000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE01812,History data 26,000*2000-01-01-00:00*0000**,
IDE01812,History data 26,013*2018-05-24-17:57*0040**,
IDE01812,History data 26,007*2018-05-24-13:58*0040**,
IDE01812,History data 26,018*2018-05-24-19:35*0040*00000*00000*00000*00000*00000*00000*00003*00000*00000*00000*00000*00000**,
IDE01816,History data 30,000*2000-00-00-00:00*0*0*0*0*0*000.00*000.00*-40**,
IDE01817,History data 31,,
IDE01817,History data 31,Nur für BEV                                             ,
IDE01817,History data 31,                                             ,
IDE01818,History data 32,000*2000-00-00-00:00*0*000*000*00.0*00.0*000*000*00.0*00.0*00000**,
IDE01819,History data 33,000*2000-00-00-00:00*0*000*000*000*000*00000*00000**,
IDE01820,History data 34,000*2000-00-00-00:00*0*0*000*000.0*00.0*00.0*000.0*00.0**,
IDE01821,History data 35,000*2000-01-01-00:00*0*000*000*000*000*000*000*000*000*000*000**,
IDE01822,History data 36,000*2000-01-01-00:00*0*000*000*000*000*000*000*000*000*000*000**,
IDE01823,History data 37,*0*0*0*0**000*2000-01-01-00:00*0*0*0*0*0,
IDE01823,History data 37,0*2000-01-01-00:00*0*0*0*0*0*0**,
IDE01823,History data 37,*0**000*2000-01-01-00:00*0*0*0*0*0*0**00,
IDE01823,History data 37,000*2000-01-01-00:00*0*0*0*0*0*0**000*20,
IDE01823,History data 37,01-00:00*0*0*0*0*0*0**000*2000-01-01-00:,
IDE01823,History data 37,00-01-01-00:00*0*0*0*0*0*0**000*2000-01-,
IDE01823,History data 37,00*0*0*0*0*0*0**000*2000-01-01-00:00*0*0,
IDE01823,History data 37,,
IDE01824,History data 38,000*2000-01-01-00:00*0*+000*000*0**,
IDE01825,History data 39,000*2019-07-12-15:33*000*001*000**,
IDE01825,History data 39,,
IDE01825,History data 39,000*2019-07-12-14:51*000*001*000**,
IDE01825,History data 39,000*2019-07-12-15:27*000*001*000**,
IDE01825,History data 39,000*2019-07-12-14:19*000*001*000**,
IDE01825,History data 39,000*2019-07-12-14:44*000*001*000**,
IDE01825,History data 39,000*2019-07-12-15:03*000*001*000**,
IDE01825,History data 39,000*2019-07-12-15:45*000*001*000**,
IDE01825,History data 39,000*2019-07-12-14:41*000*001*000**,
IDE01826,History data 40,000*2000-01-01-00:00*0*0*0*0*0*000.00*000.00*-50**,
IDE01827,Generator specified voltage value,14.6, V
IDE01828,Generator DF Signal,41.950, %
IDE01829,Generator exciter current,2.10, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,Electrical OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Valeo GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,110A - 150A MOSFET,
IDE01832-MAS06311,Generator regulator variant-ASIC manufacturer,1,
IDE01832-MAS06312,Generator regulator variant-ASIC variant,4,
IDE01833-MAS06105,Battery variant-Rated battery capacity,75, Ah
IDE01833-MAS06106,Battery variant-Battery technology,Fleece,
IDE01833-MAS06107,Battery variant-Battery manufacturer,JCI,
IDE01834,Battery voltage,14.389, V
IDE01836,Battery current,1.988, A
IDE01837,Temperature of battery sensor,31, °C
IDE01838,Battery temperature,28, °C
IDE01839,Battery charge condition,66, %
IDE01841,Battery internal resistance,3.6, mOhm
IDE01842,Usable battery charge,45, Ah
IDE01843,Battery voltage at rest,12.3, V
IDE01844,Increase idle speed request,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shutdown level,Deactivation stage 0,
IDE01847-MAS01577,Auxiliary heater activation restriction request-Parking heater,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Previous journey energy summary,1.10, Ah
IDE01849,Previous journey duration,0.13, H
IDE01850,Total energy summary,10009.00, Ah
IDE01851,Total energy throughput,3300.0, Ah
IDE01852,Static current measurement: result,Initializing,
IDE01853,Static current measurement: status,Cancel,
IDE01854-MAS09891,Energy reclamation request-recuperation active,not active,
IDE01854-MAS09892,Energy reclamation request-Charge contingent for feedback,3960, As
IDE01855,Generator current,40.8, A
IDE01864-MAS03179,Status of current bus communication-Local data bus 2,active: local wakeup event,
IDE01864-MAS03180,Status of current bus communication-Local data bus,active: local wakeup event,
IDE01864-MAS05972,Status of current bus communication-Local data bus 3,not installed,
IDE01864-MAS10445,Status of current bus communication-Data bus CAN 1,active: local wakeup event,
IDE01864-MAS10446,Status of current bus communication-Data bus CAN 2,not installed,
IDE01864-MAS10447,Status of current bus communication-Data bus CAN 3,active: local wakeup event,
IDE01864-MAS10448,Status of current bus communication-Data bus CAN 4,active: local wakeup event,
IDE01864-MAS10449,Status of current bus communication-Data bus CAN 5,active: local wakeup event,
IDE01864-MAS10450,Status of current bus communication-Data bus CAN 6,active: local wakeup event,
IDE01864-MAS11107,Status of current bus communication-Data bus CAN 7,not installed,
IDE01864-MAS11108,Status of current bus communication-FlexRay star 3,not installed,
IDE01864-MAS11244,Status of current bus communication-FlexRay star 1,active: local wakeup event,
IDE01864-MAS11245,Status of current bus communication-FlexRay star 2,not installed,
IDE01948,Battery internal resistance not normed,3.4, mOhm
IDE01971,Lowest recorded control module temperature,34, °C
IDE01972,Highest recorded control module temperature,46, °C
IDE01992-IDE14867,Installation list: current installations-Subgateway as firewall control module,Not available,
IDE01992-SFT00001,Installation list: current installations-Engine Control Module 1,Available,
IDE01992-SFT00002,Installation list: current installations-Transmission Control Module,Available,
IDE01992-SFT00006,Installation list: current installations-Seat Adjustment Passenger Side,Not available,
IDE01992-SFT00007,Installation list: current installations-Display Control Unit,Not available,
IDE01992-SFT00008,Installation list: current installations-Air Conditioning,Available,
IDE01992-SFT00009,Installation list: current installations-Central Electrics,Available,
IDE01992-SFT00012,Installation list: current installations-Rear Axle Steering 2,Not available,
IDE01992-SFT00017,Installation list: current installations-Engine Control Module 2,Not available,
IDE01992-SFT00019,Installation list: current installations-Adaptive Cruise Control,Not available,
IDE01992-SFT00022,Installation list: current installations-Steering Column Electronics,Available,
IDE01992-SFT00023,Installation list: current installations-Dash Board,Available,
IDE01992-SFT00024,Installation list: current installations-Auxiliary Parking Heater,Not available,
IDE01992-SFT00025,Installation list: current installations-Gateway,Available,
IDE01992-SFT00027,Installation list: current installations-Active Steering,Not available,
IDE01992-SFT00032,Installation list: current installations-High Beam Assistance,Not available,
IDE01992-SFT00033,Installation list: current installations-Battery Energy Control Module 2,Not available,
IDE01992-SFT00034,Installation list: current installations-All Wheel Control,Available,
IDE01992-SFT00035,Installation list: current installations-Brake Boost,Not available,
IDE01992-SFT00038,Installation list: current installations-Electronic Roof Control,Not available,
IDE01992-SFT00039,Installation list: current installations-Display Control Unit Rear,Not available,
IDE01992-SFT00040,Installation list: current installations-Climate Control Unit Rear,Not available,
IDE01992-SFT00042,Installation list: current installations-Control Unit Wireless Charging,Not available,
IDE01992-SFT00043,Installation list: current installations-Steering Column Locking,Not available,
IDE01992-SFT00048,Installation list: current installations-Special Function 2,Not available,
IDE01992-SFT00050,Installation list: current installations-Lock Electronics,Not available,
IDE01992-SFT00054,Installation list: current installations-Seat Adjustment Driver Side,Available,
IDE01992-SFT00061,Installation list: current installations-Special Function,Not available,
IDE01992-SFT00066,Installation list: current installations-Door Electronics Driver Side,Available,
IDE01992-SFT00068,Installation list: current installations-Steering Assistance,Available,
IDE01992-SFT00070,Installation list: current installations-Central Module Comfort System,Available,
IDE01992-SFT00072,Installation list: current installations-Seat Adjustment Rear Driver Side,Not available,
IDE01992-SFT00074,Installation list: current installations-Rear light,Not available,
IDE01992-SFT00077,Installation list: current installations-Löschkandidat_Datenübertragung Car2X,Not available,
IDE01992-SFT00080,Installation list: current installations-Seat Adjustment 3rd Row,Not available,
IDE01992-SFT00081,Installation list: current installations-Drive Motor Control Module,Not available,
IDE01992-SFT00082,Installation list: current installations-Door Electronics Passenger Side,Available,
IDE01992-SFT00090,Installation list: current installations-Longitudinal control,Not available,
IDE01992-SFT00091,Installation list: current installations-Seat Adjustment Rear Passenger Side,Not available,
IDE01992-SFT00095,Installation list: current installations-Information Control Unit 1,Available,
IDE01992-SFT00101,Installation list: current installations-Tire Pressure Monitoring 1,Not available,
IDE01992-SFT00105,Installation list: current installations-Trailer Function,Not available,
IDE01992-SFT00107,Installation list: current installations-Aerodynamics Control Unit,Not available,
IDE01992-SFT00108,Installation list: current installations-Camera System Rear View,Available,
IDE01992-SFT00109,Installation list: current installations-Deck Lid Control Unit,Available,
IDE01992-SFT00116,Installation list: current installations-Chassis Control,Not available,
IDE01992-SFT00118,Installation list: current installations-Parking Assistance,Not available,
IDE01992-SFT00127,Installation list: current installations-Information Control Unit 2,Not available,
IDE01992-SFT00128,Installation list: current installations-Battery Regulation Auxiliary Accumulator 1,Not available,
IDE01992-SFT00129,Installation list: current installations-Gear Shift Control Module,Available,
IDE01992-SFT00130,Installation list: current installations-Head Up Display,Not available,
IDE01992-SFT00132,Installation list: current installations-Night Vision,Not available,
IDE01992-SFT00139,Installation list: current installations-Adaptive Cruise Control 2,Not available,
IDE01992-SFT00140,Installation list: current installations-Battery Energy Control Module,Not available,
IDE01992-SFT00166,Installation list: current installations-Microphone Control Unit,Not available,
IDE01992-SFT00169,Installation list: current installations-Actuator For Structure-borne Sound,Not available,
IDE01992-SFT00172,Installation list: current installations-Reductant Control Module,Not available,
IDE01992-SFT00183,Installation list: current installations-Access Startsystem Interface,Not available,
IDE01992-SFT00186,Installation list: current installations-Assembly Mounting,Not available,
IDE01992-SFT00192,Installation list: current installations-Actuator For Exterior Noise,Not available,
IDE01992-SFT00195,Installation list: current installations-Drive Motor Control Module 3,Not available,
IDE01992-SFT00196,Installation list: current installations-DC/DC Converter Control Module,Not available,
IDE01992-SFT00197,Installation list: current installations-Thermal management,Not available,
IDE01992-SFT00198,Installation list: current installations-Battery Charger Control Module,Not available,
IDE01992-SFT00203,Installation list: current installations-Rear Axle Steering,Not available,
IDE01992-SFT00205,Installation list: current installations-Laser Scanner,Not available,
IDE01992-SFT00206,Installation list: current installations-Drive Motor Control Module 2,Not available,
IDE01992-SFT00208,Installation list: current installations-Front Axle Lift System,Not available,
IDE01992-SFT00219,Installation list: current installations-Front Corner Radar 1,Not available,
IDE01992-SFT00220,Installation list: current installations-Front Corner Radar 2,Not available,
IDE01992-SFT00221,Installation list: current installations-Control Module 2 For Sunroof,Not available,
IDE01992-SFT33031,Installation list: current installations-Antenna Control Module,Not available,
IDE01992-SFT33232,Installation list: current installations-Central control for digital matrix light,Not available,
IDE01992-SFT09760,Installation list: current installations-Sun Roof,Not available,
IDE01993-IDE14867,Control module reference number-Subgateway as firewall control module,00,
IDE01993-SFT00001,Control module reference number-Engine Control Module 1,76,
IDE01993-SFT00002,Control module reference number-Transmission Control Module,77,
IDE01993-SFT00003,Control module reference number-Brakes 1,13,
IDE01993-SFT00003,Control module reference number-Brakes 1,00,
IDE01993-SFT00006,Control module reference number-Seat Adjustment Passenger Side,4D,
IDE01993-SFT00007,Control module reference number-Display Control Unit,8E,
IDE01993-SFT00008,Control module reference number-Air Conditioning,46,
IDE01993-SFT00009,Control module reference number-Central Electrics,0E,
IDE01993-SFT00012,Control module reference number-Rear Axle Steering 2,00,
IDE01993-SFT00017,Control module reference number-Engine Control Module 2,78,
IDE01993-SFT00019,Control module reference number-Adaptive Cruise Control,57,
IDE01993-SFT00021,Control module reference number-Airbag,00,
IDE01993-SFT00021,Control module reference number-Airbag,15,
IDE01993-SFT00022,Control module reference number-Steering Column Electronics,0C,
IDE01993-SFT00023,Control module reference number-Dash Board,14,
IDE01993-SFT00024,Control module reference number-Auxiliary Parking Heater,6A,
IDE01993-SFT00025,Control module reference number-Gateway,10,
IDE01993-SFT00027,Control module reference number-Active Steering,16,
IDE01993-SFT00032,Control module reference number-High Beam Assistance,30,
IDE01993-SFT00033,Control module reference number-Battery Energy Control Module 2,9C,
IDE01993-SFT00034,Control module reference number-All Wheel Control,0F,
IDE01993-SFT00035,Control module reference number-Brake Boost,3B,
IDE01993-SFT00038,Control module reference number-Electronic Roof Control,2D,
IDE01993-SFT00039,Control module reference number-Display Control Unit Rear,93,
IDE01993-SFT00040,Control module reference number-Climate Control Unit Rear,1A,
IDE01993-SFT00042,Control module reference number-Control Unit Wireless Charging,8F,
IDE01993-SFT00043,Control module reference number-Steering Column Locking,31,
IDE01993-SFT00048,Control module reference number-Special Function 2,2B,
IDE01993-SFT00050,Control module reference number-Lock Electronics,1E,
IDE01993-SFT00054,Control module reference number-Seat Adjustment Driver Side,4C,
IDE01993-SFT00060,Control module reference number-Lane Change Assistant,4E,
IDE01993-SFT00060,Control module reference number-Lane Change Assistant,00,
IDE01993-SFT00061,Control module reference number-Special Function,2C,
IDE01993-SFT00066,Control module reference number-Door Electronics Driver Side,4A,
IDE01993-SFT00068,Control module reference number-Steering Assistance,12,
IDE01993-SFT00070,Control module reference number-Central Module Comfort System,8B,
IDE01993-SFT00072,Control module reference number-Seat Adjustment Rear Driver Side,87,
IDE01993-SFT00074,Control module reference number-Rear light,00,
IDE01993-SFT00077,Control module reference number-Löschkandidat_Datenübertragung Car2X,00,
IDE01993-SFT00080,Control module reference number-Seat Adjustment 3rd Row,95,
IDE01993-SFT00081,Control module reference number-Drive Motor Control Module,03,
IDE01993-SFT00081,Control module reference number-Drive Motor Control Module,7C,
IDE01993-SFT00082,Control module reference number-Door Electronics Passenger Side,4B,
IDE01993-SFT00090,Control module reference number-Longitudinal control,94,
IDE01993-SFT00091,Control module reference number-Seat Adjustment Rear Passenger Side,88,
IDE01993-SFT00095,Control module reference number-Information Control Unit 1,73,
IDE01993-SFT00101,Control module reference number-Tire Pressure Monitoring 1,0B,
IDE01993-SFT00105,Control module reference number-Trailer Function,47,
IDE01993-SFT00107,Control module reference number-Aerodynamics Control Unit,24,
IDE01993-SFT00108,Control module reference number-Camera System Rear View,69,
IDE01993-SFT00109,Control module reference number-Deck Lid Control Unit,23,
IDE01993-SFT00116,Control module reference number-Chassis Control,80,
IDE01993-SFT00118,Control module reference number-Parking Assistance,00,
IDE01993-SFT00127,Control module reference number-Information Control Unit 2,00,
IDE01993-SFT00128,Control module reference number-Battery Regulation Auxiliary Accumulator 1,AE,
IDE01993-SFT00129,Control module reference number-Gear Shift Control Module,53,
IDE01993-SFT00130,Control module reference number-Head Up Display,1B,
IDE01993-SFT00132,Control module reference number-Night Vision,27,
IDE01993-SFT00139,Control module reference number-Adaptive Cruise Control 2,56,
IDE01993-SFT00140,Control module reference number-Battery Energy Control Module,7B,
IDE01993-SFT00165,Control module reference number-Front Sensors Driver Assistance System,00,
IDE01993-SFT00165,Control module reference number-Front Sensors Driver Assistance System,4F,
IDE01993-SFT00166,Control module reference number-Microphone Control Unit,63,
IDE01993-SFT00169,Control module reference number-Actuator For Structure-borne Sound,1C,
IDE01993-SFT00172,Control module reference number-Reductant Control Module,2A,
IDE01993-SFT00183,Control module reference number-Access Startsystem Interface,00,
IDE01993-SFT00186,Control module reference number-Assembly Mounting,2E,
IDE01993-SFT00192,Control module reference number-Actuator For Exterior Noise,64,
IDE01993-SFT00195,Control module reference number-Drive Motor Control Module 3,00,
IDE01993-SFT00196,Control module reference number-DC/DC Converter Control Module,41,
IDE01993-SFT00197,Control module reference number-Thermal management,42,
IDE01993-SFT00198,Control module reference number-Battery Charger Control Module,44,
IDE01993-SFT00203,Control module reference number-Rear Axle Steering,60,
IDE01993-SFT00205,Control module reference number-Laser Scanner,00,
IDE01993-SFT00206,Control module reference number-Drive Motor Control Module 2,00,
IDE01993-SFT00207,Control module reference number-Control Unit Lane Change Assistant 2,00,
IDE01993-SFT00207,Control module reference number-Control Unit Lane Change Assistant 2,8A,
IDE01993-SFT00208,Control module reference number-Front Axle Lift System,00,
IDE01993-SFT00219,Control module reference number-Front Corner Radar 1,00,
IDE01993-SFT00220,Control module reference number-Front Corner Radar 2,00,
IDE01993-SFT00221,Control module reference number-Control Module 2 For Sunroof,A0,
IDE01993-SFT33031,Control module reference number-Antenna Control Module,00,
IDE01993-SFT33232,Control module reference number-Central control for digital matrix light,00,
IDE01993-SFT09760,Control module reference number-Sun Roof,84,
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,Electrical OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,0, mA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,-113.00,
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,Not available,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,Not available,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,Not available,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,Not available,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,0, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,0, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,0, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,0, dBµV
IDE02384-IDE14867,Status of event memory-Subgateway as firewall control module,OK,
IDE02384-SFT00001,Status of event memory-Engine Control Module 1,OK,
IDE02384-SFT00002,Status of event memory-Transmission Control Module,OK,
IDE02384-SFT00003,Status of event memory-Brakes 1,OK,
IDE02384-SFT00006,Status of event memory-Seat Adjustment Passenger Side,OK,
IDE02384-SFT00007,Status of event memory-Display Control Unit,OK,
IDE02384-SFT00008,Status of event memory-Air Conditioning,ERROR,
IDE02384-SFT00009,Status of event memory-Central Electrics,ERROR,
IDE02384-SFT00012,Status of event memory-Rear Axle Steering 2,OK,
IDE02384-SFT00017,Status of event memory-Engine Control Module 2,OK,
IDE02384-SFT00019,Status of event memory-Adaptive Cruise Control,OK,
IDE02384-SFT00021,Status of event memory-Airbag,OK,
IDE02384-SFT00022,Status of event memory-Steering Column Electronics,OK,
IDE02384-SFT00023,Status of event memory-Dash Board,OK,
IDE02384-SFT00024,Status of event memory-Auxiliary Parking Heater,OK,
IDE02384-SFT00025,Status of event memory-Gateway,ERROR,
IDE02384-SFT00027,Status of event memory-Active Steering,OK,
IDE02384-SFT00032,Status of event memory-High Beam Assistance,OK,
IDE02384-SFT00033,Status of event memory-Battery Energy Control Module 2,OK,
IDE02384-SFT00034,Status of event memory-All Wheel Control,OK,
IDE02384-SFT00035,Status of event memory-Brake Boost,OK,
IDE02384-SFT00038,Status of event memory-Electronic Roof Control,OK,
IDE02384-SFT00039,Status of event memory-Display Control Unit Rear,OK,
IDE02384-SFT00040,Status of event memory-Climate Control Unit Rear,OK,
IDE02384-SFT00042,Status of event memory-Control Unit Wireless Charging,OK,
IDE02384-SFT00043,Status of event memory-Steering Column Locking,OK,
IDE02384-SFT00048,Status of event memory-Special Function 2,OK,
IDE02384-SFT00050,Status of event memory-Lock Electronics,OK,
IDE02384-SFT00054,Status of event memory-Seat Adjustment Driver Side,OK,
IDE02384-SFT00060,Status of event memory-Lane Change Assistant,OK,
IDE02384-SFT00061,Status of event memory-Special Function,OK,
IDE02384-SFT00066,Status of event memory-Door Electronics Driver Side,ERROR,
IDE02384-SFT00068,Status of event memory-Steering Assistance,OK,
IDE02384-SFT00070,Status of event memory-Central Module Comfort System,ERROR,
IDE02384-SFT00072,Status of event memory-Seat Adjustment Rear Driver Side,OK,
IDE02384-SFT00074,Status of event memory-Rear light,OK,
IDE02384-SFT00077,Status of event memory-Löschkandidat_Datenübertragung Car2X,OK,
IDE02384-SFT00080,Status of event memory-Seat Adjustment 3rd Row,OK,
IDE02384-SFT00081,Status of event memory-Drive Motor Control Module,OK,
IDE02384-SFT00082,Status of event memory-Door Electronics Passenger Side,ERROR,
IDE02384-SFT00090,Status of event memory-Longitudinal control,OK,
IDE02384-SFT00091,Status of event memory-Seat Adjustment Rear Passenger Side,OK,
IDE02384-SFT00095,Status of event memory-Information Control Unit 1,OK,
IDE02384-SFT00101,Status of event memory-Tire Pressure Monitoring 1,OK,
IDE02384-SFT00105,Status of event memory-Trailer Function,OK,
IDE02384-SFT00107,Status of event memory-Aerodynamics Control Unit,OK,
IDE02384-SFT00108,Status of event memory-Camera System Rear View,OK,
IDE02384-SFT00109,Status of event memory-Deck Lid Control Unit,OK,
IDE02384-SFT00116,Status of event memory-Chassis Control,OK,
IDE02384-SFT00118,Status of event memory-Parking Assistance,OK,
IDE02384-SFT00127,Status of event memory-Information Control Unit 2,OK,
IDE02384-SFT00128,Status of event memory-Battery Regulation Auxiliary Accumulator 1,OK,
IDE02384-SFT00129,Status of event memory-Gear Shift Control Module,OK,
IDE02384-SFT00130,Status of event memory-Head Up Display,OK,
IDE02384-SFT00132,Status of event memory-Night Vision,OK,
IDE02384-SFT00139,Status of event memory-Adaptive Cruise Control 2,OK,
IDE02384-SFT00140,Status of event memory-Battery Energy Control Module,OK,
IDE02384-SFT00165,Status of event memory-Front Sensors Driver Assistance System,OK,
IDE02384-SFT00165,Status of event memory-Front Sensors Driver Assistance System,ERROR,
IDE02384-SFT00166,Status of event memory-Microphone Control Unit,OK,
IDE02384-SFT00169,Status of event memory-Actuator For Structure-borne Sound,OK,
IDE02384-SFT00172,Status of event memory-Reductant Control Module,OK,
IDE02384-SFT00183,Status of event memory-Access Startsystem Interface,OK,
IDE02384-SFT00186,Status of event memory-Assembly Mounting,OK,
IDE02384-SFT00192,Status of event memory-Actuator For Exterior Noise,OK,
IDE02384-SFT00195,Status of event memory-Drive Motor Control Module 3,OK,
IDE02384-SFT00196,Status of event memory-DC/DC Converter Control Module,OK,
IDE02384-SFT00197,Status of event memory-Thermal management,OK,
IDE02384-SFT00198,Status of event memory-Battery Charger Control Module,OK,
IDE02384-SFT00203,Status of event memory-Rear Axle Steering,OK,
IDE02384-SFT00205,Status of event memory-Laser Scanner,OK,
IDE02384-SFT00206,Status of event memory-Drive Motor Control Module 2,OK,
IDE02384-SFT00207,Status of event memory-Control Unit Lane Change Assistant 2,OK,
IDE02384-SFT00208,Status of event memory-Front Axle Lift System,OK,
IDE02384-SFT00219,Status of event memory-Front Corner Radar 1,OK,
IDE02384-SFT00220,Status of event memory-Front Corner Radar 2,OK,
IDE02384-SFT00221,Status of event memory-Control Module 2 For Sunroof,OK,
IDE02384-SFT33031,Status of event memory-Antenna Control Module,OK,
IDE02384-SFT33232,Status of event memory-Central control for digital matrix light,OK,
IDE02384-SFT09760,Status of event memory-Sun Roof,OK,
IDE02578-IDE05118,Play protection status-Counter for function calls,0,
IDE02578-MAS02040,Play protection status-Play protection,not active,
IDE02744-MAS02311,Steering wheel heater-Steering wheel heating button,not activated,
IDE02744-MAS09775,Steering wheel heater-Steering wheel temp.,Initializing,
IDE03008-MAS02193,Stop process prevented-Outside air temperature,not active,
IDE03008-MAS04055,Stop process prevented-Usable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery charge condition too low,not active,
IDE03008-MAS04059,Stop process prevented-Battery temperature,not active,
IDE03008-MAS04060,Stop process prevented-Other reasons active,not active,
IDE03008-MAS04061,Stop process prevented-Idle speed increase active,not active,
IDE03008-MAS04062,Stop process prevented-Possible service life too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS09832,Stop process prevented-Intermittent operation,not active,
IDE03009-MAS01478,Start process requested-Insuff. voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04055,Start process requested-Usable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery charge condition too low,not active,
IDE03009-MAS04058,Start process requested-Service life expired,not active,
IDE03009-MAS04060,Start process requested-Other reasons active,not active,
IDE03009-MAS06003,Start process requested-Charging contingent,not active,
IDE03009-MAS06004,Start process requested-Special start requirements,not active,
IDE03010-MAS02193,Number of prevented stop processes-Outside air temperature,0,
IDE03010-MAS04055,Number of prevented stop processes-Usable battery charge too low,0,
IDE03010-MAS04056,Number of prevented stop processes-Battery charge condition too low,356,
IDE03010-MAS04059,Number of prevented stop processes-Battery temperature,451,
IDE03010-MAS04060,Number of prevented stop processes-Other reasons active,0,
IDE03010-MAS04061,Number of prevented stop processes-Idle speed increase active,0,
IDE03010-MAS04062,Number of prevented stop processes-Possible service life too short,198,
IDE03010-MAS06001,Number of prevented stop processes-Energy management special veto,0,
IDE03010-MAS09832,Number of prevented stop processes-Intermittent operation,0,
IDE03011-MAS01478,Number of requested start processes-Insuff. voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04055,Number of requested start processes-Usable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery charge condition too low,0,
IDE03011-MAS04058,Number of requested start processes-Service life expired,0,
IDE03011-MAS04060,Number of requested start processes-Other reasons active,0,
IDE03011-MAS06003,Number of requested start processes-Charging contingent,1,
IDE03011-MAS06004,Number of requested start processes-Special start requirements,0,
IDE03150-IDE14867,Readiness for bus sleep mode-Subgateway as firewall control module,Sleep mode,
IDE03150-SFT00001,Readiness for bus sleep mode-Engine Control Module 1,active,
IDE03150-SFT00002,Readiness for bus sleep mode-Transmission Control Module,active,
IDE03150-SFT00003,Readiness for bus sleep mode-Brakes 1,active,
IDE03150-SFT00003,Readiness for bus sleep mode-Brakes 1,Sleep mode,
IDE03150-SFT00006,Readiness for bus sleep mode-Seat Adjustment Passenger Side,Sleep mode,
IDE03150-SFT00007,Readiness for bus sleep mode-Display Control Unit,Sleep mode,
IDE03150-SFT00008,Readiness for bus sleep mode-Air Conditioning,Sleep mode,
IDE03150-SFT00009,Readiness for bus sleep mode-Central Electrics,active,
IDE03150-SFT00012,Readiness for bus sleep mode-Rear Axle Steering 2,Sleep mode,
IDE03150-SFT00017,Readiness for bus sleep mode-Engine Control Module 2,Sleep mode,
IDE03150-SFT00019,Readiness for bus sleep mode-Adaptive Cruise Control,Sleep mode,
IDE03150-SFT00021,Readiness for bus sleep mode-Airbag,Sleep mode,
IDE03150-SFT00021,Readiness for bus sleep mode-Airbag,active,
IDE03150-SFT00022,Readiness for bus sleep mode-Steering Column Electronics,active,
IDE03150-SFT00023,Readiness for bus sleep mode-Dash Board,active,
IDE03150-SFT00024,Readiness for bus sleep mode-Auxiliary Parking Heater,Sleep mode,
IDE03150-SFT00025,Readiness for bus sleep mode-Gateway,active,
IDE03150-SFT00027,Readiness for bus sleep mode-Active Steering,Sleep mode,
IDE03150-SFT00032,Readiness for bus sleep mode-High Beam Assistance,Sleep mode,
IDE03150-SFT00033,Readiness for bus sleep mode-Battery Energy Control Module 2,Sleep mode,
IDE03150-SFT00034,Readiness for bus sleep mode-All Wheel Control,active,
IDE03150-SFT00035,Readiness for bus sleep mode-Brake Boost,Sleep mode,
IDE03150-SFT00038,Readiness for bus sleep mode-Electronic Roof Control,Sleep mode,
IDE03150-SFT00039,Readiness for bus sleep mode-Display Control Unit Rear,Sleep mode,
IDE03150-SFT00040,Readiness for bus sleep mode-Climate Control Unit Rear,Sleep mode,
IDE03150-SFT00042,Readiness for bus sleep mode-Control Unit Wireless Charging,Sleep mode,
IDE03150-SFT00043,Readiness for bus sleep mode-Steering Column Locking,Sleep mode,
IDE03150-SFT00048,Readiness for bus sleep mode-Special Function 2,Sleep mode,
IDE03150-SFT00050,Readiness for bus sleep mode-Lock Electronics,Sleep mode,
IDE03150-SFT00054,Readiness for bus sleep mode-Seat Adjustment Driver Side,Sleep mode,
IDE03150-SFT00060,Readiness for bus sleep mode-Lane Change Assistant,Sleep mode,
IDE03150-SFT00061,Readiness for bus sleep mode-Special Function,Sleep mode,
IDE03150-SFT00066,Readiness for bus sleep mode-Door Electronics Driver Side,active,
IDE03150-SFT00068,Readiness for bus sleep mode-Steering Assistance,active,
IDE03150-SFT00070,Readiness for bus sleep mode-Central Module Comfort System,active,
IDE03150-SFT00072,Readiness for bus sleep mode-Seat Adjustment Rear Driver Side,Sleep mode,
IDE03150-SFT00074,Readiness for bus sleep mode-Rear light,Sleep mode,
IDE03150-SFT00077,Readiness for bus sleep mode-Löschkandidat_Datenübertragung Car2X,Sleep mode,
IDE03150-SFT00080,Readiness for bus sleep mode-Seat Adjustment 3rd Row,Sleep mode,
IDE03150-SFT00081,Readiness for bus sleep mode-Drive Motor Control Module,Sleep mode,
IDE03150-SFT00082,Readiness for bus sleep mode-Door Electronics Passenger Side,active,
IDE03150-SFT00090,Readiness for bus sleep mode-Longitudinal control,Sleep mode,
IDE03150-SFT00091,Readiness for bus sleep mode-Seat Adjustment Rear Passenger Side,Sleep mode,
IDE03150-SFT00095,Readiness for bus sleep mode-Information Control Unit 1,active,
IDE03150-SFT00101,Readiness for bus sleep mode-Tire Pressure Monitoring 1,Sleep mode,
IDE03150-SFT00105,Readiness for bus sleep mode-Trailer Function,Sleep mode,
IDE03150-SFT00107,Readiness for bus sleep mode-Aerodynamics Control Unit,Sleep mode,
IDE03150-SFT00108,Readiness for bus sleep mode-Camera System Rear View,active,
IDE03150-SFT00109,Readiness for bus sleep mode-Deck Lid Control Unit,Sleep mode,
IDE03150-SFT00116,Readiness for bus sleep mode-Chassis Control,Sleep mode,
IDE03150-SFT00118,Readiness for bus sleep mode-Parking Assistance,Sleep mode,
IDE03150-SFT00127,Readiness for bus sleep mode-Information Control Unit 2,Sleep mode,
IDE03150-SFT00128,Readiness for bus sleep mode-Battery Regulation Auxiliary Accumulator 1,Sleep mode,
IDE03150-SFT00129,Readiness for bus sleep mode-Gear Shift Control Module,active,
IDE03150-SFT00130,Readiness for bus sleep mode-Head Up Display,Sleep mode,
IDE03150-SFT00132,Readiness for bus sleep mode-Night Vision,Sleep mode,
IDE03150-SFT00139,Readiness for bus sleep mode-Adaptive Cruise Control 2,Sleep mode,
IDE03150-SFT00140,Readiness for bus sleep mode-Battery Energy Control Module,Sleep mode,
IDE03150-SFT00165,Readiness for bus sleep mode-Front Sensors Driver Assistance System,Sleep mode,
IDE03150-SFT00166,Readiness for bus sleep mode-Microphone Control Unit,Sleep mode,
IDE03150-SFT00169,Readiness for bus sleep mode-Actuator For Structure-borne Sound,Sleep mode,
IDE03150-SFT00172,Readiness for bus sleep mode-Reductant Control Module,Sleep mode,
IDE03150-SFT00183,Readiness for bus sleep mode-Access Startsystem Interface,Sleep mode,
IDE03150-SFT00186,Readiness for bus sleep mode-Assembly Mounting,Sleep mode,
IDE03150-SFT00192,Readiness for bus sleep mode-Actuator For Exterior Noise,Sleep mode,
IDE03150-SFT00195,Readiness for bus sleep mode-Drive Motor Control Module 3,Sleep mode,
IDE03150-SFT00196,Readiness for bus sleep mode-DC/DC Converter Control Module,Sleep mode,
IDE03150-SFT00197,Readiness for bus sleep mode-Thermal management,Sleep mode,
IDE03150-SFT00198,Readiness for bus sleep mode-Battery Charger Control Module,Sleep mode,
IDE03150-SFT00203,Readiness for bus sleep mode-Rear Axle Steering,Sleep mode,
IDE03150-SFT00205,Readiness for bus sleep mode-Laser Scanner,Sleep mode,
IDE03150-SFT00206,Readiness for bus sleep mode-Drive Motor Control Module 2,Sleep mode,
IDE03150-SFT00207,Readiness for bus sleep mode-Control Unit Lane Change Assistant 2,Sleep mode,
IDE03150-SFT00208,Readiness for bus sleep mode-Front Axle Lift System,Sleep mode,
IDE03150-SFT00219,Readiness for bus sleep mode-Front Corner Radar 1,Sleep mode,
IDE03150-SFT00220,Readiness for bus sleep mode-Front Corner Radar 2,Sleep mode,
IDE03150-SFT00221,Readiness for bus sleep mode-Control Module 2 For Sunroof,Sleep mode,
IDE03150-SFT33031,Readiness for bus sleep mode-Antenna Control Module,Sleep mode,
IDE03150-SFT33232,Readiness for bus sleep mode-Central control for digital matrix light,Sleep mode,
IDE03150-SFT09760,Readiness for bus sleep mode-Sun Roof,Sleep mode,
IDE03205,Manufacturer code,SME,
IDE03212,Start-stop conditions,Stop release,
IDE03213,Start-stop enabling,No release by coordinator,
IDE03477-MAS00106,GPS time-Year,Not available,
IDE03477-MAS00107,GPS time-Month,Not available,
IDE03477-MAS00108,GPS time-Day,Not available,
IDE03477-MAS00109,GPS time-Hours,Not available,
IDE03477-MAS00110,GPS time-Minutes,Not available,
IDE03477-MAS00111,GPS time-Seconds,Not available,
IDE03477-MAS01632,GPS time-Status,invalid,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery malfunction,no error,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,no error,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,no error,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,no error,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,no error,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,no error,
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Not available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,invalid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 03 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition not met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,Yes,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,Condition not met,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,A1 3C 3F 3E DB 3B C7 26 46 C8 A4 60 86 76 E2 B2 7C 49 E0 E1 7A 1D 94 D7 C5 3B C1 67 2D A4 14 CC CE 63 6F 13 57 0D FE 90 D7 72 D3 56 2B 8C 68 43 6E 73 E2 EE 50 F7 11 EE 51 46 49 F7 16 0E CB 5B 98 D2 66 93 17 79 C4 43 92 9A A9 A5 57 8A EC F1 CD FC 78 C7 97 B0 84 0E A8 B0 B0 FF 3C 28 8C 12 45 E1 7D 0E 3B 73 4E DD DF 49 90 9E 8E 8C 19 6A A7 F7 AC D9 2C 26 5D B5 E4 B2 68 17 B3 C3 76 73 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04343-IDE14867,Bus identification-Subgateway as firewall control module,Unknown,
IDE04343-SFT00001,Bus identification-Engine Control Module 1,Data bus Flexray A,
IDE04343-SFT00002,Bus identification-Transmission Control Module,Data bus Flexray A,
IDE04343-SFT00003,Bus identification-Brakes 1,Unknown,
IDE04343-SFT00003,Bus identification-Brakes 1,Data bus Flexray A,
IDE04343-SFT00006,Bus identification-Seat Adjustment Passenger Side,Comfort data bus,
IDE04343-SFT00007,Bus identification-Display Control Unit,Data bus Sensor/Hybrid,
IDE04343-SFT00008,Bus identification-Air Conditioning,Data bus Sensor/Hybrid,
IDE04343-SFT00009,Bus identification-Central Electrics,Comfort data bus,
IDE04343-SFT00012,Bus identification-Rear Axle Steering 2,Unknown,
IDE04343-SFT00017,Bus identification-Engine Control Module 2,Data bus Flexray A,
IDE04343-SFT00019,Bus identification-Adaptive Cruise Control,Data bus Flexray A,
IDE04343-SFT00021,Bus identification-Airbag,Unknown,
IDE04343-SFT00021,Bus identification-Airbag,Data bus Flexray A,
IDE04343-SFT00022,Bus identification-Steering Column Electronics,Data bus Flexray A,
IDE04343-SFT00023,Bus identification-Dash Board,Databus Infotainment,
IDE04343-SFT00024,Bus identification-Auxiliary Parking Heater,Databus extended,
IDE04343-SFT00025,Bus identification-Gateway,Busmaster,
IDE04343-SFT00027,Bus identification-Active Steering,Data bus Flexray A,
IDE04343-SFT00032,Bus identification-High Beam Assistance,Databus extended,
IDE04343-SFT00033,Bus identification-Battery Energy Control Module 2,Data bus Sensor/Hybrid,
IDE04343-SFT00034,Bus identification-All Wheel Control,Data bus Flexray A,
IDE04343-SFT00035,Bus identification-Brake Boost,Data bus Flexray A,
IDE04343-SFT00038,Bus identification-Electronic Roof Control,Comfort data bus,
IDE04343-SFT00039,Bus identification-Display Control Unit Rear,Data bus Sensor/Hybrid,
IDE04343-SFT00040,Bus identification-Climate Control Unit Rear,Data bus Sensor/Hybrid,
IDE04343-SFT00042,Bus identification-Control Unit Wireless Charging,Data bus Sensor/Hybrid,
IDE04343-SFT00043,Bus identification-Steering Column Locking,Comfort data bus,
IDE04343-SFT00048,Bus identification-Special Function 2,Comfort data bus,
IDE04343-SFT00050,Bus identification-Lock Electronics,Data bus Flexray A,
IDE04343-SFT00054,Bus identification-Seat Adjustment Driver Side,Comfort data bus,
IDE04343-SFT00060,Bus identification-Lane Change Assistant,Databus extended,
IDE04343-SFT00060,Bus identification-Lane Change Assistant,Unknown,
IDE04343-SFT00061,Bus identification-Special Function,Comfort data bus,
IDE04343-SFT00066,Bus identification-Door Electronics Driver Side,Comfort data bus,
IDE04343-SFT00068,Bus identification-Steering Assistance,Data bus Flexray A,
IDE04343-SFT00070,Bus identification-Central Module Comfort System,Comfort data bus,
IDE04343-SFT00072,Bus identification-Seat Adjustment Rear Driver Side,Comfort data bus,
IDE04343-SFT00074,Bus identification-Rear light,Unknown,
IDE04343-SFT00077,Bus identification-Löschkandidat_Datenübertragung Car2X,Unknown,
IDE04343-SFT00080,Bus identification-Seat Adjustment 3rd Row,Comfort data bus,
IDE04343-SFT00081,Bus identification-Drive Motor Control Module,Data bus Flexray A,
IDE04343-SFT00081,Bus identification-Drive Motor Control Module,Data bus Sensor/Hybrid,
IDE04343-SFT00082,Bus identification-Door Electronics Passenger Side,Comfort data bus,
IDE04343-SFT00090,Bus identification-Longitudinal control,Data bus Flexray A,
IDE04343-SFT00091,Bus identification-Seat Adjustment Rear Passenger Side,Comfort data bus,
IDE04343-SFT00095,Bus identification-Information Control Unit 1,Databus Infotainment,
IDE04343-SFT00101,Bus identification-Tire Pressure Monitoring 1,Databus extended,
IDE04343-SFT00105,Bus identification-Trailer Function,Comfort data bus,
IDE04343-SFT00107,Bus identification-Aerodynamics Control Unit,Comfort data bus,
IDE04343-SFT00108,Bus identification-Camera System Rear View,Databus extended,
IDE04343-SFT00109,Bus identification-Deck Lid Control Unit,Comfort data bus,
IDE04343-SFT00116,Bus identification-Chassis Control,Data bus Flexray A,
IDE04343-SFT00118,Bus identification-Parking Assistance,Unknown,
IDE04343-SFT00127,Bus identification-Information Control Unit 2,Unknown,
IDE04343-SFT00128,Bus identification-Battery Regulation Auxiliary Accumulator 1,Data bus Sensor/Hybrid,
IDE04343-SFT00129,Bus identification-Gear Shift Control Module,Databus Infotainment,
IDE04343-SFT00130,Bus identification-Head Up Display,Databus Infotainment,
IDE04343-SFT00132,Bus identification-Night Vision,Databus extended,
IDE04343-SFT00139,Bus identification-Adaptive Cruise Control 2,Data bus Flexray A,
IDE04343-SFT00140,Bus identification-Battery Energy Control Module,Data bus Sensor/Hybrid,
IDE04343-SFT00165,Bus identification-Front Sensors Driver Assistance System,Unknown,
IDE04343-SFT00165,Bus identification-Front Sensors Driver Assistance System,Data bus Flexray A,
IDE04343-SFT00166,Bus identification-Microphone Control Unit,Databus Infotainment,
IDE04343-SFT00169,Bus identification-Actuator For Structure-borne Sound,Databus extended,
IDE04343-SFT00172,Bus identification-Reductant Control Module,Databus extended,
IDE04343-SFT00183,Bus identification-Access Startsystem Interface,Unknown,
IDE04343-SFT00186,Bus identification-Assembly Mounting,Data bus Sensor/Hybrid,
IDE04343-SFT00192,Bus identification-Actuator For Exterior Noise,Databus extended,
IDE04343-SFT00195,Bus identification-Drive Motor Control Module 3,Unknown,
IDE04343-SFT00196,Bus identification-DC/DC Converter Control Module,Data bus Sensor/Hybrid,
IDE04343-SFT00197,Bus identification-Thermal management,Data bus Sensor/Hybrid,
IDE04343-SFT00198,Bus identification-Battery Charger Control Module,Data bus Sensor/Hybrid,
IDE04343-SFT00203,Bus identification-Rear Axle Steering,Data bus Flexray A,
IDE04343-SFT00205,Bus identification-Laser Scanner,Unknown,
IDE04343-SFT00206,Bus identification-Drive Motor Control Module 2,Unknown,
IDE04343-SFT00207,Bus identification-Control Unit Lane Change Assistant 2,Unknown,
IDE04343-SFT00207,Bus identification-Control Unit Lane Change Assistant 2,Databus extended,
IDE04343-SFT00208,Bus identification-Front Axle Lift System,Unknown,
IDE04343-SFT00219,Bus identification-Front Corner Radar 1,Unknown,
IDE04343-SFT00220,Bus identification-Front Corner Radar 2,Unknown,
IDE04343-SFT00221,Bus identification-Control Module 2 For Sunroof,Unknown,
IDE04343-SFT33031,Bus identification-Antenna Control Module,Unknown,
IDE04343-SFT33232,Bus identification-Central control for digital matrix light,Unknown,
IDE04343-SFT09760,Bus identification-Sun Roof,Comfort data bus,
IDE04605-IDE01712,Navigation: Corrected position-GPS Position,Not available,
IDE04605-MAS01779,Navigation: Corrected position-Length,2D 38 31 31 34 34 37 38 33 00 00 00 00 00,
IDE04605-MAS01780,Navigation: Corrected position-Width,34 31 33 31 30 30 34 35 00 00 00 00 00 00,
IDE04605-MAS04183,Navigation: Corrected position-Position error,0, m
IDE04750-MAS03876,SIM cards-active SIM card,internal,
IDE04750-MAS03877,SIM cards-SIM ID,148630001620670,
IDE04750-MAS03878,SIM cards-SIM IMSI,310170208862989,
IDE04750-MAS04226,SIM cards-Telephone number,,
IDE04750-MAS08401,SIM cards-SIM intern,Available,
IDE04750-MAS08402,SIM cards-SIM extern,Not available,
IDE04790,Call for help button,Not available,
IDE04806-MAS10929,Driving profile selection button-Button for load profile selection,not activated,
IDE04806-MAS10937,Driving profile selection button-Driving profile selection button 1,not activated,
IDE04806-MAS10938,Driving profile selection button-Driving profile selection button 2,not activated,
IDE04806-MAS10939,Driving profile selection button-Drive profile selection rotary switch,no function,
IDE05430,Telephone serial number,148630001620670,
IDE05583-IDE09851,Pause recommendation-Function active,Yes,
IDE05583-MAS03095,Pause recommendation-Function status,not installed,
IDE05583-MAS04622,Pause recommendation-Break recommend. message,No display,
IDE05583-MAS13273,Pause recommendation-deactivation status,not installed,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG05007,Driving profile selection: system status-profile_state_1,engaged,
IDE05740-ENG05008,Driving profile selection: system status-profile_state_2,engaged,
IDE05740-ENG05009,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG05010,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG05011,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG05012,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG05013,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG05014,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,FC C0 85 AA E6,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,no entry,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,no entry,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,Engine Control Module (ECM),
IDE06007-MAS00106,Driving profile history data 1-Year,2000, yr
IDE06007-MAS00107,Driving profile history data 1-Month,0, m
IDE06007-MAS00108,Driving profile history data 1-Day,0, d
IDE06007-MAS00109,Driving profile history data 1-Hours,0, H
IDE06007-MAS00110,Driving profile history data 1-Minutes,0, min
IDE06007-MAS00111,Driving profile history data 1-Seconds,0, s
IDE06007-MAS00711,Driving profile history data 1-Odometer reading,0, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initializing,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,no entry,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,no entry,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,Start-stop,
IDE06008-MAS00106,Driving profile history data 2-Year,2000, yr
IDE06008-MAS00107,Driving profile history data 2-Month,0, m
IDE06008-MAS00108,Driving profile history data 2-Day,0, d
IDE06008-MAS00109,Driving profile history data 2-Hours,0, H
IDE06008-MAS00110,Driving profile history data 2-Minutes,0, min
IDE06008-MAS00111,Driving profile history data 2-Seconds,0, s
IDE06008-MAS00711,Driving profile history data 2-Odometer reading,0, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Initializing,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,no entry,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,no entry,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,no entry,
IDE06009-MAS00106,Driving profile history data 3-Year,2000, yr
IDE06009-MAS00107,Driving profile history data 3-Month,0, m
IDE06009-MAS00108,Driving profile history data 3-Day,0, d
IDE06009-MAS00109,Driving profile history data 3-Hours,0, H
IDE06009-MAS00110,Driving profile history data 3-Minutes,0, min
IDE06009-MAS00111,Driving profile history data 3-Seconds,0, s
IDE06009-MAS00711,Driving profile history data 3-Odometer reading,0, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Initializing,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,no entry,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,no entry,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,no entry,
IDE06010-MAS00106,Driving profile history data 4-Year,2000, yr
IDE06010-MAS00107,Driving profile history data 4-Month,0, m
IDE06010-MAS00108,Driving profile history data 4-Day,0, d
IDE06010-MAS00109,Driving profile history data 4-Hours,0, H
IDE06010-MAS00110,Driving profile history data 4-Minutes,0, min
IDE06010-MAS00111,Driving profile history data 4-Seconds,0, s
IDE06010-MAS00711,Driving profile history data 4-Odometer reading,0, km
IDE06010-MAS03095,Driving profile history data 4-Function status,Initializing,
IDE06011-ENG04999,Selected driving profile-driving_profile_1,Profile 2,
IDE06011-ENG05000,Selected driving profile-driving_profile_2,no function,
IDE06011-ENG05001,Selected driving profile-driving_profile_3,Profile 1,
IDE06011-ENG05002,Selected driving profile-driving_profile_4,no function,
IDE06011-ENG05003,Selected driving profile-driving_profile_5,no function,
IDE06011-ENG05004,Selected driving profile-driving_profile_6,no function,
IDE06011-ENG05005,Selected driving profile-driving_profile_7,no function,
IDE06011-ENG05006,Selected driving profile-driving_profile_8,no function,
IDE06165-ENG118695,Driving profile selection statistics-Profile_1,1930542892, min
IDE06165-ENG126249,Driving profile selection statistics-profile_10,0, min
IDE06165-ENG126250,Driving profile selection statistics-profile_11,0, min
IDE06165-ENG127921,Driving profile selection statistics-profile_12,0, min
IDE06165-ENG04216,Driving profile selection statistics-profile_13,0, min
IDE06165-ENG04217,Driving profile selection statistics-profile_14,0, min
IDE06165-ENG04218,Driving profile selection statistics-profile_15,0, min
IDE06165-ENG118696,Driving profile selection statistics-Profile_2,14557, min
IDE06165-ENG118697,Driving profile selection statistics-Profile_3,19725, min
IDE06165-ENG118698,Driving profile selection statistics-Profile_4,0, min
IDE06165-ENG118699,Driving profile selection statistics-Profile_5,0, min
IDE06165-ENG118700,Driving profile selection statistics-Profile_6,661, min
IDE06165-ENG118701,Driving profile selection statistics-Profile_7,352, min
IDE06165-ENG118702,Driving profile selection statistics-Profile_8,0, min
IDE06165-ENG126248,Driving profile selection statistics-profile_9,0, min
IDE06230-MAS00106,Break recommend.: last message-Year,2000, yr
IDE06230-MAS00107,Break recommend.: last message-Month,1, m
IDE06230-MAS00108,Break recommend.: last message-Day,1, d
IDE06230-MAS00109,Break recommend.: last message-Hours,0, H
IDE06230-MAS00110,Break recommend.: last message-Minutes,0, min
IDE06230-MAS00111,Break recommend.: last message-Seconds,0, s
IDE06230-MAS03095,Break recommend.: last message-Function status,Initializing,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,no warning,
IDE06264-IDE09057,Deep discharge protection-HV battery charge state,ERROR,
IDE06264-MAS04721,Deep discharge protection-Minimum charge level,ERROR,
IDE06264-MAS13070,Deep discharge protection-High-voltage energy management shut-down stage,not active,
IDE06307-MAS00106,Stop prevention history data-Year,2019,
IDE06307-MAS00107,Stop prevention history data-Month,7,
IDE06307-MAS00108,Stop prevention history data-Day,6,
IDE06307-MAS00109,Stop prevention history data-Hours,18,
IDE06307-MAS00110,Stop prevention history data-Minutes,20,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Battery charge condition too low,
IDE06308-MAS00106,Start request history data-Year,2019,
IDE06308-MAS00107,Start request history data-Month,2,
IDE06308-MAS00108,Start request history data-Day,17,
IDE06308-MAS00109,Start request history data-Hours,12,
IDE06308-MAS00110,Start request history data-Minutes,59,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308,Start request history data,Charging contingent,
IDE06308,Start request history data,not active,
IDE06522,Temperature of phone unit,37, °C
IDE06577,Supplier Identification,Conti Temic microelectronic GmbH,
IDE06805-MAS09523,Status of voltage freedom-Transformer for electrical drive,Initializing,
IDE06805-MAS09524,Status of voltage freedom-Hybrid Battery Management,Initializing,
IDE06805-MAS09525,Status of voltage freedom-Ctrl. mod. for contactless charging,Initializing,
IDE06805-MAS09526,Status of voltage freedom-High-voltage battery charger,Initializing,
IDE06805-MAS11874,Status of voltage freedom-Overall status,Initializing,
IDE06805-SFT00195,Status of voltage freedom-Drive Motor Control Module 3,Initializing,
IDE06805-SFT00206,Status of voltage freedom-Drive Motor Control Module 2,Initializing,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,02,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,not stored,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,not activated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,3,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,2,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,22,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,0,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,2,
IDE07427-IDE04447,Status: driving profile selection for power steering-Function status,engaged,
IDE07427-IDE06260,Status: driving profile selection for power steering-ID number,28,
IDE07427-MAS01156,Status: driving profile selection for power steering-Communication status,OK,
IDE07427-MAS01447,Status: driving profile selection for power steering-Act.val.,2,
IDE07428-IDE04447,Status: driving profile selection for damping adjustment-Function status,not engaged,
IDE07428-IDE06260,Status: driving profile selection for damping adjustment-ID number,44,
IDE07428-MAS01156,Status: driving profile selection for damping adjustment-Communication status,OK,
IDE07428-MAS01447,Status: driving profile selection for damping adjustment-Act.val.,0,
IDE07429-IDE04447,Status: driving profile selection for A/C-Function status,engaged,
IDE07429-IDE06260,Status: driving profile selection for A/C-ID number,251,
IDE07429-MAS01156,Status: driving profile selection for A/C-Communication status,OK,
IDE07429-MAS01447,Status: driving profile selection for A/C-Act.val.,0,
IDE07430-IDE04447,Status: driving profile selection for adaptive cruise control-Function status,not engaged,
IDE07430-IDE06260,Status: driving profile selection for adaptive cruise control-ID number,249,
IDE07430-MAS01156,Status: driving profile selection for adaptive cruise control-Communication status,OK,
IDE07430-MAS01447,Status: driving profile selection for adaptive cruise control-Act.val.,0,
IDE07431-IDE04447,Status: driv prof.select.for corn.light & headlamp range ctrl-Function status,not engaged,
IDE07431-IDE06260,Status: driv prof.select.for corn.light & headlamp range ctrl-ID number,0,
IDE07431-MAS01156,Status: driv prof.select.for corn.light & headlamp range ctrl-Communication status,OK,
IDE07431-MAS01447,Status: driv prof.select.for corn.light & headlamp range ctrl-Act.val.,0,
IDE07432-IDE04447,Status: driving profile selection for structure-borne noise-Function status,not engaged,
IDE07432-IDE06260,Status: driving profile selection for structure-borne noise-ID number,0,
IDE07432-MAS01156,Status: driving profile selection for structure-borne noise-Communication status,OK,
IDE07432-MAS01447,Status: driving profile selection for structure-borne noise-Act.val.,0,
IDE07433-IDE04447,Status: driving profile selection for ambient lighting-Function status,engaged,
IDE07433-IDE06260,Status: driving profile selection for ambient lighting-ID number,35,
IDE07433-MAS01156,Status: driving profile selection for ambient lighting-Communication status,OK,
IDE07433-MAS01447,Status: driving profile selection for ambient lighting-Act.val.,0,
IDE07434-IDE04447,Status: driving profile selection for belt tensioner-Function status,engaged,
IDE07434-IDE06260,Status: driving profile selection for belt tensioner-ID number,0,
IDE07434-MAS01156,Status: driving profile selection for belt tensioner-Communication status,OK,
IDE07434-MAS01447,Status: driving profile selection for belt tensioner-Act.val.,2,
IDE07436-IDE04447,Status: driving profile selection for free-running hub-Function status,not engaged,
IDE07436-IDE06260,Status: driving profile selection for free-running hub-ID number,0,
IDE07436-MAS01156,Status: driving profile selection for free-running hub-Communication status,OK,
IDE07436-MAS01447,Status: driving profile selection for free-running hub-Act.val.,0,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stoppage time,max.value,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,5, A
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,ended,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,9.60, V
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not recognized,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not recognized,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,0.85, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,0.90, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,ERROR,
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,704, A
IDE07847-MAS00976,Start stop requests without reason-Counter,38929,
IDE07873-MAS06193,FPA enabled profiles-Profile 1,Comfort,
IDE07873-MAS06194,FPA enabled profiles-Profile 2,AUTO,
IDE07873-MAS06195,FPA enabled profiles-Profile 3,Dynamic,
IDE07873-MAS06196,FPA enabled profiles-Profile 4,Not Used,
IDE07873-MAS06197,FPA enabled profiles-Profile 5,Not Used,
IDE07873-MAS06198,FPA enabled profiles-Profile 6,Lift,
IDE07873-MAS06199,FPA enabled profiles-Profile 7,INDIVIDUAL,
IDE07873-MAS06200,FPA enabled profiles-Profile 8,Not Used,
IDE07873-MAS08875,FPA enabled profiles-Profile 9,Not Used,
IDE07873-MAS08876,FPA enabled profiles-Profile 10,Not Used,
IDE07873-MAS08877,FPA enabled profiles-Profile 11,Not Used,
IDE07873-MAS08878,FPA enabled profiles-Profile 12,Not Used,
IDE07873-MAS08879,FPA enabled profiles-Profile 13,Not Used,
IDE07873-MAS08880,FPA enabled profiles-Profile 14,Not Used,
IDE07873-MAS08881,FPA enabled profiles-Profile 15,Not Used,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,04,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status GSG,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ELV,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,00,
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,00,
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,00,
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,00,
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,00,
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,257,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08251-MAS01483,Configuration immobilizer-Softwareversion,00 00 00,
IDE08251-MAS02832,Configuration immobilizer-Malfunction status,00,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,53 00 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,05,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,0E,
IDE08251-MAS06850,Configuration immobilizer-Supported power class 2,00,
IDE08251-MAS06851,Configuration immobilizer-Supported power class 3,00,
IDE08251-MAS06852,Configuration immobilizer-Supported power class 4,00,
IDE08251-MAS06853,Configuration immobilizer-Supported power class 5,00,
IDE08343,Immobilizer Challenge,E5 CB D4 D4,
IDE08355-IDE04447,Status: driving profile selection for external noise actuator-Function status,not engaged,
IDE08355-IDE06260,Status: driving profile selection for external noise actuator-ID number,0,
IDE08355-MAS01156,Status: driving profile selection for external noise actuator-Communication status,OK,
IDE08355-MAS01447,Status: driving profile selection for external noise actuator-Act.val.,0,
IDE08490,Activation of diagnosis via ethernet,not active,
IDE08530-MAS00106,Connection status online basic services-Year,2019, yr
IDE08530-MAS00107,Connection status online basic services-Month,7, m
IDE08530-MAS00108,Connection status online basic services-Day,12, d
IDE08530-MAS00109,Connection status online basic services-Hours,13, H
IDE08530-MAS00110,Connection status online basic services-Minutes,48, min
IDE08530-MAS00111,Connection status online basic services-Seconds,1, s
IDE08530-MAS07130,Connection status online basic services-Number of ID steps,14,
IDE08530-MAS07131,Connection status online basic services-ID steps,0,
IDE08530-MAS07132,Connection status online basic services-Code status,30,
IDE08531-MAS00106,Connection status online license services-Year,Not available,
IDE08531-MAS00107,Connection status online license services-Month,Not available,
IDE08531-MAS00108,Connection status online license services-Day,Not available,
IDE08531-MAS00109,Connection status online license services-Hours,Not available,
IDE08531-MAS00110,Connection status online license services-Minutes,Not available,
IDE08531-MAS07132,Connection status online license services-Code status,1792255,
IDE08531-MAS07133,Connection status online license services-No. of license serv.,14,
IDE08531-MAS07134,Connection status online license services-ID services,8704,
IDE08531-MAS07135,Connection status online license services-Activation status,Not available,
IDE08531-MAS07136,Connection status online license services-Exp. year,Not available,
IDE08531-MAS07137,Connection status online license services-Exp. month,Not available,
IDE08531-MAS07138,Connection status online license services-Exp. day,1, d
IDE08600-IDE04447,Status drive profile selec. for rear-wheel drive-Function status,not engaged,
IDE08600-IDE06260,Status drive profile selec. for rear-wheel drive-ID number,5,
IDE08600-MAS01156,Status drive profile selec. for rear-wheel drive-Communication status,OK,
IDE08600-MAS01447,Status drive profile selec. for rear-wheel drive-Act.val.,0,
IDE08601-IDE04447,Drive profile selection for actuator for exterior noise-Function status,engaged,
IDE08601-IDE06260,Drive profile selection for actuator for exterior noise-ID number,0,
IDE08601-MAS01156,Drive profile selection for actuator for exterior noise-Communication status,OK,
IDE08601-MAS01447,Drive profile selection for actuator for exterior noise-Act.val.,0,
IDE08602-IDE04447,Status drive profile selec. for active steering-Function status,not engaged,
IDE08602-IDE06260,Status drive profile selec. for active steering-ID number,2,
IDE08602-MAS01156,Status drive profile selec. for active steering-Communication status,OK,
IDE08602-MAS01447,Status drive profile selec. for active steering-Act.val.,0,
IDE08605-IDE04447,Status drive profile for level control system-Function status,not engaged,
IDE08605-IDE06260,Status drive profile for level control system-ID number,12,
IDE08605-MAS01156,Status drive profile for level control system-Communication status,OK,
IDE08605-MAS01447,Status drive profile for level control system-Act.val.,0,
IDE08611-IDE04447,Status drive profile for stabilizer-Function status,engaged,
IDE08611-IDE06260,Status drive profile for stabilizer-ID number,0,
IDE08611-MAS01156,Status drive profile for stabilizer-Communication status,OK,
IDE08611-MAS01447,Status drive profile for stabilizer-Act.val.,0,
IDE08614-IDE04447,Status drive profile for engine operating conditions-Function status,not engaged,
IDE08614-IDE06260,Status drive profile for engine operating conditions-ID number,0,
IDE08614-MAS01156,Status drive profile for engine operating conditions-Communication status,OK,
IDE08614-MAS01447,Status drive profile for engine operating conditions-Act.val.,0,
IDE08687-IDE04447,Status: driving profile select. for brake ctrl. sys.-Function status,engaged,
IDE08687-IDE06260,Status: driving profile select. for brake ctrl. sys.-ID number,0,
IDE08687-MAS01156,Status: driving profile select. for brake ctrl. sys.-Communication status,OK,
IDE08687-MAS01447,Status: driving profile select. for brake ctrl. sys.-Act.val.,2,
IDE08796-IDE04447,Status: driving profile selec. for hill descent control-Function status,engaged,
IDE08796-IDE06260,Status: driving profile selec. for hill descent control-ID number,0,
IDE08796-MAS01156,Status: driving profile selec. for hill descent control-Communication status,OK,
IDE08796-MAS01447,Status: driving profile selec. for hill descent control-Act.val.,0,
IDE08798-IDE04447,Status: drive profile for Matrix-Beam-Function status,engaged,
IDE08798-IDE06260,Status: drive profile for Matrix-Beam-ID number,0,
IDE08798-MAS01156,Status: drive profile for Matrix-Beam-Communication status,OK,
IDE08798-MAS01447,Status: drive profile for Matrix-Beam-Act.val.,0,
IDE08799-IDE04447,Status: driv. profile selec. for rear spoiler-Function status,not engaged,
IDE08799-IDE06260,Status: driv. profile selec. for rear spoiler-ID number,0,
IDE08799-MAS01156,Status: driv. profile selec. for rear spoiler-Communication status,OK,
IDE08799-MAS01447,Status: driv. profile selec. for rear spoiler-Act.val.,0,
IDE08804-IDE04447,Status: driv. profile selec. for ctr. differential-Function status,engaged,
IDE08804-IDE06260,Status: driv. profile selec. for ctr. differential-ID number,0,
IDE08804-MAS01156,Status: driv. profile selec. for ctr. differential-Communication status,OK,
IDE08804-MAS01447,Status: driv. profile selec. for ctr. differential-Act.val.,2,
IDE08956-MAS08051,H-V power distro-Power quota: thermal management,6400, W
IDE08956-MAS08052,H-V power distro-Power quota: 12 V electrical system,1500, W
IDE08956-MAS08054,H-V power distro-Power quota: comfort loads,3000, W
IDE08956-MAS13094,H-V power distro-Power allocation by engine electronics,ERROR,
IDE08956-MAS13095,H-V power distro-Power allocation by high-voltage battery charger,ERROR,
IDE08956-MAS13096,H-V power distro-Power allocation by hybrid battery management,ERROR,
IDE08956-MAS13097,H-V power distro-Power drawn by voltage transformer for electric drive,ERROR,
IDE08956-MAS13098,H-V power distro-Power drawn by thermal management,ERROR,
IDE09074-MAS01078,Vehicle properties-Vehicle type,Conventional combustion engine,
IDE09074-MAS08256,Vehicle properties-Max energy content,36700,
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),18.00,
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,7.00, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,20.00,
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,34.00, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,700, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,0, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,6.00,
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,10.00, l/100km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,486, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,0, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,25, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,486, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,486, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,ERROR,
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,ERROR,
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,ERROR,
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,305, km
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,305, km
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,not installed,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,miles,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,9.00, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,8.00, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,7.00, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,7.00, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,8.00, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,6.00, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,7.00, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,20.00,
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,20.00,
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,20.00,
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,20.00,
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,20.00,
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,20.00,
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,20.00,
IDE09080-MAS12005,Energy storage unit-Tank capacity with conventional fuel for range calculation,35.00, l
IDE09080-MAS12006,Energy storage unit-Energy content of HV battery for range calculation,0,
IDE09080-MAS12007,Energy storage unit-Tank capacity with CNG for range calculation,0.00, l
IDE09080-MAS12008,Energy storage unit-Tank capacity with LPG for range calculation,0.00, l
IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,Electrical OK,
IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,0, mA
IDE09293-MAS04344,Status of antenna 2 for phone-Reception level antenna 2,-113.00,
IDE09467,MAC address,00 36 F8 3E 7B 82,
IDE09468-MAS01390,IPv4 address-Block 1,0,
IDE09468-MAS01391,IPv4 address-Block 2,0,
IDE09468-MAS01392,IPv4 address-Block 3,0,
IDE09468-MAS01393,IPv4 address-Block 4,0,
IDE09469-MAS01390,IPv6 address-Block 1,00 00,
IDE09469-MAS01391,IPv6 address-Block 2,00 00,
IDE09469-MAS01392,IPv6 address-Block 3,00 00,
IDE09469-MAS01393,IPv6 address-Block 4,00 00,
IDE09469-MAS01394,IPv6 address-Block 5,00 00,
IDE09469-MAS01395,IPv6 address-Block 6,00 00,
IDE09469-MAS01396,IPv6 address-Block 7,00 00,
IDE09469-MAS01397,IPv6 address-Block 8,00 00,
IDE09891-SFT00081,Voltage converter for electric drive: status of electric drive-Drive Motor Control Module,Initializing,
IDE09891-SFT00195,Voltage converter for electric drive: status of electric drive-Drive Motor Control Module 3,Initializing,
IDE09891-SFT00206,Voltage converter for electric drive: status of electric drive-Drive Motor Control Module 2,Initializing,
IDE09892-MAS02832,Hybrid battery management: status of electric drive-Malfunction status,Initializing,
IDE09892-MAS03001,Hybrid battery management: status of electric drive-Mode,Initializing,
IDE09893-MAS17071,High voltage battery charger: status of electric drive-High-voltage charging management: current mode,Initializing,
IDE09893-MAS17072,High voltage battery charger: status of electric drive-High-voltage charging management: error status,Initializing,
IDE09894-MAS13356,Thermal management: status of electric drive-Error status additional air heating,Initializing,
IDE09894-MAS13357,Thermal management: status of electric drive-Mode additional air heating,Initializing,
IDE09894-MAS13358,Thermal management: status of electric drive-Error status A/C compressor,Initializing,
IDE09894-MAS13359,Thermal management: status of electric drive-Mode A/C compressor,Initializing,
IDE09895-MAS13099,Engine electronics: status of electric drive-Error status electric drive,Initializing,
IDE09895-MAS13100,Engine electronics: status of electric drive-Electric drive mode,Initializing,
IDE09895-MAS13101,Engine electronics: status of electric drive-Error status of electric machine,Initializing,
IDE09895-MAS13102,Engine electronics: status of electric drive-Electric machine mode,255,
IDE09896-MAS02832,Ctrl. module for contactless charging: status of electric drive-Malfunction status,Initializing,
IDE09896-MAS03001,Ctrl. module for contactless charging: status of electric drive-Mode,Initializing,
IDE09897-MAS02246,Volt. converter for elec. drive: high-volt. activ. restrict.-Timeout,not active,
IDE09897-MAS09518,Volt. converter for elec. drive: high-volt. activ. restrict.-Safety line,not active,
IDE09897-MAS09519,Volt. converter for elec. drive: high-volt. activ. restrict.-Message error,not active,
IDE09897-MAS09542,Volt. converter for elec. drive: high-volt. activ. restrict.-Error status init. error,not active,
IDE09897-MAS09544,Volt. converter for elec. drive: high-volt. activ. restrict.-No component function,not active,
IDE09897-MAS09546,Volt. converter for elec. drive: high-volt. activ. restrict.-Voltage disconnect. init. error,not active,
IDE09897-MAS12345,Volt. converter for elec. drive: high-volt. activ. restrict.-Active discharge fault,not active,
IDE09898-MAS02246,Hybrid batt. management:  H-V activ. restriction-Timeout,not active,
IDE09898-MAS03123,Hybrid batt. management:  H-V activ. restriction-Reduced performance,not active,
IDE09898-MAS09513,Hybrid batt. management:  H-V activ. restriction-Insulation test stage 1 failed,not active,
IDE09898-MAS09514,Hybrid batt. management:  H-V activ. restriction-Insulation test stage 2 failed,not active,
IDE09898-MAS09518,Hybrid batt. management:  H-V activ. restriction-Safety line,not active,
IDE09898-MAS09519,Hybrid batt. management:  H-V activ. restriction-Message error,not active,
IDE09898-MAS09520,Hybrid batt. management:  H-V activ. restriction-Safety connector,not active,
IDE09898-MAS09541,Hybrid batt. management:  H-V activ. restriction-Act. mode init. error,not active,
IDE09898-MAS09542,Hybrid batt. management:  H-V activ. restriction-Error status init. error,not active,
IDE09898-MAS09543,Hybrid batt. management:  H-V activ. restriction-Operating mode error,not active,
IDE09898-MAS09544,Hybrid batt. management:  H-V activ. restriction-No component function,not active,
IDE09898-MAS09545,Hybrid batt. management:  H-V activ. restriction-Sequence error,not active,
IDE09898-MAS09546,Hybrid batt. management:  H-V activ. restriction-Voltage disconnect. init. error,not active,
IDE09898-MAS12351,Hybrid batt. management:  H-V activ. restriction-HV voltage measurement error,not active,
IDE09898-MAS13068,Hybrid batt. management:  H-V activ. restriction-HV voltage measurement initialization error,not active,
IDE09899-MAS02246,Eng. electronics: H-V activ. restriction-Timeout,not active,
IDE09899-MAS09519,Eng. electronics: H-V activ. restriction-Message error,not active,
IDE09899-MAS09541,Eng. electronics: H-V activ. restriction-Act. mode init. error,not active,
IDE09899-MAS09545,Eng. electronics: H-V activ. restriction-Sequence error,not active,
IDE09899-MAS09547,Eng. electronics: H-V activ. restriction-Error status drive motor: init. error,not active,
IDE09899-MAS09548,Eng. electronics: H-V activ. restriction-Error status drive: init. error,not active,
IDE09899-MAS09549,Eng. electronics: H-V activ. restriction-Drive condition: init. error,not active,
IDE09899-MAS09550,Eng. electronics: H-V activ. restriction-Safety line power electronics,not active,
IDE09899-MAS09551,Eng. electronics: H-V activ. restriction-Part. oper.,not active,
IDE09899-MAS09552,Eng. electronics: H-V activ. restriction-HV shut-down due to operating strategy,not active,
IDE09899-MAS09553,Eng. electronics: H-V activ. restriction-no component function drive motor,not active,
IDE09899-MAS09554,Eng. electronics: H-V activ. restriction-no component function drive,not active,
IDE09900-MAS02246,H-V batt. charger H-V activ. restriction-Timeout,not active,
IDE09900-MAS09519,H-V batt. charger H-V activ. restriction-Message error,not active,
IDE09900-MAS09546,H-V batt. charger H-V activ. restriction-Voltage disconnect. init. error,not active,
IDE09901-MAS02246,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Timeout,not active,
IDE09901-MAS09518,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Safety line,not active,
IDE09901-MAS09519,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Message error,not active,
IDE09901-MAS09541,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Act. mode init. error,not active,
IDE09901-MAS09542,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Error status init. error,not active,
IDE09901-MAS09543,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Operating mode error,not active,
IDE09901-MAS09544,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-No component function,not active,
IDE09901-MAS09546,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Voltage disconnect. init. error,not active,
IDE09901-MAS12351,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-HV voltage measurement error,not active,
IDE09901-MAS13068,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-HV voltage measurement initialization error,not active,
IDE09902-MAS02246,A/C compressor: H-V activ. restriction-Timeout,not active,
IDE09902-MAS09518,A/C compressor: H-V activ. restriction-Safety line,not active,
IDE09902-MAS09519,A/C compressor: H-V activ. restriction-Message error,not active,
IDE09902-MAS09541,A/C compressor: H-V activ. restriction-Act. mode init. error,not active,
IDE09902-MAS09542,A/C compressor: H-V activ. restriction-Error status init. error,not active,
IDE09902-MAS09544,A/C compressor: H-V activ. restriction-No component function,not active,
IDE09902-MAS09545,A/C compressor: H-V activ. restriction-Sequence error,not active,
IDE09902-MAS12351,A/C compressor: H-V activ. restriction-HV voltage measurement error,not active,
IDE09903-MAS02246,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Timeout,not active,
IDE09903-MAS09518,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Safety line,not active,
IDE09903-MAS09519,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Message error,not active,
IDE09903-MAS09541,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Act. mode init. error,not active,
IDE09903-MAS09542,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Error status init. error,not active,
IDE09903-MAS09544,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-No component function,not active,
IDE09903-MAS09545,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Sequence error,not active,
IDE09903-MAS12351,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-HV voltage measurement error,not active,
IDE09904-MAS00799,Airbag: H-V activ. restriction-Airbag control module,not active,
IDE09904-MAS02246,Airbag: H-V activ. restriction-Timeout,not active,
IDE09904-MAS09519,Airbag: H-V activ. restriction-Message error,not active,
IDE09904-MAS09521,Airbag: H-V activ. restriction-Light accident detected,not active,
IDE09904-MAS09522,Airbag: H-V activ. restriction-Severe accident detected,not active,
IDE09905-MAS00799,H-V activ. restriction-Airbag control module,not active,
IDE09905-MAS08044,H-V activ. restriction-Thermal management,not active,
IDE09905-MAS09516,H-V activ. restriction-Engine Electronics,not active,
IDE09905-MAS09523,H-V activ. restriction-Transformer for electrical drive,not active,
IDE09905-MAS09524,H-V activ. restriction-Hybrid Battery Management,not active,
IDE09905-MAS09525,H-V activ. restriction-Ctrl. mod. for contactless charging,not active,
IDE09905-MAS09526,H-V activ. restriction-High-voltage battery charger,not active,
IDE09905-MAS09555,H-V activ. restriction-HV activation prohibited due to accident,not active,
IDE09905-MAS09557,H-V activ. restriction-HV activation prohibited due to de-activation,not active,
IDE09905-MAS09558,H-V activ. restriction-HV activation prohibited due to blocking,not active,
IDE09905-MAS12352,H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 1,not active,
IDE09905-MAS12353,H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 2,not active,
IDE10084-MAS03950,Hybrid drive operating mode-Combustion engine: status,Engine running,
IDE10084-MAS09828,Hybrid drive operating mode-Status of drive readiness hybrid,not active,
IDE10084-MAS09829,Hybrid drive operating mode-Engine start in start-stop mode active,not active,
IDE10084-MAS09830,Hybrid drive operating mode-Engine stop in start-stop mode active,not active,
IDE10084-MAS09831,Hybrid drive operating mode-Engine running or driver readiness at engine stop,active,
IDE10341-SFT09757,Install. list of subsystems: act. install.-Alternator,Available,
IDE10341-SFT09777,Install. list of subsystems: act. install.-Multi Function Steering Wheel Control Module,Available,
IDE10341-SFT09783,Install. list of subsystems: act. install.-Battery Monitoring Control Module,Available,
IDE10341-SFT09833,Install. list of subsystems: act. install.-Power Converter DC AC,Not available,
IDE10341-SFT09960,Install. list of subsystems: act. install.-Starter Generator Control Module Sub,Not available,
IDE10341-SFT10046,Install. list of subsystems: act. install.-Control module for steering wheel touch recognition,Not available,
IDE10342-IDE02068,Standard - ambient data 1: status-Time stamp,Current,
IDE10342-MAS00711,Standard - ambient data 1: status-Odometer reading,Current,
IDE10365-MAS10445,Message mirroring: bus allocation-Data bus CAN 1,Comfort data bus,
IDE10365-MAS10446,Message mirroring: bus allocation-Data bus CAN 2,not installed,
IDE10365-MAS10447,Message mirroring: bus allocation-Data bus CAN 3,Data bus Sensor/Hybrid,
IDE10365-MAS10448,Message mirroring: bus allocation-Data bus CAN 4,Databus Infotainment,
IDE10365-MAS10449,Message mirroring: bus allocation-Data bus CAN 5,Databus extended,
IDE10365-MAS10450,Message mirroring: bus allocation-Data bus CAN 6,Data bus diagnostics,
IDE10365-MAS11107,Message mirroring: bus allocation-Data bus CAN 7,not installed,
IDE10505,History data 45,000*2000-01-01-00:00*0*000*000*000*000*000*000*000*000*000*000**,
IDE10506,History data 46,000*2000-01-01-00:00*0*000*+0000*00.00*000.00*00.00*00.00*00.00*00.00*0000.00*00000**,
IDE10510-MAS00106,History data 50-Year,2018,
IDE10510-MAS00107,History data 50-Month,5,
IDE10510-MAS00108,History data 50-Day,25,
IDE10510-MAS00109,History data 50-Hours,1, H
IDE10510-MAS00110,History data 50-Minutes,57, min
IDE10510-MAS01632,History data 50-Status,activated,
IDE10510-ENG05061,History data 50-Activation_Bus_Knock_Out,activated,
IDE10510-ENG05062,History data 50-Activation_Cluster_Sleep,activated,
IDE10510-ENG05063,History data 50-Activation_Cluster_Start,activated,
IDE10510-ENG05064,History data 50-Activation_FUNC_Monitoring,activated,
IDE10510-ENG05058,History data 50-Activation_Keeping_Awake,activated,
IDE10510-ENG05059,History data 50-Activation_Logical_Wakeup,activated,
IDE10510-ENG05060,History data 50-Activation_Physical_Wakeup,activated,
IDE10510-ENG05065,History data 50-Activation_Subbus_Monitoring,activated,
IDE10510-ENG06839,History data 50-Aktivitaetsstatus_Busaktivitaet,activated,
IDE10510-ENG118680,History data 50-Cycle_Counter,75,
IDE10510-ENG06840,History data 50-Status_Activation_Car_Wake_Up,activated,
IDE10510-ENG118681,History data 50-Time_Since_Clamp_15_Off,0.00, H
IDE10510-ENG05057,History data 50-Total_Cycle_Counter,1926,
IDE10511-MAS03174,History data 51-Comfort data bus,25.70, H
IDE10511-MAS03175,History data 51-Databus extended,0.00, H
IDE10511-MAS03177,History data 51-Databus Infotainment,21.20, H
IDE10511-MAS03179,History data 51-Local data bus 2,0.00, H
IDE10511-MAS03180,History data 51-Local data bus,0.00, H
IDE10511-MAS03181,History data 51-Flexray databus,0.30, H
IDE10511-MAS05686,History data 51-Data bus diagnostics,0.00, H
IDE10511-MAS05972,History data 51-Local data bus 3,0.00, H
IDE10511-MAS07380,History data 51-Data bus Sensor/Hybrid,0.00, H
IDE10511-MAS10036,History data 51-Data bus diagnosis 2,0.00, H
IDE10511-MAS12183,History data 51-Convenience data bus 2,0.00, H
IDE10511-MAS14086,History data 51-Instrument panel data bus,0.00, H
IDE10511-ENG118679,History data 51-Total_Bus_Active,26.20, H
IDE10512-MAS03174,History data 52-Comfort data bus,12665,
IDE10512-MAS03175,History data 52-Databus extended,0,
IDE10512-MAS03177,History data 52-Databus Infotainment,21,
IDE10512-MAS03179,History data 52-Local data bus 2,0,
IDE10512-MAS03180,History data 52-Local data bus,0,
IDE10512-MAS03181,History data 52-Flexray databus,16,
IDE10512-MAS05686,History data 52-Data bus diagnostics,0,
IDE10512-MAS05972,History data 52-Local data bus 3,0,
IDE10512-MAS07380,History data 52-Data bus Sensor/Hybrid,5,
IDE10512-MAS10036,History data 52-Data bus diagnosis 2,0,
IDE10512-MAS12183,History data 52-Convenience data bus 2,0,
IDE10512-MAS14086,History data 52-Instrument panel data bus,0,
IDE10513-MAS03174,History data 53-Comfort data bus,6783,
IDE10513-MAS03175,History data 53-Databus extended,1,
IDE10513-MAS03177,History data 53-Databus Infotainment,294,
IDE10513-MAS03179,History data 53-Local data bus 2,0,
IDE10513-MAS03180,History data 53-Local data bus,0,
IDE10513-MAS03181,History data 53-Flexray databus,40,
IDE10513-MAS05686,History data 53-Data bus diagnostics,0,
IDE10513-MAS05972,History data 53-Local data bus 3,0,
IDE10513-MAS07380,History data 53-Data bus Sensor/Hybrid,1662,
IDE10513-MAS10036,History data 53-Data bus diagnosis 2,0,
IDE10513-MAS12183,History data 53-Convenience data bus 2,0,
IDE10513-MAS14086,History data 53-Instrument panel data bus,0,
IDE10514-MAS03174,History data 54-Comfort data bus,20632,
IDE10514-MAS03175,History data 54-Databus extended,0,
IDE10514-MAS03177,History data 54-Databus Infotainment,1075,
IDE10514-MAS03179,History data 54-Local data bus 2,0,
IDE10514-MAS03180,History data 54-Local data bus,0,
IDE10514-MAS03181,History data 54-Flexray databus,1654,
IDE10514-MAS05686,History data 54-Data bus diagnostics,0,
IDE10514-MAS05972,History data 54-Local data bus 3,0,
IDE10514-MAS07380,History data 54-Data bus Sensor/Hybrid,1,
IDE10514-MAS10036,History data 54-Data bus diagnosis 2,0,
IDE10514-MAS12183,History data 54-Convenience data bus 2,0,
IDE10514-MAS14086,History data 54-Instrument panel data bus,0,
IDE10515-MAS03174,History data 55-Comfort data bus,0,
IDE10515-MAS03175,History data 55-Databus extended,0,
IDE10515-MAS03177,History data 55-Databus Infotainment,4651,
IDE10515-MAS03179,History data 55-Local data bus 2,0,
IDE10515-MAS03180,History data 55-Local data bus,0,
IDE10515-MAS03181,History data 55-Flexray databus,20,
IDE10515-MAS05686,History data 55-Data bus diagnostics,0,
IDE10515-MAS05972,History data 55-Local data bus 3,0,
IDE10515-MAS07380,History data 55-Data bus Sensor/Hybrid,0,
IDE10515-MAS10036,History data 55-Data bus diagnosis 2,0,
IDE10515-MAS12183,History data 55-Convenience data bus 2,0,
IDE10515-MAS14086,History data 55-Instrument panel data bus,0,
IDE10516-ENG05046,History data 56-Cluster_1_Start_Error_Counter,30351,
IDE10516-ENG30616,History data 56-Cluster_10_Counter,1,
IDE10516-ENG30617,History data 56-Cluster_10_Sleep_Error_Counter,0,
IDE10516-ENG30618,History data 56-Cluster_10_Start_Error_Counter,0,
IDE10516-ENG05047,History data 56-Cluster_2_Sleep_Error_Counter,0,
IDE10516-ENG05048,History data 56-Cluster_3_Counter,14190,
IDE10516-ENG05050,History data 56-Cluster_3_Sleep_Error_Counter,0,
IDE10516-ENG05049,History data 56-Cluster_3_Start_Error_Counter,15617,
IDE10516-ENG05051,History data 56-Cluster_4_Counter,22538,
IDE10516-ENG05053,History data 56-Cluster_4_Sleep_Error_Counter,2412,
IDE10516-ENG05052,History data 56-Cluster_4_Start_Error_Counter,60313,
IDE10516-ENG05054,History data 56-Cluster_5_Counter,34794,
IDE10516-ENG05056,History data 56-Cluster_5_Sleep_Error_Counter,1260,
IDE10516-ENG05055,History data 56-Cluster_5_Start_Error_Counter,43384,
IDE10516-ENG30619,History data 56-Cluster_6_Counter,20354,
IDE10516-ENG30620,History data 56-Cluster_6_Sleep_Error_Counter,15308,
IDE10516-ENG30621,History data 56-Cluster_6_Start_Error_Counter,7487,
IDE10516-ENG30622,History data 56-Cluster_7_Counter,16428,
IDE10516-ENG30623,History data 56-Cluster_7_Sleep_Error_Counter,15308,
IDE10516-ENG30624,History data 56-Cluster_7_Start_Error_Counter,7487,
IDE10516-ENG30625,History data 56-Cluster_8_Counter,20062,
IDE10516-ENG30626,History data 56-Cluster_8_Sleep_Error_Counter,15308,
IDE10516-ENG30627,History data 56-Cluster_8_Start_Error_Counter,7487,
IDE10516-ENG30628,History data 56-Cluster_9_Counter,20253,
IDE10516-ENG30629,History data 56-Cluster_9_Sleep_Error_Counter,0,
IDE10516-ENG30630,History data 56-Cluster_9_Start_Error_Counter,0,
IDE10516-ENG05045,History data 56-Cluster_Sleep_1_Error_Counter,29228,
IDE10516-ENG05043,History data 56-Cluster_Start_1_Counter,36259,
IDE10516-ENG05044,History data 56-Cluster_Start_1_Error_Counter,12210,
IDE10516-ENG06838,History data 56-Cluster_Start_2_Counter,27863,
IDE10517-MAS00106,History data 57-Year,2019, yr
IDE10517-MAS00107,History data 57-Month,7, m
IDE10517-MAS00108,History data 57-Day,12, d
IDE10517-MAS00109,History data 57-Hours,15, H
IDE10517-MAS00110,History data 57-Minutes,46, min
IDE10517-ENG20570,History data 57-Bus_1,Unknown (0),
IDE10517-ENG20572,History data 57-Bus_2,Unknown (0),
IDE10517-ENG20574,History data 57-Bus_3,Unknown (0),
IDE10517-ENG20576,History data 57-Bus_4,Unknown (0),
IDE10517-ENG20578,History data 57-Bus_5,Unknown (0),
IDE10517-ENG20571,History data 57-Bus_Active_Time_1,0.00, H
IDE10517-ENG20573,History data 57-Bus_Active_Time_2,0.00, H
IDE10517-ENG20575,History data 57-Bus_Active_Time_3,0.00, H
IDE10517-ENG20577,History data 57-Bus_Active_Time_4,0.00, H
IDE10517-ENG20579,History data 57-Bus_Active_Time_5,0.00, H
IDE10517-ENG118680,History data 57-Cycle_Counter,74,
IDE10517-ENG118681,History data 57-Time_Since_Clamp_15_Off,0.00, H
IDE10518-ENG28832,History data 58-Awake_Time_ECU_1,0.00, H
IDE10518-ENG28835,History data 58-Awake_Time_ECU_2,0.00, H
IDE10518-ENG28838,History data 58-Awake_Time_ECU_3,0.00, H
IDE10518-ENG28841,History data 58-Awake_Time_ECU_4,0.00, H
IDE10518-ENG28844,History data 58-Awake_Time_ECU_5,0.00, H
IDE10518-ENG28833,History data 58-Bus_ECU_1,0,
IDE10518-ENG28836,History data 58-Bus_ECU_2,0,
IDE10518-ENG28839,History data 58-Bus_ECU_3,0,
IDE10518-ENG28842,History data 58-Bus_ECU_4,0,
IDE10518-ENG28845,History data 58-Bus_ECU_5,0,
IDE10518-ENG28834,History data 58-Cluster_ECU_1,00 00 00,
IDE10518-ENG28837,History data 58-Cluster_ECU_2,00 00 00,
IDE10518-ENG28840,History data 58-Cluster_ECU_3,00 00 00,
IDE10518-ENG28843,History data 58-Cluster_ECU_4,00 00 00,
IDE10518-ENG28846,History data 58-Cluster_ECU_5,00 00 00,
IDE10518-ENG118680,History data 58-Cycle_Counter,74,
IDE10518-ENG106038,History data 58-ECU_1,0,
IDE10518-ENG106039,History data 58-ECU_2,0,
IDE10518-ENG28620,History data 58-ECU_3,0,
IDE10518-ENG106040,History data 58-ECU_4,0,
IDE10518-ENG106041,History data 58-ECU_5,0,
IDE10518-ENG28618,History data 58-Repeat_Counter_ECU_1,0,
IDE10518-ENG28619,History data 58-Repeat_Counter_ECU_2,0,
IDE10518-ENG28621,History data 58-Repeat_Counter_ECU_3,0,
IDE10518-ENG28622,History data 58-Repeat_Counter_ECU_4,0.00,
IDE10518-ENG28623,History data 58-Repeat_Counter_ECU_5,0,
IDE10519-ENG28833,History data 59-Bus_ECU_1,15,
IDE10519-ENG28836,History data 59-Bus_ECU_2,15,
IDE10519-ENG28839,History data 59-Bus_ECU_3,15,
IDE10519-ENG28842,History data 59-Bus_ECU_4,15,
IDE10519-ENG28845,History data 59-Bus_ECU_5,15,
IDE10519-ENG28834,History data 59-Cluster_ECU_1,00 00 00,
IDE10519-ENG28837,History data 59-Cluster_ECU_2,00 00 00,
IDE10519-ENG28840,History data 59-Cluster_ECU_3,00 00 00,
IDE10519-ENG28843,History data 59-Cluster_ECU_4,00 00 28,
IDE10519-ENG28846,History data 59-Cluster_ECU_5,00 00 00,
IDE10519-ENG118680,History data 59-Cycle_Counter,74,
IDE10519-ENG106038,History data 59-ECU_1,14,
IDE10519-ENG106039,History data 59-ECU_2,74,
IDE10519-ENG28620,History data 59-ECU_3,76,
IDE10519-ENG106040,History data 59-ECU_4,139,
IDE10519-ENG106041,History data 59-ECU_5,35,
IDE10519-ENG28847,History data 59-Logical_Wakeup_ECU_1,2,
IDE10519-ENG28848,History data 59-Logical_Wakeup_ECU_2,2,
IDE10519-ENG28849,History data 59-Logical_Wakeup_ECU_3,2,
IDE10519-ENG28850,History data 59-Logical_Wakeup_ECU_4,2,
IDE10519-ENG28851,History data 59-Logical_Wakeup_ECU_5,1,
IDE10520-ENG28833,History data 60-Bus_ECU_1,15,
IDE10520-ENG28836,History data 60-Bus_ECU_2,16,
IDE10520-ENG28839,History data 60-Bus_ECU_3,15,
IDE10520-ENG28842,History data 60-Bus_ECU_4,15,
IDE10520-ENG28845,History data 60-Bus_ECU_5,0,
IDE10520-ENG28834,History data 60-Cluster_ECU_1,00 00 09,
IDE10520-ENG28837,History data 60-Cluster_ECU_2,00 00 00,
IDE10520-ENG28840,History data 60-Cluster_ECU_3,00 00 00,
IDE10520-ENG28843,History data 60-Cluster_ECU_4,00 00 28,
IDE10520-ENG28846,History data 60-Cluster_ECU_5,00 00 00,
IDE10520-ENG118680,History data 60-Cycle_Counter,74,
IDE10520-ENG106038,History data 60-ECU_1,75,
IDE10520-ENG106039,History data 60-ECU_2,255,
IDE10520-ENG28620,History data 60-ECU_3,74,
IDE10520-ENG106040,History data 60-ECU_4,139,
IDE10520-ENG106041,History data 60-ECU_5,0,
IDE10520-ENG28852,History data 60-Physical_Wakeup_ECU_1,2,
IDE10520-ENG28853,History data 60-Physical_Wakeup_ECU_2,1,
IDE10520-ENG28854,History data 60-Physical_Wakeup_ECU_3,1,
IDE10520-ENG28855,History data 60-Physical_Wakeup_ECU_4,1,
IDE10520-ENG28856,History data 60-Physical_Wakeup_ECU_5,0,
IDE10521-ENG28833,History data 61-Bus_ECU_1,18,
IDE10521-ENG28836,History data 61-Bus_ECU_2,0,
IDE10521-ENG28839,History data 61-Bus_ECU_3,0,
IDE10521-ENG28842,History data 61-Bus_ECU_4,0,
IDE10521-ENG28845,History data 61-Bus_ECU_5,0,
IDE10521-ENG28857,History data 61-Bus_Knock_Out_ECU_1,3,
IDE10521-ENG30432,History data 61-Bus_Knock_Out_ECU_2,0,
IDE10521-ENG28858,History data 61-Bus_Knock_Out_ECU_3,0,
IDE10521-ENG28859,History data 61-Bus_Knock_Out_ECU_4,0,
IDE10521-ENG28860,History data 61-Bus_Knock_Out_ECU_5,0,
IDE10521-ENG118680,History data 61-Cycle_Counter,74,
IDE10521-ENG106038,History data 61-ECU_1,20,
IDE10521-ENG106039,History data 61-ECU_2,0,
IDE10521-ENG28620,History data 61-ECU_3,0,
IDE10521-ENG106040,History data 61-ECU_4,0,
IDE10521-ENG106041,History data 61-ECU_5,0,
IDE10522-ENG28833,History data 62-Bus_ECU_1,15,
IDE10522-ENG28836,History data 62-Bus_ECU_2,15,
IDE10522-ENG28839,History data 62-Bus_ECU_3,15,
IDE10522-ENG28842,History data 62-Bus_ECU_4,23,
IDE10522-ENG28845,History data 62-Bus_ECU_5,15,
IDE10522-ENG28861,History data 62-Car_Wake_Up_Counter_ECU_1,5,
IDE10522-ENG28863,History data 62-Car_Wake_Up_Counter_ECU_2,3,
IDE10522-ENG28865,History data 62-Car_Wake_Up_Counter_ECU_3,1,
IDE10522-ENG28867,History data 62-Car_Wake_Up_Counter_ECU_4,1,
IDE10522-ENG28869,History data 62-Car_Wake_Up_Counter_ECU_5,1,
IDE10522-ENG28862,History data 62-Car_Wake_Up_Time_ECU_1,0.00, H
IDE10522-ENG28864,History data 62-Car_Wake_Up_Time_ECU_2,0.00, H
IDE10522-ENG28866,History data 62-Car_Wake_Up_Time_ECU_3,0.00, H
IDE10522-ENG28868,History data 62-Car_Wake_Up_Time_ECU_4,0.00, H
IDE10522-ENG28870,History data 62-Car_Wake_Up_Time_ECU_5,0.00, H
IDE10522-ENG118680,History data 62-Cycle_Counter,74,
IDE10522-ENG106038,History data 62-ECU_1,75,
IDE10522-ENG106039,History data 62-ECU_2,74,
IDE10522-ENG28620,History data 62-ECU_3,14,
IDE10522-ENG106040,History data 62-ECU_4,19,
IDE10522-ENG106041,History data 62-ECU_5,76,
IDE10523-ENG28833,History data 63-Bus_ECU_1,23,
IDE10523-ENG28836,History data 63-Bus_ECU_2,15,
IDE10523-ENG28839,History data 63-Bus_ECU_3,15,
IDE10523-ENG28842,History data 63-Bus_ECU_4,15,
IDE10523-ENG28845,History data 63-Bus_ECU_5,18,
IDE10523-ENG28871,History data 63-Cluster_Sleep_ECU_1,255,
IDE10523-ENG28872,History data 63-Cluster_Sleep_ECU_2,13,
IDE10523-ENG28873,History data 63-Cluster_Sleep_ECU_3,10,
IDE10523-ENG28874,History data 63-Cluster_Sleep_ECU_4,10,
IDE10523-ENG28875,History data 63-Cluster_Sleep_ECU_5,7,
IDE10523-ENG118680,History data 63-Cycle_Counter,74,
IDE10523-ENG106038,History data 63-ECU_1,21,
IDE10523-ENG106039,History data 63-ECU_2,75,
IDE10523-ENG28620,History data 63-ECU_3,14,
IDE10523-ENG106040,History data 63-ECU_4,74,
IDE10523-ENG106041,History data 63-ECU_5,115,
IDE10524-ENG28833,History data 64-Bus_ECU_1,15,
IDE10524-ENG28836,History data 64-Bus_ECU_2,15,
IDE10524-ENG28839,History data 64-Bus_ECU_3,3955,
IDE10524-ENG28842,History data 64-Bus_ECU_4,0,
IDE10524-ENG28845,History data 64-Bus_ECU_5,73,
IDE10524-ENG28876,History data 64-Cluster_1_Start,0,
IDE10524-ENG28877,History data 64-Cluster_2_Start,0,
IDE10524-ENG28878,History data 64-Cluster_3_Start,0,
IDE10524-ENG28879,History data 64-Cluster_4_Start,0,
IDE10524-ENG28880,History data 64-Cluster_5_Start,0,
IDE10524-ENG28881,History data 64-Cluster_Start_ECU_1,15,
IDE10524-ENG28882,History data 64-Cluster_Start_ECU_2,14,
IDE10524-ENG28883,History data 64-Cluster_Start_ECU_3,6,
IDE10524-ENG28884,History data 64-Cluster_Start_ECU_4,1298,
IDE10524-ENG28885,History data 64-Cluster_Start_ECU_5,0,
IDE10524-ENG118680,History data 64-Cycle_Counter,74,
IDE10524-ENG106038,History data 64-ECU_1,35,
IDE10524-ENG106039,History data 64-ECU_2,76,
IDE10524-ENG28620,History data 64-ECU_3,75,
IDE10524-ENG106040,History data 64-ECU_4,0,
IDE10524-ENG106041,History data 64-ECU_5,0,
IDE10525-ENG28887,History data 65-Awake_Time_FUNC_1,0.00, H
IDE10525-ENG28890,History data 65-Awake_Time_FUNC_2,0.00, H
IDE10525-ENG28893,History data 65-Awake_Time_FUNC_3,0.00, H
IDE10525-ENG28896,History data 65-Awake_Time_FUNC_4,0.00, H
IDE10525-ENG28899,History data 65-Awake_Time_FUNC_5,0.00, H
IDE10525-ENG118680,History data 65-Cycle_Counter,74,
IDE10525-ENG28886,History data 65-FUNC_1,2,
IDE10525-ENG28889,History data 65-FUNC_2,17,
IDE10525-ENG28892,History data 65-FUNC_3,18,
IDE10525-ENG28895,History data 65-FUNC_4,14,
IDE10525-ENG28898,History data 65-FUNC_5,11,
IDE10525-ENG28888,History data 65-Physical_Wakeup_FUNC_1,171,
IDE10525-ENG28891,History data 65-Physical_Wakeup_FUNC_2,140,
IDE10525-ENG28894,History data 65-Physical_Wakeup_FUNC_3,135,
IDE10525-ENG28897,History data 65-Physical_Wakeup_FUNC_4,115,
IDE10525-ENG28900,History data 65-Physical_Wakeup_FUNC_5,38,
IDE10526-MAS00106,History data 66-Year,2019,
IDE10526-MAS00107,History data 66-Month,4,
IDE10526-MAS00108,History data 66-Day,22,
IDE10526-MAS00109,History data 66-Hours,0, H
IDE10526-MAS00110,History data 66-Minutes,0, min
IDE10526-ENG28832,History data 66-Awake_Time_ECU_1,25.50, H
IDE10526-ENG28835,History data 66-Awake_Time_ECU_2,1.00, H
IDE10526-ENG28838,History data 66-Awake_Time_ECU_3,0.00, H
IDE10526-ENG28841,History data 66-Awake_Time_ECU_4,0.00, H
IDE10526-ENG28844,History data 66-Awake_Time_ECU_5,0.00, H
IDE10526-ENG28833,History data 66-Bus_ECU_1,15,
IDE10526-ENG28836,History data 66-Bus_ECU_2,15,
IDE10526-ENG28839,History data 66-Bus_ECU_3,0,
IDE10526-ENG28842,History data 66-Bus_ECU_4,0,
IDE10526-ENG28845,History data 66-Bus_ECU_5,0,
IDE10526-ENG28834,History data 66-Cluster_ECU_1,00 00 00,
IDE10526-ENG28837,History data 66-Cluster_ECU_2,00 00 00,
IDE10526-ENG28840,History data 66-Cluster_ECU_3,00 00 00,
IDE10526-ENG28843,History data 66-Cluster_ECU_4,00 00 00,
IDE10526-ENG28846,History data 66-Cluster_ECU_5,00 00 00,
IDE10526-ENG118680,History data 66-Cycle_Counter,89,
IDE10526-ENG106038,History data 66-ECU_1,14,
IDE10526-ENG106039,History data 66-ECU_2,74,
IDE10526-ENG28620,History data 66-ECU_3,0,
IDE10526-ENG106040,History data 66-ECU_4,0,
IDE10526-ENG106041,History data 66-ECU_5,0,
IDE10526-ENG28618,History data 66-Repeat_Counter_ECU_1,6,
IDE10526-ENG28619,History data 66-Repeat_Counter_ECU_2,0,
IDE10526-ENG28621,History data 66-Repeat_Counter_ECU_3,0,
IDE10526-ENG28622,History data 66-Repeat_Counter_ECU_4,0,
IDE10526-ENG28623,History data 66-Repeat_Counter_ECU_5,0,
IDE10526-ENG118681,History data 66-Time_Since_Clamp_15_Off,30.80, H
IDE10527-MAS00106,History data 67-Year,2019,
IDE10527-MAS00107,History data 67-Month,4,
IDE10527-MAS00108,History data 67-Day,22,
IDE10527-MAS00109,History data 67-Hours,0, H
IDE10527-MAS00110,History data 67-Minutes,0, min
IDE10527-ENG28833,History data 67-Bus_ECU_1,15,
IDE10527-ENG28836,History data 67-Bus_ECU_2,15,
IDE10527-ENG28839,History data 67-Bus_ECU_3,0,
IDE10527-ENG28842,History data 67-Bus_ECU_4,0,
IDE10527-ENG28845,History data 67-Bus_ECU_5,0,
IDE10527-ENG28834,History data 67-Cluster_ECU_1,00 00 00,
IDE10527-ENG28837,History data 67-Cluster_ECU_2,00 00 00,
IDE10527-ENG28840,History data 67-Cluster_ECU_3,00 00 00,
IDE10527-ENG28843,History data 67-Cluster_ECU_4,00 00 00,
IDE10527-ENG28846,History data 67-Cluster_ECU_5,00 00 00,
IDE10527-ENG118680,History data 67-Cycle_Counter,89,
IDE10527-ENG106038,History data 67-ECU_1,76,
IDE10527-ENG106039,History data 67-ECU_2,35,
IDE10527-ENG28620,History data 67-ECU_3,0,
IDE10527-ENG106040,History data 67-ECU_4,0,
IDE10527-ENG106041,History data 67-ECU_5,0,
IDE10527-ENG28847,History data 67-Logical_Wakeup_ECU_1,67,
IDE10527-ENG28848,History data 67-Logical_Wakeup_ECU_2,45,
IDE10527-ENG28849,History data 67-Logical_Wakeup_ECU_3,0,
IDE10527-ENG28850,History data 67-Logical_Wakeup_ECU_4,0,
IDE10527-ENG28851,History data 67-Logical_Wakeup_ECU_5,0,
IDE10527-ENG118681,History data 67-Time_Since_Clamp_15_Off,30.80, H
IDE10528-MAS00106,History data 68-Year,2019,
IDE10528-MAS00107,History data 68-Month,4,
IDE10528-MAS00108,History data 68-Day,22,
IDE10528-MAS00109,History data 68-Hours,0, H
IDE10528-MAS00110,History data 68-Minutes,0, min
IDE10528-ENG28833,History data 68-Bus_ECU_1,15,
IDE10528-ENG28836,History data 68-Bus_ECU_2,15,
IDE10528-ENG28839,History data 68-Bus_ECU_3,0,
IDE10528-ENG28842,History data 68-Bus_ECU_4,0,
IDE10528-ENG28845,History data 68-Bus_ECU_5,0,
IDE10528-ENG28834,History data 68-Cluster_ECU_1,00 00 00,
IDE10528-ENG28837,History data 68-Cluster_ECU_2,00 00 00,
IDE10528-ENG28840,History data 68-Cluster_ECU_3,00 00 00,
IDE10528-ENG28843,History data 68-Cluster_ECU_4,00 00 00,
IDE10528-ENG28846,History data 68-Cluster_ECU_5,00 00 00,
IDE10528-ENG118680,History data 68-Cycle_Counter,89,
IDE10528-ENG106038,History data 68-ECU_1,255,
IDE10528-ENG106039,History data 68-ECU_2,255,
IDE10528-ENG28620,History data 68-ECU_3,0,
IDE10528-ENG106040,History data 68-ECU_4,0,
IDE10528-ENG106041,History data 68-ECU_5,0,
IDE10528-ENG28852,History data 68-Physical_Wakeup_ECU_1,255,
IDE10528-ENG28853,History data 68-Physical_Wakeup_ECU_2,57,
IDE10528-ENG28854,History data 68-Physical_Wakeup_ECU_3,0,
IDE10528-ENG28855,History data 68-Physical_Wakeup_ECU_4,0,
IDE10528-ENG28856,History data 68-Physical_Wakeup_ECU_5,0,
IDE10528-ENG118681,History data 68-Time_Since_Clamp_15_Off,30.80, H
IDE10529-MAS00106,History data 69-Year,2019,
IDE10529-MAS00107,History data 69-Month,4,
IDE10529-MAS00108,History data 69-Day,19,
IDE10529-MAS00109,History data 69-Hours,1, H
IDE10529-MAS00110,History data 69-Minutes,5, min
IDE10529-ENG28833,History data 69-Bus_ECU_1,18,
IDE10529-ENG28836,History data 69-Bus_ECU_2,0,
IDE10529-ENG28839,History data 69-Bus_ECU_3,0,
IDE10529-ENG28842,History data 69-Bus_ECU_4,0,
IDE10529-ENG28845,History data 69-Bus_ECU_5,0,
IDE10529-ENG28857,History data 69-Bus_Knock_Out_ECU_1,34,
IDE10529-ENG30432,History data 69-Bus_Knock_Out_ECU_2,0,
IDE10529-ENG28858,History data 69-Bus_Knock_Out_ECU_3,0,
IDE10529-ENG28859,History data 69-Bus_Knock_Out_ECU_4,0,
IDE10529-ENG28860,History data 69-Bus_Knock_Out_ECU_5,0,
IDE10529-ENG118680,History data 69-Cycle_Counter,78,
IDE10529-ENG106038,History data 69-ECU_1,20,
IDE10529-ENG106039,History data 69-ECU_2,0,
IDE10529-ENG28620,History data 69-ECU_3,0,
IDE10529-ENG106040,History data 69-ECU_4,0,
IDE10529-ENG106041,History data 69-ECU_5,0,
IDE10529-ENG118681,History data 69-Time_Since_Clamp_15_Off,0.00, H
IDE10530-MAS00106,History data 70-Year,2019,
IDE10530-MAS00107,History data 70-Month,4,
IDE10530-MAS00108,History data 70-Day,22,
IDE10530-MAS00109,History data 70-Hours,0, H
IDE10530-MAS00110,History data 70-Minutes,0, min
IDE10530-ENG28833,History data 70-Bus_ECU_1,15,
IDE10530-ENG28836,History data 70-Bus_ECU_2,23,
IDE10530-ENG28839,History data 70-Bus_ECU_3,0,
IDE10530-ENG28842,History data 70-Bus_ECU_4,0,
IDE10530-ENG28845,History data 70-Bus_ECU_5,0,
IDE10530-ENG28861,History data 70-Car_Wake_Up_Counter_ECU_1,53,
IDE10530-ENG28863,History data 70-Car_Wake_Up_Counter_ECU_2,41,
IDE10530-ENG28865,History data 70-Car_Wake_Up_Counter_ECU_3,0,
IDE10530-ENG28867,History data 70-Car_Wake_Up_Counter_ECU_4,0,
IDE10530-ENG28869,History data 70-Car_Wake_Up_Counter_ECU_5,0,
IDE10530-ENG28862,History data 70-Car_Wake_Up_Time_ECU_1,0.00, H
IDE10530-ENG28864,History data 70-Car_Wake_Up_Time_ECU_2,0.00, H
IDE10530-ENG28866,History data 70-Car_Wake_Up_Time_ECU_3,0.00, H
IDE10530-ENG28868,History data 70-Car_Wake_Up_Time_ECU_4,0.00, H
IDE10530-ENG28870,History data 70-Car_Wake_Up_Time_ECU_5,0.00, H
IDE10530-ENG118680,History data 70-Cycle_Counter,89,
IDE10530-ENG106038,History data 70-ECU_1,74,
IDE10530-ENG106039,History data 70-ECU_2,19,
IDE10530-ENG28620,History data 70-ECU_3,0,
IDE10530-ENG106040,History data 70-ECU_4,0,
IDE10530-ENG106041,History data 70-ECU_5,0,
IDE10530-ENG118681,History data 70-Time_Since_Clamp_15_Off,30.80, H
IDE10531-MAS00106,History data 71-Year,2019,
IDE10531-MAS00107,History data 71-Month,7,
IDE10531-MAS00108,History data 71-Day,12,
IDE10531-MAS00109,History data 71-Hours,15, H
IDE10531-MAS00110,History data 71-Minutes,46, min
IDE10531-ENG28833,History data 71-Bus_ECU_1,23,
IDE10531-ENG28836,History data 71-Bus_ECU_2,0,
IDE10531-ENG28839,History data 71-Bus_ECU_3,0,
IDE10531-ENG28842,History data 71-Bus_ECU_4,0,
IDE10531-ENG28845,History data 71-Bus_ECU_5,0,
IDE10531-ENG28871,History data 71-Cluster_Sleep_ECU_1,255,
IDE10531-ENG28872,History data 71-Cluster_Sleep_ECU_2,0,
IDE10531-ENG28873,History data 71-Cluster_Sleep_ECU_3,0,
IDE10531-ENG28874,History data 71-Cluster_Sleep_ECU_4,0,
IDE10531-ENG28875,History data 71-Cluster_Sleep_ECU_5,0,
IDE10531-ENG118680,History data 71-Cycle_Counter,74,
IDE10531-ENG106038,History data 71-ECU_1,21,
IDE10531-ENG106039,History data 71-ECU_2,0,
IDE10531-ENG28620,History data 71-ECU_3,0,
IDE10531-ENG106040,History data 71-ECU_4,0,
IDE10531-ENG106041,History data 71-ECU_5,0,
IDE10531-ENG118681,History data 71-Time_Since_Clamp_15_Off,0.00, H
IDE10532-MAS00106,History data 72-Year,2018,
IDE10532-MAS00107,History data 72-Month,8,
IDE10532-MAS00108,History data 72-Day,26,
IDE10532-MAS00109,History data 72-Hours,19, H
IDE10532-MAS00110,History data 72-Minutes,55, min
IDE10532-ENG28833,History data 72-Bus_ECU_1,15,
IDE10532-ENG28836,History data 72-Bus_ECU_2,15,
IDE10532-ENG28839,History data 72-Bus_ECU_3,0,
IDE10532-ENG28842,History data 72-Bus_ECU_4,0,
IDE10532-ENG28845,History data 72-Bus_ECU_5,0,
IDE10532-ENG28876,History data 72-Cluster_1_Start,0,
IDE10532-ENG28877,History data 72-Cluster_2_Start,0,
IDE10532-ENG28878,History data 72-Cluster_3_Start,0,
IDE10532-ENG28879,History data 72-Cluster_4_Start,0,
IDE10532-ENG28880,History data 72-Cluster_5_Start,0,
IDE10532-ENG28834,History data 72-Cluster_ECU_1,0,
IDE10532-ENG28837,History data 72-Cluster_ECU_2,0,
IDE10532-ENG28840,History data 72-Cluster_ECU_3,0,
IDE10532-ENG28843,History data 72-Cluster_ECU_4,0,
IDE10532-ENG28846,History data 72-Cluster_ECU_5,0,
IDE10532-ENG28881,History data 72-Cluster_Start_ECU_1,174,
IDE10532-ENG28882,History data 72-Cluster_Start_ECU_2,54,
IDE10532-ENG28883,History data 72-Cluster_Start_ECU_3,0,
IDE10532-ENG28884,History data 72-Cluster_Start_ECU_4,0,
IDE10532-ENG28885,History data 72-Cluster_Start_ECU_5,0,
IDE10532-ENG118680,History data 72-Cycle_Counter,209,
IDE10532-ENG106038,History data 72-ECU_1,35,
IDE10532-ENG106039,History data 72-ECU_2,76,
IDE10532-ENG28620,History data 72-ECU_3,0,
IDE10532-ENG106040,History data 72-ECU_4,0,
IDE10532-ENG106041,History data 72-ECU_5,0,
IDE10532-ENG118681,History data 72-Time_Since_Clamp_15_Off,0.00, H
IDE10533-MAS00106,History data 73-Year,2000,
IDE10533-MAS00107,History data 73-Month,1,
IDE10533-MAS00108,History data 73-Day,1,
IDE10533-MAS00109,History data 73-Hours,0, H
IDE10533-MAS00110,History data 73-Minutes,0, min
IDE10533-ENG28907,History data 73-Activetime_MIB,0.00, H
IDE10533-ENG28904,History data 73-Activetime_MOST,0.00, H
IDE10533-ENG28901,History data 73-Activetime_MU,0.00, H
IDE10533-ENG118680,History data 73-Cycle_Counter,0,
IDE10533-ENG28903,History data 73-State_MMI,3,
IDE10533-ENG28906,History data 73-State_MOST,1,
IDE10533-ENG118681,History data 73-Time_Since_Clamp_15_Off,0.00, H
IDE10533-ENG28905,History data 73-WakeUps_MOST,1,
IDE10533-ENG28902,History data 73-WakeUps_MU,1,
IDE10534-MAS00106,History data 74-Year,2019,
IDE10534-MAS00107,History data 74-Month,7,
IDE10534-MAS00108,History data 74-Day,1,
IDE10534-MAS00109,History data 74-Hours,9, H
IDE10534-MAS00110,History data 74-Minutes,26, min
IDE10534-ENG28887,History data 74-Awake_Time_FUNC_1,0.00, H
IDE10534-ENG28890,History data 74-Awake_Time_FUNC_2,0.00, H
IDE10534-ENG28893,History data 74-Awake_Time_FUNC_3,0.00, H
IDE10534-ENG28896,History data 74-Awake_Time_FUNC_4,0.00, H
IDE10534-ENG28899,History data 74-Awake_Time_FUNC_5,0.00, H
IDE10534-ENG118680,History data 74-Cycle_Counter,242,
IDE10534-ENG28886,History data 74-FUNC_1,2,
IDE10534-ENG28889,History data 74-FUNC_2,17,
IDE10534-ENG28892,History data 74-FUNC_3,18,
IDE10534-ENG28895,History data 74-FUNC_4,14,
IDE10534-ENG28898,History data 74-FUNC_5,11,
IDE10534-ENG28888,History data 74-Physical_Wakeup_FUNC_1,255,
IDE10534-ENG28891,History data 74-Physical_Wakeup_FUNC_2,255,
IDE10534-ENG28894,History data 74-Physical_Wakeup_FUNC_3,255,
IDE10534-ENG28897,History data 74-Physical_Wakeup_FUNC_4,171,
IDE10534-ENG28900,History data 74-Physical_Wakeup_FUNC_5,78,
IDE10534-ENG118681,History data 74-Time_Since_Clamp_15_Off,0.00, H
IDE10535-MAS03174,History data 75-Comfort data bus,0,
IDE10535-MAS03175,History data 75-Databus extended,0,
IDE10535-MAS03177,History data 75-Databus Infotainment,0,
IDE10535-MAS03179,History data 75-Local data bus 2,0,
IDE10535-MAS03180,History data 75-Local data bus,0,
IDE10535-MAS03181,History data 75-Flexray databus,0,
IDE10535-MAS05686,History data 75-Data bus diagnostics,0,
IDE10535-MAS05972,History data 75-Local data bus 3,0,
IDE10535-MAS07380,History data 75-Data bus Sensor/Hybrid,0,
IDE10535-MAS10036,History data 75-Data bus diagnosis 2,0,
IDE10535-MAS12183,History data 75-Convenience data bus 2,0,
IDE10535-MAS14086,History data 75-Instrument panel data bus,0,
IDE10623-IDE04447,Status drive profile for roll stabilization-Function status,engaged,
IDE10623-IDE06260,Status drive profile for roll stabilization-ID number,0,
IDE10623-MAS01156,Status drive profile for roll stabilization-Communication status,OK,
IDE10623-MAS01447,Status drive profile for roll stabilization-Act.val.,0,
IDE10624-IDE04447,Status: driving profile selection for sport differential-Function status,engaged,
IDE10624-IDE06260,Status: driving profile selection for sport differential-ID number,0,
IDE10624-MAS01156,Status: driving profile selection for sport differential-Communication status,OK,
IDE10624-MAS01447,Status: driving profile selection for sport differential-Act.val.,0,
IDE10625-IDE04447,Stat.driv.profile select.for warn.in case of. risk of collision-Function status,not engaged,
IDE10625-IDE06260,Stat.driv.profile select.for warn.in case of. risk of collision-ID number,0,
IDE10625-MAS01156,Stat.driv.profile select.for warn.in case of. risk of collision-Communication status,OK,
IDE10625-MAS01447,Stat.driv.profile select.for warn.in case of. risk of collision-Act.val.,0,
IDE10626-IDE04447,Stat.driv.prof. select. f. warn. when risk of col.with pedes.-Function status,not engaged,
IDE10626-IDE06260,Stat.driv.prof. select. f. warn. when risk of col.with pedes.-ID number,0,
IDE10626-MAS01156,Stat.driv.prof. select. f. warn. when risk of col.with pedes.-Communication status,OK,
IDE10626-MAS01447,Stat.driv.prof. select. f. warn. when risk of col.with pedes.-Act.val.,0,
IDE10627-IDE04447,Status driving profile selection for hybrid battery management-Function status,engaged,
IDE10627-IDE06260,Status driving profile selection for hybrid battery management-ID number,0,
IDE10627-MAS01156,Status driving profile selection for hybrid battery management-Communication status,OK,
IDE10627-MAS01447,Status driving profile selection for hybrid battery management-Act.val.,0,
IDE10628-IDE04447,Status: driving profile selection for emerg. brake assistance-Function status,engaged,
IDE10628-IDE06260,Status: driving profile selection for emerg. brake assistance-ID number,0,
IDE10628-MAS01156,Status: driving profile selection for emerg. brake assistance-Communication status,OK,
IDE10628-MAS01447,Status: driving profile selection for emerg. brake assistance-Act.val.,2,
IDE10629-IDE04447,Status: driving profile select. for rear axle differential lock-Function status,not engaged,
IDE10629-IDE06260,Status: driving profile select. for rear axle differential lock-ID number,0,
IDE10629-MAS01156,Status: driving profile select. for rear axle differential lock-Communication status,OK,
IDE10629-MAS01447,Status: driving profile select. for rear axle differential lock-Act.val.,0,
IDE10644-MAS06193,Driving profile selection: statistics distance driven-Profile 1,1965, km
IDE10644-MAS06194,Driving profile selection: statistics distance driven-Profile 2,12909, km
IDE10644-MAS06195,Driving profile selection: statistics distance driven-Profile 3,18558, km
IDE10644-MAS06196,Driving profile selection: statistics distance driven-Profile 4,0, km
IDE10644-MAS06197,Driving profile selection: statistics distance driven-Profile 5,0, km
IDE10644-MAS06198,Driving profile selection: statistics distance driven-Profile 6,503, km
IDE10644-MAS06199,Driving profile selection: statistics distance driven-Profile 7,590, km
IDE10644-MAS06200,Driving profile selection: statistics distance driven-Profile 8,0, km
IDE10644-MAS08875,Driving profile selection: statistics distance driven-Profile 9,0, km
IDE10644-MAS08876,Driving profile selection: statistics distance driven-Profile 10,0, km
IDE10644-MAS08877,Driving profile selection: statistics distance driven-Profile 11,0, km
IDE10644-MAS08878,Driving profile selection: statistics distance driven-Profile 12,0, km
IDE10644-MAS08879,Driving profile selection: statistics distance driven-Profile 13,0, km
IDE10644-MAS08880,Driving profile selection: statistics distance driven-Profile 14,0, km
IDE10644-MAS08881,Driving profile selection: statistics distance driven-Profile 15,0, km
IDE10655-MAS00106,Pause recommendation: hist. data-Year,2019, yr
IDE10655-MAS00107,Pause recommendation: hist. data-Month,7, m
IDE10655-MAS00108,Pause recommendation: hist. data-Day,12, d
IDE10655-MAS00109,Pause recommendation: hist. data-Hours,15, H
IDE10655-MAS00110,Pause recommendation: hist. data-Minutes,32, min
IDE10655-MAS00111,Pause recommendation: hist. data-Seconds,33, s
IDE10655-MAS03401,Pause recommendation: hist. data-Parameter 1,0.40,
IDE10655-MAS03402,Pause recommendation: hist. data-Parameter 2,1.00,
IDE10655-MAS03403,Pause recommendation: hist. data-Parameter 3,1.00,
IDE10655-MAS03404,Pause recommendation: hist. data-Parameter 4,4.09,
IDE10655-MAS03405,Pause recommendation: hist. data-Parameter 5,0, %
IDE10655-MAS10985,Pause recommendation: hist. data-Overall drive duration,3, min
IDE10655-MAS10986,Pause recommendation: hist. data-Drive duration in active speed range,0, min
IDE10655-MAS10987,Pause recommendation: hist. data-Drive duration with warning readiness,0, min
IDE10655-MAS10988,Pause recommendation: hist. data-No. of warnings issued,00,
IDE10655-MAS14091,Pause recommendation: hist. data-Travel duration until first warning,0, min
IDE10656-MAS10989,Pause recommended: use-No. of drives with activated pause recommendation,01 8E,
IDE10656-MAS10990,Pause recommended: use-No. of drives with deactivated pause recommendation,01 00,
IDE10669-MAS11003,Internal SIM card: identification-ICCID,89011702272088629891,
IDE10669-MAS11004,Internal SIM card: identification-UICCID,8949320005030623187F,
IDE10927-MAS11760,Total static current-current total quiescent current,0, mA
IDE10927-MAS11761,Total static current-Total time quiescent current exceeded,0.0, H
IDE10973,Generator voltage,14.5, V
IDE10974,12 V elec. system: error status,no error,
IDE11191-MAS12370,Open circuit detection: H-V lines-Wiring circuit 1,Mode not active,
IDE11191-MAS12371,Open circuit detection: H-V lines-Wiring circuit 2,Mode not active,
IDE11282-IDE00704,Battery for emergency call module-Charge level,97, %
IDE11282-MAS00362,Battery for emergency call module-Battery voltage,3318, mV
IDE11282-MAS02201,Battery for emergency call module-Temperature,34, °C
IDE11282-MAS02476,Battery for emergency call module-install,installed,
IDE11282-MAS08415,Battery for emergency call module-Battery condition,01,
IDE11282-MAS12544,Battery for emergency call module-Charge status,was not charged,
IDE11284-MAS00106,Sending status of online functions: history data-Year,2255, yr
IDE11284-MAS00107,Sending status of online functions: history data-Month,15, m
IDE11284-MAS00108,Sending status of online functions: history data-Day,31, d
IDE11284-MAS00109,Sending status of online functions: history data-Hours,31, H
IDE11284-MAS00110,Sending status of online functions: history data-Minutes,63, min
IDE11284-MAS00111,Sending status of online functions: history data-Seconds,63, s
IDE11284-MAS07134,Sending status of online functions: history data-ID services,ID_OTV,
IDE11284-MAS12545,Sending status of online functions: history data-Send attempt: status,not OK,
IDE11286-MAS01737,Crash signal: status-Diagnosis,not active,
IDE11286-MAS03849,Crash signal: status-Crash signal,not active,
IDE11286-MAS11203,Crash signal: status-Output DTM,not active,
IDE11295-MAS12548,Mobile radio network ident.-Country recognition of mobile radio network,36,
IDE11295-MAS12549,Mobile radio network ident.-Operator recognition of mobile radio network,9A,
IDE11378,Mobile radio network: registration status,registered,
IDE11485-MAS02832,HV voltage converter: status for electric drive-Malfunction status,Initializing,
IDE11485-MAS03001,HV voltage converter: status for electric drive-Mode,Initializing,
IDE11486-MAS02246,HV battery charge management: HV activation restriction-Timeout,not active,
IDE11486-MAS09518,HV battery charge management: HV activation restriction-Safety line,not active,
IDE11486-MAS09519,HV battery charge management: HV activation restriction-Message error,not active,
IDE11486-MAS09541,HV battery charge management: HV activation restriction-Act. mode init. error,not active,
IDE11486-MAS09542,HV battery charge management: HV activation restriction-Error status init. error,not active,
IDE11486-MAS09543,HV battery charge management: HV activation restriction-Operating mode error,not active,
IDE11486-MAS09544,HV battery charge management: HV activation restriction-No component function,not active,
IDE11486-MAS09545,HV battery charge management: HV activation restriction-Sequence error,not active,
IDE11486-MAS12351,HV battery charge management: HV activation restriction-HV voltage measurement error,not active,
IDE11486-MAS13068,HV battery charge management: HV activation restriction-HV voltage measurement initialization error,not active,
IDE11586-IDE04447,Status drive profile selection for integral steering-Function status,not engaged,
IDE11586-IDE06260,Status drive profile selection for integral steering-ID number,0,
IDE11586-MAS01156,Status drive profile selection for integral steering-Communication status,OK,
IDE11586-MAS01447,Status drive profile selection for integral steering-Act.val.,0,
IDE11661-IDE06930,Autonomous operation states-Voltage converter: status: Status,ERROR,
IDE11661-IDE08958,Autonomous operation states-H-V system: start request,active,
IDE11661-MAS07605,Autonomous operation states-Charge request,ERROR,
IDE11661-MAS08040,Autonomous operation states-Automatic recharging of starter battery,active,
IDE11661-MAS13088,Autonomous operation states-Preconditioning of the interior,ERROR,
IDE11661-MAS13089,Autonomous operation states-High-voltage vehicle electrical system: status,not active,
IDE11662-MAS13090,H-V power distribution-Energy allocation thermal management,12700, Wh
IDE11662-MAS13091,H-V power distribution-Energy allocation12-volt electrical system,102300, Wh
IDE11662-MAS13092,H-V power distribution-Energy content of the high-voltage battery,ERROR,
IDE11663,H-V energy management mode,Standby-mode,
IDE11664,Requirement to recharge the H-V battery charging management,not active,
IDE11671-MAS02246,H-V power transformers: prohibition on turning-on H-V-Timeout,not active,
IDE11671-MAS09518,H-V power transformers: prohibition on turning-on H-V-Safety line,not active,
IDE11671-MAS09519,H-V power transformers: prohibition on turning-on H-V-Message error,not active,
IDE11671-MAS09541,H-V power transformers: prohibition on turning-on H-V-Act. mode init. error,not active,
IDE11671-MAS09542,H-V power transformers: prohibition on turning-on H-V-Error status init. error,not active,
IDE11671-MAS09543,H-V power transformers: prohibition on turning-on H-V-Operating mode error,not active,
IDE11671-MAS09544,H-V power transformers: prohibition on turning-on H-V-No component function,not active,
IDE11671-MAS09545,H-V power transformers: prohibition on turning-on H-V-Sequence error,not active,
IDE11671-MAS12351,H-V power transformers: prohibition on turning-on H-V-HV voltage measurement error,not active,
IDE11671-MAS13068,H-V power transformers: prohibition on turning-on H-V-HV voltage measurement initialization error,not active,
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11675-MAS02246,Roll stabilization: prohibition on turning-on 48V-Timeout,not active,
IDE11675-MAS09519,Roll stabilization: prohibition on turning-on 48V-Message error,not active,
IDE11675-MAS09541,Roll stabilization: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11675-MAS09542,Roll stabilization: prohibition on turning-on 48V-Error status init. error,not active,
IDE11675-MAS09543,Roll stabilization: prohibition on turning-on 48V-Operating mode error,not active,
IDE11675-MAS09544,Roll stabilization: prohibition on turning-on 48V-No component function,not active,
IDE11675-MAS09545,Roll stabilization: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11679-MAS02246,Electrical compressor: prohibition on turning-on 48V-Timeout,not active,
IDE11679-MAS09519,Electrical compressor: prohibition on turning-on 48V-Message error,not active,
IDE11679-MAS09541,Electrical compressor: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11679-MAS09542,Electrical compressor: prohibition on turning-on 48V-Error status init. error,not active,
IDE11679-MAS09544,Electrical compressor: prohibition on turning-on 48V-No component function,not active,
IDE11679-MAS09545,Electrical compressor: prohibition on turning-on 48V-Sequence error,not active,
IDE11679-MAS13455,Electrical compressor: prohibition on turning-on 48V-48 V voltage measurement error,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11682-IDE04447,Status of driving profile selection for exhaust flaps-Function status,engaged,
IDE11682-IDE06260,Status of driving profile selection for exhaust flaps-ID number,0,
IDE11682-MAS01156,Status of driving profile selection for exhaust flaps-Communication status,OK,
IDE11682-MAS01447,Status of driving profile selection for exhaust flaps-Act.val.,0,
IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,Initializing,
IDE11683-MAS13708,Engine electronics: status of 48V network-Error status of electrical compressor,Initializing,
IDE11683-MAS13715,Engine electronics: status of 48V network-Electro compressor mode,Initializing,
IDE11683-MAS13716,Engine electronics: status of 48V network-Error status of drive,Initializing,
IDE11683-MAS13717,Engine electronics: status of 48V network-State of drive,Initializing,
IDE11683-MAS13718,Engine electronics: status of 48V network-Handshake,255,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initializing,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initializing,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initializing,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initializing,
IDE11686-MAS02832,Anti-roll stabilization: status for 48V power-Malfunction status,Initializing,
IDE11686-MAS03001,Anti-roll stabilization: status for 48V power-Mode,Initializing,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS10933,48V activation restriction-Roll stabilization,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery Energy Control Module 2,not active,
IDE11911-SFT00196,48V activation restriction-DC/DC Converter Control Module,not active,
IDE11911-SFT09769,48V activation restriction-Control module for auxiliary air heater,not active,
IDE11911-SFT09997,48V activation restriction-Electrical Charger,not active,
IDE12084-MAS14046,Status of component protection slaves-Node address of the immobilizer master,00 8B,
IDE12084-MAS14047,Status of component protection slaves-Generation of the immobilizer master,Generation 2,
IDE12084-MAS14048,Status of component protection slaves-Authentication status of the immobilizer master,valid authentication,
IDE12084-MAS14053,Status of component protection slaves-Status of start authentication,switched on,
IDE12084-MAS14054,Status of component protection slaves-Start authentication can be deactivated,No,
IDE12084-MAS14055,Status of component protection slaves-Immobilizer master sends authentication request,Yes,
IDE12084-MAS14056,Status of component protection slaves-Status of the IKA key for immobilizer master,IKA key stored,
IDE12084-MAS14059,Status of component protection slaves-Node address of the component protection participant,00 6F,
IDE12084-MAS14060,Status of component protection slaves-Prioritized participant,No,
IDE12084-MAS14061,Status of component protection slaves-Authentication status of the component protection participant,incompletely authenticated,
IDE12084-MAS14062,Status of component protection slaves-Participant extended start authentication,No,
IDE12084-MAS14063,Status of component protection slaves-Component protection participant sends authentication request,No,
IDE12084-MAS14064,Status of component protection slaves-Status of the IKA key for component protection participants,no IKA key stored,
IDE12581-ENG28833,History data 76-Bus_ECU_1,0,
IDE12581-ENG28836,History data 76-Bus_ECU_2,0,
IDE12581-ENG28839,History data 76-Bus_ECU_3,0,
IDE12581-ENG28842,History data 76-Bus_ECU_4,0,
IDE12581-ENG28845,History data 76-Bus_ECU_5,0,
IDE12581-ENG118680,History data 76-Cycle_Counter,74,
IDE12581-ENG106038,History data 76-ECU_1,0,
IDE12581-ENG106039,History data 76-ECU_2,0,
IDE12581-ENG28620,History data 76-ECU_3,0,
IDE12581-ENG106040,History data 76-ECU_4,0,
IDE12581-ENG106041,History data 76-ECU_5,0,
IDE12581-ENG30992,History data 76-ECU_Knock_Out_ECU_1,0, min
IDE12581-ENG30993,History data 76-ECU_Knock_Out_ECU_2,0, min
IDE12581-ENG30994,History data 76-ECU_Knock_Out_ECU_3,0, min
IDE12581-ENG30995,History data 76-ECU_Knock_Out_ECU_4,0, min
IDE12581-ENG30996,History data 76-ECU_Knock_Out_ECU_5,0, min
IDE12581-ENG31201,History data 76-Fkt_Ausloesung_ECU_1,0,
IDE12581-ENG31202,History data 76-Fkt_Ausloesung_ECU_2,0,
IDE12581-ENG31203,History data 76-Fkt_Ausloesung_ECU_3,0,
IDE12581-ENG31204,History data 76-Fkt_Ausloesung_ECU_4,0,
IDE12581-ENG31205,History data 76-Fkt_Ausloesung_ECU_5,0,
IDE12581-ENG32787,History data 76-Sub_System_Aktiv_ECU_1,0,
IDE12581-ENG32788,History data 76-Sub_System_Aktiv_ECU_2,0,
IDE12581-ENG32789,History data 76-Sub_System_Aktiv_ECU_3,0,
IDE12581-ENG32790,History data 76-Sub_System_Aktiv_ECU_4,0,
IDE12581-ENG32791,History data 76-Sub_System_Aktiv_ECU_5,0,
IDE12581-ENG33300,History data 76-Veto_Aktiv_ECU_1,0,
IDE12581-ENG33301,History data 76-Veto_Aktiv_ECU_2,0,
IDE12581-ENG33302,History data 76-Veto_Aktiv_ECU_3,0,
IDE12581-ENG33303,History data 76-Veto_Aktiv_ECU_4,0,
IDE12581-ENG33304,History data 76-Veto_Aktiv_ECU_5,0,
IDE12583-MAS00106,History data 77-Year,2000, yr
IDE12583-MAS00107,History data 77-Month,1, m
IDE12583-MAS00108,History data 77-Day,1, d
IDE12583-MAS00109,History data 77-Hours,0, H
IDE12583-MAS00110,History data 77-Minutes,0, min
IDE12583-ENG28833,History data 77-Bus_ECU_1,0,
IDE12583-ENG28836,History data 77-Bus_ECU_2,0,
IDE12583-ENG28839,History data 77-Bus_ECU_3,0,
IDE12583-ENG28842,History data 77-Bus_ECU_4,0,
IDE12583-ENG28845,History data 77-Bus_ECU_5,0,
IDE12583-ENG118680,History data 77-Cycle_Counter,0,
IDE12583-ENG106038,History data 77-ECU_1,0,
IDE12583-ENG106039,History data 77-ECU_2,0,
IDE12583-ENG28620,History data 77-ECU_3,0,
IDE12583-ENG106040,History data 77-ECU_4,0,
IDE12583-ENG106041,History data 77-ECU_5,0,
IDE12583-ENG30992,History data 77-ECU_Knock_Out_ECU_1,0, min
IDE12583-ENG30993,History data 77-ECU_Knock_Out_ECU_2,0, min
IDE12583-ENG30994,History data 77-ECU_Knock_Out_ECU_3,0, min
IDE12583-ENG30995,History data 77-ECU_Knock_Out_ECU_4,0, min
IDE12583-ENG30996,History data 77-ECU_Knock_Out_ECU_5,0, min
IDE12583-ENG31201,History data 77-Fkt_Ausloesung_ECU_1,0,
IDE12583-ENG31202,History data 77-Fkt_Ausloesung_ECU_2,0,
IDE12583-ENG31203,History data 77-Fkt_Ausloesung_ECU_3,0,
IDE12583-ENG31204,History data 77-Fkt_Ausloesung_ECU_4,0,
IDE12583-ENG31205,History data 77-Fkt_Ausloesung_ECU_5,0,
IDE12583-ENG32787,History data 77-Sub_System_Aktiv_ECU_1,0,
IDE12583-ENG32788,History data 77-Sub_System_Aktiv_ECU_2,0,
IDE12583-ENG32789,History data 77-Sub_System_Aktiv_ECU_3,0,
IDE12583-ENG32790,History data 77-Sub_System_Aktiv_ECU_4,0,
IDE12583-ENG32791,History data 77-Sub_System_Aktiv_ECU_5,0,
IDE12583-ENG118681,History data 77-Time_Since_Clamp_15_Off,0.00, H
IDE12583-ENG33300,History data 77-Veto_Aktiv_ECU_1,0,
IDE12583-ENG33301,History data 77-Veto_Aktiv_ECU_2,0,
IDE12583-ENG33302,History data 77-Veto_Aktiv_ECU_3,0,
IDE12583-ENG33303,History data 77-Veto_Aktiv_ECU_4,0,
IDE12583-ENG33304,History data 77-Veto_Aktiv_ECU_5,0,
IDE13018-MAS02246,Electrical drive 2: high-voltage switch on prevention-Timeout,not active,
IDE13018-MAS09518,Electrical drive 2: high-voltage switch on prevention-Safety line,not active,
IDE13018-MAS09519,Electrical drive 2: high-voltage switch on prevention-Message error,not active,
IDE13018-MAS09542,Electrical drive 2: high-voltage switch on prevention-Error status init. error,not active,
IDE13018-MAS09544,Electrical drive 2: high-voltage switch on prevention-No component function,not active,
IDE13018-MAS09546,Electrical drive 2: high-voltage switch on prevention-Voltage disconnect. init. error,not active,
IDE13018-MAS12345,Electrical drive 2: high-voltage switch on prevention-Active discharge fault,not active,
IDE13019-MAS02246,Electrical drive 3: high-voltage switch on prevention-Timeout,not active,
IDE13019-MAS09518,Electrical drive 3: high-voltage switch on prevention-Safety line,not active,
IDE13019-MAS09519,Electrical drive 3: high-voltage switch on prevention-Message error,not active,
IDE13019-MAS09542,Electrical drive 3: high-voltage switch on prevention-Error status init. error,not active,
IDE13019-MAS09544,Electrical drive 3: high-voltage switch on prevention-No component function,not active,
IDE13019-MAS09546,Electrical drive 3: high-voltage switch on prevention-Voltage disconnect. init. error,not active,
IDE13019-MAS12345,Electrical drive 3: high-voltage switch on prevention-Active discharge fault,not active,
IDE13032,Emergency call module: start condition status,Not available,
IDE13033-MAS15531,Communication status of emergency call module: analysis-Components 1,Not available,
IDE13033-MAS15532,Communication status of emergency call module: analysis-Components 2,Not available,
IDE13033-MAS15533,Communication status of emergency call module: analysis-Components 3,Not available,
IDE13033-MAS15534,Communication status of emergency call module: analysis-Components 4,Available,
IDE13033-MAS15535,Communication status of emergency call module: analysis-Components 5,Available,
IDE13057-MAS15615,Lithium ions starter battery-Battery: fault status,no error,
IDE13057-MAS15620,Lithium ions starter battery-Battery cut-out element: fault status,no error,
IDE13140,History data 78,,
IDE13140,History data 78,*00*00*00*00*00*00*00*00*00*00*00*00*0000000000000008*00400C00*00000000*00000000*0D000000*00000000*00000000*00000000*00**,
IDE13140,History data 78,1048574*2000-00-00-00:00:00*000*04*1*0*0*0*0*0*0*1*0*0*0*0*0*0*0*1*119*00*00*00*00*00*64*00*30*28*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*0000000000000008*00400C00*00000000*00000000*0D000000*00000000*00000000*00000000*00**,
IDE13140,History data 78,1048574*2000-00-00-00:00:00*000*04*1*0*0*0*0*0*0*1*0*0*0*0*0*0*0*1*119*00*00*00*00*00*64*00*30*28*00*00*00*00*00*00*00,
IDE13141,History data 79,0029851*2019-04-22-09:00:18**,
IDE13141,History data 79,1048574*2000-00-00-00:00:00**,
IDE13142,History data 80,1048574*2000-00-00-00:00:00*000*04*1*0*0*0*0*0*0*1*0*0*0*0*0*0*0*1*119*00*00*00*00*00*64*00*30*28*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*0000000000000008*00400C00*00000000*00000000*0D000000*00000000*00000000*00000000*00**,
IDE13142,History data 80,1048574*2000-00-00-00:00:00*000*04*1*0*0*0*0*0*0*1*0*0*0*0*0*0*0*1*119*00*00*00*00*00*64*00*30*28*00*00*00*00*00*00*00,
IDE13142,History data 80,,
IDE13142,History data 80,*00*00*00*00*00*00*00*00*00*00*00*00*0000000000000008*00400C00*00000000*00000000*0D000000*00000000*00000000*00000000*00**,
IDE13398-ENG39192,Driving profile history data 5-Battery_Charge,0, min
IDE13398-ENG39193,Driving profile history data 5-Battery_Hold,0, min
IDE13398-ENG39289,Driving profile history data 5-EV,0, min
IDE13398-ENG98636,Driving profile history data 5-Hybrid,0, min
IDE13402-MAS06193,Driving profile history data 6-Profile 1,0, km
IDE13402-MAS06194,Driving profile history data 6-Profile 2,0, km
IDE13402-MAS06195,Driving profile history data 6-Profile 3,0, km
IDE13402-MAS06196,Driving profile history data 6-Profile 4,0, km
IDE13573-IDE11095,Advanced StartStop display version-Rqmt. spec. version,,
IDE13573-MAS01483,Advanced StartStop display version-Softwareversion,,
IDE13673,Microphone 2 status,Not available,
IDE13674,Microphone 2 voltage consumption,0.00, mA
IDE13754-MAS03095,Diagnosis filter: status-Function status,Function is not active,
IDE13754-MAS16866,Diagnosis filter: status-Odometer,0, km
IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,Not deactivated,
IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter is not active,
IDE13755,Diagnosis filter: history data,,
IDE13848-MAS06568,Onboard network components: medium-voltage-Auxiliary Heater,not installed,
IDE13848-MAS10933,Onboard network components: medium-voltage-Roll stabilization,not installed,
IDE13848-MAS11243,Onboard network components: medium-voltage-Battery Management 48V,not installed,
IDE13848-MAS16949,Onboard network components: medium-voltage-Active setup verification,not installed,
IDE13848-MAS16953,Onboard network components: medium-voltage-Belt driven starter generator 48V,not installed,
IDE13848-MAS17010,Onboard network components: medium-voltage-48V Vehicle Electrical System Storage Capacitor,not installed,
IDE13848-SFT00196,Onboard network components: medium-voltage-DC/DC Converter Control Module,not installed,
IDE13848-SFT09997,Onboard network components: medium-voltage-Electrical Charger,not installed,
IDE13849-IDE12114,Onboard network diagnosis 48V 1-48V vehicle electrical system diagnosis,requested,
IDE13849-MAS01867,Onboard network diagnosis 48V 1-Measurement,OK,
IDE13849-MAS15721,Onboard network diagnosis 48V 1-Battery management 48V power supply battery,Initializing,
IDE13850-MAS01867,Onboard network diagnosis 48V 2-Measurement,OK,
IDE13850-MAS06864,Onboard network diagnosis 48V 2-Generator actual voltage,Initializing,
IDE13850-MAS15119,Onboard network diagnosis 48V 2-48V vehicle electrical system,not active,
IDE13850-MAS15722,Onboard network diagnosis 48V 2-Battery management 48V: actual voltage,Initializing,
IDE13850-MAS16957,Onboard network diagnosis 48V 2-Electrically driven compressor: current voltage,Initializing,
IDE13850-MAS16958,Onboard network diagnosis 48V 2-Voltage converter: current voltage,Initializing,
IDE13850-MAS16959,Onboard network diagnosis 48V 2-Roll stabilization front axis current voltage,Initializing,
IDE13850-MAS16960,Onboard network diagnosis 48V 2-Roll stabilization rear axis current voltage,Initializing,
IDE13850-MAS16961,Onboard network diagnosis 48V 2-Active setup verification front axle current voltage,Initializing,
IDE13850-MAS16962,Onboard network diagnosis 48V 2-Active setup verification rear axle current voltage,Initializing,
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,0E,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,00,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,00,
MAS00077-MAS06797,Immobilizer-Status configuration,04,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,7,
MAS00464-MAS00108,Standard - ambient data 1-Day,12,
MAS00464-MAS00109,Standard - ambient data 1-Hours,16,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,0,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,9,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,99,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,34677,
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,not activated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,not activated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,3,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,Audi,
MAS00769-MAS01288,Multifunction steering wheel control module-Signal horn,not activated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Unknown (0),
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Unknown (0),
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,11,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,0,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,not activated,
MAS01758-IDE00500,Date/time-Hour,20, H
MAS01758-IDE00501,Date/time-Minute,0, min
MAS01758-IDE00502,Date/time-Year,2019, yr
MAS01758-IDE00503,Date/time-Month,7, m
MAS01758-IDE00504,Date/time-Day,12, d
MAS01758-MAS00111,Date/time-Seconds,10, s
MAS01758-MAS02238,Date/time-Current,Winter time,
MAS01758-MAS03617,Date/time-Time zone,0.00, H
MAS04394-IDE03580,Connection status-Country code for mobile network,310,
MAS04394-IDE07699,Connection status-Mobile network operator,410,
MAS04394-MAS03991,Connection status-Reception level antenna 1,17.69, %
MAS04394-MAS04460,Connection status-Validity,valid,
MAS04394-MAS08406,Connection status-Network type,Unknown (19),
MAS04394-MAS08407,Connection status-Data connection,active,
MAS04394-MAS13670,Connection status-Mobile radio cell identification,4381,
MAS04394-ENG123308,Connection status-TCP_Connection_State,not active,
MAS06413,Audio signal output,Electrical OK,
MAS08178-IDE02493,Crash information-Automatic door unlocking,Not available,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08178-MAS08956,Crash information-Automatic emergency call activated:Fuel shut-off,Not available,
MAS08200,Emergency call speaker status,Electrical OK,
ENG06732-ENG06827,12V_zustart_prohibition-12V_start_system_error,00 04,
ENG06732-ENG06826,12V_zustart_prohibition-12V_zustart_prohibition_on_drive,00 58,
ENG06732-ENG06825,12V_zustart_prohibition-12V_zustart_prohibition_on_stop,00 00,
ENG08764-MAS01867,48V_overvoltage_check-Measurement,OK,
ENG08764-ENG09344,48V_overvoltage_check-Bms_48V_actual_voltage,Initializing,
ENG08764-ENG09345,48V_overvoltage_check-Bms_48V_Soc,Initializing,
ENG08769-MAS11874,48V_Zero_potential_status-Overall status,Initializing,
ENG04784,Break_Recommendation_Index,1.00,
ENG04785-ENG126257,Break_Recommendation_TTNR-TTNR_DS,0,
ENG04785-ENG126256,Break_Recommendation_TTNR-TTNR_SW,60042,
ENG06743,Challenge_KS,B1 B7 16 49,
ENG06744-MAS06854,Checksumme_KS-Version,81,
ENG06744-MAS06855,Checksumme_KS-Test sum,8B F9 1B F9,
ENG08767-ENG09366,coldstart_requirement_engine-requirement_12V_start,active,
ENG08767-ENG09367,coldstart_requirement_engine-requirement_48V_start,not active,
ENG118784-ENG05030,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Active_Body_Control,not active,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG05036,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Autonomous_Emergency_Breaking,not active,
ENG118784-ENG05035,Driv._Prof._Sel._Coord._Retry_State-Retry_State_battery_management,not active,
ENG118784-ENG118738,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Beam_Control,not active,
ENG118784-ENG05018,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG05023,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Centre_and_rear_axle_differential,not active,
ENG118784-ENG118735,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Climatronic,not active,
ENG118784-ENG05029,Driv._Prof._Sel._Coord._Retry_State-Retry_State_corner_assist,not active,
ENG118784-ENG05032,Driv._Prof._Sel._Coord._Retry_State-Retry_State_cruise_control,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG05024,Driv._Prof._Sel._Coord._Retry_State-Retry_State_e_quattro,not active,
ENG118784-ENG05031,Driv._Prof._Sel._Coord._Retry_State-Retry_State_E_Sound,not active,
ENG118784-ENG05038,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Differential_Lock,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG05037,Driv._Prof._Sel._Coord._Retry_State-Retry_State_engine_operating_state,not active,
ENG118784-ENG05021,Driv._Prof._Sel._Coord._Retry_State-Retry_State_exhaust_gas_flaps,not active,
ENG118784-ENG05039,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Forward_Collision_Warning_Objects,not active,
ENG118784-ENG05040,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Forward_Collision_Warning_Pedestrian,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG05041,Driv._Prof._Sel._Coord._Retry_State-Retry_State_integral_steering,not active,
ENG118784-ENG05034,Driv._Prof._Sel._Coord._Retry_State-Retry_State_lift_control_unit,not active,
ENG118784-ENG05025,Driv._Prof._Sel._Coord._Retry_State-Retry_State_matrixbeam,not active,
ENG118784-ENG05022,Driv._Prof._Sel._Coord._Retry_State-Retry_State_middle_differential,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG05015,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Rear_Axle_Differential,not active,
ENG118784-ENG05027,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_axle_steering,not active,
ENG118784-ENG05017,Driv._Prof._Sel._Coord._Retry_State-Retry_State_ride-height_control_system,not active,
ENG118784-ENG118740,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Routing_Adaption,not active,
ENG118784-ENG05020,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sailing_suggestion,not active,
ENG118784-ENG05033,Driv._Prof._Sel._Coord._Retry_State-Retry_State_servo_tronic,not active,
ENG118784-ENG05019,Driv._Prof._Sel._Coord._Retry_State-Retry_State_sidepanel_seat,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG05026,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Spoiler_Control_Unit,not active,
ENG118784-ENG05028,Driv._Prof._Sel._Coord._Retry_State-Retry_State_stabilisation_control_unit,not active,
ENG118784-ENG118731,Driv._Prof._Sel._Coord._Retry_State-Retry_State_StartStop,not active,
ENG118784-ENG05016,Driv._Prof._Sel._Coord._Retry_State-Retry_State_steering_control_unit,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not recognized,
ENG118786-ENG05042,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile_BMA,not recognized,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,3,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG06742-MAS02832,eABC_48V_status-Malfunction status,Initializing,
ENG06742-MAS03001,eABC_48V_status-Mode,Initializing,
ENG118766,eASS_operation_status,active,
ENG06152-ENG112328,eCall Active Cell ID-CID,04 D9 11 1D,
ENG06150,eCall_Current_Heading,65535, °
ENG06149-MAS01779,eCall_Current_Position-Length,81, °
ENG06149-MAS01780,eCall_Current_Position-Width,41, °
ENG06151-ENG06150,eCall_Current_Position_Confidence-eCall_Current_Heading,100, m
ENG06154-MAS01779,eCall_Last_Valid_Position-Length,81, °
ENG06154-MAS01780,eCall_Last_Valid_Position-Width,41, °
ENG06153-ENG98842,eCall_Position_Confidence-Position,100, m
ENG04786-ENG05075,Ehr_segment_load-attribute_pool,0.00,
ENG04786-ENG05074,Ehr_segment_load-segment_pool,0.00,
ENG04786-ENG05076,Ehr_segment_load-speedlimit_pool,0.00,
ENG106121-ENG101157,EM_Battery_charge_discharge-BZE_Q_Elad,3300.0, Ah
ENG106121-ENG100159,EM_Battery_charge_discharge-BZE_Q_Lad,3425.5, Ah
ENG04782,EM_bdm_error_state,0,
ENG106123,EM_blAlternator On,On,
ENG26761,EM_Current_Control,not active,
ENG118437,EM_IAlternatorReserve,92.0, A
ENG118434,EM_LoadResponse Time,3, s
ENG106154,EM_PAltMechanical,800, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,94, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,100, %
ENG106157,EM_RecuMode_Engine,Neutral,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,Release,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,Release,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,Release,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,Release,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,No enabling,
ENG118780-ENG04973,EM_Recuperation_Precondition-battery_disconnected,Release,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,Release,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,Release,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,Release,
ENG118780-ENG30744,EM_Recuperation_Precondition-dc_source_activity,Release,
ENG118780-ENG30745,EM_Recuperation_Precondition-dc_source_diagnosis,Release,
ENG118780-ENG118444,EM_Recuperation_Precondition-generator_workload,Release,
ENG118780-ENG31832,EM_Recuperation_Precondition-hv_cutoff_level,Release,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,Release,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,Release,
ENG118780-ENG32123,EM_Recuperation_Precondition-mv_cutoff_level,Release,
ENG118780-ENG102605,EM_Recuperation_Precondition-outside_temperature,Release,
ENG118780-ENG104256,EM_Recuperation_Precondition-production_mode,Release,
ENG118780-ENG04974,EM_Recuperation_Precondition-trailer_dedection,Release,
ENG118780-ENG111086,EM_Recuperation_Precondition-Transport_Mode,Release,
ENG106169,EM_valHlkLevelRequirement,950, W
ENG106169,EM_valHlkLevelRequirement,Stage 1,
ENG06717,EM_vehicle_bus_state,01 03 00 3D,
ENG04777,EM_vehicle_state,02 10,
ENG04779-ENG04996,EM_voltage_control_state-EM_das_control_state,0,
ENG04779-ENG04995,EM_voltage_control_state-EM_gas_control_state,1,
ENG04779-ENG04997,EM_voltage_control_state-EM_ras_control_state,0,
ENG04779-ENG04998,EM_voltage_control_state-EM_Ureg_control_state,1,
ENG04776,EMZ_state,6,
ENG04775,engine_identifier,3,
ENG04780,freewheel_info,0,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,160101,
ENG118782-ENG05091,Gateway app. software identification-software_version_cGW,090025,
ENG118782-ENG05083,Gateway app. software identification-software_version_cha,250300,
ENG118782-ENG05090,Gateway app. software identification-software_version_eHorizont,130600,
ENG118782-ENG05085,Gateway app. software identification-software_version_HvEm,120800,
ENG118782-ENG05086,Gateway app. software identification-software_version_HvK,120800,
ENG118782-ENG05092,Gateway app. software identification-software_version_MvEM,120800,
ENG118782-ENG05093,Gateway app. software identification-software_version_MVK,120800,
ENG118782-ENG05084,Gateway app. software identification-software_version_NvEm,120800,
ENG118782-ENG05087,Gateway app. software identification-software_version_ObDc,080524,
ENG118782-ENG05088,Gateway app. software identification-software_version_PE,060610,
ENG118782-ENG05089,Gateway app. software identification-software_version_range,100105,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,110201,
ENG04773-ENG04886,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x03,00 00 00,
ENG04773-ENG31556,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x04,00 00 00,
ENG04773-ENG31557,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x05,00 00 00,
ENG04773-ENG31558,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x06,00 00 00,
ENG04773-ENG31559,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x07,00 00 00,
ENG04773-ENG31560,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x08,00 00 00,
ENG04773-ENG04887,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0A,00 00 00,
ENG04773-ENG04888,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0B,00 00 00,
ENG04773-ENG04889,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0C,00 00 00,
ENG04773-ENG04890,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0E,00 00 00,
ENG04773-ENG04891,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0F,00 00 00,
ENG04773-ENG04892,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x12,00 00 00,
ENG04773-ENG04893,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x13,00 00 00,
ENG04773-ENG04894,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x14,00 00 00,
ENG04773-ENG04895,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x15,00 00 00,
ENG04773-ENG04896,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x16,00 00 00,
ENG04773-ENG04897,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1A,00 00 00,
ENG04773-ENG04898,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1B,00 00 00,
ENG04773-ENG04899,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1C,00 00 00,
ENG04773-ENG04900,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1E,00 00 00,
ENG04773-ENG04901,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x23,10 00 00,
ENG04773-ENG04902,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x24,00 00 00,
ENG04773-ENG04903,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x27,04 00 00,
ENG04773-ENG04904,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2A,00 00 00,
ENG04773-ENG04905,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2B,00 00 00,
ENG04773-ENG04906,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2C,00 00 00,
ENG04773-ENG04907,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2D,00 00 00,
ENG04773-ENG04908,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2E,00 00 00,
ENG04773-ENG04909,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x30,00 00 00,
ENG04773-ENG04910,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x31,00 00 00,
ENG04773-ENG04911,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x32,00 00 00,
ENG04773-ENG04912,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x3B,00 00 00,
ENG04773-ENG04913,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x41,00 00 00,
ENG04773-ENG04914,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x42,00 00 00,
ENG04773-ENG31561,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x43,00 00 00,
ENG04773-ENG04915,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x44,00 01 00,
ENG04773-ENG04916,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x46,00 00 00,
ENG04773-ENG04917,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x47,02 00 00,
ENG04773-ENG116879,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x49,00 00 00,
ENG04773-ENG04918,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4A,00 00 00,
ENG04773-ENG04919,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4B,01 00 00,
ENG04773-ENG04920,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4C,08 00 00,
ENG04773-ENG04921,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4D,08 00 00,
ENG04773-ENG04922,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4E,00 00 00,
ENG04773-ENG04923,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4F,00 00 00,
ENG04773-ENG04924,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x53,00 00 00,
ENG04773-ENG04925,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x56,00 00 00,
ENG04773-ENG04926,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x57,00 00 00,
ENG04773-ENG31562,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x59,00 00 00,
ENG04773-ENG04927,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x5A,00 00 00,
ENG04773-ENG04928,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x60,00 00 00,
ENG04773-ENG31563,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x61,00 00 00,
ENG04773-ENG04929,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x63,00 00 00,
ENG04773-ENG04930,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x64,00 00 00,
ENG04773-ENG04931,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x69,00 00 00,
ENG04773-ENG04932,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x6A,00 00 00,
ENG04773-ENG04933,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x73,E0 00 00,
ENG04773-ENG04934,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x76,00 00 00,
ENG04773-ENG04935,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x77,00 00 00,
ENG04773-ENG04936,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x78,00 00 00,
ENG04773-ENG04937,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x7B,00 00 00,
ENG04773-ENG04938,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x7C,00 00 00,
ENG04773-ENG04939,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x80,00 00 00,
ENG04773-ENG04940,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x84,10 00 00,
ENG04773-ENG04941,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x87,08 00 00,
ENG04773-ENG04942,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x88,08 00 00,
ENG04773-ENG31564,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x89,00 00 00,
ENG04773-ENG04943,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8A,00 00 00,
ENG04773-ENG04944,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8B,00 00 00,
ENG04773-ENG04945,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8E,00 00 00,
ENG04773-ENG04946,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8F,00 00 00,
ENG04773-ENG04947,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x93,00 00 00,
ENG04773-ENG04948,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x94,00 00 00,
ENG04773-ENG04949,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x95,08 00 00,
ENG04773-ENG04950,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9B,00 00 00,
ENG04773-ENG04951,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9C,00 00 00,
ENG04773-ENG04952,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9D,00 00 00,
ENG04773-ENG04953,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9E,00 00 00,
ENG04773-ENG04954,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xA0,10 00 00,
ENG04773-ENG08116,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xAD,00 00 00,
ENG04773-ENG31565,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xAE,00 00 00,
ENG04773-ENG31566,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xB8,00 00 00,
ENG04773-ENG31567,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xBB,00 00 00,
ENG04773-ENG116981,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF3,00 00 00,
ENG04772-ENG04819,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x03,00,
ENG04772-ENG04833,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x1E,00,
ENG04772-ENG04843,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x32,00,
ENG04772-ENG04878,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x93,00,
ENG04772-ENG04879,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x94,00,
ENG04772-ENG04880,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x95,00,
ENG04772-ENG04881,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x9B,00,
ENG04772-ENG04882,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x9C,00,
ENG04772-ENG31568,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x04,00,
ENG04772-ENG31569,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x05,00,
ENG04772-ENG31570,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x06,00,
ENG04772-ENG31571,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x07,00,
ENG04772-ENG31572,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x08,00,
ENG04772-ENG04820,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0A,00,
ENG04772-ENG04821,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0B,00,
ENG04772-ENG04822,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0C,02,
ENG04772-ENG04823,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0E,02,
ENG04772-ENG04824,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0F,02,
ENG04772-ENG04825,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x12,02,
ENG04772-ENG04826,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x13,02,
ENG04772-ENG04827,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x14,02,
ENG04772-ENG04828,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x15,02,
ENG04772-ENG04829,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x16,00,
ENG04772-ENG04830,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1A,00,
ENG04772-ENG04831,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1B,00,
ENG04772-ENG04832,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1C,00,
ENG04772-ENG04834,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x23,02,
ENG04772-ENG06781,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x24,00,
ENG04772-ENG04835,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x27,00,
ENG04772-ENG04836,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2A,00,
ENG04772-ENG04837,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2B,00,
ENG04772-ENG04838,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2C,00,
ENG04772-ENG04839,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2D,00,
ENG04772-ENG04840,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2E,00,
ENG04772-ENG04841,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x30,00,
ENG04772-ENG04842,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x31,00,
ENG04772-ENG04844,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x3B,00,
ENG04772-ENG04845,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x41,00,
ENG04772-ENG04846,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x42,00,
ENG04772-ENG31573,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x43,00,
ENG04772-ENG04847,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x44,00,
ENG04772-ENG04848,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x46,02,
ENG04772-ENG04849,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x47,00,
ENG04772-ENG116935,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x49,00,
ENG04772-ENG04850,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4A,02,
ENG04772-ENG04851,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4B,02,
ENG04772-ENG04852,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4C,02,
ENG04772-ENG04853,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4D,00,
ENG04772-ENG04854,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4E,00,
ENG04772-ENG31574,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4F,00,
ENG04772-ENG04856,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x53,02,
ENG04772-ENG04857,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x56,00,
ENG04772-ENG04858,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x57,00,
ENG04772-ENG31575,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x59,00,
ENG04772-ENG04859,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x5A,00,
ENG04772-ENG04860,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x60,00,
ENG04772-ENG31576,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x61,00,
ENG04772-ENG06782,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x63,00,
ENG04772-ENG04861,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x64,00,
ENG04772-ENG04862,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x69,02,
ENG04772-ENG04863,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x6A,00,
ENG04772-ENG04864,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x73,02,
ENG04772-ENG04865,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x76,02,
ENG04772-ENG04866,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x77,02,
ENG04772-ENG04867,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x78,00,
ENG04772-ENG04868,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x7B,00,
ENG04772-ENG04869,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x7C,00,
ENG04772-ENG04870,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x80,00,
ENG04772-ENG04871,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x84,00,
ENG04772-ENG04872,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x87,00,
ENG04772-ENG04873,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x88,00,
ENG04772-ENG31577,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x89,00,
ENG04772-ENG04874,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8A,00,
ENG04772-ENG04875,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8B,02,
ENG04772-ENG04876,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8E,00,
ENG04772-ENG04877,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8F,00,
ENG04772-ENG04883,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x9D,00,
ENG04772-ENG04884,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x9E,00,
ENG04772-ENG04885,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xA0,00,
ENG04772-ENG08115,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xAD,00,
ENG04772-ENG31578,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xAE,00,
ENG04772-ENG31579,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xB8,00,
ENG04772-ENG31580,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xBB,00,
ENG04772-ENG117001,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF3,00,
ENG117867-ENG06211,GPS_Count_Satellite_Phase_Lock_Counter-count_sattelite_phase_lock,0,
ENG123212-ENG123347,GPS_Dilution_of_precision-geometric_dilution_of_precision,00 00,
ENG123212-ENG123346,GPS_Dilution_of_precision-horizontal_dilution_of_precision,00 00,
ENG123212-ENG123296,GPS_Dilution_of_precision-Initiation,not initialized,
ENG123212-ENG123348,GPS_Dilution_of_precision-positional_dilution_of_precision,00 00,
ENG123212-ENG123345,GPS_Dilution_of_precision-time_dilution_of_precision,00 00,
ENG123212-ENG123344,GPS_Dilution_of_precision-vertical_dilution_of_precision,00 00,
ENG117868-ENG06212,GPS_Satellite_Code_Lock_Counter-count_sattelite_code_lock,0,
ENG06145-ENG06200,hvk_high_voltag_total_discharge_prevention-dcdc_target_mode,0,
ENG06145-ENG06199,hvk_high_voltag_total_discharge_prevention-hvk_total_discharge_prevention_state,0,
ENG06145-ENG06201,hvk_high_voltag_total_discharge_prevention-tme_ekk_target_mode,0,
ENG06145-ENG06202,hvk_high_voltag_total_discharge_prevention-tme_hvptc_target_mode,0,
ENG06144-ENG30377,hvk_high_voltage_zero_potential-awc_zero_potential,0,
ENG06144-ENG06195,hvk_high_voltage_zero_potential-bms_failure_state,7,
ENG06144-ENG06192,hvk_high_voltage_zero_potential-bms_zero_potential,0,
ENG06144-ENG06194,hvk_high_voltage_zero_potential-em1_zero_potential,0,
ENG06144-ENG39295,hvk_high_voltage_zero_potential-Flexray_status,1,
ENG06144-ENG39330,hvk_high_voltage_zero_potential-HCAN_status,1,
ENG06144-ENG06198,hvk_high_voltage_zero_potential-hvk_total_zero_potential,0,
ENG06144-ENG06196,hvk_high_voltage_zero_potential-hvlm_connector_plug_state,0,
ENG06144-ENG06193,hvk_high_voltage_zero_potential-lad_zero_potential,0,
ENG123205,Incoming_call_line_state,Idle,
ENG26975-ENG30888,MFLe_LIN-DI_Emblem,OFF,
ENG26975-ENG46163,MFLe_LIN-DI_KL_50xs,0,
ENG26975-ENG46164,MFLe_LIN-DI_KL_58xt,10,
ENG26975-ENG30921,MFLe_LIN-Dimmung_01_gueltig,invalid,
ENG26975-ENG31890,MFLe_LIN-Klemme_15_MFL,On,
ENG26975-ENG31892,MFLe_LIN-KLR_Modusanforderung,Normal_mode,
ENG26975-ENG31980,MFLe_LIN-LR_HZG_Freigabe,no_restriction,
ENG26975-ENG31981,MFLe_LIN-LR_HZG_on_off,OFF,
ENG26975-ENG32052,MFLe_LIN-MFLe_Anzeige_LaunchControl,display_off,
ENG26975-ENG32053,MFLe_LIN-MFLe_Anzeige_MAP,OFF,
ENG26975-ENG32054,MFLe_LIN-MFLe_Anzeige_Sport,display_off,
ENG26975-ENG32055,MFLe_LIN-MFLe_Anzeige_Sport_Plus,display_off,
ENG26975-ENG32056,MFLe_LIN-MFLe_Tastencode_alt_neu,apply_keycode_new,
ENG26975-ENG32226,MFLe_LIN-P_Mode_MFL,OFF,
ENG06740,MVEM_dc_current_Mv,204.0, A
ENG06739,MVEM_dc_power_desired,0, W
ENG06734,MVEM_DC_voltage_desired,63.50, V
ENG06741,MVEM_dc_voltage_Mv,63.25, V
ENG06736-ENG09198,MVEM_Derating_voltage-Derating_group_A,63.50, V
ENG06736-ENG09199,MVEM_Derating_voltage-Derating_group_B,63.50, V
ENG06736-ENG09200,MVEM_Derating_voltage-Derating_group_C,63.50, V
ENG06736-ENG09337,MVEM_Derating_voltage-Derating_Umax_feedback,63.5, V
ENG06738,MVEM_EMG_level_of_capacity,100.000, %
ENG06737,MVEM_Emg_voltage_desired,63.50, V
ENG06733,MVEM_Mv_current,-11, A
ENG08763-ENG09342,MVEM_recommendation_Dcdc-Dcdc_boost_mode,not active,
ENG08763-ENG09343,MVEM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG08762-ENG09338,MVEM_release-12V_coldstart_release,No enabling,
ENG08762-ENG09339,MVEM_release-12V_warmstart_release,No enabling,
ENG08762-ENG09340,MVEM_release-48V_coldstart_release,No enabling,
ENG08762-ENG09341,MVEM_release-start_stopp_support_release,No enabling,
ENG06735,MVEM_RSG_maximal_current,508, A
ENG08761-ENG09336,MVEM_RSG_maximal_voltage-RSG_maximal_voltage,63.50, V
ENG06718-ENG06799,NVEM_12Vrsg_input_parameter-rsg_cutoff_ rotation_speed,3000, /min
ENG06718-ENG06798,NVEM_12Vrsg_input_parameter-rsg_exciter current_limit,16.0, A
ENG06718-ENG06800,NVEM_12Vrsg_input_parameter-rsg_load_response_time,3, s
ENG06718-ENG06801,NVEM_12Vrsg_input_parameter-rsg_target_mode,0,
ENG06718-ENG06797,NVEM_12Vrsg_input_parameter-rsg_voltage_desired,10.6, V
ENG04778-ENG55511,NVEM_Hlr_release-Release_FlHz_hl,No enabling,
ENG04778-ENG55512,NVEM_Hlr_release-Release_FlHz_hr,No enabling,
ENG04778-ENG55513,NVEM_Hlr_release-Release_FlHz_rest_seat,No enabling,
ENG04778-ENG55514,NVEM_Hlr_release-Release_FlHz_vl,No enabling,
ENG04778-ENG55515,NVEM_Hlr_release-Release_FlHz_vr,No enabling,
ENG04778-ENG04987,NVEM_Hlr_release-Release_FSH,OFF,
ENG04778-ENG04986,NVEM_Hlr_release-Release_HSH,No enabling,
ENG04778-ENG04989,NVEM_Hlr_release-Release_KRH_vl,No enabling,
ENG04778-ENG04988,NVEM_Hlr_release-Release_KRH_vr,No enabling,
ENG04778-ENG04990,NVEM_Hlr_release-Release_LRH,No enabling,
ENG04778-ENG04991,NVEM_Hlr_release-Release_PTC,No enabling,
ENG04778-ENG04992,NVEM_Hlr_release-Release_PTC_linear,0, W
ENG04778-ENG04975,NVEM_Hlr_release-Release_SIH_Fond,Release,
ENG04778-ENG04979,NVEM_Hlr_release-Release_SIH_hl,No enabling,
ENG04778-ENG04978,NVEM_Hlr_release-Release_SIH_hr,No enabling,
ENG04778-ENG04977,NVEM_Hlr_release-Release_SIH_vl,No enabling,
ENG04778-ENG04976,NVEM_Hlr_release-Release_SIH_vr,No enabling,
ENG04778-ENG04983,NVEM_Hlr_release-Release_SIL_hl,No enabling,
ENG04778-ENG04982,NVEM_Hlr_release-Release_SIL_hr,No enabling,
ENG04778-ENG04981,NVEM_Hlr_release-Release_SIL_vl,No enabling,
ENG04778-ENG04980,NVEM_Hlr_release-Release_SIL_vr,No enabling,
ENG04778-ENG04985,NVEM_Hlr_release-Release_Sp_heatin_codriver,No enabling,
ENG04778-ENG04984,NVEM_Hlr_release-Release_Sp_heatin_driver,No enabling,
ENG04778-ENG32447,NVEM_Hlr_release-Release_TCH,No enabling,
ENG06726,NVEM_Hv_DcDc_voltage_desired_nv,10.6, V
ENG04783,NVEM_hybrid_info,3,
ENG06730,NVEM_Mv_DcDc_voltage_desired_nv,10.6, V
ENG04774-ENG06796,NVEM_Voltage_Request-Voltage_Request_BCM,not active,
ENG04774-ENG04969,NVEM_Voltage_Request-Voltage_Request_ClimatControl,not active,
ENG04774-ENG04968,NVEM_Voltage_Request-Voltage_Request_engine,Stage 1,
ENG04774-ENG04966,NVEM_Voltage_Request-Voltage_Request_EPS,not active,
ENG04774-ENG04967,NVEM_Voltage_Request-Voltage_Request_ESP,not active,
ENG04774-ENG04970,NVEM_Voltage_Request-Voltage_Request_GearControl,not active,
ENG04774-ENG04971,NVEM_Voltage_Request-Voltage_Request_Reduction_Alternator_Load,not active,
ENG04788-ENG98667,operation_hours-Kilometers,787,
ENG123204,Outgoing_call_line_state,line_free,
ENG08771-ENG09431,Stack_Size_Max-Stack_Size_Max_ISR,10, %
ENG08771-ENG09408,Stack_Size_Max-Stack_Size_Max_Task_01,0, %
ENG08771-ENG09409,Stack_Size_Max-Stack_Size_Max_Task_02,25, %
ENG08771-ENG09410,Stack_Size_Max-Stack_Size_Max_Task_03,0, %
ENG08771-ENG09411,Stack_Size_Max-Stack_Size_Max_Task_04,0, %
ENG08771-ENG09412,Stack_Size_Max-Stack_Size_Max_Task_05,0, %
ENG08771-ENG09413,Stack_Size_Max-Stack_Size_Max_Task_06,16, %
ENG08771-ENG09414,Stack_Size_Max-Stack_Size_Max_Task_07,0, %
ENG08771-ENG09415,Stack_Size_Max-Stack_Size_Max_Task_08,52, %
ENG08771-ENG09416,Stack_Size_Max-Stack_Size_Max_Task_09,16, %
ENG08771-ENG09417,Stack_Size_Max-Stack_Size_Max_Task_10,31, %
ENG08771-ENG09418,Stack_Size_Max-Stack_Size_Max_Task_11,31, %
ENG08771-ENG09419,Stack_Size_Max-Stack_Size_Max_Task_12,61, %
ENG08771-ENG09420,Stack_Size_Max-Stack_Size_Max_Task_13,50, %
ENG08771-ENG09421,Stack_Size_Max-Stack_Size_Max_Task_14,0, %
ENG08771-ENG09422,Stack_Size_Max-Stack_Size_Max_Task_15,0, %
ENG08771-ENG09423,Stack_Size_Max-Stack_Size_Max_Task_16,0, %
ENG08771-ENG09424,Stack_Size_Max-Stack_Size_Max_Task_17,0, %
ENG08771-ENG09425,Stack_Size_Max-Stack_Size_Max_Task_18,0, %
ENG08771-ENG09426,Stack_Size_Max-Stack_Size_Max_Task_19,0, %
ENG08771-ENG09427,Stack_Size_Max-Stack_Size_Max_Task_20,0, %
ENG08771-ENG09428,Stack_Size_Max-Stack_Size_Max_Task_21,0, %
ENG08771-ENG09429,Stack_Size_Max-Stack_Size_Max_Task_22,0, %
ENG08771-ENG09430,Stack_Size_Max-Stack_Size_Max_Task_23,15, %
ENG04781,StartStop_info,0,
ENG08770-ENG09376,State_Dataset_AuxFunktions-Datensatz_0,not_valid,
ENG08770-ENG09377,State_Dataset_AuxFunktions-Datensatz_1,valid,
ENG08770-ENG09392,State_Dataset_AuxFunktions-Datensatz_10,not_valid,
ENG08770-ENG09393,State_Dataset_AuxFunktions-Datensatz_11,not_valid,
ENG08770-ENG09394,State_Dataset_AuxFunktions-Datensatz_12,not_valid,
ENG08770-ENG09395,State_Dataset_AuxFunktions-Datensatz_13,not_valid,
ENG08770-ENG09396,State_Dataset_AuxFunktions-Datensatz_14,not_valid,
ENG08770-ENG09397,State_Dataset_AuxFunktions-Datensatz_15,not_valid,
ENG08770-ENG09398,State_Dataset_AuxFunktions-Datensatz_16,not_valid,
ENG08770-ENG09399,State_Dataset_AuxFunktions-Datensatz_17,not_valid,
ENG08770-ENG09400,State_Dataset_AuxFunktions-Datensatz_18,not_valid,
ENG08770-ENG09401,State_Dataset_AuxFunktions-Datensatz_19,not_valid,
ENG08770-ENG09402,State_Dataset_AuxFunktions-Datensatz_1A,valid,
ENG08770-ENG09403,State_Dataset_AuxFunktions-Datensatz_1B,valid,
ENG08770-ENG09404,State_Dataset_AuxFunktions-Datensatz_1C,valid,
ENG08770-ENG09405,State_Dataset_AuxFunktions-Datensatz_1D,valid,
ENG08770-ENG09406,State_Dataset_AuxFunktions-Datensatz_1E,valid,
ENG08770-ENG09407,State_Dataset_AuxFunktions-Datensatz_1F,valid,
ENG08770-ENG09378,State_Dataset_AuxFunktions-Datensatz_2,not_valid,
ENG08770-ENG09379,State_Dataset_AuxFunktions-Datensatz_3,not_valid,
ENG08770-ENG09380,State_Dataset_AuxFunktions-Datensatz_4,not_valid,
ENG08770-ENG09381,State_Dataset_AuxFunktions-Datensatz_5,not_valid,
ENG08770-ENG09382,State_Dataset_AuxFunktions-Datensatz_6,not_valid,
ENG08770-ENG09383,State_Dataset_AuxFunktions-Datensatz_7,not_valid,
ENG08770-ENG09384,State_Dataset_AuxFunktions-Datensatz_8,not_valid,
ENG08770-ENG09385,State_Dataset_AuxFunktions-Datensatz_9,not_valid,
ENG08770-ENG09386,State_Dataset_AuxFunktions-Datensatz_A,not_valid,
ENG08770-ENG09387,State_Dataset_AuxFunktions-Datensatz_B,not_valid,
ENG08770-ENG09388,State_Dataset_AuxFunktions-Datensatz_C,not_valid,
ENG08770-ENG09389,State_Dataset_AuxFunktions-Datensatz_D,not_valid,
ENG08770-ENG09390,State_Dataset_AuxFunktions-Datensatz_E,not_valid,
ENG08770-ENG09391,State_Dataset_AuxFunktions-Datensatz_F,not_valid,
ENG06146-MAS00106,Status_to_a_agree_a_appointment_online-Year,2000,
ENG06146-MAS00107,Status_to_a_agree_a_appointment_online-Month,0,
ENG06146-MAS00108,Status_to_a_agree_a_appointment_online-Day,0,
ENG06146-MAS00109,Status_to_a_agree_a_appointment_online-Hours,0,
ENG06146-MAS00110,Status_to_a_agree_a_appointment_online-Minutes,0,
ENG06146-MAS00111,Status_to_a_agree_a_appointment_online-Seconds,0,
ENG06146-ENG28929,Status_to_a_agree_a_appointment_online-Status_OTV_remind_Flag,no_Set,
ENG06146-ENG28928,Status_to_a_agree_a_appointment_online-Status_OTV_Trigger,no_Set,
ENG08634-ENG120595,Transportmode_Status-Transport_Protection,not activated,
ENG08634-ENG98982,Transportmode_Status-Transportmode,not activated,
ENG04789-ENG05094,Voltage_Comfort_CAN-Voltage_CAN_High,1.32, V
ENG04789-ENG05095,Voltage_Comfort_CAN-Voltage_CAN_Low,1.16, V
ENG04792-ENG05094,Voltage_Extended_CAN-Voltage_CAN_High,1.26, V
ENG04792-ENG05095,Voltage_Extended_CAN-Voltage_CAN_Low,1.20, V
ENG04790-ENG05094,Voltage_Hybrid_CAN-Voltage_CAN_High,1.28, V
ENG04790-ENG05095,Voltage_Hybrid_CAN-Voltage_CAN_Low,1.16, V
ENG04791-ENG05094,Voltage_Infotainment_CAN-Voltage_CAN_High,1.32, V
ENG04791-ENG05095,Voltage_Infotainment_CAN-Voltage_CAN_Low,1.18, V
Elapsed Time: 06:49
adpmap-19-8W6-907-468-F
;SW:8W6-907-468-F   HW:8W6-907-468-E ---  CAN Gateway
;Component:Gateway       H43 0123, Coding:030100010000064029070000005900324C3A0007100000000175078E10000000
;EV_CGateCONTIAU491,003111,EV_CGateCONTIAU491_003_AU49.rod
;Friday,12,July,2019,16:02:18:64285
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: CDDD6A749C2A8327A2-8098
IDE00001-IDE00332-Production mode-Buttons for multi-function steering wheel,Deactivating ,3
IDE00001-IDE10279-Production mode-Onboard data collector,Deactivating ,3
IDE00001-MAS01490-Production mode-Energy management,Deactivating ,3
IDE00001-MAS11109-Production mode-Wireless network connection,Deactivating ,3
IDE00002-Transport mode,not activated ,1
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS03504-Activating and deactivating all development messages-XCP,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE01996-IDE14867-Installation list: specified installations-Subgateway as firewall control module,Not coded ,32
IDE01996-MAS00796-Installation list: specified installations-Engine Control Module (ECM),coded ,32
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded ,32
IDE01996-SFT00007-Installation list: specified installations-Display Control Unit,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded ,32
IDE01996-SFT00012-Installation list: specified installations-Rear Axle Steering 2,Not coded ,32
IDE01996-SFT00017-Installation list: specified installations-Engine Control Module 2,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,Not coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,coded ,32
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Gateway,coded ,32
IDE01996-SFT00027-Installation list: specified installations-Active Steering,Not coded ,32
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery Energy Control Module 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,coded ,32
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded ,32
IDE01996-SFT00039-Installation list: specified installations-Display Control Unit Rear,Not coded ,32
IDE01996-SFT00040-Installation list: specified installations-Climate Control Unit Rear,Not coded ,32
IDE01996-SFT00042-Installation list: specified installations-Control Unit Wireless Charging,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,Not coded ,32
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,coded ,32
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded ,32
IDE01996-SFT00070-Installation list: specified installations-Central Module Comfort System,coded ,32
IDE01996-SFT00072-Installation list: specified installations-Seat Adjustment Rear Driver Side,Not coded ,32
IDE01996-SFT00074-Installation list: specified installations-Rear light,Not coded ,32
IDE01996-SFT00077-Installation list: specified installations-Löschkandidat_Datenübertragung Car2X,Not coded ,32
IDE01996-SFT00080-Installation list: specified installations-Seat Adjustment 3rd Row,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded ,32
IDE01996-SFT00090-Installation list: specified installations-Longitudinal control,Not coded ,32
IDE01996-SFT00091-Installation list: specified installations-Seat Adjustment Rear Passenger Side,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32
IDE01996-SFT00107-Installation list: specified installations-Aerodynamics Control Unit,Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,coded ,32
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,coded ,32
IDE01996-SFT00113-Installation list: specified installations-Battery Charger,Not coded ,32
IDE01996-SFT00116-Installation list: specified installations-Chassis Control,Not coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,Not coded ,32
IDE01996-SFT00127-Installation list: specified installations-Information Control Unit 2,Not coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1,Not coded ,32
IDE01996-SFT00129-Installation list: specified installations-Gear Shift Control Module,coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded ,32
IDE01996-SFT00132-Installation list: specified installations-Night Vision,Not coded ,32
IDE01996-SFT00139-Installation list: specified installations-Adaptive Cruise Control 2,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded ,32
IDE01996-SFT00172-Installation list: specified installations-Reductant Control Module,Not coded ,32
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,Not coded ,32
IDE01996-SFT00186-Installation list: specified installations-Assembly Mounting,Not coded ,32
IDE01996-SFT00195-Installation list: specified installations-Drive Motor Control Module 3,Not coded ,32
IDE01996-SFT00196-Installation list: specified installations-DC/DC Converter Control Module,Not coded ,32
IDE01996-SFT00203-Installation list: specified installations-Rear Axle Steering,Not coded ,32
IDE01996-SFT00205-Installation list: specified installations-Laser Scanner,Not coded ,32
IDE01996-SFT00206-Installation list: specified installations-Drive Motor Control Module 2,Not coded ,32
IDE01996-SFT00208-Installation list: specified installations-Front Axle Lift System,Not coded ,32
IDE01996-SFT00219-Installation list: specified installations-Front Corner Radar 1,Not coded ,32
IDE01996-SFT00220-Installation list: specified installations-Front Corner Radar 2,Not coded ,32
IDE01996-SFT00221-Installation list: specified installations-Control Module 2 For Sunroof,Not coded ,32
IDE01996-SFT33031-Installation list: specified installations-Antenna Control Module,Not coded ,32
IDE01996-SFT33232-Installation list: specified installations-Central control for digital matrix light,Not coded ,32
IDE01996-SFT271904-Installation list: specified installations-Sun Roof,Not coded ,32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,75 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,280327R1X2 ,15
IDE03903-Production process data 1,00 00 00 00 00 00 ,6
IDE04159-Deactivation of start-stop function,regular operation ,1
IDE06748-Pause recommendation,activated ,1
IDE07139-Normal bus behavior during diagnosis,active ,1
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,10.20 l/100km,48
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,40.10 km/h,48
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,100 W,48
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,10 W,48
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,990 W,48
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,24 A,48
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,23.10 kWh/100 km,48
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,23.10 kWh/100 km,48
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,23.10 kWh/100 km,48
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,23.10 kWh/100 km,48
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,23.10 kWh/100 km,48
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,23.10 kWh/100 km,48
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),24.10 kWh/100 km,48
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,10.30 l/100km,48
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,23.30 kWh/100 km,48
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,23.10 kWh/100 km,48
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,6.10 kg/100 km,48
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,10.20 l/100km,48
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,10.20 l/100km,48
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,10.20 l/100km,48
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,10.20 l/100km,48
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,10.20 l/100km,48
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,10.20 l/100km,48
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,10.20 l/100km,48
IDE10351-MAS05767-Message mirroring-port,00 00 ,21
IDE10351-MAS09111-Message mirroring-IP address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,21
IDE10351-MAS10445-Message mirroring-Data bus CAN 1,not active ,21
IDE10351-MAS10446-Message mirroring-Data bus CAN 2,not active ,21
IDE10351-MAS10447-Message mirroring-Data bus CAN 3,not active ,21
IDE10351-MAS10448-Message mirroring-Data bus CAN 4,not active ,21
IDE10351-MAS10449-Message mirroring-Data bus CAN 5,not active ,21
IDE10351-MAS10450-Message mirroring-Data bus CAN 6,not active ,21
IDE10351-MAS10451-Message mirroring-Data bus Flexray A,not active ,21
IDE10351-MAS10452-Message mirroring-Data bus LIN 1,not active ,21
IDE10351-MAS10453-Message mirroring-Data bus LIN 2,not active ,21
IDE10351-MAS10454-Message mirroring-Data bus LIN 3,not active ,21
IDE10351-MAS10460-Message mirroring-Target bus,not active ,21
IDE10351-MAS11107-Message mirroring-Data bus CAN 7,not active ,21
IDE10351-MAS13143-Message mirroring-FlexRay B data bus,not active ,21
IDE10351-MAS17841-Message mirroring-Data bus CAN 8,not active ,21
IDE11209-MAS12388-Vehicle condition report: settings-Send report after terminal 15 off wait time,3C ,5
IDE11209-MAS12389-Vehicle condition report: settings-After terminal 15 off: also wait for bus inactivity,OFF ,5
IDE11209-MAS12390-Vehicle condition report: settings-Send report after terminal 15 on wait time,3C ,5
IDE11209-MAS12391-Vehicle condition report: settings-Send report after bus inactivity wait time,05 ,5
IDE11209-MAS12392-Vehicle condition report: settings-Send report upon reaching BEM shutdown level,OFF ,5
IDE11688-IDE08958-Autonomous operation request-H-V system: start request,regular operation ,3
IDE11688-MAS08040-Autonomous operation request-Automatic recharging of starter battery,regular operation ,3
IDE11688-MAS13088-Autonomous operation request-Preconditioning of the interior,regular operation ,3
IDE13338-Basic functions connect,Deactivating ,4
IDE13756-Diagnosis filter: activation,not active ,1
ENG137256-Adaption_high_voltage_zero_potential,regular operation ,1
ENG137852-Backup_Power_Threshold,0 %,1
ENG153689-Counter_for_inconsistent_conditions,20 ,2
ENG153814-download_eem,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,256
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,13
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,120 ,13
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,13
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,13
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms,13
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,13
ENG118777-ENG136172-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Number_of_Keys,1 ,13
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,13
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,500 ms,13
ENG118777-ENG136168-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_1,800 ms,13
ENG118777-ENG136169-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_2,1000 ms,13
ENG118777-ENG136170-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_3,0 ms,13
ENG118777-ENG136171-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_4,0 ms,13
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,6000 ms,13
ENG118775-energy_management_deactiv_stage,regular operation ,1
ENG137255-HVK_Warning,regular operation ,1
ENG118451-ENG118685-Switch_on_ban_independent_car_heater-Set_point_target_time,80 min,2
ENG118451-ENG118684-Switch_on_ban_independent_car_heater-Switch_on_ban_activation,regular operation ,2
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,2
ENG118774-ENG136195-WakeUpMonitor_Activation-Activation_Bus_Activity,activated ,2
ENG118774-ENG136134-WakeUpMonitor_Activation-Activation_Cluster_Sleep,activated ,2
ENG118774-ENG136135-WakeUpMonitor_Activation-Activation_Cluster_Start,activated ,2
ENG118774-ENG136197-WakeUpMonitor_Activation-Activation_CWUP,activated ,2
ENG118774-ENG136130-WakeUpMonitor_Activation-Activation_Keeping_Awake,activated ,2
ENG118774-ENG136196-WakeUpMonitor_Activation-Activation_Knock_Out,activated ,2
ENG118774-ENG136131-WakeUpMonitor_Activation-Activation_Logical_Wakeup,activated ,2
ENG118774-ENG136198-WakeUpMonitor_Activation-Activation_NFU,activated ,2
ENG118774-ENG136132-WakeUpMonitor_Activation-Activation_Physical_Wakeup,activated ,2
ENG118774-ENG136199-WakeUpMonitor_Activation-Activation_SBU,activated ,2
ENG118773-ENG136190-WakeUpMonitor_Configuration-Max_Num_Cluster_Sleep,20 counts,13
ENG118773-ENG136191-WakeUpMonitor_Configuration-Max_Num_Cluster_Start,20 counts,13
ENG118773-ENG136192-WakeUpMonitor_Configuration-Max_Num_CWUP,30 counts,13
ENG118773-ENG136189-WakeUpMonitor_Configuration-Max_Num_Knock_Out,3 counts,13
ENG118773-ENG136187-WakeUpMonitor_Configuration-Max_Num_Logical_Wakeup,40 counts,13
ENG118773-ENG136193-WakeUpMonitor_Configuration-Max_Num_NF,20 min,13
ENG118773-ENG136188-WakeUpMonitor_Configuration-Max_Num_Physical_Wakeup,10 counts,13
ENG118773-ENG136194-WakeUpMonitor_Configuration-Max_Num_Sb,20 min,13
ENG118773-ENG136186-WakeUpMonitor_Configuration-Max_Time_Keeping_Awake,20 min,13
ENG118773-ENG109064-WakeUpMonitor_Configuration-Start_Delay,0 s,13
ENG118773-ENG136185-WakeUpMonitor_Configuration-Wake_Delay,20 min,13
Elapsed Time: 00:28
DrPeter
16.4905° S, 151.7375° W
Maps [01] - [09]
More maps............
blockmap-01-80A-906-259-A
;SW:80A-906-259-A   HW:06L-907-425-C ---  Engine
;Component:2.0l R4 TFSI  H15 0003, Coding:2A6500122526012E74080000000000000000000000000000
;EV_ECM20TFS02080A906259A,001004,EV_ECM20TFS02080A906259A.rod
;Friday,12,July,2019,16:02:53:64285
;VCID: A915FEE4C802BF076E-80FC
Group,Description,Actual
IDE00018,Voltage terminal 15,13.945, V
IDE00019,Voltage terminal 30,14.160, V
IDE00021,Engine speed,801, /min
IDE00025,Coolant temperature,108, °C
IDE00078,Time since engine start,919, s
IDE00083,Throttle valve position (absolute),11.4, %
IDE00084,Absolute load value,22, %
IDE00085,Normed load value,14.5, %
IDE00086,Accelerator position,15, %
IDE00090,selected gear,Shifting process active,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00102,Control Module temperature,94.0, °C
IDE00148,Median injection timing,0.9, ms
IDE00149,Ignition angle of current cylinder: actual value,1.50, °
IDE00150,Pressure in brake booster,1.150, bar
IDE00151,Oil fill level,75, mm
IDE00155,Timing angle retardation cylinder 1,0.00, °
IDE00156,Timing angle retardation cylinder 2,0.00, °
IDE00157,Timing angle retardation cylinder 3,0.00, °
IDE00158,Timing angle retardation cylinder 4,0.00, °
IDE00167,Exhaust temperature 1 bank 1,423.4, °C
IDE00172,A/C compressor torque,-13.03, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,4.5, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,4.5, °
IDE00178,Camshaft adjustment intake bank 1: specified value,5.0, °
IDE00179,Camshaft adjustment intake bank 1: actual value,4.9, °
IDE00182,Camshaft adaptation intake bank 1: phase position,-0.3, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,-2.2, °
IDE00186,Fuel low pressure: actual value,11.003, bar
IDE00187,Coolant temperature at engine start,84.7, °C
IDE00188,Fuel high pressure: actual value,56.5, bar
IDE00189,Activation of fuel pump electronics,29.47, %
IDE00190,Charge air pressure specified value,0.773, bar
IDE00191,Charge air pressure: actual value,0.973, bar
IDE00192,Coolant temperature at radiator outlet: actual value,52.6, °C
IDE00193,Coolant temperature at engine outlet: specified value,108.0, °C
IDE00194,Coolant temperature at radiator output: specified value,-48.0, °C
IDE00195,Coolant temperature difference between engine and radiator,55.5, °C
IDE00196,Engine oil temperature,93.0, °C
IDE00199,Mean engine air mass,12, kg/h
IDE00200,Median vehicle speed,0.00, km/h
IDE00201,High fuel pressure: specified value,56.5, bar
IDE00202,Low fuel pressure: specified value,6.223, bar
IDE00252,Brake system vacuum pump,Pump off,
IDE00304,Fuel level,38, l
IDE00348,Intake air temperature,62, °C
IDE00349,Throttle valve position: normed,2, %
IDE00350,Air mass: specified value,12, kg/h
IDE00355,Cruise Control System (CCS): status,passive,
IDE00357,Fuel temperature,96.0, °C
IDE00358,Limitation: torque,229.8, Nm
IDE00371,Fuel consumption,1.15, l/h
IDE00375,Generator: load signal,0.03, %
IDE00380,Coolant fan 1: activation,36.72, %
IDE00381,Coolant fan 2: activation,48.05, %
IDE00392,Accelerator pedal: sensor voltage 1,0.751, V
IDE00393,Accelerator pedal: sensor voltage 2,0.376, V
IDE00396,Charge Pressure Actuator: acknowledgment,3.613, V
IDE00400,Intake manifold Runner Control (IMRC): activation,100.00, %
IDE00401,Intake manifold Runner Control (IMRC): acknowledgment,100.00, %
IDE00404,Throttle valve: activation,19.27, %
IDE00405,Crankshaft speed (RPM),800, /min
IDE00406,Camshaft speed (RPM),0, /min
IDE00407,Rail pressure regulation: status,Regulated operation via quantity control valve,
IDE00408,Engine mount 1,active,
IDE00409,Engine mount 2,active,
IDE00412,Starter control: terminal 50,not active,
IDE00413,Starter control: Interlock- or P/N-signal,00,
IDE00414,Starter control: relay 1,00,
IDE00415,Starter control: relay 2,00,
IDE00416,Starter control: terminal 50 acknowledgment,01,
IDE00417,Starter control: shut-off conditions 1,00 01,
IDE00450,Operating Instructions,--no display--,
IDE00451,Currently running routine,Unknown (0),
IDE00472,Mean injection quantity,9, mg/stroke
IDE00474,Ambient air pressure,97, kPa abs
IDE00476,Fuel Metering Valve,14.40, %
IDE00477,Torque request: sum of auxiliary aggregate,24.6, Nm
IDE00478,Engine-drag torque,9.7, Nm
IDE00482,Limitation: torque of clutch protection,1024.0, Nm
IDE00495,Calculated oil temperature,93.0, °C
IDE00496,Activation of oil pressure switch valve,Low pressure,
IDE00497-MAS00627,Status of oil pressure switches-Oil pressure switch for high pressure,Open,
IDE00497-MAS00628,Status of oil pressure switches-Oil pressure switch for low pressure,closed,
IDE00556,Outside air temperature,29, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.004 Lambda / -0.016 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.775, V
IDE00582,Equivalence ratio target value,0.998, Lambda
IDE00583,Throttle valve specified value,1, %
IDE00584,Distance driven since erasing DTC memory,34636, km
IDE00588,Fuel tank fill level,54.1, %
IDE00589,Fuel pressure,5550, kPa rel
IDE00592,Oxygen sensor control status,Closed loop,  / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,2.0, Degrees
IDE00594,Absolute intake pressure,34, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,0.8, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,255,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,20.4, %
IDE00949-ENG98517,Hide cylinder-Cylinder 1,not active,
IDE00949-ENG98491,Hide cylinder-Cylinder 10,not active,
IDE00949-ENG98492,Hide cylinder-Cylinder 11,not active,
IDE00949-ENG98493,Hide cylinder-Cylinder 12,not active,
IDE00949-ENG98518,Hide cylinder-Cylinder 13,not active,
IDE00949-ENG98519,Hide cylinder-Cylinder 14,not active,
IDE00949-ENG98520,Hide cylinder-Cylinder 15,not active,
IDE00949-ENG98494,Hide cylinder-Cylinder 16,not active,
IDE00949-ENG98521,Hide cylinder-Cylinder 2,not active,
IDE00949-ENG98522,Hide cylinder-Cylinder 3,not active,
IDE00949-ENG98523,Hide cylinder-Cylinder 4,not active,
IDE00949-ENG98495,Hide cylinder-Cylinder 5,not active,
IDE00949-ENG98524,Hide cylinder-Cylinder 6,not active,
IDE00949-ENG98496,Hide cylinder-Cylinder 7,not active,
IDE00949-ENG98497,Hide cylinder-Cylinder 8,not active,
IDE00949-ENG98498,Hide cylinder-Cylinder 9,not active,
IDE00968,Compressor speed,0, /min
IDE01076-MAS00109,Time since ignition off-Hours,0, H
IDE01076-MAS00110,Time since ignition off-Minutes,15, min
IDE01076-MAS00111,Time since ignition off-Seconds,8, s
IDE01098,Test of knock sensors: short trip result,Test not started,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,0.000,
IDE01266,Coolant shut-off valve,Open,
IDE01369,Intake manifold runner control (IMRC): offset closed,0.000, V
IDE01377,Throttle valve adapter: actual value,1.9, °
IDE01378,High fuel pressure: control deviation,0, bar
IDE01385,Wear index,0.00000026,
IDE01405-MAS05513,Status of starter activation-Bit 0,OK,
IDE01405-MAS05514,Status of starter activation-Bit 1,Before starter activation,
IDE01405-MAS05515,Status of starter activation-Bit 2,After starter activation,
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test not started,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.776, V
IDE01649,Throttle valve position 1,0.581, V
IDE01650,Throttle valve position 2,11, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test not started,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test not started,
IDE01670,Short trip status for oil pressure control,Test not started,
IDE01671,Starter control: clutch switch,pressed,
IDE01672,Starter control: automatic start,not possible,
IDE01673-MAS05513,Starter control: readiness bits-Bit 0,Mech. test of starter complete,
IDE01673-MAS05514,Starter control: readiness bits-Bit 1,Test of starter relay switching contacts not complete,
IDE01673-MAS05515,Starter control: readiness bits-Bit 2,Test of starter relay activation complete,
IDE01673-MAS05516,Starter control: readiness bits-Bit 3,Test of terminal 50R return measuring line completed,
IDE01673-MAS05517,Starter control: readiness bits-Bit 4,Test of starter request double injection complete,
IDE01673-MAS05518,Starter control: readiness bits-Bit 5,Test of PN signal not complete,
IDE01673-MAS05519,Starter control: readiness bits-Bit 6,Test of interlock switch complete,
IDE01673-MAS05520,Starter control: readiness bits-Bit 7,Test of clutch pedal switch complete,
IDE01677,Result of O2 sensor test ready bank 1 after cat. conv.,Test not started,
IDE01683-MAS05304,Valve stroke switch of AVS from small to large-Cylinder 1,switched,
IDE01683-MAS05305,Valve stroke switch of AVS from small to large-Cylinder 2,switched,
IDE01683-MAS05306,Valve stroke switch of AVS from small to large-Cylinder 3,switched,
IDE01683-MAS05307,Valve stroke switch of AVS from small to large-Cylinder 4,switched,
IDE01683-MAS05308,Valve stroke switch of AVS from small to large-Cylinder 5,switched,
IDE01683-MAS05309,Valve stroke switch of AVS from small to large-Cylinder 6,switched,
IDE01683-MAS05310,Valve stroke switch of AVS from small to large-Cylinder 7,switched,
IDE01683-MAS05311,Valve stroke switch of AVS from small to large-Cylinder 8,switched,
IDE01684-MAS05304,Valve stroke switch of AVS from large to small-Cylinder 1,switched,
IDE01684-MAS05305,Valve stroke switch of AVS from large to small-Cylinder 2,switched,
IDE01684-MAS05306,Valve stroke switch of AVS from large to small-Cylinder 3,switched,
IDE01684-MAS05307,Valve stroke switch of AVS from large to small-Cylinder 4,switched,
IDE01684-MAS05308,Valve stroke switch of AVS from large to small-Cylinder 5,switched,
IDE01684-MAS05309,Valve stroke switch of AVS from large to small-Cylinder 6,switched,
IDE01684-MAS05310,Valve stroke switch of AVS from large to small-Cylinder 7,switched,
IDE01684-MAS05311,Valve stroke switch of AVS from large to small-Cylinder 8,switched,
IDE01685,Result of test of valve stroke switch AVS,Test not started,
IDE01773,Misfire sum counter,0,
IDE01774,Status misfire recognition,active,
IDE01870,Oxygen sensor after catalytic converter: operating status,Bank 1: sensor 1 OK,
IDE01873,Test of catalytic converter: measured value,0.008,
IDE01874,Test of catalytic converter: result,Test not started,
IDE01876,Adaptation of loss torque,-2.5, Nm
IDE01878,Adaptation of throttle valve,Test of closing springs ended,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4.126, V
IDE01884,Camshaft adjustment intake bank 1: activation,43.51, %
IDE01886,Number of high pressure incursions,0,
IDE01894,Charge press. ctrl.: adapt. higher than max. threshold,0.00, %
IDE01895,Charge pressure control: less than min. threshold adaptation,0.49, %
IDE01901,Lost torque adaptation: idle,5.3, Nm
IDE01905,Average of ignition timing angle delay adjustment,16.50, °
IDE01906,Dynamic average of ignition timing angle delay adjustment,2.62, °
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,0,
IDE01913,Number of oxygen sensor dynamic tests: bank 1 sensor 1,0,
IDE01922,Vehicle distance driven,34677, km
IDE01923,Control module distance driven,34649, km
IDE01924,Load shift flaps: actual value,closed,
IDE01925,Load shift flaps: specified value,closed,
IDE01926,Adaptation of load shift flaps,Cancel: prerequisites have not been met,
IDE01928,Close cam shaft angle at quantity control valve,32.6, °
IDE01929,Open cam shaft angle at quantity control valve,4.0, °
IDE01931,High pressure pump injection volume control deviation,4, mg/stroke
IDE01932,High pressure pump injection volume,14, mg/stroke
IDE01975,Numb.of misfir.: cylinder 1,0,
IDE01976,Numb.of misfir.: cylinder 2,0,
IDE01977,Numb.of misfir.: cylinder 3,0,
IDE01978,Numb.of misfir.: cylinder 4,0,
IDE01986,Contact for tank leak test,closed,
IDE02116,Exhaust gas temperature before catalytic converter,405.9, °C
IDE02119,Long term adaptation of oxygen sensor control: bank 1,-3.1, %
IDE02229,Exh.gas temp.sen 1,1110.0, °C
IDE02756,Number of manual engine starts,1699,
IDE02757,Number of automatic engine starts,2114,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,active,
IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,1240,
IDE03010-MAS01627,Number of prevented stop processes-Steering,2678,
IDE03010-MAS02040,Number of prevented stop processes-Play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,55,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,35,
IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,3091,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,1097,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,47,
IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,6,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,150,
IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,31,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test not started,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,-179.96, °
IDE03246,Neutral position sensor: upper adaptation value,0.000, V
IDE03247,Neutral position sensor: lower adaptation value,0.000, V
IDE03262,Adapt of angle sensor 1 f throttle valve,0.493, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.507, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.942, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.058, V
IDE03267,Intake air temperature: unconditioned voltage,0.918, V
IDE03276,Charge air pressure sensor: unconditioned voltage,1.567, V
IDE03277,Intake manifold Runner Control (IMRC): unconditioned voltage,3.784, V
IDE03328,Transmission neutral position sensor voltage,0.000, V
IDE03361,Driver request torque,34.2, Nm
IDE03362,Requested transmission torque,1024.0, Nm
IDE03375,Adaptation status for transmission neutral position sensor,0,
IDE03377,Coolant temp at radiator output: unconditioned voltage,2.192, V
IDE03582,Temperature sensor for engine temperature management,108.0, °C
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,active,
IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stop overrides for active participants-Transmission,not active,
IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
IDE03587-MAS01490,Stop overrides for active participants-Energy management,not active,
IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stop overrides for active participants-Engine,not active,
IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03692-MAS05513,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0,Test of camshaft adjustment bank 2 outlet not complete,
IDE03692-MAS05514,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 1,Test of camshaft adjustment bank 1 outlet complete,
IDE03692-MAS05515,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 2,Test of camshaft adjustment bank 2 intake not complete,
IDE03692-MAS05516,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 3,Test of camshaft adjustment bank 1 intake complete,
IDE03692-MAS05517,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 4,Test of knock sensor 4 not complete,
IDE03692-MAS05518,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 5,Test of knock sensor 3 not complete,
IDE03692-MAS05519,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 6,Test of knock sensor 2 not complete,
IDE03692-MAS05520,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 7,Test of knock sensor 1 complete,
IDE03693-MAS05513,Monitoring status of additional Onboard Diagnosis-Bit 0,Test of brake light switch not complete,
IDE03693-MAS05514,Monitoring status of additional Onboard Diagnosis-Bit 1,Test of clutch switch not complete,
IDE03693-MAS05515,Monitoring status of additional Onboard Diagnosis-Bit 2,Test of idle control not complete,
IDE03693-MAS05516,Monitoring status of additional Onboard Diagnosis-Bit 3,Test of coolant temperature sensor not complete,
IDE03693-MAS05517,Monitoring status of additional Onboard Diagnosis-Bit 4,Test of throttle valve potentiometer not complete,
IDE03693-MAS05518,Monitoring status of additional Onboard Diagnosis-Bit 5,Test of thermostat complete,
IDE03693-MAS05519,Monitoring status of additional Onboard Diagnosis-Bit 6,Test of charge pressure control complete,
IDE03693-MAS05520,Monitoring status of additional Onboard Diagnosis-Bit 7,Test of CCS switch not complete,
IDE03693-MAS05521,Monitoring status of additional Onboard Diagnosis-Bit 8,Test of oxygen adaptation bank 1 complete,
IDE03711,Mass flow through throttle valve,9, kg/h
IDE03767,Engine status,Idling,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,48.70, %
IDE03806,Oxygen sensor bank 1 sensor 1: status,1,
IDE03807,Oxygen sensor bank 1 sensor 2: status,1,
IDE03816,Exhaust flap bank 1,Open,
IDE03818,Heated oxygen sensor bank 1: sensor 2: resistance,331, Ohm
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,37.89, %
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,305, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,35.55, %
IDE03832,Oxygen sensor bank 1 sensor 2: response time,0, ms
IDE03834,Oxygen sensor bank 1 sensor 2: response time filtered,0, ms
IDE03836,Result of O2 sensor aging test bank 1 after cat. conv.,Test not started,
IDE03892,Fuel high pressure sensor: unconditioned voltage,1.293, V
IDE03918,Engine reverse rotation recognition,not recognized,
IDE03919,Oxygen regulation operability and status,On,
IDE03920,Oxygen adaptation status,Condition not met,
IDE03921,Mixture adaptation factor at partial load,2.00, %
IDE03922,Mixture adaptation factor at idle speed,-0.47, %
IDE03923,Adaptive long-term value of mix. condition after cat. conv,0.00090,
IDE03924,Relay for reserve coolant pump: status,not activated,
IDE03928,Counter for fuel entry in oil,0,
IDE03930,Charge pressure actuator: operating status,Operating mode,
IDE03931,Charge pressure actuator: actual position,0.00, %
IDE03932,Charge pressure actuator: specified position,0.00, %
IDE03933,Charge pressure actuator: specified value,0.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3.569, V
IDE03935,Charge pressure actuator: adaptation for upper stop,0.570, V
IDE03949,Air mass: actual value (mg/stroke),133.36, mg/stroke
IDE03953,Oxygen control: adaptation value at partial load: bank 1,2.56, %
IDE03957,Throttle valve angle: specified value,1.9, °
IDE03963,Low fuel pressure adaptation value for EFP,0, mbar
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03998,Clutch Position Sensor,99.61, %
IDE04002,Charge press. ctrl.,BP_A act:97, kPa
IDE04405,Mixture deviation in adapted partial load range 1,2.56, %
IDE04409,Intake manifold pressure: corrected,0.352, bar
IDE04410,Intake manifold pressure: target value,0.348, bar
IDE04412,Pressure before throttle valve: corrected,0.973, bar
IDE04415,Oxygen ctrl factor with precontrol correction,1.12, %
IDE04629,AVS operating condition,Test is running,
IDE04630,AVS valve stroke position: current,AVS Stroke,
IDE04632-MAS05304,AVS error status of last switch-over standard stroke direction-Cylinder 1,OK,
IDE04632-MAS05305,AVS error status of last switch-over standard stroke direction-Cylinder 2,OK,
IDE04632-MAS05306,AVS error status of last switch-over standard stroke direction-Cylinder 3,OK,
IDE04632-MAS05307,AVS error status of last switch-over standard stroke direction-Cylinder 4,OK,
IDE04632-MAS05308,AVS error status of last switch-over standard stroke direction-Cylinder 5,OK,
IDE04632-MAS05309,AVS error status of last switch-over standard stroke direction-Cylinder 6,OK,
IDE04632-MAS05310,AVS error status of last switch-over standard stroke direction-Cylinder 7,OK,
IDE04632-MAS05311,AVS error status of last switch-over standard stroke direction-Cylinder 8,OK,
IDE04633-MAS05304,AVS error status of last switch-over AVS stroke direction-Cylinder 1,OK,
IDE04633-MAS05305,AVS error status of last switch-over AVS stroke direction-Cylinder 2,OK,
IDE04633-MAS05306,AVS error status of last switch-over AVS stroke direction-Cylinder 3,OK,
IDE04633-MAS05307,AVS error status of last switch-over AVS stroke direction-Cylinder 4,OK,
IDE04633-MAS05308,AVS error status of last switch-over AVS stroke direction-Cylinder 5,OK,
IDE04633-MAS05309,AVS error status of last switch-over AVS stroke direction-Cylinder 6,OK,
IDE04633-MAS05310,AVS error status of last switch-over AVS stroke direction-Cylinder 7,OK,
IDE04633-MAS05311,AVS error status of last switch-over AVS stroke direction-Cylinder 8,OK,
IDE04634,AVS switch-over meter for reg activation of curr. drive cycle,0,
IDE04635,AVS switch-over meter: total,4416,
IDE04636,AVS overflow meter for all switch-overs,0,
IDE04637,Engine temperature management actuator,0.00, %
IDE04638,Transmission coolant valve,Open,
IDE04677,O2 sensor 1 bank 1: O2 sensor actual value,1,
IDE04680,O2 sensor 1: bank 1: voltage raw value O2 signal,1.978, V
IDE04713,Active brake system status,Not operated,
IDE04814,Transmission oil cooler valve,Open,
IDE04937,Sensor for engine block temperature: raw value,-48.0, °C
IDE05140,Intake manifold pressure raw value,0.352, bar
IDE05259,Gear position sensor: raw value,0.00, %
IDE05260,Gear position sensor: current value,Intermediate position,
IDE05261,Gear position sensor: last valid value,Neutral,
IDE05262,Gear position sensor: gear position valid,invalid,
IDE05310,Charge air pressure control valve position: target value,0.00, %
IDE05311,Charge air pressure control valve position: actual value,0.00, %
IDE05312,Charge air pressure control valve uncond voltage sensor,3.6133, V
IDE05313,Charge air pressure control valve activation pulse duty factor,-14.80, %
IDE05314-ENG112584,Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0],00000000 ,
IDE05315,Charge air pressure control valve voltage: position closed,3.5693, V
IDE05316,Charge air pressure control valve voltage: position open,0.5701, V
IDE05317-ENG112583,Charge air pressure control valve adaptation performed-LV_BPA_AD_ASA_SUC[0],00000000 ,
IDE05508,Adaptation val cyl 1 with slow diagnosis,0.000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,0.000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,0.000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,0.000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,0.000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,0.000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,0.000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,0.000,
IDE05593,Secondary air injection sensor 1,0.375, bar
IDE05622-ENG125277,Status of tank leak diagnosis with electrical diagnostic pump-STATE_DMTL_EOL,0,
IDE06006,Idle speed specified value,800, /min
IDE06192,Knock sensor: cylinder 2: voltage,0.545, V
IDE06193,Knock sensor: cylinder 3: voltage,0.415, V
IDE06194,Knock sensor: cylinder 4: voltage,0.714, V
IDE06195,Knock sensor: cylinder 1: voltage,0.412, V
IDE06296-ENG104200,Activation of oxygen control after main cat-Lambda probe 2: bank 1: status,00000001 ,
IDE06307-MAS00106,Stop prevention history data-Year,2019,
IDE06307-MAS00107,Stop prevention history data-Month,7,
IDE06307-MAS00108,Stop prevention history data-Day,12,
IDE06307-MAS00109,Stop prevention history data-Hours,15,
IDE06307-MAS00110,Stop prevention history data-Minutes,32,
IDE06307-MAS00111,Stop prevention history data-Seconds,18,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Driving situation,
IDE06308-MAS00106,Start request history data-Year,2019,
IDE06308-MAS00107,Start request history data-Month,4,
IDE06308-MAS00108,Start request history data-Day,14,
IDE06308-MAS00109,Start request history data-Hours,13,
IDE06308-MAS00110,Start request history data-Minutes,40,
IDE06308-MAS00111,Start request history data-Seconds,31,
IDE06308,Start request history data,not active,
IDE06308,Start request history data,Brake under pressure too low,
IDE06386,Oil level: static measurement,0, mm
IDE06387,Oil level: last valid dynamic value,0, mm
IDE06388,Oil level: condition for static measurement fulfilled,Condition not met,
IDE06389,Oil level: maximum value,0, mm
IDE06390,Oil level: minimum value,0, mm
IDE06391,Oil temperature sensor 2,99.0, °C
IDE06392,Oil temperature sensor 2: raw value,65.535, V
IDE06393,Oil level: dynamic average value,0, mm
IDE06394,Sensor 1 for secondary air pressure: unconditioned voltage,0.000, V
IDE06395,Fuel low pressure sensor: unconditioned voltage,4.995, V
IDE06396,Coolant temperature at engine outlet: unconditioned voltage,0.668, V
IDE06397,Temperature sensor for engine temp. management: target value,107.3, °C
IDE06398,Temperature sensor for engine temp. management: uncond. voltage,0.669, V
IDE06399,Manifold absolute pressure sensor: unconditioned voltage,0.776, V
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06432,Oxygen sensor 1 bank 1 signal status,active,
IDE06444,Oxygen sensor before cat bank 1 (LSB) voltage,1.963, V
IDE06567,Start-stop function deactivation frequency counter,1675,
IDE06568,Stop prevention by driver frequency counter,5556,
IDE06569,Vehicle stopped frequency counter,16087,
IDE06573,Long-term adaptation of intake manifold injection,0.00, %
IDE06574,Long-term adaptation of intake manifold injection in idle,0.00, mg/stroke
IDE06610,Vehicle standstill with stop frequency counter,2262,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,No,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,Yes,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,Yes,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC,
IDE06707,CCS Switch,CCS operating unit,
IDE06709,ACC variants (coding),CCS,
IDE06710,Cruise control system: permanent deactivation,No switch-off occurs,
IDE06726,Timing deviation after chain replacement: intake bank 1,-0.63, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,-2.50, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,-0.56, °
IDE06736,Timing deviation: current value exhaust bank 1,-2.38, °
IDE07001,Piston-cooling jets: activation,On,
IDE07008,Tank leak: number no leak detected,255,
IDE07011,Tank leak: number communication errors to engine control,487,
IDE07014,Tank leak: number very small leaks detected,0,
IDE07019,Number of ignitions direct injection,0,
IDE07020,Number of ignitions intake manifold injection,0,
IDE07023,Misfires per 1000 revolutions of cyl. 1 intake manif. injection,0,
IDE07024,Misfires per 1000 revolutions of cyl. 2 intake manif. injection,0,
IDE07025,Misfires per 1000 revolutions of cyl. 3 intake manif. injection,0,
IDE07026,Misfires per 1000 revolutions of cyl. 4 intake manif. injection,0,
IDE07027,Heat quantity that was transported via the catalytic converter,2.6214e+010, J
IDE07031,Oil pressure switch for piston-cooling jets: status,Open,
IDE07159-MAS00478,Control module switch-off: counter-Reserved,-1,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07548,Engine temp. mangmt. actuator: specified value of angle,71.50, °
IDE07549,Engine temp. mangmt. actuator: actual value of angle,70.61, °
IDE07550,Engine temp. management actuator: raw value,1197,
IDE07551,Engine temp. management actuator: duty cycle activation,-5.40, %
IDE07552,Engine temper.managem.actuator adaptation: result adaptation,Adaptation successfully finished,
IDE07553,Engine temperature management actuator: after-run stop,3949,
IDE07554,Engine temperature management actuator: stop open,142,
IDE07564,Required torque adjustment by idling regulator,0.4, Nm
IDE07571,Engine torque,24.8, Nm
IDE07572,High pressure regulation: adaptation value,7.12, mg
IDE07574,Long-term fuel trim bank 1 at idle,-0.04, mg/stroke
IDE07575,Driver request torque,0.4, Nm
IDE07576,Lost torque adaptation driving mode,0.9, Nm
IDE07577,Lost torque adaptation A/C compressor and driving mode,-1.2, Nm
IDE07598-MAS00320,Cruise control switch actuation-Main switch,operated,
IDE07598-MAS00325,Cruise control switch actuation-Setting,not activated,
IDE07598-MAS00326,Cruise control switch actuation-Activation,not activated,
IDE07598-MAS01632,Cruise control switch actuation-Status,OK,
IDE07598-MAS02309,Cruise control switch actuation-Accelerate,not activated,
IDE07598-MAS02310,Cruise control switch actuation-Decelerate,not activated,
IDE07598-MAS05172,Cruise control switch actuation-Cancel,not activated,
IDE07598-MAS05806,Cruise control switch actuation-Main switch hardware,operated,
IDE07598-MAS05807,Cruise control switch actuation-Coding,plausible,
IDE07598-MAS05809,Cruise control switch actuation-Limit function,not selected,
IDE07598-MAS05812,Cruise control switch actuation-Limit button,not activated,
IDE07598-MAS05813,Cruise control switch actuation-Main switch CAN,operated,
IDE07598-MAS05842,Cruise control switch actuation-Large increment,not activated,
IDE07598-MAS05843,Cruise control switch actuation-Control component verified,Yes,
IDE07599-MAS01505,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine off,No,
IDE07599-MAS03849,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Crash signal,No,
IDE07599-MAS04795,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-main switch off,No,
IDE07599-MAS05135,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Open or no gear selected,No,
IDE07599-MAS05136,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Hill descent control,No,
IDE07599-MAS05190,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Parking brake or hand brake actuated,Yes,
IDE07599-MAS05192,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Driver braking,No,
IDE07599-MAS05196,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error,No,
IDE07599-MAS05814,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN communication error,No,
IDE07599-MAS05815,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN signal error,No,
IDE07599-MAS05816,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESP control response error,No,
IDE07599-MAS05817,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-RPM limitation,No,
IDE07599-MAS05818,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Transmission coding not plausible,No,
IDE07599-MAS05819,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC active during braking,No,
IDE07599-MAS05820,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC error,No,
IDE07599-MAS05821,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking intervention too weak,No,
IDE07599-MAS05822,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking control not available,No,
IDE07599-MAS05823,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error during initialization,No,
IDE07599-MAS05824,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Emer. engine operation,No,
IDE07599-MAS05825,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine control module fault,No,
IDE07599-MAS05826,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Torque reduction due to fault,No,
IDE07599-MAS05827,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Diagnosis requirements not met,No,
IDE07599-MAS05828,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake excess temperature,No,
IDE07599-MAS05829,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake light fault,No,
IDE07599-MAS05830,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CCS deactivated due to fault in control component,No,
IDE07599-MAS05831,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC deactivated due to fault in control component,No,
IDE07599-MAS05832,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Coding error,No,
IDE07599-MAS05833,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESC error,No,
IDE07599-MAS05834,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake pedal fault,No,
IDE07599-MAS05835,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Clutch pedal fault,No,
IDE07599-MAS05836,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Acceleration monitoring error,No,
IDE07599-MAS05837,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC control response error,No,
IDE07605,Cruise control system: temporary deactivation,No switch-off,
IDE07669,Oxygen sensor 2 Bank 1 after cat operation readiness Status,active,
IDE07901,Error counter bad fuel,0,
IDE07904-ENG118117,Brake test switch status-actuated__activated,not activated,
IDE07904-ENG114825,Brake test switch status-Ident_32,0,
IDE07905-ENG118117,Brake light switch status-actuated__activated,not activated,
IDE07905-ENG114825,Brake light switch status-Ident_32,0,
IDE07906-ENG118117,Upper clutch switch: status-actuated__activated,not activated,
IDE07906-ENG114825,Upper clutch switch: status-Ident_32,0,
IDE07945-MAS00334,Status of intermittent monitoring-Catalytic converter monitoring,completed successfully,
IDE07945-MAS00335,Status of intermittent monitoring-Monitoring of catalytic converter at operating temperature,completed successfully,
IDE07945-MAS00336,Status of intermittent monitoring-Monitoring of tank ventilation system,completed successfully,
IDE07945-MAS00337,Status of intermittent monitoring-Monitoring of Secondary Air Injection (AIR) system,completed successfully,
IDE07945-MAS00338,Status of intermittent monitoring-Monitoring of A/C system refrigerant,completed successfully,
IDE07945-MAS00339,Status of intermittent monitoring-Monitoring of oxygen sensor,completed successfully,
IDE07945-MAS00340,Status of intermittent monitoring-Monitoring of oxygen sensor heater,completed successfully,
IDE07945-MAS00341,Status of intermittent monitoring-Monitoring of Exhaust Gas recirc. (EGR),not completed successfully,
IDE08071-ENG119931,Remote start cancellation reason store 1-LF_ST_REQ_EXT_DVC_DEAC_1,0,
IDE08072-ENG119932,Remote start cancellation reason store 2-LF_ST_REQ_EXT_DVC_DEAC_2,0,
IDE08073-ENG119933,Remote start cancellation reason store 3-LF_ST_REQ_EXT_DVC_DEAC_3,0,
IDE08074-ENG119934,Remote start cancellation reason store 4-LF_ST_REQ_EXT_DVC_DEAC_4,0,
IDE08075-ENG119935,Remote start cancellation reason store 5-LF_ST_REQ_EXT_DVC_DEAC_5,0,
IDE08495,Activation radiator shutter result,89.84, %
IDE08805,EVAP valve diag. activation condition at minimal load,0.095, counts
IDE08806,EVAP valve diag. activation condition at maximum load,618, mbar
IDE10063-MAS00666,Engine oil level: current value-Warning,no warning,
IDE10063-MAS00900,Engine oil level: current value-Oil level,76.10, %
IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,34270, km
IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,34264, km
IDE10063-MAS09804,Engine oil level: current value-Test method 1,OFF,
IDE10063-MAS09805,Engine oil level: current value-Test method 2,On,
IDE10063-MAS09806,Engine oil level: current value-Test method 3,OFF,
IDE10063-MAS09807,Engine oil level: current value-Qualification,7,
IDE10064-MAS00666,Engine oil level: history 1-Warning,no warning,
IDE10064-MAS00900,Engine oil level: history 1-Oil level,66.30, %
IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,33524, km
IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,33512, km
IDE10064-MAS09804,Engine oil level: history 1-Test method 1,On,
IDE10064-MAS09805,Engine oil level: history 1-Test method 2,On,
IDE10064-MAS09806,Engine oil level: history 1-Test method 3,OFF,
IDE10064-MAS09807,Engine oil level: history 1-Qualification,7,
IDE10065-MAS00666,Engine oil level: history 2-Warning,no warning,
IDE10065-MAS00900,Engine oil level: history 2-Oil level,59.10, %
IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,32776, km
IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,32753, km
IDE10065-MAS09804,Engine oil level: history 2-Test method 1,On,
IDE10065-MAS09805,Engine oil level: history 2-Test method 2,On,
IDE10065-MAS09806,Engine oil level: history 2-Test method 3,OFF,
IDE10065-MAS09807,Engine oil level: history 2-Qualification,7,
IDE10066-MAS00666,Engine oil level: history 3-Warning,no warning,
IDE10066-MAS00900,Engine oil level: history 3-Oil level,65.30, %
IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,32030, km
IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,32027, km
IDE10066-MAS09804,Engine oil level: history 3-Test method 1,On,
IDE10066-MAS09805,Engine oil level: history 3-Test method 2,On,
IDE10066-MAS09806,Engine oil level: history 3-Test method 3,OFF,
IDE10066-MAS09807,Engine oil level: history 3-Qualification,7,
IDE10067-MAS00666,Engine oil level: history 4-Warning,no warning,
IDE10067-MAS00900,Engine oil level: history 4-Oil level,63.00, %
IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,31287, km
IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,31278, km
IDE10067-MAS09804,Engine oil level: history 4-Test method 1,On,
IDE10067-MAS09805,Engine oil level: history 4-Test method 2,On,
IDE10067-MAS09806,Engine oil level: history 4-Test method 3,OFF,
IDE10067-MAS09807,Engine oil level: history 4-Qualification,7,
IDE10068-MAS00666,Engine oil level: history 5-Warning,no warning,
IDE10068-MAS00900,Engine oil level: history 5-Oil level,70.00, %
IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,30546, km
IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,30536, km
IDE10068-MAS09804,Engine oil level: history 5-Test method 1,On,
IDE10068-MAS09805,Engine oil level: history 5-Test method 2,On,
IDE10068-MAS09806,Engine oil level: history 5-Test method 3,OFF,
IDE10068-MAS09807,Engine oil level: history 5-Qualification,7,
IDE10069-MAS00666,Engine oil level: history 6-Warning,no warning,
IDE10069-MAS00900,Engine oil level: history 6-Oil level,78.30, %
IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,29802, km
IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,29797, km
IDE10069-MAS09804,Engine oil level: history 6-Test method 1,On,
IDE10069-MAS09805,Engine oil level: history 6-Test method 2,On,
IDE10069-MAS09806,Engine oil level: history 6-Test method 3,OFF,
IDE10069-MAS09807,Engine oil level: history 6-Qualification,7,
IDE10070-MAS00666,Engine oil level: history 7-Warning,no warning,
IDE10070-MAS00900,Engine oil level: history 7-Oil level,83.80, %
IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,0, km
IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,29047, km
IDE10070-MAS09804,Engine oil level: history 7-Test method 1,On,
IDE10070-MAS09805,Engine oil level: history 7-Test method 2,On,
IDE10070-MAS09806,Engine oil level: history 7-Test method 3,OFF,
IDE10070-MAS09807,Engine oil level: history 7-Qualification,7,
IDE10071-MAS00666,Engine oil level: history 8-Warning,no warning,
IDE10071-MAS00900,Engine oil level: history 8-Oil level,90.60, %
IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,0, km
IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,28302, km
IDE10071-MAS09804,Engine oil level: history 8-Test method 1,On,
IDE10071-MAS09805,Engine oil level: history 8-Test method 2,On,
IDE10071-MAS09806,Engine oil level: history 8-Test method 3,OFF,
IDE10071-MAS09807,Engine oil level: history 8-Qualification,7,
IDE10072-MAS00666,Engine oil level: history 9-Warning,no warning,
IDE10072-MAS00900,Engine oil level: history 9-Oil level,77.40, %
IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,0, km
IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,27526, km
IDE10072-MAS09804,Engine oil level: history 9-Test method 1,On,
IDE10072-MAS09805,Engine oil level: history 9-Test method 2,On,
IDE10072-MAS09806,Engine oil level: history 9-Test method 3,OFF,
IDE10072-MAS09807,Engine oil level: history 9-Qualification,7,
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,3.670, V
IDE10380,Knock sensor average voltage bank 1,0.527, V
IDE10551-MAS05304,Pre-ignition counter for oxygen shift-Cylinder 1,0,
IDE10551-MAS05305,Pre-ignition counter for oxygen shift-Cylinder 2,1,
IDE10551-MAS05306,Pre-ignition counter for oxygen shift-Cylinder 3,2,
IDE10551-MAS05307,Pre-ignition counter for oxygen shift-Cylinder 4,1,
IDE10551-MAS05308,Pre-ignition counter for oxygen shift-Cylinder 5,0,
IDE10551-MAS05309,Pre-ignition counter for oxygen shift-Cylinder 6,0,
IDE10551-MAS05310,Pre-ignition counter for oxygen shift-Cylinder 7,0,
IDE10551-MAS05311,Pre-ignition counter for oxygen shift-Cylinder 8,0,
IDE10552-MAS05304,Pre-ignition counter for torque reduction-Cylinder 1,0,
IDE10552-MAS05305,Pre-ignition counter for torque reduction-Cylinder 2,0,
IDE10552-MAS05306,Pre-ignition counter for torque reduction-Cylinder 3,0,
IDE10552-MAS05307,Pre-ignition counter for torque reduction-Cylinder 4,0,
IDE10552-MAS05308,Pre-ignition counter for torque reduction-Cylinder 5,0,
IDE10552-MAS05309,Pre-ignition counter for torque reduction-Cylinder 6,0,
IDE10552-MAS05310,Pre-ignition counter for torque reduction-Cylinder 7,0,
IDE10552-MAS05311,Pre-ignition counter for torque reduction-Cylinder 8,0,
IDE10553-MAS05304,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 1,0,
IDE10553-MAS05305,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 2,0,
IDE10553-MAS05306,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 3,0,
IDE10553-MAS05307,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 4,0,
IDE10553-MAS05308,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 5,0,
IDE10553-MAS05309,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 6,0,
IDE10553-MAS05310,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 7,0,
IDE10553-MAS05311,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 8,0,
IDE10554-MAS05304,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 1,0,
IDE10554-MAS05305,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 2,0,
IDE10554-MAS05306,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 3,0,
IDE10554-MAS05307,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 4,0,
IDE10554-MAS05308,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 5,0,
IDE10554-MAS05309,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 6,0,
IDE10554-MAS05310,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 7,0,
IDE10554-MAS05311,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 8,0,
IDE10580,Engine oil level: test method 1,79.70, %
IDE10581,Engine oil level: test method 2,80.00, %
IDE10582,Engine oil level: test method 3,93.60, %
IDE10634,Clutch protection function: slip speed of the clutch,0, /min
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10848,Accelerator position,0.00, %
IDE10922,Pump current of tank leakage diag.: corrected & filtered,0.000, mA
IDE10968,Activation radiator shutter result,100.00, %
IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2127,
IDE10989-MAS00107,Immobilizer: historic data-Month,15,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,31,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,63,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Function locked due to excessive stalling,
IDE10989,Immobilizer: historic data,Engine hood open,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10994,Poor start counter at start-stop,0,
IDE11065,Accel. pedal pos. sensor 1,614,
IDE11066,Accel. pedal pos. sensor 2,307,
IDE11115,Start/stop driver request: counter restart by starter,91,
IDE11116,Start/stop driver request: counter internal-motor restart,16,
IDE11267,Oil level: max. value: relative,84.20, %
IDE11268,Oil level: min. value: relative,63.70, %
IDE11302-MAS05513,Engine oil level: test method 1:qualification-Bit 0,7,
IDE11302,Engine oil level: test method 1:qualification,Saved mean value,
IDE11303-MAS05513,Engine oil level: test method 3:qualification-Bit 0,2,
IDE11303,Engine oil level: test method 3:qualification,Engine hood was open,
IDE11331-MAS03057,Torque reduction: clutch protection history 1-Kilometers,0, km
IDE11331-MAS10499,Torque reduction: clutch protection history 1-Torque,0, Nm
IDE11332-MAS03057,Torque reduction: clutch protection history 2-Kilometers,0, km
IDE11332-MAS10499,Torque reduction: clutch protection history 2-Torque,0, Nm
IDE11333-MAS03057,Torque reduction: clutch protection history 3-Kilometers,0, km
IDE11333-MAS10499,Torque reduction: clutch protection history 3-Torque,0, Nm
IDE11334-MAS03057,Torque reduction: clutch protection history 4-Kilometers,0, km
IDE11334-MAS10499,Torque reduction: clutch protection history 4-Torque,0, Nm
IDE11335-MAS03057,Torque reduction: clutch protection history 5-Kilometers,0, km
IDE11335-MAS10499,Torque reduction: clutch protection history 5-Torque,0, Nm
IDE11336-MAS03057,Torque reduction: clutch protection history 6-Kilometers,0, km
IDE11336-MAS10499,Torque reduction: clutch protection history 6-Torque,0, Nm
IDE11337-MAS03057,Torque reduction: clutch protection history 7-Kilometers,0, km
IDE11337-MAS10499,Torque reduction: clutch protection history 7-Torque,0, Nm
IDE11338-MAS03057,Torque reduction: clutch protection history 8-Kilometers,0, km
IDE11338-MAS10499,Torque reduction: clutch protection history 8-Torque,0, Nm
IDE11339-MAS03057,Torque reduction: clutch protection history 9-Kilometers,0, km
IDE11339-MAS10499,Torque reduction: clutch protection history 9-Torque,0, Nm
IDE11340-MAS03057,Torque reduction: clutch protection history 10-Kilometers,0, km
IDE11340-MAS10499,Torque reduction: clutch protection history 10-Torque,0, Nm
IDE11598,Tank deaeration valve diagnosis: unweighted input value,0.000, counts
IDE11599,Tank deaeration valve diagnosis: weighted output value,0.000, counts
IDE11600,Tank tightness: ambient temperature,30.75, °C
IDE11635,Radiator shutter 1: status referencing,completed successfully,
IDE11919,Lock time for cooling down of secondary air pump,0, s
IDE12137,Tank fill level diagnostic reference value,53.0, l
IDE12138,Fuel consumption per driving cycle,92.52, l/100km
ENG102981,AC compressor: speed increase,00000001 ,
ENG103860,AC request: speed increase,00000000 ,
ENG103042,Accelerator pedal sender: learned end stop,4.126, V
ENG101488,ACF: load,0.00000,
ENG103474,Activation of oil pressure switching valve,00000001 ,
ENG103323,Additional water pump,00000001 ,
ENG101828,Air mass,9.44, kg/h
ENG104264,Alternator load,800, W
ENG103910,Ambient temperature,25.50, °C
ENG112539,AR_THR_AD_ADD_MMV,-0.0215, cm²
ENG98377,As,none,
ENG103165,Battery voltage,14.1, V
ENG07601,Bypasstool_a2l_name,SCBS4031_C_OEM A2L,
ENG07600,Bypasstool_manipulation_bit,not active,
ENG128780,CAM_DIF_VCP[EX_1],0.141, °
ENG128781,CAM_DIF_VCP[IN_1],0.063, °
ENG102002,CAM_OFS_IVVT_IN[1],0.000, °
ENG112540,CAM_PHA_ENG[GES_EX][CBK_1],4.523, °
ENG112541,CAM_PHA_ENG[GES_IN][CBK_1],5.031, °
ENG101169,CAM_PHA_OFS_MAF[IN][1],0.000, °
ENG112542,CAM_SP_IND_VCP[EX_1],4.500, °
ENG112543,CAM_SP_IND_VCP[IN_1],5.000, °
ENG112544,CAM_VCP[EX_1],4.313, °
ENG112545,CAM_VCP[IN_1],4.742, °
ENG103849,Cat. ageing: bank 1: actual,0.008,
ENG101785,Cat. temperature: bank 1,423.8500, °C
ENG102214,CPU_LOAD,56.8, %
ENG125189,CTR_CAM_IN_SP_PI_DET_REQ[0],0,
ENG125190,CTR_CAM_IN_SP_PI_DET_REQ[1],2,
ENG125191,CTR_CAM_IN_SP_PI_DET_REQ[2],1,
ENG125192,CTR_CAM_IN_SP_PI_DET_REQ[3],1,
ENG101127,CTR_CDN_OBD_RBM,586,
ENG114826,CTR_EDGE_CAM_EX[1],38,
ENG114827,CTR_EDGE_CAM_IN[1],43,
ENG100536,CTR_IGK_CYC_RBM,1818,
ENG125193,CTR_LAMB_SP_PI_REQ[0],0,
ENG125194,CTR_LAMB_SP_PI_REQ[1],2,
ENG125195,CTR_LAMB_SP_PI_REQ[2],1,
ENG125196,CTR_LAMB_SP_PI_REQ[3],1,
ENG112554,CTR_MIS_DC_MMV_CYL_SAE[0],0,
ENG112555,CTR_MIS_DC_MMV_CYL_SAE[1],1,
ENG112556,CTR_MIS_DC_MMV_CYL_SAE[2],1,
ENG112557,CTR_MIS_DC_MMV_CYL_SAE[3],1,
ENG112558,CTR_MIS_TOT_NVMY_SAE,5661,
ENG125197,CTR_REQ_IV_OFF_PI_FAST[0],0,
ENG125198,CTR_REQ_IV_OFF_PI_FAST[1],0,
ENG125199,CTR_REQ_IV_OFF_PI_FAST[2],0,
ENG125200,CTR_REQ_IV_OFF_PI_FAST[3],0,
ENG125201,CTR_REQ_IV_OFF_PI_SLOW[0],0,
ENG125202,CTR_REQ_IV_OFF_PI_SLOW[1],0,
ENG125203,CTR_REQ_IV_OFF_PI_SLOW[2],0,
ENG125204,CTR_REQ_IV_OFF_PI_SLOW[3],0,
ENG128782,CTR_REQ_IV_OFF_PI_SLOW_TMP[0],0,
ENG128783,CTR_REQ_IV_OFF_PI_SLOW_TMP[1],0,
ENG128784,CTR_REQ_IV_OFF_PI_SLOW_TMP[2],0,
ENG128785,CTR_REQ_IV_OFF_PI_SLOW_TMP[3],0,
ENG100764,CTR_SUM_SRV_INTL,0.0,
ENG125205,CTR_TQI_POW_MAX_PI_REQ[0],0,
ENG125206,CTR_TQI_POW_MAX_PI_REQ[1],0,
ENG125207,CTR_TQI_POW_MAX_PI_REQ[2],0,
ENG125208,CTR_TQI_POW_MAX_PI_REQ[3],0,
ENG119929,CTR_VLD_CAT_GAP_AFL[1],0,
ENG119930,CTR_VLD_CAT_GAP_AFR[1],0,
ENG99428,CTR_VLFT_1_SWI_NOT[0],0,
ENG103626,CTR_VLFT_1_SWI_NOT[1],0,
ENG100809,CTR_VLFT_1_SWI_NOT[2],0,
ENG99336,CTR_VLFT_1_SWI_NOT[3],0,
ENG103025,CTR_VLFT_STND_SWI_NOT[0],0,
ENG100017,CTR_VLFT_STND_SWI_NOT[1],0,
ENG100438,CTR_VLFT_STND_SWI_NOT[2],0,
ENG100736,CTR_VLFT_STND_SWI_NOT[3],0,
ENG112559,CTR_VVL_LIH_ACT,0,
ENG101271,CTR_VVL_LIH_DEAC,0,
ENG100551,CTR_VVL_SWI_DC,0,
ENG99561,CTR_VVL_SWI_H,0,
ENG101173,CTR_VVL_SWI_L,4416,
ENG99084,Cycle flags: (completed cycles): cat: lambda probe heater,9,
ENG100943,Cycle flags: (completed cycles): lambda probes: EGR,0,
ENG99495,Cycle flags: (completed tests): lambda adaption:,8,
ENG103597,Cycle flags:(completed cycles):lambda probes:sec.air sys.,56,
ENG101652,Cylinder shut-off: cylinder suppression,00000000 ,
ENG102657,DIAG_INST[0],NO_ERROR,
ENG99120,DIAG_INST[1],NO_ERROR,
ENG103260,DIAG_INST[2],NO_ERROR,
ENG99710,DIAG_INST[3],NO_ERROR,
ENG102667,DIAG_INST[4],NO_ERROR,
ENG102739,DIAG_INST[5],NO_ERROR,
ENG100162,DIAG_INST[6],NO_ERROR,
ENG99103,DIAG_INST[7],NO_ERROR,
ENG99261,DIAG_INST[8],NO_ERROR,
ENG103622,DIAG_INST[9],NO_ERROR,
ENG112560,DIST_ACT_MIL_SAE,0, km
ENG112561,DIST_DTC_CLR_SAE,34636, km
ENG103766,DIST_ENG_RUN_IN,34650788.0, m
ENG100531,DIST_ST,3.46492e+007, m
ENG100131,ECU_STATE,SYN_ENG_IGK_ON,
ENG103712,EFPPWM_MIN_AD,0.000, %
ENG104044,Engine load,14.843750, %
ENG102494,Engine speed: actual,800, /min
ENG102783,Engine: operating status,IS,
ENG103667,ENVD_0_MON,0,
ENG100777,ENVD_0_MON_3,0,
ENG126934,ENVD_0_MON_3_VD,0,
ENG99424,ENVD_1_MON,0,
ENG100344,ENVD_1_MON_3,0,
ENG126935,ENVD_1_MON_3_VD,0,
ENG99790,ENVD_2_MON,0,
ENG100541,ENVD_2_MON_3,0,
ENG126936,ENVD_2_MON_3_VD,0,
ENG99455,ENVD_3_MON,0,
ENG101268,ENVD_3_MON_3,0,
ENG126937,ENVD_3_MON_3_VD,0,
ENG01743,ENVD_4_MON,0,
ENG01744,ENVD_5_MON,0,
ENG01745,ENVD_6_MON,0,
ENG99752,Error flags: (completed cycles): cat: lambda probe heater,0,
ENG101275,Error flags: (completed cycles): lambda probes: EGR,0,
ENG104132,Error flags: (completed cycles): lambda probes:sec.air sys.,0,
ENG101942,ESI (extended service intervals) oil warning threshold,0.00, mm
ENG112562,FAC_AR_THR_AD,0.000, %
ENG104194,FAC_H_RNG_LAM_AD[1],0.000, %
ENG104151,FAC_L_RNG_LAM_AD[1],2.565, %
ENG100298,FAC_LAM_CP,-0.522, %
ENG100108,FAC_LAM_LIM[1],-0.444, %
ENG99722,FAC_LAM_TCO_A[1],-2.327, %
ENG103521,FAC_LAM_TCO_B[1],-3.151, %
ENG103641,FAC_LAM_TCO_C[1],-3.833, %
ENG101578,FAC_LAM_TCO_D[1],-2.473, %
ENG100685,FAC_LAM_TCO_E[1],-0.954, %
ENG103307,FAC_MAF_MAX,0.04749,
ENG99791,FAC_SLOP_IV[1],0.00000,
ENG102306,FAC_TPS_1_SAE,11.718750, %
ENG102292,FAC_TPS_1_SAE,11.718750, %
ENG99630,Fan control relay: fan run-on,4194304,
ENG101437,Fan request from air conditioner,48.0, %
ENG124827,FIBEX_Integration_Step,V08.10.00,
ENG103644,FRF_IMMO_SNAPSHOT_BYTE1,0,
ENG102892,FRF_IMMO_SNAPSHOT_BYTE2,0,
ENG100521,FRF_IMMO_SNAPSHOT_BYTE3,0,
ENG101852,FRF_IMMO_SNAPSHOT_BYTE4,0,
ENG99312,FRF_IMMO_SNAPSHOT_BYTE5,0,
ENG103956,FRF_IMMO_SNAPSHOT_BYTE6,0,
ENG128786,FTL_SAE,54.11764795, %
ENG104248,Fuel consumption signal,2742, µl
ENG101667,Fuel pump: adaption value,0.000, %
ENG100969,Fuel pump: fuel pressure: I-controller,0.000, %
ENG100250,Fuel regulating valve: duty cycle,14.447, %
ENG101692,Fuel supply system: high-pressure regulator,42.1069, hPa
ENG114828,FUP_EFP_MES,11000.8, hPa
ENG103553,FUP_EFP_ST_H,0, hPa
ENG101056,FUP_EFP_ST_L,0, hPa
ENG99950,FUP_EFP_STOP_H,0, hPa
ENG100784,FUP_EFP_STOP_L,0, hPa
ENG102108,FUP_H,56516.6, hPa
ENG112563,FUP_H_SAE,5560.0, kPa
ENG103368,Gearbox -CAN bus messages,110455,
ENG99170,Height correction,970.38, hPa
ENG103575,High-pressure system: regulator,0.34, mg
ENG103879,High-pressure system: regulator: mobile part,-2.78, mg
ENG102603,High-pressure system: status,MFP_CTL,
ENG101567,Idling speed stabilisation: duty cycle/AC compressor torque,11.8, Nm
ENG101946,Idling stabilisation: operating status,00000000 ,
ENG100345,IGA_ADJ_KNK[0],0.000, °
ENG103593,IGA_ADJ_KNK[1],0.000, °
ENG103360,IGA_ADJ_KNK[2],0.000, °
ENG99404,IGA_ADJ_KNK[3],0.000, °
ENG100425,IGA_IGC[0],2.250, °
ENG101655,IGA_IGC[1],1.875, °
ENG100410,IGA_IGC[2],1.875, °
ENG100407,IGA_IGC[3],1.875, °
ENG112564,IGA_IGC_SAE,2.0, °
ENG101741,Intake air temperature,61.50, °C
ENG125209,KNKS_ERR_REL[0],0.0000, V
ENG99741,LAMB_DELTA_AD_LAM_ADJ[1],-0.00427,
ENG99601,LAMB_DELTA_I_LAM_ADJ[1],0.00098,
ENG112565,LAMB_DELTA_SUM_LAM_ADJ_AD[1],-0.00427,
ENG99674,Lambda controller: bank 1 (averaged value),-0.285, %
ENG101381,Lambda probe 1: bank 1: status,00000001 ,
ENG101039,Lambda probe 1: bank 1: status,00000000 ,
ENG102886,Lambda probe 1: bank 1: status,00000000 ,
ENG104200,Lambda probe 2: bank 1: status,00000001 ,
ENG101336,Lambda probe 2: bank 1: status,00000001 ,
ENG99661,Lambda probe ageing: bank 1: dynamic factor,0.0000,
ENG101869,Lambda probe ageing: bank 1: probe 1: short trip result,326.2875, °C
ENG100478,Lambda probe correction: duty cycle offset: bank 1,0.00153,
ENG103776,Lambda probe heater: bank 1: probe 2: short trip result,00000000 ,
ENG102380,Lambda probe heater: resistance: bank 1: probe 2,331, Ohm
ENG99353,Lambda probe voltage: bank 1: probe 1 (broadband probe),1.968, V
ENG102763,Lambda probes actual: bank1,1.0020,
ENG104114,Lambda probes specified: bank1,0.9990,
ENG06592,LF_COSI_CTL_ERR_A,0,
ENG06593,LF_COSI_CTL_ERR_B,0,
ENG112566,LF_DPS_CYC_ERR_RAW_BSW[1],16384,
ENG112567,LF_DPS_CYC_ERR_RAW_BSW[2],16384,
ENG112568,LF_DPS_CYC_ERR_VLD_BSW[1],65535,
ENG112569,LF_DPS_CYC_ERR_VLD_BSW[2],65535,
ENG112570,LF_DPS_INI_ERR_RAW_BSW[1],0,
ENG112571,LF_DPS_INI_ERR_RAW_BSW[2],0,
ENG112572,LF_IV_ERR_RAW_BSW[0],0,
ENG112573,LF_IV_ERR_RAW_BSW[1],0,
ENG112574,LF_IV_ERR_RAW_BSW[2],0,
ENG112575,LF_IV_ERR_RAW_BSW[3],0,
ENG112576,LF_IV_ERR_VLD_BSW[0],8191,
ENG112577,LF_IV_ERR_VLD_BSW[1],8191,
ENG112578,LF_IV_ERR_VLD_BSW[2],8191,
ENG112579,LF_IV_ERR_VLD_BSW[3],8191,
ENG07602,LF_MVB_BUS_INTC_DIAG,256,
ENG07603,LF_MVB_PDU_INTC_DIAG_1,0,
ENG07604,LF_MVB_PDU_INTC_DIAG_10,0,
ENG07605,LF_MVB_PDU_INTC_DIAG_13,19367,
ENG07606,LF_MVB_PDU_INTC_DIAG_14,0,
ENG07607,LF_MVB_PDU_INTC_DIAG_15,38928,
ENG07608,LF_MVB_PDU_INTC_DIAG_16,0,
ENG07609,LF_MVB_PDU_INTC_DIAG_17,512,
ENG07610,LF_MVB_PDU_INTC_DIAG_18,51,
ENG07611,LF_MVB_PDU_INTC_DIAG_2,49152,
ENG07612,LF_MVB_PDU_INTC_DIAG_3,3,
ENG07613,LF_MVB_PDU_INTC_DIAG_4,0,
ENG07614,LF_MVB_PDU_INTC_DIAG_5,0,
ENG07615,LF_MVB_PDU_INTC_DIAG_6,45088,
ENG07616,LF_MVB_PDU_INTC_DIAG_7,36864,
ENG07617,LF_MVB_PDU_INTC_DIAG_8,199,
ENG07618,LF_MVB_PDU_INTC_DIAG_9,64896,
ENG101645,LF_VVL_DIAG_SWI_NOT,0,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2019,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,7,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,11,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,7,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,11,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,0,
ENG127734,Life_cycle_data_start_requirement_development,not active,
ENG127734,Life_cycle_data_start_requirement_development,A/C,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2019,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,7,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,12,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,14,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,53,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,35,
ENG127735,Life_cycle_data_stop_prohibition_development,not active,
ENG127735,Life_cycle_data_stop_prohibition_development,A/C,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2019,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,6,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,19,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,7,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,6,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,24,
ENG127733,Life_cycle_data_system_failure,not active,
ENG127733,Life_cycle_data_system_failure,Kessy,
ENG122701,LMVDes_st_Mod_Out_VW,250,
ENG122702,LMVDes_v_Max_Man_Lim_VW,511.992, km/h
ENG122703,LMVLim_v_Auth_Max_Out_VW,203.0000, km/h
ENG100402,LOIL_SUM_SRV_INTL,-0.06, mm
ENG99162,LV_ACC_RED_CMD,00000000 ,
ENG102235,LV_ATB_ACT_1,00000000 ,
ENG102541,LV_ATB_ACT_2,00000000 ,
ENG114829,LV_BPA_LIH_REQ[0],0,
ENG99095,LV_CAN_HOOD_SWI,00000000 ,
ENG128787,LV_CMD_RCL_OPEN,00000000 ,
ENG07619,LV_ECRAS_FB_DIAG_POS_RESP[1],00000001 ,
ENG103049,LV_EFPPWM_AD_STOP,00000001 ,
ENG101712,LV_ENG_RUN_IN,00000000 ,
ENG100267,LV_ENG_RUN_IN_EXT_ADJ,00000000 ,
ENG103319,LV_ERR_VLFT_1_SWI[1],00000000 ,
ENG103549,LV_ERR_VLFT_1_SWI[2],00000000 ,
ENG103191,LV_ERR_VLFT_1_SWI[3],00000000 ,
ENG101989,LV_ERR_VLFT_1_SWI[4],00000000 ,
ENG102313,LV_ERR_VLFT_STND_SWI[1],00000000 ,
ENG103044,LV_ERR_VLFT_STND_SWI[2],00000000 ,
ENG103443,LV_ERR_VLFT_STND_SWI[3],00000000 ,
ENG100487,LV_ERR_VLFT_STND_SWI[4],00000000 ,
ENG112471,LV_IGK,00000001 ,
ENG103773,LV_INH_STR_RLY,00000000 ,
ENG100044,LV_LOIL_L_WARN,00000000 ,
ENG103492,LV_LOIL_L_WARN_ACT,00000000 ,
ENG103908,LV_LOIL_L_WARN_TMP,00000000 ,
ENG103716,LV_POIL_SWI_H,00000000 ,
ENG100912,LV_POIL_SWI_L,00000001 ,
ENG112586,LV_PWR_RLY[0],00000001 ,
ENG102417,LV_TPS_AD_ACT,00000000 ,
ENG100842,LV_TPS_AD_DIAG_ERR,0,
ENG103996,LV_TPS_AD_REQ,00000000 ,
ENG112587,LV_VCP_AD_END,00000001 ,
ENG99288,MAF_DIF_CAM_OFS_AD_SQ_TOT,0.000, kg²/h²
ENG112588,MAP_MES_SAE,34, kPa
ENG103501,MASS_SA_REL[0],0.000,
ENG100896,MASS_SA_REL_21_PHA,0.000,
ENG103045,MASS_SA_REL_22_PHA,0.000,
ENG103346,MFF_ADD_LAM_AD[1],-0.04, mg/stroke
ENG126493,MFF_MPL_ADD_LAM_AD[1][1],-0.04, mg/stroke
ENG101360,Misfire detection active,00000000 ,
ENG102335,Misfires all cylinders per 1000 rpm,0,
ENG128796,N_SP_IS_CLC,800, /min
ENG103004,N_TCHA,8514.4, /min
ENG112590,N_TOOTH,795, /min
ENG107737-ENG112538,NC_NR_DIAG_RBM-NC Value,149,
ENG126111,NL_PRE[0],0.26695, V
ENG126112,NL_PRE[1],0.17281, V
ENG126113,NL_PRE[2],0.45891, V
ENG126114,NL_PRE[3],0.54039, V
ENG128789,NR_CYC_AD_DC_BAL_HOM[RNG_H],0,
ENG128790,NR_CYC_AD_DC_BAL_HOM[RNG_IS],0,
ENG128791,NR_CYC_AD_DC_BAL_HOM[RNG_L],0,
ENG128792,NR_CYC_AD_DIAG_BAL_HOM[0],0,
ENG128793,NR_CYC_AD_DIAG_BAL_HOM[1],0,
ENG128794,NR_CYC_AD_DIAG_BAL_HOM[2],0,
ENG128795,NR_CYC_AD_DIAG_BAL_HOM[3],0,
ENG112589,NR_CYL_FIRST_VVL_SWI,0,
ENG99776,NR_CYL_VVL_H_ACK,0,
ENG119936,O2L_MAX_CAT_GAP_AFL_MV[1],0.00000, g
ENG119937,O2L_MAX_CAT_GAP_AFR_MV[1],0.00000, g
ENG99157,PRS_SA_DIF,0.00, hPa
ENG02464,PRS_UP_THR_MES,972.71, hPa
ENG112591,PSN_EDGE_REL_AD_CAM_EX[1][1],-1.6875, °
ENG112592,PSN_EDGE_REL_AD_CAM_IN[1][1],0.1250, °
ENG114830,PSN_EDGE_REL_AD_CAM_SAVE_EX[1][1],-1.6875, °
ENG114831,PSN_EDGE_REL_AD_CAM_SAVE_EX[1][2],-3.3125, °
ENG114832,PSN_EDGE_REL_AD_CAM_SAVE_IN[1][1],0.1250, °
ENG114833,PSN_EDGE_REL_AD_CAM_SAVE_IN[1][2],0.1875, °
ENG128797,PV,0.00, %
ENG102195,PV_AV_1,0.00, %
ENG99137,PV_AV_2,0.00, %
ENG101068,PV_AV_H,0.00, %
ENG112593,PWM_ACT_VCP[EX_1],90.002, %
ENG112594,PWM_ACT_VCP[IN_1],90.002, %
ENG101350,PWM_ETC,-18.588, %
ENG112595,PWM_HLD_VCP[EX_1],48.682, %
ENG112596,PWM_HLD_VCP[IN_1],43.475, %
ENG112597,PWM_PAS_VCP[EX_1],9.686, %
ENG112598,PWM_PAS_VCP[IN_1],9.845, %
ENG101201,Radiator fan 1: run-on: status,300W,
ENG102359,Radiator fan 2: run-on: status,300W,
ENG119939,RATIO_O2L_LIM_CAT_GAP_AFL_MV[1],0.0000000,
ENG119940,RATIO_O2L_LIM_CAT_GAP_AFR_MV[1],0.0000000,
ENG102377,Ready and error flags,0,
ENG112599,RVC_AV,70.67, °
ENG112601,RVC_SP,71.50, °
ENG112600,RVCPWM,-5.280, %
ENG103248,SEG_AD_MMV_ER[0],0.0000, ‰
ENG101135,SEG_AD_MMV_ER[1],0.1257, ‰
ENG99078,SEG_AD_MMV_ER[2],-0.0841, ‰
ENG103257,SEG_AD_MMV_ER[3],0.2380, ‰
ENG102511,SEG_AD_MMV_ER_H[0],0.0000, ‰
ENG103258,SEG_AD_MMV_ER_H[1],0.1166, ‰
ENG99291,SEG_AD_MMV_ER_H[2],-0.1454, ‰
ENG99954,SEG_AD_MMV_ER_H[3],0.2773, ‰
ENG100568,SEG_AD_MMV_ER_L[0],0.0000, ‰
ENG100601,SEG_AD_MMV_ER_L[1],0.1257, ‰
ENG102668,SEG_AD_MMV_ER_L[2],-0.0841, ‰
ENG101232,SEG_AD_MMV_ER_L[3],0.2380, ‰
ENG101561,SEG_AD_MMV_ER_MID[0],0.0000, ‰
ENG102964,SEG_AD_MMV_ER_MID[1],-0.0651, ‰
ENG100890,SEG_AD_MMV_ER_MID[2],-0.1373, ‰
ENG99793,SEG_AD_MMV_ER_MID[3],0.0489, ‰
ENG103381,Shut-off time,6.30, s
ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,8, %
ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,20, %
ENG102971,Start adaption: temperature adaption factor 1,1.000000,
ENG102489,Start adaption: temperature adaption factor 2,1.000000,
ENG100723,Start adaption: temperature adaption factor 3,1.000000,
ENG100919,Starter control: interlock switch,00000000 ,
ENG100800,Starter: start relay 1,00000000 ,
ENG99979,Starter: start relay 2,00000000 ,
ENG102033,STATE_BPA[0],OPM,
ENG102127,STATE_COMC_NVLD,Wait,
ENG112602,STATE_CRK_STST,CRK_STST_ACQ_SHO_LEVEL,
ENG114834,STATE_CRU_OFF_IRR_CUS,0,
ENG114835,STATE_CRU_OFF_REV_CUS,17301568,
ENG112603,STATE_EOL_VVL,DEAC,
ENG112605,STATE_LS_SAE[1],CL,
ENG104238,STATE_NVLD,COMPLETE_DIAG,
ENG112606,STATE_PWM_VCP[EX_1],HLD,
ENG112607,STATE_PWM_VCP[IN_1],HLD,
ENG101078,STATE_READY_OBD_1,7,
ENG100369,STATE_READY_OBD_3,0,
ENG100342,STATE_REQ_NVLD,NO_REQ,
ENG109090,STATE_SW_MVB,SCBS4010 CBS0050,
ENG128798,STATE_T_ES_RD,1,
ENG128799,STATE_T_ES_VLD_RD,1,
ENG112608,STATE_VCP,enable,
ENG114836,STATE_VCV_CLOSE_SL,OFF,
ENG103723,STATE_VVL_MNG,VVL_L,
ENG112609,T_ACT_MIL_SAE,0, min
ENG112494,T_AST_SAE,997, s
ENG104148,T_COOL_LOIL,568.7, ms
ENG112613,T_DTC_CLR_SAE,38152, min
ENG102790,T_EFP_MEM_H,0.00, s
ENG102123,T_EFP_MEM_L,0.00, s
ENG109299,T_ES,15, min
ENG112616,T_ES_DC,15, min
ENG99463,T_ES_H,910, s
ENG128802,T_IGK,655.35, s
ENG99398,T_POP_COC_INTER_1,0.0, s
ENG102747,T_PWL,0.0, s
ENG08783,T_PWL_ECU_ATIC,383.9, s
ENG112636,T_SWI_VVL_ACR,68.9, ms
ENG101325,T_TEMP_SIG_LOIL,64.8, ms
ENG99126,T_VS_TOL_LOCK,0, min
ENG125440,TAA,26.000, °C
ENG102048,Tank breather valve: duty cycle,20.312500, %
ENG101339,Tank breather valve: short trip result,0.7670, kg/h
ENG100439,Tank level,00000000 ,
ENG112610,TCO_1_FIRST_ST,85, °C
ENG112611,TCO_1_ST,85, °C
ENG112612,TCO_1_SYS,107, °C
ENG103434,TCO_A_LAM_AD_WUP[1],-15.00, °C
ENG100381,TCO_B_LAM_AD_WUP[1],-6.00, °C
ENG101581,TCO_C_LAM_AD_WUP[1],9.00, °C
ENG100354,TCO_D_LAM_AD_WUP[1],22.50, °C
ENG101973,TCO_E_LAM_AD_WUP[1],25.50, °C
ENG128800,TCO_MDL[STUCK_L_COOL_MON],42.492, °C
ENG124460,TCO_MDL[TH],62.852, °C
ENG100390,TCO_MIN_INTER_LAM_AD_WUP[1],106.50, °C
ENG100853,TCO_MIN_LAM_AD_WUP[1],-6.00, °C
ENG102279,TCS/ESP: specified torque,1023.96875, Nm
ENG99857,TCS: status,00000000 ,
ENG110436,TEG_DYN_LS_DOWN[1],390.1000, °C
ENG110437,TEG_DYN_LS_UP[1],406.8500, °C
ENG101941,TEMP_CAT_STAT_MDL[1],423.9125, °C
ENG112614,TEMP_CAT_UP_1_SAE,424.4, °C
ENG114837,TFPA,108, °C
ENG114838,TFU_HPP,44.25, °C
ENG99608,Throttle valve adjuster: adaption status,ST_CHK_END,
ENG101411,Throttle valve angle,1.896, °
ENG102845,Throttle valve deviation,-6.178, %
ENG126115,TI_1_MES_MPI[0],0.000, ms
ENG126116,TI_1_MES_MPI[1],0.000, ms
ENG126117,TI_1_MES_MPI[2],0.000, ms
ENG126118,TI_1_MES_MPI[3],0.000, ms
ENG126119,TI_MES_4[PLS_1][0],0.984, ms
ENG126120,TI_MES_4[PLS_1][1],0.936, ms
ENG126121,TI_MES_4[PLS_1][2],0.988, ms
ENG126122,TI_MES_4[PLS_1][3],0.992, ms
ENG126123,TI_MES_4[PLS_2][0],0.000, ms
ENG126124,TI_MES_4[PLS_2][1],0.000, ms
ENG126125,TI_MES_4[PLS_2][2],0.000, ms
ENG126126,TI_MES_4[PLS_2][3],0.000, ms
ENG126127,TI_MES_4[PLS_3][0],0.000, ms
ENG126128,TI_MES_4[PLS_3][1],0.000, ms
ENG126129,TI_MES_4[PLS_3][2],0.000, ms
ENG126130,TI_MES_4[PLS_3][3],0.000, ms
ENG128801,TIA_CHA_DOWN_MV,69.750, °C
ENG125276,TIG_MES_SAE[IM],62, °C
ENG103351,Time since engine start,1004.0, s
ENG112634,TLTS_MES[TCE],107.742, °C
ENG112635,TMAG_VCP,93, °C
ENG110444,TPS_AD_CDN_MIS,0,
ENG114839,TPS_ETC,1.896, °
ENG99274,TPS_SP,1.867, °
ENG103021,TQ_CONV,0.00000, Nm
ENG128804,TQI_ADD_ACT,37.40625, Nm
ENG101426,TQI_GS_FAST_INC,0.00, Nm
ENG128805,TQI_N_TCHA_MAX,1023.96875, Nm
ENG102329,TTIP_MES_LS_UP[1],785.0000, °C
ENG100355,V_FUP_EFP_MV,4.995, V
ENG100739,V_PVS_1_BAS,0.7510, V
ENG114840,V_PVS_KD,0.000, V
ENG99514,VBOOST,65.0, V
ENG103201,VCV_CLOSE_RNG,23.3, °
ENG102311,Vehicle speed: filtered,0.000, km/h
ENG122704,VLCAvl_st_Pt_VW,4,
ENG122705,VLCReq_st_Dem_VW,6,
ENG112639,VLS_DOWN_SAE[1],0.770, V
ENG128806,VOL_FLOW_CHA_UP_RED_MV,0.002258, m³/s
ENG101929,VP_TPS_1,0.5811, V
ENG102985,VP_TPS_2,4.4141, V
ENG100421,VP_TPS_AD_EL_BOL_1,0.4932, V
ENG103444,VP_TPS_AD_EL_BOL_2,4.5070, V
ENG101674,VP_TPS_AD_LIH_1,0.9424, V
ENG99507,VP_TPS_AD_LIH_2,4.0576, V
Elapsed Time: 01:26
adpmap-01-80A-906-259-A
;SW:80A-906-259-A   HW:06L-907-425-C ---  Engine
;Component:2.0l R4 TFSI  H15 0003, Coding:2A6500122526012E74080000000000000000000000000000
;EV_ECM20TFS02080A906259A,001004,EV_ECM20TFS02080A906259A.rod
;Friday,12,July,2019,16:04:20:64285
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: A915FEE4C802BF076E-80FC
IDE01945-Engine run-in oil pressure,not active ,1
IDE04158-Activation of start-stop function,active ,1
IDE06726-Timing deviation after chain replacement: intake bank 1,-0.63 °,2
IDE06728-Timing deviation after chain replacement: exhaust bank 1,-2.50 °,2
IDE06730-Timing deviation after other repairs: intake bank 1,0.00 °,2
IDE06732-Timing deviation after other repairs: exhaust bank 1,0.00 °,2
IDE06734-Timing deviation: current value intake bank 1,-0.56 °,2
IDE06736-Timing deviation: current value exhaust bank 1,-2.38 °,2
IDE06738-Chain elongation: no. of valid initial values: intake bank 1,4 ,1
IDE06740-Chain elongation: no. of valid initial values: exhaust bank 1,5 ,1
IDE06742-Chain elongation: initial values valid: intake bank 1,active ,1
IDE06744-Chain elongation: initial values valid: exhaust bank 1,active ,1
IDE07160-MAS00478-Control module switch-off: switch-off time-Reserved,0 ,2
IDE10261-MAS10172-Operating mode selec.-DI operation,not activated ,4
IDE10261-MAS10174-Operating mode selec.-CNG operation,not activated ,4
IDE10261-Operating mode selec.-,not activated ,4
Elapsed Time: 00:04
blockmap-02-80A-927-155-AJ
;SW:80A-927-155-AJ   HW:0CJ-927-156 ---  Auto Trans
;Component:0CJ 20TFSINAR H05 0001, Coding:000001
;EV_TCMDL382021,002027,EV_TCMDL382021_AU49.rod
;Friday,12,July,2019,16:04:29:64285
;VCID: F1A5D684205287C7E6-80A4
Group,Description,Actual
IDE00019,Voltage terminal 30,14.400, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine speed,801, /min
IDE00022,Transmission input speed,799.00, /min
IDE00023,Transmission output speed,0.00, /min
IDE00024-ENG98502,Transmission fluid temperature-Data,69, °C
IDE00025,Coolant temperature,107, °C
IDE00026,Vehicle speed from transmission,0.00, km/h
IDE00027-MAS00179,Status of brake signals-Brake Light Switch,not activated,
IDE00027-MAS00180,Status of brake signals-Brake pressure switch,not activated,
IDE00027-MAS00181,Status of brake signals-Validity of brake pressure information,plausible,
IDE00027-MAS00182,Status of brake signals-Validity of brake pedal information,plausible,
IDE00027-ENG119971,Status of brake signals-MO_Fahrer_bremst,not activated,
IDE00027-ENG06674,Status of brake signals-MO_Konsistenz_Bremsped,plausible,
IDE00028,Road resistance index,0, %
IDE00031,Torque transmitting function,0.0,
IDE00085,Normed load value,14.9, %
IDE00086,Accelerator position,15, %
IDE00087-MAS00115,Tiptronic status-Tiptronic gate,not active,
IDE00087-MAS00116,Tiptronic status-Tiptronic +,not active,
IDE00087-MAS00117,Tiptronic status-Tiptronic -,not active,
IDE00087-MAS00118,Tiptronic status-Tiptronic steering wheel +,not active,
IDE00087-MAS00119,Tiptronic status-Tiptronic steering wheel -,not active,
IDE00089-ENG98502,Driving position-Data,P,
IDE00090-ENG100894,selected gear-Ist Gang,1,
IDE00091,Status of starter lock,On,
IDE00094,Kick-down status,not active,
IDE00095,Status of selector lever lock,not active,
IDE00096,Selector lever position,Error E5,
IDE00098,Transmission position,P,
IDE00100-ENG98502,Engine torque-Data,0, Nm
IDE00102,Control Module temperature,68, °C
IDE00109-ENG98502,Selector lever maximum pulse width High-Data,0.000, ms
IDE00110-ENG98502,Selector lever minimum pulse width High-Data,26.214, ms
IDE00111-ENG98502,Selector lever maximum pulse width Low-Data,0.000, ms
IDE00112-ENG98502,Selector lever minimum pulse width Low-Data,26.214, ms
IDE00138,Total driving time,481.00, H
IDE00139,Economical driving time portion,84.8, %
IDE00140,Sport driving time portion,14.4, %
IDE00141,Manual driving time portion,0.4, %
IDE00450-ENG100352,Operating Instructions-Requested Action for Routine,--no display--,
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00853-ENG98502,Clutch 1 lower adaptation point-Data,2.854, bar
IDE00854-ENG98502,Clutch 1 upper adaptation point-Data,13.176, bar
IDE00855-ENG98502,Clutch 2 lower adaptation point-Data,3.165, bar
IDE00856-ENG98502,Clutch 2 upper adaptation point-Data,12.904, bar
IDE00857-ENG98502,Target gear of shift during upshift-Data,1,
IDE00858-ENG98502,Condition of upshift-Data,Selecting,
IDE00861-ENG98502,Target gear of shift during downshift-Data,1,
IDE00866-ENG98502,Specified torque clutch 1-Data,-500.00, Nm
IDE00867-ENG98502,Specified torque clutch 2-Data,-500.00, Nm
IDE00878-ENG98502,Clutch status-Data,Neutral,
IDE02861-ENG98502,Mechatronic identification-Data,0CK325026AA0CK325031APP2C09K0159180322,
IDE02862-ENG98502,Production data transmission-Data,006SUXC033368K180323,
IDE03008-MAS03911,Stop process prevented-Oil temperature too low,not active,
IDE03008-MAS03912,Stop process prevented-Transmission fluid temperature too high,not active,
IDE03008-MAS03915,Stop process prevented-Gear 1 or 2 not selected,not active,
IDE03008-MAS16496,Stop process prevented-Current draw of transmission control module is too high,not active,
IDE03010-MAS03911,Number of prevented stop processes-Oil temperature too low,6,
IDE03010-MAS03912,Number of prevented stop processes-Transmission fluid temperature too high,0,
IDE03010-MAS03915,Number of prevented stop processes-Gear 1 or 2 not selected,0,
IDE03010-MAS16496,Number of prevented stop processes-Current draw of transmission control module is too high,0,
IDE03011-MAS03916,Number of requested start processes-Gear selector position,0,
IDE03011-MAS16496,Number of requested start processes-Current draw of transmission control module is too high,0,
IDE03127-IDE03008,Prevented stop processes (ring memory)-Stop process prevented,Oil temperature too low,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2127,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,15,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,31,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,31,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,63,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,63,
IDE03128-IDE03009,Requested start processes (ring memory)-Start process requested,Unknown (255),
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03212,Start-stop conditions,Stop release,
IDE03213,Start-stop enabling,No release by coordinator,
IDE04288-ENG101799,Adaptation status of the engagement point of clutch 1-Param to DOP,Engagement point broken in,
IDE04289-ENG101799,Adaptation status of the engagement point of clutch 2-Param to DOP,Engagement point broken in,
IDE04347-IDE00019,Expanded environmental conditions-Voltage terminal 30,7.6, V
IDE04347-IDE00021,Expanded environmental conditions-Engine speed,0.00, /min
IDE04347-IDE00023,Expanded environmental conditions-Transmission output speed,0, /min
IDE04347-IDE00024,Expanded environmental conditions-Transmission fluid temperature,15, °C
IDE04347-IDE00026,Expanded environmental conditions-Vehicle speed from transmission,0.0, km/h
IDE04347-IDE00089,Expanded environmental conditions-Driving position,P,
IDE04347-IDE00090,Expanded environmental conditions-selected gear,1,
IDE04347-IDE00100,Expanded environmental conditions-Engine torque,-26.00, Nm
IDE04347-IDE00102,Expanded environmental conditions-Control Module temperature,20, °C
IDE04347-IDE00853,Expanded environmental conditions-Clutch 1 lower adaptation point,2.8, bar
IDE04347-IDE00854,Expanded environmental conditions-Clutch 1 upper adaptation point,13.6, bar
IDE04347-IDE00855,Expanded environmental conditions-Clutch 2 lower adaptation point,3.2, bar
IDE04347-IDE00856,Expanded environmental conditions-Clutch 2 upper adaptation point,12.7, bar
IDE04347-IDE00857,Expanded environmental conditions-Target gear of shift during upshift,N,
IDE04347-IDE00858,Expanded environmental conditions-Condition of upshift,Selecting,
IDE04347-IDE00861,Expanded environmental conditions-Target gear of shift during downshift,N,
IDE04347-IDE00866,Expanded environmental conditions-Specified torque clutch 1,-500.00, Nm
IDE04347-IDE00867,Expanded environmental conditions-Specified torque clutch 2,-500.00, Nm
IDE04347-IDE00868,Expanded environmental conditions-Current of gear Solen.val. 1-3,1.5, mA
IDE04347-IDE00869,Expanded environmental conditions-Current of gear Solen.val. 2-R,2.0, mA
IDE04347-IDE00870,Expanded environmental conditions-Current of gear Solen.val. 4-6,2.1, mA
IDE04347-IDE00872,Expanded environmental conditions-Current of main pressure valve,3.7, mA
IDE04347-IDE00873,Expanded environmental conditions-Current of cooling oil valve,2.6, mA
IDE04347-IDE00874,Expanded environmental conditions-Current of partial transmission valve 1,0.0, mA
IDE04347-IDE00875,Expanded environmental conditions-Current of partial transmission valve 2,0.0, mA
IDE04347-IDE00876,Expanded environmental conditions-Clutch pressure: clutch 1,0.0, bar
IDE04347-IDE00877,Expanded environmental conditions-Clutch pressure: clutch 2,0.0, bar
IDE04347-IDE00878,Expanded environmental conditions-Clutch status,Neutral,
IDE04347-IDE05990,Expanded environmental conditions-Pressure of clutch 2: specified value,0.0, bar
IDE04347-IDE05991,Expanded environmental conditions-Pressure of clutch 1: specified value,0.0, bar
IDE04347-IDE09396,Expanded environmental conditions-Aux. hydraulic pump 1: actual RPM,0, /min
IDE04347-IDE09397,Expanded environmental conditions-Aux. hydraulic pump 1: spec. RPM,0, /min
IDE04347-IDE09399,Expanded environmental conditions-Electrical pump 2 for trans. oil: nominal speed,-5, °C
IDE04347-IDE09400,Expanded environmental conditions-Oil pressure reservoir: status,undefined,
IDE04347-IDE10177,Expanded environmental conditions-Transmission input speed sensor 1,0, /min
IDE04347-IDE10178,Expanded environmental conditions-Transmission input speed sensor 2,0, /min
IDE04347-MAS00106,Expanded environmental conditions-Year,2019,
IDE04347-MAS00107,Expanded environmental conditions-Month,4,
IDE04347-MAS00108,Expanded environmental conditions-Day,22,
IDE04347-MAS00109,Expanded environmental conditions-Hours,8,
IDE04347-MAS00110,Expanded environmental conditions-Minutes,45,
IDE04347-MAS00111,Expanded environmental conditions-Seconds,0,
IDE04347-MAS00156,Expanded environmental conditions-Driving direction,unbestimmt,
IDE04347-ENG129958,Expanded environmental conditions-Accumulator_pressure_valve_actual_current,0.0, mA
IDE04347-ENG129957,Expanded environmental conditions-Accumulator_pressure_valve_commanded_current,0.0, mA
IDE04347-ENG129751,Expanded environmental conditions-Automatic_transmission_fluid_pressure_accumulator_pressure,0.0, bar
IDE04347-ENG129686,Expanded environmental conditions-Automatic_transmission_fluid_pump_adaption_state,Init,
IDE04347-ENG130017,Expanded environmental conditions-Automatic_transmission_fluid_pump_current_adapted,0.0, A
IDE04347-ENG129731,Expanded environmental conditions-Automatic_transmission_fluid_pump_phase_current,0, A
IDE04347-ENG130016,Expanded environmental conditions-Automatic_transmission_fluid_pump_phase_current_reference_value,0.0, A
IDE04347-ENG130015,Expanded environmental conditions-Automatic_transmission_fluid_pump_shunt_current,0.01, A
IDE04347-ENG129701,Expanded environmental conditions-Automatic_transmission_fluid_source_of_commanded_speed,ATF-Motor-Nachlauf,
IDE04347-ENG118442,Expanded environmental conditions-Clutch_0_actual_torque_hyb,0.00, Nm
IDE04347-ENG118288,Expanded environmental conditions-Clutch_0_adaption_kisspoint,0.0, bar
IDE04347-ENG118374,Expanded environmental conditions-Clutch_0_adaption_PKp1,0.0, bar
IDE04347-ENG118416,Expanded environmental conditions-Clutch_0_adaption_PKp2,0.0, bar
IDE04347-ENG129961,Expanded environmental conditions-Clutch_0_commanded_pressure,0.0, bar
IDE04347-ENG118399,Expanded environmental conditions-Clutch_0_commanded_torque_hyb,0.00, Nm
IDE04347-ENG118318,Expanded environmental conditions-Clutch_0_steel_leaves_temperatur,0, °C
IDE04347-ENG129954,Expanded environmental conditions-Clutch_0_valve_actual_current,0.0, mA
IDE04347-ENG129953,Expanded environmental conditions-Clutch_0_valve_commanded_current,0.0, mA
IDE04347-ENG129969,Expanded environmental conditions-Clutch_1_cooling_oil_requirement_actual_value,0.0, l/min
IDE04347-ENG129968,Expanded environmental conditions-Clutch_1_cooling_oil_requirement_commanded_value,0.0, l/min
IDE04347-ENG129972,Expanded environmental conditions-Clutch_1_steel_leaves_temperatur,15, °C
IDE04347-ENG129955,Expanded environmental conditions-Clutch_1_valve_commanded_current,0.0, mA
IDE04347-ENG129971,Expanded environmental conditions-Clutch_2_cooling_oil_requirement_actual_value,0.0, l/min
IDE04347-ENG129970,Expanded environmental conditions-Clutch_2_cooling_oil_requirement_commanded_value,0.0, l/min
IDE04347-ENG129973,Expanded environmental conditions-Clutch_2_steel_leaves_temperatur,15, °C
IDE04347-ENG129956,Expanded environmental conditions-Clutch_2_valve_commanded_current,0.0, mA
IDE04347-ENG129966,Expanded environmental conditions-Clutch_actuation_substate,0,
IDE04347-ENG129965,Expanded environmental conditions-Clutch_adaption_kisspoint_state,OFF,
IDE04347-ENG118401,Expanded environmental conditions-Combustion_engine_speed_hyb,0, /min
IDE04347-ENG129952,Expanded environmental conditions-Cooling_pressure_valve_commanded_current,0.0, mA
IDE04347-ENG99228,Expanded environmental conditions-Diagnostic Fault Check Code,00 51 B6,
IDE04347-ENG129997,Expanded environmental conditions-Drive_position_sensor_value_neg,84.5, %
IDE04347-ENG129996,Expanded environmental conditions-Drive_position_sensor_value_pos,83.5, %
IDE04347-ENG130005,Expanded environmental conditions-Driving_strategy_ABS_state,OFF,
IDE04347-ENG130013,Expanded environmental conditions-Driving_strategy_accelerator_pedal_position_modified,0.0, %
IDE04347-ENG130014,Expanded environmental conditions-Driving_strategy_angle_of_inclination,0.0, %
IDE04347-ENG130010,Expanded environmental conditions-Driving_strategy_ASR_state,OFF,
IDE04347-ENG130006,Expanded environmental conditions-Driving_strategy_brake_state,On,
IDE04347-ENG118434,Expanded environmental conditions-Driving_strategy_clutch0_main_state,Kupplung K0 ist offen,
IDE04347-ENG130004,Expanded environmental conditions-Driving_strategy_down_shift_actuation_state,Selecting,
IDE04347-ENG130007,Expanded environmental conditions-Driving_strategy_EDS_state,OFF,
IDE04347-ENG118236,Expanded environmental conditions-Driving_strategy_electrical_drive,Init,
IDE04347-ENG130008,Expanded environmental conditions-Driving_strategy_ESP_state,OFF,
IDE04347-ENG130002,Expanded environmental conditions-Driving_strategy_gear_commanded,1,
IDE04347-ENG130003,Expanded environmental conditions-Driving_strategy_gear_preset,R,
IDE04347-ENG130009,Expanded environmental conditions-Driving_strategy_GRA_state,OFF,
IDE04347-ENG130012,Expanded environmental conditions-Driving_strategy_vehicle_coordinator_main_state,After-run,
IDE04347-ENG118348,Expanded environmental conditions-Electric_engine_torque_hyb,0.00, Nm
IDE04347-ENG118213,Expanded environmental conditions-Electrical_pump_3_for_transmission_actual_speed,0, /min
IDE04347-ENG118214,Expanded environmental conditions-Electrical_pump_3_for_transmission_commanded_speed,0, /min
IDE04347-ENG118400,Expanded environmental conditions-Electrical_pump_3_for_transmission_current,0.0, A
IDE04347-ENG114478,Expanded environmental conditions-Electrical_pump_3_for_transmission_phase_current,-63.0, A
IDE04347-ENG110459,Expanded environmental conditions-Engine_idle_speed_commanded_value,1250, /min
IDE04347-ENG129959,Expanded environmental conditions-Engine_intervention_state,8192,
IDE04347-ENG130000,Expanded environmental conditions-Engine_torque_dominant,0.00, Nm
IDE04347-ENG129946,Expanded environmental conditions-Gear_selector_1_3_valve_commanded_current,0.0, mA
IDE04347-ENG129988,Expanded environmental conditions-Gear_selector_13_adapted_synchron_position_neg,-2.8, mm
IDE04347-ENG129989,Expanded environmental conditions-Gear_selector_13_adapted_synchron_position_pos,2.1, mm
IDE04347-ENG129984,Expanded environmental conditions-Gear_selector_13_measured_distance,9.3, mm
IDE04347-ENG129980,Expanded environmental conditions-Gear_selector_13_state,Abschaltung Bereit,
IDE04347-ENG129950,Expanded environmental conditions-Gear_selector_2_R_valve_commanded_current,0.0, mA
IDE04347-ENG129994,Expanded environmental conditions-Gear_selector_2R_adapted_synchron_position_neg,-2.4, mm
IDE04347-ENG129995,Expanded environmental conditions-Gear_selector_2R_adapted_synchron_position_pos,1.9, mm
IDE04347-ENG129987,Expanded environmental conditions-Gear_selector_2R_measured_distance,-9.4, mm
IDE04347-ENG129983,Expanded environmental conditions-Gear_selector_2R_state,Abschaltung Bereit,
IDE04347-ENG129949,Expanded environmental conditions-Gear_selector_4_6_valve_commanded_current,0.0, mA
IDE04347-ENG129992,Expanded environmental conditions-Gear_selector_46_adapted_synchron_position_neg,-2.5, mm
IDE04347-ENG129993,Expanded environmental conditions-Gear_selector_46_adapted_synchron_position_pos,1.9, mm
IDE04347-ENG129986,Expanded environmental conditions-Gear_selector_46_measured_distance,-0.1, mm
IDE04347-ENG129982,Expanded environmental conditions-Gear_selector_46_state,Abschaltung Bereit,
IDE04347-ENG129948,Expanded environmental conditions-Gear_selector_5_7_valve_actual_current,1.1, mA
IDE04347-ENG129947,Expanded environmental conditions-Gear_selector_5_7_valve_commanded_current,0.0, mA
IDE04347-ENG129990,Expanded environmental conditions-Gear_selector_57_adapted_synchron_position_neg,-2.4, mm
IDE04347-ENG129991,Expanded environmental conditions-Gear_selector_57_adapted_synchron_position_pos,2.0, mm
IDE04347-ENG129985,Expanded environmental conditions-Gear_selector_57_measured_distance,-0.2, mm
IDE04347-ENG129981,Expanded environmental conditions-Gear_selector_57_state,Abschaltung Bereit,
IDE04347-ENG130011,Expanded environmental conditions-KL15_state,OFF,
IDE04347-ENG103792,Expanded environmental conditions-km-Mileage,29851, km
IDE04347-ENG129951,Expanded environmental conditions-Main_pressure_valve_commanded_current,0.0, mA
IDE04347-ENG129755,Expanded environmental conditions-Manual_transmission_fluid_pump_actual_speed,0, /min
IDE04347-ENG129756,Expanded environmental conditions-Manual_transmission_fluid_pump_commanded_speed,0, /min
IDE04347-ENG27077,Expanded environmental conditions-Pressure_sensor_change_state,nicht vertauscht,
IDE04347-ENG129999,Expanded environmental conditions-Selector_lever_holding_magnet_state,2,
IDE04347-ENG99809,Expanded environmental conditions-System time in after-run mode,14, s
IDE04347-ENG99203,Expanded environmental conditions-System time in normal mode,18, s
IDE04347-ENG129976,Expanded environmental conditions-Transmission_control_module_LM71_temperature,13, °C
IDE04347-ENG129721,Expanded environmental conditions-Voltage_supply_1_for_sensors,5.0, V
IDE04347-ENG129722,Expanded environmental conditions-Voltage_supply_2_for_sensors,5.0, V
IDE04347-ENG129977,Expanded environmental conditions-Voltage_supply_3_for_sensors,5.0, V
IDE04347-ENG129978,Expanded environmental conditions-Voltage_supply_commanded_value,0.0, V
IDE04347-ENG129979,Expanded environmental conditions-Voltage_supply_speed_sensor,6.1, V
IDE05566-ENG100476,Counter for operation with increased engine oil temp-TEMP_INTERVAL_01_HOURS,458, H
IDE05566-ENG102684,Counter for operation with increased engine oil temp-TEMP_INTERVAL_01_MINUTES,26, min
IDE05566-ENG104078,Counter for operation with increased engine oil temp-TEMP_INTERVAL_01_SECONDS,42, s
IDE05566-ENG99589,Counter for operation with increased engine oil temp-TEMP_INTERVAL_02_HOURS,0, H
IDE05566-ENG103797,Counter for operation with increased engine oil temp-TEMP_INTERVAL_02_MINUTES,0, min
IDE05566-ENG103883,Counter for operation with increased engine oil temp-TEMP_INTERVAL_02_SECONDS,0, s
IDE05566-ENG103406,Counter for operation with increased engine oil temp-TEMP_INTERVAL_03_HOURS,0, H
IDE05566-ENG100661,Counter for operation with increased engine oil temp-TEMP_INTERVAL_03_MINUTES,0, min
IDE05566-ENG102183,Counter for operation with increased engine oil temp-TEMP_INTERVAL_03_SECONDS,0, s
IDE05566-ENG99316,Counter for operation with increased engine oil temp-TEMP_INTERVAL_04_HOURS,0, H
IDE05566-ENG99998,Counter for operation with increased engine oil temp-TEMP_INTERVAL_04_MINUTES,0, min
IDE05566-ENG100721,Counter for operation with increased engine oil temp-TEMP_INTERVAL_04_SECONDS,0, s
IDE05566-ENG100915,Counter for operation with increased engine oil temp-TEMP_INTERVAL_05_HOURS,0, H
IDE05566-ENG102533,Counter for operation with increased engine oil temp-TEMP_INTERVAL_05_MINUTES,0, min
IDE05566-ENG102011,Counter for operation with increased engine oil temp-TEMP_INTERVAL_05_SECONDS,0, s
IDE05815-MAS02985,Sail function-Value,257,
IDE05815-MAS07649,Sail function-Gas pedal depress.,No,
IDE05815-MAS07650,Sail function-Brake pedal depress.,No,
IDE05815-MAS12738,Sail function-Accel. pedal activated too quickly,No,
IDE05815-MAS12739,Sail function-Trailer hitched,No,
IDE05815-MAS12740,Sail function-Incline/decline excessive,No,
IDE05815-MAS12741,Sail function-Vehicle speed outside permitted range,Yes,
IDE05815-MAS12742,Sail function-Transmission adaption active,No,
IDE05815-MAS12743,Sail function-Transmission temp. outside permissible range,No,
IDE05815-MAS12744,Sail function-Exterior temperature outside permissible range,No,
IDE05815-MAS12745,Sail function-Event memory entry active,No,
IDE05815-MAS12746,Sail function-Coding of control module for automatic transmission incorrect,No,
IDE05815-MAS12747,Sail function-Engine drag torque control: ABS or ESC control active,No,
IDE05815-MAS12748,Sail function-Button for ASR and ESP activated,No,
IDE05815-MAS12749,Sail function-Activation prevented by engine control module,No,
IDE05815-MAS12750,Sail function-Activation prevented by battery energy management,No,
IDE05815-MAS12752,Sail function-Activation prevented by Climatronic control module,No,
IDE05815-MAS12753,Sail function-Activation prevented by ACC,No,
IDE05815-MAS12754,Sail function-Driving style insufficiently defined,No,
IDE05815-MAS12755,Sail function-Corner driving detected,No,
IDE05815-MAS12756,Sail function-Engine temperature too low/warm-up not finished,No,
IDE05815-MAS12757,Sail function-Deactivation by driver,No,
IDE05815-MAS12758,Sail function-Position of selector lever or drive program incorrect,Yes,
IDE06241,Uneven road surface recognition: total driving portion,0.00, %
IDE06242,Distance since last activation: uneven road surface recognition,16777215, km
IDE06243,Longest active distance with uneven road surface recognition,0, km
IDE06307-MAS00106,Stop prevention history data-Year,2127,
IDE06307-MAS00107,Stop prevention history data-Month,15,
IDE06307-MAS00108,Stop prevention history data-Day,31,
IDE06307-MAS00109,Stop prevention history data-Hours,31,
IDE06307-MAS00110,Stop prevention history data-Minutes,63,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307,Stop prevention history data,Oil temperature too low,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,not active,
IDE06658,Pressure control valve 2: act. current,0.6, mA
IDE06659,Pressure control valve 3: act. current,8.7, mA
IDE06660,Pressure control valve 3: spec. current,0.0, mA
IDE06661,Pressure control valve 2: spec. current,0.0, mA
IDE06662,Pressure control valve 4: spec. current,513.3, mA
IDE06663,Pressure control valve 4: act. current,-55.2, mA
IDE06668,Pressure control valve 1: act. current,1.7, mA
IDE06669,Pressure control valve 1: spec. current,0.0, mA
IDE07677,Counter Auto-P,81,
IDE07678,Counter N-hold. phase,9,
IDE07679,Counter engine off in P,1070,
IDE07680,Counter insertion processes P,1717,
IDE08133-ENG98502,Basic setting: cause for cancellation-Data,Basic setting not active,
IDE09372-ENG98933,Oil pressure reservoir: status of emptying-Status,not active,
IDE09373-ENG98502,Oil pressure reservoir: pressure-Data,20.9, bar
IDE09396,Aux. hydraulic pump 1: actual RPM,616, /min
IDE09397-ENG98502,Aux. hydraulic pump 1: spec. RPM-Data,623, /min
IDE09398,Electrical pump 2 for trans. oil: actual speed,2999, /min
IDE09399,Electrical pump 2 for trans. oil: nominal speed,3000, /min
IDE09400-ENG98502,Oil pressure reservoir: status-Data,was not charged,
IDE09640-MAS09266,Adapted pressure values for clutch 1: raising-Basic value 1,0.000, bar
IDE09640-MAS09267,Adapted pressure values for clutch 1: raising-Basic value 2,0.000, bar
IDE09640-MAS09268,Adapted pressure values for clutch 1: raising-Basic value 3,0.000, bar
IDE09640-MAS09269,Adapted pressure values for clutch 1: raising-Basic value 4,0.000, bar
IDE09640-MAS09270,Adapted pressure values for clutch 1: raising-Basic value 5,0.000, bar
IDE09640-MAS09271,Adapted pressure values for clutch 1: raising-Basic value 6,0.000, bar
IDE09640-MAS09272,Adapted pressure values for clutch 1: raising-Basic value 7,0.000, bar
IDE09640-MAS09273,Adapted pressure values for clutch 1: raising-Basic value 8,0.000, bar
IDE09640-MAS09274,Adapted pressure values for clutch 1: raising-Basic value 9,0.000, bar
IDE09640-MAS09275,Adapted pressure values for clutch 1: raising-Basic value 10,0.000, bar
IDE09640-MAS09276,Adapted pressure values for clutch 1: raising-Basic value 11,0.000, bar
IDE09640-MAS09277,Adapted pressure values for clutch 1: raising-Basic value 12,0.000, bar
IDE09640-MAS09278,Adapted pressure values for clutch 1: raising-Basic value 13,0.000, bar
IDE09640-MAS09279,Adapted pressure values for clutch 1: raising-Basic value 14,0.000, bar
IDE09640-MAS09280,Adapted pressure values for clutch 1: raising-Basic value 15,0.000, bar
IDE09640-MAS09281,Adapted pressure values for clutch 1: raising-Basic value 16,0.000, bar
IDE09640-MAS09309,Adapted pressure values for clutch 1: raising-Basic value 17,0.000, bar
IDE09641-MAS09266,Adapted pressure values for clutch 1: falling-Basic value 1,0.000, bar
IDE09641-MAS09267,Adapted pressure values for clutch 1: falling-Basic value 2,0.000, bar
IDE09641-MAS09268,Adapted pressure values for clutch 1: falling-Basic value 3,0.000, bar
IDE09641-MAS09269,Adapted pressure values for clutch 1: falling-Basic value 4,0.000, bar
IDE09641-MAS09270,Adapted pressure values for clutch 1: falling-Basic value 5,0.000, bar
IDE09641-MAS09271,Adapted pressure values for clutch 1: falling-Basic value 6,0.000, bar
IDE09641-MAS09272,Adapted pressure values for clutch 1: falling-Basic value 7,0.000, bar
IDE09641-MAS09273,Adapted pressure values for clutch 1: falling-Basic value 8,0.000, bar
IDE09641-MAS09274,Adapted pressure values for clutch 1: falling-Basic value 9,0.000, bar
IDE09641-MAS09275,Adapted pressure values for clutch 1: falling-Basic value 10,0.000, bar
IDE09641-MAS09276,Adapted pressure values for clutch 1: falling-Basic value 11,0.000, bar
IDE09641-MAS09277,Adapted pressure values for clutch 1: falling-Basic value 12,0.000, bar
IDE09641-MAS09278,Adapted pressure values for clutch 1: falling-Basic value 13,0.000, bar
IDE09641-MAS09279,Adapted pressure values for clutch 1: falling-Basic value 14,0.000, bar
IDE09641-MAS09280,Adapted pressure values for clutch 1: falling-Basic value 15,0.000, bar
IDE09641-MAS09281,Adapted pressure values for clutch 1: falling-Basic value 16,0.000, bar
IDE09641-MAS09309,Adapted pressure values for clutch 1: falling-Basic value 17,0.000, bar
IDE09642-MAS09266,Adapted pressure values for clutch 2: raising-Basic value 1,0.000, bar
IDE09642-MAS09267,Adapted pressure values for clutch 2: raising-Basic value 2,0.000, bar
IDE09642-MAS09268,Adapted pressure values for clutch 2: raising-Basic value 3,0.000, bar
IDE09642-MAS09269,Adapted pressure values for clutch 2: raising-Basic value 4,0.000, bar
IDE09642-MAS09270,Adapted pressure values for clutch 2: raising-Basic value 5,0.000, bar
IDE09642-MAS09271,Adapted pressure values for clutch 2: raising-Basic value 6,0.000, bar
IDE09642-MAS09272,Adapted pressure values for clutch 2: raising-Basic value 7,0.000, bar
IDE09642-MAS09273,Adapted pressure values for clutch 2: raising-Basic value 8,0.000, bar
IDE09642-MAS09274,Adapted pressure values for clutch 2: raising-Basic value 9,0.000, bar
IDE09642-MAS09275,Adapted pressure values for clutch 2: raising-Basic value 10,0.000, bar
IDE09642-MAS09276,Adapted pressure values for clutch 2: raising-Basic value 11,0.000, bar
IDE09642-MAS09277,Adapted pressure values for clutch 2: raising-Basic value 12,0.000, bar
IDE09642-MAS09278,Adapted pressure values for clutch 2: raising-Basic value 13,0.000, bar
IDE09642-MAS09279,Adapted pressure values for clutch 2: raising-Basic value 14,0.000, bar
IDE09642-MAS09280,Adapted pressure values for clutch 2: raising-Basic value 15,0.000, bar
IDE09642-MAS09281,Adapted pressure values for clutch 2: raising-Basic value 16,0.000, bar
IDE09642-MAS09309,Adapted pressure values for clutch 2: raising-Basic value 17,0.000, bar
IDE09643-MAS09266,Adapted pressure values for clutch 2: falling-Basic value 1,0.000, bar
IDE09643-MAS09267,Adapted pressure values for clutch 2: falling-Basic value 2,0.000, bar
IDE09643-MAS09268,Adapted pressure values for clutch 2: falling-Basic value 3,0.000, bar
IDE09643-MAS09269,Adapted pressure values for clutch 2: falling-Basic value 4,0.000, bar
IDE09643-MAS09270,Adapted pressure values for clutch 2: falling-Basic value 5,0.000, bar
IDE09643-MAS09271,Adapted pressure values for clutch 2: falling-Basic value 6,0.000, bar
IDE09643-MAS09272,Adapted pressure values for clutch 2: falling-Basic value 7,0.000, bar
IDE09643-MAS09273,Adapted pressure values for clutch 2: falling-Basic value 8,0.000, bar
IDE09643-MAS09274,Adapted pressure values for clutch 2: falling-Basic value 9,0.000, bar
IDE09643-MAS09275,Adapted pressure values for clutch 2: falling-Basic value 10,0.000, bar
IDE09643-MAS09276,Adapted pressure values for clutch 2: falling-Basic value 11,0.000, bar
IDE09643-MAS09277,Adapted pressure values for clutch 2: falling-Basic value 12,0.000, bar
IDE09643-MAS09278,Adapted pressure values for clutch 2: falling-Basic value 13,0.000, bar
IDE09643-MAS09279,Adapted pressure values for clutch 2: falling-Basic value 14,0.000, bar
IDE09643-MAS09280,Adapted pressure values for clutch 2: falling-Basic value 15,0.000, bar
IDE09643-MAS09281,Adapted pressure values for clutch 2: falling-Basic value 16,0.000, bar
IDE09643-MAS09309,Adapted pressure values for clutch 2: falling-Basic value 17,0.000, bar
IDE09644-MAS09266,Adapted press. values for gear select. valve: raising-Basic value 1,0.000, bar
IDE09644-MAS09267,Adapted press. values for gear select. valve: raising-Basic value 2,0.000, bar
IDE09644-MAS09268,Adapted press. values for gear select. valve: raising-Basic value 3,0.000, bar
IDE09644-MAS09269,Adapted press. values for gear select. valve: raising-Basic value 4,0.000, bar
IDE09644-MAS09270,Adapted press. values for gear select. valve: raising-Basic value 5,0.000, bar
IDE09644-MAS09271,Adapted press. values for gear select. valve: raising-Basic value 6,0.000, bar
IDE09644-MAS09272,Adapted press. values for gear select. valve: raising-Basic value 7,0.000, bar
IDE09644-MAS09273,Adapted press. values for gear select. valve: raising-Basic value 8,0.000, bar
IDE09644-MAS09274,Adapted press. values for gear select. valve: raising-Basic value 9,0.000, bar
IDE09644-MAS09275,Adapted press. values for gear select. valve: raising-Basic value 10,0.000, bar
IDE09644-MAS09276,Adapted press. values for gear select. valve: raising-Basic value 11,0.000, bar
IDE09644-MAS09277,Adapted press. values for gear select. valve: raising-Basic value 12,0.000, bar
IDE09644-MAS09278,Adapted press. values for gear select. valve: raising-Basic value 13,0.000, bar
IDE09644-MAS09279,Adapted press. values for gear select. valve: raising-Basic value 14,0.000, bar
IDE09644-MAS09280,Adapted press. values for gear select. valve: raising-Basic value 15,0.000, bar
IDE09644-MAS09281,Adapted press. values for gear select. valve: raising-Basic value 16,0.000, bar
IDE09644-MAS09309,Adapted press. values for gear select. valve: raising-Basic value 17,0.000, bar
IDE09645-MAS09266,Adapted press. values for gear select. valve: falling-Basic value 1,0.000, bar
IDE09645-MAS09267,Adapted press. values for gear select. valve: falling-Basic value 2,0.000, bar
IDE09645-MAS09268,Adapted press. values for gear select. valve: falling-Basic value 3,0.000, bar
IDE09645-MAS09269,Adapted press. values for gear select. valve: falling-Basic value 4,0.000, bar
IDE09645-MAS09270,Adapted press. values for gear select. valve: falling-Basic value 5,0.000, bar
IDE09645-MAS09271,Adapted press. values for gear select. valve: falling-Basic value 6,0.000, bar
IDE09645-MAS09272,Adapted press. values for gear select. valve: falling-Basic value 7,0.000, bar
IDE09645-MAS09273,Adapted press. values for gear select. valve: falling-Basic value 8,0.000, bar
IDE09645-MAS09274,Adapted press. values for gear select. valve: falling-Basic value 9,0.000, bar
IDE09645-MAS09275,Adapted press. values for gear select. valve: falling-Basic value 10,0.000, bar
IDE09645-MAS09276,Adapted press. values for gear select. valve: falling-Basic value 11,0.000, bar
IDE09645-MAS09277,Adapted press. values for gear select. valve: falling-Basic value 12,0.000, bar
IDE09645-MAS09278,Adapted press. values for gear select. valve: falling-Basic value 13,0.000, bar
IDE09645-MAS09279,Adapted press. values for gear select. valve: falling-Basic value 14,0.000, bar
IDE09645-MAS09280,Adapted press. values for gear select. valve: falling-Basic value 15,0.000, bar
IDE09645-MAS09281,Adapted press. values for gear select. valve: falling-Basic value 16,0.000, bar
IDE09645-MAS09309,Adapted press. values for gear select. valve: falling-Basic value 17,0.000, bar
IDE10177,Transmission input speed sensor 1,0, /min
IDE10178,Transmission input speed sensor 2,0, /min
IDE10181-ENG98502,Rotor position sensor for auxil. hydraulic pump 1: offset sinus-Data,2771.4, mV
IDE10182-ENG98502,Rotor posit. sensor for auxil. hydraulic pump 1: offset cosine-Data,2784.8, mV
IDE10183-ENG98502,Rotor posit.sensor for auxil. hydraulic pump 1: amplitude sinus-Data,1060.2, mV
IDE10184-ENG98502,Rotor posit. sensor for auxil. hydraulic pump 1: amplitude cos.-Data,1051.1, mV
IDE10185-ENG98502,Rotor pos.sensor for auxil. hydraul.pump 1: max. upper shafts-Data,0.0, mV
IDE10186-ENG98502,Rotor posit.sens. for auxil. hydraulic pump 1: angle difference-Data,0.00, °
IDE10203-ENG98502,Audi drive select: drive program-Data,AUTO,
IDE10204-ENG98502,Transm. oil temp. MTD-Data,58, °C
IDE10209-ENG98502,Driving mode sensor 1: position-Data,P,
IDE10210-ENG98502,Driving mode sensor 2: position-Data,P,
IDE10213-ENG98502,Driving mode sensor: highest value for D-Data,37.00, %
IDE10394-ENG98502,Driving mode sensor: lowest value for D-Data,14.00, %
IDE10469-ENG98502,Clutch pressure: clutch 1-Data,0.0, bar
IDE10470-ENG98502,Clutch pressure: clutch 2-Data,0.0, bar
IDE10687-ENG98502,Electrical pump 2 for transmission: supply voltage terminal 30-Data,14.2, V
IDE10688-ENG98502,Electrical pump 2 for transmission: supply voltage terminal 15-Data,13.4, V
IDE10851-ENG98502,Selector lever position sensor: calibration status-Data,Init,
IDE10852-ENG98502,Selector lever position sensor: calibration step-Data,Checking prerequisites,
IDE10853-ENG98502,Transm. calibration: reason for abort-Data,OK,
IDE10854-ENG98502,Transm. calibration: calibration step-Data,Calibration off,
IDE11142-MAS12238,Configuration of valves-Solenoid valve 1,Gear selector positive gear 1 - negative gear 3,
IDE11142-MAS12239,Configuration of valves-Solenoid valve 2,Gear selector positive gear 2 - negative gear R,
IDE11142-MAS12240,Configuration of valves-Solenoid valve 3,Gear selector positive gear 5 - negative gear 7,
IDE11142-MAS12241,Configuration of valves-Solenoid valve 4,Gear selector positive gear 4 - negative gear 6,
IDE11142-MAS12242,Configuration of valves-Solenoid valve 5,Cooling oil valve,
IDE11142-MAS12243,Configuration of valves-Solenoid valve 6,Accum. press. valve,
IDE11142-MAS12244,Configuration of valves-Press.ctrl. valve 1,Clutch 1,
IDE11142-MAS12245,Configuration of valves-Press.ctrl. valve 2,Clutch 2,
IDE11142-MAS12246,Configuration of valves-Press.ctrl. valve 3,Main pressure valve,
IDE11142-MAS12247,Configuration of valves-Press.ctrl. valve 4,Clutch 0,
IDE11143,Sol. valve 1: act. current,2.2, mA
IDE11144,Sol. valve 1: spec. current,0.0, mA
IDE11145,Sol. valve 2: act. current,3.8, mA
IDE11146,Sol. valve 2: spec. current,0.0, mA
IDE11147,Sol. valve 3: act. current,2.4, mA
IDE11148,Sol. valve 3: spec. current,0.0, mA
IDE11149,Sol. valve 4: act. current,2.0, mA
IDE11150,Sol. valve 4: spec. current,0.0, mA
IDE11154-MAS12270,Sol. valve 1: engagement points of gear selector-Positive activation,846.0, mA
IDE11154-MAS12271,Sol. valve 1: engagement points of gear selector-Negative activation,658.0, mA
IDE11155-MAS12270,Sol. valve 2: engagement points of gear selector-Positive activation,853.0, mA
IDE11155-MAS12271,Sol. valve 2: engagement points of gear selector-Negative activation,657.0, mA
IDE11156-MAS12270,Sol. valve 3: engagement points of gear selector-Positive activation,841.0, mA
IDE11156-MAS12271,Sol. valve 3: engagement points of gear selector-Negative activation,655.0, mA
IDE11157-MAS12270,Sol. valve 4: engagement points of gear selector-Positive activation,857.0, mA
IDE11157-MAS12271,Sol. valve 4: engagement points of gear selector-Negative activation,662.0, mA
IDE11158-MAS12272,Configuration of distance sensors-Gear position distance sensor 1,Gear selector positive gear 1 - negative gear 3,
IDE11158-MAS12273,Configuration of distance sensors-Gear position distance sensor 2,Gear selector positive gear 2 - negative gear R,
IDE11158-MAS12274,Configuration of distance sensors-Gear position distance sensor 3,Gear selector positive gear 5 - negative gear 7,
IDE11158-MAS12275,Configuration of distance sensors-Gear position distance sensor 4,Gear selector positive gear 4 - negative gear 6,
IDE11159,Gear selector dist. sensor 1: position,9.2, mm
IDE11160,Gear selector dist. sensor 2: position,-9.4, mm
IDE11161,Gear selector dist. sensor 3: position,-0.3, mm
IDE11162,Gear selector dist. sensor 4: position,-0.4, mm
IDE11164-MAS12280,Gear 1: synchronization point-Adapted position,2.06, mm
IDE11164-MAS12281,Gear 1: synchronization point-Calibrated position,2.05, mm
IDE11165-MAS12280,Gear 2: synchronization point-Adapted position,1.98, mm
IDE11165-MAS12281,Gear 2: synchronization point-Calibrated position,2.56, mm
IDE11166-MAS12280,Gear 3: synchronization point-Adapted position,-2.69, mm
IDE11166-MAS12281,Gear 3: synchronization point-Calibrated position,-2.24, mm
IDE11167-MAS12280,Gear 4: synchronization point-Adapted position,1.85, mm
IDE11167-MAS12281,Gear 4: synchronization point-Calibrated position,2.01, mm
IDE11168-MAS12280,Gear 5: synchronization point-Adapted position,1.95, mm
IDE11168-MAS12281,Gear 5: synchronization point-Calibrated position,2.11, mm
IDE11169-MAS12280,Gear 6: synchronization point-Adapted position,-2.47, mm
IDE11169-MAS12281,Gear 6: synchronization point-Calibrated position,-2.50, mm
IDE11170-MAS12280,Gear 7: synchronization point-Adapted position,-2.45, mm
IDE11170-MAS12281,Gear 7: synchronization point-Calibrated position,-2.49, mm
IDE11171-MAS12280,Gear R: synchronization point-Adapted position,-2.37, mm
IDE11171-MAS12281,Gear R: synchronization point-Calibrated position,-2.37, mm
IDE11172,Gear 1: calibrated end position,9.30, mm
IDE11173,Gear 2: calibrated end position,9.48, mm
IDE11174,Gear 3: calibrated end position,-9.50, mm
IDE11175,Gear 4: calibrated end position,9.26, mm
IDE11176,Gear 5: calibrated end position,9.16, mm
IDE11177,Gear 6: calibrated end position,-9.50, mm
IDE11178,Gear 7: calibrated end position,-9.49, mm
IDE11179,Gear R: calibrated end position,-9.53, mm
IDE11180,Sol. valve 5: act. current,715.1, mA
IDE11181,Sol. valve 5: spec. current,749.4, mA
IDE11182,Sol. valve 6: act. current,0.0, mA
IDE11183,Sol. valve 6: spec. current,0.0, mA
IDE11187-MAS12281,Path sensor 2 for gear actuator: neutr.pos.calibr.and virt.-Calibrated position,0.02, mm
IDE11187-MAS13292,Path sensor 2 for gear actuator: neutr.pos.calibr.and virt.-Virtual position,0.00, mm
IDE11287-MAS12281,Path sensor 1 for gear actuator: neutr.pos.calibr.and virt.-Calibrated position,-0.09, mm
IDE11287-MAS13292,Path sensor 1 for gear actuator: neutr.pos.calibr.and virt.-Virtual position,0.00, mm
IDE11296-MAS12281,Path sensor 3 for gear actuator: neutr.pos.calibr.and virt.-Calibrated position,-0.20, mm
IDE11296-MAS13292,Path sensor 3 for gear actuator: neutr.pos.calibr.and virt.-Virtual position,0.00, mm
IDE11374-MAS12281,Path sensor 4 for gear actuator: neutr.pos.calibr.and virt.-Calibrated position,-0.13, mm
IDE11374-MAS13292,Path sensor 4 for gear actuator: neutr.pos.calibr.and virt.-Virtual position,0.00, mm
IDE11394-MAS12281,Gear 1: end position calibrated and virtual-Calibrated position,9.30, mm
IDE11394-MAS13292,Gear 1: end position calibrated and virtual-Virtual position,0.00, mm
IDE11420-MAS12281,Gear 2: end position calibrated and virtual-Calibrated position,9.48, mm
IDE11420-MAS13292,Gear 2: end position calibrated and virtual-Virtual position,0.00, mm
IDE11450-MAS12281,Gear 3: end position calibrated and virtual-Calibrated position,-9.50, mm
IDE11450-MAS13292,Gear 3: end position calibrated and virtual-Virtual position,0.00, mm
IDE11505-MAS12281,Gear 4: end position calibrated and virtual-Calibrated position,9.26, mm
IDE11505-MAS13292,Gear 4: end position calibrated and virtual-Virtual position,0.00, mm
IDE11534-MAS12281,Gear 5: end position calibrated and virtual-Calibrated position,9.16, mm
IDE11534-MAS13292,Gear 5: end position calibrated and virtual-Virtual position,0.00, mm
IDE11535-MAS12281,Gear 6: end position calibrated and virtual-Calibrated position,-9.50, mm
IDE11535-MAS13292,Gear 6: end position calibrated and virtual-Virtual position,0.00, mm
IDE11536-MAS12281,Gear 7: end position calibrated and virtual-Calibrated position,-9.49, mm
IDE11536-MAS13292,Gear 7: end position calibrated and virtual-Virtual position,0.00, mm
IDE11572-MAS12281,Gear R: end position calibrated and virtual-Calibrated position,-9.53, mm
IDE11572-MAS13292,Gear R: end position calibrated and virtual-Virtual position,0.00, mm
IDE11718-MAS13293,Solen.val. 1: applic.point of the gear actuat. calibr.and virt.-Positive application point,846.0, mA
IDE11718-MAS13294,Solen.val. 1: applic.point of the gear actuat. calibr.and virt.-Negative application point,658.0, mA
IDE11718-MAS13295,Solen.val. 1: applic.point of the gear actuat. calibr.and virt.-Virtual positive application point,0.0, mA
IDE11718-MAS13296,Solen.val. 1: applic.point of the gear actuat. calibr.and virt.-Virtual negative application point,0.0, mA
IDE11768-MAS13293,Solen.val. 2: applic.point of the gear actuat. calibr.and virt.-Positive application point,853.0, mA
IDE11768-MAS13294,Solen.val. 2: applic.point of the gear actuat. calibr.and virt.-Negative application point,657.0, mA
IDE11768-MAS13295,Solen.val. 2: applic.point of the gear actuat. calibr.and virt.-Virtual positive application point,0.0, mA
IDE11768-MAS13296,Solen.val. 2: applic.point of the gear actuat. calibr.and virt.-Virtual negative application point,0.0, mA
IDE11772-MAS13293,Solen.val. 3: applic.point of the gear actuat. calibr.and virt.-Positive application point,841.0, mA
IDE11772-MAS13294,Solen.val. 3: applic.point of the gear actuat. calibr.and virt.-Negative application point,655.0, mA
IDE11772-MAS13295,Solen.val. 3: applic.point of the gear actuat. calibr.and virt.-Virtual positive application point,0.0, mA
IDE11772-MAS13296,Solen.val. 3: applic.point of the gear actuat. calibr.and virt.-Virtual negative application point,0.0, mA
IDE11787-MAS13293,Solen.val. 4: applic.point of the gear actuat. calibr.and virt.-Positive application point,857.0, mA
IDE11787-MAS13294,Solen.val. 4: applic.point of the gear actuat. calibr.and virt.-Negative application point,662.0, mA
IDE11787-MAS13295,Solen.val. 4: applic.point of the gear actuat. calibr.and virt.-Virtual positive application point,0.0, mA
IDE11787-MAS13296,Solen.val. 4: applic.point of the gear actuat. calibr.and virt.-Virtual negative application point,0.0, mA
IDE11806-MAS13316,Calibration of path sensors: status for all gear actuators-Measured data of the gear actuator basic measurement,valid,
IDE11806-MAS13317,Calibration of path sensors: status for all gear actuators-Virtual data of the gear actuator basic measurement,valid,
IDE11806-MAS13318,Calibration of path sensors: status for all gear actuators-Measured data of the application points,valid,
IDE11806-MAS13319,Calibration of path sensors: status for all gear actuators-Virtual data of the application points,invalid,
IDE11806-MAS13320,Calibration of path sensors: status for all gear actuators-Measured data of the synchronous positions,valid,
IDE11806-MAS13321,Calibration of path sensors: status for all gear actuators-Virtual data of the synchronous positions,invalid,
IDE11807-MAS13308,Calibration of path sensors: status for sub-gearbox 1-Measured data of the end positions of sub-gearbox 1,valid,
IDE11807-MAS13309,Calibration of path sensors: status for sub-gearbox 1-Virtual data of the end positions of sub-gearbox 1,invalid,
IDE11807-MAS13310,Calibration of path sensors: status for sub-gearbox 1-Measured data of the synchronous positions of sub-gearbox 1,valid,
IDE11807-MAS13311,Calibration of path sensors: status for sub-gearbox 1-Virtual data of the synchronous positions of sub-gearbox 1,invalid,
IDE11808-MAS13312,Calibration of path sensors: status for sub-gearbox 2-Measured data of the end positions of sub-gearbox 2,valid,
IDE11808-MAS13313,Calibration of path sensors: status for sub-gearbox 2-Virtual data of the end positions of sub-gearbox 2,invalid,
IDE11808-MAS13314,Calibration of path sensors: status for sub-gearbox 2-Measured data of the synchronous positions of sub-gearbox 2,valid,
IDE11808-MAS13315,Calibration of path sensors: status for sub-gearbox 2-Virtual data of the synchronous positions of sub-gearbox 2,invalid,
IDE11809-MAS13300,Calibration of path sensors: status for neutral position-Measured data of the neutral position of gear actuator 1/3,valid,
IDE11809-MAS13301,Calibration of path sensors: status for neutral position-Virtual data of the neutral position of gear actuator 1/3,invalid,
IDE11809-MAS13302,Calibration of path sensors: status for neutral position-Measured data of the neutral position of gear actuator 2/R,valid,
IDE11809-MAS13303,Calibration of path sensors: status for neutral position-Virtual data of the neutral position of gear actuator 2/R,invalid,
IDE11809-MAS13304,Calibration of path sensors: status for neutral position-Measured data of the neutral position of gear actuator 5/7,valid,
IDE11809-MAS13305,Calibration of path sensors: status for neutral position-Virtual data of the neutral position of gear actuator 5/7,invalid,
IDE11809-MAS13306,Calibration of path sensors: status for neutral position-Measured data of the neutral position of gear actuator 4/6,valid,
IDE11809-MAS13307,Calibration of path sensors: status for neutral position-Virtual data of the neutral position of gear actuator 4/6,invalid,
IDE11813-MAS12280,Gear 1: synchronization point calibrated: adapted: virtual-Adapted position,2.06, mm
IDE11813-MAS12281,Gear 1: synchronization point calibrated: adapted: virtual-Calibrated position,2.05, mm
IDE11813-MAS13292,Gear 1: synchronization point calibrated: adapted: virtual-Virtual position,0.00, mm
IDE11814-MAS12280,Gear 2: synchronization point calibrated: adapted: virtual-Adapted position,1.98, mm
IDE11814-MAS12281,Gear 2: synchronization point calibrated: adapted: virtual-Calibrated position,2.56, mm
IDE11814-MAS13292,Gear 2: synchronization point calibrated: adapted: virtual-Virtual position,0.00, mm
IDE11815-MAS12280,Gear 3: synchronization point calibrated: adapted: virtual-Adapted position,-2.69, mm
IDE11815-MAS12281,Gear 3: synchronization point calibrated: adapted: virtual-Calibrated position,-2.24, mm
IDE11815-MAS13292,Gear 3: synchronization point calibrated: adapted: virtual-Virtual position,0.00, mm
IDE11816-MAS12280,Gear 4: synchronization point calibrated: adapted: virtual-Adapted position,1.85, mm
IDE11816-MAS12281,Gear 4: synchronization point calibrated: adapted: virtual-Calibrated position,2.01, mm
IDE11816-MAS13292,Gear 4: synchronization point calibrated: adapted: virtual-Virtual position,0.00, mm
IDE11817-MAS12280,Gear 5: synchronization point calibrated: adapted: virtual-Adapted position,1.95, mm
IDE11817-MAS12281,Gear 5: synchronization point calibrated: adapted: virtual-Calibrated position,2.11, mm
IDE11817-MAS13292,Gear 5: synchronization point calibrated: adapted: virtual-Virtual position,0.00, mm
IDE11818-MAS12280,Gear 6: synchronization point calibrated: adapted: virtual-Adapted position,-2.47, mm
IDE11818-MAS12281,Gear 6: synchronization point calibrated: adapted: virtual-Calibrated position,-2.50, mm
IDE11818-MAS13292,Gear 6: synchronization point calibrated: adapted: virtual-Virtual position,0.00, mm
IDE11819-MAS12280,Gear 7: synchronization point calibrated: adapted: virtual-Adapted position,-2.45, mm
IDE11819-MAS12281,Gear 7: synchronization point calibrated: adapted: virtual-Calibrated position,-2.49, mm
IDE11819-MAS13292,Gear 7: synchronization point calibrated: adapted: virtual-Virtual position,0.00, mm
IDE11820-MAS12280,Gear R: synchronization point calibrated: adapted: virtual-Adapted position,-2.37, mm
IDE11820-MAS12281,Gear R: synchronization point calibrated: adapted: virtual-Calibrated position,-2.37, mm
IDE11820-MAS13292,Gear R: synchronization point calibrated: adapted: virtual-Virtual position,0.00, mm
IDE11821-MAS13297,Clutch 1 frict.point: ref.pres. calibr. and virtual-Calibrated pressure,2620, mbar
IDE11821-MAS13298,Clutch 1 frict.point: ref.pres. calibr. and virtual-Virtual pressure,0, mbar
IDE11822-MAS13297,Clutch 2 frict.point: ref.pres. calibr. and virtual-Calibrated pressure,3320, mbar
IDE11822-MAS13298,Clutch 2 frict.point: ref.pres. calibr. and virtual-Virtual pressure,0, mbar
IDE11823-MAS13297,Clutch 1 frict.point: actual pressure calibrated and virtual-Calibrated pressure,2340, mbar
IDE11823-MAS13298,Clutch 1 frict.point: actual pressure calibrated and virtual-Virtual pressure,0, mbar
IDE11824-MAS13297,Clutch 2 frict.point: actual pressure calibrated and virtual-Calibrated pressure,0, mbar
IDE11824-MAS13298,Clutch 2 frict.point: actual pressure calibrated and virtual-Virtual pressure,0, mbar
IDE11825-MAS13297,Clutch 1 frict.point: corrected ref.pres. calibr. and virtual-Calibrated pressure,2854, mbar
IDE11825-MAS13298,Clutch 1 frict.point: corrected ref.pres. calibr. and virtual-Virtual pressure,0, mbar
IDE11826-MAS13297,Clutch 2 frict.point: corrected ref.pres. calibr. and virtual-Calibrated pressure,3165, mbar
IDE11826-MAS13298,Clutch 2 frict.point: corrected ref.pres. calibr. and virtual-Virtual pressure,0, mbar
IDE11827-MAS13297,Clutch 1 frict.point: corrected act. pres. calibr. and virtual-Calibrated pressure,2758, mbar
IDE11827-MAS13298,Clutch 1 frict.point: corrected act. pres. calibr. and virtual-Virtual pressure,0, mbar
IDE11828-MAS13297,Clutch 2 frict.point: corrected act. pres. calibr. and virtual-Calibrated pressure,3093, mbar
IDE11828-MAS13298,Clutch 2 frict.point: corrected act. pres. calibr. and virtual-Virtual pressure,0, mbar
IDE11829,Adapt. of clutch frict.points: friction loss torque shaft 1,0.0, Nm
IDE11830,Adapt. of clutch frict.points: friction loss torque shaft 2,0.0, Nm
IDE11831,Adapt. of clutch frict.points: drag torque clutch 1,0.0, Nm
IDE11832,Adapt. of clutch frict.points: drag torque clutch 2,0.0, Nm
IDE12593-IDE11433,Hydraulic test: status of the clutch path-Status of magnet for park. lock.,OK,
IDE12593-MAS02985,Hydraulic test: status of the clutch path-Value,0,
IDE12593-MAS14780,Hydraulic test: status of the clutch path-Clutch 1 maximum pressure,OK,
IDE12593-MAS14781,Hydraulic test: status of the clutch path-Clutch 2 maximum pressure,OK,
IDE12593-MAS14782,Hydraulic test: status of the clutch path-Preload pressure: clutch 1,OK,
IDE12593-MAS14783,Hydraulic test: status of the clutch path-Preload pressure: clutch 2,OK,
IDE12593-MAS14784,Hydraulic test: status of the clutch path-Oil pressure reservoir: gas pressure spring characteristic curve,OK,
IDE12593-MAS14785,Hydraulic test: status of the clutch path-Clutch pressure increasing: clutch 1,OK,
IDE12593-MAS14786,Hydraulic test: status of the clutch path-Clutch pressure increasing: clutch 2,OK,
IDE12593-MAS14787,Hydraulic test: status of the clutch path-Retention leakage in the high-pressure area,OK,
IDE12593-MAS14788,Hydraulic test: status of the clutch path-Retention leakage in the area of clutch 1,OK,
IDE12593-MAS14789,Hydraulic test: status of the clutch path-Retention leakage in the area of clutch 2,OK,
IDE12593-MAS14790,Hydraulic test: status of the clutch path-Charge leakage in high pressure area,OK,
IDE12593-MAS14791,Hydraulic test: status of the clutch path-Charge leakage in the area of clutch 1,OK,
IDE12593-MAS14792,Hydraulic test: status of the clutch path-Charge leakage in the area of clutch 2,OK,
IDE12593-MAS14793,Hydraulic test: status of the clutch path-Pressure release by emptying oil pressure reservoir,OK,
IDE12593-MAS20157,Hydraulic test: status of the clutch path-Separating clutch: preload pressure,OK,
IDE12593-MAS20158,Hydraulic test: status of the clutch path-Separating clutch: coupling pressure increasing,OK,
IDE12593-MAS20159,Hydraulic test: status of the clutch path-Stop leakage near separating clutch,OK,
IDE12593-MAS20160,Hydraulic test: status of the clutch path-Charge leakage near separating clutch,OK,
IDE12594-MAS02985,Hydraulic test: status of the gear positioner path-Value,0,
IDE12594-MAS14795,Hydraulic test: status of the gear positioner path-Pressure leakage in gear R,OK,
IDE12594-MAS14796,Hydraulic test: status of the gear positioner path-Pressure leakage in gear 1,OK,
IDE12594-MAS14797,Hydraulic test: status of the gear positioner path-Pressure leakage in gear 2,OK,
IDE12594-MAS14798,Hydraulic test: status of the gear positioner path-Pressure leakage in gear 3,OK,
IDE12594-MAS14799,Hydraulic test: status of the gear positioner path-Pressure leakage in gear 4,OK,
IDE12594-MAS14800,Hydraulic test: status of the gear positioner path-Pressure leakage in gear 5,OK,
IDE12594-MAS14801,Hydraulic test: status of the gear positioner path-Pressure leakage in gear 6,OK,
IDE12594-MAS14802,Hydraulic test: status of the gear positioner path-Pressure leakage in gear 7,OK,
IDE12595-MAS02985,Hydraulic test: status of the reservoir volume-Value,0,
IDE12595-MAS14803,Hydraulic test: status of the reservoir volume-Extraction volume,OK,
IDE12596-MAS02985,Hydraulic test: load valve status for store-Value,0,
IDE12596-MAS14804,Hydraulic test: load valve status for store-switches too infrequently,OK,
IDE12596-MAS14805,Hydraulic test: load valve status for store-switches too often,OK,
IDE12596-MAS14806,Hydraulic test: load valve status for store-switches too soon,OK,
IDE12596-MAS14807,Hydraulic test: load valve status for store-Switches too late,OK,
IDE12596-MAS14808,Hydraulic test: load valve status for store-does not switch at all,OK,
IDE12596-MAS14809,Hydraulic test: load valve status for store-switches implausibly during volume extraction,OK,
IDE12597-MAS02985,Hydraulic test: status of solenoid valve 6-Value,0,
IDE12597-MAS14810,Hydraulic test: status of solenoid valve 6-Sticks in pressure absent condition,OK,
IDE12597-MAS14811,Hydraulic test: status of solenoid valve 6-Sticks in pressure maintaining condition,OK,
IDE12598-MAS02985,Hydraulic test status of the ATF pump-Value,0,
IDE12598-MAS14812,Hydraulic test status of the ATF pump-Power output,OK,
IDE13197-IDE00024,Hydraulic test: reason for cancellation-Transmission fluid temperature,OK,
IDE13197-IDE11433,Hydraulic test: reason for cancellation-Status of magnet for park. lock.,OK,
IDE13197-MAS00362,Hydraulic test: reason for cancellation-Battery voltage,OK,
IDE13197-MAS00370,Hydraulic test: reason for cancellation-Vehicle speed,OK,
IDE13197-MAS00371,Hydraulic test: reason for cancellation-Engine speed,OK,
IDE13197-MAS01730,Hydraulic test: reason for cancellation-Pressure reduction,OK,
IDE13197-MAS03259,Hydraulic test: reason for cancellation-Pressure reservoir test,OK,
IDE13197-MAS05190,Hydraulic test: reason for cancellation-Parking brake or hand brake actuated,OK,
IDE13197-MAS05441,Hydraulic test: reason for cancellation-Selector lever in position P,OK,
IDE13197-MAS11577,Hydraulic test: reason for cancellation-Adaptation mode,OK,
IDE13197-MAS11730,Hydraulic test: reason for cancellation-Gear selector: Place in Neutral,OK,
IDE13197-MAS13382,Hydraulic test: reason for cancellation-Internal system status,OK,
IDE13197-MAS14719,Hydraulic test: reason for cancellation-Maximum time elapsed,OK,
IDE13197-MAS14794,Hydraulic test: reason for cancellation-ATF speed difference,OK,
IDE13197-MAS15617,Hydraulic test: reason for cancellation-Internal sensor malfunction,OK,
IDE13197-MAS15841,Hydraulic test: reason for cancellation-Flow deflection valve,OK,
IDE13197-MAS16121,Hydraulic test: reason for cancellation-Temperature difference between ATF and MTF,OK,
IDE13197-MAS16151,Hydraulic test: reason for cancellation-Valves flow release,OK,
IDE13197-MAS16153,Hydraulic test: reason for cancellation-Mobility of gear positioner,OK,
IDE13197-MAS16157,Hydraulic test: reason for cancellation-Parking lock function,OK,
IDE13327-IDE08627,Status internal sensors-Hydraulic pressure sensor 1,not OK,
IDE13327-MAS12272,Status internal sensors-Gear position distance sensor 1,not OK,
IDE13327-MAS12273,Status internal sensors-Gear position distance sensor 2,not OK,
IDE13327-MAS12274,Status internal sensors-Gear position distance sensor 3,not OK,
IDE13327-MAS12275,Status internal sensors-Gear position distance sensor 4,not OK,
IDE13327-MAS16154,Status internal sensors-Hydraulic pressure sensor 2,not OK,
IDE13327-MAS16155,Status internal sensors-Transmission fluid aux. hydraulic pump rotor position sensor,not OK,
IDE13327-MAS16156,Status internal sensors-Transmission fluid temperature sensor,not OK,
IDE13327-MAS16160,Status internal sensors-Drive position sensor,not OK,
IDE13327-MAS16161,Status internal sensors-Drive position sensor 2,not OK,
IDE13330-MAS12238,Valve flow deviation-Solenoid valve 1,OK,
IDE13330-MAS12239,Valve flow deviation-Solenoid valve 2,OK,
IDE13330-MAS12240,Valve flow deviation-Solenoid valve 3,OK,
IDE13330-MAS12241,Valve flow deviation-Solenoid valve 4,OK,
IDE13330-MAS12242,Valve flow deviation-Solenoid valve 5,OK,
IDE13330-MAS12243,Valve flow deviation-Solenoid valve 6,OK,
IDE13330-MAS12244,Valve flow deviation-Press.ctrl. valve 1,OK,
IDE13330-MAS12245,Valve flow deviation-Press.ctrl. valve 2,OK,
IDE13330-MAS12246,Valve flow deviation-Press.ctrl. valve 3,OK,
IDE13330-MAS12247,Valve flow deviation-Press.ctrl. valve 4,OK,
IDE13333,Solenoid valve 6: result of the hydraulic functional test,no error,
IDE80001-IDE00019,Analysis 1-Voltage terminal 30,7.6, V
IDE80001-IDE00021,Analysis 1-Engine speed,0.00, /min
IDE80001-IDE00023,Analysis 1-Transmission output speed,0, /min
IDE80001-IDE00026,Analysis 1-Vehicle speed from transmission,0.0, km/h
IDE80001-IDE00089,Analysis 1-Driving position,P,
IDE80001-IDE00100,Analysis 1-Engine torque,-26.00, Nm
IDE80001-IDE00856,Analysis 1-Clutch 2 upper adaptation point,Neutral,
IDE80001-IDE00866,Analysis 1-Specified torque clutch 1,-500.00, Nm
IDE80001-IDE00867,Analysis 1-Specified torque clutch 2,-500.00, Nm
IDE80001-IDE05990,Analysis 1-Pressure of clutch 2: specified value,0.0, bar
IDE80001-IDE05991,Analysis 1-Pressure of clutch 1: specified value,0.0, bar
IDE80001-IDE06658,Analysis 1-Pressure control valve 2: act. current,0.0, mA
IDE80001-IDE06659,Analysis 1-Pressure control valve 3: act. current,3.7, mA
IDE80001-IDE06660,Analysis 1-Pressure control valve 3: spec. current,0.0, mA
IDE80001-IDE06661,Analysis 1-Pressure control valve 2: spec. current,0.0, mA
IDE80001-IDE06662,Analysis 1-Pressure control valve 4: spec. current,0.0, mA
IDE80001-IDE06663,Analysis 1-Pressure control valve 4: act. current,-55.1, mA
IDE80001-IDE06668,Analysis 1-Pressure control valve 1: act. current,0.0, mA
IDE80001-IDE06669,Analysis 1-Pressure control valve 1: spec. current,0.0, mA
IDE80001-IDE09396,Analysis 1-Aux. hydraulic pump 1: actual RPM,0, /min
IDE80001-IDE09397,Analysis 1-Aux. hydraulic pump 1: spec. RPM,0, /min
IDE80001-IDE10177,Analysis 1-Transmission input speed sensor 1,0, /min
IDE80001-IDE10178,Analysis 1-Transmission input speed sensor 2,0, /min
IDE80001-IDE10469,Analysis 1-Clutch pressure: clutch 1,0.0, bar
IDE80001-IDE10470,Analysis 1-Clutch pressure: clutch 2,0.0, bar
IDE80001-IDE11143,Analysis 1-Sol. valve 1: act. current,1.8, mA
IDE80001-IDE11144,Analysis 1-Sol. valve 1: spec. current,0.0, mA
IDE80001-IDE11145,Analysis 1-Sol. valve 2: act. current,2.1, mA
IDE80001-IDE11146,Analysis 1-Sol. valve 2: spec. current,0.0, mA
IDE80001-IDE11147,Analysis 1-Sol. valve 3: act. current,1.4, mA
IDE80001-IDE11148,Analysis 1-Sol. valve 3: spec. current,0.0, mA
IDE80001-IDE11149,Analysis 1-Sol. valve 4: act. current,1.9, mA
IDE80001-IDE11150,Analysis 1-Sol. valve 4: spec. current,0.0, mA
IDE80001-IDE11159,Analysis 1-Gear selector dist. sensor 1: position,9.3, mm
IDE80001-IDE11160,Analysis 1-Gear selector dist. sensor 2: position,-9.4, mm
IDE80001-IDE11161,Analysis 1-Gear selector dist. sensor 3: position,-0.2, mm
IDE80001-IDE11162,Analysis 1-Gear selector dist. sensor 4: position,-0.1, mm
IDE80001-IDE11180,Analysis 1-Sol. valve 5: act. current,2.6, mA
IDE80001-IDE11181,Analysis 1-Sol. valve 5: spec. current,0.0, mA
IDE80001-IDE11182,Analysis 1-Sol. valve 6: act. current,0.0, mA
IDE80001-IDE11183,Analysis 1-Sol. valve 6: spec. current,0.0, mA
IDE80001-ENG129731,Analysis 1-Automatic_transmission_fluid_pump_phase_current,0, A
IDE80001-ENG130016,Analysis 1-Automatic_transmission_fluid_pump_phase_current_reference_value,0.0, A
IDE80001-ENG130015,Analysis 1-Automatic_transmission_fluid_pump_shunt_current,0.02, A
IDE80001-ENG129701,Analysis 1-Automatic_transmission_fluid_source_of_commanded_speed,ATF-Motor-Nachlauf,
IDE80001-ENG118442,Analysis 1-Clutch_0_actual_torque_hyb,0.00, Nm
IDE80001-ENG129961,Analysis 1-Clutch_0_commanded_pressure,0.0, bar
IDE80001-ENG118399,Analysis 1-Clutch_0_commanded_torque_hyb,0.00, Nm
IDE80001-ENG129966,Analysis 1-Clutch_actuation_substate,0,
IDE80001-ENG118401,Analysis 1-Combustion_engine_speed_hyb,0, /min
IDE80001-ENG130018,Analysis 1-Data State,Data available,
IDE80001-ENG129997,Analysis 1-Drive_position_sensor_value_neg,84.5, %
IDE80001-ENG129996,Analysis 1-Drive_position_sensor_value_pos,83.5, %
IDE80001-ENG130013,Analysis 1-Driving_strategy_accelerator_pedal_position_modified,0, %
IDE80001-ENG118434,Analysis 1-Driving_strategy_clutch0_main_state,Kupplung K0 ist offen,
IDE80001-ENG130012,Analysis 1-Driving_strategy_vehicle_coordinator_main_state,After-run,
IDE80001-ENG118348,Analysis 1-Electric_engine_torque_hyb,0.00, Nm
IDE80001-ENG118213,Analysis 1-Electrical_pump_3_for_transmission_actual_speed,0, /min
IDE80001-ENG118214,Analysis 1-Electrical_pump_3_for_transmission_commanded_speed,0, /min
IDE80001-ENG118400,Analysis 1-Electrical_pump_3_for_transmission_current,0.0, A
IDE80001-ENG114478,Analysis 1-Electrical_pump_3_for_transmission_phase_current,-63.0, A
IDE80001-ENG129980,Analysis 1-Gear_selector_13_state,Abschaltung Bereit,
IDE80001-ENG129983,Analysis 1-Gear_selector_2R_state,Abschaltung Bereit,
IDE80001-ENG129982,Analysis 1-Gear_selector_46_state,Abschaltung Bereit,
IDE80001-ENG129981,Analysis 1-Gear_selector_57_state,Abschaltung Bereit,
IDE80001-ENG130011,Analysis 1-KL15_state,OFF,
IDE80001-ENG05954,Analysis 1-Time_difference_before_storage_of_diagnostic_entry,170, ms
IDE80001-ENG129721,Analysis 1-Voltage_supply_1_for_sensors,5.0, V
IDE80001-ENG129722,Analysis 1-Voltage_supply_2_for_sensors,5.0, V
IDE80001-ENG129977,Analysis 1-Voltage_supply_3_for_sensors,5.0, V
IDE80001-ENG129978,Analysis 1-Voltage_supply_commanded_value,0.0, V
IDE80001-ENG129979,Analysis 1-Voltage_supply_speed_sensor,6.2, V
IDE80002-IDE00019,Analysis 2-Voltage terminal 30,7.6, V
IDE80002-IDE00021,Analysis 2-Engine speed,0.00, /min
IDE80002-IDE00023,Analysis 2-Transmission output speed,0, /min
IDE80002-IDE00026,Analysis 2-Vehicle speed from transmission,0.0, km/h
IDE80002-IDE00089,Analysis 2-Driving position,P,
IDE80002-IDE00100,Analysis 2-Engine torque,-26.00, Nm
IDE80002-IDE00856,Analysis 2-Clutch 2 upper adaptation point,Neutral,
IDE80002-IDE00866,Analysis 2-Specified torque clutch 1,-500.00, Nm
IDE80002-IDE00867,Analysis 2-Specified torque clutch 2,-500.00, Nm
IDE80002-IDE05990,Analysis 2-Pressure of clutch 2: specified value,0.0, bar
IDE80002-IDE05991,Analysis 2-Pressure of clutch 1: specified value,0.0, bar
IDE80002-IDE06658,Analysis 2-Pressure control valve 2: act. current,0.0, mA
IDE80002-IDE06659,Analysis 2-Pressure control valve 3: act. current,3.7, mA
IDE80002-IDE06660,Analysis 2-Pressure control valve 3: spec. current,0.0, mA
IDE80002-IDE06661,Analysis 2-Pressure control valve 2: spec. current,0.0, mA
IDE80002-IDE06662,Analysis 2-Pressure control valve 4: spec. current,0.0, mA
IDE80002-IDE06663,Analysis 2-Pressure control valve 4: act. current,-55.2, mA
IDE80002-IDE06668,Analysis 2-Pressure control valve 1: act. current,0.0, mA
IDE80002-IDE06669,Analysis 2-Pressure control valve 1: spec. current,0.0, mA
IDE80002-IDE09396,Analysis 2-Aux. hydraulic pump 1: actual RPM,6, /min
IDE80002-IDE09397,Analysis 2-Aux. hydraulic pump 1: spec. RPM,0, /min
IDE80002-IDE10177,Analysis 2-Transmission input speed sensor 1,0, /min
IDE80002-IDE10178,Analysis 2-Transmission input speed sensor 2,0, /min
IDE80002-IDE10469,Analysis 2-Clutch pressure: clutch 1,0.0, bar
IDE80002-IDE10470,Analysis 2-Clutch pressure: clutch 2,0.0, bar
IDE80002-IDE11143,Analysis 2-Sol. valve 1: act. current,1.8, mA
IDE80002-IDE11144,Analysis 2-Sol. valve 1: spec. current,0.0, mA
IDE80002-IDE11145,Analysis 2-Sol. valve 2: act. current,2.1, mA
IDE80002-IDE11146,Analysis 2-Sol. valve 2: spec. current,0.0, mA
IDE80002-IDE11147,Analysis 2-Sol. valve 3: act. current,1.4, mA
IDE80002-IDE11148,Analysis 2-Sol. valve 3: spec. current,0.0, mA
IDE80002-IDE11149,Analysis 2-Sol. valve 4: act. current,2.0, mA
IDE80002-IDE11150,Analysis 2-Sol. valve 4: spec. current,0.0, mA
IDE80002-IDE11159,Analysis 2-Gear selector dist. sensor 1: position,9.3, mm
IDE80002-IDE11160,Analysis 2-Gear selector dist. sensor 2: position,-9.4, mm
IDE80002-IDE11161,Analysis 2-Gear selector dist. sensor 3: position,-0.2, mm
IDE80002-IDE11162,Analysis 2-Gear selector dist. sensor 4: position,-0.1, mm
IDE80002-IDE11180,Analysis 2-Sol. valve 5: act. current,2.6, mA
IDE80002-IDE11181,Analysis 2-Sol. valve 5: spec. current,0.0, mA
IDE80002-IDE11182,Analysis 2-Sol. valve 6: act. current,0.0, mA
IDE80002-IDE11183,Analysis 2-Sol. valve 6: spec. current,0.0, mA
IDE80002-ENG129731,Analysis 2-Automatic_transmission_fluid_pump_phase_current,0, A
IDE80002-ENG130016,Analysis 2-Automatic_transmission_fluid_pump_phase_current_reference_value,0.0, A
IDE80002-ENG130015,Analysis 2-Automatic_transmission_fluid_pump_shunt_current,0.02, A
IDE80002-ENG129701,Analysis 2-Automatic_transmission_fluid_source_of_commanded_speed,ATF-Motor-Nachlauf,
IDE80002-ENG118442,Analysis 2-Clutch_0_actual_torque_hyb,0.00, Nm
IDE80002-ENG129961,Analysis 2-Clutch_0_commanded_pressure,0.0, bar
IDE80002-ENG118399,Analysis 2-Clutch_0_commanded_torque_hyb,0.00, Nm
IDE80002-ENG129966,Analysis 2-Clutch_actuation_substate,0,
IDE80002-ENG118401,Analysis 2-Combustion_engine_speed_hyb,0, /min
IDE80002-ENG130018,Analysis 2-Data State,Data available,
IDE80002-ENG129997,Analysis 2-Drive_position_sensor_value_neg,84.5, %
IDE80002-ENG129996,Analysis 2-Drive_position_sensor_value_pos,83.5, %
IDE80002-ENG130013,Analysis 2-Driving_strategy_accelerator_pedal_position_modified,0, %
IDE80002-ENG118434,Analysis 2-Driving_strategy_clutch0_main_state,Kupplung K0 ist offen,
IDE80002-ENG130012,Analysis 2-Driving_strategy_vehicle_coordinator_main_state,After-run,
IDE80002-ENG118348,Analysis 2-Electric_engine_torque_hyb,0.00, Nm
IDE80002-ENG118213,Analysis 2-Electrical_pump_3_for_transmission_actual_speed,0, /min
IDE80002-ENG118214,Analysis 2-Electrical_pump_3_for_transmission_commanded_speed,0, /min
IDE80002-ENG118400,Analysis 2-Electrical_pump_3_for_transmission_current,0.0, A
IDE80002-ENG114478,Analysis 2-Electrical_pump_3_for_transmission_phase_current,-63.0, A
IDE80002-ENG129980,Analysis 2-Gear_selector_13_state,Abschaltung Bereit,
IDE80002-ENG129983,Analysis 2-Gear_selector_2R_state,Abschaltung Bereit,
IDE80002-ENG129982,Analysis 2-Gear_selector_46_state,Abschaltung Bereit,
IDE80002-ENG129981,Analysis 2-Gear_selector_57_state,Abschaltung Bereit,
IDE80002-ENG130011,Analysis 2-KL15_state,OFF,
IDE80002-ENG05954,Analysis 2-Time_difference_before_storage_of_diagnostic_entry,130, ms
IDE80002-ENG129721,Analysis 2-Voltage_supply_1_for_sensors,5.0, V
IDE80002-ENG129722,Analysis 2-Voltage_supply_2_for_sensors,5.0, V
IDE80002-ENG129977,Analysis 2-Voltage_supply_3_for_sensors,5.0, V
IDE80002-ENG129978,Analysis 2-Voltage_supply_commanded_value,0.0, V
IDE80002-ENG129979,Analysis 2-Voltage_supply_speed_sensor,6.1, V
IDE80003-IDE00019,Analysis 3-Voltage terminal 30,7.6, V
IDE80003-IDE00021,Analysis 3-Engine speed,0.00, /min
IDE80003-IDE00023,Analysis 3-Transmission output speed,0, /min
IDE80003-IDE00026,Analysis 3-Vehicle speed from transmission,0.0, km/h
IDE80003-IDE00089,Analysis 3-Driving position,P,
IDE80003-IDE00100,Analysis 3-Engine torque,-26.00, Nm
IDE80003-IDE00856,Analysis 3-Clutch 2 upper adaptation point,Neutral,
IDE80003-IDE00866,Analysis 3-Specified torque clutch 1,-500.00, Nm
IDE80003-IDE00867,Analysis 3-Specified torque clutch 2,-500.00, Nm
IDE80003-IDE05990,Analysis 3-Pressure of clutch 2: specified value,0.0, bar
IDE80003-IDE05991,Analysis 3-Pressure of clutch 1: specified value,0.0, bar
IDE80003-IDE06658,Analysis 3-Pressure control valve 2: act. current,0.0, mA
IDE80003-IDE06659,Analysis 3-Pressure control valve 3: act. current,3.7, mA
IDE80003-IDE06660,Analysis 3-Pressure control valve 3: spec. current,0.0, mA
IDE80003-IDE06661,Analysis 3-Pressure control valve 2: spec. current,0.0, mA
IDE80003-IDE06662,Analysis 3-Pressure control valve 4: spec. current,0.0, mA
IDE80003-IDE06663,Analysis 3-Pressure control valve 4: act. current,-54.8, mA
IDE80003-IDE06668,Analysis 3-Pressure control valve 1: act. current,0.0, mA
IDE80003-IDE06669,Analysis 3-Pressure control valve 1: spec. current,0.0, mA
IDE80003-IDE09396,Analysis 3-Aux. hydraulic pump 1: actual RPM,6, /min
IDE80003-IDE09397,Analysis 3-Aux. hydraulic pump 1: spec. RPM,0, /min
IDE80003-IDE10177,Analysis 3-Transmission input speed sensor 1,0, /min
IDE80003-IDE10178,Analysis 3-Transmission input speed sensor 2,0, /min
IDE80003-IDE10469,Analysis 3-Clutch pressure: clutch 1,0.0, bar
IDE80003-IDE10470,Analysis 3-Clutch pressure: clutch 2,0.0, bar
IDE80003-IDE11143,Analysis 3-Sol. valve 1: act. current,1.7, mA
IDE80003-IDE11144,Analysis 3-Sol. valve 1: spec. current,0.0, mA
IDE80003-IDE11145,Analysis 3-Sol. valve 2: act. current,1.9, mA
IDE80003-IDE11146,Analysis 3-Sol. valve 2: spec. current,0.0, mA
IDE80003-IDE11147,Analysis 3-Sol. valve 3: act. current,1.4, mA
IDE80003-IDE11148,Analysis 3-Sol. valve 3: spec. current,0.0, mA
IDE80003-IDE11149,Analysis 3-Sol. valve 4: act. current,1.9, mA
IDE80003-IDE11150,Analysis 3-Sol. valve 4: spec. current,0.0, mA
IDE80003-IDE11159,Analysis 3-Gear selector dist. sensor 1: position,9.3, mm
IDE80003-IDE11160,Analysis 3-Gear selector dist. sensor 2: position,-9.4, mm
IDE80003-IDE11161,Analysis 3-Gear selector dist. sensor 3: position,-0.2, mm
IDE80003-IDE11162,Analysis 3-Gear selector dist. sensor 4: position,-0.1, mm
IDE80003-IDE11180,Analysis 3-Sol. valve 5: act. current,2.5, mA
IDE80003-IDE11181,Analysis 3-Sol. valve 5: spec. current,0.0, mA
IDE80003-IDE11182,Analysis 3-Sol. valve 6: act. current,0.0, mA
IDE80003-IDE11183,Analysis 3-Sol. valve 6: spec. current,0.0, mA
IDE80003-ENG129731,Analysis 3-Automatic_transmission_fluid_pump_phase_current,0, A
IDE80003-ENG130016,Analysis 3-Automatic_transmission_fluid_pump_phase_current_reference_value,0.0, A
IDE80003-ENG130015,Analysis 3-Automatic_transmission_fluid_pump_shunt_current,0.02, A
IDE80003-ENG129701,Analysis 3-Automatic_transmission_fluid_source_of_commanded_speed,ATF-Motor-Nachlauf,
IDE80003-ENG118442,Analysis 3-Clutch_0_actual_torque_hyb,0.00, Nm
IDE80003-ENG129961,Analysis 3-Clutch_0_commanded_pressure,0.0, bar
IDE80003-ENG118399,Analysis 3-Clutch_0_commanded_torque_hyb,0.00, Nm
IDE80003-ENG129966,Analysis 3-Clutch_actuation_substate,0,
IDE80003-ENG118401,Analysis 3-Combustion_engine_speed_hyb,0, /min
IDE80003-ENG130018,Analysis 3-Data State,Data available,
IDE80003-ENG129997,Analysis 3-Drive_position_sensor_value_neg,84.5, %
IDE80003-ENG129996,Analysis 3-Drive_position_sensor_value_pos,83.5, %
IDE80003-ENG130013,Analysis 3-Driving_strategy_accelerator_pedal_position_modified,0, %
IDE80003-ENG118434,Analysis 3-Driving_strategy_clutch0_main_state,Kupplung K0 ist offen,
IDE80003-ENG130012,Analysis 3-Driving_strategy_vehicle_coordinator_main_state,After-run,
IDE80003-ENG118348,Analysis 3-Electric_engine_torque_hyb,0.00, Nm
IDE80003-ENG118213,Analysis 3-Electrical_pump_3_for_transmission_actual_speed,0, /min
IDE80003-ENG118214,Analysis 3-Electrical_pump_3_for_transmission_commanded_speed,0, /min
IDE80003-ENG118400,Analysis 3-Electrical_pump_3_for_transmission_current,0.0, A
IDE80003-ENG114478,Analysis 3-Electrical_pump_3_for_transmission_phase_current,-63.0, A
IDE80003-ENG129980,Analysis 3-Gear_selector_13_state,Abschaltung Bereit,
IDE80003-ENG129983,Analysis 3-Gear_selector_2R_state,Abschaltung Bereit,
IDE80003-ENG129982,Analysis 3-Gear_selector_46_state,Abschaltung Bereit,
IDE80003-ENG129981,Analysis 3-Gear_selector_57_state,Abschaltung Bereit,
IDE80003-ENG130011,Analysis 3-KL15_state,OFF,
IDE80003-ENG05954,Analysis 3-Time_difference_before_storage_of_diagnostic_entry,90, ms
IDE80003-ENG129721,Analysis 3-Voltage_supply_1_for_sensors,5.0, V
IDE80003-ENG129722,Analysis 3-Voltage_supply_2_for_sensors,5.0, V
IDE80003-ENG129977,Analysis 3-Voltage_supply_3_for_sensors,5.0, V
IDE80003-ENG129978,Analysis 3-Voltage_supply_commanded_value,0.0, V
IDE80003-ENG129979,Analysis 3-Voltage_supply_speed_sensor,6.2, V
IDE80004-IDE00019,Analysis 4-Voltage terminal 30,7.6, V
IDE80004-IDE00021,Analysis 4-Engine speed,0.00, /min
IDE80004-IDE00023,Analysis 4-Transmission output speed,0, /min
IDE80004-IDE00026,Analysis 4-Vehicle speed from transmission,0.0, km/h
IDE80004-IDE00089,Analysis 4-Driving position,P,
IDE80004-IDE00100,Analysis 4-Engine torque,-26.00, Nm
IDE80004-IDE00856,Analysis 4-Clutch 2 upper adaptation point,Neutral,
IDE80004-IDE00866,Analysis 4-Specified torque clutch 1,-500.00, Nm
IDE80004-IDE00867,Analysis 4-Specified torque clutch 2,-500.00, Nm
IDE80004-IDE05990,Analysis 4-Pressure of clutch 2: specified value,0.0, bar
IDE80004-IDE05991,Analysis 4-Pressure of clutch 1: specified value,0.0, bar
IDE80004-IDE06658,Analysis 4-Pressure control valve 2: act. current,0.0, mA
IDE80004-IDE06659,Analysis 4-Pressure control valve 3: act. current,3.7, mA
IDE80004-IDE06660,Analysis 4-Pressure control valve 3: spec. current,0.0, mA
IDE80004-IDE06661,Analysis 4-Pressure control valve 2: spec. current,0.0, mA
IDE80004-IDE06662,Analysis 4-Pressure control valve 4: spec. current,0.0, mA
IDE80004-IDE06663,Analysis 4-Pressure control valve 4: act. current,-55.1, mA
IDE80004-IDE06668,Analysis 4-Pressure control valve 1: act. current,0.0, mA
IDE80004-IDE06669,Analysis 4-Pressure control valve 1: spec. current,0.0, mA
IDE80004-IDE09396,Analysis 4-Aux. hydraulic pump 1: actual RPM,65530, /min
IDE80004-IDE09397,Analysis 4-Aux. hydraulic pump 1: spec. RPM,0, /min
IDE80004-IDE10177,Analysis 4-Transmission input speed sensor 1,0, /min
IDE80004-IDE10178,Analysis 4-Transmission input speed sensor 2,0, /min
IDE80004-IDE10469,Analysis 4-Clutch pressure: clutch 1,0.0, bar
IDE80004-IDE10470,Analysis 4-Clutch pressure: clutch 2,0.0, bar
IDE80004-IDE11143,Analysis 4-Sol. valve 1: act. current,1.7, mA
IDE80004-IDE11144,Analysis 4-Sol. valve 1: spec. current,0.0, mA
IDE80004-IDE11145,Analysis 4-Sol. valve 2: act. current,2.0, mA
IDE80004-IDE11146,Analysis 4-Sol. valve 2: spec. current,0.0, mA
IDE80004-IDE11147,Analysis 4-Sol. valve 3: act. current,1.7, mA
IDE80004-IDE11148,Analysis 4-Sol. valve 3: spec. current,0.0, mA
IDE80004-IDE11149,Analysis 4-Sol. valve 4: act. current,1.7, mA
IDE80004-IDE11150,Analysis 4-Sol. valve 4: spec. current,0.0, mA
IDE80004-IDE11159,Analysis 4-Gear selector dist. sensor 1: position,9.3, mm
IDE80004-IDE11160,Analysis 4-Gear selector dist. sensor 2: position,-9.4, mm
IDE80004-IDE11161,Analysis 4-Gear selector dist. sensor 3: position,-0.2, mm
IDE80004-IDE11162,Analysis 4-Gear selector dist. sensor 4: position,-0.1, mm
IDE80004-IDE11180,Analysis 4-Sol. valve 5: act. current,2.6, mA
IDE80004-IDE11181,Analysis 4-Sol. valve 5: spec. current,0.0, mA
IDE80004-IDE11182,Analysis 4-Sol. valve 6: act. current,0.0, mA
IDE80004-IDE11183,Analysis 4-Sol. valve 6: spec. current,0.0, mA
IDE80004-ENG129731,Analysis 4-Automatic_transmission_fluid_pump_phase_current,0, A
IDE80004-ENG130016,Analysis 4-Automatic_transmission_fluid_pump_phase_current_reference_value,0.0, A
IDE80004-ENG130015,Analysis 4-Automatic_transmission_fluid_pump_shunt_current,0.02, A
IDE80004-ENG129701,Analysis 4-Automatic_transmission_fluid_source_of_commanded_speed,ATF-Motor-Nachlauf,
IDE80004-ENG118442,Analysis 4-Clutch_0_actual_torque_hyb,0.00, Nm
IDE80004-ENG129961,Analysis 4-Clutch_0_commanded_pressure,0.0, bar
IDE80004-ENG118399,Analysis 4-Clutch_0_commanded_torque_hyb,0.00, Nm
IDE80004-ENG129966,Analysis 4-Clutch_actuation_substate,0,
IDE80004-ENG118401,Analysis 4-Combustion_engine_speed_hyb,0, /min
IDE80004-ENG130018,Analysis 4-Data State,Data available,
IDE80004-ENG129997,Analysis 4-Drive_position_sensor_value_neg,84.5, %
IDE80004-ENG129996,Analysis 4-Drive_position_sensor_value_pos,83.5, %
IDE80004-ENG130013,Analysis 4-Driving_strategy_accelerator_pedal_position_modified,0, %
IDE80004-ENG118434,Analysis 4-Driving_strategy_clutch0_main_state,Kupplung K0 ist offen,
IDE80004-ENG130012,Analysis 4-Driving_strategy_vehicle_coordinator_main_state,After-run,
IDE80004-ENG118348,Analysis 4-Electric_engine_torque_hyb,0.00, Nm
IDE80004-ENG118213,Analysis 4-Electrical_pump_3_for_transmission_actual_speed,0, /min
IDE80004-ENG118214,Analysis 4-Electrical_pump_3_for_transmission_commanded_speed,0, /min
IDE80004-ENG118400,Analysis 4-Electrical_pump_3_for_transmission_current,0.0, A
IDE80004-ENG114478,Analysis 4-Electrical_pump_3_for_transmission_phase_current,-63.0, A
IDE80004-ENG129980,Analysis 4-Gear_selector_13_state,Abschaltung Bereit,
IDE80004-ENG129983,Analysis 4-Gear_selector_2R_state,Abschaltung Bereit,
IDE80004-ENG129982,Analysis 4-Gear_selector_46_state,Abschaltung Bereit,
IDE80004-ENG129981,Analysis 4-Gear_selector_57_state,Abschaltung Bereit,
IDE80004-ENG130011,Analysis 4-KL15_state,OFF,
IDE80004-ENG05954,Analysis 4-Time_difference_before_storage_of_diagnostic_entry,50, ms
IDE80004-ENG129721,Analysis 4-Voltage_supply_1_for_sensors,5.0, V
IDE80004-ENG129722,Analysis 4-Voltage_supply_2_for_sensors,5.0, V
IDE80004-ENG129977,Analysis 4-Voltage_supply_3_for_sensors,5.0, V
IDE80004-ENG129978,Analysis 4-Voltage_supply_commanded_value,0.0, V
IDE80004-ENG129979,Analysis 4-Voltage_supply_speed_sensor,6.1, V
IDE80005-IDE00019,Analysis 5-Voltage terminal 30,7.6, V
IDE80005-IDE00021,Analysis 5-Engine speed,0.00, /min
IDE80005-IDE00023,Analysis 5-Transmission output speed,0, /min
IDE80005-IDE00026,Analysis 5-Vehicle speed from transmission,0.0, km/h
IDE80005-IDE00089,Analysis 5-Driving position,P,
IDE80005-IDE00100,Analysis 5-Engine torque,-26.00, Nm
IDE80005-IDE00856,Analysis 5-Clutch 2 upper adaptation point,Neutral,
IDE80005-IDE00866,Analysis 5-Specified torque clutch 1,-500.00, Nm
IDE80005-IDE00867,Analysis 5-Specified torque clutch 2,-500.00, Nm
IDE80005-IDE05990,Analysis 5-Pressure of clutch 2: specified value,0.0, bar
IDE80005-IDE05991,Analysis 5-Pressure of clutch 1: specified value,0.0, bar
IDE80005-IDE06658,Analysis 5-Pressure control valve 2: act. current,0.0, mA
IDE80005-IDE06659,Analysis 5-Pressure control valve 3: act. current,3.7, mA
IDE80005-IDE06660,Analysis 5-Pressure control valve 3: spec. current,0.0, mA
IDE80005-IDE06661,Analysis 5-Pressure control valve 2: spec. current,0.0, mA
IDE80005-IDE06662,Analysis 5-Pressure control valve 4: spec. current,0.0, mA
IDE80005-IDE06663,Analysis 5-Pressure control valve 4: act. current,-54.5, mA
IDE80005-IDE06668,Analysis 5-Pressure control valve 1: act. current,0.0, mA
IDE80005-IDE06669,Analysis 5-Pressure control valve 1: spec. current,0.0, mA
IDE80005-IDE09396,Analysis 5-Aux. hydraulic pump 1: actual RPM,65530, /min
IDE80005-IDE09397,Analysis 5-Aux. hydraulic pump 1: spec. RPM,0, /min
IDE80005-IDE10177,Analysis 5-Transmission input speed sensor 1,0, /min
IDE80005-IDE10178,Analysis 5-Transmission input speed sensor 2,0, /min
IDE80005-IDE10469,Analysis 5-Clutch pressure: clutch 1,0.0, bar
IDE80005-IDE10470,Analysis 5-Clutch pressure: clutch 2,0.0, bar
IDE80005-IDE11143,Analysis 5-Sol. valve 1: act. current,1.4, mA
IDE80005-IDE11144,Analysis 5-Sol. valve 1: spec. current,0.0, mA
IDE80005-IDE11145,Analysis 5-Sol. valve 2: act. current,2.0, mA
IDE80005-IDE11146,Analysis 5-Sol. valve 2: spec. current,0.0, mA
IDE80005-IDE11147,Analysis 5-Sol. valve 3: act. current,1.3, mA
IDE80005-IDE11148,Analysis 5-Sol. valve 3: spec. current,0.0, mA
IDE80005-IDE11149,Analysis 5-Sol. valve 4: act. current,2.0, mA
IDE80005-IDE11150,Analysis 5-Sol. valve 4: spec. current,0.0, mA
IDE80005-IDE11159,Analysis 5-Gear selector dist. sensor 1: position,9.3, mm
IDE80005-IDE11160,Analysis 5-Gear selector dist. sensor 2: position,-9.4, mm
IDE80005-IDE11161,Analysis 5-Gear selector dist. sensor 3: position,-0.2, mm
IDE80005-IDE11162,Analysis 5-Gear selector dist. sensor 4: position,-0.1, mm
IDE80005-IDE11180,Analysis 5-Sol. valve 5: act. current,2.6, mA
IDE80005-IDE11181,Analysis 5-Sol. valve 5: spec. current,0.0, mA
IDE80005-IDE11182,Analysis 5-Sol. valve 6: act. current,0.0, mA
IDE80005-IDE11183,Analysis 5-Sol. valve 6: spec. current,0.0, mA
IDE80005-ENG129731,Analysis 5-Automatic_transmission_fluid_pump_phase_current,0, A
IDE80005-ENG130016,Analysis 5-Automatic_transmission_fluid_pump_phase_current_reference_value,0.0, A
IDE80005-ENG130015,Analysis 5-Automatic_transmission_fluid_pump_shunt_current,0.02, A
IDE80005-ENG129701,Analysis 5-Automatic_transmission_fluid_source_of_commanded_speed,ATF-Motor-Nachlauf,
IDE80005-ENG118442,Analysis 5-Clutch_0_actual_torque_hyb,0.00, Nm
IDE80005-ENG129961,Analysis 5-Clutch_0_commanded_pressure,0.0, bar
IDE80005-ENG118399,Analysis 5-Clutch_0_commanded_torque_hyb,0.00, Nm
IDE80005-ENG129966,Analysis 5-Clutch_actuation_substate,0,
IDE80005-ENG118401,Analysis 5-Combustion_engine_speed_hyb,0, /min
IDE80005-ENG130018,Analysis 5-Data State,Data available,
IDE80005-ENG129997,Analysis 5-Drive_position_sensor_value_neg,84.5, %
IDE80005-ENG129996,Analysis 5-Drive_position_sensor_value_pos,83.5, %
IDE80005-ENG130013,Analysis 5-Driving_strategy_accelerator_pedal_position_modified,0, %
IDE80005-ENG118434,Analysis 5-Driving_strategy_clutch0_main_state,Kupplung K0 ist offen,
IDE80005-ENG130012,Analysis 5-Driving_strategy_vehicle_coordinator_main_state,After-run,
IDE80005-ENG118348,Analysis 5-Electric_engine_torque_hyb,0.00, Nm
IDE80005-ENG118213,Analysis 5-Electrical_pump_3_for_transmission_actual_speed,0, /min
IDE80005-ENG118214,Analysis 5-Electrical_pump_3_for_transmission_commanded_speed,0, /min
IDE80005-ENG118400,Analysis 5-Electrical_pump_3_for_transmission_current,0.0, A
IDE80005-ENG114478,Analysis 5-Electrical_pump_3_for_transmission_phase_current,-63.0, A
IDE80005-ENG129980,Analysis 5-Gear_selector_13_state,Abschaltung Bereit,
IDE80005-ENG129983,Analysis 5-Gear_selector_2R_state,Abschaltung Bereit,
IDE80005-ENG129982,Analysis 5-Gear_selector_46_state,Abschaltung Bereit,
IDE80005-ENG129981,Analysis 5-Gear_selector_57_state,Abschaltung Bereit,
IDE80005-ENG130011,Analysis 5-KL15_state,OFF,
IDE80005-ENG05954,Analysis 5-Time_difference_before_storage_of_diagnostic_entry,10, ms
IDE80005-ENG129721,Analysis 5-Voltage_supply_1_for_sensors,5.0, V
IDE80005-ENG129722,Analysis 5-Voltage_supply_2_for_sensors,5.0, V
IDE80005-ENG129977,Analysis 5-Voltage_supply_3_for_sensors,5.0, V
IDE80005-ENG129978,Analysis 5-Voltage_supply_commanded_value,0.0, V
IDE80005-ENG129979,Analysis 5-Voltage_supply_speed_sensor,6.1, V
IDE80006,Analysis 6,B1 98 79 09 E5 75 95 93 6B 25 CC D2 8F 19 EC 8C F5 62 E5 C3 91 0B EB 8C 6A A3 84 C1 A9 3F DA 42 80 89 C7 2C 6E DC 29 45 A6 ED 82 5C 66 D8 2B 44 26 AD A2 4C DB 71 88 47 A7 6D C2 7C 76 D0 2F 46 27 2D E2 6C 0E EC 31 49 05 4B A6 9C 06 E8 33 48 20 AE 23 8C 1E E4 35 4B A1 6E 43 BC B3 45 92 4A 21 2E 63 AC 2E FC 39 4D A2 EF 83 DC 26 F8 3B 4C 87 0A 06 CC 3E F4 3D 4F A3 6F C3 FC 36 F0 3F 4E 23 2F E3 EC 6B 29 A4 51 AC E8 00 1D C6 88 03 50 2C A8 20 0D DE 84 05 53 69 E9 85 01,
MAS00156-ENG98502,Driving direction-Data,not recognized,
ENG00803,A004_Notfahren_NAnHS,0, /min
ENG00804-ENG98502,A014_NAnHS-Data,0, /min
ENG00805-ENG98502,A015_NAnHSKD-Data,10000, /min
ENG00806-ENG98502,A016_NAnHSKF-Data,0, /min
ENG00807-ENG98502,A017_NAnHSMin-Data,0, /min
ENG00808-ENG98502,A018_NAnRS-Data,0, /min
ENG00809-ENG98502,A019_NAnRSKF-Data,0, /min
ENG00810-ENG98502,A020_NAnRSMin-Data,0, /min
ENG00811-ENG98502,A022_NAnSchalt-Data,0, /min
ENG00812-ENG98502,A023_Bergab_NAnRSMin-Data,0, /min
ENG00813-ENG98502,A024_Bergab_NAnHSMin-Data,0, /min
ENG105000,A028_Svc_NMotLLSoll,800, /min
ENG38833-ENG98502,Ak0a_EepromData_PK0_Ist_PKP1-Data,6.500, bar
ENG38834-ENG98502,Ak0a_EepromData_PK0_Soll_PKP1-Data,6.500, bar
ENG38835-ENG98502,Ak0a_PSoll_PKP1_Roh-Data,6.500, bar
ENG38836-ENG98502,Ak0k_EepromData_PK0_Ist_PKP0-Data,4.100, bar
ENG38837-ENG98502,Ak0k_EepromData_PK0_Soll_PKP0-Data,4.200, bar
ENG38838-ENG98502,Ak0k_PSoll_PKP0_Norm-Data,4.200, bar
ENG08715-ENG98502,Ambient_air_pressure_during_adaption-Data,0.955, bar
ENG08716-ENG98502,Ambient_air_pressure_value-Data,0.955, bar
ENG129684-ENG130027,Atf_angle_sensor_error_code_of_adaption-Atf adaption Error Code,no error,
ENG129683-ENG98502,Atf_angle_sensor_state_of_adaption-Data,(0) Kal nicht aktiv,
ENG05873-ENG115659,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-y0,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG99777,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y1,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG115668,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-y10,69 AC 93 7D 57 32 20 7F 07 B6 9B 81 51 18 0B 01 00 00 00 00,
ENG05873-ENG05915,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y11,75 B3 9A 7D 57 32 20 7F 06 B8 9D 7F 51 19 0D 01 00 00 00 00,
ENG05873-ENG05916,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y12,7E AF 96 7D 57 33 22 56 16 B0 96 7E 50 16 0D 01 00 00 00 00,
ENG05873-ENG05917,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y13,86 C1 A8 7D 57 35 23 06 FF BF A6 7D 4D 10 05 01 00 00 00 00,
ENG05873-ENG05918,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y14,8D FA AF 7D 57 36 25 80 FF EB B1 79 49 1E 10 01 00 00 00 00,
ENG05873-ENG05919,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y15,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG05920,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y16,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG05921,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y17,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG05922,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y18,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG05923,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y19,00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 01 00 00 00 00,
ENG05873-ENG100480,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y2,1E A6 8D 7D 57 32 1F 00 FF FF D8 C1 94 56 29 01 00 00 00 00,
ENG05873-ENG100773,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y3,22 A5 8C 7D 57 32 1F 02 FF FD D3 BD 90 51 22 01 00 00 00 00,
ENG05873-ENG100631,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y4,30 B0 97 7D 57 32 1F 19 FF DC BC A1 76 2E 14 01 00 00 00 00,
ENG05873-ENG102174,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y5,38 B8 9F 7D 57 32 1F 3A FF CD B2 90 64 22 0F 01 00 00 00 00,
ENG05873-ENG113993,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-Y6,44 AF 96 7D 57 32 1F 5C 0A BE A1 87 5B 1F 0E 01 00 00 00 00,
ENG05873-ENG115665,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-y7,4A A8 8F 7D 57 32 1F 7F 09 BE A8 91 62 23 11 01 00 00 00 00,
ENG05873-ENG115666,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-y8,54 A9 90 7D 57 32 1F 7F 08 BE A3 8C 5D 22 12 01 00 00 00 00,
ENG05873-ENG115667,Automatic_transmission_fluid_pump_adaption_eeprom_raw_values-y9,5E AF 96 7D 57 32 1F 7F 48 BC A3 86 58 19 0B 01 00 00 00 00,
ENG129686-ENG98502,Automatic_transmission_fluid_pump_adaption_state-Data,Init,
ENG129691,Automatic_transmission_fluid_pump_atic_current_limitation,32896,
ENG129695,Automatic_transmission_fluid_pump_atic_device_state,56814,
ENG129720,Automatic_transmission_fluid_pump_atic_diagnose_aux_state,0,
ENG129689,Automatic_transmission_fluid_pump_atic_diagnose_state,0,
ENG129690,Automatic_transmission_fluid_pump_atic_hardware_state,61456,
ENG129719,Automatic_transmission_fluid_pump_atic_offstate_diagnose,0,
ENG129692,Automatic_transmission_fluid_pump_atic_onstate_diagnose,0,
ENG08700,Automatic_transmission_fluid_pump_commanded_phase_current,4, A
ENG08701-ENG98502,Automatic_transmission_fluid_pump_commanded_voltage-Data,3.7, V
ENG08714-ENG98502,Automatic_transmission_fluid_pump_commutation_angle-Data,3.8, °
ENG129699-ENG98502,Automatic_transmission_fluid_pump_cos_voltage_value-Data,2.133, V
ENG08697,Automatic_transmission_fluid_pump_current_limitation_counter,0,
ENG129687-ENG130032,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Abbruchtimer,No,
ENG129687-ENG130029,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Akustikzustand,No,
ENG129687-ENG130039,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Drehzahlabweichung,No,
ENG129687-ENG99021,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Insuff. voltage,No,
ENG129687-ENG130030,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Kuehlung,No,
ENG129687-ENG129443,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Maxdrehzahl,No,
ENG129687-ENG130035,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Maxstrom,No,
ENG129687-ENG09326,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Minstrom,No,
ENG129687-ENG130038,Automatic_transmission_fluid_pump_error_code_of_current_adaption-MittenTempBereich,No,
ENG129687-ENG130033,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Monotonie,No,
ENG129687-ENG09327,Automatic_transmission_fluid_pump_error_code_of_current_adaption-SollwertQuelle,No,
ENG129687-ENG130034,Automatic_transmission_fluid_pump_error_code_of_current_adaption-Stromabweichung,No,
ENG129687-ENG130028,Automatic_transmission_fluid_pump_error_code_of_current_adaption-TBereich,No,
ENG129687-ENG130036,Automatic_transmission_fluid_pump_error_code_of_current_adaption-TMin,No,
ENG129687-ENG130037,Automatic_transmission_fluid_pump_error_code_of_current_adaption-UIntegral,No,
ENG129687-ENG130031,Automatic_transmission_fluid_pump_error_code_of_current_adaption-V_Motor_Start,No,
ENG08713,Automatic_transmission_fluid_pump_limited_phase_current,60, A
ENG129688-ENG98502,Automatic_transmission_fluid_pump_max_permissible_voltage-Data,14.406, V
ENG08698-ENG98502,Automatic_transmission_fluid_pump_modulation_commanded_speed-Data,1000, /min
ENG129731,Automatic_transmission_fluid_pump_phase_current,4, A
ENG08699-ENG98502,Automatic_transmission_fluid_pump_scaling_factor-Data,0.26,
ENG129698-ENG98502,Automatic_transmission_fluid_pump_sin_voltage_value-Data,3.319, V
ENG129696-ENG98502,Automatic_transmission_fluid_pump_unit_circle_diagnose_value-Data,-100, %
ENG129697-ENG98502,Automatic_transmission_fluid_pump_unit_circle_sensor_value-Data,1.143,
ENG129701,Automatic_transmission_fluid_source_of_commanded_speed,SP Laden Notdrehzahl,
ENG05872-ENG05929,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_adaption,172, min
ENG05872-ENG05931,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_ATF_filtering,13739, min
ENG05872-ENG05926,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_cooling,7187, min
ENG05872-ENG05928,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_cooling_request,0, min
ENG05872-ENG05933,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_none,1670, min
ENG05872-ENG05924,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_others,8, min
ENG05872-ENG05932,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_partial_accumulator,89, min
ENG05872-ENG05930,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_pressure accumulator_special_forced_speed,905, min
ENG05872-ENG05925,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_pressure_accumulator,5839, min
ENG05872-ENG05927,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_test,8625, min
ENG05872-ENG05934,Automatic_transmission_fluid_source_of_commanded_time-Automatic_transmission_fluid_source_of_commanded_time_WDE_control,42, min
ENG101413,Calibration Identification,80A155AJ00011   ,
ENG99697,Calibration Verification Number,9F DB 41 84,
ENG129678-ENG129945,CAN_messages_reception_state-State Dashboard received,received,
ENG129678-ENG101987,CAN_messages_reception_state-State ECM received,received,
ENG129678-ENG102056,CAN_messages_reception_state-State ESP received,received,
ENG129678-ENG103751,CAN_messages_reception_state-State Gateway received,received,
ENG129678-ENG104211,CAN_messages_reception_state-State Parking Brake received,received,
ENG129678-ENG101883,CAN_messages_reception_state-State Steering Angle received,received,
ENG129678-ENG102283,CAN_messages_reception_state-State Steering Assist received,received,
ENG08723-ENG98502,Clutch_1_absolute_pressure_value-Data,1.0, bar
ENG129681-ENG98502,Clutch_1_actual_pressure_raw_value-Data,1.0, bar
ENG08721,Clutch_1_adaption_temperature_range,4,
ENG08703-ENG98502,Clutch_1_filtered_absolute_pressure_during_adaption-Data,0.040, bar
ENG08695-ENG98502,Clutch_1_pressure_offset_adapted_value-Data,0.038, bar
ENG08717,Clutch_1_pressure_signal_quality,valid,
ENG08724-ENG98502,Clutch_2_absolute_pressure_value-Data,1.0, bar
ENG129682-ENG98502,Clutch_2_actual_pressure_raw_value-Data,1.0, bar
ENG08722,Clutch_2_adaption_temperature_range,4,
ENG08704-ENG98502,Clutch_2_filtered_absolute_pressure_during_adaption-Data,0.003, bar
ENG08696-ENG98502,Clutch_2_pressure_offset_adapted_adaption-Data,0.006, bar
ENG08718,Clutch_2_pressure_signal_quality,valid,
ENG129743-ENG98502,Clutch_temperature_calculated-Data,70, °C
ENG103018-ENG57629,Current Test Routine-Routine ID,Unknown (0),
ENG105740-ENG98502,D004_Svu_UChs2-Data,14.3, V
ENG105741-ENG98502,D005_Svu_UChs3-Data,14.4, V
ENG105742-ENG98502,D009_Svu_UChs1-Data,14.4, V
ENG05909,Drive_limiter_cause_safety_controller,0,
ENG05905,Drive_limiter_cause_signal_plausi,keine Fehler,
ENG05911,Drive_limiter_sopc_warning_level,0,
ENG26670-ENG30927,Drive_position_sensor_1_cause_of_failure-Drive_position_sensor_1_short_circuit_error_active,No,
ENG26670-ENG30928,Drive_position_sensor_1_cause_of_failure-Drive_position_sensor_1_src_error_active,No,
ENG26670-ENG30929,Drive_position_sensor_1_cause_of_failure-Drive_position_sensor_1_timing_error_active,No,
ENG26670-ENG98891,Drive_position_sensor_1_cause_of_failure-Reserved,-1,
ENG26671,Drive_position_sensor_1_high_level,305950,
ENG26672,Drive_position_sensor_1_interrupt,595005,
ENG26673,Drive_position_sensor_1_low_level,1627125,
ENG26674,Drive_position_sensor_1_sensor_state,3,
ENG26675-ENG98502,Drive_position_sensor_1_signal_quality-Data,gueltig,
ENG57616-ENG98502,Drive_position_sensor_1_value-Data,84.0, %
ENG26676-ENG30930,Drive_position_sensor_2_cause_of_failure-Drive_position_sensor_2_short_circuit_error_active,No,
ENG26676-ENG30931,Drive_position_sensor_2_cause_of_failure-Drive_position_sensor_2_src_error_active,No,
ENG26676-ENG30932,Drive_position_sensor_2_cause_of_failure-Drive_position_sensor_2_timing_error_active,No,
ENG26676-ENG98891,Drive_position_sensor_2_cause_of_failure-Reserved,-1,
ENG26677,Drive_position_sensor_2_high_level,1646350,
ENG26678,Drive_position_sensor_2_interrupt,592166,
ENG26679,Drive_position_sensor_2_low_level,297275,
ENG26680,Drive_position_sensor_2_sensor_state,3,
ENG26681-ENG98502,Drive_position_sensor_2_signal_quality-Data,gueltig,
ENG57617-ENG98502,Drive_position_sensor_2_value-Data,85.0, %
ENG06619-ENG102678,Drive_position_sensor_calculated_positions-Kalibrier Position D,0.00, %
ENG06619-ENG100378,Drive_position_sensor_calculated_positions-Kalibrier Position N,0.00, %
ENG06619-ENG103389,Drive_position_sensor_calculated_positions-Kalibrier Position P,0.00, %
ENG06619-ENG103160,Drive_position_sensor_calculated_positions-Kalibrier Position R,0.00, %
ENG06628-ENG98502,Drive_position_sensor_calibrated_range_D_minimum-Data,10.00, %
ENG06627-ENG98502,Drive_position_sensor_calibrated_range_ND-Data,33.00, %
ENG06624-ENG98502,Drive_position_sensor_calibrated_range_P_maximum-Data,90.00, %
ENG06625-ENG98502,Drive_position_sensor_calibrated_range_PR-Data,67.00, %
ENG06626-ENG98502,Drive_position_sensor_calibrated_range_RN-Data,47.00, %
ENG06618,Drive_position_sensor_calibration_saved_state,170,
ENG105999-ENG98502,E003_Akk_PKupAkt_PKp0[K1]-Data,2.758, bar
ENG106000-ENG98502,E004_Akk_PKupAkt_PKp0[K2]-Data,3.093, bar
ENG106006-ENG98502,E012_Akm_kl[K1].PKp0-Data,2.273, bar
ENG106007-ENG98502,E013_Akm_kl[k2].PKp0-Data,1.595, bar
ENG106008-ENG98502,E016_AkkEeprom.PKp0[K1]-Data,2.854, bar
ENG106009-ENG98502,E017_AkkEeprom.PKp0[K2]-Data,3.165, bar
ENG106010-ENG98502,E018_Akm_Eeprom.PKp1[K1]-Data,13.176, bar
ENG106011-ENG98502,E019_Akm_Eeprom.PKp1[K2]-Data,12.904, bar
ENG106014-ENG98502,E024_Akk_EEProm_Pakt.Pkupakt[K1]-Data,2.758, bar
ENG106015-ENG98502,E025_Akk_EEProm_Pakt.Pkupakt[K2]-Data,3.093, bar
ENG125929,ECU_R,04 00 09 05 02 00 BE E2 34 08 00 10 D0 01 4C FC B8 37 93 FC,
ENG125930,ECU_ST,00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG100152,ECUNAME,-,
ENG100152-ENG28381,ECUNAME-Acronym,TCM-TransmisCtrl,
ENG100152,ECUNAME,TransmisCtrl,
ENG26777,ESP_Wheel_circumference,2251,
ENG103533-ENG98502,F004_Mmr_MMotEingriffDomina-Data,1600.00, Nm
ENG00839-ENG98502,F006_MLastHS-Data,97, Nm
ENG00840-ENG98502,F007_MLastRS-Data,40, Nm
ENG106462-ENG98502,F008_UmwMAbtrieb-Data,0, Nm
ENG105256,Front left wheel speed,0.0, km/h
ENG105255,Front right wheel speed,0.0, km/h
ENG106736-ENG104204,G016_Aop_TempAdapt_ka / Aop_POffsetAdapt_kl[K1]/[K2]-SS_1,-15, °C
ENG106736-ENG101895,G016_Aop_TempAdapt_ka / Aop_POffsetAdapt_kl[K1]/[K2]-SS_2,5, °C
ENG106736-ENG100724,G016_Aop_TempAdapt_ka / Aop_POffsetAdapt_kl[K1]/[K2]-SS_3,25, °C
ENG106736-ENG103268,G016_Aop_TempAdapt_ka / Aop_POffsetAdapt_kl[K1]/[K2]-SS_4,45, °C
ENG106736-ENG102350,G016_Aop_TempAdapt_ka / Aop_POffsetAdapt_kl[K1]/[K2]-SS_5,65, °C
ENG106736-ENG103362,G016_Aop_TempAdapt_ka / Aop_POffsetAdapt_kl[K1]/[K2]-SS_6,85, °C
ENG106736-ENG99474,G016_Aop_TempAdapt_ka / Aop_POffsetAdapt_kl[K1]/[K2]-SS_7,105, °C
ENG106736-ENG101681,G016_Aop_TempAdapt_ka / Aop_POffsetAdapt_kl[K1]/[K2]-SS_8,125, °C
ENG08705-ENG98502,Gear_1_synchron_speed-Data,0, /min
ENG08706-ENG98502,Gear_2_synchron_speed-Data,0, /min
ENG08707-ENG98502,Gear_3_synchron_speed-Data,0, /min
ENG08708-ENG98502,Gear_4_synchron_speed-Data,0, /min
ENG08709-ENG98502,Gear_5_synchron_speed-Data,0, /min
ENG08710-ENG98502,Gear_6_synchron_speed-Data,0, /min
ENG08711-ENG98502,Gear_7_synchron_speed-Data,0, /min
ENG08712-ENG98502,Gear_R_synchron_speed-Data,0, /min
ENG06638,Gear_selector_1_commanded_distance,9.2, mm
ENG06632,Gear_selector_1_flag_position_control_active,OFF,
ENG06636-ENG98502,Gear_selector_1_offset_to_nominal_position-Data,0.14, mm
ENG06620,Gear_selector_1_state,Eingelegt (Pos),
ENG06629,Gear_selector_2_commanded_distance,-9.4, mm
ENG06633,Gear_selector_2_flag_position_control_active,OFF,
ENG06637-ENG98502,Gear_selector_2_offset_to_nominal_position-Data,-0.11, mm
ENG06621,Gear_selector_2_state,Eingelegt (Pos),
ENG06630,Gear_selector_3_commanded_distance,-0.3, mm
ENG06634,Gear_selector_3_flag_position_control_active,OFF,
ENG06640-ENG98502,Gear_selector_3_offset_to_nominal_position-Data,0.08, mm
ENG06623,Gear_selector_3_state,Standby,
ENG06631,Gear_selector_4_commanded_distance,-0.4, mm
ENG06635,Gear_selector_4_flag_position_control_active,OFF,
ENG06639-ENG98502,Gear_selector_4_offset_to_nominal_position-Data,0.29, mm
ENG06622,Gear_selector_4_state,Standby,
ENG05869,Gear_selector_basic_calibration_type,drehend,
ENG05870,Gear_selector_basic_calibration_validity,valid,
ENG08702-ENG09320,Gear_selector_calibration_state-GrdGs_EepromData.val.Sonstiges.Daten_EPA_gueltig,valid,
ENG08702-ENG09321,Gear_selector_calibration_state-GrdGs_EepromData.val.Sonstiges.Daten_SyncPos_ermittelt,gemessen,
ENG08702-ENG09322,Gear_selector_calibration_state-GrdGs_EepromData.val.Sonstiges.Daten_TG1_Endl_gueltig,valid,
ENG08702-ENG09323,Gear_selector_calibration_state-GrdGs_EepromData.val.Sonstiges.Daten_TG1_Sync_gueltig,valid,
ENG08702-ENG09324,Gear_selector_calibration_state-GrdGs_EepromData.val.Sonstiges.Daten_TG2_Endl_gueltig,valid,
ENG08702-ENG09325,Gear_selector_calibration_state-GrdGs_EepromData.val.Sonstiges.Daten_TG2_Sync_gueltig,valid,
ENG08702-ENG09319,Gear_selector_calibration_state-GrdGs_EepromData.val.Sonstiges.DatenGRDgueltig,valid,
ENG08702-ENG98891,Gear_selector_calibration_state-Reserved,NOT-DEFINED,
ENG05871-ENG115659,Gear_selector_synchronization_adaption_start_pressure_correction_factor-y0,6B 68 61 6B,
ENG05871-ENG99777,Gear_selector_synchronization_adaption_start_pressure_correction_factor-Y1,65 58 6E 6A,
ENG05871-ENG100480,Gear_selector_synchronization_adaption_start_pressure_correction_factor-Y2,5D 49 3F 5D,
ENG05871-ENG100773,Gear_selector_synchronization_adaption_start_pressure_correction_factor-Y3,4B 4A 51 5A,
ENG05871-ENG100631,Gear_selector_synchronization_adaption_start_pressure_correction_factor-Y4,5C 4C 52 5C,
ENG05871-ENG102174,Gear_selector_synchronization_adaption_start_pressure_correction_factor-Y5,63 5A 67 63,
ENG05871-ENG113993,Gear_selector_synchronization_adaption_start_pressure_correction_factor-Y6,5A 5A 5A 5A,
ENG05871-ENG115665,Gear_selector_synchronization_adaption_start_pressure_correction_factor-y7,64 64 64 64,
ENG06646,Gear_shift_module_P_taste_state,1,
ENG06644,Gear_shift_module_position_roh,4,
ENG06645,Gear_shift_module_position_roh_invers,11,
ENG06655,Gear_shift_module_reset_counter_since_erasing_DTC_memory,0,
ENG06653-ENG06673,Gear_shift_module_reset_state-Reset_status,No Error (other values does not exist),
ENG06654,Gear_shift_module_switch_off_counter_over_length_of_life,0,
ENG06656,Gear_shift_module_switch_off_counter_since_erasing_DTC_memory,0,
ENG06643,Gear_shift_module_variante,4,
ENG00878-ENG100894,H003_GangMax-Ist Gang,7,
ENG00879-ENG100894,H004_GangIst-Ist Gang,1,
ENG00880-ENG100894,H007_GangSoll-Ist Gang,1,
ENG00881-ENG100894,H008_GangVorwahl-Ist Gang,R,
ENG00882-ENG100894,H009_Notfahren_GangMax-Ist Gang,N,
ENG00883-ENG100894,H010_Notfahren_GangMin-Ist Gang,N,
ENG00884-ENG100894,H011_Notfahren_GangMaxGetrSchutz-Ist Gang,N,
ENG102399,Immobilizer_ambient_data,00 00 00 00 00 00,
ENG26900-ENG104089,Intelligent_park_assist_state-Drive readiness,No,
ENG26900-ENG31586,Intelligent_park_assist_state-GE_Status_GE_IPA,Not available,
ENG26900-ENG31605,Intelligent_park_assist_state-GSG_verfuegbar,No,
ENG26900-ENG31873,Intelligent_park_assist_state-IPA_01_E2E_unplausibel,No,
ENG26900-ENG31874,Intelligent_park_assist_state-IPA_01_Timeout,No,
ENG26900-ENG31875,Intelligent_park_assist_state-IPA_01_Wert_unplausibel,No,
ENG26900-ENG31876,Intelligent_park_assist_state-IPA_Fahrstufenwunsch,Initializing,
ENG26900-ENG31877,Intelligent_park_assist_state-IPA_relevanter_Fehler,No,
ENG26900-ENG31878,Intelligent_park_assist_state-IPA_Status_IPA_GE,Initializing,
ENG26900-ENG31932,Intelligent_park_assist_state-Letztes_P_einlegen_erfolgreich,No,
ENG26900-ENG32233,Intelligent_park_assist_state-P_Taste_betaetigt,not activated,
ENG26900-ENG32235,Intelligent_park_assist_state-Paddle_betaetigt,not activated,
ENG26900-ENG33260,Intelligent_park_assist_state-v_kleiner_Schwelle_Fahrstufenwechsel,No,
ENG26900-ENG33261,Intelligent_park_assist_state-v_kleiner_Schwelle_PiloPa_v_max,No,
ENG26900-ENG33262,Intelligent_park_assist_state-v_kleiner_Schwelle_Stillstand,No,
ENG26900-ENG33263,Intelligent_park_assist_state-v_Signal_Ersatzwert,No,
ENG26900-ENG33264,Intelligent_park_assist_state-v_Signal_intern_gebildet,No,
ENG26900-ENG33322,Intelligent_park_assist_state-Vorhalt 1,00000000 ,
ENG26900-ENG33323,Intelligent_park_assist_state-Vorhalt 2,00000000 ,
ENG26900-ENG33324,Intelligent_park_assist_state-Vorhalt 3,00000000 ,
ENG26900-ENG33325,Intelligent_park_assist_state-Vorhalt 4,00000000 ,
ENG26900-ENG33326,Intelligent_park_assist_state-Vorhalt 5,00000000 ,
ENG26900-ENG33327,Intelligent_park_assist_state-Vorhalt 6,00000000 ,
ENG26900-ENG33352,Intelligent_park_assist_state-WH_betaetigt,not activated,
ENG26900-ENG33392,Intelligent_park_assist_state-Zuendung,OFF,
ENG107135-ENG98502,J009_Akk_PKp0_def_ko[K1]-Data,3.000, bar
ENG107136-ENG98502,J010_Akk_PKp0_def_ko[K2]-Data,3.000, bar
ENG107137-ENG98502,J011_AkmPKp0Def_Msr_ko[K1]-Data,3.000, bar
ENG107138-ENG98502,J012_AkmPKp0Def_Msr_ko[K2]-Data,3.000, bar
ENG00895-ENG98502,K004_Schaltart-Data,Eco,
ENG00896-ENG98502,K009_FastOff_FlagAktiv-Data,No,
ENG00897-ENG98502,K010_FastOff_NAnHSMin-Data,0, /min
ENG00898-ENG98502,K011_TSK_NAnHSMin-Data,0, /min
ENG00899-ENG98502,K012_TSK_NAnRSMin-Data,0, /min
ENG00900-ENG98502,K013_Kurve_FlagAktiv-Data,No,
ENG00901-ENG98502,K014_Kurve_NAnHSMin-Data,0, /min
ENG00902-ENG98502,K015_Kurve_NAnRSMin-Data,0, /min
ENG00903-ENG98502,K016_SVF_FlagAktiv-Data,No,
ENG00904-ENG98502,K017_SVF_NAnHSMin-Data,0, /min
ENG00905-ENG98502,K018_SVF_NAnRSMin-Data,0, /min
ENG00906-ENG98502,K019_Vorwahl_ZustSchaltung-Data,Noch keine Prognose,
ENG00907-ENG102522,K020_StatusSchaltung-K022_Anzahl_HS,0,
ENG00907-ENG101683,K020_StatusSchaltung-K023_Anzahl_RS,0,
ENG00907-ENG101143,K020_StatusSchaltung-K024_Anzahl_bevorzuegteRS,0,
ENG00907-ENG101162,K020_StatusSchaltung-K025_Anzahl_AnfahrRS,0,
ENG107331-ENG99166,L001_Engine Coding Information-Z054_Engine_Code,69,
ENG107331-ENG103915,L001_Engine Coding Information-Z055_Transmission_Code,DL382_Allrad,
ENG107331-ENG101704,L001_Engine Coding Information-Z056_Emission_Type,no EOBD: no OBD (US),
ENG107332-ENG104007,L002_FehFehlerspeicher.0.s.FID[Fehler_0]-Error Code,Unknown (640),
ENG107333-ENG104007,L003_FehFehlerspeicher.1.s.FID[Fehler_1]-Error Code,Unknown (640),
ENG107334-ENG104007,L004_FehFehlerspeicher.2.s.FID[Fehler_2]-Error Code,Unknown (640),
ENG107335-ENG104007,L005_FehFehlerspeicher.3.s.FID[Fehler_3]-Error Code,Unknown (640),
ENG107336-ENG104007,L006_FehFehlerspeicher.4.s.FID[Fehler_4]-Error Code,Unknown (640),
ENG107337-ENG104007,L007_FehFehlerspeicher.5.s.FID[Fehler_5]-Error Code,Unknown (640),
ENG107338-ENG104007,L008_FehFehlerspeicher.6.s.FID[Fehler_6]-Error Code,Unknown (640),
ENG107339-ENG104007,L009_FehFehlerspeicher.7.s.FID[Fehler_7]-Error Code,Unknown (640),
ENG107340-ENG104007,L010_FehFehlerspeicher.8.s.FID[Fehler_8]-Error Code,Unknown (640),
ENG107341-ENG104007,L011_FehFehlerspeicher.9.s.FID[Fehler_9]-Error Code,Unknown (640),
ENG107342-ENG104007,L012_FehFehlerspeicher.10.s.FID[Fehler_10]-Error Code,Unknown (640),
ENG107343-ENG104007,L013_FehFehlerspeicher.11.s.FID[Fehler_11]-Error Code,Unknown (640),
ENG102017-ENG98502,M011_KrsZustand-Data,Selecting,
ENG100485,M012_KscZustandTSchutz,0,
ENG104077-ENG98502,M016_Svc_ABSAktiv-Data,OFF,
ENG101606-ENG98502,M017_Svc_Bremse-Data,OFF,
ENG99346-ENG98502,M018_Svc_EDSAktiv-Data,OFF,
ENG101980-ENG98502,M019_Svc_ESPAktiv-Data,OFF,
ENG107505-ENG98502,M020_Fzk_ZustHaupt-Data,Neutral,
ENG100481-ENG98502,M021_Svc_ZustKlima-Data,On,
ENG99617-ENG100068,M022_Svc_ZustStatusGRA-GRA Status,nicht verbaut / kein ACC zulässig,
ENG00916-ENG98502,M023_Zustand-Data,P,
ENG100148,M024_Svu_ZustKl15,Terminal 15 on,
ENG00917-ENG98502,M025_SFZ_FlagAktiv-Data,Undetected,
ENG107508-ENG98502,M026_Umw_NAbRichtung-Data,forwards,
ENG107510-ENG98502,M028_Akk_FlagPKp0_allg.Freigabe-Data,OFF,
ENG107511-ENG98502,M030_Vwh_FlagWh_TipInfo_FehlerStatus-Data,Error E5: Tiptronic Info wrong timing,
ENG107516-ENG103355,M035_Grd_FlagBed_VwhKal-Elektrisch Parkbremse Aus,No,
ENG107516-ENG101955,M035_Grd_FlagBed_VwhKal-Fehler Vorhanden,No,
ENG107516-ENG100526,M035_Grd_FlagBed_VwhKal-Klemme15 ist Aus,No,
ENG107516-ENG104233,M035_Grd_FlagBed_VwhKal-Motor ist nicht Aus,Yes,
ENG107516-ENG102761,M035_Grd_FlagBed_VwhKal-Temperatur Außerhalb Toleranz,No,
ENG107517-ENG98502,M036_SCM_Single_Bit_Error_Status-Data,Undetected,
ENG107524-ENG104213,M045_Grd_AbbruchCode-Abbruch Grunde,(0) GRD_KEIN_FEHLER,
ENG129679-ENG98502,M046_Grd_AnzeigeZustand-Data,(0) GRD_ZUST_HAUPT_AUS,
ENG107530,M052_Grd_Zust_Haupt,OFF,
ENG107531-ENG98502,M053_Akk_FehlerPkp0_Zust-Data,(0) Aus,
ENG107534-ENG98502,M056_Umw_SFZ_FlagErkannt-Data,No,
ENG107539-ENG98502,M061_Grd_ZustAbnahme_allg.alle-Data,Keine Routine laeuft,
ENG107540-ENG98502,M066_AopNeustart_ZustAdapt-Data,Unknown (7),
ENG107561-ENG100894,M088_GwsDat.Zustand[W1]-Ist Gang,1,
ENG107562-ENG100894,M089_GwsDat.Zustand[W2]-Ist Gang,R,
ENG129729,Manual_transmission_fluid_error_code,0,
ENG129727,Manual_transmission_fluid_pump_actual_current,746, mA
ENG129749,Manual_transmission_fluid_pump_CALID,0CK281L 0576MTF ,
ENG129750,Manual_transmission_fluid_pump_CVN,00 00 28 4C,
ENG06648,Manual_transmission_fluid_pump_lin_communication_error_state,Test not completed,
ENG06650,Manual_transmission_fluid_pump_recieved_lin_frame_1_timeout_counter,0,
ENG06651,Manual_transmission_fluid_pump_recieved_lin_frame_2_timeout_counter,0,
ENG06652,Manual_transmission_fluid_pump_recieved_lin_frame_3_timeout_counter,0,
ENG06649,Manual_transmission_fluid_pump_sent_lin_frame_timeout_counter,0,
ENG06647,Manual_transmission_fluid_pump_state,EMC_MTF_BETRIEB,
ENG129730-ENG98502,Manual_transmission_fluid_pump_temperature-Data,58, °C
ENG129728-ENG98502,Manual_transmission_fluid_temperature_PCB-Data,200, °C
ENG06641,Multifunction_steering_wheel_tiptronic_left_error,0,
ENG06642,Multifunction_steering_wheel_tiptronic_right_error,0,
ENG125928,Occurrence_counter_over_length_of_life,255,
ENG107905-ENG130040,Offset_values_for_clutch_pressure_sensor-K1 Offset Bereich 1,0.139, bar
ENG107905-ENG130041,Offset_values_for_clutch_pressure_sensor-K1 Offset Bereich 2,0.094, bar
ENG107905-ENG130042,Offset_values_for_clutch_pressure_sensor-K1 Offset Bereich 3,0.074, bar
ENG107905-ENG130043,Offset_values_for_clutch_pressure_sensor-K1 Offset Bereich 4,0.040, bar
ENG107905-ENG130044,Offset_values_for_clutch_pressure_sensor-K1 Offset Bereich 5,0.038, bar
ENG107905-ENG130045,Offset_values_for_clutch_pressure_sensor-K1 Offset Bereich 6,0.041, bar
ENG107905-ENG130046,Offset_values_for_clutch_pressure_sensor-K1 Offset Bereich 7,0.044, bar
ENG107905-ENG130047,Offset_values_for_clutch_pressure_sensor-K1 Offset Bereich 8,0.000, bar
ENG107905-ENG130048,Offset_values_for_clutch_pressure_sensor-K2 Offset Bereich 1,0.126, bar
ENG107905-ENG130049,Offset_values_for_clutch_pressure_sensor-K2 Offset Bereich 2,0.075, bar
ENG107905-ENG130050,Offset_values_for_clutch_pressure_sensor-K2 Offset Bereich 3,0.058, bar
ENG107905-ENG130051,Offset_values_for_clutch_pressure_sensor-K2 Offset Bereich 4,0.015, bar
ENG107905-ENG130052,Offset_values_for_clutch_pressure_sensor-K2 Offset Bereich 5,0.006, bar
ENG107905-ENG130053,Offset_values_for_clutch_pressure_sensor-K2 Offset Bereich 6,0.005, bar
ENG107905-ENG130054,Offset_values_for_clutch_pressure_sensor-K2 Offset Bereich 7,0.018, bar
ENG107905-ENG130055,Offset_values_for_clutch_pressure_sensor-K2 Offset Bereich 8,0.000, bar
ENG08732-ENG98502,Parking_lock_calibrated_position_in_P-Data,84.45, %
ENG08733-ENG98502,Parking_lock_calibrated_position_not_in_P-Data,50.80, %
ENG06657-ENG06675,Parking_lock_counter_holding_verification-Counter_from_N_to_P,0,
ENG06657-ENG06677,Parking_lock_counter_holding_verification-Counter_from_P_to_N,0,
ENG06657-ENG06676,Parking_lock_counter_holding_verification-Counter_in_P,0,
ENG08728-ENG118270,Parking_lock_error_state-PbW_Fehler_01_PHM_Eingelegt,no error,
ENG08728-ENG118311,Parking_lock_error_state-PbW_Fehler_02_PHM_Ausgelegt,no error,
ENG08728-ENG09312,Parking_lock_error_state-PbW_Fehler_03_Mechanik_Einlegen,no error,
ENG08728-ENG09313,Parking_lock_error_state-PbW_Fehler_04_Mechanik_EinlegenL,no error,
ENG08728-ENG09314,Parking_lock_error_state-PbW_Fehler_05_Mechanik_Auslegen,no error,
ENG08728-ENG118295,Parking_lock_error_state-PbW_Fehler_06_PHM_Unplausibel,no error,
ENG08728-ENG118370,Parking_lock_error_state-PbW_Fehler_07_PHM_Rueckmeldung,no error,
ENG08728-ENG09317,Parking_lock_error_state-PbW_Fehler_08_SW_Unplausibel,no error,
ENG08728-ENG09318,Parking_lock_error_state-PbW_Fehler_09_SW_Unplausibel,no error,
ENG08728-ENG118352,Parking_lock_error_state-PbW_Fehler_10_PHM_Init,used,
ENG08728-ENG118396,Parking_lock_error_state-PbW_Fehler_11_PHM_Fehler,no error,
ENG08728-ENG98891,Parking_lock_error_state-Reserved,-1,
ENG08720,Parking_lock_function_state_E0,Eingelegt halten,
ENG08725,Parking_lock_function_state_E1,P_HALTEN,
ENG08726,Parking_lock_function_state_E2,Wait,
ENG08730,Parking_lock_hold_magnet_actual_position,Hold,
ENG08729,Parking_lock_hold_magnet_commanded_position,Hold,
ENG08719,Parking_lock_position_state,Parksperre_eingelegt,
ENG08727,Parking_lock_state_for_lock_function,PBW_L_INIT,
ENG129732,Pressure_sensor_1_buffer_error_count,0,
ENG129725,Pressure_sensor_1_error_code,0,
ENG129736,Pressure_sensor_1_fastchannel_crc_check_error_count,0,
ENG129723,Pressure_sensor_1_fastchannel_message_number,32932,
ENG129706,Pressure_sensor_1_received_values_correct_counter,16,
ENG129708,Pressure_sensor_1_serial_number,05 F0 01 66 00 00 00 00,
ENG129704-ENG98502,Pressure_sensor_1_temperature-Data,66, °C
ENG129734,Pressure_sensor_1_timestamp_error_count,0,
ENG129733,Pressure_sensor_2_buffer_error_count,0,
ENG129726,Pressure_sensor_2_error_code,0,
ENG129737,Pressure_sensor_2_fastchannel_crc_check_error_count,0,
ENG129724,Pressure_sensor_2_fastchannel_message_number,16911,
ENG129707,Pressure_sensor_2_received_values_correct_counter,17,
ENG129709,Pressure_sensor_2_serial_number,05 E3 01 66 00 00 00 00,
ENG129705-ENG98502,Pressure_sensor_2_temperature-Data,67, °C
ENG129735,Pressure_sensor_2_timestamp_error_count,0,
ENG27077,Pressure_sensor_change_state,nicht vertauscht,
ENG129685-ENG98502,Pressure_sensor_offset_adaption_state-Data,Adaption gelaufen,
ENG108362-ENG102813,Q001_OBD Cycle And MIL State-Driving Cycle,active,
ENG108362-ENG98734,Q001_OBD Cycle And MIL State-mil,not active,
ENG108362-ENG99968,Q001_OBD Cycle And MIL State-WarmUp Cycle,not active,
ENG105258,Rear left wheel speed,0.0, km/h
ENG105257,Rear right wheel speed,0.0, km/h
ENG05895,Safety_interface_automatic_transmission_output_speed_gradient,0, 1/min/s
ENG05876,Safety_interface_automatic_transmission_shift_position,P,
ENG05906-ENG98502,Safety_interface_brake_signal_state-Data,not activated,
ENG05878-ENG05941,Safety_interface_calculated_selected_gear_nsync-Shaft_1,1,
ENG05878-ENG05942,Safety_interface_calculated_selected_gear_nsync-Shaft_2,R,
ENG05910-ENG98432,Safety_interface_can_signal_state-brakes,invalid,
ENG05910-ENG98432,Safety_interface_can_signal_state-brakes,Current,
ENG05910-ENG05935,Safety_interface_can_signal_state-NAn,Current,
ENG05910-ENG05935,Safety_interface_can_signal_state-NAn,invalid,
ENG05910-ENG05940,Safety_interface_can_signal_state-VFzg,invalid,
ENG05910-ENG05940,Safety_interface_can_signal_state-VFzg,Current,
ENG05910-ENG05936,Safety_interface_can_signal_state-VRad (front left),invalid,
ENG05910-ENG05936,Safety_interface_can_signal_state-VRad (front left),Current,
ENG05910-ENG05937,Safety_interface_can_signal_state-VRad (front right),Current,
ENG05910-ENG05937,Safety_interface_can_signal_state-VRad (front right),invalid,
ENG05910-ENG05938,Safety_interface_can_signal_state-VRad (rear left),invalid,
ENG05910-ENG05938,Safety_interface_can_signal_state-VRad (rear left),Current,
ENG05910-ENG05939,Safety_interface_can_signal_state-VRad (rear right),Current,
ENG05910-ENG05939,Safety_interface_can_signal_state-VRad (rear right),invalid,
ENG05890-ENG98502,Safety_interface_clutch_1_actual_pressure-Data,2.0, bar
ENG05891-ENG98502,Safety_interface_clutch_2_actual_pressure-Data,2.0, bar
ENG05875-ENG118109,Safety_interface_drive_position_sensor_signal_state-Sensor_1,valid,
ENG05875-ENG118110,Safety_interface_drive_position_sensor_signal_state-Sensor_2,valid,
ENG05883,Safety_interface_engine_speed,0, /min
ENG05896,Safety_interface_engine_speed_gradient,0, 1/min/s
ENG27107,Safety_interface_expected_wheel_circumference,2251,
ENG05904,Safety_interface_filtered_automatic_transmission_output_speed_negative_gradien,0, /min
ENG05899-ENG98502,Safety_interface_gear_selector_1_measured_distance-Data,9.18, mm
ENG05902-ENG98502,Safety_interface_gear_selector_2_measured_distance-Data,-9.39, mm
ENG05901-ENG98502,Safety_interface_gear_selector_3_measured_distance-Data,-0.27, mm
ENG05900-ENG98502,Safety_interface_gear_selector_4_measured_distance-Data,-0.44, mm
ENG05877-ENG05944,Safety_interface_gear_selector_signal_state-Gear_selector_1,valid,
ENG05877-ENG05945,Safety_interface_gear_selector_signal_state-Gear_selector_2,valid,
ENG05877-ENG05946,Safety_interface_gear_selector_signal_state-Gear_selector_3,valid,
ENG05877-ENG05947,Safety_interface_gear_selector_signal_state-Gear_selector_4,valid,
ENG05879-ENG05944,Safety_interface_gear_selector_speed_slowly_state-Gear_selector_1,No,
ENG05879-ENG05945,Safety_interface_gear_selector_speed_slowly_state-Gear_selector_2,No,
ENG05879-ENG05946,Safety_interface_gear_selector_speed_slowly_state-Gear_selector_3,No,
ENG05879-ENG05947,Safety_interface_gear_selector_speed_slowly_state-Gear_selector_4,No,
ENG05880-ENG02681,Safety_interface_gear_state-Gear_1,Eingespurt,
ENG05880-ENG02682,Safety_interface_gear_state-Gear_2,Neutral,
ENG05880-ENG02683,Safety_interface_gear_state-Gear_3,Neutral,
ENG05880-ENG02684,Safety_interface_gear_state-Gear_4,Neutral,
ENG05880-ENG02685,Safety_interface_gear_state-Gear_5,Neutral,
ENG05880-ENG02686,Safety_interface_gear_state-Gear_6,Neutral,
ENG05880-ENG02687,Safety_interface_gear_state-Gear_7,Neutral,
ENG05880-ENG05943,Safety_interface_gear_state-Gear_R,Eingespurt,
ENG05903-ENG98502,Safety_interface_gradient_filtered_vehicle_speed-Data,0.0, km/h
ENG08754-ENG09328,Safety_interface_holding_magnet_state-Holding Magnet State,ERROR,
ENG08755-ENG98502,Safety_interface_input_speed_sensor_1-Data,0, /min
ENG08756-ENG98502,Safety_interface_input_speed_sensor_2-Data,0, /min
ENG08753-ENG09329,Safety_interface_parking_brake_state-Parking Brake State,ERROR,
ENG08752-ENG09330,Safety_interface_parking_lock_state-Parking Lock State,selected,
ENG27108,Safety_interface_Pos_Info_status,1,
ENG27109,Safety_interface_Pos_Info_value,0,
ENG05897,Safety_interface_pressure_regulating_valve_1_actual_current,0.0, mA
ENG05888,Safety_interface_pressure_regulating_valve_1_allowed_current,1636.7, mA
ENG05898,Safety_interface_pressure_regulating_valve_2_actual_current,0.0, mA
ENG05889,Safety_interface_pressure_regulating_valve_2_allowed_current,1532.4, mA
ENG05907-ENG129639,Safety_interface_pressure_signal_state-Clutch_1,valid,
ENG05907-ENG129640,Safety_interface_pressure_signal_state-Clutch_2,valid,
ENG129742,Safety_interface_safety_controller_eeprom_prog_block_state,no error,
ENG05908-ENG05948,Safety_interface_safety_goal_error_state-Safety_goal_3_1,no error,
ENG05908-ENG05949,Safety_interface_safety_goal_error_state-Safety_goal_6,no error,
ENG05908-ENG05950,Safety_interface_safety_goal_error_state-Safety_goal_7_8,00,
ENG05884-ENG98502,Safety_interface_sensor_signal_gear_selector_1-Data,87, %
ENG05885-ENG98502,Safety_interface_sensor_signal_gear_selector_2-Data,12, %
ENG05887-ENG98502,Safety_interface_sensor_signal_gear_selector_3-Data,49, %
ENG05886-ENG98502,Safety_interface_sensor_signal_gear_selector_4-Data,48, %
ENG27110,Safety_interface_SG78_max_allowed_output_speed_gradient,64859,
ENG08757,Safety_interface_solenoid_valve_6_actual_current,0.0, mA
ENG08758,Safety_interface_solenoid_valve_6_current_before_SZ,0.0, mA
ENG08759-ENG98353,Safety_interface_solenoid_valve_6_source_unjustified_current-Adaption,No,
ENG08759-ENG09333,Safety_interface_solenoid_valve_6_source_unjustified_current-Fahr-SW,No,
ENG08759-ENG09335,Safety_interface_solenoid_valve_6_source_unjustified_current-Fehlerreaktion,No,
ENG08759-ENG09331,Safety_interface_solenoid_valve_6_source_unjustified_current-Pruefstand,No,
ENG08759-ENG09334,Safety_interface_solenoid_valve_6_source_unjustified_current-Tests,No,
ENG08759-ENG09332,Safety_interface_solenoid_valve_6_source_unjustified_current-Ventilanregung,No,
ENG05881-ENG98502,Safety_interface_vehicle_speed-Data,0.0, km/h
ENG05882-ENG98502,Safety_interface_vehicle_speed_from_wheel-Data,0.0, km/h
ENG05874-ENG05951,Safety_interface_voltage_state-Voltage_supply_1,valid,
ENG05874-ENG05952,Safety_interface_voltage_state-Voltage_supply_2,valid,
ENG05874-ENG05953,Safety_interface_voltage_state-Voltage_supply_3,valid,
ENG05874-ENG129979,Safety_interface_voltage_state-Voltage_supply_speed_sensor,valid,
ENG05892-ENG98502,Safety_interface_voltage_supply_1_for_sensors-Data,5.003, V
ENG05893-ENG98502,Safety_interface_voltage_supply_2_for_sensors-Data,5.005, V
ENG05894-ENG98502,Safety_interface_voltage_supply_3_for_sensors-Data,5.009, V
ENG122768,Scm_extended_fault_code,0,
ENG122761-ENG98502,Scm_fault_code-Data,SCM_E_NONE,
ENG38977,Scm_Fault_Code_Extend_Active,0,
ENG122765,Scm_faults_since_power_up,10 00 00 00,
ENG122766-ENG98502,Scm_persistent_safe_state-Data,SCM_NON_PERSISTENT,
ENG129741-ENG130070,SCM_PosInfo_ErrorFlag-PWM Pos Info Error Flag,stuck at ok,
ENG129740-ENG130069,SCM_PosInfo_InitFlag-PWM Pos Info Init Flag,true,
ENG129739-ENG130065,SCM_PWM_ErrorFlag-PWM GS13 Error Flag,stuck at ok,
ENG129739-ENG130066,SCM_PWM_ErrorFlag-PWM GS2R Error Flag,stuck at ok,
ENG129739-ENG130067,SCM_PWM_ErrorFlag-PWM GS46 Error Flag,stuck at ok,
ENG129739-ENG130068,SCM_PWM_ErrorFlag-PWM GS57 Error Flag,stuck at ok,
ENG129738-ENG130059,SCM_PWM_InitFlag-PWM GS13 Initflag,true,
ENG129738-ENG130060,SCM_PWM_InitFlag-PWM GS2R Initflag,true,
ENG129738-ENG130061,SCM_PWM_InitFlag-PWM GS46 Initflag,true,
ENG129738-ENG130062,SCM_PWM_InitFlag-PWM GS57 Initflag,true,
ENG129738-ENG130063,SCM_PWM_InitFlag-PWM MPIO Initflag,true,
ENG129738-ENG130064,SCM_PWM_InitFlag-PWM MTF PUMP Initflag,false,
ENG129738-ENG130057,SCM_PWM_InitFlag-PWM WHS1 Initflag,true,
ENG129738-ENG130058,SCM_PWM_InitFlag-PWM WHS2 Initflag,true,
ENG122763-ENG98502,Scm_reset_class-Data,SCM_RESET_TSBC,
ENG38980,Scm_Reset_Prrogram_Counter,00 00 00 00,
ENG122767-ENG98502,Scm_state-Data,SCM_STATE_NORMAL,
ENG38987,Scm_Task_Error_Nr,0,
ENG129717,Scm_trap_info,0,
ENG122762,Scm_warm_reset_cnt,1,
ENG122764,Scm_weight_rst_cnt,0,
ENG08731,Solenoid_valve_6_commanded_current_from_parking_lock_modul,0.0, mA
ENG129694-ENG98502,Sopc_Error_State_MC-Data,SOPC_ERR_OK,
ENG129716-ENG98502,Sopc_Nrst5_Active-Data,NRST5 nicht aktiv,
ENG129711,Sopc_SDS4_Dev1_Error,00000000 ,
ENG129712,Sopc_SDS4_Dev2_Error,00000000 ,
ENG129713,Sopc_SDS4_Dev3_Error,00000000 ,
ENG129703,Sopc_State_Diag,00001111 ,
ENG129693-ENG130019,Sopc_State_Diag_Sequence-Test_Step_1,00000000 ,
ENG129693-ENG130020,Sopc_State_Diag_Sequence-Test_Step_2,00001111 ,
ENG129693-ENG130021,Sopc_State_Diag_Sequence-Test_Step_3,00000000 ,
ENG129693-ENG130022,Sopc_State_Diag_Sequence-Test_Step_4,00001111 ,
ENG129693-ENG130023,Sopc_State_Diag_Sequence-Test_Step_5,00000000 ,
ENG129693-ENG130024,Sopc_State_Diag_Sequence-Test_Step_6,00001111 ,
ENG129693-ENG130025,Sopc_State_Diag_Sequence-Test_Step_7,00000000 ,
ENG129693-ENG130026,Sopc_State_Diag_Sequence-Test_Step_8,00001111 ,
ENG129702,Sopc_Test_Step,8,
ENG129714,Sopc_Tsbc_Diag1,00000000 00000000 00000000 00000111 ,
ENG129715,Sopc_Tsbc_Diag2,00000000 00000000 00000000 00000000 ,
ENG129710,Sopc_U_Kl30,1784,
ENG107872-ENG101695,System Supplier Boot Software Identification (BB)-System Supplier Boot Identification,0407      ,
ENG107872-ENG101202,System Supplier Boot Software Identification (BB)-System Supplier Calibration Data Identification,Q5NF 2,0lT 185kW NAR quattro,
ENG107872-ENG101224,System Supplier Boot Software Identification (BB)-System Supplier HW Version,9  ,
ENG107872-ENG103214,System Supplier Boot Software Identification (BB)-System Supplier HW Version 2,Series,
ENG107872-ENG99311,System Supplier Boot Software Identification (BB)-System Supplier Software Identification,R8E2                                              ,
ENG00991-ENG98502,T002_FpModi-Data,0.0, %
ENG109306-ENG98502,T003_Svc_Fp-Data,0.0, %
ENG105260,Transfer speed by dash panel insert,0.00, km/h
ENG105259,Transfer speed from ESP,0.00, km/h
ENG129718,Tsbc_Report_diag_source_reg_value,00 04 00 28,
ENG129700-ENG98502,Voltage_sensor_sv1-Data,4.999, V
ENG129721-ENG98502,Voltage_supply_1_for_sensors-Data,5.0, V
ENG129722-ENG98502,Voltage_supply_2_for_sensors-Data,5.0, V
ENG129977-ENG98502,Voltage_supply_3_for_sensors-Data,5.0, V
ENG110036-ENG98502,W002_Vwh_FlagWh_PLCD1_FehlerStatus-Data,Signal OK,
ENG110038-ENG98502,W004_Vwh_FlagWh_PLCD2_FehlerStatus-Data,Signal OK,
ENG05868,XCP_communication_state,not active,
ENG110309-ENG98502,Z003_Umw_TSK_ASollMin-Data,-0.100, m/s²
ENG110311-ENG98502,Z005_Umw_TSK_AMaxGang[Gang1]-Data,1.641, m/s²
ENG01034-ENG98502,Z008_Freischau_FlagAktiv-Data,not active,
ENG110314-ENG98502,Z009_Umw_TSK_AMaxGang[Gang2]-Data,1.096, m/s²
ENG01035-ENG98502,Z010_Bergab_FlagAktiv-Data,not active,
ENG110316-ENG98502,Z011_Umw_TSK_AMaxGang[Gang3]-Data,0.729, m/s²
ENG110317-ENG98502,Z012_Umw_TSK_AMaxGang[Gang4]-Data,0.477, m/s²
ENG01036-ENG98502,Z013_RDLock_FlagAktiv-Data,No Detection,
ENG110319-ENG98502,Z014_Umw_TSK_AMaxGang[Gang5]-Data,0.304, m/s²
ENG110321-ENG98502,Z016_Umw_TSK_AMaxGang[Gang6]-Data,0.178, m/s²
ENG110322-ENG98502,Z017_Umw_TSK_AMaxGang[Gang7]-Data,0.112, m/s²
ENG110323-ENG98502,Z018_Umw_TSK_ASollMax-Data,0.150, m/s²
ENG110324-ENG98502,Z021_UmwKurvenRadius-Data,10000, m
ENG110325-ENG98502,Z024_UmwAnhaenger_vorhanden-Data,No,
ENG110327,Z027_UmwMadAnzahl,0,
ENG110329-ENG98502,Z030_UmwMasseLast-Data,0, kg
ENG110330,Z031_Umw_MAbtrieb_Zustand,invalid,
ENG01037-ENG98502,Z039_ZwangsSchaltung-Data,No,
ENG01038-ENG98502,Z042_TipSignalMinusAktiv-Data,not active,
ENG01039-ENG98502,Z043_TipSignalPlusAktiv-Data,not active,
ENG01040-ENG98502,Z044_TipbeiKD-Data,No,
ENG110337-ENG98502,Z045_UmwRadradius-Data,358, mm
ENG110338-ENG98502,Z046_UmwStrasseErkannt-Data,Unknown (255),
ENG101517-ENG98502,Z047_Umw_PrzNeig-Data,0.0, %
ENG110339-ENG98502,Z048_Ftp_PrzFtp-Data,0, %
ENG110340-ENG98502,Z052_Akk_FehlerPkp0_Welle-Data,(0) Welle1,
ENG110342-ENG98502,Z057_NsyUebGang[1]-Data,16.894,
ENG110343-ENG98502,Z058_NsyUebGang[2]-Data,11.609,
ENG110344-ENG98502,Z059_NsyUebGang[3]-Data,8.041,
ENG110345-ENG98502,Z060_NsyUebGang[4]-Data,5.603,
ENG110346-ENG98502,Z061_NsyUebGang[5]-Data,3.912,
ENG110347-ENG98502,Z062_NsyUebGang[6]-Data,2.687,
ENG110348-ENG98502,Z063_NsyUebGang[7]-Data,2.040,
ENG110349-ENG98502,Z064_NsyUebGang[N]-Data,1.000,
ENG110350-ENG98502,Z065_NsyUebGang[R]-Data,14.577,
ENG110352-ENG98502,Z067_Vwh_TWh_AbbruchZeit-Data,10000, ms
ENG110353-ENG98502,Z069_Akk_Tadap_PKp0[K1]-Data,0, ms
ENG110354-ENG98502,Z070_Akk_Tadap_PKp0[K2]-Data,0, ms
ENG01041-ENG98502,Z100_Notfahren_FlagAktiv-Data,not active,
Elapsed Time: 01:26
blockmap-03-80A-907-379-J
;SW:80A-907-379-J   HW:80A-907-379 ---  ABS Brakes
;Component:ESP9 Plus     H11 0775, Coding:4CAA40BE28AB0A9891A7489220834292E53592320214508912044249A7AC49
;EV_ESP9BOSCHCMP,002013,EV_ESP9BOSCHCMP_002.rod
;Friday,12,July,2019,16:06:11:64285
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: B62F259809BCE0FFF3-80E2
Group,Description,Actual
IDE00019,Voltage terminal 30,14.632, V
IDE00020-MAS06489,Terminal 15 status-Terminal 15 signal,On,
IDE00020-MAS06490,Terminal 15 status-Terminal 15 load,On,
IDE00021,Engine speed,799, /min
IDE00025,Coolant temperature,107, °C
IDE00078,Time since engine start,1116, s
IDE00085,Normed load value,14.9, %
IDE00086,Accelerator position,15, %
IDE00097,OBD - requirements for which this vehicle is designed,None,
IDE00100,Engine torque,0, Nm
IDE00150-MAS00102,Pressure in brake booster-valid,-944.69, mbar
IDE00322,Status of basic setting,Basic setting not active,
IDE00326,Steering wheel angle,4.26, °
IDE00445-MAS01759,Unlearning counter according OBD-OBD unlearning counter,FF,
IDE00556,Outside air temperature,32, °C
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00611,Malfunction that has caused the ambient data to be stored,P0000,
IDE00920,Front left wheel speed,0.00, km/h
IDE00921,Front right wheel speed,0.00, km/h
IDE00922,Left rear wheel speed,0.00, km/h
IDE00923,Right rear wheel speed,0.00, km/h
IDE01985-MAS06855,FAZIT identification test sum-Test sum,F3 C5 90 99,
IDE02211-MAS03714,Brake pressure-Left front wheel,not installed,
IDE02211-MAS03716,Brake pressure-Left rear wheel,not installed,
IDE02211-MAS09170,Brake pressure-Brake pressure sensor 1,-0.000, bar
IDE02239,Rotation rate sensor 1,0.00, rad/s
IDE02241,Lateral acceleration sensor 1,0.77, m/s²
IDE02243,Rotation rate sensor 2,0.00, rad/s
IDE02245,Lateral acceleration sensor 2,0.00, m/s²
IDE02305,ESP brake application information,not activated,
IDE02308,ESP button status,not activated,
IDE02309,Valve relay status,passive,
IDE02310,Status of return pump,passive,
IDE02311-MAS12079,Left front wheel speed sensor installation position-Signal amplitude,0,
IDE02311-MAS12080,Left front wheel speed sensor installation position-Signal amplitude measurement: status,invalid,
IDE02311-MAS12081,Left front wheel speed sensor installation position-Current air gap: status,OK,
IDE02311-MAS12082,Left front wheel speed sensor installation position-Average air gap: status,OK,
IDE02312-MAS12079,Right front wheel speed sensor installation position-Signal amplitude,0,
IDE02312-MAS12080,Right front wheel speed sensor installation position-Signal amplitude measurement: status,invalid,
IDE02312-MAS12081,Right front wheel speed sensor installation position-Current air gap: status,OK,
IDE02312-MAS12082,Right front wheel speed sensor installation position-Average air gap: status,OK,
IDE02313-MAS12079,Left rear wheel speed sensor installation position-Signal amplitude,0,
IDE02313-MAS12080,Left rear wheel speed sensor installation position-Signal amplitude measurement: status,invalid,
IDE02313-MAS12081,Left rear wheel speed sensor installation position-Current air gap: status,OK,
IDE02313-MAS12082,Left rear wheel speed sensor installation position-Average air gap: status,OK,
IDE02314-MAS12079,Right rear wheel speed sensor installation position-Signal amplitude,0,
IDE02314-MAS12080,Right rear wheel speed sensor installation position-Signal amplitude measurement: status,invalid,
IDE02314-MAS12081,Right rear wheel speed sensor installation position-Current air gap: status,OK,
IDE02314-MAS12082,Right rear wheel speed sensor installation position-Average air gap: status,OK,
IDE02315,Direction of rotation front left wheel speed sensor,invalid,
IDE02316,Direction of rotation front right wheel speed sensor,invalid,
IDE02317,Direction of rotation rear left wheel speed sensor,invalid,
IDE02318,Direction of rotation rear right wheel speed sensor,invalid,
IDE02319-MAS02149,Hill start assistant signals-Hillside power take-off torque high wheel limit crawl torque,passive,
IDE02319-MAS02150,Hill start assistant signals-Engine torque high hillside power take-off torque,passive,
IDE02319-MAS02151,Hill start assistant signals-Q bit: incline angle EPB,passive,
IDE02319-MAS02153,Hill start assistant signals-Q bit EPB clutch pedal travel,active,
IDE02319-MAS02154,Hill start assistant signals-Q bit EPB switch position,passive,
IDE02319-MAS02155,Hill start assistant signals-EPB error status,passive,
IDE02538,Longitudinal acceleration sensor,-0.19, m/s²
IDE02611-MAS02964,Incline angle of parking brake-Angle value,0.00, %
IDE02611-MAS09580,Incline angle of parking brake-Sensor status,valid value,
IDE02612-MAS01849,Parking brake tensioning force attained-Left,13200, N
IDE02612-MAS01850,Parking brake tensioning force attained-Right,13200, N
IDE02613,Status of parking brake button,Not operated,
IDE02626,Coding dynamic steering in ESP,Not coded,
IDE02656-MAS00128,System condition of parking brake-Distance Regulation,not coded/not installed,
IDE02656-MAS01090,System condition of parking brake-Transmission,automatic,
IDE02656-MAS02575,System condition of parking brake-Start of operations,performed,
IDE02656-MAS02665,System condition of parking brake-Automatic closing at button malfunction,active,
IDE02656-MAS02666,System condition of parking brake-Seat belt buckle scan,active,
IDE02656-MAS02669,System condition of parking brake-Automatic closing with engine off (key),not active,
IDE02656-MAS02670,System condition of parking brake-Gradual release of brake,not active,
IDE02656-MAS02672,System condition of parking brake-Start-stop,active,
IDE02656-MAS12067,System condition of parking brake-After automatic closing of the parking brake,Extended driver presence recognition,
IDE02656-MAS12068,System condition of parking brake-After manual closing of the parking brake,Driver side door contact and belt switch,
IDE02659-MAS01849,Parking brake status-Left,closed,
IDE02659-MAS01850,Parking brake status-Right,closed,
IDE03008-MAS04511,Stop process prevented-Skidding vehicle detected,not active,
IDE03008-MAS04512,Stop process prevented-Hard deceleration to standstill,not active,
IDE03008-MAS04513,Stop process prevented-Brake control module pump operation,not active,
IDE03008-MAS04514,Stop process prevented-Button for hill descent assist operated,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03008-MAS04516,Stop process prevented-ASR and ESP button operated,not active,
IDE03008-MAS04594,Stop process prevented-Road surface incline too high,not active,
IDE03010-MAS04511,Number of prevented stop processes-Skidding vehicle detected,0,
IDE03010-MAS04512,Number of prevented stop processes-Hard deceleration to standstill,0,
IDE03010-MAS04513,Number of prevented stop processes-Brake control module pump operation,0,
IDE03010-MAS04514,Number of prevented stop processes-Button for hill descent assist operated,0,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,0,
IDE03010-MAS04516,Number of prevented stop processes-ASR and ESP button operated,18,
IDE03010-MAS04594,Number of prevented stop processes-Road surface incline too high,23,
IDE03011-MAS04511,Number of requested start processes-Skidding vehicle detected,0,
IDE03011-MAS04514,Number of requested start processes-Button for hill descent assist operated,1,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,0,
IDE03011-MAS04516,Number of requested start processes-ASR and ESP button operated,0,
IDE03315-MAS01000,Warnings-Warning text,4,
IDE03315-MAS01911,Warnings-Tone sensor,OFF,
IDE03315-MAS02590,Warnings-Red warning light,OFF,
IDE03315-MAS02591,Warnings-Yellow warning light,On,
IDE03315-MAS02592,Warnings-Red operating lamp,OFF,
IDE03315-MAS02593,Warnings-Green operating lamp,OFF,
IDE03315-MAS02594,Warnings-Indicator light in switch,OFF,
IDE03316-MAS02595,Deceleration: setpoint-Deceleration,0.00, m/s²
IDE03317,Transmission range gear recognition switch,Neutral,
IDE03491,Hydraulic pump run-on time,0, ms
IDE03493-MAS11867,Driver door status-Driver door status: qualification,no error,
IDE03493,Driver door status,Open,
IDE03680-MAS12015,Supply voltages-Terminal 30 for electronics,14.27, V
IDE03680-MAS12064,Supply voltages-Return pump,14.27, V
IDE03680-MAS12065,Supply voltages-ABS valves,14.35, V
IDE04253,Sys status of tire press monitoring display,5F 20,
IDE04446,Hill descent control,switched off,
IDE04451-IDE02763,Tire press monitoring display indictor lamp-System malfunction lamp: status,passive,
IDE04451-IDE02765,Tire press monitoring display indictor lamp-Pressure warning lamp: status,passive,
IDE04604-MAS02472,Accelerator pedal travel-Qualification bit,OFF,
IDE04604,Accelerator pedal travel,0.00, %
IDE05712,AUTO HOLD,Initialization/not installed,
IDE06307-MAS00106,Stop prevention history data-Year,2019,
IDE06307-MAS00107,Stop prevention history data-Month,7,
IDE06307-MAS00108,Stop prevention history data-Day,10,
IDE06307-MAS00109,Stop prevention history data-Hours,15,
IDE06307-MAS00110,Stop prevention history data-Minutes,0,
IDE06307-MAS00111,Stop prevention history data-Seconds,22,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Road surface incline too high,
IDE06308-MAS00106,Start request history data-Year,2018,
IDE06308-MAS00107,Start request history data-Month,10,
IDE06308-MAS00108,Start request history data-Day,20,
IDE06308-MAS00109,Start request history data-Hours,9,
IDE06308-MAS00110,Start request history data-Minutes,32,
IDE06308-MAS00111,Start request history data-Seconds,44,
IDE06308,Start request history data,not active,
IDE06308,Start request history data,Button for hill descent assist operated,
IDE06425-MAS02832,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06752,Hill descent control button,not activated,
IDE06921-MAS02472,Calculated vehicle speed-Qualification bit,OFF,
IDE06921,Calculated vehicle speed,0.00, km/h
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,01,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,09,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07905-MAS11308,Brake light switch status-"Driver braking" information from brake electronics,not activated,
IDE07905-MAS11309,Brake light switch status-"Driver braking" information from brake booster,not activated,
IDE07905-MAS11310,Brake light switch status-"Driver braking" information from brake electronics: qualif.,valid,
IDE07905-MAS11311,Brake light switch status-"Driver braking" information from brake booster: qualif.,valid,
IDE08343,Immobilizer Challenge,27 94 DD E1,
IDE08623,OBD configuration,NO OBD,
IDE09285,Reason for tire monitoring warning,No warning display on,
IDE09286,Software version of tire monitoring display,R1409j,
IDE09287,Param. set version tire press monitoring display,5N0E,
IDE09288,Param. set tire press monitor display: checksum,DF E4 65 56 42 EB 46 E1,
IDE09289,Tire press monitor.display: diagnosis status,00 00 00 00,
IDE09580-MAS09177,RPM sensor: air gap-Left front: med. value,00,
IDE09580-MAS09178,RPM sensor: air gap-Left front: minimum,00,
IDE09580-MAS09179,RPM sensor: air gap-Left front: maximum,00,
IDE09580-MAS09180,RPM sensor: air gap-Right front: med. value,00,
IDE09580-MAS09181,RPM sensor: air gap-Right front: minimum,00,
IDE09580-MAS09182,RPM sensor: air gap-Right front: maximum,00,
IDE09580-MAS09183,RPM sensor: air gap-Left rear: med. value,00,
IDE09580-MAS09184,RPM sensor: air gap-Left rear: minimum,00,
IDE09580-MAS09185,RPM sensor: air gap-Left rear: maximum,00,
IDE09580-MAS09186,RPM sensor: air gap-Right rear: med. value,00,
IDE09580-MAS09187,RPM sensor: air gap-Right rear: minimum,00,
IDE09580-MAS09188,RPM sensor: air gap-Right rear: maximum,00,
IDE09581-MAS01853,RPM sensor: configuration-Left front,Sensor with rotation direction detection,
IDE09581-MAS01854,RPM sensor: configuration-Right front,Sensor with rotation direction detection,
IDE09581-MAS01855,RPM sensor: configuration-Left rear,Sensor with rotation direction detection,
IDE09581-MAS01856,RPM sensor: configuration-Right rear,Sensor with rotation direction detection,
IDE09581-MAS12016,RPM sensor: configuration-Front axle: number of terminals,48,
IDE09581-MAS12017,RPM sensor: configuration-Rear axle: number of terminals,48,
IDE10034-MAS01853,RPM sensor: overall wiring fault-Left front,0.00, %
IDE10034-MAS01854,RPM sensor: overall wiring fault-Right front,0.00, %
IDE10034-MAS01855,RPM sensor: overall wiring fault-Left rear,0.00, %
IDE10034-MAS01856,RPM sensor: overall wiring fault-Right rear,0.00, %
IDE10034-MAS09178,RPM sensor: overall wiring fault-Left front: minimum,0.00, %
IDE10034-MAS09179,RPM sensor: overall wiring fault-Left front: maximum,0.00, %
IDE10034-MAS09181,RPM sensor: overall wiring fault-Right front: minimum,0.00, %
IDE10034-MAS09182,RPM sensor: overall wiring fault-Right front: maximum,0.00, %
IDE10034-MAS09184,RPM sensor: overall wiring fault-Left rear: minimum,0.00, %
IDE10034-MAS09185,RPM sensor: overall wiring fault-Left rear: maximum,0.00, %
IDE10034-MAS09187,RPM sensor: overall wiring fault-Right rear: minimum,0.00, %
IDE10034-MAS09188,RPM sensor: overall wiring fault-Right rear: maximum,0.00, %
IDE10035-MAS09177,RPM sensor: single separation fault-Left front: med. value,0.00, µs
IDE10035-MAS09178,RPM sensor: single separation fault-Left front: minimum,0.00, %
IDE10035-MAS09179,RPM sensor: single separation fault-Left front: maximum,0.00, %
IDE10035-MAS09180,RPM sensor: single separation fault-Right front: med. value,0.00, µs
IDE10035-MAS09181,RPM sensor: single separation fault-Right front: minimum,0.00, %
IDE10035-MAS09182,RPM sensor: single separation fault-Right front: maximum,0.00, %
IDE10035-MAS09183,RPM sensor: single separation fault-Left rear: med. value,0.00, µs
IDE10035-MAS09184,RPM sensor: single separation fault-Left rear: minimum,0.00, %
IDE10035-MAS09185,RPM sensor: single separation fault-Left rear: maximum,0.00, %
IDE10035-MAS09186,RPM sensor: single separation fault-Right rear: med. value,0.00, µs
IDE10035-MAS09187,RPM sensor: single separation fault-Right rear: minimum,0.00, %
IDE10035-MAS09188,RPM sensor: single separation fault-Right rear: maximum,0.00, %
IDE10348,Trip distance data,32 00 00 00 00 00 00 00 00 00 03 00 00 00 00 57 41 31 41 4E 41 46 59 39 4A 32 31 39 32 39 31 36 53 F0 25 57 3F 87 76 13 00 06 00 02 00 73 87 00,
IDE10372-MAS00102,Brake booster vacuum sensor 2-valid,Not coded,
IDE10636-MAS01447,Driving program for downhill driving assistance-Act.val.,0,
IDE10636-MAS01448,Driving program for downhill driving assistance-Specified value,2,
IDE10636-MAS05631,Driving program for downhill driving assistance-System status,Not available,
IDE10667-MAS01447,Driving program for brake electronics-Act.val.,2,
IDE10667-MAS01448,Driving program for brake electronics-Specified value,2,
IDE10667-MAS05631,Driving program for brake electronics-System status,Available,
IDE10787-MAS00106,Tire press. monitoring sys.: last warning-Year,2018, yr
IDE10787-MAS00107,Tire press. monitoring sys.: last warning-Month,11, mon
IDE10787-MAS00108,Tire press. monitoring sys.: last warning-Day,14, d
IDE10787-MAS00109,Tire press. monitoring sys.: last warning-Hours,8, H
IDE10787-MAS00110,Tire press. monitoring sys.: last warning-Minutes,38, min
IDE10787-MAS00711,Tire press. monitoring sys.: last warning-Odometer reading,13039, km
IDE10787-MAS02832,Tire press. monitoring sys.: last warning-Malfunction status,07 0F 00 00,
IDE10788-MAS00106,Tire press. monitoring sys.: second last warning-Year,2018, yr
IDE10788-MAS00107,Tire press. monitoring sys.: second last warning-Month,5, mon
IDE10788-MAS00108,Tire press. monitoring sys.: second last warning-Day,24, d
IDE10788-MAS00109,Tire press. monitoring sys.: second last warning-Hours,19, H
IDE10788-MAS00110,Tire press. monitoring sys.: second last warning-Minutes,47, min
IDE10788-MAS00711,Tire press. monitoring sys.: second last warning-Odometer reading,0, km
IDE10788-MAS02832,Tire press. monitoring sys.: second last warning-Malfunction status,02 05 00 00,
IDE10789-MAS00106,Tire press. monitoring sys.: third last warning-Year,2018, yr
IDE10789-MAS00107,Tire press. monitoring sys.: third last warning-Month,5, mon
IDE10789-MAS00108,Tire press. monitoring sys.: third last warning-Day,24, d
IDE10789-MAS00109,Tire press. monitoring sys.: third last warning-Hours,19, H
IDE10789-MAS00110,Tire press. monitoring sys.: third last warning-Minutes,41, min
IDE10789-MAS00711,Tire press. monitoring sys.: third last warning-Odometer reading,0, km
IDE10789-MAS02832,Tire press. monitoring sys.: third last warning-Malfunction status,02 05 00 00,
IDE10790-MAS00106,Tire press. monitoring sys.: fourth last warning-Year,2018, yr
IDE10790-MAS00107,Tire press. monitoring sys.: fourth last warning-Month,5, mon
IDE10790-MAS00108,Tire press. monitoring sys.: fourth last warning-Day,24, d
IDE10790-MAS00109,Tire press. monitoring sys.: fourth last warning-Hours,19, H
IDE10790-MAS00110,Tire press. monitoring sys.: fourth last warning-Minutes,40, min
IDE10790-MAS00711,Tire press. monitoring sys.: fourth last warning-Odometer reading,0, km
IDE10790-MAS02832,Tire press. monitoring sys.: fourth last warning-Malfunction status,03 06 00 00,
IDE10791-MAS00106,Tire press. monitoring sys.: fifth last warning-Year,2018, yr
IDE10791-MAS00107,Tire press. monitoring sys.: fifth last warning-Month,5, mon
IDE10791-MAS00108,Tire press. monitoring sys.: fifth last warning-Day,24, d
IDE10791-MAS00109,Tire press. monitoring sys.: fifth last warning-Hours,19, H
IDE10791-MAS00110,Tire press. monitoring sys.: fifth last warning-Minutes,38, min
IDE10791-MAS00711,Tire press. monitoring sys.: fifth last warning-Odometer reading,0, km
IDE10791-MAS02832,Tire press. monitoring sys.: fifth last warning-Malfunction status,03 06 00 00,
IDE10792-MAS00106,Tire press. monitoring sys.: last calibration-Year,2018, yr
IDE10792-MAS00107,Tire press. monitoring sys.: last calibration-Month,12, mon
IDE10792-MAS00108,Tire press. monitoring sys.: last calibration-Day,17, d
IDE10792-MAS00109,Tire press. monitoring sys.: last calibration-Hours,10, H
IDE10792-MAS00110,Tire press. monitoring sys.: last calibration-Minutes,3, min
IDE10792-MAS00711,Tire press. monitoring sys.: last calibration-Odometer reading,17083, km
IDE10792-MAS02201,Tire press. monitoring sys.: last calibration-Temperature,1, °C
IDE10793-MAS00106,Tire press. monitoring sys.: second last calibration-Year,2018, yr
IDE10793-MAS00107,Tire press. monitoring sys.: second last calibration-Month,11, mon
IDE10793-MAS00108,Tire press. monitoring sys.: second last calibration-Day,15, d
IDE10793-MAS00109,Tire press. monitoring sys.: second last calibration-Hours,19, H
IDE10793-MAS00110,Tire press. monitoring sys.: second last calibration-Minutes,29, min
IDE10793-MAS00711,Tire press. monitoring sys.: second last calibration-Odometer reading,13194, km
IDE10793-MAS02201,Tire press. monitoring sys.: second last calibration-Temperature,2, °C
IDE10794-MAS00106,Tire press. monitoring sys.: third last calibration-Year,2018, yr
IDE10794-MAS00107,Tire press. monitoring sys.: third last calibration-Month,7, mon
IDE10794-MAS00108,Tire press. monitoring sys.: third last calibration-Day,13, d
IDE10794-MAS00109,Tire press. monitoring sys.: third last calibration-Hours,10, H
IDE10794-MAS00110,Tire press. monitoring sys.: third last calibration-Minutes,12, min
IDE10794-MAS00711,Tire press. monitoring sys.: third last calibration-Odometer reading,11, km
IDE10794-MAS02201,Tire press. monitoring sys.: third last calibration-Temperature,31, °C
IDE10795-MAS00106,Tire press. monitoring sys.: fourth last calibration-Year,2018, yr
IDE10795-MAS00107,Tire press. monitoring sys.: fourth last calibration-Month,5, mon
IDE10795-MAS00108,Tire press. monitoring sys.: fourth last calibration-Day,24, d
IDE10795-MAS00109,Tire press. monitoring sys.: fourth last calibration-Hours,19, H
IDE10795-MAS00110,Tire press. monitoring sys.: fourth last calibration-Minutes,40, min
IDE10795-MAS00711,Tire press. monitoring sys.: fourth last calibration-Odometer reading,0, km
IDE10795-MAS02201,Tire press. monitoring sys.: fourth last calibration-Temperature,26, °C
IDE10796-MAS00106,Tire press. monitoring sys.: fifth last calibration-Year,2000, yr
IDE10796-MAS00107,Tire press. monitoring sys.: fifth last calibration-Month,0, mon
IDE10796-MAS00108,Tire press. monitoring sys.: fifth last calibration-Day,0, d
IDE10796-MAS00109,Tire press. monitoring sys.: fifth last calibration-Hours,0, H
IDE10796-MAS00110,Tire press. monitoring sys.: fifth last calibration-Minutes,0, min
IDE10796-MAS00711,Tire press. monitoring sys.: fifth last calibration-Odometer reading,0, km
IDE10796-MAS02201,Tire press. monitoring sys.: fifth last calibration-Temperature,0, °C
IDE11037,Brake light switch: qualification,active,
IDE11039,Tire pr.monit.sys.: counter for fast press. loss: le. frt,253,
IDE11040,Tire pr.monit.sys.: counter for fast pres.loss: ri. frt.,246,
IDE11041,Tire pr.monit.sys.:counter for fast press. loss: le. rr.,255,
IDE11042,Tire pr.monit.sys.: counter for fast press. loss: ri. rr.,249,
IDE11043,Tire pr.monit.sys.: counter for slow press. loss: le. frt,245,
IDE11044,Tire pr.monit.sys.: counter for slow press. loss: ri. frt.,235,
IDE11045,Tire pr.monit.sys.: counter for slow press. loss: le. rr.,255,
IDE11046,Tire pr.monit.sys.: counter for slow press. loss: ri. rr.,245,
IDE11053-MAS00179,Brake light switch: signal from engine ctrl. mod.-Brake Light Switch,Brake not actuated,
IDE11053-MAS12083,Brake light switch: signal from engine ctrl. mod.-"Driver braking" signal,not activated,
IDE11053-MAS12084,Brake light switch: signal from engine ctrl. mod.-"Driver braking" signal: qualification,valid,
IDE11053-MAS12085,Brake light switch: signal from engine ctrl. mod.-Brake pedal information: plausibility,plausible,
IDE80100,Analysis 100,0F 00 45 53 50 39 41 75 64 69 4D 4C 42 65 76 6F 01 00 55 AA 00 00 00 00 00 00 46 4C 4D 39 01 63 AF D0 02 10 FD 15 00 02 17 2F 00 00 DD 4B 00 00 15 E5 00 00 01 64 00 00 15 1F 00 00 00 00 00 29 71 2A 00 00 0D EF 00 57 08 0A 00 3E 6B 9A 00 49 BC A7 00 01 26 17 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 29 00 00 00 00 00 00 00 00 00 00 99 A0 00 00 00 00 00 00 00 00 4A 4C 41 52 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 08 D5 00 00 00 00 00 02 D6 71 00 56 64 08 00 15 E5 69 00 14 50 4E 00 12 69 AA 00 23 A5 FE 00 31 0A 05 00 4E FE E6 00 29 F5 DC 00 00 31 31 00 00 00 00 00 00 00 1F 00 00 00 8F 00 00 0F E9 00 00 6D 06 00 03 14 DE 00 0D 33 9A 00 2D 8F 5A 00 E5 B1 1E 00 2F FD 70 00 0D 0F AD 00 02 38 D3 00 00 4F 23 00 00 10 07 00 00 04 29 01 54 E5 3C 00 0B 00 B4 00 03 16 32 00 00 B0 BA 00 00 02 F4 00 00 00 00 00 00 02 DA 00 00 04 2D 00 00 01 C0 00 00 00 72 00 00 00 2C 00 00 01 3C 00 00 00 01 00 00 00 00 52 4F 54 48 00 00 00 22 00 01 60 91 00 00 00 00 00 00 06 B5 00 00 00 00 00 00 02 A4 00 00 00 00 00 00 04 D6 00 00 00 00 00 00 00 6B 00 00 00 A8 56 30 01 00 0D 41 00 00 00 0D 00 0B 00 01 00 06 00 05 00 38 00 79 00 D9 00 0E 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 E8 00 00 00 02 00 00 00 00 00 00 00 00 00 41 01 6F 00 26 00 99 00 04 00 00 00 00 00 00 00 00 02 35 00 1E 00 00 00 00 00 00 00 16 00 63 00 00 00 00 00 00 00 00 00 00 00 28 00 00 00 00 00 00 00 00 00 00 00 00 00 11 00 00 00 00 01 A3 00 00 44 44 00 0F 00 0F 00 2F 00 05 02 B3 00 DF 00 E7 00 C8 00 A9 00 6D 00 3D 00 00 04 9B 03 12 00 00 00 00 00 05 00 26 00 ED 01 AE 01 33 01 A3 00 68 00 01 01 43 00 24 00 00 00 00 00 00 00 00 00 00 00 00 07 C2 00 C3 00 00 00 00 11 C0 00 00 00 00 00 00 00 1D 00 01 00 01 00 00 00 03 00 02 00 00 00 00 00 41 00 00 00 00 01 48 00 3E 00 1B 00 01 00 01 00 00 07 28 03 D9 00 4B 00 00 00 00 00 00 00 18 00 01 00 00 00 00 00 00 07 E4 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 27 00 00 00 00 00 00 00 00 44 44 00 00 00 00 00 07 00 02 00 00 00 00 00 01 00 17 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF 00 63 00 1C A8 B6 00 00 00 00 3D B5 00 00 00 00 5D 51 00 00 00 00 14 92 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44 00 00 00 00 03 00 00 00 44 03 07 15 19 05 08 00 00 00 02 44 00 02 D2 00 01 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 00 0C A0 00 1A DC 29 7F 4D 04 AF 94 00 01 B0 00 00 5C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 17 00 00 00 00 00 00 00 02 99 00 00 00 00 00 00 00 00 00 44 00 07 C8 00 00 00 00 00 00 00 0F 08 00 1B 9D 00 11 5F 00 07 AF 04 5A 01 6E 00 2D 00 00 00 00 00 04 00 03 00 19 00 D6 00 04 86 00 40 10 00 06 91 01 42 00 38 00 02 00 00 00 00 00 00 00 2B 00 06 00 07 00 0F 00 0E 00 17 00 26 00 34 00 00 47 00 00 88 00 00 B7 01 3F 05 00 00 59 00 01 67 00 19 C3 00 30 1C 00 03 6C 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 73 F1 00 72 7B 00 26 52 00 0D F1 00 05 F5 00 06 27 03 8C 69 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44 00 00 00 00 00 7D 00 00 00 4F 04 00 00 62 04 80 3B 00 8B 00 37 00 02 00 00 01 6B 09 65 0A 12 04 6C 02 34 01 78 00 EE 00 8B 00 FA 00 6E 00 02 00 00 00 09 00 62 00 BE 00 8C 00 71 00 5B 00 46 00 2A 79 21 00 00 00 00 01 00 12 00 19 3B 00 8B 00 37 00 02 00 00 01 6B 09 65 0A 12 04 6C 02 34 01 78 00 EE 00 8B 00 FA 00 6E 00 02 00 00 00 09 00 62 00 BE 00 8C 00 71 00 5B 00 46 00 2A 79 21 00 00 00 00 01 00 12 00 19 00 1A 00 05 00 04 00 00 00 00 00 00 00 01 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 69 00 57 00 02 00 00 00 00 00 11 00 24 00 03 00 00 00 00 00 06 00 04 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 03 00 00 02 00 00 08 00 00 00 00 00 04 00 00 06 00 00 18 00 00 47 00 00 90 00 00 EF 00 00 05 00 00 1F 00 00 35 00 01 77 00 03 1B 00 05 A7 00 08 34 00 00 51 00 00 3D 00 01 34 00 05 41 00 0A A9 00 14 6D 00 1A E2 00 01 34 00 00 AD 00 02 49 00 06 B4 00 0B 50 00 17 AB 00 1C 0D 00 00 A6 00 0D FD 00 13 BE 00 08 A0 00 05 F7 00 0D D6 00 0F 94 00 00 2B 53 00 00 00 01 00 1B 01 6E 01 E0 00 26 00 00 00 00 00 00 00 03 00 2A 00 24 00 01 00 00 00 00 00 00 00 03 00 1F 00 2A 00 03 00 00 00 00 00 01 00 03 00 17 00 17 00 04 00 00 00 00 00 00 00 00 00 0B 00 07 00 03 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 14 02 D7 09 39 01 BE 00 17 00 00 00 00 00 0B 00 DE 01 1D 00 14 00 02 00 00 00 00 00 00 00 00 11 00 01 71 00 01 57 00 00 20 00 00 01 00 00 00 00 00 00 00 00 24 00 01 AE 00 01 98 00 00 28 00 00 06 00 00 00 00 00 02 00 00 0E 00 00 8B 00 00 CF 00 00 35 00 00 01 00 00 00 00 00 00 00 00 02 00 00 20 00 00 25 00 00 0A 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 00 E8 06 49 04 03 00 84 00 00 00 00 00 04 00 C0 02 48 00 89 00 0D 00 00 00 00 00 00 00 00 09 00 01 D9 00 03 CF 00 00 9E 00 00 0B 00 00 00 00 00 00 00 00 13 00 02 3D 00 04 64 00 00 D9 00 00 0D 00 00 00 00 00 00 00 00 09 00 00 D9 00 02 DD 00 01 1F 00 00 1E 00 00 00 00 00 00 00 00 08 00 00 7F 00 01 51 00 00 98 00 00 11 00 00 00 00 00 00 00 00 00 00 00 02 00 00 03 00 00 02 00 00 00 00 00 00 00 00 00 00 29 03 4B 06 5B 02 39 00 00 00 00 00 02 00 26 01 76 01 42 00 3F 00 00 00 00 00 00 00 00 03 00 00 71 00 03 60 00 02 0C 00 00 50 00 00 00 00 00 00 00 00 06 00 00 B2 00 04 93 00 02 26 00 00 32 00 00 00 00 00 00 00 00 01 00 00 86 00 04 5B 00 03 90 00 00 95 00 00 00 00 00 00 00 00 00 00 00 5C 00 02 FF 00 02 D7 00 00 8A 00 00 00 00 00 00 00 00 00 00 00 02 00 00 0B 00 00 09 00 00 02 00 00 00 00 00 00 00 0D 00 BD 04 87 07 03 00 00 00 00 00 00 00 08 00 B1 01 A3 00 C5 00 00 00 00 00 00 00 00 00 00 00 13 00 01 75 00 03 06 00 00 E7 00 00 00 00 00 00 00 00 00 00 00 18 00 02 55 00 03 4E 00 00 BD 00 00 00 00 00 00 00 00 00 00 00 17 00 02 8E 00 05 AB 00 01 A8 00 00 00 00 00 00 00 00 00 00 00 16 00 02 52 00 05 00 00 01 E7 00 00 00 00 00 00 00 00 00 00 00 01 00 00 08 00 00 19 00 00 05 00 00 00 00 00 00 00 01 00 1C 01 9F 09 F4 00 00 00 00 00 00 00 00 00 24 01 12 01 7A 00 00 00 00 00 00 00 00 00 00 00 01 00 00 61 00 02 59 00 01 B6 00 00 00 00 00 00 00 00 01 00 00 01 00 00 A7 00 03 36 00 01 00 00 00 00 7D 00 00 00 29 03 00 00 62 04 80 00 00 00 00 00 00 00 00 00 04 00 75 0A F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 15 00 01 94 00 08 58 00 00 00 00 00 00 00 00 00 00 00 02 00 00 1D 00 02 97 00 07 0B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 75 0A F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 15 00 01 94 00 08 58 00 00 00 00 00 00 00 00 00 00 00 02 00 00 1D 00 02 97 00 07 0B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 03 87 00 0C 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16 00 02 EA 00 0B A4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 1C 00 00 93 50 39 36 31 38 36 00 07 29 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS06948-ENG56075,Brake bleeding and replacement check hydraulic connections-Measurement_Value_Basic_Setting,Ready to start,
ENG04544,Accelerator_pedal_position_requested_by_driver_or_cruise_control,0.00, %
ENG04547-ENG04671,Apply Counter left_right-Left_Brake_Full_Clamping_Force,478,
ENG04547-ENG04672,Apply Counter left_right-Left_Brake_Reduced_Clamping_Force,0,
ENG04547-ENG04669,Apply Counter left_right-Right_Brake_Full_Clamping_Force,479,
ENG04547-ENG04670,Apply Counter left_right-Right_Brake_Reduced_Clamping_Force,0,
ENG04525-ENG101167,BB_Num_and_SW_Version-Base version,7705,
ENG04525-ENG101969,BB_Num_and_SW_Version-BB-No.,96186,
ENG04525-ENG98430,BB_Num_and_SW_Version-Branch 1,0100,
ENG04525-ENG98431,BB_Num_and_SW_Version-Branch 2,0000,
ENG07087-ENG04744,Bootloader_Bosch_Signature_Status-Bosch_Signature,Yes,
ENG04560-IDE04450,Brake_pressure_at_BLS_change-Brake pressure sensor 1,31.961, bar
ENG04532,BTM_Driving_with_pushed_brakes,0, s
ENG04533-MAS00106,BTM_Last_occurence_of_driving_with_pushed_brakes-Year,2000, yr
ENG04533-MAS00107,BTM_Last_occurence_of_driving_with_pushed_brakes-Month,0, mon
ENG04533-MAS00108,BTM_Last_occurence_of_driving_with_pushed_brakes-Day,0, d
ENG04530-MAS00106,BTM_Last_occurence_of_maximum_temp_FL-Year,2019, yr
ENG04530-MAS00107,BTM_Last_occurence_of_maximum_temp_FL-Month,2, mon
ENG04530-MAS00108,BTM_Last_occurence_of_maximum_temp_FL-Day,25, d
ENG04528-MAS00106,BTM_Last_occurence_of_temperature_FL_greater_than_temp_limit-Year,2000, yr
ENG04528-MAS00107,BTM_Last_occurence_of_temperature_FL_greater_than_temp_limit-Month,0, mon
ENG04528-MAS00108,BTM_Last_occurence_of_temperature_FL_greater_than_temp_limit-Day,0, d
ENG04534-MAS00106,BTM_Last_reset_of_driving_with pushed_brakes-Year,2000, yr
ENG04534-MAS00107,BTM_Last_reset_of_driving_with pushed_brakes-Month,0, mon
ENG04534-MAS00108,BTM_Last_reset_of_driving_with pushed_brakes-Day,0, d
ENG04531-MAS00106,BTM_Last_reset_of_maximum_temp_FL-Year,2000, yr
ENG04531-MAS00107,BTM_Last_reset_of_maximum_temp_FL-Month,0, mon
ENG04531-MAS00108,BTM_Last_reset_of_maximum_temp_FL-Day,0, d
ENG04529-MAS00106,BTM_Last_reset_of_temperature_FL_greater_than_temp_limit-Year,2000, yr
ENG04529-MAS00107,BTM_Last_reset_of_temperature_FL_greater_than_temp_limit-Month,0, mon
ENG04529-MAS00108,BTM_Last_reset_of_temperature_FL_greater_than_temp_limit-Day,0, d
ENG04545,BTM_Maximum_temp_of_temperature_brake_FL,255.00, °C
ENG04527,BTM_Time_of_temperature_FL_greater_than_temp_limit,0, s
ENG101413,Calibration Identification,80A379J 0775 00,
ENG99697,Calibration Verification Number,01 74 74 0A,
ENG04552-ENG04693,Driver_Presence_Status-Input_Signal_A_Belt_Error,no error,
ENG04552-ENG04692,Driver_Presence_Status-Input_Signal_A_Belt_Status,not selected,
ENG04552-ENG04695,Driver_Presence_Status-Input_Signal_B_Door_Error,no error,
ENG04552-ENG04694,Driver_Presence_Status-Input_Signal_B_Door_Status,Open,
ENG04562-MAS02141,DSDL_VIN_Check_Status-Monitoring VIN,active,
ENG04562-ENG04743,DSDL_VIN_Check_Status-VIN_Check_Status,performed,
ENG100152-ENG104003,ECUNAME-ECU,BSC,
ENG100152,ECUNAME,-BrakeSystem,
ENG04543,EDS_active_flag,passive,
ENG04539-MAS00109,Engine_off_time-Hours,0, H
ENG04539-MAS00110,Engine_off_time-Minutes,12, min
ENG04542,Engine_torque_loss,1, Nm
ENG04540,Engine_torque_with_external_intervention,509, Nm
ENG04548-ENG04677,ESC_EPBi_Dataset_Daten-ESC_DS_Compatibility_Version,0000,
ENG04548-ENG04675,ESC_EPBi_Dataset_Daten-ESC_EPBi_DS_Checksums,2B F4 49 CE,
ENG04548-ENG04673,ESC_EPBi_Dataset_Daten-ESC_EPBi_DS_LogAdr,71 06,
ENG04548-ENG04674,ESC_EPBi_Dataset_Daten-ESC_EPBi_DS_Version,----,
ENG04548-ENG04676,ESC_EPBi_Dataset_Daten-ESC_SW_Compatibility_Version,0000,
ENG04548-ENG04679,ESC_EPBi_Dataset_Daten-PBC_DS_Checksums,30 6B,
ENG04548-ENG32276,ESC_EPBi_Dataset_Daten-PBC_DS_Compatibility_Version,00 1C,
ENG04548-ENG04678,ESC_EPBi_Dataset_Daten-PBC_DS_Version,0003,
ENG04549-ENG04682,ESC_EPBi_Dataset_Satus-ESC_Dataset_Status_Compatibility,valid,
ENG04549-ENG04681,ESC_EPBi_Dataset_Satus-ESC_Dataset_Status_CS,Correct result,
ENG04549-ENG04684,ESC_EPBi_Dataset_Satus-PBC_Dataset_Status_Compatibility,valid,
ENG04549-ENG04683,ESC_EPBi_Dataset_Satus-PBC_Dataset_Status_CS,Correct result,
ENG07646,ESC_Function_mode,1,
ENG07088-ENG07109,ESP_Charisma_interface_signals-CHA_Ziel_FahrPr_ESP,2,
ENG07088-ENG07110,ESP_Charisma_interface_signals-ESP_Charisma_FahrPr,2,
ENG07088-ENG07111,ESP_Charisma_interface_signals-ESP_Charisma_Status,Init,
ENG04523,ESP_Sensor_unit_2_lateral_acceleration_confidence_factor,5,
ENG04521,ESP_Sensor_unit_2_turn_rate_confidence_factor,5,
ENG04522,ESP_Sensor_unit_lateral_acceleration_confidence_factor,0,
ENG04524,ESP_Sensor_unit_longitudinal_acceleration_confidence_factor,0,
ENG04520,ESP_Sensor_unit_turn_rate_confidence_factor,0,
ENG04536,FIBEX_Version,0811_00,
ENG04537,Lateral_acceleration_sensor_2_minus_lateral_acceleration_sensor_1,-0.76800, m/s²
ENG111914-ENG04664,NoPata-BME Last5ICs,00000000 ,
ENG111914-ENG04660,NoPata-BME ThisIC,00000000 ,
ENG111914-ENG111902,NoPata-EPB Last5ICs,00000000 ,
ENG111914-ENG111895,NoPata-EPB ThisIC,00000000 ,
ENG111914-ENG111900,NoPata-Handtaschenlogik Last5ICs,00000000 ,
ENG111914-ENG111893,NoPata-Handtaschenlogik ThisIC,00000000 ,
ENG111914-ENG111904,NoPata-LUFE Last5ICs,00000000 ,
ENG111914-ENG111897,NoPata-LUFE ThisIC,00000000 ,
ENG111914-ENG111905,NoPata-QSP Last5ICs,00000000 ,
ENG111914-ENG111898,NoPata-QSP ThisIC,00000000 ,
ENG111914-ENG04663,NoPata-SCM Last5ICs,00000000 ,
ENG111914-ENG04659,NoPata-SCM ThisIC,00000000 ,
ENG111914-ENG111906,NoPata-Spoiler Last5ICs,00000000 ,
ENG111914-ENG111899,NoPata-Spoiler ThisIC,00000000 ,
ENG111914-ENG04662,NoPata-Systemdegradation Last5ICs,00000000 ,
ENG111914-ENG04658,NoPata-Systemdegradation ThisIC,00000000 ,
ENG111914-ENG04665,NoPata-TSK Last5ICs,00000000 ,
ENG111914-ENG04661,NoPata-TSK ThisIC,00000000 ,
ENG04553,PBC_SW_Version,089_00,
ENG04526-ENG99585,Steering_angle_sensor_data-LWI_QBit_Steering_wheel_angle,active,
ENG04526-ENG100735,Steering_angle_sensor_data-LWI_QBit_sub_data,active,
ENG04526-ENG99156,Steering_angle_sensor_data-LWI_sensor_status,OK,
ENG04526-ENG04627,Steering_angle_sensor_data-LWI_sub_data_SSI,valid,
ENG07092-ENG07114,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Day,31,
ENG07092-ENG07115,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Hour,31, H
ENG07092-ENG07118,Time_Mileage_RollerBenchMode_907_Deactivation-RBM KM,1048575, km
ENG07092-ENG07116,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Minute,63, min
ENG07092-ENG07113,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Month,15, mon
ENG07092-ENG07117,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Second,63, s
ENG07092-ENG07112,Time_Mileage_RollerBenchMode_907_Deactivation-RBM Year,2127, yr
ENG04561-ENG04713,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Day,31,
ENG04561-ENG04714,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Hour,31, H
ENG04561-ENG04717,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 KM,1048575, km
ENG04561-ENG04715,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Minute,63, min
ENG04561-ENG04712,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Month,15, mon
ENG04561-ENG04716,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Second,63, s
ENG04561-ENG04718,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Status,active,
ENG04561-ENG04711,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Year,2127, yr
ENG04561-ENG04721,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Day,31,
ENG04561-ENG04722,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Hour,31, H
ENG04561-ENG04725,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 KM,1048575, km
ENG04561-ENG04723,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Minute,63, min
ENG04561-ENG04720,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Month,15, mon
ENG04561-ENG04724,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Second,63, s
ENG04561-ENG04726,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Status,active,
ENG04561-ENG04719,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Year,2127, yr
ENG04561-ENG04729,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Day,31,
ENG04561-ENG04730,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Hour,31, H
ENG04561-ENG04733,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 KM,1048575, km
ENG04561-ENG04731,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Minute,63, min
ENG04561-ENG04728,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Month,15, mon
ENG04561-ENG04732,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Second,63, s
ENG04561-ENG04734,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Status,active,
ENG04561-ENG04727,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Year,2127, yr
ENG04561-ENG04737,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Day,31,
ENG04561-ENG04738,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Hour,31, H
ENG04561-ENG04741,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 KM,1048575, km
ENG04561-ENG04739,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Minute,63, min
ENG04561-ENG04736,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Month,15, mon
ENG04561-ENG04740,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Second,63, s
ENG04561-ENG04742,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Status,active,
ENG04561-ENG04735,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Year,2127, yr
ENG110108-ENG103252,WAU Info KL15-FlexRay Transceiver PIN,passive,
ENG110108-ENG102268,WAU Info KL15-Klemme 15 PIN,active,
ENG04535,YAW_rate_sensor_2_minus_yawrate_sensor_1,0.00000, rad/s
Elapsed Time: 00:33
adpmap-03-80A-907-379-J
;Friday,12,July,2019,16:06:45:64285
IDE00001-IDE01211-Production mode-Static current measuring mode,Deactivating ,3
IDE00001-IDE09543-Production mode-Vehicle holding function,Deactivating ,3
IDE00001-MAS16682-Production mode-Production mode after-run monitoring,Deactivating ,3
IDE00820-ENG135838-Activating and deactivating all development messages-EWB_DEV_EPB_01,not activated ,3
IDE00820-ENG135837-Activating and deactivating all development messages-EWB_DEV_ESP_01,not activated ,3
IDE00820-ENG135839-Activating and deactivating all development messages-EWB_DEV_RKA_01,not activated ,3
IDE00820-ENG135834-Activating and deactivating all development messages-EWB_S100,not activated ,3
IDE00820-ENG135835-Activating and deactivating all development messages-EWB_S101,not activated ,3
IDE00820-ENG135836-Activating and deactivating all development messages-EWB_S102,not activated ,3
IDE00820-ENG102355-Activating and deactivating all development messages-Internal System Error Number,00 00 ,3
IDE02630-MAS09081-ESP coasting operation-Axis for vehicle speed measurement,Front axle activated ,1
IDE02630-MAS09082-ESP coasting operation-Roller operation ESP: status,not active ,1
IDE02631-Brake disc wiper,normal ,1
IDE08134-Automatic parking brake,not activated ,1
IDE08220-Vehicle production mode-,Deactivating ,4
IDE08801-Tire press. monitor. sys: position display,Default ,1
IDE09290-Tire press monitor.display: warning sensitivity,0 ,1
IDE09537-Driver warn. during hill descent,active ,1
IDE09539-Tripping threshold for start-up assist.,normal ,1
IDE09540-ENG101644-Install. position of wheel speed sens.-Wheel FL,regularly ,1
IDE09540-ENG102524-Install. position of wheel speed sens.-Wheel FR,regularly ,1
IDE09540-ENG99883-Install. position of wheel speed sens.-Wheel RL,regularly ,1
IDE09540-ENG99053-Install. position of wheel speed sens.-wheel rr,regularly ,1
IDE09541-Brake direction holding function,OFF ,1
IDE10866-Hold management in production mode,Deactivating ,1
IDE10867-MAS11564-Hold management in transport mode-Local activation,Deactivating ,1
IDE10867-MAS13351-Hold management in transport mode-Automatically take over transport mode,Activate ,1
IDE11038-Automatic closing if error in button for parking brake,activated ,1
IDE11628-Analysis data: status,activated ,1
ENG135668-auto_hold_seatbelt_evaluation,Activate ,1
ENG135671-ENG135644-Dimmung_EPB_TaLa-Pos1_KL_58xd,1 ,6
ENG135671-ENG135645-Dimmung_EPB_TaLa-Pos2_KL_58xd,1 ,6
ENG135671-ENG135646-Dimmung_EPB_TaLa-Pos3_KL_58xd,10 ,6
ENG135671-ENG135647-Dimmung_EPB_TaLa-Pos4_KL_58xd,25 ,6
ENG135671-ENG135648-Dimmung_EPB_TaLa-Pos5_KL_58xd,60 ,6
ENG135671-ENG135649-Dimmung_EPB_TaLa-Pos6_KL_58xd,100 ,6
ENG135665-Driving_Steering_Recommendation,active ,1
ENG135670-DSDL_EOLCheck,not active ,1
ENG106318-ESP_ASR,ESC_Vollsystem ,1
ENG135666-Fading_Assistant_FBS_HFC_HPS,active ,1
ENG135672-Glaettung_PWM_Dimmung,not active ,1
ENG138177-HDC_switch_on_configuration,Vorschlag: button_only ,1
ENG135673-Nominal_Voltage_dimming,13.00 V,1
ENG135669-Powertrain_Protection,active ,1
ENG167431-Reset_ESC_Maximal_System_Runtime,valid value stored ,1
ENG135662-Reset_RKA_Maximal_System_Runtime,valid value stored ,1
ENG135660-RKA_Datalog_Mode,datalog off ,1
ENG135661-RKA_Simulation_Mode,00 00 ,2
ENG135663-RKA_Stop-Start,use real Kl.15 ,1
ENG100419-text_warning,active ,1
ENG100453-VIN_monitoring,active ,1
Elapsed Time: 00:14
blockmap-08-80A-820-043-K
;SW:80A-820-043-K   HW:80A-820-043-K ---  Auto HVAC
;Component:Klima Zone 3  H60 0210, Coding:640801095544000D10000100080000000000000000000000000000000000
;EV_AirCondiBHTCAU491,001013,EV_AirCondiBHTCAU491.rod
;Friday,12,July,2019,16:07:01:64285
;VCID: A50DF2D4A41A9B674A-80F0
IDE00019,Voltage terminal 30,14.16, V
IDE00021,Engine speed,797, /min
IDE00025,Coolant temperature,110.20, °C
IDE00198,Refrigerant pressure,15.00, bar
IDE00767,No. of unscheduled ECU resets,8,
IDE00965,Compressor shut-off requirement,Compressor active: no shut-off condition is present,
IDE00966,Compressor current: actual value,0.48, A
IDE00967,Compressor current: specified value,0.49, A
IDE00970,Coolant fan activation: actual value,48.00, %
IDE00971,Coolant fan activation: specified value,48.40, %
IDE00972,Idle speed increase,not active,
IDE00973,Outside air temperature,30.50, °C
IDE00974,Outside air temperature internally calculated,29.00, °C
IDE00976,Left front vent temperature,8.70, °C
IDE00977,Right front vent temperature,9.90, °C
IDE00979,Left footwell vent temperature,22.90, °C
IDE00980,Right footwell vent temperature,21.40, °C
IDE00982,Temperature after evaporator,3.40, °C
IDE00983,Interior temperature,27.60, °C
IDE00984,Sun intensity left,90, W/m²
IDE00985,Sun intensity right,380, W/m²
IDE01063,Status of recirculation air,Partial recirc.,
IDE01065,Rear vent temperature,19.50, °C
IDE01066,Convertible top status,closed,
IDE01076,Time since ignition off,0, min
IDE01217-MAS01448,Left heated seat stage-Specified value,0,
IDE01218-MAS01448,Right heated seat stage-Specified value,0,
IDE01227,Blower current,3.00, A
IDE01232,Supply voltage for external components,5.00, V
IDE01287,Counter of compressor switch-offs,0,
IDE01309,Recirculation air flap motor: actual value,11027,
IDE01311,Left side vent flap motor: actual value,10000,
IDE01312,Right side vent flap motor: actual value,10000,
IDE01319,Rear temperature flap motor: actual value,10384,
IDE01328-IDE09056,Recirculation air flap motor: diagnostic-Last operating state,Move flap motor,
IDE01328-MAS01458,Recirculation air flap motor: diagnostic-Operating condition,No routine started,
IDE01330-IDE09056,Left side vent flap motor: diagnostic-Last operating state,Engine start,
IDE01330-MAS01458,Left side vent flap motor: diagnostic-Operating condition,No routine started,
IDE01331-IDE09056,Right side vent flap motor: diagnostic-Last operating state,Blocking,
IDE01331-MAS01458,Right side vent flap motor: diagnostic-Operating condition,No routine started,
IDE01338-IDE09056,Rear temperature flap motor: diagnosis-Last operating state,Move flap motor,
IDE01338-MAS01458,Rear temperature flap motor: diagnosis-Operating condition,No routine started,
IDE01352,Temperature unit,°F,
IDE01419,Compressor shut-off condition: last,Malfunction on fresh air blower,
IDE01420,Compressor shut-off requirement: penultimate,Shut-off from Engine Control Module (ECM) via CAN,
IDE01421,Compressor shut-off requirement: antepenultimate,Malfunction on fresh air blower,
IDE01425,Defrost flap motor: actual value,10000,
IDE01426,Left temperature flap motor: actual value,10000,
IDE01427,Right temperature flap motor: actual value,10000,
IDE01428-IDE09056,Defrost flap motor: diagnostic-Last operating state,Engine start,
IDE01428-MAS01458,Defrost flap motor: diagnostic-Operating condition,No routine started,
IDE01429-IDE09056,Left temperature flap motor: diagnostic-Last operating state,Engine start,
IDE01429-MAS01458,Left temperature flap motor: diagnostic-Operating condition,No routine started,
IDE01430-IDE09056,Right temperature flap motor: diagnostic-Last operating state,Engine start,
IDE01430-MAS01458,Right temperature flap motor: diagnostic-Operating condition,No routine started,
IDE01433,Air quality status,Clean air,
IDE01442-IDE10964,Pressing a button-Button for instrument panel vents,not activated,
IDE01442-MAS01533,Pressing a button-Defrost,not activated,
IDE01442-MAS01534,Pressing a button-Recirculating air,not activated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,not activated,
IDE01442-MAS01536,Pressing a button-Left pressure knob,not activated,
IDE01442-MAS01537,Pressing a button-Right pressure knob,not activated,
IDE01442-MAS01538,Pressing a button-Left air distribution,not activated,
IDE01442-MAS01539,Pressing a button-Right air distribution,not activated,
IDE01442-MAS01545,Pressing a button-AUTO left,not activated,
IDE01442-MAS01546,Pressing a button-AUTO right,not activated,
IDE01442-MAS01547,Pressing a button-Air quantity left,not activated,
IDE01442-MAS01548,Pressing a button-Air quantity right,not activated,
IDE01442-MAS01550,Pressing a button-AC,not activated,
IDE01442-MAS01554,Pressing a button-Left heated seat,not activated,
IDE01442-MAS01555,Pressing a button-Left seat ventilation,not activated,
IDE01442-MAS01556,Pressing a button-Right heated seat,not activated,
IDE01442-MAS01557,Pressing a button-Right seat ventilation,not activated,
IDE01442-MAS01560,Pressing a button-OFF,not activated,
IDE01442-MAS02015,Pressing a button-AUTO,not activated,
IDE01442-MAS02191,Pressing a button-Air quantity,not activated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,not activated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,not activated,
IDE01442-MAS03832,Pressing a button-Air distribution up,not activated,
IDE01442-MAS04621,Pressing a button-Left cabin heater,not activated,
IDE01442-MAS04648,Pressing a button-Right cabin heater,not activated,
IDE01442-MAS07066,Pressing a button-AC max/eco,not activated,
IDE01442-MAS07154,Pressing a button-Input mode,not activated,
IDE01442-MAS07155,Pressing a button-A/C mode,not activated,
IDE01455,Key number,2,
IDE01622,Fresh air blower: speed,2020, /min
IDE01689,Left rear footwell vent temperature,31.50, °C
IDE01985-MAS06855,FAZIT identification test sum-Test sum,86 52 92 5A,
IDE02492,Start-stop function: coding information,Start-stop function in control module active,
IDE02834,Fresh air flap motor: actual value,10427,
IDE02835-IDE09056,Fresh air flap motor: diagnostic-Last operating state,Move flap motor,
IDE02835-MAS01458,Fresh air flap motor: diagnostic-Operating condition,No routine started,
IDE03008-IDE80251,Stop process prevented-Head area heater,not active,
IDE03008-MAS00385,Stop process prevented-Basic setting active,not active,
IDE03008-MAS01957,Stop process prevented-Outside air temperature,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to setting,not active,
IDE03008-MAS02803,Stop process prevented-Interior vent difference to setting,active,
IDE03008-MAS03902,Stop process prevented-Stop release for A/C comfort adaptation,not active,
IDE03010-IDE80251,Number of prevented stop processes-Head area heater,0,
IDE03010-MAS00385,Number of prevented stop processes-Basic setting active,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,272,
IDE03010-MAS01957,Number of prevented stop processes-Outside air temperature,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to setting,1867,
IDE03010-MAS02803,Number of prevented stop processes-Interior vent difference to setting,2465,
IDE03010-MAS03902,Number of prevented stop processes-Stop release for A/C comfort adaptation,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),133,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),240,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,1353,
IDE03011-IDE80251,Number of requested start processes-Head area heater,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,1,
IDE03011-MAS01957,Number of requested start processes-Outside air temperature,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to setting,0,
IDE03011-MAS02803,Number of requested start processes-Interior vent difference to setting,13,
IDE03011-MAS03902,Number of requested start processes-Stop release for A/C comfort adaptation,0,
IDE03011-MAS03903,Number of requested start processes-Dew point gradient,0,
IDE03011-MAS03904,Number of requested start processes-maximum stop duration reached,66,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),1,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),7,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,2,
IDE03212,Start-stop conditions,Stop prohibition: no start request,
IDE03213,Start-stop enabling,No release by coordinator,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,1178, s
IDE04312-MAS00084,System run time-Terminal 15 on,1267, s
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,228,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,supported,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,supported,
IDE05738-ENG06682,Subssystem diagnosis classes-DC2/DC2F_sysystems,supported,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Not supported,
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,numerical value: no text,
IDE06091-MAS04647,Humidity sensor: internal-Dew point,numerical value: no text,
IDE06091-ENG07792,Humidity sensor: internal-dew_point_Textual,numerical value: no text,
IDE06091-ENG29452,Humidity sensor: internal-relative_humidity_Textual,numerical value: no text,
IDE06163-MAS04628,External humidity sensor-Air temperature,47.70, °C
IDE06163-MAS04630,External humidity sensor-Relative humidity,21.00, %
IDE06163-MAS04647,External humidity sensor-Dew point,23.70, °C
IDE06163-ENG29450,External humidity sensor-Air temperature_Textual,numerical value: no text,
IDE06163-ENG07792,External humidity sensor-dew_point_Textual,numerical value: no text,
IDE06163-ENG29452,External humidity sensor-relative_humidity_Textual,numerical value: no text,
IDE06234-IDE01270,Auxiliary heater: in stages-Enabling for auxiliary heater operation,No enabling,
IDE06234-MAS01447,Auxiliary heater: in stages-Act.val.,6,
IDE06234-MAS01448,Auxiliary heater: in stages-Specified value,0,
IDE06307-MAS00108,Stop prevention history data-Day,12,
IDE06307-MAS00109,Stop prevention history data-Hours,14,
IDE06307-MAS00110,Stop prevention history data-Minutes,53,
IDE06307-MAS00111,Stop prevention history data-Seconds,36,
IDE06307,Stop prevention history data,Interior temperature difference to setting,
IDE06307,Stop prevention history data,Interior vent difference to setting,
IDE06308-MAS00106,Start request history data-Year,2019,
IDE06308-MAS00107,Start request history data-Month,7,
IDE06308-MAS00108,Start request history data-Day,11,
IDE06308-MAS00109,Start request history data-Hours,7,
IDE06308-MAS00110,Start request history data-Minutes,11,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308,Start request history data,Interior vent difference to setting,
IDE06807,Fresh-air door motor / specified value,10427,
IDE06808,Fresh-air door motor / dynamics,1221,
IDE06809,Left temp. door motor / specified value,10000,
IDE06810,Left temp. door motor / dynamics,1456,
IDE06811,Right temp. door motor: specified value,10000,
IDE06812,Right temp. door motor: dynamics,1453,
IDE06813,Defroster door motor: specified value,10000,
IDE06814,Defroster door motor: dynamics,1536,
IDE06815,Recirc. air flap motor: spec.value,11027,
IDE06816,Recirc. air flap motor: dynamics,1581,
IDE06817,Rear temp. door motor: specified value,10384,
IDE06818,Rear temp. door motor: dynamics,1588,
IDE07133,Fresh air blower motor: temperature,35, °C
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,08,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07499,Left side vent flap motor: spec.value,10000,
IDE07500,Left side vent flap motor: dynamics,4061,
IDE07501,Right side vent flap motor: spec. value,10000,
IDE07502,Right side vent flap motor: dynamics,4076,
IDE07950-IDE04095,Historical data of motors-Engine running time,510, s
IDE07950-IDE09056,Historical data of motors-Last operating state,No routine started,
IDE07950-MAS00084,Historical data of motors-Terminal 15 on,510, s
IDE07950-MAS00106,Historical data of motors-Year,2019,
IDE07950-MAS00107,Historical data of motors-Month,5,
IDE07950-MAS00108,Historical data of motors-Day,8,
IDE07950-MAS00109,Historical data of motors-Hours,14,
IDE07950-MAS00110,Historical data of motors-Minutes,38,
IDE07950-MAS00111,Historical data of motors-Seconds,33,
IDE07950-MAS01458,Historical data of motors-Operating condition,Dynamic calibration,
IDE07950,Historical data of motors,17.50, V
IDE07950,Historical data of motors,32,
IDE07965,Rear air distribution flap motor: actual value,14307,
IDE07966,Rear air distr.flap mot.:spec.val,14307,
IDE07967,Rear air distribution flap motor: dynamic,6325,
IDE08343,Immobilizer Challenge,0D 5E D6 8E,
IDE08372,Fresh air blower: target speed,2020, /min
IDE08774-MAS01453,Fresh air blower: error status-Blocking detection,not active,
IDE08774-MAS01478,Fresh air blower: error status-Insuff. voltage,not active,
IDE08774-MAS01479,Fresh air blower: error status-Excess voltage,not active,
IDE08774-MAS01480,Fresh air blower: error status-Excess temp.,not active,
IDE08774-MAS01575,Fresh air blower: error status-Internal malfunction,not active,
IDE08774-MAS01807,Fresh air blower: error status-Short circuit,not active,
IDE08774-MAS07627,Fresh air blower: error status-Over current string,not active,
IDE08774-MAS07628,Fresh air blower: error status-Over current phase,not active,
IDE08774-MAS07629,Fresh air blower: error status-Error current offset,not active,
IDE08774-MAS07630,Fresh air blower: error status-error temperature sensor,not active,
IDE08774-MAS07631,Fresh air blower: error status-Error bridge driver,not active,
IDE08774-MAS07632,Fresh air blower: error status-Excess temp. bridge driver,not active,
IDE09584-MAS07663,Assembly position of users at local data bus 1: 3 zones front-Pos. 1 from master,Rear temperature door motor,
IDE09584-MAS07664,Assembly position of users at local data bus 1: 3 zones front-Pos. 2 from master,Left temperature flap positioning motor,
IDE09584-MAS07665,Assembly position of users at local data bus 1: 3 zones front-Pos. 3 from master,Left side vent motor,
IDE09584-MAS07666,Assembly position of users at local data bus 1: 3 zones front-Pos. 4 from master,Defroster flap motor,
IDE09584-MAS07667,Assembly position of users at local data bus 1: 3 zones front-Pos. 5 from master,Right side vent motor,
IDE09584-MAS07668,Assembly position of users at local data bus 1: 3 zones front-Pos. 6 from master,Right temperature flap positioning motor,
IDE09584-MAS07669,Assembly position of users at local data bus 1: 3 zones front-Pos. 7 from master,Rear air distribution door motor,
IDE09584-MAS07670,Assembly position of users at local data bus 1: 3 zones front-Pos. 8 from master,Fresh air door motor,
IDE09584-MAS07671,Assembly position of users at local data bus 1: 3 zones front-Pos. 9 from master,Recirculation flap motor,
IDE09584-MAS07672,Assembly position of users at local data bus 1: 3 zones front-Pos. 10 from master,not installed,
IDE09584-MAS07673,Assembly position of users at local data bus 1: 3 zones front-Pos. 11 from master,not installed,
IDE09584-MAS07674,Assembly position of users at local data bus 1: 3 zones front-Pos. 12 from master,not installed,
IDE09584-MAS07675,Assembly position of users at local data bus 1: 3 zones front-Pos. 13 from master,not installed,
IDE09584-MAS07676,Assembly position of users at local data bus 1: 3 zones front-Pos. 14 from master,not installed,
IDE09584-MAS07677,Assembly position of users at local data bus 1: 3 zones front-Pos. 15 from master,not installed,
IDE10418-IDE09056,Rear air distribution flap motor: diagnosis-Last operating state,Move flap motor,
IDE10418-MAS01458,Rear air distribution flap motor: diagnosis-Operating condition,No routine started,
IDE10967-MAS07663,Assembly position of users at local data bus 2: 2 zones front-Pos. 1 from master,Ctrl. motor for instrument panel vents,
IDE10967-MAS07664,Assembly position of users at local data bus 2: 2 zones front-Pos. 2 from master,not installed,
IDE10967-MAS07665,Assembly position of users at local data bus 2: 2 zones front-Pos. 3 from master,not installed,
IDE10967-MAS07666,Assembly position of users at local data bus 2: 2 zones front-Pos. 4 from master,not installed,
IDE10967-MAS07667,Assembly position of users at local data bus 2: 2 zones front-Pos. 5 from master,not installed,
IDE10967-MAS07668,Assembly position of users at local data bus 2: 2 zones front-Pos. 6 from master,not installed,
IDE10967-MAS07669,Assembly position of users at local data bus 2: 2 zones front-Pos. 7 from master,not installed,
IDE10967-MAS07670,Assembly position of users at local data bus 2: 2 zones front-Pos. 8 from master,not installed,
IDE10967-MAS07671,Assembly position of users at local data bus 2: 2 zones front-Pos. 9 from master,not installed,
IDE10967-MAS07672,Assembly position of users at local data bus 2: 2 zones front-Pos. 10 from master,not installed,
IDE10967-MAS07673,Assembly position of users at local data bus 2: 2 zones front-Pos. 11 from master,not installed,
IDE10967-MAS07674,Assembly position of users at local data bus 2: 2 zones front-Pos. 12 from master,not installed,
IDE10967-MAS07675,Assembly position of users at local data bus 2: 2 zones front-Pos. 13 from master,not installed,
IDE10967-MAS07676,Assembly position of users at local data bus 2: 2 zones front-Pos. 14 from master,not installed,
IDE10967-MAS07677,Assembly position of users at local data bus 2: 2 zones front-Pos. 15 from master,not installed,
IDE80001-ENG110385,Analysis 1-Channel,0,
IDE80001-ENG02514,Analysis 1-Comma,not active,
IDE80001-ENG99000,Analysis 1-Value,1410,
Elapsed Time: 00:19
adpmap-08-80A-820-043-K
;Friday,12,July,2019,16:07:21:64285
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
IDE01476-Store recirculation air setting for terminal 15 off,According to country version ,1
IDE01482-After-run of parking heater or parking ventilation,activated ,1
IDE01485-Shut-off temperature for solar sunroof,5 °C,1
IDE01488-Retrofitting of parking heater without CAN,not installed ,1
IDE01491-Temperature offset: summer operation,Default ,1
IDE01492-Temperature offset: winter operation,Default ,1
IDE01493-Air quality sensor sensitivity,Medium ,1
IDE01495-After-run time of auxiliary heater with A/C off,120 s,1
IDE01500-Window condensation reduction at high humidity,Matching coding ,1
IDE01501-Leakage air to footwell,automatic ,1
IDE01503-Runtime for compressor run-in basic setting,60 s,1
IDE01506-Tolerance range for flap end stops,0 ,1
IDE01536-Post-heating of parking heater,10 min,1
IDE02380-MMI display time for controls at rear,10 s,1
IDE03252-Window condensation parameter for start-stop function,5 ,1
IDE03253-A/C comfort parameter for start-stop function,5 ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE05569-Compressor control in efficiency mode,Eco mode ,1
IDE06546-Interior target temperature for production routines,22 °C,1
IDE06547-Air distribution for production routines,Air distribution upper body vents and footwell ,1
IDE06593-Recirculation air for production routines,Recirculating air ,1
IDE06769-Blower regulator for production routines,7 ,1
IDE08209-Speed of motors,Default ,1
IDE08373-Offset of fresh air blower speed,Default ,1
IDE10914-Seat occupancy-depending A/C,none ,1
IDE13688-Parameter dew point vaporizer for sailing performance,5 ,1
IDE13691-Water loading for sailing performance parameter,5 ,1
ENG131964-ENG133589-EntwID_activation-CapSense,not activated ,2
ENG131964-ENG133591-EntwID_activation-Clima-OBD,not activated ,2
ENG131964-ENG133588-EntwID_activation-Climate,not activated ,2
ENG131964-ENG98556-EntwID_activation-Display,not activated ,2
ENG131964-ENG133587-EntwID_activation-Flaps,not activated ,2
ENG131964-ENG133398-EntwID_activation-LIN1,not activated ,2
ENG131964-ENG133399-EntwID_activation-LIN2,not activated ,2
ENG131964-ENG133590-EntwID_activation-Massflow,not activated ,2
ENG131964-ENG116788-EntwID_activation-Potentiometer,not activated ,2
ENG131964-ENG98962-EntwID_activation-system,not activated ,2
ENG133583-OBD_activation,not activated ,1
ENG128343-OBD_channel,0 ,2
Elapsed Time: 00:08
blockmap-09-8W0-907-063-CE
;SW:8W0-907-063-CE   HW:8W0-907-063-BE ---  Cent. Elect.
;Component:BCM1 MLBevo   H13 0267, Coding:C2500362C0081CCD051587149CAE98B9100B3D08000000000000000000001A0001610002001204
;EV_BCM1BOSCHAU736,018006,EV_BCM1BOSCHAU736_018_AU49.rod
;Friday,12,July,2019,16:07:33:64285
;VCID: 804383401BF89E4F19-80D4
Group,Description,Actual
IDE01164-MAS06614,Park assist button-Version,not coded/not installed,
IDE01164-MAS07693,Park assist button-Button Status,not coded/not installed,
IDE01164-MAS07694,Park assist button-Button status on CAN,Initialization/not installed,
IDE01164-MAS07699,Park assist button-Status indicator light on CAN,OFF,
IDE01164-MAS08062,Park assist button-Indicator light activation,not coded/not installed,
IDE01236-MAS01580,Coolant recirculation pump-Activation,not coded/not installed,
IDE01236-MAS01634,Coolant recirculation pump-Supply voltage,not coded/not installed,
IDE01236-MAS06707,Coolant recirculation pump-Operating mode,not coded/not installed,
IDE01236-MAS07836,Coolant recirculation pump-Eng. delay. cool. shutdown,not coded/not installed,
IDE01236-MAS07837,Coolant recirculation pump-Last reason for local activity,not coded/not installed,
IDE01236-MAS07839,Coolant recirculation pump-Status feedback,not coded/not installed,
IDE01236-MAS12621,Coolant recirculation pump-Current draw (effective value),not coded/not installed,
IDE01266-MAS01580,Coolant shut-off valve-Activation,OFF,
IDE01266-MAS07806,Coolant shut-off valve-Spec. cond.,Open,
IDE01266-MAS12621,Coolant shut-off valve-Current draw (effective value),0, mA
IDE01268-MAS01464,Windshield wiper-Emergency running mode,not active,
IDE01268-MAS01632,Windshield wiper-Status,not active,
IDE01268-MAS02832,Windshield wiper-Malfunction status,not faulty,
IDE01268-MAS03006,Windshield wiper-Overload,not active,
IDE01268-MAS03638,Windshield wiper-Wipe speed,No wiping,
IDE01268-MAS06732,Windshield wiper-Status local activity,not active,
IDE01268-MAS06897,Windshield wiper-Wipe cycle counter,860,
IDE01268-MAS07055,Windshield wiper-Response error,not active,
IDE01268-MAS07998,Windshield wiper-park position,active,
IDE01268-MAS09379,Windshield wiper-Service position,not active,
IDE01268-MAS09595,Windshield wiper-Production mode,not active,
IDE01268-MAS09596,Windshield wiper-Debug Data,On,
IDE01268-MAS09597,Windshield wiper-Turn posn.,not active,
IDE01268-MAS09626,Windshield wiper-Status error validity,valid,
IDE01268-MAS09627,Windshield wiper-Error status: wiper 2,not faulty,
IDE01268-MAS09628,Windshield wiper-Overload: wiper 2,not active,
IDE01268-MAS09629,Windshield wiper-Status error validity: wiper 2,invalid,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,0, %
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,0, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,OFF,
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,OFF,
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,not coded/not installed,
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,30.20, °C
IDE01540-MAS07052,Left front heated seat-Setting,OFF,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,6.67, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,not coded/not installed,
IDE01540-MAS07921,Left front heated seat-Balance setting,Neutral,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,0, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,OFF,
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,OFF,
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not active,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not coded/not installed,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,-0.03, V
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,0, %
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,OFF,
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,OFF,
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,not coded/not installed,
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,32.60, °C
IDE01541-MAS07052,Right front heated seat-Setting,OFF,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,6.10, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,not coded/not installed,
IDE01541-MAS07921,Right front heated seat-Balance setting,Neutral,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,0, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,OFF,
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,OFF,
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not active,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not coded/not installed,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,-0.03, V
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01544-MAS05377,Auxiliary Air Heater-Low heat output relay,not coded/not installed,
IDE01544-MAS05378,Auxiliary Air Heater-High heat output relay,not coded/not installed,
IDE01544-MAS07914,Auxiliary Air Heater-Heating stage: spec value,not coded/not installed,
IDE01544-MAS12633,Auxiliary Air Heater-Relay for small heater output: current draw (effective value),not coded/not installed,
IDE01544-MAS12634,Auxiliary Air Heater-Relay for large heater output: current draw (effective value),not coded/not installed,
IDE01946,ESP intervention,OFF,
IDE01965-MAS06614,Parallel parking assistance button-Version,not coded/not installed,
IDE01965-MAS07693,Parallel parking assistance button-Button Status,not coded/not installed,
IDE01965-MAS07694,Parallel parking assistance button-Button status on CAN,Initialization/not installed,
IDE01965-MAS07699,Parallel parking assistance button-Status indicator light on CAN,OFF,
IDE01965-MAS08062,Parallel parking assistance button-Indicator light activation,not coded/not installed,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,34 8E E9 B7,
IDE01992-SFT00009,Installation list: current installations-Central Electrics,can be reached,
IDE01992-SFT00041,Installation list: current installations-Light Control Left,can be reached,
IDE01992-SFT00057,Installation list: current installations-Light Control Right,can be reached,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,cannot be reached,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,cannot be reached,
IDE01993-SFT00009,Control module reference number-Central Electrics,Central Electrics,
IDE01993-SFT00041,Control module reference number-Light Control Left,Light Control Left,
IDE01993-SFT00057,Control module reference number-Light Control Right,Light Control Right,
IDE01993-SFT00214,Control module reference number-Light Control Left 2,Light Control Left 2,
IDE01993-SFT00215,Control module reference number-Light Control Right 2,Light Control Right 2,
IDE01995-SFT00009,Control module protocol information-Central Electrics,ISO-TP,
IDE01995-SFT00041,Control module protocol information-Light Control Left,ISO-TP,
IDE01995-SFT00057,Control module protocol information-Light Control Right,ISO-TP,
IDE01995-SFT00214,Control module protocol information-Light Control Left 2,ISO-TP,
IDE01995-SFT00215,Control module protocol information-Light Control Right 2,ISO-TP,
IDE02384-SFT00009,Status of event memory-Central Electrics,ERROR,
IDE02384-SFT00041,Status of event memory-Light Control Left,OK,
IDE02384-SFT00057,Status of event memory-Light Control Right,ERROR,
IDE02384-SFT00214,Status of event memory-Light Control Left 2,OK,
IDE02384-SFT00215,Status of event memory-Light Control Right 2,OK,
IDE02455-MAS06911,Light function "Coming/Leaving Home"-Status Coming Home,not active,
IDE02455-MAS06912,Light function "Coming/Leaving Home"-Status Leaving Home,not active,
IDE02711-MAS09598,Rear Window Wiper-Request on CAN,OFF,
IDE02711-MAS09599,Rear Window Wiper-Error status via CAN,No error: no wiper activation,
IDE03111-MAS06885,Interior light-Terminal 30 for interior illumination,84, %
IDE03111-MAS06886,Interior light-Interior light delay (dimmer),0, %
IDE03111-MAS06986,Interior light-Footwell illumination rear,0, %
IDE03111-MAS06987,Interior light-Footwell illumination front,0, %
IDE03111-MAS09295,Interior light-ambient light.chan. 1,0, %
IDE03111-MAS09297,Interior light-Ambient illumination power supply,not coded/not installed,
IDE03111-MAS12622,Interior light-Terminal 30 for interior lighting: current draw (effect. value),5, mA
IDE03111-MAS12623,Interior light-Foot well illumination: rear: current draw (effective value),0, mA
IDE03111-MAS12624,Interior light-Foot well illumination: front: current draw (effective value),0, mA
IDE03111-MAS12625,Interior light-Ambient illumination channel 1: current draw (effective value),0, mA
IDE03111-MAS12626,Interior light-Supply for ambient illumination: current draw (effective value),not coded/not installed,
IDE03111-MAS12627,Interior light-Trunk illumination: front: current draw (effective value),not coded/not installed,
IDE03150-SFT00009,Readiness for bus sleep mode-Central Electrics,active,
IDE03150-SFT00041,Readiness for bus sleep mode-Light Control Left,Sleep mode,
IDE03150-SFT00057,Readiness for bus sleep mode-Light Control Right,Sleep mode,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,active,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,active,
IDE03197-IDE08190,Rain/Light Recognition Sensor-Request exterior illumination,OFF,
IDE03197-MAS02475,Rain/Light Recognition Sensor-Brightness infrared,43200, lx
IDE03197-MAS03637,Rain/Light Recognition Sensor-Rain quantity,0, %
IDE03197-MAS04806,Rain/Light Recognition Sensor-Splash,not active,
IDE03197-MAS06899,Rain/Light Recognition Sensor-Request glass close,not active,
IDE03197-MAS06900,Rain/Light Recognition Sensor-Status glass,closed,
IDE03197-MAS06998,Rain/Light Recognition Sensor-Request exterior illumination: inverse,On,
IDE03197-MAS06999,Rain/Light Recognition Sensor-Bright/dark information,Bright,
IDE03197-MAS07055,Rain/Light Recognition Sensor-Response error,not active,
IDE03197-MAS09630,Rain/Light Recognition Sensor-Qualification status of exterior lighting requirement,valid,
IDE03197-MAS09631,Rain/Light Recognition Sensor-Highway light requirement,OFF,
IDE03197-MAS09632,Rain/Light Recognition Sensor-Rain light requirement,OFF,
IDE03197-MAS09633,Rain/Light Recognition Sensor-Wiper speed requirement,No wiping,
IDE03197-MAS09634,Rain/Light Recognition Sensor-Adaptation error,not active,
IDE03197-MAS09635,Rain/Light Recognition Sensor-Error status rain sensors,not faulty,
IDE03197-MAS09636,Rain/Light Recognition Sensor-Error status light sensors,not faulty,
IDE03197-MAS10232,Rain/Light Recognition Sensor-Brightness ahead,4674, lx
IDE03197-MAS10233,Rain/Light Recognition Sensor-Brightness ahead: boost,up to 6428 Lux,
IDE03602,Left front level control system sensor,Measured value not available,
IDE03604,Left rear level control system sensor,Measured value not available,
IDE03620,Front jounce travel,Measured value not available,
IDE03621,Rear jounce travel,Measured value not available,
IDE03622,Left headlight beam adjusting motor: status,Measured value not available,
IDE03623,Right headlight beam adjusting motor: status,Measured value not available,
IDE03628,Adjusting motor for variable left front lighting: status,Measured value not available,
IDE03629,Adjusting motor for variable right front lighting: status,Measured value not available,
IDE03630,Left headlight beam adjusting motor: specified value,Measured value not available,
IDE03631,Right headlight beam adjusting motor: specified value,Measured value not available,
IDE03632,Left-/right hand driving switch-over,Measured value not available,
IDE03638-IDE03717,static AFS light-Dim static left AFS light,Measured value not available,
IDE03638-IDE03718,static AFS light-Dim static right AFS light,Measured value not available,
IDE03662-MAS06614,ASR/ESP button-Version,Local data bus: operating unit 1,
IDE03662-MAS07693,ASR/ESP button-Button Status,Not operated,
IDE03662-MAS07694,ASR/ESP button-Button status on CAN,Not operated,
IDE03662-MAS07699,ASR/ESP button-Status indicator light on CAN,OFF,
IDE03662-MAS08062,ASR/ESP button-Indicator light activation,OFF,
IDE03663-MAS06614,-AUTO HOLD- Button-Version,not coded/not installed,
IDE03663-MAS07693,-AUTO HOLD- Button-Button Status,not coded/not installed,
IDE03663-MAS07694,-AUTO HOLD- Button-Button status on CAN,Initialization/not installed,
IDE03663-MAS07699,-AUTO HOLD- Button-Status indicator light on CAN,OFF,
IDE03663-MAS08062,-AUTO HOLD- Button-Indicator light activation,not coded/not installed,
IDE03669,Light distribution status,Measured value not available,
IDE03679-MAS09575,Adaptive light functions-High beam request,OFF,
IDE03679-MAS10260,Adaptive light functions-Request for automatic high beam,OFF,
IDE03679-MAS10261,Adaptive light functions-Automatic high beam availability,not coded/not installed,
IDE03679-MAS10264,Adaptive light functions-High beam: status,not coded/not installed,
IDE03679-MAS10265,Adaptive light functions-Left high beam: error status,not coded/not installed,
IDE03679-MAS10266,Adaptive light functions-Right high beam: error status,not coded/not installed,
IDE03679-MAS10268,Adaptive light functions-Matrix automatic high beam availability,not coded/not installed,
IDE03679-MAS10271,Adaptive light functions-Matrix high beam: status,not coded/not installed,
IDE03679-MAS10272,Adaptive light functions-Left Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10273,Adaptive light functions-Right Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10274,Adaptive light functions-Sensor status: auto. high beam,not coded/not installed,
IDE03679-MAS10275,Adaptive light functions-Matrix auto. high beam: sensor status,not coded/not installed,
IDE03680-MAS00043,Supply voltages-Supply voltage: Terminal 30,14.15, V
IDE03680-MAS06254,Supply voltages-Supply voltage Terminal 30 - 2,14.17, V
IDE03680-MAS06255,Supply voltages-Supply voltage Terminal 30 - 3,14.23, V
IDE03680-MAS06490,Supply voltages-Terminal 15 load,14.15, V
IDE03680-MAS06838,Supply voltages-Supply voltage: terminal 30 left,14.17, V
IDE03680-MAS06839,Supply voltages-Supply voltage terminal 30 right,14.21, V
IDE03680-MAS06840,Supply voltages-Supply voltage Terminal 30 - 4,14.28, V
IDE03680-MAS06841,Supply voltages-Supply voltage Terminal 30 - 5,14.17, V
IDE03680-MAS06842,Supply voltages-Supply voltage Terminal 30 - 6,14.25, V
IDE03727,Variable left front lighting specified position,Measured value not available,
IDE03728,Variable right front lighting specified position,Measured value not available,
IDE03788,Status of basic headlamp setting,Measured value not available,
IDE03850,Left front level ctrl sys sensor: adaptation value (zero pos),Measured value not available,
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),Measured value not available,
IDE04343-SFT00009,Bus identification-Central Electrics,Busmaster,
IDE04343-SFT00041,Bus identification-Light Control Left,AFS/From light data bus,
IDE04343-SFT00057,Bus identification-Light Control Right,AFS/From light data bus,
IDE04343-SFT00214,Bus identification-Light Control Left 2,AFS/From light data bus,
IDE04343-SFT00215,Bus identification-Light Control Right 2,AFS/From light data bus,
IDE04806-MAS06614,Driving profile selection button-Version,Local data bus: operating unit 1,
IDE04806-MAS07693,Driving profile selection button-Button Status,Not operated,
IDE04806-MAS07694,Driving profile selection button-Button status on CAN,Not operated,
IDE04923-MAS08125,Turn signal control-Left front turn signal bulb: status,OFF,
IDE04923-MAS08127,Turn signal control-Right front turn signal bulb: status,OFF,
IDE04923-MAS08131,Turn signal control-Left turn signal lights: clock,OFF,
IDE04923-MAS08132,Turn signal control-Right turn signal lights: clock,OFF,
IDE05042-MAS06614,Emergency flasher button-Version,Discreet wire,
IDE05042-MAS07693,Emergency flasher button-Button Status,Not operated,
IDE05042-MAS07694,Emergency flasher button-Button status on CAN,Not operated,
IDE05042-MAS08062,Emergency flasher button-Indicator light activation,OFF,
IDE05071-MAS06614,Lane change assistance button-Version,not coded/not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not coded/not installed,
IDE05071-MAS07694,Lane change assistance button-Button status on CAN,Initialization/not installed,
IDE05071-MAS08062,Lane change assistance button-Indicator light activation,not coded/not installed,
IDE05534-MAS01580,Headlamp washer system-Activation,not coded/not installed,
IDE05534-MAS12621,Headlamp washer system-Current draw (effective value),not coded/not installed,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,58.90, °C
IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,58.50, °C
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,20, %
IDE06091-MAS04647,Humidity sensor: internal-Dew point,15.80, °C
IDE06091-MAS07055,Humidity sensor: internal-Response error,not active,
IDE06644-MAS06993,Vehicle positioning system-Request signal horn,not coded/not installed,
IDE06644-MAS09570,Vehicle positioning system-Parking light request,not coded/not installed,
IDE06644-MAS09571,Vehicle positioning system-Low beam request,not coded/not installed,
IDE06752-MAS06614,Hill descent control button-Version,Local data bus: operating unit 1,
IDE06752-MAS07693,Hill descent control button-Button Status,Not operated,
IDE06752-MAS07694,Hill descent control button-Button status on CAN,Not operated,
IDE06752-MAS07699,Hill descent control button-Status indicator light on CAN,OFF,
IDE06752-MAS08062,Hill descent control button-Indicator light activation,OFF,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,01,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07991-MAS01580,A/C clutch-Activation,not coded/not installed,
IDE07991-MAS07919,A/C clutch-Min current consumption: spec value,not coded/not installed,
IDE07991-MAS12621,A/C clutch-Current draw (effective value),not coded/not installed,
IDE07991-MAS12776,A/C clutch-Spec.val. min.cur. draw prior to rec.op.circ./short circ. to B+,not coded/not installed,
IDE07991-MAS12778,A/C clutch-Act.val. min.curr. draw prior to recogn open circ/sh circ to B+,not coded/not installed,
IDE08125-MAS01458,Left cabin heater-Operating condition,not coded/not installed,
IDE08125-MAS02832,Left cabin heater-Malfunction status,not coded/not installed,
IDE08125-MAS06652,Left cabin heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08125-MAS07055,Left cabin heater-Response error,not coded/not installed,
IDE08125-MAS09644,Left cabin heater-Vent temperature,not coded/not installed,
IDE08125-MAS12677,Left cabin heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08126-MAS01458,Right cabin heater-Operating condition,not coded/not installed,
IDE08126-MAS02832,Right cabin heater-Malfunction status,not coded/not installed,
IDE08126-MAS06652,Right cabin heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS07055,Right cabin heater-Response error,not coded/not installed,
IDE08126-MAS09644,Right cabin heater-Vent temperature,not coded/not installed,
IDE08126-MAS12677,Right cabin heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08196-IDE01351,Terminal control-Terminal 75 status,On,
IDE08196-MAS06982,Terminal control-Terminal 15 status signal,On,
IDE08196-MAS07720,Terminal control-Terminal 15 via CAN,On,
IDE08196-MAS08123,Terminal control-Term 75: qualification,OFF,
IDE08343,Immobilizer Challenge,CD 42 8C 2C,
IDE08364-MAS01447,Left seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE08364-MAS01448,Left seat backrest fan 1: activation-Specified value,not coded/not installed,
IDE08365-MAS01447,Left seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08365-MAS01448,Left seat backrest fan 2: activation-Specified value,not coded/not installed,
IDE08366-MAS01447,Left seat seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE08366-MAS01448,Left seat seat cushion fan 1: activation-Specified value,not coded/not installed,
IDE08367-MAS01447,Left seat seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08367-MAS01448,Left seat seat cushion fan 2: activation-Specified value,not coded/not installed,
IDE08368-MAS01447,Right seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE08368-MAS01448,Right seat backrest fan 1: activation-Specified value,not coded/not installed,
IDE08369-MAS01447,Right seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08369-MAS01448,Right seat backrest fan 2: activation-Specified value,not coded/not installed,
IDE08370-MAS01447,Right seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE08370-MAS01448,Right seat cushion fan 1: activation-Specified value,not coded/not installed,
IDE08371-MAS01447,Right seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08371-MAS01448,Right seat cushion fan 2: activation-Specified value,not coded/not installed,
IDE08376-MAS01580,Right daytime running lamp and parking lamp bulb-Activation,not coded/not installed,
IDE08376-MAS01737,Right daytime running lamp and parking lamp bulb-Diagnosis,not coded/not installed,
IDE08376-MAS12621,Right daytime running lamp and parking lamp bulb-Current draw (effective value),not coded/not installed,
IDE08377-MAS01580,Left daytime running lamp and parking lamp bulb-Activation,not coded/not installed,
IDE08377-MAS01737,Left daytime running lamp and parking lamp bulb-Diagnosis,not coded/not installed,
IDE08377-MAS12621,Left daytime running lamp and parking lamp bulb-Current draw (effective value),not coded/not installed,
IDE08378-MAS01580,Right front turn signal bulb-Activation,not coded/not installed,
IDE08378-MAS01737,Right front turn signal bulb-Diagnosis,not coded/not installed,
IDE08378-MAS12621,Right front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08379-MAS01580,Left front turn signal bulb-Activation,not coded/not installed,
IDE08379-MAS01737,Left front turn signal bulb-Diagnosis,not coded/not installed,
IDE08379-MAS12621,Left front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08380-MAS01580,Right side marker lamp bulb-Activation,not coded/not installed,
IDE08380-MAS01737,Right side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08380-MAS12621,Right side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08381-MAS01580,Left side marker lamp bulb-Activation,not coded/not installed,
IDE08381-MAS01737,Left side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08381-MAS12621,Left side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08382-MAS01580,Right front side marker lamp bulb-Activation,not coded/not installed,
IDE08382-MAS01737,Right front side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08382-MAS12621,Right front side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08383-MAS01580,Left front side marker lamp bulb-Activation,not coded/not installed,
IDE08383-MAS01737,Left front side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08383-MAS12621,Left front side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08384-MAS01580,Right daytime running lamp bulb-Activation,not coded/not installed,
IDE08384-MAS01737,Right daytime running lamp bulb-Diagnosis,not coded/not installed,
IDE08384-MAS12621,Right daytime running lamp bulb-Current draw (effective value),not coded/not installed,
IDE08385-MAS01580,Left daytime running lamp bulb-Activation,not coded/not installed,
IDE08385-MAS01737,Left daytime running lamp bulb-Diagnosis,not coded/not installed,
IDE08385-MAS12621,Left daytime running lamp bulb-Current draw (effective value),not coded/not installed,
IDE08386-MAS01580,Right low beam headlamp bulb-Activation,0.00, %
IDE08386-MAS01737,Right low beam headlamp bulb-Diagnosis,no error,
IDE08386-MAS12621,Right low beam headlamp bulb-Current draw (effective value),0, mA
IDE08387-MAS01580,Left low beam headlamp bulb-Activation,0.00, %
IDE08387-MAS01737,Left low beam headlamp bulb-Diagnosis,no error,
IDE08387-MAS12621,Left low beam headlamp bulb-Current draw (effective value),0, mA
IDE08388-MAS01580,Right high beam headlamp bulb-Activation,not coded/not installed,
IDE08388-MAS01737,Right high beam headlamp bulb-Diagnosis,not coded/not installed,
IDE08388-MAS12621,Right high beam headlamp bulb-Current draw (effective value),not coded/not installed,
IDE08389-MAS01580,Left high beam headlamp bulb-Activation,not coded/not installed,
IDE08389-MAS01737,Left high beam headlamp bulb-Diagnosis,not coded/not installed,
IDE08389-MAS12621,Left high beam headlamp bulb-Current draw (effective value),not coded/not installed,
IDE08390-MAS01580,Right fog light bulb-Activation,0.00, %
IDE08390-MAS01737,Right fog light bulb-Diagnosis,no error,
IDE08390-MAS12621,Right fog light bulb-Current draw (effective value),0, mA
IDE08391-MAS01580,Left fog light bulb-Activation,0.00, %
IDE08391-MAS01737,Left fog light bulb-Diagnosis,no error,
IDE08391-MAS12621,Left fog light bulb-Current draw (effective value),0, mA
IDE08392-MAS01580,Right LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08392-MAS01737,Right LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08392-MAS12621,Right LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08393-MAS01580,Left LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08393-MAS01737,Left LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08393-MAS12621,Left LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08394-MAS01580,Right LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08394-MAS01737,Right LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08394-MAS12621,Right LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08395-MAS01580,Left LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08395-MAS01737,Left LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08395-MAS12621,Left LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08396-MAS01580,Headlights right: supply-Activation,not coded/not installed,
IDE08396-MAS01737,Headlights right: supply-Diagnosis,not coded/not installed,
IDE08396-MAS12621,Headlights right: supply-Current draw (effective value),not coded/not installed,
IDE08397-MAS01580,Headlights left: supply-Activation,not coded/not installed,
IDE08397-MAS01737,Headlights left: supply-Diagnosis,not coded/not installed,
IDE08397-MAS12621,Headlights left: supply-Current draw (effective value),not coded/not installed,
IDE08402-IDE05742,Light switch-Light switch position,AUTO,
IDE08402-IDE07956,Light switch-redundant signal line,Medium,
IDE08402-MAS03866,Light switch-Head-up display button,Not operated,
IDE08402-MAS03868,Light switch-Position of eye box,0,
IDE08402-MAS06887,Light switch-Light switch position on CAN,AUTO,
IDE08402-MAS06888,Light switch-Fog light button,Not operated,
IDE08402-MAS06889,Light switch-Rear fog light button,Not operated,
IDE08402-MAS06890,Light switch-Night vision system button,Not operated,
IDE08402-MAS06891,Light switch-Control for Eyebox position,no operation,
IDE08404-IDE01351,Local data bus 1: information-Terminal 75 status,On,
IDE08404-MAS00370,Local data bus 1: information-Vehicle speed,0.00, km/h
IDE08404-MAS03679,Local data bus 1: information-Terminal 15 status,On,
IDE08404-MAS06495,Local data bus 1: information-Engine hood contact switch,closed,
IDE08405-MAS05030,Outside air temperature sensor-Resistance,0.72, kOhm
IDE08405-MAS08858,Outside air temperature sensor-Outside air temperature on CAN,32.50, °C
IDE08408-MAS12845,Hood contact-Switch 1,closed,
IDE08408-MAS12846,Hood contact-Switch 2,closed,
IDE08434-MAS01580,Right turn signal light bulb-Activation,not coded/not installed,
IDE08434-MAS01737,Right turn signal light bulb-Diagnosis,not coded/not installed,
IDE08434-MAS12621,Right turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08435-MAS01580,Left turn signal light bulb-Activation,not coded/not installed,
IDE08435-MAS01737,Left turn signal light bulb-Diagnosis,not coded/not installed,
IDE08435-MAS12621,Left turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08441-MAS06992,Control module for steering col electronics: requirements-Request wiping,Intermittent operation,
IDE08441-MAS06993,Control module for steering col electronics: requirements-Request signal horn,OFF,
IDE08441-MAS09575,Control module for steering col electronics: requirements-High beam request,OFF,
IDE08441-MAS09576,Control module for steering col electronics: requirements-Wash request,OFF,
IDE08441-MAS09577,Control module for steering col electronics: requirements-Rear interval wash request,OFF,
IDE08441-MAS09586,Control module for steering col electronics: requirements-Headlight flasher request,OFF,
IDE08441-MAS09587,Control module for steering col electronics: requirements-Headlight washer request,OFF,
IDE08441-MAS09600,Control module for steering col electronics: requirements-Request to flashing left,not active,
IDE08441-MAS09601,Control module for steering col electronics: requirements-Request to flashing right,not active,
IDE08442-MAS01580,Wiper storage and spray nozzle heater-Activation,OFF,
IDE08442-MAS07000,Wiper storage and spray nozzle heater-Switch-on current,0, mA
IDE08442-MAS12621,Wiper storage and spray nozzle heater-Current draw (effective value),0, mA
IDE08500-MAS07921,Left front seat ventilation setting-Balance setting,not coded/not installed,
IDE08500-MAS07928,Left front seat ventilation setting-Ventilation stage,not coded/not installed,
IDE08500-MAS07929,Left front seat ventilation setting-Power quota setting by energy management,not coded/not installed,
IDE08501-MAS07921,Right front seat ventilation setting-Balance setting,not coded/not installed,
IDE08501-MAS07928,Right front seat ventilation setting-Ventilation stage,not coded/not installed,
IDE08501-MAS07929,Right front seat ventilation setting-Power quota setting by energy management,not coded/not installed,
IDE08502-MAS01580,A/C compressor regulator valve-Activation,51, %
IDE08502-MAS09777,A/C compressor regulator valve-Specified current,476, mA
IDE08502-MAS09780,A/C compressor regulator valve-Supply Highside,On,
IDE08502-MAS12632,A/C compressor regulator valve-Current draw (mean value),479, mA
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,Measured value not available,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,Measured value not available,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,Measured value not available,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather lights,Measured value not available,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,Measured value not available,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,Measured value not available,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,Measured value not available,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,Measured value not available,
IDE08543-MAS00370,Garage door opener: last programming-Vehicle speed,below threshold,
IDE08543-MAS01240,Garage door opener: last programming-Programming status,0F,
IDE08543-MAS02246,Garage door opener: last programming-Timeout,Not reached,
IDE08543-MAS02949,Garage door opener: last programming-Frequency,04 9E 6F,
IDE08543-MAS03159,Garage door opener: last programming-Manufacturer,FF,
IDE08543-MAS04184,Garage door opener: last programming-Cancellation by user,Yes,
IDE08543-MAS06670,Garage door opener: last programming-Channel,Channel 1,
IDE08543-MAS09308,Garage door opener: last programming-Error status and modulation,01010000 ,
IDE08543-MAS10442,Garage door opener: last programming-Programming antenna,External antenna,
IDE08544-MAS00370,Garage door opener: second-to-last progr.-Vehicle speed,below threshold,
IDE08544-MAS01240,Garage door opener: second-to-last progr.-Programming status,00,
IDE08544-MAS02246,Garage door opener: second-to-last progr.-Timeout,Not reached,
IDE08544-MAS02949,Garage door opener: second-to-last progr.-Frequency,Programming not performed,
IDE08544-MAS03159,Garage door opener: second-to-last progr.-Manufacturer,00,
IDE08544-MAS04184,Garage door opener: second-to-last progr.-Cancellation by user,No,
IDE08544-MAS06670,Garage door opener: second-to-last progr.-Channel,Programming not performed,
IDE08544-MAS09308,Garage door opener: second-to-last progr.-Error status and modulation,01000000 ,
IDE08544-MAS10442,Garage door opener: second-to-last progr.-Programming antenna,External antenna,
IDE08545-MAS00370,Garage door opener: third-to-last progr.-Vehicle speed,below threshold,
IDE08545-MAS01240,Garage door opener: third-to-last progr.-Programming status,00,
IDE08545-MAS02246,Garage door opener: third-to-last progr.-Timeout,Not reached,
IDE08545-MAS02949,Garage door opener: third-to-last progr.-Frequency,Programming not performed,
IDE08545-MAS03159,Garage door opener: third-to-last progr.-Manufacturer,00,
IDE08545-MAS04184,Garage door opener: third-to-last progr.-Cancellation by user,No,
IDE08545-MAS06670,Garage door opener: third-to-last progr.-Channel,Programming not performed,
IDE08545-MAS09308,Garage door opener: third-to-last progr.-Error status and modulation,00000000 ,
IDE08545-MAS10442,Garage door opener: third-to-last progr.-Programming antenna,External antenna,
IDE08622,Garage door opener: supply voltage,14.22, V
IDE08795-MAS06614,Button for rear window shade-Version,not coded/not installed,
IDE08795-MAS07693,Button for rear window shade-Button Status,not coded/not installed,
IDE08795-MAS07694,Button for rear window shade-Button status on CAN,Initialization/not installed,
IDE08948-MAS01632,Electrically Adjustable Steering Column-Status,not coded/not installed,
IDE08948-MAS06732,Electrically Adjustable Steering Column-Status local activity,not coded/not installed,
IDE08948-MAS09493,Electrically Adjustable Steering Column-Position: vertical,not coded/not installed,
IDE08948-MAS09494,Electrically Adjustable Steering Column-Position: axial,not coded/not installed,
IDE08948-MAS09495,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation up,not coded/not installed,
IDE08948-MAS09496,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation down,not coded/not installed,
IDE08948-MAS09497,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation out,not coded/not installed,
IDE08948-MAS09498,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation in,not coded/not installed,
IDE08948-MAS09501,Electrically Adjustable Steering Column-Entry assistance button,not coded/not installed,
IDE08948-MAS12678,Electrically Adjustable Steering Column-Motor for vertical adjustment: current draw (effective value),not coded/not installed,
IDE08948-MAS12679,Electrically Adjustable Steering Column-Motor for axial adjustment: current draw (effective value),not coded/not installed,
IDE08953,Garage door opener: country code,North America,
IDE08957-MAS01632,Supply for power outlets-Status,On,
IDE08957-MAS04445,Supply for power outlets-Relay output voltage,14.21, V
IDE08957-MAS07309,Supply for power outlets-Maximum current draw,36.80, A
IDE08957-MAS08025,Supply for power outlets-Output to input voltage ratio with relay switched off,45.39, %
IDE08957-MAS12621,Supply for power outlets-Current draw (effective value),96, mA
IDE08960-MAS08026,Status: control heads for driving and comfort functions-Control head for driving and comfort functions,ready for operation,
IDE08960-MAS08027,Status: control heads for driving and comfort functions-Control head 2 for driving and comfort functions,not coded/not installed,
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Separate activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Separate activation of backrest and seat cushion,
IDE08962-IDE08356,Installation info: seat ventilation-Left seat backrest fan 1,not installed,
IDE08962-IDE08357,Installation info: seat ventilation-Left seat backrest fan 2,not installed,
IDE08962-IDE08358,Installation info: seat ventilation-Left seat cushion fan 1,not installed,
IDE08962-IDE08359,Installation info: seat ventilation-Left seat cushion fan 2,not installed,
IDE08962-IDE08360,Installation info: seat ventilation-Right seat backrest fan 1,not installed,
IDE08962-IDE08361,Installation info: seat ventilation-Right seat backrest fan 2,not installed,
IDE08962-IDE08362,Installation info: seat ventilation-Right seat cushion fan 1,not installed,
IDE08962-IDE08363,Installation info: seat ventilation-Right seat cushion fan 2,not installed,
IDE08978-MAS01580,Windshield washer pump-Activation,OFF,
IDE08978-MAS09022,Windshield washer pump-PWM value,0, %
IDE08978-MAS12621,Windshield washer pump-Current draw (effective value),0, mA
IDE08979-MAS06614,Valet parking lock button-Version,not coded/not installed,
IDE08979-MAS07693,Valet parking lock button-Button Status,not coded/not installed,
IDE08979-MAS07694,Valet parking lock button-Button status on CAN,Not operated,
IDE08979-MAS08062,Valet parking lock button-Indicator light activation,not coded/not installed,
IDE08980-MAS06614,Button for rear spoiler adjustment-Version,not coded/not installed,
IDE08980-MAS07693,Button for rear spoiler adjustment-Button Status,not coded/not installed,
IDE08980-MAS07694,Button for rear spoiler adjustment-Button status on CAN,Initialization/not installed,
IDE08980-MAS07699,Button for rear spoiler adjustment-Status indicator light on CAN,OFF,
IDE08980-MAS08062,Button for rear spoiler adjustment-Indicator light activation,not coded/not installed,
IDE08981-MAS06614,Front display open/close button-Version,Local data bus: operating unit 1,
IDE08981-MAS07693,Front display open/close button-Button Status,Not operated,
IDE08981-MAS07694,Front display open/close button-Button status on CAN,Not operated,
IDE08982-MAS06614,Button for start/stop operation/electrical driving-Version,Local data bus: operating unit 1,
IDE08982-MAS07693,Button for start/stop operation/electrical driving-Button Status,Not operated,
IDE08982-MAS07694,Button for start/stop operation/electrical driving-Button status on CAN,Not operated,
IDE08982-MAS08062,Button for start/stop operation/electrical driving-Indicator light activation,OFF,
IDE08983-MAS06614,Driving profile selection button 2-Version,Local data bus: operating unit 1,
IDE08983-MAS07693,Driving profile selection button 2-Button Status,Not operated,
IDE08983-MAS07694,Driving profile selection button 2-Button status on CAN,Not operated,
IDE08998-MAS06901,Driver info-Washer fluid level,OK,
IDE08998-MAS08063,Driver info-Coolant level from sensor for low coolant display,OK,
IDE08998-MAS08064,Driver info-Coolant level from sensor 2 for low coolant display,OK,
IDE08998-MAS08065,Driver info-Brake fluid level,OK,
IDE08998-MAS08122,Driver info-Brake lining,OK,
IDE08999-MAS08124,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: request,OFF,
IDE08999-MAS08125,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: status,OFF,
IDE08999-MAS08126,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: request,OFF,
IDE08999-MAS08127,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: status,OFF,
IDE08999-MAS08128,Control modules for light activation: turn sig ctrl-Left flashing function,not active,
IDE08999-MAS08129,Control modules for light activation: turn sig ctrl-Right flashing function,not active,
IDE08999-MAS08133,Control modules for light activation: turn sig ctrl-Flashing mode,normal,
IDE09000-MAS01580,Control module for light activation: left: supply-Activation,100, %
IDE09000-MAS01737,Control module for light activation: left: supply-Diagnosis,no error,
IDE09000-MAS12621,Control module for light activation: left: supply-Current draw (effective value),869, mA
IDE09001-MAS01580,Control module for light activation: right: supply-Activation,100, %
IDE09001-MAS01737,Control module for light activation: right: supply-Diagnosis,no error,
IDE09001-MAS12621,Control module for light activation: right: supply-Current draw (effective value),827, mA
IDE09234-MAS01580,Subfloor lighting-Activation,not coded/not installed,
IDE09234-MAS12621,Subfloor lighting-Current draw (effective value),not coded/not installed,
IDE09850-MAS07146,Garage Door Opener Operating Unit-Button 1,Not operated,
IDE09850-MAS07147,Garage Door Opener Operating Unit-Button 2,Not operated,
IDE09850-MAS07148,Garage Door Opener Operating Unit-Button 3,Not operated,
IDE09887-MAS01580,Right daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09887-MAS01737,Right daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09887-MAS12621,Right daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09888-MAS01580,Left daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09888-MAS01737,Left daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09888-MAS12621,Left daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09920-MAS06614,Special Purpose Vehicle Control Module-Version,not coded/not installed,
IDE09920-MAS06992,Special Purpose Vehicle Control Module-Request wiping,not coded/not installed,
IDE09920-MAS06993,Special Purpose Vehicle Control Module-Request signal horn,not coded/not installed,
IDE09920-MAS09569,Special Purpose Vehicle Control Module-Remote control status,not coded/not installed,
IDE09920-MAS09570,Special Purpose Vehicle Control Module-Parking light request,not coded/not installed,
IDE09920-MAS09571,Special Purpose Vehicle Control Module-Low beam request,not coded/not installed,
IDE09920-MAS09572,Special Purpose Vehicle Control Module-Intermittent high beam request,not coded/not installed,
IDE09920-MAS09573,Special Purpose Vehicle Control Module-Footwell illumination request,not coded/not installed,
IDE09920-MAS09574,Special Purpose Vehicle Control Module-Interior illumination request,not coded/not installed,
IDE09920-MAS09575,Special Purpose Vehicle Control Module-High beam request,not coded/not installed,
IDE09920-MAS09576,Special Purpose Vehicle Control Module-Wash request,not coded/not installed,
IDE09920-MAS09577,Special Purpose Vehicle Control Module-Rear interval wash request,not coded/not installed,
IDE09920-MAS09586,Special Purpose Vehicle Control Module-Headlight flasher request,not coded/not installed,
IDE09920-MAS09588,Special Purpose Vehicle Control Module-Emerg. sig. flasher request,not coded/not installed,
IDE09920-MAS09589,Special Purpose Vehicle Control Module-Daytime running light deactivation req.,not coded/not installed,
IDE09920-MAS09590,Special Purpose Vehicle Control Module-Suppression of interior illumination request,not coded/not installed,
IDE09921-MAS01632,Automatic high beam assist control module-Status,not coded/not installed,
IDE09921-MAS02832,Automatic high beam assist control module-Malfunction status,not coded/not installed,
IDE09921-MAS09580,Automatic high beam assist control module-Sensor status,not coded/not installed,
IDE09921-MAS09581,Automatic high beam assist control module-PWM specs.,not coded/not installed,
IDE09921-MAS09582,Automatic high beam assist control module-Status on combi,not coded/not installed,
IDE09921-MAS09583,Automatic high beam assist control module-error status on combi,not coded/not installed,
IDE09921-MAS09584,Automatic high beam assist control module-Sensor status on combi,not coded/not installed,
IDE09921-MAS09585,Automatic high beam assist control module-Turn up headlights request,not coded/not installed,
IDE09922-MAS01448,Static headlight range adjustment-Specified value,not coded/not installed,
IDE09922-MAS09527,Static headlight range adjustment-Activation voltage: act. value,not coded/not installed,
IDE09922-MAS10074,Static headlight range adjustment-Supply voltage: actual value,not coded/not installed,
IDE09922-MAS10075,Static headlight range adjustment-Activation voltage/supply voltage ratio,not coded/not installed,
IDE09922-MAS12621,Static headlight range adjustment-Current draw (effective value),not coded/not installed,
IDE09933,Multifunction steerg. wheel: request signal horn,OFF,
IDE09934-MAS09591,Shift lever / selector lever position-Signal transm. ctrl. mod.,Selector lever in position P,
IDE09934-MAS09592,Shift lever / selector lever position-Signal engine ctrl. mod.,Unknown (9),
IDE09936-MAS01580,Right daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09936-MAS01737,Right daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09936-MAS12621,Right daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09937-MAS01580,Left daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09937-MAS01737,Left daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09937-MAS12621,Left daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09938-MAS01580,Right front turn signal bulb 2-Activation,not coded/not installed,
IDE09938-MAS01737,Right front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09938-MAS12621,Right front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09939-MAS01580,Left front turn signal bulb 2-Activation,not coded/not installed,
IDE09939-MAS01737,Left front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09939-MAS12621,Left front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09940-MAS01580,Right side marker bulb 2-Activation,not coded/not installed,
IDE09940-MAS01737,Right side marker bulb 2-Diagnosis,not coded/not installed,
IDE09940-MAS12621,Right side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09941-MAS01580,Left side marker bulb 2-Activation,not coded/not installed,
IDE09941-MAS01737,Left side marker bulb 2-Diagnosis,not coded/not installed,
IDE09941-MAS12621,Left side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09955-MAS07693,Dimming interior rearview mirror-Button Status,Not operated,
IDE09955-MAS09651,Dimming interior rearview mirror-Error status sensor front,not faulty,
IDE09955-MAS09652,Dimming interior rearview mirror-Error status sensor rear,not faulty,
IDE09955-MAS10386,Dimming interior rearview mirror-Dim. value spec.: exterior mirror,0.00, V
IDE09958-MAS01580,Right low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09958-MAS01737,Right low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09958-MAS12621,Right low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE09959-MAS01580,Left low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09959-MAS01737,Left low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09959-MAS12621,Left low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE10085-MAS09757,Switch and display illumination-Terminal 58xs on CAN,0, %
IDE10085-MAS09815,Switch and display illumination-Terminal 58xd on CAN,246,
IDE10085-MAS09816,Switch and display illumination-Phototransistor wert,246,
IDE10085-MAS09817,Switch and display illumination-Terminal 58xs,0.00, %
IDE10085-MAS09819,Switch and display illumination-T. 58xs: Diagnosis,no error,
IDE10085-MAS09820,Switch and display illumination-Terminal 58xt,10.00, %
IDE10085-MAS09822,Switch and display illumination-T. 58xt: Diagnosis,no error,
IDE10085-MAS09823,Switch and display illumination-Driver's request (light switch),1, %
IDE10085-MAS09824,Switch and display illumination-Driver's request (Kombi),0, %
IDE10085-MAS09825,Switch and display illumination-Driver's request (MMI),0, %
IDE10085-MAS09826,Switch and display illumination-Driver's request on CAN,1, %
IDE10085-MAS09827,Switch and display illumination-Terminal 58xt on CAN,10, %
IDE10085-MAS12628,Switch and display illumination-Terminal 58xs: current draw (effective value),0, mA
IDE10085-MAS12629,Switch and display illumination-Terminal 58xt: current draw (effective value),33, mA
IDE10219-MAS01580,High/low tone horn-Activation,OFF,
IDE10219-MAS12621,High/low tone horn-Current draw (effective value),0, mA
IDE10260-MAS01448,Static headlight range adjustment: spec./counter-Specified value,not coded/not installed,
IDE10260-MAS10076,Static headlight range adjustment: spec./counter-Step index,not coded/not installed,
IDE10260-MAS11358,Static headlight range adjustment: spec./counter-Number of adjustments left motor,0,
IDE10260-MAS11359,Static headlight range adjustment: spec./counter-Number of adjustments right motor,0,
IDE10327-MAS01632,Cupholder with heating and cooling element-Status,not coded/not installed,
IDE10327-MAS01968,Cupholder with heating and cooling element-Fan,not coded/not installed,
IDE10327-MAS02819,Cupholder with heating and cooling element-CURRENT temperature,not coded/not installed,
IDE10327-MAS02832,Cupholder with heating and cooling element-Malfunction status,not coded/not installed,
IDE10327-MAS10303,Cupholder with heating and cooling element-Heating function indicator lamp,not coded/not installed,
IDE10327-MAS10304,Cupholder with heating and cooling element-Cooling function indicator lamp,not coded/not installed,
IDE10327-MAS10305,Cupholder with heating and cooling element-Light for residual heat display,not coded/not installed,
IDE10327-MAS10333,Cupholder with heating and cooling element-Heat function button,not coded/not installed,
IDE10327-MAS10334,Cupholder with heating and cooling element-Cooling function button,not coded/not installed,
IDE10327-MAS10336,Cupholder with heating and cooling element-Peltier element,not coded/not installed,
IDE10327-MAS10337,Cupholder with heating and cooling element-Peltier element: PWM value,not coded/not installed,
IDE10338,Ctrl. motor for left headlight range adjust.: act. value,Measured value not available,
IDE10339,Ctrl. motor for right headlight range adjust.: act. value,Measured value not available,
IDE10340-IDE00104,Roof electronics control module-DTC,0,
IDE10340-MAS01634,Roof electronics control module-Supply voltage,13.90, V
IDE10340-MAS02832,Roof electronics control module-Malfunction status,not faulty,
IDE10340-MAS05946,Roof electronics control module-Actual temp.,50, °C
IDE10340-MAS09113,Roof electronics control module-Maximum temperature,110, °C
IDE10343-MAS01795,Roof electronics control module: dim. value-Front interior light,0, %
IDE10343-MAS10432,Roof electronics control module: dim. value-Uplight: front,255, %
IDE10343-MAS10433,Roof electronics control module: dim. value-Search rings,255, %
IDE10343-MAS10434,Roof electronics control module: dim. value-indicator lights,54, %
IDE10344-MAS10485,Roof electr.ctrl module: read. light/ceiling contour lights-Left front reading lamp: dim. value,0, %
IDE10344-MAS10486,Roof electr.ctrl module: read. light/ceiling contour lights-Left front reading lamp: diagnosis,Unknown (1),
IDE10344-MAS10487,Roof electr.ctrl module: read. light/ceiling contour lights-Right front reading lamp: dim. value,0, %
IDE10344-MAS10488,Roof electr.ctrl module: read. light/ceiling contour lights-Right front reading lamp: diagnosis,Unknown (1),
IDE10344-MAS10489,Roof electr.ctrl module: read. light/ceiling contour lights-Left rear reading lamp: dim. value,0, %
IDE10344-MAS10490,Roof electr.ctrl module: read. light/ceiling contour lights-Left rear reading lamp: diagnosis,Unknown (0),
IDE10344-MAS10491,Roof electr.ctrl module: read. light/ceiling contour lights-Right rear reading lamp: dim. value,0, %
IDE10344-MAS10492,Roof electr.ctrl module: read. light/ceiling contour lights-Right rear reading lamp: diagnosis,Unknown (0),
IDE10344-MAS10493,Roof electr.ctrl module: read. light/ceiling contour lights-Left read. lamp: 3rd seat row: dim. value,0, %
IDE10344-MAS10494,Roof electr.ctrl module: read. light/ceiling contour lights-Left read. lamp: 3rd seat row: diagnosis,Unknown (0),
IDE10344-MAS10495,Roof electr.ctrl module: read. light/ceiling contour lights-Right read. lamp: 3rd seat row: dim. value,0, %
IDE10344-MAS10496,Roof electr.ctrl module: read. light/ceiling contour lights-Right read. lamp: 3rd seat row: diagnosis,Unknown (0),
IDE10344-MAS10497,Roof electr.ctrl module: read. light/ceiling contour lights-Ceiling contour lights: dim. value,255, %
IDE10344-MAS10498,Roof electr.ctrl module: read. light/ceiling contour lights-Ceiling contour lights: diagnosis,Short circuit to ground,
IDE10345-MAS10416,Roof electronics control module: button-Front interior light button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10418,Roof electronics control module: button-Front button for rear reading light,Not operated,
IDE10345-MAS10419,Roof electronics control module: button-Front reading lamp button: left,Not operated,
IDE10345-MAS10420,Roof electronics control module: button-Front reading lamp button: right,Not operated,
IDE10345-MAS10421,Roof electronics control module: button-Left rear reading lamp switch,Not operated,
IDE10345-MAS10422,Roof electronics control module: button-Right rear reading lamp button,Not operated,
IDE10345-MAS10423,Roof electronics control module: button-Left reading light button: 3rd seat row,Not operated,
IDE10345-MAS10424,Roof electronics control module: button-Right reading light button: 3rd seat row,Not operated,
IDE10345-MAS10425,Roof electronics control module: button-Emergency call button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE10346-MAS10427,Roof electronics control module: indicator lights-Indicator lamp for interior light: front,OFF,
IDE10346-MAS10428,Roof electronics control module: indicator lights-Indicator light for door contact switching,OFF,
IDE10346-MAS10429,Roof electronics control module: indicator lights-Indicator lamp for front reading light,OFF,
IDE10346-MAS10430,Roof electronics control module: indicator lights-Indicator light for emerg. call,On,
IDE10346-MAS10431,Roof electronics control module: indicator lights-Indicator light for roadside assist.,OFF,
IDE10360-MAS01442,A/C compressor speed sensor-Compressor speed,not coded/not installed,
IDE10360-MAS10225,A/C compressor speed sensor-Signal level,not coded/not installed,
IDE10360-MAS10455,A/C compressor speed sensor-Deviation of compressor speed from specified RPM,not coded/not installed,
IDE10361-MAS06905,Driver information sensor-Washer fluid level sensor,3.97, kOhm
IDE10361-MAS06906,Driver information sensor-Sensor for inadequate coolant level display,1.21, kOhm
IDE10361-MAS07003,Driver information sensor-Sensor 2 for inadequate coolant level display,not coded/not installed,
IDE10482-MAS01632,Release for external systems-Status,not coded/not installed,
IDE10482-MAS07929,Release for external systems-Power quota setting by energy management,not coded/not installed,
IDE10482-MAS10746,Release for external systems-Installation info.: external system,no system,
IDE10808-MAS06614,Directional stabilization assistance button-Version,not coded/not installed,
IDE10808-MAS07693,Directional stabilization assistance button-Button Status,not coded/not installed,
IDE10808-MAS07694,Directional stabilization assistance button-Button status on CAN,Initialization/not installed,
IDE10808-MAS08062,Directional stabilization assistance button-Indicator light activation,OFF,
IDE10810-MAS06614,Button for side view camera-Version,not coded/not installed,
IDE10810-MAS07693,Button for side view camera-Button Status,not coded/not installed,
IDE10810-MAS07694,Button for side view camera-Button status on CAN,Initialization/not installed,
IDE11273-MAS10360,Control unit 2 for driv.and convenience funct.: special funct.-Lift button for vehicle leveling,not coded/not installed,
IDE11273-MAS10361,Control unit 2 for driv.and convenience funct.: special funct.-Lower button for vehicle leveling,not coded/not installed,
IDE11273-MAS12379,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: actual mode,not coded/not installed,
IDE11273-MAS12380,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: mode setting,not coded/not installed,
IDE11273-MAS12499,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for load level,not coded/not installed,
IDE11273-MAS12500,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for low level,not coded/not installed,
IDE11273-MAS12501,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for high level,not coded/not installed,
IDE11273-MAS12502,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for special off-road level,not coded/not installed,
IDE11274-MAS08932,Operating controls for sunroof/tilt roof and roof blind-Sunroof shade button,not coded/not installed,
IDE11274-MAS12383,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof,not coded/not installed,
IDE11274-MAS12515,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof: rear,not coded/not installed,
IDE11274-MAS12516,Operating controls for sunroof/tilt roof and roof blind-Button sunroof shade button: rear,not coded/not installed,
IDE11301-MAS12561,Number of events: headlight theft monitoring-Theft: left headlight suspected due to cold monitoring,0,
IDE11301-MAS12562,Number of events: headlight theft monitoring-Theft: right headlight suspected due to cold monitoring,0,
IDE11301-MAS12563,Number of events: headlight theft monitoring-Theft: left headlight confirmed due to heat monitoring,0,
IDE11301-MAS12564,Number of events: headlight theft monitoring-Theft: right headlight confirmed due to heat monitoring,0,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,95, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,370, W/m²
IDE12318-MAS01580,Left signature light bulb: supply-Activation,not coded/not installed,
IDE12318-MAS01737,Left signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12318-MAS12621,Left signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12319-MAS01580,Right signature light bulb: supply-Activation,not coded/not installed,
IDE12319-MAS01737,Right signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12319-MAS12621,Right signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12342-MAS06614,Button engine sound generation-Version,not coded/not installed,
IDE12342-MAS07693,Button engine sound generation-Button Status,not coded/not installed,
IDE12342-MAS07694,Button engine sound generation-Button status on CAN,Initialization/not installed,
IDE12342-MAS07699,Button engine sound generation-Status indicator light on CAN,ERROR,
IDE12342-MAS08062,Button engine sound generation-Indicator light activation,not coded/not installed,
IDE12826-MAS07693,Engine noise selection button-Button Status,not coded/not installed,
IDE12826-MAS07694,Engine noise selection button-Button status on CAN,Not operated,
IDE12882-MAS06614,Rear window shade button 2-Version,not coded/not installed,
IDE12882-MAS07693,Rear window shade button 2-Button Status,not coded/not installed,
IDE12882-MAS07694,Rear window shade button 2-Button status on CAN,Initialization/not installed,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06997,Head area heater-Outside temperature: filtered,Temp. sensor not installed,
IDE80251-MAS09637,Head area heater-Head area heater left: release,not coded/not installed,
IDE80251-MAS09638,Head area heater-Head area heater right: release,not coded/not installed,
IDE80251-MAS09639,Head area heater-Head area heater left: output DTM,not coded/not installed,
IDE80251-MAS09640,Head area heater-Head area heater right: output DTM,not coded/not installed,
IDE80251-MAS09641,Head area heater-Interior temperature,Temp. sensor not installed,
IDE80251-MAS09642,Head area heater-Adaptation vent temperature,not coded/not installed,
IDE80251-MAS09643,Head area heater-Adaptation fan speed,not coded/not installed,
IDE80251-MAS09646,Head area heater-Occupation status not available,not coded/not installed,
IDE80251-MAS09778,Head area heater-Convert. top open and locked,not coded/not installed,
IDE80251-MAS09779,Head area heater-Convert. top closed and locked,not coded/not installed,
ENG02609,average_Voltage_terminals,14.10, V
ENG26644-ENG30703,Data_Definitions-Data_Definition_BAP_Climate_Master,,
ENG26644-ENG30704,Data_Definitions-Data_Definition_BAP_Climate_Zone_1_2,,
ENG26644-ENG30705,Data_Definitions-Data_Definition_BAP_Climate_Zone_3_4,,
ENG26644-ENG30706,Data_Definitions-Data_Definition_BAP_Clock,,
ENG26644-ENG30707,Data_Definitions-Data_Definition_BAP_ExteriorLight,,
ENG26644-ENG30708,Data_Definitions-Data_Definition_BAP_InteriorLight,,
ENG26644-ENG30709,Data_Definitions-Data_Definition_BAP_Parkheater,,
ENG26644-ENG30710,Data_Definitions-Data_Definition_BAP_PDC,,
ENG26644-ENG30711,Data_Definitions-Data_Definition_BAP_SeatPneumatic,,
ENG26644-ENG30712,Data_Definitions-Data_Definition_BAP_TrailorAssist,,
ENG26644-ENG30713,Data_Definitions-Data_Definition_BAP_Wiper,,
ENG26644-ENG30714,Data_Definitions-Data_Definition_CAN_Frontlight,ýý"
&òÿþÿþpaÈ2¹2½NŽBù,
ENG26644-ENG30715,Data_Definitions-Data_Definition_CAN_Komfort,D"ýý"
&òÿþÿþpaÈ2¹2½NŽBù,
ENG26644-ENG30716,Data_Definitions-Data_Definition_LIN_1,"
&òÿþÿþpaÈ2¹2½NŽBù,
ENG26644-ENG30717,Data_Definitions-Data_Definition_LIN_10,,
ENG26644-ENG30718,Data_Definitions-Data_Definition_LIN_11,,
ENG26644-ENG30719,Data_Definitions-Data_Definition_LIN_12,,
ENG26644-ENG30720,Data_Definitions-Data_Definition_LIN_2,þpaÈ2¹2½NŽBù,
ENG26644-ENG30721,Data_Definitions-Data_Definition_LIN_3,aÈ2¹2½NŽBù,
ENG26644-ENG30722,Data_Definitions-Data_Definition_LIN_4,¹2½NŽBù,
ENG26644-ENG30723,Data_Definitions-Data_Definition_LIN_5,,
ENG26644-ENG30724,Data_Definitions-Data_Definition_LIN_6,,
ENG26644-ENG30725,Data_Definitions-Data_Definition_LIN_7,,
ENG26644-ENG30726,Data_Definitions-Data_Definition_LIN_8,,
ENG26644-ENG30727,Data_Definitions-Data_Definition_LIN_9,,
ENG02611-ENG02852,EVLS-block_counter_axial_in,not coded/not installed,
ENG02611-ENG02851,EVLS-block_counter_axial_out,not coded/not installed,
ENG02611-ENG02850,EVLS-block_counter_vertically_down,not coded/not installed,
ENG02611-ENG02849,EVLS-block_counter_vertically_up,not coded/not installed,
ENG02611-ENG02847,EVLS-drivers_door_open,not coded/not installed,
ENG02611-ENG02856,EVLS-Electrically_adjustable_steering_column_BCM1_down,not coded/not installed,
ENG02611-ENG02858,EVLS-Electrically_adjustable_steering_column_BCM1_in,not coded/not installed,
ENG02611-ENG02857,EVLS-Electrically_adjustable_steering_column_BCM1_out,not coded/not installed,
ENG02611-ENG02855,EVLS-Electrically_adjustable_steering_column_BCM1_up,not coded/not installed,
ENG02611-ENG02845,EVLS-Electrically_adjustable_steering_column_error,not coded/not installed,
ENG02611-ENG02853,EVLS-Electrically_adjustable_steering_column_response_error,not coded/not installed,
ENG02611-ENG02848,EVLS-Electrically_adjustable_steering_column_state,not coded/not installed,
ENG02611-ENG02844,EVLS-Electrically_adjustable_steering_column_state_HV,not coded/not installed,
ENG02611-ENG02843,EVLS-Electrically_adjustable_steering_column_state_LV,not coded/not installed,
ENG02611-ENG02842,EVLS-FS_MMB_global_stop_mode,not coded/not installed,
ENG02611-ENG02838,EVLS-FS_MMB_storage_mode,not coded/not installed,
ENG02611-ENG02841,EVLS-FS_MMB_store_mode,not coded/not installed,
ENG02611-ENG02840,EVLS-FS_MMB_tap_mode,not coded/not installed,
ENG02611-ENG02839,EVLS-FS_MMB_tip_mode,not coded/not installed,
ENG02611-ENG02846,EVLS-LSV_EE_switch,not coded/not installed,
ENG02611-ENG02854,EVLS-motor_start_stopp_restart,not coded/not installed,
ENG101323,Headlight leveling control state,Measured value not available,
ENG02610,interior_temperature,27.50, °C
ENG107366,Left headlight leveling motor position,Measured value not available,
ENG116804-ENG121679,Light sensor parameter-BRGC6,0,
ENG116804-ENG121663,Light sensor parameter-darkstart_mode,not active,
ENG116804-ENG121664,Light sensor parameter-night_mode,not active,
ENG116804-ENG121667,Light sensor parameter-night_sensitivity,not active,
ENG116804-ENG121666,Light sensor parameter-rain_mode,not active,
ENG116804-ENG121671,Light sensor parameter-rb_Amb_Night_Threshold_g,135,
ENG116804-ENG03606,Light sensor parameter-rb_E2_Sensor_Error_1_g,0,
ENG116804-ENG03607,Light sensor parameter-rb_E2_Sensor_Error_2_g,0,
ENG116804-ENG03608,Light sensor parameter-rb_E2_Sensor_Error_3_g,0,
ENG116804-ENG03609,Light sensor parameter-rb_E2_Sensor_Error_4_g,0,
ENG116804-ENG121672,Light sensor parameter-rb_FW_Night_Threshold_g,135,
ENG116804-ENG121670,Light sensor parameter-rb_IR_Day_Threshold_g,45,
ENG116804-ENG121673,Light sensor parameter-rb_IR_Night_Threshold_g,68,
ENG116804-ENG121676,Light sensor parameter-rb_LIN_BIT_ERROR_COUNTER_g,0,
ENG116804-ENG121678,Light sensor parameter-rb_LIN_BIT_NORESPONSE_COUNTER_g,0,
ENG116804-ENG03603,Light sensor parameter-rb_LIN_CHECKSUM_ERROR_COUNTER_g,0,
ENG116804-ENG03605,Light sensor parameter-rb_LIN_FRAME_ERROR_COUNTER_g,0,
ENG116804-ENG03604,Light sensor parameter-rb_LIN_OVER_T_FRAME_MAX_COUNTER_g,0,
ENG116804-ENG03602,Light sensor parameter-rb_LIN_OVER_T_HEADER_MAX_COUNTER_g,0,
ENG116804-ENG121668,Light sensor parameter-rw_Amb_Day_Threshold_g,93,
ENG116804-ENG121662,Light sensor parameter-rw_Amb_light16bit_g,4046, bit
ENG116804-ENG121674,Light sensor parameter-rw_dayCounter_mg,0,
ENG116804-ENG121669,Light sensor parameter-rw_FW_Day_Threshold_g,90,
ENG116804-ENG121660,Light sensor parameter-rw_FW_light16bit_g,714, bit
ENG116804-ENG121661,Light sensor parameter-rw_IR_light16bit_g,974, bit
ENG116804-ENG121675,Light sensor parameter-rw_nightCounter_mg,0,
ENG116804-ENG121665,Light sensor parameter-tunnel_mode,not active,
ENG02672-ENG121648,Rain_sensor_parameters-rb_CloseTypeStandby_g,0,
ENG02672-ENG121657,Rain_sensor_parameters-rb_Errorflags_g,0,
ENG02672-ENG121651,Rain_sensor_parameters-rb_HumTemp_ErrorCode_g,0,
ENG02672-ENG121653,Rain_sensor_parameters-rb_NoCommunicationCounter,0,
ENG02672-ENG121641,Rain_sensor_parameters-rb_PotiStageFromBox_g,5,
ENG02672-ENG121642,Rain_sensor_parameters-rb_PWM_Voltage_g,128,
ENG02672-ENG121652,Rain_sensor_parameters-rb_StaticNoCommunicationCounter,0,
ENG02672-ENG121654,Rain_sensor_parameters-rb_SupplyVoltage_mg,179,
ENG02672-ENG03611,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Max_g,141,
ENG02672-ENG03610,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Min_g,139,
ENG02672-ENG121640,Rain_sensor_parameters-rub_Empf_Faktor,20,
ENG02672-ENG121639,Rain_sensor_parameters-rub_Int_Speicher,0,
ENG02672-ENG121645,Rain_sensor_parameters-rub_LengthCounter,166,
ENG02672-ENG121643,Rain_sensor_parameters-rub_Nachwisch_Count,0,
ENG02672-ENG121638,Rain_sensor_parameters-rub_Ovr_Speicher,0,
ENG02672-ENG121646,Rain_sensor_parameters-rub_PulseCounter,4,
ENG02672-ENG121647,Rain_sensor_parameters-rub_SignalIntegral_g,0,
ENG02672-ENG121644,Rain_sensor_parameters-ruw_StX_Speicher,0,
ENG02672-ENG121650,Rain_sensor_parameters-rw_HumiTicks_g,8312,
ENG02672-ENG121649,Rain_sensor_parameters-rw_TempTicks_g,978,
ENG108469,Right headlight leveling motor position,Measured value not available,
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,0,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,3,
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,0,
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Slope,5,
ENG03700-ENG109174,sw_version_integration_afs-SW_VERSION,I266,
Elapsed Time: 01:29
blockmap-09-8W0-907-063-CE
;SW:8W0-907-063-CE   HW:8W0-907-063-BE ---  Cent. Elect.
;Component:BCM1 MLBevo   H13 0267, Coding:C2500362C0081CCD051587149CAE98B9100B3D08000000000000000000001A0001610002001204
;EV_BCM1BOSCHAU736,018006,EV_BCM1BOSCHAU736_018_AU49.rod
;Friday,12,July,2019,16:07:33:64285
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: 804383401BF89E4F19-80D4
Group,Description,Actual
IDE01164-MAS06614,Park assist button-Version,not coded/not installed,
IDE01164-MAS07693,Park assist button-Button Status,not coded/not installed,
IDE01164-MAS07694,Park assist button-Button status on CAN,Initialization/not installed,
IDE01164-MAS07699,Park assist button-Status indicator light on CAN,OFF,
IDE01164-MAS08062,Park assist button-Indicator light activation,not coded/not installed,
IDE01236-MAS01580,Coolant recirculation pump-Activation,not coded/not installed,
IDE01236-MAS01634,Coolant recirculation pump-Supply voltage,not coded/not installed,
IDE01236-MAS06707,Coolant recirculation pump-Operating mode,not coded/not installed,
IDE01236-MAS07836,Coolant recirculation pump-Eng. delay. cool. shutdown,not coded/not installed,
IDE01236-MAS07837,Coolant recirculation pump-Last reason for local activity,not coded/not installed,
IDE01236-MAS07839,Coolant recirculation pump-Status feedback,not coded/not installed,
IDE01236-MAS12621,Coolant recirculation pump-Current draw (effective value),not coded/not installed,
IDE01266-MAS01580,Coolant shut-off valve-Activation,OFF,
IDE01266-MAS07806,Coolant shut-off valve-Spec. cond.,Open,
IDE01266-MAS12621,Coolant shut-off valve-Current draw (effective value),0, mA
IDE01268-MAS01464,Windshield wiper-Emergency running mode,not active,
IDE01268-MAS01632,Windshield wiper-Status,not active,
IDE01268-MAS02832,Windshield wiper-Malfunction status,not faulty,
IDE01268-MAS03006,Windshield wiper-Overload,not active,
IDE01268-MAS03638,Windshield wiper-Wipe speed,No wiping,
IDE01268-MAS06732,Windshield wiper-Status local activity,not active,
IDE01268-MAS06897,Windshield wiper-Wipe cycle counter,860,
IDE01268-MAS07055,Windshield wiper-Response error,not active,
IDE01268-MAS07998,Windshield wiper-park position,active,
IDE01268-MAS09379,Windshield wiper-Service position,not active,
IDE01268-MAS09595,Windshield wiper-Production mode,not active,
IDE01268-MAS09596,Windshield wiper-Debug Data,On,
IDE01268-MAS09597,Windshield wiper-Turn posn.,not active,
IDE01268-MAS09626,Windshield wiper-Status error validity,valid,
IDE01268-MAS09627,Windshield wiper-Error status: wiper 2,not faulty,
IDE01268-MAS09628,Windshield wiper-Overload: wiper 2,not active,
IDE01268-MAS09629,Windshield wiper-Status error validity: wiper 2,invalid,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,0, %
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,0, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,OFF,
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,OFF,
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,not coded/not installed,
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,30.20, °C
IDE01540-MAS07052,Left front heated seat-Setting,OFF,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,6.67, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,not coded/not installed,
IDE01540-MAS07921,Left front heated seat-Balance setting,Neutral,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,0, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,OFF,
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,OFF,
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not active,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not coded/not installed,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,-0.03, V
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,0, %
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,OFF,
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,OFF,
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,not coded/not installed,
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,32.60, °C
IDE01541-MAS07052,Right front heated seat-Setting,OFF,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,6.10, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,not coded/not installed,
IDE01541-MAS07921,Right front heated seat-Balance setting,Neutral,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,0, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,OFF,
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,OFF,
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not active,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not coded/not installed,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,-0.03, V
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01544-MAS05377,Auxiliary Air Heater-Low heat output relay,not coded/not installed,
IDE01544-MAS05378,Auxiliary Air Heater-High heat output relay,not coded/not installed,
IDE01544-MAS07914,Auxiliary Air Heater-Heating stage: spec value,not coded/not installed,
IDE01544-MAS12633,Auxiliary Air Heater-Relay for small heater output: current draw (effective value),not coded/not installed,
IDE01544-MAS12634,Auxiliary Air Heater-Relay for large heater output: current draw (effective value),not coded/not installed,
IDE01946,ESP intervention,OFF,
IDE01965-MAS06614,Parallel parking assistance button-Version,not coded/not installed,
IDE01965-MAS07693,Parallel parking assistance button-Button Status,not coded/not installed,
IDE01965-MAS07694,Parallel parking assistance button-Button status on CAN,Initialization/not installed,
IDE01965-MAS07699,Parallel parking assistance button-Status indicator light on CAN,OFF,
IDE01965-MAS08062,Parallel parking assistance button-Indicator light activation,not coded/not installed,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,34 8E E9 B7,
IDE01992-SFT00009,Installation list: current installations-Central Electrics,can be reached,
IDE01992-SFT00041,Installation list: current installations-Light Control Left,can be reached,
IDE01992-SFT00057,Installation list: current installations-Light Control Right,can be reached,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,cannot be reached,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,cannot be reached,
IDE01993-SFT00009,Control module reference number-Central Electrics,Central Electrics,
IDE01993-SFT00041,Control module reference number-Light Control Left,Light Control Left,
IDE01993-SFT00057,Control module reference number-Light Control Right,Light Control Right,
IDE01993-SFT00214,Control module reference number-Light Control Left 2,Light Control Left 2,
IDE01993-SFT00215,Control module reference number-Light Control Right 2,Light Control Right 2,
IDE01995-SFT00009,Control module protocol information-Central Electrics,ISO-TP,
IDE01995-SFT00041,Control module protocol information-Light Control Left,ISO-TP,
IDE01995-SFT00057,Control module protocol information-Light Control Right,ISO-TP,
IDE01995-SFT00214,Control module protocol information-Light Control Left 2,ISO-TP,
IDE01995-SFT00215,Control module protocol information-Light Control Right 2,ISO-TP,
IDE02384-SFT00009,Status of event memory-Central Electrics,ERROR,
IDE02384-SFT00041,Status of event memory-Light Control Left,OK,
IDE02384-SFT00057,Status of event memory-Light Control Right,ERROR,
IDE02384-SFT00214,Status of event memory-Light Control Left 2,OK,
IDE02384-SFT00215,Status of event memory-Light Control Right 2,OK,
IDE02455-MAS06911,Light function "Coming/Leaving Home"-Status Coming Home,not active,
IDE02455-MAS06912,Light function "Coming/Leaving Home"-Status Leaving Home,not active,
IDE02711-MAS09598,Rear Window Wiper-Request on CAN,OFF,
IDE02711-MAS09599,Rear Window Wiper-Error status via CAN,No error: no wiper activation,
IDE03111-MAS06885,Interior light-Terminal 30 for interior illumination,84, %
IDE03111-MAS06886,Interior light-Interior light delay (dimmer),0, %
IDE03111-MAS06986,Interior light-Footwell illumination rear,0, %
IDE03111-MAS06987,Interior light-Footwell illumination front,0, %
IDE03111-MAS09295,Interior light-ambient light.chan. 1,0, %
IDE03111-MAS09297,Interior light-Ambient illumination power supply,not coded/not installed,
IDE03111-MAS12622,Interior light-Terminal 30 for interior lighting: current draw (effect. value),5, mA
IDE03111-MAS12623,Interior light-Foot well illumination: rear: current draw (effective value),0, mA
IDE03111-MAS12624,Interior light-Foot well illumination: front: current draw (effective value),0, mA
IDE03111-MAS12625,Interior light-Ambient illumination channel 1: current draw (effective value),0, mA
IDE03111-MAS12626,Interior light-Supply for ambient illumination: current draw (effective value),not coded/not installed,
IDE03111-MAS12627,Interior light-Trunk illumination: front: current draw (effective value),not coded/not installed,
IDE03150-SFT00009,Readiness for bus sleep mode-Central Electrics,active,
IDE03150-SFT00041,Readiness for bus sleep mode-Light Control Left,Sleep mode,
IDE03150-SFT00057,Readiness for bus sleep mode-Light Control Right,Sleep mode,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,active,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,active,
IDE03197-IDE08190,Rain/Light Recognition Sensor-Request exterior illumination,OFF,
IDE03197-MAS02475,Rain/Light Recognition Sensor-Brightness infrared,43200, lx
IDE03197-MAS03637,Rain/Light Recognition Sensor-Rain quantity,0, %
IDE03197-MAS04806,Rain/Light Recognition Sensor-Splash,not active,
IDE03197-MAS06899,Rain/Light Recognition Sensor-Request glass close,not active,
IDE03197-MAS06900,Rain/Light Recognition Sensor-Status glass,closed,
IDE03197-MAS06998,Rain/Light Recognition Sensor-Request exterior illumination: inverse,On,
IDE03197-MAS06999,Rain/Light Recognition Sensor-Bright/dark information,Bright,
IDE03197-MAS07055,Rain/Light Recognition Sensor-Response error,not active,
IDE03197-MAS09630,Rain/Light Recognition Sensor-Qualification status of exterior lighting requirement,valid,
IDE03197-MAS09631,Rain/Light Recognition Sensor-Highway light requirement,OFF,
IDE03197-MAS09632,Rain/Light Recognition Sensor-Rain light requirement,OFF,
IDE03197-MAS09633,Rain/Light Recognition Sensor-Wiper speed requirement,No wiping,
IDE03197-MAS09634,Rain/Light Recognition Sensor-Adaptation error,not active,
IDE03197-MAS09635,Rain/Light Recognition Sensor-Error status rain sensors,not faulty,
IDE03197-MAS09636,Rain/Light Recognition Sensor-Error status light sensors,not faulty,
IDE03197-MAS10232,Rain/Light Recognition Sensor-Brightness ahead,4674, lx
IDE03197-MAS10233,Rain/Light Recognition Sensor-Brightness ahead: boost,up to 6428 Lux,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03602,Left front level control system sensor,Measured value not available,
IDE03604,Left rear level control system sensor,Measured value not available,
IDE03620,Front jounce travel,Measured value not available,
IDE03621,Rear jounce travel,Measured value not available,
IDE03622,Left headlight beam adjusting motor: status,Measured value not available,
IDE03623,Right headlight beam adjusting motor: status,Measured value not available,
IDE03628,Adjusting motor for variable left front lighting: status,Measured value not available,
IDE03629,Adjusting motor for variable right front lighting: status,Measured value not available,
IDE03630,Left headlight beam adjusting motor: specified value,Measured value not available,
IDE03631,Right headlight beam adjusting motor: specified value,Measured value not available,
IDE03632,Left-/right hand driving switch-over,Measured value not available,
IDE03638-IDE03717,static AFS light-Dim static left AFS light,Measured value not available,
IDE03638-IDE03718,static AFS light-Dim static right AFS light,Measured value not available,
IDE03662-MAS06614,ASR/ESP button-Version,Local data bus: operating unit 1,
IDE03662-MAS07693,ASR/ESP button-Button Status,Not operated,
IDE03662-MAS07694,ASR/ESP button-Button status on CAN,Not operated,
IDE03662-MAS07699,ASR/ESP button-Status indicator light on CAN,OFF,
IDE03662-MAS08062,ASR/ESP button-Indicator light activation,OFF,
IDE03663-MAS06614,-AUTO HOLD- Button-Version,not coded/not installed,
IDE03663-MAS07693,-AUTO HOLD- Button-Button Status,not coded/not installed,
IDE03663-MAS07694,-AUTO HOLD- Button-Button status on CAN,Initialization/not installed,
IDE03663-MAS07699,-AUTO HOLD- Button-Status indicator light on CAN,OFF,
IDE03663-MAS08062,-AUTO HOLD- Button-Indicator light activation,not coded/not installed,
IDE03669,Light distribution status,Measured value not available,
IDE03679-MAS09575,Adaptive light functions-High beam request,OFF,
IDE03679-MAS10260,Adaptive light functions-Request for automatic high beam,OFF,
IDE03679-MAS10261,Adaptive light functions-Automatic high beam availability,not coded/not installed,
IDE03679-MAS10264,Adaptive light functions-High beam: status,not coded/not installed,
IDE03679-MAS10265,Adaptive light functions-Left high beam: error status,not coded/not installed,
IDE03679-MAS10266,Adaptive light functions-Right high beam: error status,not coded/not installed,
IDE03679-MAS10268,Adaptive light functions-Matrix automatic high beam availability,not coded/not installed,
IDE03679-MAS10271,Adaptive light functions-Matrix high beam: status,not coded/not installed,
IDE03679-MAS10272,Adaptive light functions-Left Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10273,Adaptive light functions-Right Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10274,Adaptive light functions-Sensor status: auto. high beam,not coded/not installed,
IDE03679-MAS10275,Adaptive light functions-Matrix auto. high beam: sensor status,not coded/not installed,
IDE03680-MAS00043,Supply voltages-Supply voltage: Terminal 30,14.15, V
IDE03680-MAS06254,Supply voltages-Supply voltage Terminal 30 - 2,14.17, V
IDE03680-MAS06255,Supply voltages-Supply voltage Terminal 30 - 3,14.23, V
IDE03680-MAS06490,Supply voltages-Terminal 15 load,14.15, V
IDE03680-MAS06838,Supply voltages-Supply voltage: terminal 30 left,14.17, V
IDE03680-MAS06839,Supply voltages-Supply voltage terminal 30 right,14.21, V
IDE03680-MAS06840,Supply voltages-Supply voltage Terminal 30 - 4,14.28, V
IDE03680-MAS06841,Supply voltages-Supply voltage Terminal 30 - 5,14.17, V
IDE03680-MAS06842,Supply voltages-Supply voltage Terminal 30 - 6,14.25, V
IDE03727,Variable left front lighting specified position,Measured value not available,
IDE03728,Variable right front lighting specified position,Measured value not available,
IDE03788,Status of basic headlamp setting,Measured value not available,
IDE03850,Left front level ctrl sys sensor: adaptation value (zero pos),Measured value not available,
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),Measured value not available,
IDE04343-SFT00009,Bus identification-Central Electrics,Busmaster,
IDE04343-SFT00041,Bus identification-Light Control Left,AFS/From light data bus,
IDE04343-SFT00057,Bus identification-Light Control Right,AFS/From light data bus,
IDE04343-SFT00214,Bus identification-Light Control Left 2,AFS/From light data bus,
IDE04343-SFT00215,Bus identification-Light Control Right 2,AFS/From light data bus,
IDE04806-MAS06614,Driving profile selection button-Version,Local data bus: operating unit 1,
IDE04806-MAS07693,Driving profile selection button-Button Status,Not operated,
IDE04806-MAS07694,Driving profile selection button-Button status on CAN,Not operated,
IDE04923-MAS08125,Turn signal control-Left front turn signal bulb: status,OFF,
IDE04923-MAS08127,Turn signal control-Right front turn signal bulb: status,OFF,
IDE04923-MAS08131,Turn signal control-Left turn signal lights: clock,OFF,
IDE04923-MAS08132,Turn signal control-Right turn signal lights: clock,OFF,
IDE05042-MAS06614,Emergency flasher button-Version,Discreet wire,
IDE05042-MAS07693,Emergency flasher button-Button Status,Not operated,
IDE05042-MAS07694,Emergency flasher button-Button status on CAN,Not operated,
IDE05042-MAS08062,Emergency flasher button-Indicator light activation,OFF,
IDE05071-MAS06614,Lane change assistance button-Version,not coded/not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not coded/not installed,
IDE05071-MAS07694,Lane change assistance button-Button status on CAN,Initialization/not installed,
IDE05071-MAS08062,Lane change assistance button-Indicator light activation,not coded/not installed,
IDE05534-MAS01580,Headlamp washer system-Activation,not coded/not installed,
IDE05534-MAS12621,Headlamp washer system-Current draw (effective value),not coded/not installed,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,58.90, °C
IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,58.50, °C
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,20, %
IDE06091-MAS04647,Humidity sensor: internal-Dew point,15.80, °C
IDE06091-MAS07055,Humidity sensor: internal-Response error,not active,
IDE06644-MAS06993,Vehicle positioning system-Request signal horn,not coded/not installed,
IDE06644-MAS09570,Vehicle positioning system-Parking light request,not coded/not installed,
IDE06644-MAS09571,Vehicle positioning system-Low beam request,not coded/not installed,
IDE06752-MAS06614,Hill descent control button-Version,Local data bus: operating unit 1,
IDE06752-MAS07693,Hill descent control button-Button Status,Not operated,
IDE06752-MAS07694,Hill descent control button-Button status on CAN,Not operated,
IDE06752-MAS07699,Hill descent control button-Status indicator light on CAN,OFF,
IDE06752-MAS08062,Hill descent control button-Indicator light activation,OFF,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,01,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,08,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07991-MAS01580,A/C clutch-Activation,not coded/not installed,
IDE07991-MAS07919,A/C clutch-Min current consumption: spec value,not coded/not installed,
IDE07991-MAS12621,A/C clutch-Current draw (effective value),not coded/not installed,
IDE07991-MAS12776,A/C clutch-Spec.val. min.cur. draw prior to rec.op.circ./short circ. to B+,not coded/not installed,
IDE07991-MAS12778,A/C clutch-Act.val. min.curr. draw prior to recogn open circ/sh circ to B+,not coded/not installed,
IDE08125-MAS01458,Left cabin heater-Operating condition,not coded/not installed,
IDE08125-MAS02832,Left cabin heater-Malfunction status,not coded/not installed,
IDE08125-MAS06652,Left cabin heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08125-MAS07055,Left cabin heater-Response error,not coded/not installed,
IDE08125-MAS09644,Left cabin heater-Vent temperature,not coded/not installed,
IDE08125-MAS12677,Left cabin heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08126-MAS01458,Right cabin heater-Operating condition,not coded/not installed,
IDE08126-MAS02832,Right cabin heater-Malfunction status,not coded/not installed,
IDE08126-MAS06652,Right cabin heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS07055,Right cabin heater-Response error,not coded/not installed,
IDE08126-MAS09644,Right cabin heater-Vent temperature,not coded/not installed,
IDE08126-MAS12677,Right cabin heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08196-IDE01351,Terminal control-Terminal 75 status,On,
IDE08196-MAS06982,Terminal control-Terminal 15 status signal,On,
IDE08196-MAS07720,Terminal control-Terminal 15 via CAN,On,
IDE08196-MAS08123,Terminal control-Term 75: qualification,OFF,
IDE08343,Immobilizer Challenge,CD 42 8C 2C,
IDE08364-MAS01447,Left seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE08364-MAS01448,Left seat backrest fan 1: activation-Specified value,not coded/not installed,
IDE08365-MAS01447,Left seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08365-MAS01448,Left seat backrest fan 2: activation-Specified value,not coded/not installed,
IDE08366-MAS01447,Left seat seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE08366-MAS01448,Left seat seat cushion fan 1: activation-Specified value,not coded/not installed,
IDE08367-MAS01447,Left seat seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08367-MAS01448,Left seat seat cushion fan 2: activation-Specified value,not coded/not installed,
IDE08368-MAS01447,Right seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE08368-MAS01448,Right seat backrest fan 1: activation-Specified value,not coded/not installed,
IDE08369-MAS01447,Right seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08369-MAS01448,Right seat backrest fan 2: activation-Specified value,not coded/not installed,
IDE08370-MAS01447,Right seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE08370-MAS01448,Right seat cushion fan 1: activation-Specified value,not coded/not installed,
IDE08371-MAS01447,Right seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08371-MAS01448,Right seat cushion fan 2: activation-Specified value,not coded/not installed,
IDE08376-MAS01580,Right daytime running lamp and parking lamp bulb-Activation,not coded/not installed,
IDE08376-MAS01737,Right daytime running lamp and parking lamp bulb-Diagnosis,not coded/not installed,
IDE08376-MAS12621,Right daytime running lamp and parking lamp bulb-Current draw (effective value),not coded/not installed,
IDE08377-MAS01580,Left daytime running lamp and parking lamp bulb-Activation,not coded/not installed,
IDE08377-MAS01737,Left daytime running lamp and parking lamp bulb-Diagnosis,not coded/not installed,
IDE08377-MAS12621,Left daytime running lamp and parking lamp bulb-Current draw (effective value),not coded/not installed,
IDE08378-MAS01580,Right front turn signal bulb-Activation,not coded/not installed,
IDE08378-MAS01737,Right front turn signal bulb-Diagnosis,not coded/not installed,
IDE08378-MAS12621,Right front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08379-MAS01580,Left front turn signal bulb-Activation,not coded/not installed,
IDE08379-MAS01737,Left front turn signal bulb-Diagnosis,not coded/not installed,
IDE08379-MAS12621,Left front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08380-MAS01580,Right side marker lamp bulb-Activation,not coded/not installed,
IDE08380-MAS01737,Right side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08380-MAS12621,Right side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08381-MAS01580,Left side marker lamp bulb-Activation,not coded/not installed,
IDE08381-MAS01737,Left side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08381-MAS12621,Left side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08382-MAS01580,Right front side marker lamp bulb-Activation,not coded/not installed,
IDE08382-MAS01737,Right front side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08382-MAS12621,Right front side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08383-MAS01580,Left front side marker lamp bulb-Activation,not coded/not installed,
IDE08383-MAS01737,Left front side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08383-MAS12621,Left front side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08384-MAS01580,Right daytime running lamp bulb-Activation,not coded/not installed,
IDE08384-MAS01737,Right daytime running lamp bulb-Diagnosis,not coded/not installed,
IDE08384-MAS12621,Right daytime running lamp bulb-Current draw (effective value),not coded/not installed,
IDE08385-MAS01580,Left daytime running lamp bulb-Activation,not coded/not installed,
IDE08385-MAS01737,Left daytime running lamp bulb-Diagnosis,not coded/not installed,
IDE08385-MAS12621,Left daytime running lamp bulb-Current draw (effective value),not coded/not installed,
IDE08386-MAS01580,Right low beam headlamp bulb-Activation,0.00, %
IDE08386-MAS01737,Right low beam headlamp bulb-Diagnosis,no error,
IDE08386-MAS12621,Right low beam headlamp bulb-Current draw (effective value),0, mA
IDE08387-MAS01580,Left low beam headlamp bulb-Activation,0.00, %
IDE08387-MAS01737,Left low beam headlamp bulb-Diagnosis,no error,
IDE08387-MAS12621,Left low beam headlamp bulb-Current draw (effective value),0, mA
IDE08388-MAS01580,Right high beam headlamp bulb-Activation,not coded/not installed,
IDE08388-MAS01737,Right high beam headlamp bulb-Diagnosis,not coded/not installed,
IDE08388-MAS12621,Right high beam headlamp bulb-Current draw (effective value),not coded/not installed,
IDE08389-MAS01580,Left high beam headlamp bulb-Activation,not coded/not installed,
IDE08389-MAS01737,Left high beam headlamp bulb-Diagnosis,not coded/not installed,
IDE08389-MAS12621,Left high beam headlamp bulb-Current draw (effective value),not coded/not installed,
IDE08390-MAS01580,Right fog light bulb-Activation,0.00, %
IDE08390-MAS01737,Right fog light bulb-Diagnosis,no error,
IDE08390-MAS12621,Right fog light bulb-Current draw (effective value),0, mA
IDE08391-MAS01580,Left fog light bulb-Activation,0.00, %
IDE08391-MAS01737,Left fog light bulb-Diagnosis,no error,
IDE08391-MAS12621,Left fog light bulb-Current draw (effective value),0, mA
IDE08392-MAS01580,Right LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08392-MAS01737,Right LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08392-MAS12621,Right LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08393-MAS01580,Left LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08393-MAS01737,Left LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08393-MAS12621,Left LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08394-MAS01580,Right LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08394-MAS01737,Right LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08394-MAS12621,Right LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08395-MAS01580,Left LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08395-MAS01737,Left LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08395-MAS12621,Left LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08396-MAS01580,Headlights right: supply-Activation,not coded/not installed,
IDE08396-MAS01737,Headlights right: supply-Diagnosis,not coded/not installed,
IDE08396-MAS12621,Headlights right: supply-Current draw (effective value),not coded/not installed,
IDE08397-MAS01580,Headlights left: supply-Activation,not coded/not installed,
IDE08397-MAS01737,Headlights left: supply-Diagnosis,not coded/not installed,
IDE08397-MAS12621,Headlights left: supply-Current draw (effective value),not coded/not installed,
IDE08402-IDE05742,Light switch-Light switch position,AUTO,
IDE08402-IDE07956,Light switch-redundant signal line,Medium,
IDE08402-MAS03866,Light switch-Head-up display button,Not operated,
IDE08402-MAS03868,Light switch-Position of eye box,0,
IDE08402-MAS06887,Light switch-Light switch position on CAN,AUTO,
IDE08402-MAS06888,Light switch-Fog light button,Not operated,
IDE08402-MAS06889,Light switch-Rear fog light button,Not operated,
IDE08402-MAS06890,Light switch-Night vision system button,Not operated,
IDE08402-MAS06891,Light switch-Control for Eyebox position,no operation,
IDE08404-IDE01351,Local data bus 1: information-Terminal 75 status,On,
IDE08404-MAS00370,Local data bus 1: information-Vehicle speed,0.00, km/h
IDE08404-MAS03679,Local data bus 1: information-Terminal 15 status,On,
IDE08404-MAS06495,Local data bus 1: information-Engine hood contact switch,closed,
IDE08405-MAS05030,Outside air temperature sensor-Resistance,0.72, kOhm
IDE08405-MAS08858,Outside air temperature sensor-Outside air temperature on CAN,32.50, °C
IDE08408-MAS12845,Hood contact-Switch 1,closed,
IDE08408-MAS12846,Hood contact-Switch 2,closed,
IDE08434-MAS01580,Right turn signal light bulb-Activation,not coded/not installed,
IDE08434-MAS01737,Right turn signal light bulb-Diagnosis,not coded/not installed,
IDE08434-MAS12621,Right turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08435-MAS01580,Left turn signal light bulb-Activation,not coded/not installed,
IDE08435-MAS01737,Left turn signal light bulb-Diagnosis,not coded/not installed,
IDE08435-MAS12621,Left turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08441-MAS06992,Control module for steering col electronics: requirements-Request wiping,Intermittent operation,
IDE08441-MAS06993,Control module for steering col electronics: requirements-Request signal horn,OFF,
IDE08441-MAS09575,Control module for steering col electronics: requirements-High beam request,OFF,
IDE08441-MAS09576,Control module for steering col electronics: requirements-Wash request,OFF,
IDE08441-MAS09577,Control module for steering col electronics: requirements-Rear interval wash request,OFF,
IDE08441-MAS09586,Control module for steering col electronics: requirements-Headlight flasher request,OFF,
IDE08441-MAS09587,Control module for steering col electronics: requirements-Headlight washer request,OFF,
IDE08441-MAS09600,Control module for steering col electronics: requirements-Request to flashing left,not active,
IDE08441-MAS09601,Control module for steering col electronics: requirements-Request to flashing right,not active,
IDE08442-MAS01580,Wiper storage and spray nozzle heater-Activation,OFF,
IDE08442-MAS07000,Wiper storage and spray nozzle heater-Switch-on current,0, mA
IDE08442-MAS12621,Wiper storage and spray nozzle heater-Current draw (effective value),0, mA
IDE08500-MAS07921,Left front seat ventilation setting-Balance setting,not coded/not installed,
IDE08500-MAS07928,Left front seat ventilation setting-Ventilation stage,not coded/not installed,
IDE08500-MAS07929,Left front seat ventilation setting-Power quota setting by energy management,not coded/not installed,
IDE08501-MAS07921,Right front seat ventilation setting-Balance setting,not coded/not installed,
IDE08501-MAS07928,Right front seat ventilation setting-Ventilation stage,not coded/not installed,
IDE08501-MAS07929,Right front seat ventilation setting-Power quota setting by energy management,not coded/not installed,
IDE08502-MAS01580,A/C compressor regulator valve-Activation,51, %
IDE08502-MAS09777,A/C compressor regulator valve-Specified current,476, mA
IDE08502-MAS09780,A/C compressor regulator valve-Supply Highside,On,
IDE08502-MAS12632,A/C compressor regulator valve-Current draw (mean value),479, mA
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,Measured value not available,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,Measured value not available,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,Measured value not available,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather lights,Measured value not available,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,Measured value not available,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,Measured value not available,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,Measured value not available,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,Measured value not available,
IDE08543-MAS00370,Garage door opener: last programming-Vehicle speed,below threshold,
IDE08543-MAS01240,Garage door opener: last programming-Programming status,0F,
IDE08543-MAS02246,Garage door opener: last programming-Timeout,Not reached,
IDE08543-MAS02949,Garage door opener: last programming-Frequency,04 9E 6F,
IDE08543-MAS03159,Garage door opener: last programming-Manufacturer,FF,
IDE08543-MAS04184,Garage door opener: last programming-Cancellation by user,Yes,
IDE08543-MAS06670,Garage door opener: last programming-Channel,Channel 1,
IDE08543-MAS09308,Garage door opener: last programming-Error status and modulation,01010000 ,
IDE08543-MAS10442,Garage door opener: last programming-Programming antenna,External antenna,
IDE08544-MAS00370,Garage door opener: second-to-last progr.-Vehicle speed,below threshold,
IDE08544-MAS01240,Garage door opener: second-to-last progr.-Programming status,00,
IDE08544-MAS02246,Garage door opener: second-to-last progr.-Timeout,Not reached,
IDE08544-MAS02949,Garage door opener: second-to-last progr.-Frequency,Programming not performed,
IDE08544-MAS03159,Garage door opener: second-to-last progr.-Manufacturer,00,
IDE08544-MAS04184,Garage door opener: second-to-last progr.-Cancellation by user,No,
IDE08544-MAS06670,Garage door opener: second-to-last progr.-Channel,Programming not performed,
IDE08544-MAS09308,Garage door opener: second-to-last progr.-Error status and modulation,01000000 ,
IDE08544-MAS10442,Garage door opener: second-to-last progr.-Programming antenna,External antenna,
IDE08545-MAS00370,Garage door opener: third-to-last progr.-Vehicle speed,below threshold,
IDE08545-MAS01240,Garage door opener: third-to-last progr.-Programming status,00,
IDE08545-MAS02246,Garage door opener: third-to-last progr.-Timeout,Not reached,
IDE08545-MAS02949,Garage door opener: third-to-last progr.-Frequency,Programming not performed,
IDE08545-MAS03159,Garage door opener: third-to-last progr.-Manufacturer,00,
IDE08545-MAS04184,Garage door opener: third-to-last progr.-Cancellation by user,No,
IDE08545-MAS06670,Garage door opener: third-to-last progr.-Channel,Programming not performed,
IDE08545-MAS09308,Garage door opener: third-to-last progr.-Error status and modulation,00000000 ,
IDE08545-MAS10442,Garage door opener: third-to-last progr.-Programming antenna,External antenna,
IDE08622,Garage door opener: supply voltage,14.22, V
IDE08795-MAS06614,Button for rear window shade-Version,not coded/not installed,
IDE08795-MAS07693,Button for rear window shade-Button Status,not coded/not installed,
IDE08795-MAS07694,Button for rear window shade-Button status on CAN,Initialization/not installed,
IDE08948-MAS01632,Electrically Adjustable Steering Column-Status,not coded/not installed,
IDE08948-MAS06732,Electrically Adjustable Steering Column-Status local activity,not coded/not installed,
IDE08948-MAS09493,Electrically Adjustable Steering Column-Position: vertical,not coded/not installed,
IDE08948-MAS09494,Electrically Adjustable Steering Column-Position: axial,not coded/not installed,
IDE08948-MAS09495,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation up,not coded/not installed,
IDE08948-MAS09496,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation down,not coded/not installed,
IDE08948-MAS09497,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation out,not coded/not installed,
IDE08948-MAS09498,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation in,not coded/not installed,
IDE08948-MAS09501,Electrically Adjustable Steering Column-Entry assistance button,not coded/not installed,
IDE08948-MAS12678,Electrically Adjustable Steering Column-Motor for vertical adjustment: current draw (effective value),not coded/not installed,
IDE08948-MAS12679,Electrically Adjustable Steering Column-Motor for axial adjustment: current draw (effective value),not coded/not installed,
IDE08953,Garage door opener: country code,North America,
IDE08957-MAS01632,Supply for power outlets-Status,On,
IDE08957-MAS04445,Supply for power outlets-Relay output voltage,14.21, V
IDE08957-MAS07309,Supply for power outlets-Maximum current draw,36.80, A
IDE08957-MAS08025,Supply for power outlets-Output to input voltage ratio with relay switched off,45.39, %
IDE08957-MAS12621,Supply for power outlets-Current draw (effective value),96, mA
IDE08960-MAS08026,Status: control heads for driving and comfort functions-Control head for driving and comfort functions,ready for operation,
IDE08960-MAS08027,Status: control heads for driving and comfort functions-Control head 2 for driving and comfort functions,not coded/not installed,
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Separate activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Separate activation of backrest and seat cushion,
IDE08962-IDE08356,Installation info: seat ventilation-Left seat backrest fan 1,not installed,
IDE08962-IDE08357,Installation info: seat ventilation-Left seat backrest fan 2,not installed,
IDE08962-IDE08358,Installation info: seat ventilation-Left seat cushion fan 1,not installed,
IDE08962-IDE08359,Installation info: seat ventilation-Left seat cushion fan 2,not installed,
IDE08962-IDE08360,Installation info: seat ventilation-Right seat backrest fan 1,not installed,
IDE08962-IDE08361,Installation info: seat ventilation-Right seat backrest fan 2,not installed,
IDE08962-IDE08362,Installation info: seat ventilation-Right seat cushion fan 1,not installed,
IDE08962-IDE08363,Installation info: seat ventilation-Right seat cushion fan 2,not installed,
IDE08978-MAS01580,Windshield washer pump-Activation,OFF,
IDE08978-MAS09022,Windshield washer pump-PWM value,0, %
IDE08978-MAS12621,Windshield washer pump-Current draw (effective value),0, mA
IDE08979-MAS06614,Valet parking lock button-Version,not coded/not installed,
IDE08979-MAS07693,Valet parking lock button-Button Status,not coded/not installed,
IDE08979-MAS07694,Valet parking lock button-Button status on CAN,Not operated,
IDE08979-MAS08062,Valet parking lock button-Indicator light activation,not coded/not installed,
IDE08980-MAS06614,Button for rear spoiler adjustment-Version,not coded/not installed,
IDE08980-MAS07693,Button for rear spoiler adjustment-Button Status,not coded/not installed,
IDE08980-MAS07694,Button for rear spoiler adjustment-Button status on CAN,Initialization/not installed,
IDE08980-MAS07699,Button for rear spoiler adjustment-Status indicator light on CAN,OFF,
IDE08980-MAS08062,Button for rear spoiler adjustment-Indicator light activation,not coded/not installed,
IDE08981-MAS06614,Front display open/close button-Version,Local data bus: operating unit 1,
IDE08981-MAS07693,Front display open/close button-Button Status,Not operated,
IDE08981-MAS07694,Front display open/close button-Button status on CAN,Not operated,
IDE08982-MAS06614,Button for start/stop operation/electrical driving-Version,Local data bus: operating unit 1,
IDE08982-MAS07693,Button for start/stop operation/electrical driving-Button Status,Not operated,
IDE08982-MAS07694,Button for start/stop operation/electrical driving-Button status on CAN,Not operated,
IDE08982-MAS08062,Button for start/stop operation/electrical driving-Indicator light activation,OFF,
IDE08983-MAS06614,Driving profile selection button 2-Version,Local data bus: operating unit 1,
IDE08983-MAS07693,Driving profile selection button 2-Button Status,Not operated,
IDE08983-MAS07694,Driving profile selection button 2-Button status on CAN,Not operated,
IDE08998-MAS06901,Driver info-Washer fluid level,OK,
IDE08998-MAS08063,Driver info-Coolant level from sensor for low coolant display,OK,
IDE08998-MAS08064,Driver info-Coolant level from sensor 2 for low coolant display,OK,
IDE08998-MAS08065,Driver info-Brake fluid level,OK,
IDE08998-MAS08122,Driver info-Brake lining,OK,
IDE08999-MAS08124,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: request,OFF,
IDE08999-MAS08125,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: status,OFF,
IDE08999-MAS08126,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: request,OFF,
IDE08999-MAS08127,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: status,OFF,
IDE08999-MAS08128,Control modules for light activation: turn sig ctrl-Left flashing function,not active,
IDE08999-MAS08129,Control modules for light activation: turn sig ctrl-Right flashing function,not active,
IDE08999-MAS08133,Control modules for light activation: turn sig ctrl-Flashing mode,normal,
IDE09000-MAS01580,Control module for light activation: left: supply-Activation,100, %
IDE09000-MAS01737,Control module for light activation: left: supply-Diagnosis,no error,
IDE09000-MAS12621,Control module for light activation: left: supply-Current draw (effective value),869, mA
IDE09001-MAS01580,Control module for light activation: right: supply-Activation,100, %
IDE09001-MAS01737,Control module for light activation: right: supply-Diagnosis,no error,
IDE09001-MAS12621,Control module for light activation: right: supply-Current draw (effective value),827, mA
IDE09234-MAS01580,Subfloor lighting-Activation,not coded/not installed,
IDE09234-MAS12621,Subfloor lighting-Current draw (effective value),not coded/not installed,
IDE09850-MAS07146,Garage Door Opener Operating Unit-Button 1,Not operated,
IDE09850-MAS07147,Garage Door Opener Operating Unit-Button 2,Not operated,
IDE09850-MAS07148,Garage Door Opener Operating Unit-Button 3,Not operated,
IDE09887-MAS01580,Right daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09887-MAS01737,Right daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09887-MAS12621,Right daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09888-MAS01580,Left daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09888-MAS01737,Left daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09888-MAS12621,Left daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09920-MAS06614,Special Purpose Vehicle Control Module-Version,not coded/not installed,
IDE09920-MAS06992,Special Purpose Vehicle Control Module-Request wiping,not coded/not installed,
IDE09920-MAS06993,Special Purpose Vehicle Control Module-Request signal horn,not coded/not installed,
IDE09920-MAS09569,Special Purpose Vehicle Control Module-Remote control status,not coded/not installed,
IDE09920-MAS09570,Special Purpose Vehicle Control Module-Parking light request,not coded/not installed,
IDE09920-MAS09571,Special Purpose Vehicle Control Module-Low beam request,not coded/not installed,
IDE09920-MAS09572,Special Purpose Vehicle Control Module-Intermittent high beam request,not coded/not installed,
IDE09920-MAS09573,Special Purpose Vehicle Control Module-Footwell illumination request,not coded/not installed,
IDE09920-MAS09574,Special Purpose Vehicle Control Module-Interior illumination request,not coded/not installed,
IDE09920-MAS09575,Special Purpose Vehicle Control Module-High beam request,not coded/not installed,
IDE09920-MAS09576,Special Purpose Vehicle Control Module-Wash request,not coded/not installed,
IDE09920-MAS09577,Special Purpose Vehicle Control Module-Rear interval wash request,not coded/not installed,
IDE09920-MAS09586,Special Purpose Vehicle Control Module-Headlight flasher request,not coded/not installed,
IDE09920-MAS09588,Special Purpose Vehicle Control Module-Emerg. sig. flasher request,not coded/not installed,
IDE09920-MAS09589,Special Purpose Vehicle Control Module-Daytime running light deactivation req.,not coded/not installed,
IDE09920-MAS09590,Special Purpose Vehicle Control Module-Suppression of interior illumination request,not coded/not installed,
IDE09921-MAS01632,Automatic high beam assist control module-Status,not coded/not installed,
IDE09921-MAS02832,Automatic high beam assist control module-Malfunction status,not coded/not installed,
IDE09921-MAS09580,Automatic high beam assist control module-Sensor status,not coded/not installed,
IDE09921-MAS09581,Automatic high beam assist control module-PWM specs.,not coded/not installed,
IDE09921-MAS09582,Automatic high beam assist control module-Status on combi,not coded/not installed,
IDE09921-MAS09583,Automatic high beam assist control module-error status on combi,not coded/not installed,
IDE09921-MAS09584,Automatic high beam assist control module-Sensor status on combi,not coded/not installed,
IDE09921-MAS09585,Automatic high beam assist control module-Turn up headlights request,not coded/not installed,
IDE09922-MAS01448,Static headlight range adjustment-Specified value,not coded/not installed,
IDE09922-MAS09527,Static headlight range adjustment-Activation voltage: act. value,not coded/not installed,
IDE09922-MAS10074,Static headlight range adjustment-Supply voltage: actual value,not coded/not installed,
IDE09922-MAS10075,Static headlight range adjustment-Activation voltage/supply voltage ratio,not coded/not installed,
IDE09922-MAS12621,Static headlight range adjustment-Current draw (effective value),not coded/not installed,
IDE09933,Multifunction steerg. wheel: request signal horn,OFF,
IDE09934-MAS09591,Shift lever / selector lever position-Signal transm. ctrl. mod.,Selector lever in position P,
IDE09934-MAS09592,Shift lever / selector lever position-Signal engine ctrl. mod.,Unknown (9),
IDE09936-MAS01580,Right daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09936-MAS01737,Right daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09936-MAS12621,Right daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09937-MAS01580,Left daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09937-MAS01737,Left daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09937-MAS12621,Left daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09938-MAS01580,Right front turn signal bulb 2-Activation,not coded/not installed,
IDE09938-MAS01737,Right front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09938-MAS12621,Right front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09939-MAS01580,Left front turn signal bulb 2-Activation,not coded/not installed,
IDE09939-MAS01737,Left front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09939-MAS12621,Left front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09940-MAS01580,Right side marker bulb 2-Activation,not coded/not installed,
IDE09940-MAS01737,Right side marker bulb 2-Diagnosis,not coded/not installed,
IDE09940-MAS12621,Right side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09941-MAS01580,Left side marker bulb 2-Activation,not coded/not installed,
IDE09941-MAS01737,Left side marker bulb 2-Diagnosis,not coded/not installed,
IDE09941-MAS12621,Left side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09955-MAS07693,Dimming interior rearview mirror-Button Status,Not operated,
IDE09955-MAS09651,Dimming interior rearview mirror-Error status sensor front,not faulty,
IDE09955-MAS09652,Dimming interior rearview mirror-Error status sensor rear,not faulty,
IDE09955-MAS10386,Dimming interior rearview mirror-Dim. value spec.: exterior mirror,0.00, V
IDE09958-MAS01580,Right low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09958-MAS01737,Right low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09958-MAS12621,Right low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE09959-MAS01580,Left low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09959-MAS01737,Left low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09959-MAS12621,Left low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE10085-MAS09757,Switch and display illumination-Terminal 58xs on CAN,0, %
IDE10085-MAS09815,Switch and display illumination-Terminal 58xd on CAN,246,
IDE10085-MAS09816,Switch and display illumination-Phototransistor wert,246,
IDE10085-MAS09817,Switch and display illumination-Terminal 58xs,0.00, %
IDE10085-MAS09819,Switch and display illumination-T. 58xs: Diagnosis,no error,
IDE10085-MAS09820,Switch and display illumination-Terminal 58xt,10.00, %
IDE10085-MAS09822,Switch and display illumination-T. 58xt: Diagnosis,no error,
IDE10085-MAS09823,Switch and display illumination-Driver's request (light switch),1, %
IDE10085-MAS09824,Switch and display illumination-Driver's request (Kombi),0, %
IDE10085-MAS09825,Switch and display illumination-Driver's request (MMI),0, %
IDE10085-MAS09826,Switch and display illumination-Driver's request on CAN,1, %
IDE10085-MAS09827,Switch and display illumination-Terminal 58xt on CAN,10, %
IDE10085-MAS12628,Switch and display illumination-Terminal 58xs: current draw (effective value),0, mA
IDE10085-MAS12629,Switch and display illumination-Terminal 58xt: current draw (effective value),33, mA
IDE10219-MAS01580,High/low tone horn-Activation,OFF,
IDE10219-MAS12621,High/low tone horn-Current draw (effective value),0, mA
IDE10260-MAS01448,Static headlight range adjustment: spec./counter-Specified value,not coded/not installed,
IDE10260-MAS10076,Static headlight range adjustment: spec./counter-Step index,not coded/not installed,
IDE10260-MAS11358,Static headlight range adjustment: spec./counter-Number of adjustments left motor,0,
IDE10260-MAS11359,Static headlight range adjustment: spec./counter-Number of adjustments right motor,0,
IDE10327-MAS01632,Cupholder with heating and cooling element-Status,not coded/not installed,
IDE10327-MAS01968,Cupholder with heating and cooling element-Fan,not coded/not installed,
IDE10327-MAS02819,Cupholder with heating and cooling element-CURRENT temperature,not coded/not installed,
IDE10327-MAS02832,Cupholder with heating and cooling element-Malfunction status,not coded/not installed,
IDE10327-MAS10303,Cupholder with heating and cooling element-Heating function indicator lamp,not coded/not installed,
IDE10327-MAS10304,Cupholder with heating and cooling element-Cooling function indicator lamp,not coded/not installed,
IDE10327-MAS10305,Cupholder with heating and cooling element-Light for residual heat display,not coded/not installed,
IDE10327-MAS10333,Cupholder with heating and cooling element-Heat function button,not coded/not installed,
IDE10327-MAS10334,Cupholder with heating and cooling element-Cooling function button,not coded/not installed,
IDE10327-MAS10336,Cupholder with heating and cooling element-Peltier element,not coded/not installed,
IDE10327-MAS10337,Cupholder with heating and cooling element-Peltier element: PWM value,not coded/not installed,
IDE10338,Ctrl. motor for left headlight range adjust.: act. value,Measured value not available,
IDE10339,Ctrl. motor for right headlight range adjust.: act. value,Measured value not available,
IDE10340-IDE00104,Roof electronics control module-DTC,0,
IDE10340-MAS01634,Roof electronics control module-Supply voltage,13.90, V
IDE10340-MAS02832,Roof electronics control module-Malfunction status,not faulty,
IDE10340-MAS05946,Roof electronics control module-Actual temp.,50, °C
IDE10340-MAS09113,Roof electronics control module-Maximum temperature,110, °C
IDE10343-MAS01795,Roof electronics control module: dim. value-Front interior light,0, %
IDE10343-MAS10432,Roof electronics control module: dim. value-Uplight: front,255, %
IDE10343-MAS10433,Roof electronics control module: dim. value-Search rings,255, %
IDE10343-MAS10434,Roof electronics control module: dim. value-indicator lights,54, %
IDE10344-MAS10485,Roof electr.ctrl module: read. light/ceiling contour lights-Left front reading lamp: dim. value,0, %
IDE10344-MAS10486,Roof electr.ctrl module: read. light/ceiling contour lights-Left front reading lamp: diagnosis,Unknown (1),
IDE10344-MAS10487,Roof electr.ctrl module: read. light/ceiling contour lights-Right front reading lamp: dim. value,0, %
IDE10344-MAS10488,Roof electr.ctrl module: read. light/ceiling contour lights-Right front reading lamp: diagnosis,Unknown (1),
IDE10344-MAS10489,Roof electr.ctrl module: read. light/ceiling contour lights-Left rear reading lamp: dim. value,0, %
IDE10344-MAS10490,Roof electr.ctrl module: read. light/ceiling contour lights-Left rear reading lamp: diagnosis,Unknown (0),
IDE10344-MAS10491,Roof electr.ctrl module: read. light/ceiling contour lights-Right rear reading lamp: dim. value,0, %
IDE10344-MAS10492,Roof electr.ctrl module: read. light/ceiling contour lights-Right rear reading lamp: diagnosis,Unknown (0),
IDE10344-MAS10493,Roof electr.ctrl module: read. light/ceiling contour lights-Left read. lamp: 3rd seat row: dim. value,0, %
IDE10344-MAS10494,Roof electr.ctrl module: read. light/ceiling contour lights-Left read. lamp: 3rd seat row: diagnosis,Unknown (0),
IDE10344-MAS10495,Roof electr.ctrl module: read. light/ceiling contour lights-Right read. lamp: 3rd seat row: dim. value,0, %
IDE10344-MAS10496,Roof electr.ctrl module: read. light/ceiling contour lights-Right read. lamp: 3rd seat row: diagnosis,Unknown (0),
IDE10344-MAS10497,Roof electr.ctrl module: read. light/ceiling contour lights-Ceiling contour lights: dim. value,255, %
IDE10344-MAS10498,Roof electr.ctrl module: read. light/ceiling contour lights-Ceiling contour lights: diagnosis,Short circuit to ground,
IDE10345-MAS10416,Roof electronics control module: button-Front interior light button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10418,Roof electronics control module: button-Front button for rear reading light,Not operated,
IDE10345-MAS10419,Roof electronics control module: button-Front reading lamp button: left,Not operated,
IDE10345-MAS10420,Roof electronics control module: button-Front reading lamp button: right,Not operated,
IDE10345-MAS10421,Roof electronics control module: button-Left rear reading lamp switch,Not operated,
IDE10345-MAS10422,Roof electronics control module: button-Right rear reading lamp button,Not operated,
IDE10345-MAS10423,Roof electronics control module: button-Left reading light button: 3rd seat row,Not operated,
IDE10345-MAS10424,Roof electronics control module: button-Right reading light button: 3rd seat row,Not operated,
IDE10345-MAS10425,Roof electronics control module: button-Emergency call button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE10346-MAS10427,Roof electronics control module: indicator lights-Indicator lamp for interior light: front,OFF,
IDE10346-MAS10428,Roof electronics control module: indicator lights-Indicator light for door contact switching,OFF,
IDE10346-MAS10429,Roof electronics control module: indicator lights-Indicator lamp for front reading light,OFF,
IDE10346-MAS10430,Roof electronics control module: indicator lights-Indicator light for emerg. call,On,
IDE10346-MAS10431,Roof electronics control module: indicator lights-Indicator light for roadside assist.,OFF,
IDE10360-MAS01442,A/C compressor speed sensor-Compressor speed,not coded/not installed,
IDE10360-MAS10225,A/C compressor speed sensor-Signal level,not coded/not installed,
IDE10360-MAS10455,A/C compressor speed sensor-Deviation of compressor speed from specified RPM,not coded/not installed,
IDE10361-MAS06905,Driver information sensor-Washer fluid level sensor,3.97, kOhm
IDE10361-MAS06906,Driver information sensor-Sensor for inadequate coolant level display,1.21, kOhm
IDE10361-MAS07003,Driver information sensor-Sensor 2 for inadequate coolant level display,not coded/not installed,
IDE10482-MAS01632,Release for external systems-Status,not coded/not installed,
IDE10482-MAS07929,Release for external systems-Power quota setting by energy management,not coded/not installed,
IDE10482-MAS10746,Release for external systems-Installation info.: external system,no system,
IDE10808-MAS06614,Directional stabilization assistance button-Version,not coded/not installed,
IDE10808-MAS07693,Directional stabilization assistance button-Button Status,not coded/not installed,
IDE10808-MAS07694,Directional stabilization assistance button-Button status on CAN,Initialization/not installed,
IDE10808-MAS08062,Directional stabilization assistance button-Indicator light activation,OFF,
IDE10810-MAS06614,Button for side view camera-Version,not coded/not installed,
IDE10810-MAS07693,Button for side view camera-Button Status,not coded/not installed,
IDE10810-MAS07694,Button for side view camera-Button status on CAN,Initialization/not installed,
IDE11273-MAS10360,Control unit 2 for driv.and convenience funct.: special funct.-Lift button for vehicle leveling,not coded/not installed,
IDE11273-MAS10361,Control unit 2 for driv.and convenience funct.: special funct.-Lower button for vehicle leveling,not coded/not installed,
IDE11273-MAS12379,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: actual mode,not coded/not installed,
IDE11273-MAS12380,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: mode setting,not coded/not installed,
IDE11273-MAS12499,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for load level,not coded/not installed,
IDE11273-MAS12500,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for low level,not coded/not installed,
IDE11273-MAS12501,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for high level,not coded/not installed,
IDE11273-MAS12502,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for special off-road level,not coded/not installed,
IDE11274-MAS08932,Operating controls for sunroof/tilt roof and roof blind-Sunroof shade button,not coded/not installed,
IDE11274-MAS12383,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof,not coded/not installed,
IDE11274-MAS12515,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof: rear,not coded/not installed,
IDE11274-MAS12516,Operating controls for sunroof/tilt roof and roof blind-Button sunroof shade button: rear,not coded/not installed,
IDE11301-MAS12561,Number of events: headlight theft monitoring-Theft: left headlight suspected due to cold monitoring,0,
IDE11301-MAS12562,Number of events: headlight theft monitoring-Theft: right headlight suspected due to cold monitoring,0,
IDE11301-MAS12563,Number of events: headlight theft monitoring-Theft: left headlight confirmed due to heat monitoring,0,
IDE11301-MAS12564,Number of events: headlight theft monitoring-Theft: right headlight confirmed due to heat monitoring,0,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,95, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,370, W/m²
IDE12318-MAS01580,Left signature light bulb: supply-Activation,not coded/not installed,
IDE12318-MAS01737,Left signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12318-MAS12621,Left signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12319-MAS01580,Right signature light bulb: supply-Activation,not coded/not installed,
IDE12319-MAS01737,Right signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12319-MAS12621,Right signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12342-MAS06614,Button engine sound generation-Version,not coded/not installed,
IDE12342-MAS07693,Button engine sound generation-Button Status,not coded/not installed,
IDE12342-MAS07694,Button engine sound generation-Button status on CAN,Initialization/not installed,
IDE12342-MAS07699,Button engine sound generation-Status indicator light on CAN,ERROR,
IDE12342-MAS08062,Button engine sound generation-Indicator light activation,not coded/not installed,
IDE12826-MAS07693,Engine noise selection button-Button Status,not coded/not installed,
IDE12826-MAS07694,Engine noise selection button-Button status on CAN,Not operated,
IDE12882-MAS06614,Rear window shade button 2-Version,not coded/not installed,
IDE12882-MAS07693,Rear window shade button 2-Button Status,not coded/not installed,
IDE12882-MAS07694,Rear window shade button 2-Button status on CAN,Initialization/not installed,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06997,Head area heater-Outside temperature: filtered,Temp. sensor not installed,
IDE80251-MAS09637,Head area heater-Head area heater left: release,not coded/not installed,
IDE80251-MAS09638,Head area heater-Head area heater right: release,not coded/not installed,
IDE80251-MAS09639,Head area heater-Head area heater left: output DTM,not coded/not installed,
IDE80251-MAS09640,Head area heater-Head area heater right: output DTM,not coded/not installed,
IDE80251-MAS09641,Head area heater-Interior temperature,Temp. sensor not installed,
IDE80251-MAS09642,Head area heater-Adaptation vent temperature,not coded/not installed,
IDE80251-MAS09643,Head area heater-Adaptation fan speed,not coded/not installed,
IDE80251-MAS09646,Head area heater-Occupation status not available,not coded/not installed,
IDE80251-MAS09778,Head area heater-Convert. top open and locked,not coded/not installed,
IDE80251-MAS09779,Head area heater-Convert. top closed and locked,not coded/not installed,
ENG02609,average_Voltage_terminals,14.10, V
ENG26644-ENG30703,Data_Definitions-Data_Definition_BAP_Climate_Master,,
ENG26644-ENG30704,Data_Definitions-Data_Definition_BAP_Climate_Zone_1_2,,
ENG26644-ENG30705,Data_Definitions-Data_Definition_BAP_Climate_Zone_3_4,,
ENG26644-ENG30706,Data_Definitions-Data_Definition_BAP_Clock,,
ENG26644-ENG30707,Data_Definitions-Data_Definition_BAP_ExteriorLight,,
ENG26644-ENG30708,Data_Definitions-Data_Definition_BAP_InteriorLight,,
ENG26644-ENG30709,Data_Definitions-Data_Definition_BAP_Parkheater,,
ENG26644-ENG30710,Data_Definitions-Data_Definition_BAP_PDC,,
ENG26644-ENG30711,Data_Definitions-Data_Definition_BAP_SeatPneumatic,,
ENG26644-ENG30712,Data_Definitions-Data_Definition_BAP_TrailorAssist,,
ENG26644-ENG30713,Data_Definitions-Data_Definition_BAP_Wiper,,
ENG26644-ENG30714,Data_Definitions-Data_Definition_CAN_Frontlight,ýý"
&òÿþÿþpaÈ2¹2½NŽBù,
ENG26644-ENG30715,Data_Definitions-Data_Definition_CAN_Komfort,D"ýý"
&òÿþÿþpaÈ2¹2½NŽBù,
ENG26644-ENG30716,Data_Definitions-Data_Definition_LIN_1,"
&òÿþÿþpaÈ2¹2½NŽBù,
ENG26644-ENG30717,Data_Definitions-Data_Definition_LIN_10,,
ENG26644-ENG30718,Data_Definitions-Data_Definition_LIN_11,,
ENG26644-ENG30719,Data_Definitions-Data_Definition_LIN_12,,
ENG26644-ENG30720,Data_Definitions-Data_Definition_LIN_2,þpaÈ2¹2½NŽBù,
ENG26644-ENG30721,Data_Definitions-Data_Definition_LIN_3,aÈ2¹2½NŽBù,
ENG26644-ENG30722,Data_Definitions-Data_Definition_LIN_4,¹2½NŽBù,
ENG26644-ENG30723,Data_Definitions-Data_Definition_LIN_5,,
ENG26644-ENG30724,Data_Definitions-Data_Definition_LIN_6,,
ENG26644-ENG30725,Data_Definitions-Data_Definition_LIN_7,,
ENG26644-ENG30726,Data_Definitions-Data_Definition_LIN_8,,
ENG26644-ENG30727,Data_Definitions-Data_Definition_LIN_9,,
ENG02611-ENG02852,EVLS-block_counter_axial_in,not coded/not installed,
ENG02611-ENG02851,EVLS-block_counter_axial_out,not coded/not installed,
ENG02611-ENG02850,EVLS-block_counter_vertically_down,not coded/not installed,
ENG02611-ENG02849,EVLS-block_counter_vertically_up,not coded/not installed,
ENG02611-ENG02847,EVLS-drivers_door_open,not coded/not installed,
ENG02611-ENG02856,EVLS-Electrically_adjustable_steering_column_BCM1_down,not coded/not installed,
ENG02611-ENG02858,EVLS-Electrically_adjustable_steering_column_BCM1_in,not coded/not installed,
ENG02611-ENG02857,EVLS-Electrically_adjustable_steering_column_BCM1_out,not coded/not installed,
ENG02611-ENG02855,EVLS-Electrically_adjustable_steering_column_BCM1_up,not coded/not installed,
ENG02611-ENG02845,EVLS-Electrically_adjustable_steering_column_error,not coded/not installed,
ENG02611-ENG02853,EVLS-Electrically_adjustable_steering_column_response_error,not coded/not installed,
ENG02611-ENG02848,EVLS-Electrically_adjustable_steering_column_state,not coded/not installed,
ENG02611-ENG02844,EVLS-Electrically_adjustable_steering_column_state_HV,not coded/not installed,
ENG02611-ENG02843,EVLS-Electrically_adjustable_steering_column_state_LV,not coded/not installed,
ENG02611-ENG02842,EVLS-FS_MMB_global_stop_mode,not coded/not installed,
ENG02611-ENG02838,EVLS-FS_MMB_storage_mode,not coded/not installed,
ENG02611-ENG02841,EVLS-FS_MMB_store_mode,not coded/not installed,
ENG02611-ENG02840,EVLS-FS_MMB_tap_mode,not coded/not installed,
ENG02611-ENG02839,EVLS-FS_MMB_tip_mode,not coded/not installed,
ENG02611-ENG02846,EVLS-LSV_EE_switch,not coded/not installed,
ENG02611-ENG02854,EVLS-motor_start_stopp_restart,not coded/not installed,
ENG101323,Headlight leveling control state,Measured value not available,
ENG02610,interior_temperature,27.50, °C
ENG107366,Left headlight leveling motor position,Measured value not available,
ENG116804-ENG121679,Light sensor parameter-BRGC6,0,
ENG116804-ENG121663,Light sensor parameter-darkstart_mode,not active,
ENG116804-ENG121664,Light sensor parameter-night_mode,not active,
ENG116804-ENG121667,Light sensor parameter-night_sensitivity,not active,
ENG116804-ENG121666,Light sensor parameter-rain_mode,not active,
ENG116804-ENG121671,Light sensor parameter-rb_Amb_Night_Threshold_g,135,
ENG116804-ENG03606,Light sensor parameter-rb_E2_Sensor_Error_1_g,0,
ENG116804-ENG03607,Light sensor parameter-rb_E2_Sensor_Error_2_g,0,
ENG116804-ENG03608,Light sensor parameter-rb_E2_Sensor_Error_3_g,0,
ENG116804-ENG03609,Light sensor parameter-rb_E2_Sensor_Error_4_g,0,
ENG116804-ENG121672,Light sensor parameter-rb_FW_Night_Threshold_g,135,
ENG116804-ENG121670,Light sensor parameter-rb_IR_Day_Threshold_g,45,
ENG116804-ENG121673,Light sensor parameter-rb_IR_Night_Threshold_g,68,
ENG116804-ENG121676,Light sensor parameter-rb_LIN_BIT_ERROR_COUNTER_g,0,
ENG116804-ENG121678,Light sensor parameter-rb_LIN_BIT_NORESPONSE_COUNTER_g,0,
ENG116804-ENG03603,Light sensor parameter-rb_LIN_CHECKSUM_ERROR_COUNTER_g,0,
ENG116804-ENG03605,Light sensor parameter-rb_LIN_FRAME_ERROR_COUNTER_g,0,
ENG116804-ENG03604,Light sensor parameter-rb_LIN_OVER_T_FRAME_MAX_COUNTER_g,0,
ENG116804-ENG03602,Light sensor parameter-rb_LIN_OVER_T_HEADER_MAX_COUNTER_g,0,
ENG116804-ENG121668,Light sensor parameter-rw_Amb_Day_Threshold_g,93,
ENG116804-ENG121662,Light sensor parameter-rw_Amb_light16bit_g,4046, bit
ENG116804-ENG121674,Light sensor parameter-rw_dayCounter_mg,0,
ENG116804-ENG121669,Light sensor parameter-rw_FW_Day_Threshold_g,90,
ENG116804-ENG121660,Light sensor parameter-rw_FW_light16bit_g,714, bit
ENG116804-ENG121661,Light sensor parameter-rw_IR_light16bit_g,974, bit
ENG116804-ENG121675,Light sensor parameter-rw_nightCounter_mg,0,
ENG116804-ENG121665,Light sensor parameter-tunnel_mode,not active,
ENG02672-ENG121648,Rain_sensor_parameters-rb_CloseTypeStandby_g,0,
ENG02672-ENG121657,Rain_sensor_parameters-rb_Errorflags_g,0,
ENG02672-ENG121651,Rain_sensor_parameters-rb_HumTemp_ErrorCode_g,0,
ENG02672-ENG121653,Rain_sensor_parameters-rb_NoCommunicationCounter,0,
ENG02672-ENG121641,Rain_sensor_parameters-rb_PotiStageFromBox_g,5,
ENG02672-ENG121642,Rain_sensor_parameters-rb_PWM_Voltage_g,128,
ENG02672-ENG121652,Rain_sensor_parameters-rb_StaticNoCommunicationCounter,0,
ENG02672-ENG121654,Rain_sensor_parameters-rb_SupplyVoltage_mg,179,
ENG02672-ENG03611,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Max_g,141,
ENG02672-ENG03610,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Min_g,139,
ENG02672-ENG121640,Rain_sensor_parameters-rub_Empf_Faktor,20,
ENG02672-ENG121639,Rain_sensor_parameters-rub_Int_Speicher,0,
ENG02672-ENG121645,Rain_sensor_parameters-rub_LengthCounter,166,
ENG02672-ENG121643,Rain_sensor_parameters-rub_Nachwisch_Count,0,
ENG02672-ENG121638,Rain_sensor_parameters-rub_Ovr_Speicher,0,
ENG02672-ENG121646,Rain_sensor_parameters-rub_PulseCounter,4,
ENG02672-ENG121647,Rain_sensor_parameters-rub_SignalIntegral_g,0,
ENG02672-ENG121644,Rain_sensor_parameters-ruw_StX_Speicher,0,
ENG02672-ENG121650,Rain_sensor_parameters-rw_HumiTicks_g,8312,
ENG02672-ENG121649,Rain_sensor_parameters-rw_TempTicks_g,978,
ENG108469,Right headlight leveling motor position,Measured value not available,
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,0,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,3,
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,0,
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Slope,5,
ENG03700-ENG109174,sw_version_integration_afs-SW_VERSION,I266,
Elapsed Time: 01:29
adpmap-09-8W0-907-063-CE
;SW:8W0-907-063-CE   HW:8W0-907-063-BE ---  Cent. Elect.
;Component:BCM1 MLBevo   H13 0267, Coding:C2500362C0081CCD051587149CAE98B9100B3D08000000000000000000001A0001610002001204
;EV_BCM1BOSCHAU736,018006,EV_BCM1BOSCHAU736_018_AU49.rod
;Friday,12,July,2019,16:09:03:64285
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: 804383401BF89E4F19-80D4
IDE00001-MAS10842-Production mode-Deactivate exterior lighting,not active ,3
IDE00001-MAS10843-Production mode-Deactivate interior lighting,not active ,3
IDE00001-MAS10844-Production mode-Deactivate rear windshield wiper,not active ,3
IDE00001-MAS10847-Production mode-Deactivate windshield wipers,not active ,3
IDE00001-MAS10848-Production mode-Deactivate left-/right hand driving switch-over,not active ,3
IDE00001-MAS10849-Production mode-Switch parking assist to mute,not active ,3
IDE00001-MAS10850-Production mode-Deactivate massage function,not active ,3
IDE00001-MAS10871-Production mode-Deactivate AC compressor,not active ,3
IDE00001-MAS13264-Production mode-Activate headlamp cleaning system directly,not active ,3
IDE01550-Service position,168.49 ,2
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,installed ,1
IDE01996-SFT00041-Installation list: specified installations-Light Control Left,installed ,1
IDE01996-SFT00057-Installation list: specified installations-Light Control Right,installed ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,not installed ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,not installed ,1
IDE03641-Presentation run dynamic AFS light,not active ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE05274-Acoustic warning for rear lid assistant,active ,1
IDE07356-Position during interval mode,38.49 ,2
IDE10296-upper turn position,168.49 ,2
IDE10297-lower turn position,38.49 ,2
IDE10298-Alternating park position 1,30.00 ,2
IDE10299-Alternating park position 2,32.00 ,2
IDE10307-Presentation mode of multicolor ambient and contour lighting,not active ,1
IDE10321-MAS01364-Seat heater: micro adjust.-Stage 1,0 °C,3
IDE10321-MAS01365-Seat heater: micro adjust.-Stage 2,0 °C,3
IDE10321-MAS01366-Seat heater: micro adjust.-Stage 3,0 °C,3
IDE10322-MAS01364-Seat ventilation: micro adjust.-Stage 1,0 %,3
IDE10322-MAS01365-Seat ventilation: micro adjust.-Stage 2,0 %,3
IDE10322-MAS01366-Seat ventilation: micro adjust.-Stage 3,0 %,3
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,not active ,1
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,not active ,1
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,not active ,1
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,not active ,1
IDE10729-Runtime measurement,on task level ,1
IDE11055-Headlight cleaning system: activation time in production mode,2.56e+006 ms,2
IDE11954-Automatic activation of parking distance control,active ,1
IDE12224-MAS14154-Rear parking aid warning buzzer with open convertible top-Volume at Level 1,4 ,2
IDE12224-MAS14155-Rear parking aid warning buzzer with open convertible top-Increment between the volume levels,4 ,2
IDE12225-MAS14154-Front parking aid warning buzzer with open convertible top-Volume at Level 1,4 ,2
IDE12225-MAS14155-Front parking aid warning buzzer with open convertible top-Increment between the volume levels,4 ,2
MAS12843-Maneuvering brake function,activated ,1
ENG133836-Fehlermaske 2,00 00 00 00 ,4
ENG117283-Frontwaschfunktion,10 ,2
ENG133832-sLWR_counter_left,0 ,4
ENG133833-sLWR_counter_right,0 ,4
Elapsed Time: 00:57
DrPeter
16.4905° S, 151.7375° W
Maps [15] - [39]
More maps con't
blockmap-15-80A-959-655-L
;SW:80A-959-655-L   HW:80A-959-655-L ---  Airbags
;Component:AirbagVW30    023 0513, Coding:AECCFCC000800000A000003FF20C40000065
;EV_AirbaVW31SMEAU65x,001006,EV_AirbaVW31SMEAU65x_AU49.rod
;Friday,12,July,2019,16:10:03:64285
;VCID: BC3B37B037903AAF05-80E8
Group,Description,Actual
IDE00821,Safety belt switch 2nd row driver side,not installed,
IDE00822,Safety belt switch 2nd row frt.passenger side,not installed,
IDE00823,Safety belt switch 2nd row center,not installed,
IDE00824,Driver side 3rd row seat belt switch,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,3.0, Ohm
IDE00956,Occupation status: frt.passenger seat,Empty or child or child safety seat,
IDE01099,Driver side airbag igniter 2 ohm value,too High,
IDE01100,Passenger side airbag igniter ohm value,2.2, Ohm
IDE01101,Passenger side airbag igniter 2 ohm value,2.1, Ohm
IDE01102,Driver's side airbag igniter ohm value,2.4, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.7, Ohm
IDE01104,driver side rear airbag igniter ohm value,too High,
IDE01105,Ft. pass.side rear airbag igniter ohm value,too High,
IDE01106,Driver side head curtain airbag igniter ohm value,2.6, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.8, Ohm
IDE01108,Driver side knee airbag igniter ohm value,too High,
IDE01109,Frt.pass. side knee airbag igniter ohm value,too High,
IDE01110,Driver side belt tensioner igniter ohm value,2.4, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.5, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,2.4, Ohm
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,2.7, Ohm
IDE01114,Driver side belt force limiter igniter ohm value,2.2, Ohm
IDE01115,side belt force limiter igniter ohm value,2.5, Ohm
IDE01116,driver side rear belt tensioner igniter ohm value,2.5, Ohm
IDE01117,Passenger side rear belt tensioner igniter ohm value,2.7, Ohm
IDE01118,Rear center belt tensioner igniter ohm value,no measured value present,
IDE01119,Battery open circuit igniter ohm value,2.4, Ohm
IDE01120,Driver side active head restraint igniter ohm value,no measured value present,
IDE01121,Passenger side active head restraint igniter ohm value,no measured value present,
IDE01193,Driver belt tensioner ohm value,420.0, Ohm
IDE01194,Frt.pass. belt tensioner ohm value,420.0, Ohm
IDE01195,Front passenger side seat occupancy detection: Ohm value,too High,
IDE01197,Key switch contact 1 ohm value,too High,
IDE01198,Key switch contact 2 ohm value,too High,
IDE01200,Driver seat position sensor current value,5.8, mA
IDE01201,Frt.pass. seat position sensor current value,5.8, mA
IDE01205,Safety belt switch 2nd row driver side ohm value,too High,
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,too High,
IDE01207,Safety belt switch center 2nd row ohm value,too High,
IDE01208,Seat belt switch 3rd row driver side ohm value,too High,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,too High,
IDE01271,Number of rollover bar deployments,0,
IDE01357,Pedestrian protection trigger: driver side,cannot be measured currently,
IDE01358,Pedestrian protection trigger: frt.pass. side,cannot be measured currently,
IDE01359,Front pedestrian protection trigger,cannot be measured currently,
IDE01554-MAS01143,Workshop code for last rollover bar deployment-Device number,2097151,
IDE01554-MAS01144,Workshop code for last rollover bar deployment-Importer number,1023,
IDE01554-MAS01145,Workshop code for last rollover bar deployment-Dealership number,131071,
IDE01555,Number of frontal crashes,0,
IDE01560,Number of activations of active head restraint,0,
IDE01634,Pedestrian protection trigger: driver side ohmic value,no measured value present,
IDE01635,Pedestrian protection trigger: frt.pass. side ohmic value,no measured value present,
IDE01636,Pedestrian protection trigger: front ohmic value,no measured value present,
IDE02852,Igniter for battery interrupt: high voltage battery,not installed,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,too High,
IDE03730,Igniter for driver side air bag release valve: ohm value,2.9, Ohm
IDE03731,Igniter for frt.pass. side air bag release valve: ohm value,2.2, Ohm
IDE03800,Driver airbag release valve igniter,correct,
IDE03801,Frt.pass. airbag release valve igniter,correct,
IDE03870,Seat occupied recognition malfunction status,00,
IDE03870,Seat occupied recognition malfunction status,0,
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05726-MAS09976,Terminal 58xd dimmer-Dim. value indicator lamp for airbag 'off': frt. pass. side,no measured value present,
IDE05726-MAS09977,Terminal 58xd dimmer-Dim. value indicator lamp for airbag 'on': frt. pass. side,no measured value present,
IDE05726-MAS09978,Terminal 58xd dimmer-Dim. value indicator lamp for airbag 'text': frt. pass. side,no measured value present,
IDE06034,Rollover protection trigger: driver side,cannot be measured currently,
IDE06035,Rollover protection trigger: frt.pass. side,cannot be measured currently,
IDE06036,Rollover protection trigger: driver side ohm value,no measured value present,
IDE06038,Rollover protection trigger: frt.pass. side ohm value,no measured value present,
IDE06110,Right belt tensioner supply voltage,correct,
IDE06118,Right belt tensioner current consumption,0.0, A
IDE06119,Left belt tensioner tensioning cycles charac. curve 1,0,
IDE06120,Left belt tensioner tensioning cycles charac. curve 2,5,
IDE06121,Left belt tensioner tensioning cycles charac. curve 3,0,
IDE06122,Left belt tensioner tensioning cycles charac. curve 4,0,
IDE06123,Right belt tensioner tensioning cycles charac. curve 1,0,
IDE06124,Right belt tensioner tensioning cycles charac. curve 2,2,
IDE06125,Right belt tensioner tensioning cycles charac. curve 3,0,
IDE06126,Right belt tensioner tensioning cycles charac. curve 4,0,
IDE06128,Left belt tensioner temperature,37.0, °C
IDE06129,Right belt tensioner temperature,35.5, °C
IDE06130,Left belt tensioner supply voltage,correct,
IDE06131,Left belt tensioner current consumption,0.0, A
IDE06525,Left belt tensioner error status,40,
IDE06525,Left belt tensioner error status,00,
IDE06525,Left belt tensioner error status,0,
IDE06526,Right belt tensioner error status,0,
IDE06526,Right belt tensioner error status,00,
IDE06526,Right belt tensioner error status,40,
IDE06959,Seat occupant detection: diagnosis signal,38.0, %
IDE06960,Seat occupant detection: msmt. signal,0.5, %
IDE06961,Seat occupant detection: ref. signal,too Low,
IDE07190,Igniter for battery open circuit 2nd battery,cannot be measured currently,
IDE07191,2nd Battery open circuit igniter ohm value,no measured value present,
IDE07192,Igniter for window airbag,cannot be measured currently,
IDE07193,Igniter for window airbag Ohm-value,no measured value present,
IDE08436,Driver side seat belt tensioner igniter 3,cannot be measured currently,
IDE08437,Frt.pass. side seat belt tensioner igniter 3,cannot be measured currently,
IDE08438,Driver side seat belt tensioner igniter 3rd row ohm value,no measured value present,
IDE08439,Frt.pass. side seat belt tensioner igniter 3rd row ohm value,no measured value present,
IDE10187,Supply voltage [V],14.2, V
IDE10188,Left belt tensioner supply voltage [V],14.2, V
IDE10189,Right belt tensioner supply voltage [V],14.2, V
IDE11715-MAS01632,Igniter 2 for seat belt tension.:2nd row: fr pas side-Status,cannot be measured currently,
IDE11715-MAS05030,Igniter 2 for seat belt tension.:2nd row: fr pas side-Resistance,no measured value present,
IDE11716-MAS01632,Igniter 2 for seat belt tensioner: 2nd row: driver side-Status,cannot be measured currently,
IDE11716-MAS05030,Igniter 2 for seat belt tensioner: 2nd row: driver side-Resistance,no measured value present,
IDE12056-MAS01632,Igniter for interaction air bag: driver side-Status,cannot be measured currently,
IDE12056-MAS05030,Igniter for interaction air bag: driver side-Resistance,no measured value present,
IDE12057-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,cannot be measured currently,
IDE12057-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,no measured value present,
IDE12158-MAS01632,Front pedestrian protection trigger 2-Status,cannot be measured currently,
IDE12158-MAS05030,Front pedestrian protection trigger 2-Resistance,no measured value present,
IDE80001,Analysis 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80002,Analysis 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80003,Analysis 3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80004,Analysis 4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80005,Analysis 5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80006,Analysis 6,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS00001,Driver airbag igniter,correct,
MAS00002,Driver airbag igniter 2,not installed,
MAS00003,Passenger airbag igniter,correct,
MAS00004,Front passenger airbag igniter 2,correct,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger side airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,not installed,
MAS00008,Passenger side rear thorax airbag igniter,not installed,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,not installed,
MAS00012,Front passenger knee airbag igniter,not installed,
MAS00013,Driver side seat belt tension igniter,correct,
MAS00014,Front passenger side seat belt tension igniter,correct,
MAS00015,Driver seat belt tensioner igniter 2,correct,
MAS00016,Front passenger side seat belt tensioner igniter 2,correct,
MAS00017,Driver side belt force limiter igniter,correct,
MAS00018,Front passenger side belt force limiter igniter,correct,
MAS00019,Driver side rear safety belt tension igniter,correct,
MAS00020,Passenger side rear safety belt tension igniter,correct,
MAS00021,Center rear seat belt tensioner igniter,cannot be measured currently,
MAS00022,Igniter for battery interrupt,correct,
MAS00023,Driver side active head restraint igniter,cannot be measured currently,
MAS00024,Igniter for active head restraint on frt. passenger side,cannot be measured currently,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupied recognition,Not assigned,
MAS00031,Airbag deactivation status,OFF,
MAS00032,Key switch terminal 1,not installed,
MAS00033,Key switch terminal 2,not installed,
MAS00035,Seat position sensor: driver side,Rear,
MAS00036,Seat position sensor: front passenger side,Rear,
MAS00037,Calibration status,0,
MAS01634,Supply voltage,correct,
Elapsed Time: 00:23
adpmap-15-80A-959-655-L
;Friday,12,July,2019,16:10:27:64285
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE05178-Conclude start of operation,locked ,1
IDE06314-Calibration data: pre-crash,01 40 7D FF FE FB 33 6F 00 03 00 00 68 5B 00 C0 1E 18 ,18
IDE06527-IDE06311-Adaptation pre-crash-Seat belt tensioner: left,activated ,4
IDE06527-IDE06312-Adaptation pre-crash-Seat belt tensioner: right,activated ,4
IDE06527-IDE07271-Adaptation pre-crash-Belt tensioner 2nd row: right,not defined ,4
IDE06527-IDE07274-Adaptation pre-crash-Belt tensioner 2nd row: left,not defined ,4
IDE06527-IDE12159-Adaptation pre-crash-Control module for belt feed: second second row left,not defined ,4
IDE06527-IDE12160-Adaptation pre-crash-Control module for belt feed: second second row right,not defined ,4
IDE06528-Programming: left belt tensioner,80 00 0D 00 30 0E 00 FF 28 29 2A 2B 2C FF FF FF 0D 0E 00 FF 30 31 32 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0D 0E 00 FF 48 49 4A FF FF FF FF FF 00 02 1E 01 01 00 FF FF 00 0A 16 01 01 10 FF FF 00 14 10 01 01 10 FF FF 0D AC 1A 09 00 00 FF FF 00 0A 00 81 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 1E 14 01 00 10 FF FF 0D AC 14 09 00 10 FF FF 00 0A 00 81 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 05 E2 84 00 00 FF FF 00 14 E2 04 00 00 FF FF 00 05 00 84 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,384
IDE06529-Programming: right belt tensioner,80 00 0D 00 30 0E 00 FF 28 29 2A 2B 2C FF FF FF 0D 0E 00 FF 30 31 32 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0D 0E 00 FF 48 49 4A FF FF FF FF FF 00 02 1E 01 01 00 FF FF 00 0A 16 01 01 10 FF FF 00 14 10 01 01 10 FF FF 0D AC 1A 09 00 00 FF FF 00 0A 00 81 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 1E 14 01 00 10 FF FF 0D AC 14 09 00 10 FF FF 00 0A 00 81 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 05 E2 84 00 00 FF FF 00 14 E2 04 00 00 FF FF 00 05 00 84 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,384
IDE09601-IDE03311-Adaptation PreCrash functions-Emergency brake display,not defined ,16
IDE09601-IDE03633-Adaptation PreCrash functions-Close sunroof,activated ,16
IDE09601-IDE03634-Adaptation PreCrash functions-Close windows,activated ,16
IDE09601-IDE09602-Adaptation PreCrash functions-Locale hazard warning,not defined ,16
IDE09601-IDE09603-Adaptation PreCrash functions-RECAS,not defined ,16
IDE09601-IDE09604-Adaptation PreCrash functions-Seat adjustment - backrest,activated ,16
IDE09601-IDE09605-Adaptation PreCrash functions-Seat adjust. - side bolster,activated ,16
IDE09601-IDE09606-Adaptation PreCrash functions-Seat adjustment - headrests,activated ,16
IDE09601-IDE09607-Adaptation PreCrash functions-PreCrash Front,activated ,16
IDE09601-IDE09608-Adaptation PreCrash functions-Seat belt slack reduction: left,not defined ,16
IDE09601-IDE09609-Adaptation PreCrash functions-Seat belt slack reduction: right,not defined ,16
IDE09601-IDE09610-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row left,not defined ,16
IDE09601-IDE09611-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row right,not defined ,16
IDE09601-IDE09612-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row ctr.,not defined ,16
IDE09601-IDE09613-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row left,not defined ,16
IDE09601-IDE09614-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row right,not defined ,16
IDE09601-IDE09615-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row ctr.,not defined ,16
IDE09601-IDE09616-Adaptation PreCrash functions-Reversible belt tensioning left,activated ,16
IDE09601-IDE09617-Adaptation PreCrash functions-Reversible belt tensioning right,activated ,16
IDE09601-IDE09618-Adaptation PreCrash functions-Reversible belt tensioning: act. code of seat belt tightenert,not defined ,16
IDE09601-IDE09619-Adaptation PreCrash functions-Reversible belt tensioning: 2nd row right,not defined ,16
IDE09601-IDE09620-Adaptation PreCrash functions-Reversible belt tensioning: 2nd row ctr.,not defined ,16
IDE09601-IDE09621-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row left,not defined ,16
IDE09601-IDE09622-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row right,not defined ,16
IDE09601-IDE09623-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row ctr.,not defined ,16
IDE09601-MAS00478-Adaptation PreCrash functions-Reserved,2 ,16
IDE09601-MAS03834-Adaptation PreCrash functions-Emergency signal flashing,activated ,16
IDE09601-MAS09950-Adaptation PreCrash functions-LED bar activation,not defined ,16
IDE09601-MAS15067-Adaptation PreCrash functions-Belt parking: first Row,not defined ,16
IDE09601-MAS15068-Adaptation PreCrash functions-Belt parking: second Row,not defined ,16
IDE09601-MAS15069-Adaptation PreCrash functions-Measurement value recording,not defined ,16
IDE09601-MAS15070-Adaptation PreCrash functions-BAP resistance PreSense system,not defined ,16
IDE09601-MAS15071-Adaptation PreCrash functions-BAP resistance PreSense warning,not defined ,16
IDE09601-MAS15072-Adaptation PreCrash functions-BAP resistance: distance warning,not defined ,16
IDE09601-MAS15073-Adaptation PreCrash functions-BAP resistance: turning assistance,not defined ,16
IDE09601-MAS15074-Adaptation PreCrash functions-BAP resistance proactive passenger cover,not defined ,16
IDE12055-IDE12056-Adaptation airbag 2-Igniter for interaction air bag: driver side,not defined ,8
IDE12055-IDE12057-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,not defined ,8
IDE12055-IDE12258-Adaptation airbag 2-Assistance system monitor,not defined ,8
IDE12055-IDE14239-Adaptation airbag 2-Igniter for high-voltage battery 2 open circuit,not defined ,8
IDE12055-IDE14240-Adaptation airbag 2-Driver side seat occupancy detection,not defined ,8
IDE12055-MAS00478-Adaptation airbag 2-Reserved,2 ,8
MAS00975-IDE00947-Airbag adaptations-driver side rear curtain airbag igniter,not defined ,8
MAS00975-IDE00948-Airbag adaptations-Frt.passenger side rear curtain airbag igniter,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery,not defined ,8
MAS00975-IDE07190-Airbag adaptations-Igniter for battery open circuit 2nd battery,not defined ,8
MAS00975-IDE07192-Airbag adaptations-Igniter for window airbag,not defined ,8
MAS00975-IDE08436-Airbag adaptations-Driver side seat belt tensioner igniter 3,not defined ,8
MAS00975-IDE08437-Airbag adaptations-Frt.pass. side seat belt tensioner igniter 3,not defined ,8
MAS00975-IDE12208-Airbag adaptations-Igniter for deactivation of A/C system 1,not defined ,8
MAS00975-IDE12209-Airbag adaptations-Igniter for deactivation of A/C system 2,not defined ,8
MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,not defined ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter,activated ,8
MAS00975-MAS00021-Airbag adaptations-Center rear seat belt tensioner igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt,activated ,8
MAS00975-MAS00023-Airbag adaptations-Driver side active head restraint igniter,not defined ,8
MAS00975-MAS00024-Airbag adaptations-Igniter for active head restraint on frt. passenger side,not defined ,8
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch not parameterized ,8
MAS00975-MAS00231-Airbag adaptations-Seat occupant detection: front passenger side,not defined ,8
Elapsed Time: 00:11
blockmap-16-80A-907-129-BR
;SW:80A-907-129-BR   HW:80A-907-129-BR ---  Steering wheel
;Component:Lenks.Modul   H02 0005, Coding:
;EV_SMLSKLOAU736,007012,EV_SMLSKLOAU736_007_AU49.rod
;Friday,12,July,2019,16:10:41:64285
;VCID: F9B5EEA47822CF875E-80AC
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,On,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not installed,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,not activated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Accelerate tap,not activated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,not activated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,not activated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,not activated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,CCS Switch,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Delay tip level 2,not activated,
IDE00356-MAS04523,Cruise Control System (CCS): switch position-Accelerate tip level 2,not activated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,8 positions,
IDE00356-MAS05360,Cruise Control System (CCS): switch position-Discreet wire,High-level,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS10720,Cruise Control System (CCS): switch position-Speed limiter,not installed,
IDE00356-MAS13642,Cruise Control System (CCS): switch position-Button for cruise control system,not installed,
IDE02068-MAS00106,Time stamp-Year,2018, yr
IDE02068-MAS00107,Time stamp-Month,5, m
IDE02068-MAS00108,Time stamp-Day,24, d
IDE02068-MAS00109,Time stamp-Hours,19, H
IDE02068-MAS00110,Time stamp-Minutes,59, min
IDE02068-MAS00111,Time stamp-Seconds,10, s
IDE02068-MAS00711,Time stamp-Odometer reading,0, km
IDE02068-MAS02543,Time stamp-VIN determined during calibration,57 41 31 41 4E 41 46 59 39 4A 32 31 39 32 39 31 36,
IDE02693-IDE02335,Turn signals and parking lights-Signal light switch position,not activated,
IDE02693-IDE08189,Turn signals and parking lights-Malfunction status flasher,No malfunction detected,
IDE02695-IDE01268,Front wiping: front washing-Windshield wiper,Intermittent operation,
IDE02695-IDE11269,Front wiping: front washing-Front windshield wiper error status,No malfunction detected,
IDE02695-MAS02338,Front wiping: front washing-Windshield wiper: intermittent stage,Stage 4,
IDE02695-MAS02339,Front wiping: front washing-Windshield washer system,not activated,
IDE02696-IDE02711,Rear wiping: rear washing-Rear Window Wiper,not activated,
IDE02696-MAS02341,Rear wiping: rear washing-Rear window washer system,not activated,
IDE02743-IDE05742,High Beam-Light switch position,not activated,
IDE03680-IDE00019,Supply voltages-Voltage terminal 30,14167.97, mV
IDE03680-IDE00618,Supply voltages-Voltage supply 5V,4914.84, mV
IDE03680-MAS00125,Supply voltages-Cruise control system,12569.53, mV
IDE05725-IDE01763,Terminal 58xs dimmer-Dimming,00,
IDE05725-MAS03873,Terminal 58xs dimmer-Duty cycle,0, %
IDE08696-IDE02219,Steerg. wheel angle sens.-Steering wheel angle: sign,Positive,
IDE08696-MAS00037,Steerg. wheel angle sens.-Calibration status,calibrated,
IDE08696-MAS00370,Steerg. wheel angle sens.-Vehicle speed,in permissible range,
IDE08696-MAS02125,Steerg. wheel angle sens.-Steering wheel angle speed,0, °/s
IDE08696-MAS02126,Steerg. wheel angle sens.-Steering angle sensor: status,initialized,
IDE08696-MAS02128,Steerg. wheel angle sens.-Q bit: steering wheel angle,valid,
IDE08696-MAS02357,Steerg. wheel angle sens.-Vehicle identification,detected,
IDE08696-MAS02358,Steerg. wheel angle sens.-Calibration angle,outside permissible range,
IDE08696-MAS02406,Steerg. wheel angle sens.-Steering wheel angle: internal value,5.3, °
IDE08696-MAS02453,Steerg. wheel angle sens.-Steering wheel angle offset,1.1, °
IDE08696-MAS02832,Steerg. wheel angle sens.-Malfunction status,no error,
IDE08696-MAS02983,Steerg. wheel angle sens.-Steering wheel angle,4.2, °
IDE08696-MAS04474,Steerg. wheel angle sens.-Left front wheel speed,0.00, km/h
IDE08696-MAS04475,Steerg. wheel angle sens.-Right front wheel speed,0.00, km/h
IDE08696-MAS04476,Steerg. wheel angle sens.-Left rear wheel speed,0.00, km/h
IDE08696-MAS04477,Steerg. wheel angle sens.-Right rear wheel speed,0.00, km/h
IDE08696-MAS07727,Steerg. wheel angle sens.-Steering wheel angle: prefix internal value,Positive,
IDE08696-MAS07728,Steerg. wheel angle sens.-Steering wheel angle offset: prefix,Positive,
IDE08696-MAS07729,Steerg. wheel angle sens.-Steering wheel speed: prefix,Positive,
IDE09381-IDE02219,Steering angle sensor calibration status-Steering wheel angle: sign,Positive,
IDE09381-MAS00037,Steering angle sensor calibration status-Calibration status,calibrated,
IDE09381-MAS00370,Steering angle sensor calibration status-Vehicle speed,in permissible range,
IDE09381-MAS02126,Steering angle sensor calibration status-Steering angle sensor: status,initialized,
IDE09381-MAS02357,Steering angle sensor calibration status-Vehicle identification,detected,
IDE09381-MAS02358,Steering angle sensor calibration status-Calibration angle,outside permissible range,
IDE09381-MAS02406,Steering angle sensor calibration status-Steering wheel angle: internal value,5.3, °
IDE09381-MAS02832,Steering angle sensor calibration status-Malfunction status,no error,
IDE09381-MAS02983,Steering angle sensor calibration status-Steering wheel angle,4.2, °
IDE09381-MAS04121,Steering angle sensor calibration status-Voltage,in permissible range,
IDE09381-MAS07727,Steering angle sensor calibration status-Steering wheel angle: prefix internal value,Positive,
IDE09381-MAS08808,Steering angle sensor calibration status-Maximal allowed offset angle,0.0, °
IDE09381-MAS08809,Steering angle sensor calibration status-Maximal allowed offset angle: sign,Positive,
IDE09381-MAS08810,Steering angle sensor calibration status-Minimum allowed offset angle,0.0, °
IDE09381-MAS08811,Steering angle sensor calibration status-Minimum allowed offset angle: sign,Positive,
Elapsed Time: 00:05
adpmap-16-80A-907-129-BR
;Friday,12,July,2019,16:10:47:64285
IDE00820-IDE80001-Activating and deactivating all development messages-Analysis 1,OFF ,1
IDE00820-IDE80002-Activating and deactivating all development messages-Analysis 2,OFF ,1
IDE00820-IDE80003-Activating and deactivating all development messages-Analysis 3,OFF ,1
IDE00820-IDE80004-Activating and deactivating all development messages-Analysis 4,OFF ,1
IDE00820-IDE80005-Activating and deactivating all development messages-Analysis 5,OFF ,1
IDE12365-Switching off the MFL buttons during dynamic driving,On ,1
Elapsed Time: 00:01
blockmap-22-80A-927-755
;SW:80A-927-755   HW:0CJ-927-749-A ---  AWD
;Component:Q5_DL3_N_SD4  H01 0004, Coding:11070000
;EV_AWDCQUOD31,001048,EV_AWDCQUOD31.rod
;Friday,12,July,2019,16:10:51:64285
;VCID: EC9BC7F007706A2FD5-80B8
IDE00021,Engine speed,795.00, /min
IDE00030-ENG102351,Status of actuator test-Actuator Test Status,not active,
IDE00322-ENG28319,Status of basic setting-Basic Setting Status,not active,
IDE00445-ENG28259,Unlearning counter according OBD-OBD unlearning counter,255,
IDE04342-ENG30601,Cause for cancellation of actuator test-Cause_of_abortion_acutator_test,Output diagnostic test not active,
IDE04553,VIN received,WA1ANAFY9J2192916,
IDE04554,VIN stored,WA1ANAFY9J2192916,
IDE05821-IDE00920,Input signals from brake control module-Front left wheel speed,0.0, km/h
IDE05821-IDE00921,Input signals from brake control module-Front right wheel speed,0.0, km/h
IDE05821-IDE00922,Input signals from brake control module-Left rear wheel speed,0.0, km/h
IDE05821-IDE00923,Input signals from brake control module-Right rear wheel speed,0.0, km/h
IDE05821-IDE02205,Input signals from brake control module-Left front wheel: rotational direction,forwards,
IDE05821-IDE02206,Input signals from brake control module-Right front wheel: rotational direction,forwards,
IDE05821-IDE02207,Input signals from brake control module-Left rear wheel: rotational direction,forwards,
IDE05821-IDE02208,Input signals from brake control module-Right rear wheel: rotational direction,forwards,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE08133-ENG121991,Basic setting: cause for cancellation-Routine_abort_reason,Basic setting not active,
IDE11277-IDE01717,Ctrl. mod.: operating condition-Processor load,77, %
IDE11277-MAS00043,Ctrl. mod.: operating condition-Supply voltage: Terminal 30,14.17285156250000, V
IDE11277-MAS06981,Ctrl. mod.: operating condition-Terminal 15 status signal via CAN,On,
IDE11277-MAS06982,Ctrl. mod.: operating condition-Terminal 15 status signal,On,
IDE11277-MAS09113,Ctrl. mod.: operating condition-Maximum temperature,69, °C
IDE12260-IDE03198,Clutch actuator 1 for all-wheel drive-Static calibration,not active,
IDE12260-IDE05421,Clutch actuator 1 for all-wheel drive-Torque: current value,0, Nm
IDE12260-IDE10258,Clutch actuator 1 for all-wheel drive-Torque: spec. value,1.00, Nm
IDE12260-MAS02358,Clutch actuator 1 for all-wheel drive-Calibration angle,21.1406250000000, °
IDE12260-MAS02964,Clutch actuator 1 for all-wheel drive-Angle value,40.5, °
IDE12260-MAS04136,Clutch actuator 1 for all-wheel drive-Current,0.0762, A
IDE12260-MAS14338,Clutch actuator 1 for all-wheel drive-After-run calibration,not active,
IDE12260-MAS14339,Clutch actuator 1 for all-wheel drive-After-run calibration: angle,25.1718750000000, °
IDE12423-MAS04136,Clutch actuator 2 for all-wheel drive-Current,0.0117, A
IDE12423-MAS09527,Clutch actuator 2 for all-wheel drive-Activation voltage: act. value,0.00195312500000, V
IDE12423-MAS09528,Clutch actuator 2 for all-wheel drive-Activation voltage: spec. value,0.00000000000000, V
IDE12425-MAS02324,Drive shaft speed sensor-Voltage at sensor,4.99902343750000, V
IDE12425-MAS06857,Drive shaft speed sensor-Speed,0, /min
IDE80100-ENG30960,Analysis 100-EA Block,00 00 07 64 00 00 BE 0E 00 02 9F EA 00 00 A3 C2 00 00 10 36 00 00 03 40 00 00 01 06 00 00 01 56 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3A 1A 00 03 94 1E 00 00 3C BA 00 00 0E 22 00 00 03 B0 00 00 00 92 00 00 00 0C 00 00 00 04 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 03 7E 9E 00 00 7B B8 00 00 19 38 00 00 08 12 00 00 02 CA 00 00 00 CE 00 00 00 1E 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 74 00 00 31 EA 00 00 3B 78 00 01 71 94 00 02 4E 8E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C2 A8 00 02 15 B8 00 01 30 60 00 00 19 2C 00 00 01 EA 00 00 00 52 00 00 00 0C 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4E 00 00 2A 7A 00 00 85 E2 00 00 B9 86 00 01 96 58 00 01 23 82 00 00 01 54 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4F 00 87 01 48 01 5E 01 0F 01 10 02 0D 01 90 02 20 09 9A 00 19 00 1D 00 6A 00 70 00 57 00 4C 00 A1 00 8B 00 D1 02 E9 00 00 00 00 00 00 00 00 00 19 00 1D 00 6A 00 70 00 57 00 4C 00 A1 00 8B 00 D1 02 E9 00 05 00 00 00 00 00 18 01 3B 02 BF 09 12 03 77 02 F2 0B CC 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 18 01 3B 02 BF 09 12 03 77 02 F2 0B CC 00 00 00 00 00 00 00 02 00 1E 00 07 00 36 00 8A 01 61 04 1C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 1E 00 07 00 36 00 8A 01 61 04 1C 00 01 00 00 00 00 00 28 00 00 00 17 00 00 10 D8 00 00 05 4E 00 00 00 00 00 00 00 00 04 19 00 7A 00 EB 02 03 00 5B 00 67 00 5E 00 40 00 49 00 B5 00 8D 00 09 00 14 00 2E 00 09 00 14 00 31 00 03 00 02 00 09 00 00 00 00 00 00 00 00 00 8D 00 09 00 14 00 2E 00 09 00 14 00 31 00 03 00 02 00 09 00 00 00 3B 00 00 00 2F 00 00 2E B5 00 00 00 20 00 00 02 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2D 82 00 00 00 00 00 00 38 B4 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 BD 00 00 06 C8 00 00 00 0F 00 00 00 00 00 00 00 00 00 00 00 01 00 00 34 9C 00 00 15 9B 00 00 13 BC 00 00 00 03 00 03 84 03 00 01 D6 F4 00 01 2C 4A 00 00 BE B5 00 00 2C 3A 00 00 05 5A 00 00 05 EB 00 00 02 04 00 00 07 DE 00 00 01 FE 00 00 00 00 00 00 00 00 00 00 00 07 00 00 00 10 00 00 00 2F 00 00 00 03 00 00 00 00 00 00 00 00 00 00 02 51 00 00 00 01 00 00 03 B5 00 00 00 55 00 00 02 2B 00 00 00 4B 00 00 00 28 00 00 00 17 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 79 00 00 00 D9 00 00 00 62 04 80 00 00 00 00 00 00 13 0D AF 00 13 44 4A FF FF 5A DB 00 01 15 12 17 00 FF EE 00 1C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 13 0D AF 00 13 44 4A FF FF 5A DB 00 01 15 12 17 00 FF EE 00 1C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80100-ENG31000,Analysis 100-EF Block,00 14 93 F1 00 06 EB 06 00 18 84 B6 00 08 E4 E5 00 00 10 D8 00 00 05 4E 00 00 00 00 00 00 00 00 00 00 01 E3 00 00 00 5F 00 00 08 1B 00 00 02 96 00 00 00 00 00 00 00 00 00 00 1F 59 00 00 06 64 2D 00 1A 8E 12 DC 0D BB 0A B7 06 20 00 00 0C 7A 00 00 00 3B 00 00 02 78 00 00 2E B5 00 00 00 89 00 00 00 2F 00 00 00 67 00 00 00 20 00 00 01 CC 00 00 00 DD 00 00 05 A2 00 00 00 CD 68 00 68 00 02 1B 01 72 00 FF 00 B2 00 7B 00 55 00 40 66 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80100-ENG32111,Analysis 100-MPT Block,00 11 07 00 00 18 05 24 00 06 46 22 09 57 00 00 00 00 00 00 00 01 01 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 00 00 00 00 87 75 00 00 00 00 00 00 00 00 00 00 00 00 00 57 41 31 41 4E 41 46 59 39 4A 32 31 39 32 39 31 36 A8 BE CE BE B1 BE B9 A6 C6 B5 CD CE C6 CD C6 CE C9 00 00 00 00 FF FF FF FF 01 14 00 00 1E 00 55 00 00 00 08 FF E5 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG26478-ENG30373,Autosar Error Dump (AS_COMM_E_NET_START_IND_CHANNEL_0)-Autosar Error,AS_COMM_E_NET_START_IND_CHANNEL_0,
ENG26479-ENG30373,Autosar Error Dump (AS_FLS_E_COMPARE_FAILED)-Autosar Error,AS_FLS_E_COMPARE_FAILED,
ENG26480-ENG30373,Autosar Error Dump (AS_FLS_E_ERASE_FAILED)-Autosar Error,AS_FLS_E_ERASE_FAILED,
ENG26481-ENG30373,Autosar Error Dump (AS_FLS_E_READ_FAILED)-Autosar Error,AS_FLS_E_READ_FAILED,
ENG26482-ENG30373,Autosar Error Dump (AS_FLS_E_TIMEOUT)-Autosar Error,AS_FLS_E_TIMEOUT,
ENG26483-ENG30373,Autosar Error Dump (AS_FLS_E_WRITE_FAILED)-Autosar Error,AS_FLS_E_WRITE_FAILED,
ENG26484-ENG30373,Autosar Error Dump (AS_FR_E_ACCESS)-Autosar Error,AS_FR_E_ACCESS,
ENG26485-ENG30373,Autosar Error Dump (AS_FR_E_CTRLTESTRESULT)-Autosar Error,AS_FR_E_CTRLTESTRESULT,
ENG26486-ENG30373,Autosar Error Dump (AS_FRTRCV_E_FR_NO_TRCV_CONTROL)-Autosar Error,AS_FRTRCV_E_FR_NO_TRCV_CONTROL,
ENG26487-ENG30373,Autosar Error Dump (AS_FRTRCV_E_FR_STARLOCKED)-Autosar Error,AS_FRTRCV_E_FR_STARLOCKED,
ENG26488-ENG30373,Autosar Error Dump (AS_NVM_E_INTEGRITY_FAILED)-Autosar Error,AS_NVM_E_INTEGRITY_FAILED,
ENG26489-ENG30373,Autosar Error Dump (AS_PDUR_E_INIT_FAILED)-Autosar Error,AS_PDUR_E_INIT_FAILED,
ENG26490-ENG30373,Autosar Error Dump (AS_PDUR_E_PDU_INSTANCE_LOST)-Autosar Error,AS_PDUR_E_PDU_INSTANCE_LOST,
ENG26494-ENG30603,CC Error Dump (EVENT_CC_BROKEN_MECHANICS)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26495-ENG30603,CC Error Dump (EVENT_CC_CALIB_ANGLE_ERR)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26496-ENG30603,CC Error Dump (EVENT_CC_CALIB_ERR)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26497-ENG30603,CC Error Dump (EVENT_CC_CLASSIFICATION_NOT_DONE)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26498-ENG30603,CC Error Dump (EVENT_CC_CLUTCH_END_OF_LIFE)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26499-ENG30603,CC Error Dump (EVENT_CC_CLUTCH_PROTECTION)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26500-ENG30603,CC Error Dump (EVENT_CC_CLUTCH_WEAR_PLAUSI)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26501-ENG30603,CC Error Dump (EVENT_CC_ECU_PROTECTION)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26502-ENG30603,CC Error Dump (EVENT_CC_EX_MAX_ANGLE)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26503-ENG30603,CC Error Dump (EVENT_CC_INITIAL_POSITION)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26504-ENG30603,CC Error Dump (EVENT_CC_INITIAL_POSITION_DEVIATION)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26505-ENG30603,CC Error Dump (EVENT_CC_NO_CALIB)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26506-ENG30603,CC Error Dump (EVENT_CC_NVMDATA_CORRUPT)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26507-ENG30603,CC Error Dump (EVENT_CC_PHI_TUBE)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26508-ENG30603,CC Error Dump (EVENT_CC_WEAR_OIL)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26509-ENG30603,CC Error Dump (EVENT_DC_DOG_CLUTCH_MECHANICAL_DISCONNECT_ERROR)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26510-ENG30603,CC Error Dump (EVENT_DC_DOG_CLUTCH_MECHANICAL_ERROR)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26511-ENG30603,CC Error Dump (EVENT_DC_FULL_LOCK_TORQUE_DEACTIVATED)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26512-ENG30603,CC Error Dump (EVENT_DC_NOT_SYNCHRONOUS)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26513-ENG30603,CC Error Dump (EVENT_DC_REAR_AXLE_GEAR_RATIO_MISMATCH)-CC Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26514-ENG30604,CDD Error Dump (EVENT_BATT_SUPPLY_SLOW_OV)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26515-ENG30604,CDD Error Dump (EVENT_BATT_SUPPLY_SLOW_UV)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26516-ENG30604,CDD Error Dump (EVENT_CAN_ELECTRICAL_FAILURE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26517-ENG30604,CDD Error Dump (EVENT_ECU_OT_SHDWN)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26518-ENG30604,CDD Error Dump (EVENT_EXT_SENS_SIGN_DUTY_RANGE_CHECK)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26519-ENG30604,CDD Error Dump (EVENT_EXT_SENS_SIGN_FREQ_RANGE_CHECK)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26520-ENG30604,CDD Error Dump (EVENT_EXT_SENS_SIGN_OL_FAILURE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26521-ENG30604,CDD Error Dump (EVENT_EXT_SENS_SIGN_SCB_FAILURE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26522-ENG30604,CDD Error Dump (EVENT_EXT_SENS_SIGN_SCG_FAILURE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26523-ENG30604,CDD Error Dump (EVENT_EXT_SENS_SUPPLY_OL_FAILURE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26524-ENG30604,CDD Error Dump (EVENT_EXT_SENS_SUPPLY_OV_FAILURE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26525-ENG30604,CDD Error Dump (EVENT_EXT_SENS_SUPPLY_UV_FAILURE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26526-ENG30604,CDD Error Dump (EVENT_HSOUT_CU_SDP_TEST)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26527-ENG30604,CDD Error Dump (EVENT_HSOUT_HIGH)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26528-ENG30604,CDD Error Dump (EVENT_HSOUT_Kl31_OC)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26529-ENG30604,CDD Error Dump (EVENT_HSOUT_LOW)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26530-ENG30604,CDD Error Dump (EVENT_HSOUT_OC)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26531-ENG30604,CDD Error Dump (EVENT_HSOUT_OT_SHDWN)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26532-ENG30604,CDD Error Dump (EVENT_HSOUT_OVLD)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26533-ENG30604,CDD Error Dump (EVENT_MCU_ADC_CTU_CHECK)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26534-ENG30604,CDD Error Dump (EVENT_MCU_ETIMER_COMPARE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26535-ENG30604,CDD Error Dump (EVENT_MCU_FCCU_CLK_MON)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26536-ENG30604,CDD Error Dump (EVENT_MCU_FCCU_CORE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26537-ENG30604,CDD Error Dump (EVENT_MCU_FCCU_ECC_MON)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26538-ENG30604,CDD Error Dump (EVENT_MCU_FCCU_SELF_CHECK)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26539-ENG30604,CDD Error Dump (EVENT_MCU_OT_SHDWN)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26540-ENG30604,CDD Error Dump (EVENT_MCU_PERIPHERAL_REGCRC)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26541-ENG30604,CDD Error Dump (EVENT_MCU_TEMP_LOW)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26542-ENG30604,CDD Error Dump (EVENT_MCU_TEMP_PLAUSIB)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26543-ENG30604,CDD Error Dump (EVENT_MU_3V3CORE_DRIFT)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26544-ENG30604,CDD Error Dump (EVENT_MU_CHECK_FCCU)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26545-ENG30604,CDD Error Dump (EVENT_MU_CHECK_FS0b)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26546-ENG30604,CDD Error Dump (EVENT_MU_CHECK_RSTb)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26547-ENG30604,CDD Error Dump (EVENT_MU_CONFIG_DEBUG)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26548-ENG30604,CDD Error Dump (EVENT_MU_CONFIG_INIT)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26549-ENG30604,CDD Error Dump (EVENT_MU_CONFIG_WD_WINDOW)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26550-ENG30604,CDD Error Dump (EVENT_MU_GLOBAL_UV_RST)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26551-ENG30604,CDD Error Dump (EVENT_MU_MCU_PFM)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26552-ENG30604,CDD Error Dump (EVENT_MU_MCU_RESET)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26553-ENG30604,CDD Error Dump (EVENT_MU_MCU_SUPPLY_OV)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26554-ENG30604,CDD Error Dump (EVENT_MU_MCU_SUPPLY_UV)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26555-ENG30604,CDD Error Dump (EVENT_MU_OT_SHDWN)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26556-ENG30604,CDD Error Dump (EVENT_MU_SPI_COM_FAILURE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26557-ENG30604,CDD Error Dump (EVENT_MU_TEMP_LOW)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26558-ENG30604,CDD Error Dump (EVENT_MU_TEMP_PLAUSIB)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26559-ENG30604,CDD Error Dump (EVENT_MU_WD_REFRESH)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26559-ENG18429,CDD Error Dump (EVENT_MU_WD_REFRESH)-dummy,FF FF FF,
ENG26559-ENG32215,CDD Error Dump (EVENT_MU_WD_REFRESH)-OSTM Last Timer ID,FF,
ENG26560-ENG30604,CDD Error Dump (EVENT_PMSM_CALIBDATA_INVALID)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26561-ENG30604,CDD Error Dump (EVENT_PMSM_CU_DISABLE_CHECK)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26562-ENG30604,CDD Error Dump (EVENT_PMSM_CURRENT_CROSS_CHECK)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26563-ENG30604,CDD Error Dump (EVENT_PMSM_CURRENT_OFFSET_CHECK)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26564-ENG30604,CDD Error Dump (EVENT_PMSM_CURRENT_PLAUSIB_CHECK)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26565-ENG30604,CDD Error Dump (EVENT_PMSM_CURRENT_RANGE_CHECK)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26566-ENG30604,CDD Error Dump (EVENT_PMSM_GD_CHARGE_PUMP)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26567-ENG30604,CDD Error Dump (EVENT_PMSM_GD_CONFIG_FAILURE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26568-ENG30604,CDD Error Dump (EVENT_PMSM_GD_ERR_CONSIST)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26569-ENG30604,CDD Error Dump (EVENT_PMSM_GD_INT_SUP_FAILURE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26570-ENG30604,CDD Error Dump (EVENT_PMSM_GD_OC_SHDWN)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26571-ENG30604,CDD Error Dump (EVENT_PMSM_GD_OT_SHDN)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26572-ENG30604,CDD Error Dump (EVENT_PMSM_GD_OVLD_DO_FAILURE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26573-ENG30604,CDD Error Dump (EVENT_PMSM_GD_SCD)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26574-ENG30604,CDD Error Dump (EVENT_PMSM_GD_SPI_COM_FAILURE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26575-ENG30604,CDD Error Dump (EVENT_PMSM_GD_SUPPLY_OV)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26576-ENG30604,CDD Error Dump (EVENT_PMSM_GD_SUPPLY_UV)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26577-ENG30604,CDD Error Dump (EVENT_PMSM_MOSFET_PATTERN_CHECK)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26578-ENG30604,CDD Error Dump (EVENT_PMSM_SUPPLY_FAST_OV)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26579-ENG30604,CDD Error Dump (EVENT_PMSM_SUPPLY_FAST_UV)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26580-ENG30604,CDD Error Dump (EVENT_PMSM_SUPPLY_VOLTAGE_CROSS_CHECK)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26581-ENG30604,CDD Error Dump (EVENT_PSU_CONFIG)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26582-ENG30604,CDD Error Dump (EVENT_RPS_CONFIG_FAILURE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26583-ENG30604,CDD Error Dump (EVENT_RPS_IIF_GRADIENT_CHECK)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26584-ENG30604,CDD Error Dump (EVENT_RPS_RAW_DATA_CHECK)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26585-ENG30604,CDD Error Dump (EVENT_RPS_SPI_2_IIF_INPLAUSIBLE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26586-ENG30604,CDD Error Dump (EVENT_RPS_SPI_COM_FAILURE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26587-ENG30604,CDD Error Dump (EVENT_RPS_SYSTEM_FAILURE)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26588-ENG30604,CDD Error Dump (EVENT_RPS_TEMP_CROSS_CHK)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26589-ENG30604,CDD Error Dump (EVENT_RPS_TEMP_RANGE_CHECK_HIGH)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26590-ENG30604,CDD Error Dump (EVENT_RPS_TEMP_RANGE_CHK_LOW)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26591-ENG30604,CDD Error Dump (EVENT_SW_CORE_EXCEPTION)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26592-ENG30604,CDD Error Dump (EVENT_SW_MODULE_CONF_INVALID)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26593-ENG30604,CDD Error Dump (EVENT_SW_RANGE_CHECK_FAILED)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26594-ENG30604,CDD Error Dump (EVENT_TEMP_SENS_CROSS_CHK)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26595-ENG30604,CDD Error Dump (EVENT_TEMP_SENS_SC_HIGH)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26596-ENG30604,CDD Error Dump (EVENT_TEMP_SENS_SC_LOW)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26597-ENG30604,CDD Error Dump (EVENT_TEMP_SENS_TEMP_GRADIENT)-CDD Error Dump,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
ENG26682-ENG30952,DTC Subcode (FR_AFR_01_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26683-ENG30952,DTC Subcode (FR_EPB_01_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26684-ENG30952,DTC Subcode (FR_ESP_03_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26685-ENG30952,DTC Subcode (FR_ESP_05_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26686-ENG30952,DTC Subcode (FR_ESP_07_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26687-ENG30952,DTC Subcode (FR_ESP_08_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26688-ENG30952,DTC Subcode (FR_ESP_14_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26689-ENG30952,DTC Subcode (FR_ESP_20_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26690-ENG30952,DTC Subcode (FR_ESP_21_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26691-ENG30952,DTC Subcode (FR_ESP_22_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26692-ENG30952,DTC Subcode (FR_ESP_23_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26693-ENG30952,DTC Subcode (FR_ESP_24_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26694-ENG30952,DTC Subcode (FR_ESP_26_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26695-ENG30952,DTC Subcode (FR_ESP_28_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26696-ENG30952,DTC Subcode (FR_ESP_32_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26697-ENG30952,DTC Subcode (FR_ESP_33_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26698-ENG30952,DTC Subcode (FR_FAHRWERK_01_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26699-ENG30952,DTC Subcode (FR_GETRIEBE_11_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26700-ENG30952,DTC Subcode (FR_GETRIEBE_13_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26701-ENG30952,DTC Subcode (FR_GETRIEBE_17_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26702-ENG30952,DTC Subcode (FR_HAL_01_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26703-ENG30952,DTC Subcode (FR_KLEMMEN_STATUS_01_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26704-ENG30952,DTC Subcode (FR_KOMBI_02_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26705-ENG30952,DTC Subcode (FR_LH_EPS_03_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26706-ENG30952,DTC Subcode (FR_LWI_01_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26707-ENG30952,DTC Subcode (FR_MOTOR_07_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26708-ENG30952,DTC Subcode (FR_MOTOR_11_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26709-ENG30952,DTC Subcode (FR_MOTOR_12_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26710-ENG30952,DTC Subcode (FR_MOTOR_14_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26711-ENG30952,DTC Subcode (FR_MOTOR_16_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26712-ENG30952,DTC Subcode (FR_MOTOR_20_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26713-ENG30952,DTC Subcode (FR_MOTOR_CODE_01_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26714-ENG30952,DTC Subcode (FR_SARA_06_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26715-ENG30952,DTC Subcode (FR_SCU_01_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26716-ENG30952,DTC Subcode (FR_TSK_06_SIGNAL_ERROR)-DTC SubCode,Unknown (255),
ENG26812-ENG31895,four_wheel_drive_system_status-Kupplungsmoment_in_pct,0.0, %
ENG26812-ENG32018,four_wheel_drive_system_status-max_Kupplungsmoment,660.0, Nm
ENG26812-ENG32737,four_wheel_drive_system_status-state_allwheel_drive_disconnect_system,zugeschaltet,
ENG26812-ENG32738,four_wheel_drive_system_status-state_allwheel_drive_system,Regelmodus,
ENG26921-ENG25149,KL15 State-Combined KL15,1,
ENG26921-ENG25189,KL15 State-HW KL15 Debounce Time,50, ms
ENG26921-ENG25190,KL15 State-HW KL15 Filtered,1,
ENG26921-ENG25191,KL15 State-HW KL15 Raw,1,
ENG26921-ENG25269,KL15 State-SW KL15,1,
ENG26921-ENG25270,KL15 State-SW KL15 Timeout,0,
ENG26993,NM-State,NM_STATE_NORMAL_OPERATION,
ENG27085-MAS12637,Rear_drive_shaft_synchronisation-Adaption value 1,4.75, Nm
ENG27085-MAS12638,Rear_drive_shaft_synchronisation-Adaption value 2,6.25, Nm
ENG27085-MAS12639,Rear_drive_shaft_synchronisation-Adaption value 3,8.50, Nm
ENG27085-MAS12640,Rear_drive_shaft_synchronisation-Adaption value 4,13.50, Nm
ENG27085-MAS12641,Rear_drive_shaft_synchronisation-Adaption value 5,26.00, Nm
ENG27085-MAS12642,Rear_drive_shaft_synchronisation-Adaption value 6,52.25, Nm
ENG27085-ENG30294,Rear_drive_shaft_synchronisation-Adaption_value_1_state,Adaptation successfully finished,
ENG27085-ENG30295,Rear_drive_shaft_synchronisation-Adaption_value_2_state,Adaptation successfully finished,
ENG27085-ENG30296,Rear_drive_shaft_synchronisation-Adaption_value_3_state,Adaptation successfully finished,
ENG27085-ENG30297,Rear_drive_shaft_synchronisation-Adaption_value_4_state,Adaptation successfully finished,
ENG27085-ENG30298,Rear_drive_shaft_synchronisation-Adaption_value_5_state,Adaptation successfully finished,
ENG27085-ENG30299,Rear_drive_shaft_synchronisation-Adaption_value_6_state,Adaptation successfully finished,
ENG27085-ENG36217,Rear_drive_shaft_synchronisation-Basis_value_1,0.003242, Nm/rpm
ENG27085-ENG36218,Rear_drive_shaft_synchronisation-Basis_value_2,0.003242, Nm/rpm
ENG27085-ENG36219,Rear_drive_shaft_synchronisation-Basis_value_3,0.003242, Nm/rpm
ENG27085-ENG36220,Rear_drive_shaft_synchronisation-Basis_value_4,0.003242, Nm/rpm
ENG27085-ENG36221,Rear_drive_shaft_synchronisation-Basis_value_5,0.003242, Nm/rpm
ENG27085-ENG36222,Rear_drive_shaft_synchronisation-Basis_value_6,0.003242, Nm/rpm
ENG27085-ENG36271,Rear_drive_shaft_synchronisation-Number_of_Adaptions,25,
ENG26216-ENG32457,Reset reason-ResetReason,00 00 00 00,
ENG27087,Reset Safe RAM CDD,00 00 00 00 00 00 00 00 00 00,
ENG27120,Sensor Speed,0, /min
ENG27123-ENG32552,Shadow Error Memory-Shadow Error Memory (1),DTC_FR_TIMEOUT_SMLS,
ENG27123-ENG32553,Shadow Error Memory-Shadow Error Memory (10),DTC_FR_ESP_23_SIGNAL_ERROR,
ENG27123-ENG32554,Shadow Error Memory-Shadow Error Memory (11),DTC_FR_ESP_21_SIGNAL_ERROR,
ENG27123-ENG32555,Shadow Error Memory-Shadow Error Memory (12),DTC_FR_ESP_22_SIGNAL_ERROR,
ENG27123-ENG32556,Shadow Error Memory-Shadow Error Memory (13),DTC_FR_ESP_23_SIGNAL_ERROR,
ENG27123-ENG32557,Shadow Error Memory-Shadow Error Memory (14),DTC_FR_ESP_21_SIGNAL_ERROR,
ENG27123-ENG32558,Shadow Error Memory-Shadow Error Memory (15),DTC_FR_ESP_08_SIGNAL_ERROR,
ENG27123-ENG32559,Shadow Error Memory-Shadow Error Memory (16),DTC_FR_ESP_21_SIGNAL_ERROR,
ENG27123-ENG32560,Shadow Error Memory-Shadow Error Memory (17),DTC_FR_ESP_22_SIGNAL_ERROR,
ENG27123-ENG32561,Shadow Error Memory-Shadow Error Memory (18),DTC_FR_ESP_23_SIGNAL_ERROR,
ENG27123-ENG32562,Shadow Error Memory-Shadow Error Memory (19),DTC_FR_ESP_22_SIGNAL_ERROR,
ENG27123-ENG32563,Shadow Error Memory-Shadow Error Memory (2),DTC_FR_TIMEOUT_SC,
ENG27123-ENG32564,Shadow Error Memory-Shadow Error Memory (20),DTC_FR_ESP_23_SIGNAL_ERROR,
ENG27123-ENG32565,Shadow Error Memory-Shadow Error Memory (21),DTC_FR_ESP_22_SIGNAL_ERROR,
ENG27123-ENG32566,Shadow Error Memory-Shadow Error Memory (22),DTC_FR_ESP_23_SIGNAL_ERROR,
ENG27123-ENG32567,Shadow Error Memory-Shadow Error Memory (23),DTC_FR_ESP_22_SIGNAL_ERROR,
ENG27123-ENG32568,Shadow Error Memory-Shadow Error Memory (24),DTC_FR_ESP_23_SIGNAL_ERROR,
ENG27123-ENG32569,Shadow Error Memory-Shadow Error Memory (25),DTC_FR_ESP_22_SIGNAL_ERROR,
ENG27123-ENG32570,Shadow Error Memory-Shadow Error Memory (26),DTC_FR_ESP_23_SIGNAL_ERROR,
ENG27123-ENG32571,Shadow Error Memory-Shadow Error Memory (27),DTC_FR_ESP_21_SIGNAL_ERROR,
ENG27123-ENG32572,Shadow Error Memory-Shadow Error Memory (28),DTC_FR_ESP_22_SIGNAL_ERROR,
ENG27123-ENG32573,Shadow Error Memory-Shadow Error Memory (29),DTC_FR_ESP_23_SIGNAL_ERROR,
ENG27123-ENG32574,Shadow Error Memory-Shadow Error Memory (3),DTC_FR_TIMEOUT_KOMBI,
ENG27123-ENG32575,Shadow Error Memory-Shadow Error Memory (30),DTC_FR_ESP_21_SIGNAL_ERROR,
ENG27123-ENG32576,Shadow Error Memory-Shadow Error Memory (31),DTC_FR_ESP_22_SIGNAL_ERROR,
ENG27123-ENG32577,Shadow Error Memory-Shadow Error Memory (32),DTC_FR_ESP_23_SIGNAL_ERROR,
ENG27123-ENG32578,Shadow Error Memory-Shadow Error Memory (33),DTC_FR_ESP_21_SIGNAL_ERROR,
ENG27123-ENG32579,Shadow Error Memory-Shadow Error Memory (34),DTC_FR_ESP_22_SIGNAL_ERROR,
ENG27123-ENG32580,Shadow Error Memory-Shadow Error Memory (35),DTC_FR_ESP_23_SIGNAL_ERROR,
ENG27123-ENG32581,Shadow Error Memory-Shadow Error Memory (36),DTC_FR_ESP_21_SIGNAL_ERROR,
ENG27123-ENG32582,Shadow Error Memory-Shadow Error Memory (37),DTC_FR_ESP_22_SIGNAL_ERROR,
ENG27123-ENG32583,Shadow Error Memory-Shadow Error Memory (38),DTC_FR_ESP_23_SIGNAL_ERROR,
ENG27123-ENG32584,Shadow Error Memory-Shadow Error Memory (39),DTC_FR_ESP_21_SIGNAL_ERROR,
ENG27123-ENG32585,Shadow Error Memory-Shadow Error Memory (4),DTC_FR_TIMEOUT_GETRIEBE,
ENG27123-ENG32586,Shadow Error Memory-Shadow Error Memory (40),DTC_FR_ESP_22_SIGNAL_ERROR,
ENG27123-ENG32587,Shadow Error Memory-Shadow Error Memory (41),DTC_FR_ESP_23_SIGNAL_ERROR,
ENG27123-ENG32588,Shadow Error Memory-Shadow Error Memory (42),DTC_PRODUCTION_MODE_ACTIVE,
ENG27123-ENG32589,Shadow Error Memory-Shadow Error Memory (43),DTC_FR_ESP_08_SIGNAL_ERROR,
ENG27123-ENG32590,Shadow Error Memory-Shadow Error Memory (44),DTC_PRODUCTION_MODE_ACTIVE,
ENG27123-ENG32591,Shadow Error Memory-Shadow Error Memory (45),DTC_DC_TOO_HIGH_DRAG_TORQUE,
ENG27123-ENG32592,Shadow Error Memory-Shadow Error Memory (46),DTC_FR_TIMEOUT_BCM2,
ENG27123-ENG32593,Shadow Error Memory-Shadow Error Memory (47),DTC_IGNITION_PLAUSIBILISATION,
ENG27123-ENG32594,Shadow Error Memory-Shadow Error Memory (48),DTC_DC_TOO_HIGH_DRAG_TORQUE,
ENG27123-ENG32595,Shadow Error Memory-Shadow Error Memory (49),DTC_SUPPLY_UNDERVOLTAGE,
ENG27123-ENG32596,Shadow Error Memory-Shadow Error Memory (5),DTC_FR_ESP_08_SIGNAL_ERROR,
ENG27123-ENG32597,Shadow Error Memory-Shadow Error Memory (50),DTC_PMSM_SUPPLY_FAST_OV,
ENG27123-ENG32598,Shadow Error Memory-Shadow Error Memory (6),DTC_FR_ESP_22_SIGNAL_ERROR,
ENG27123-ENG32599,Shadow Error Memory-Shadow Error Memory (7),DTC_FR_ESP_23_SIGNAL_ERROR,
ENG27123-ENG32600,Shadow Error Memory-Shadow Error Memory (8),DTC_FR_ESP_08_SIGNAL_ERROR,
ENG27123-ENG32601,Shadow Error Memory-Shadow Error Memory (9),DTC_FR_ESP_22_SIGNAL_ERROR,
ENG27128-ENG32651,Solenoid Current-SolenoidCurrent,0.0000, A
ENG27139-ENG30631,Status CC ECU Data-CMDBackupFCN,No Backup Function,
ENG27139-ENG30632,Status CC ECU Data-CMDBackupFCN 2,No Backup Function,
ENG27139-ENG36230,Status CC ECU Data-CNT Misuse Det Low,0,
ENG27139-ENG36232,Status CC ECU Data-Delta Phi Clutch,0.0, rad/ms
ENG27139-ENG36239,Status CC ECU Data-DLTNFrax2Rax,0.0, /min
ENG27139-ENG36250,Status CC ECU Data-I BLDC,0.0371093750000, A
ENG27139-ENG36267,Status CC ECU Data-Misuse Tmp Blade,52.7656250000000, °
ENG27139-ENG36268,Status CC ECU Data-Natr,0.000000000000, /min
ENG27139-ENG36269,Status CC ECU Data-NEngine,800.0, /min
ENG27139-ENG32133,Status CC ECU Data-NEngine QF,valid,
ENG27139-ENG36270,Status CC ECU Data-NFrax,0.0, /min
ENG27139-ENG36275,Status CC ECU Data-Phi Int,4.8,
ENG27139-ENG36276,Status CC ECU Data-PhiAtr,40.5000000000000, °
ENG27139-ENG36277,Status CC ECU Data-PRC Tmp Stress Clutch,0.0, %
ENG27139-ENG98891,Status CC ECU Data-Reserved,00,
ENG27139-ENG32709,Status CC ECU Data-St Misuse low temp active,0,
ENG27139-ENG32710,Status CC ECU Data-St Pt Engaged,0,
ENG27139-ENG32711,Status CC ECU Data-St Pt Engaged QF,valid,
ENG27139-ENG36299,Status CC ECU Data-Temp stDisc,51.9219, °C
ENG27139-ENG36301,Status CC ECU Data-Tmp Bridge,59.9375000000000, °
ENG27139-ENG36302,Status CC ECU Data-TRQ Break Drive Req,0, Nm
ENG27139-ENG33190,Status CC ECU Data-TRQ Break Drive Req QF,valid,
ENG27139-ENG36303,Status CC ECU Data-TRQ Misuse Set Point Max,660.00, Nm
ENG27139-ENG33227,Status CC ECU Data-Type Gearbox,1,
ENG27139-ENG28938,Status CC ECU Data-UBatt,14.172, V
ENG27139-ENG33230,Status CC ECU Data-UBLDC,0.000, V
ENG27139-ENG36307,Status CC ECU Data-V Front Min,0.0000000000000, km/h
ENG27139-ENG33259,Status CC ECU Data-V Front Min QF,valid,
ENG27139-ENG36311,Status CC ECU Data-Wear Oil Gain,15.9,
ENG27139-ENG36312,Status CC ECU Data-Wear Oil Offset,1.5,
ENG27139-ENG33365,Status CC ECU Data-Work clutch,70.190000, kWh
ENG27139-ENG33366,Status CC ECU Data-Work oil,25, kWh
ENG27139-ENG33367,Status CC ECU Data-Work Sync,0.400000, kWh
ENG27140-ENG30348,Status Daten Kupplung-Anzahl_Sollposition_Nicht_Erreicht_Abbau,0,
ENG27140-ENG30349,Status Daten Kupplung-Anzahl_Sollposition_Nicht_Erreicht_Aufbau,0,
ENG27140-ENG30633,Status Daten Kupplung-Cnt_CalNOK,108,
ENG27140-ENG30634,Status Daten Kupplung-Cnt_CalOK,247,
ENG27140-ENG30635,Status Daten Kupplung-Cnt_IBLDC_High,2, 10 ms
ENG27140-ENG30636,Status Daten Kupplung-Cnt_IBLDC_Low,0, 10 ms
ENG27140-ENG30637,Status Daten Kupplung-Cnt_IBLDC_Very_High,0, 10 ms
ENG27140-ENG30638,Status Daten Kupplung-Cnt_IBLDC_Very_Low,0, 10 ms
ENG27140-ENG30639,Status Daten Kupplung-Cnt_InitPos_OK,2074,
ENG27140-ENG30640,Status Daten Kupplung-Cnt_Misusedet_1,0,
ENG27140-ENG30641,Status Daten Kupplung-Cnt_Misusedet_2,0,
ENG27140-ENG30642,Status Daten Kupplung-Cnt_Misusedet_3,0,
ENG27140-ENG30643,Status Daten Kupplung-Cnt_Misusedet_4,0,
ENG27140-ENG36233,Status Daten Kupplung-Delta_Phi_Cal,25.1718750000000, °
ENG27140-ENG36234,Status Daten Kupplung-Delta_Phi_Cal_First,21.1406250000000, °
ENG27140-ENG36235,Status Daten Kupplung-Delta_Phi_Cal_Raw,25.2343750000000, °
ENG27140-ENG36240,Status Daten Kupplung-EOL_Delta_Phi_Cal_EOL,24.1875000000000, °
ENG27140-ENG31508,Status Daten Kupplung-Float_Const,0, Nm/A
ENG27140-ENG31893,Status Daten Kupplung-KMVehicle_Since_Oilchange,34678, km
ENG27140-ENG31994,Status Daten Kupplung-LT_Integrator_KM_TC,34678, km
ENG27140-ENG31995,Status Daten Kupplung-LT_Work_Clutch,70.180000, kWh
ENG27140-ENG31996,Status Daten Kupplung-LT_Work_Disc_1,1.060000, kWh
ENG27140-ENG31997,Status Daten Kupplung-LT_Work_Disc_2,0.580000, kWh
ENG27140-ENG31998,Status Daten Kupplung-LT_Work_Disc_3,0.030000, kWh
ENG27140-ENG32064,Status Daten Kupplung-Mile_KM,0, km
ENG27140-ENG32099,Status Daten Kupplung-Mom_Ueberglz_1,61234,
ENG27140-ENG32100,Status Daten Kupplung-Mom_Ueberglz_2,6730,
ENG27140-ENG32101,Status Daten Kupplung-Mom_Ueberglz_3,1,
ENG27140-ENG28629,Status Daten Kupplung-operation_time,0, ms
ENG27140-ENG98891,Status Daten Kupplung-Reserved,0,
ENG27140-ENG33143,Status Daten Kupplung-Time_Rel,0, s
ENG27140-ENG33328,Status Daten Kupplung-Vorhalt_1,0, s
ENG27140-ENG33329,Status Daten Kupplung-Vorhalt_2,0, s
ENG27140-ENG33330,Status Daten Kupplung-Vorhalt_3,0,
ENG27140-ENG33331,Status Daten Kupplung-Vorhalt_4,0, m
ENG27140-ENG33332,Status Daten Kupplung-Vorhalt_5,0,
ENG27140-ENG33333,Status Daten Kupplung-Vorhalt_6,0, m
ENG27140-ENG33334,Status Daten Kupplung-Vorhalt_7,0, m
ENG27140-ENG33368,Status Daten Kupplung-Work_Clutch,70.190000, kWh
ENG27140-ENG33369,Status Daten Kupplung-Work_Disc1,1.070000, kWh
ENG27140-ENG33370,Status Daten Kupplung-Work_Disc2,0.590000, kWh
ENG27140-ENG33371,Status Daten Kupplung-Work_Disc3,0.040000, kWh
ENG27140-ENG33372,Status Daten Kupplung-Work_Oil,25, kWh
ENG27140-ENG33373,Status Daten Kupplung-Work_Oil4Diag,25, kWh
ENG27140-ENG33374,Status Daten Kupplung-Work_Sync,0.400000, kWh
ENG27141-ENG30668,Status Disconnect-Counter Disconnect to Partial Connect 2,7889,
ENG27141-ENG30669,Status Disconnect-Counter Disconnect-Connect,5014,
ENG27141-ENG30670,Status Disconnect-Counter Partial Connect 1 to Connect,15,
ENG27141-ENG30671,Status Disconnect-Counter Partial Connect 1 to Parial Connect 2,6,
ENG27141-ENG30922,Status Disconnect-Distance Connect Overall,3658004, m
ENG27141-ENG30923,Status Disconnect-Distance Disconnect Overall,30667112, m
ENG27141-ENG36244,Status Disconnect-Faktor Correction High,1.3,
ENG27141-ENG36245,Status Disconnect-Faktor Correction Low,1.1,
ENG27141-ENG36246,Status Disconnect-Faktor Correction Middle,1.2,
ENG27141-ENG33140,Status Disconnect-Time Connect Overall,896875, s
ENG27141-ENG33141,Status Disconnect-Time Disconnect Overall,1393245, s
ENG27142-ENG33166,Status Histogramm Temp STDISC-TimeTemp_STDISC_0,26567, s
ENG27142-ENG33167,Status Histogramm Temp STDISC-TimeTemp_STDISC_1,812621, s
ENG27142-ENG33168,Status Histogramm Temp STDISC-TimeTemp_STDISC_10,0, s
ENG27142-ENG33169,Status Histogramm Temp STDISC-TimeTemp_STDISC_11,0, s
ENG27142-ENG33170,Status Histogramm Temp STDISC-TimeTemp_STDISC_2,1438614, s
ENG27142-ENG33171,Status Histogramm Temp STDISC-TimeTemp_STDISC_3,6, s
ENG27142-ENG33172,Status Histogramm Temp STDISC-TimeTemp_STDISC_4,0, s
ENG27142-ENG33173,Status Histogramm Temp STDISC-TimeTemp_STDISC_5,0, s
ENG27142-ENG33174,Status Histogramm Temp STDISC-TimeTemp_STDISC_6,0, s
ENG27142-ENG33175,Status Histogramm Temp STDISC-TimeTemp_STDISC_7,0, s
ENG27142-ENG33176,Status Histogramm Temp STDISC-TimeTemp_STDISC_8,0, s
ENG27142-ENG33177,Status Histogramm Temp STDISC-TimeTemp_STDISC_9,0, s
ENG27143-ENG33145,Status Histogramm Timetemp-TimeTemp_History_0,0, s
ENG27143-ENG33146,Status Histogramm Timetemp-TimeTemp_History_1,0, s
ENG27143-ENG33147,Status Histogramm Timetemp-TimeTemp_History_10,11310, s
ENG27143-ENG33148,Status Histogramm Timetemp-TimeTemp_History_11,0, s
ENG27143-ENG33149,Status Histogramm Timetemp-TimeTemp_History_12,0, s
ENG27143-ENG33150,Status Histogramm Timetemp-TimeTemp_History_13,0, s
ENG27143-ENG33151,Status Histogramm Timetemp-TimeTemp_History_14,0, s
ENG27143-ENG33152,Status Histogramm Timetemp-TimeTemp_History_15,0, s
ENG27143-ENG33153,Status Histogramm Timetemp-TimeTemp_History_16,0, s
ENG27143-ENG33154,Status Histogramm Timetemp-TimeTemp_History_17,0, s
ENG27143-ENG33155,Status Histogramm Timetemp-TimeTemp_History_18,0, s
ENG27143-ENG33156,Status Histogramm Timetemp-TimeTemp_History_19,0, s
ENG27143-ENG33157,Status Histogramm Timetemp-TimeTemp_History_2,754, s
ENG27143-ENG33158,Status Histogramm Timetemp-TimeTemp_History_20,0, s
ENG27143-ENG33159,Status Histogramm Timetemp-TimeTemp_History_3,5892, s
ENG27143-ENG33160,Status Histogramm Timetemp-TimeTemp_History_4,36832, s
ENG27143-ENG33161,Status Histogramm Timetemp-TimeTemp_History_5,109522, s
ENG27143-ENG33162,Status Histogramm Timetemp-TimeTemp_History_6,654404, s
ENG27143-ENG33163,Status Histogramm Timetemp-TimeTemp_History_7,833894, s
ENG27143-ENG33164,Status Histogramm Timetemp-TimeTemp_History_8,418752, s
ENG27143-ENG33165,Status Histogramm Timetemp-TimeTemp_History_9,217928, s
ENG27144-ENG33191,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_11_History,2290432, Ws
ENG27144-ENG33192,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_12_History,402605, Ws
ENG27144-ENG33193,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_13_History,3768, Ws
ENG27144-ENG33194,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_14_History,2, Ws
ENG27144-ENG33195,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_15_History,0, Ws
ENG27144-ENG33196,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_21_History,1067264, Ws
ENG27144-ENG33197,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_22_History,101338, Ws
ENG27144-ENG33198,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_23_History,299, Ws
ENG27144-ENG33199,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_24_History,0, Ws
ENG27144-ENG33200,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_25_History,0, Ws
ENG27144-ENG33201,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_31_History,1294944, Ws
ENG27144-ENG33202,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_32_History,182324, Ws
ENG27144-ENG33203,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_33_History,508, Ws
ENG27144-ENG33204,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_34_History,0, Ws
ENG27144-ENG33205,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_35_History,0, Ws
ENG27144-ENG33206,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_41_History,510771, Ws
ENG27144-ENG33207,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_42_History,162838, Ws
ENG27144-ENG33208,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_43_History,2562, Ws
ENG27144-ENG33209,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_44_History,0, Ws
ENG27144-ENG33210,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_45_History,0, Ws
ENG27144-ENG33211,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_51_History,4883, Ws
ENG27144-ENG33212,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_52_History,7674, Ws
ENG27144-ENG33213,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_53_History,0, Ws
ENG27144-ENG33214,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_54_History,0, Ws
ENG27144-ENG33215,Status Histogramm Trqdeltaphiclutch-TRQ_DeltaPhiClutch_55_History,0, Ws
ENG27145-ENG28501,Status Kalibrierung-Calibration,0,
ENG27145-ENG30633,Status Kalibrierung-Cnt_CalNOK,108,
ENG27145-ENG30634,Status Kalibrierung-Cnt_CalOK,247,
ENG27145-ENG36233,Status Kalibrierung-Delta_Phi_Cal,25.1718750000000, °
ENG27145-ENG36234,Status Kalibrierung-Delta_Phi_Cal_First,21.1406250000000, °
ENG27145-ENG36235,Status Kalibrierung-Delta_Phi_Cal_Raw,25.2343750000000, °
ENG27145-ENG36241,Status Kalibrierung-EOL_Erstkal,24.1875000000000, °
ENG27146-ENG31881,Status Kupplung Moment-IstMoment,0.25, Nm
ENG27146-ENG32405,Status Kupplung Moment-Qualifier_IstMoment,valid,
ENG27146-ENG32406,Status Kupplung Moment-Qualifier_SollMoment,Unknown (0),
ENG27146-ENG100868,Status Kupplung Moment-Sollmoment,1.00, Nm
ENG27147-ENG30267,Status NIA-Active BF,Cancel,
ENG27147-ENG30415,Status NIA-BLDC BD Status,7,
ENG27147-ENG30416,Status NIA-BLDC BD Status Bits,87,
ENG27147-ENG36224,Status NIA-BLDC RPS Winkel,3649, °
ENG27147-ENG36225,Status NIA-BLDC Strom,0.0000, A
ENG27147-ENG30962,Status NIA-ECU Overtemp Counter,0,
ENG27147-ENG31181,Status NIA-External Sensor,34996224,
ENG27147-ENG36242,Status NIA-External Sensor Signal,3.95117187500000, V
ENG27147-ENG36243,Status NIA-External Sensor Supply,4.99609375000000, V
ENG27147-ENG36247,Status NIA-HS Strom,0.0000, A
ENG27147-ENG31879,Status NIA-ISR WECT,24358,
ENG27147-ENG31880,Status NIA-ISR WEP,0,
ENG27147-ENG32501,Status NIA-RPS Status Bits,61343,
ENG27147-ENG32527,Status NIA-SBC Aufwach Grund,FLEXRAY_UP,
ENG27147-ENG32528,Status NIA-SBC Status Bits,418129284,
ENG27147-ENG36295,Status NIA-Temp Controller,61, °C
ENG27147-ENG36296,Status NIA-Temp NTC,59.9375000000000, °
ENG27147-ENG36297,Status NIA-Temp RPS,64, °C
ENG27147-ENG36298,Status NIA-Temp SBC,57, °C
ENG27147-ENG36304,Status NIA-UDC,14.19042968750000, V
ENG27147-ENG36305,Status NIA-UKl30,14.17285156250000, V
ENG27148-ENG30417,Status NIA Energy-BLDC Energy Cons IGN,12, Ws
ENG27148-ENG36223,Status NIA Energy-BLDC Energy Cons Lifetime,0.08617, kWh
ENG27148-ENG31831,Status NIA Energy-HSIDE Energy Cons IGN,0, Ws
ENG27148-ENG36248,Status NIA Energy-HSIDE Energy Cons Lifetime,2.19202, kWh
ENG27148-ENG31975,Status NIA Energy-Logic Energy Cons IGN,2193, Ws
ENG27148-ENG36266,Status NIA Energy-Logic Energy Cons Lifetime,0.98038, kWh
ENG27148-ENG36272,Status NIA Energy-Operation Time IGN,25.3833, m
ENG27148-ENG36273,Status NIA Energy-Operation Time Lifetime,680.61527777777781, H
ENG27149-ENG31844,Status NIA IEM-IEM Datafield 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG27149-ENG31845,Status NIA IEM-IEM Datafield 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG27149-ENG31846,Status NIA IEM-IEM Datafield 3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG27149-ENG31847,Status NIA IEM-IEM Datafield 4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG27150-ENG32113,Status NIA MST-MST Datafield 1,08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 00 08 08 08 08 08 08 08 08 08 08,
ENG27150-ENG32114,Status NIA MST-MST Datafield 2,08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08,
ENG27151-ENG36305,Status Spannung-UKl30,14.19921875000000, V
ENG27151-ENG36306,Status Spannung-UKL30_VPS,14.17285156250000, V
ENG27166-ENG30613,SW Klassierversion-ClassVersionSW,7,
ENG24960-ENG28264,System condition-System conditions,00 00,
ENG27184-ENG33144,Timeout PDU ID (FR_BCM2_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27185-ENG33144,Timeout PDU ID (FR_EFP_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27186-ENG33144,Timeout PDU ID (FR_EPS_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27187-ENG33144,Timeout PDU ID (FR_ESP_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27188-ENG33144,Timeout PDU ID (FR_GATEWAY_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27189-ENG33144,Timeout PDU ID (FR_GETRIEBE_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27190-ENG33144,Timeout PDU ID (FR_HAL_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27191-ENG33144,Timeout PDU ID (FR_HDSG_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27192-ENG33144,Timeout PDU ID (FR_KOMBI_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27193-ENG33144,Timeout PDU ID (FR_MOTOR_MLBEVO_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27194-ENG33144,Timeout PDU ID (FR_SAD_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27195-ENG33144,Timeout PDU ID (FR_SC_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27196-ENG33144,Timeout PDU ID (FR_SCU_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27197-ENG33144,Timeout PDU ID (FR_SMLS_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27198-ENG33144,Timeout PDU ID (FR_TSG_BT_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27199-ENG33144,Timeout PDU ID (FR_TSG_FS_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27200-ENG33144,Timeout PDU ID (FR_VSG_TIMEOUT)-Timeout PDU ID,Unknown (255),
ENG27284-ENG33340,Wakeup-Reason-Wakeup Reason,FLEXRAY_UP,
ENG27285-ENG30310,Wrong Coding Information-AFR_01,no problem,
ENG27285-ENG29928,Wrong Coding Information-Getriebe_11,no problem,
ENG27285-ENG57093,Wrong Coding Information-Getriebe_12,no problem,
ENG27285-ENG29929,Wrong Coding Information-Getriebe_13,no problem,
ENG27285-ENG29930,Wrong Coding Information-Getriebe_17,no problem,
ENG27285-ENG29931,Wrong Coding Information-HAL_01,no problem,
ENG27285-ENG32091,Wrong Coding Information-MO_Hybridfahrzeug not correctly,no problem,
ENG27285-ENG32135,Wrong Coding Information-no dynamic steering,no problem,
ENG27285-ENG32139,Wrong Coding Information-not diesel,no problem,
ENG27285-ENG32140,Wrong Coding Information-not DL,no problem,
ENG27285-ENG32141,Wrong Coding Information-not gasoline,no problem,
ENG27285-ENG32144,Wrong Coding Information-not ML,no problem,
ENG27285-ENG32145,Wrong Coding Information-not standard steering,no problem,
ENG27285-ENG101821,Wrong Coding Information-Not Used,no problem,
ENG27285-ENG32146,Wrong Coding Information-not used 2,no problem,
ENG27285-ENG110805,Wrong Coding Information-SCU_01,no problem,
Elapsed Time: 00:33
adpmap-22-80A-927-755
;Friday,12,July,2019,16:11:25:64285
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
IDE00820-ENG154874-Activating and deactivating all development messages-Activation_of_message_dev_allrad_00,not activated ,1
IDE00820-ENG154875-Activating and deactivating all development messages-Activation_of_message_dev_allrad_02,not activated ,1
IDE00820-ENG154876-Activating and deactivating all development messages-Activation_of_message_dev_x_03,not activated ,1
IDE00820-ENG154877-Activating and deactivating all development messages-Activation_of_message_dev_x_06,not activated ,1
IDE00820-ENG154878-Activating and deactivating all development messages-Activation_of_obd,not activated ,1
IDE00820-ENG154879-Activating and deactivating all development messages-Activation_of_xcp,not activated ,1
IDE03199-ENG101043-Dynamic calibration-Checksum,00 00 00 2B ,128
IDE03199-ENG154997-Dynamic calibration-Data Recovery (1),00 00 00 F0 38 0F C7 00 00 87 76 00 18 00 87 00 00 87 76 00 00 00 28 00 00 1B 6B 00 00 00 6B 00 00 00 3B 00 00 00 04 00 00 00 8E 00 00 00 00 00 00 1B ,128
IDE03199-ENG154998-Dynamic calibration-Data Recovery (2),6A 00 00 00 6A 00 00 00 3A 00 00 00 03 00 00 EF 32 00 00 1A 4A 00 00 00 01 00 02 00 00 00 02 00 00 00 07 00 04 00 01 00 00 00 00 00 00 00 00 00 00 00 ,128
IDE03199-ENG154999-Dynamic calibration-Data Recovery (3),00 00 00 00 00 F8 07 ,128
IDE03199-ENG99892-Dynamic calibration-VIN,WA1ANAFY9J2192916 ,128
IDE03339-ENG167401-Friction classes (customer service)-Class Gearbox,4039 ,3
IDE03339-ENG154974-Friction classes (customer service)-Class Version,7 ,3
IDE12421-ENG154921-Counter for center differential lock-ARG Set Full_Lock_Histogram_1,2 ,28
IDE12421-ENG154922-Counter for center differential lock-ARG Set Full_Lock_Histogram_10,0 ,28
IDE12421-ENG154923-Counter for center differential lock-ARG Set Full_Lock_Histogram_11,0 ,28
IDE12421-ENG154924-Counter for center differential lock-ARG Set Full_Lock_Histogram_12,0 ,28
IDE12421-ENG154925-Counter for center differential lock-ARG Set Full_Lock_Histogram_13,0 ,28
IDE12421-ENG154926-Counter for center differential lock-ARG Set Full_Lock_Histogram_14,0 ,28
IDE12421-ENG154927-Counter for center differential lock-ARG Set Full_Lock_Histogram_2,0 ,28
IDE12421-ENG154928-Counter for center differential lock-ARG Set Full_Lock_Histogram_3,2 ,28
IDE12421-ENG154929-Counter for center differential lock-ARG Set Full_Lock_Histogram_4,0 ,28
IDE12421-ENG154930-Counter for center differential lock-ARG Set Full_Lock_Histogram_5,7 ,28
IDE12421-ENG154931-Counter for center differential lock-ARG Set Full_Lock_Histogram_6,4 ,28
IDE12421-ENG154932-Counter for center differential lock-ARG Set Full_Lock_Histogram_7,1 ,28
IDE12421-ENG154933-Counter for center differential lock-ARG Set Full_Lock_Histogram_8,0 ,28
IDE12421-ENG154934-Counter for center differential lock-ARG Set Full_Lock_Histogram_9,0 ,28
IDE12446-MAS06099-All Wheel Drive acoustics-Acoustic measure: anti droning,No measure ,4
IDE12446-MAS06100-All Wheel Drive acoustics-Acoustic measure: anti impact wrench,No measure ,4
IDE12446-MAS07124-All Wheel Drive acoustics-Lower speed threshold,75 km/h ,4
IDE12446-MAS14475-All Wheel Drive acoustics-Lowest gear,9 ,4
MAS09595-ENG155365-Production mode-not used Bit 0,not active ,3
MAS09595-ENG155366-Production mode-not used Bit 10,not active ,3
MAS09595-ENG155367-Production mode-not used Bit 11,not active ,3
MAS09595-ENG155368-Production mode-not used Bit 13,not active ,3
MAS09595-ENG155369-Production mode-not used Bit 14,not active ,3
MAS09595-ENG155370-Production mode-not used Bit 15,not active ,3
MAS09595-ENG155371-Production mode-not used Bit 16,not active ,3
MAS09595-ENG155372-Production mode-not used Bit 17,not active ,3
MAS09595-ENG155373-Production mode-not used Bit 18,not active ,3
MAS09595-ENG155374-Production mode-not used Bit 19,not active ,3
MAS09595-ENG155375-Production mode-not used Bit 20,not active ,3
MAS09595-ENG155376-Production mode-not used Bit 21,not active ,3
MAS09595-ENG155377-Production mode-not used Bit 22,not active ,3
MAS09595-ENG155378-Production mode-not used Bit 23,not active ,3
MAS09595-ENG155379-Production mode-not used Bit 3,not active ,3
MAS09595-ENG155380-Production mode-not used Bit 4,not active ,3
MAS09595-ENG155381-Production mode-not used Bit 5,not active ,3
MAS09595-ENG155382-Production mode-not used Bit 6,not active ,3
MAS09595-ENG155383-Production mode-not used Bit 7,not active ,3
MAS09595-ENG155384-Production mode-not used Bit 8,not active ,3
MAS09595-ENG155385-Production mode-not used Bit 9,not active ,3
MAS09595-ENG155568-Production mode-Permanent 2WD,not active ,3
MAS09595-ENG155924-Production mode-Suppress Shutdown Calibration,not active ,3
MAS09595-ENG155990-Production mode-UDS additional physical services,not active ,3
ENG153960-Steuern Deactivate FullLock,Not Used ,1
Elapsed Time: 00:06
blockmap-29-80A-907-397-A
;SW:80A-907-397-A   HW:80A-907-397-A ---  Left Light
;Component:LCM_MLBevo    H07 0022, Coding:
;EV_LCMLeftCONTIAU426,001009,EV_LCMLeftCONTIAU426_VW41.rod
;Friday,12,July,2019,16:11:34:64285
;VCID: AD1D0AF4FCEAA32782-80F8
Group,Description,Actual
IDE00767-MAS01478,No. of unscheduled ECU resets-Insuff. voltage,78,
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,15,
IDE03680-MAS01468,Supply voltages-Terminal 15,Not available,
IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,14.00, V
IDE06876-MAS01482,Signature light bulb-Hardwareversion,not installed,
IDE06876-MAS01483,Signature light bulb-Softwareversion,not installed,
IDE06876-MAS12381,Signature light bulb-Software subversion,0F,
IDE06876-ENG14244,Signature light bulb-Software_sub_version_Textual,Not available,
IDE06926-IDE02068,History memory: reset counter-Time stamp,78 FB D8 4D 00,
IDE06926-MAS09176,History memory: reset counter-Reset reason,Insuff. voltage,
IDE08742-MAS01155,Operating time-Control module,697.32, H
IDE08742-MAS03835,Operating time-Parking light,272.32, H
IDE08742-MAS09325,Operating time-Daytime running lights,358.44, H
IDE08742-MAS09330,Operating time-Cover for low beam headlight,1.93, H
IDE08742-MAS09332,Operating time-Turn signal,16.21, H
IDE08742-MAS09333,Operating time-Side-marker light,272.32, H
IDE08742-MAS09334,Operating time-Parking light,0.00, H
IDE09492-MAS01155,Temperatures-Control module,86.00, °C
IDE09492-MAS09339,Temperatures-extern. temperature sensor 1,89.00, °C
IDE09492-MAS09340,Temperatures-extern. temperature sensor 2,not installed,
IDE09768-MAS04121,LED channel 1-Voltage,9.14, V
IDE09768-MAS04136,LED channel 1-Current,1000, mA
IDE09768-MAS09022,LED channel 1-PWM value,88.50, %
IDE09768-MAS09327,LED channel 1-LED brightness class,1,
IDE09768-MAS09328,LED channel 1-Primary function,Daytime running lights,
IDE09768-MAS09329,LED channel 1-Secondary function,Daytime running lights,
IDE09769-MAS04121,LED channel 2-Voltage,0.00, V
IDE09769-MAS04136,LED channel 2-Current,0, mA
IDE09769-MAS09022,LED channel 2-PWM value,0.00, %
IDE09769-MAS09327,LED channel 2-LED brightness class,ERROR,
IDE09769-MAS09328,LED channel 2-Primary function,no function,
IDE09769-MAS09329,LED channel 2-Secondary function,no function,
IDE09770-MAS04136,High side channel 1-Current,0, mA
IDE09770-MAS09022,High side channel 1-PWM value,0.00, %
IDE09770-MAS09326,High side channel 1-Function,Turn signal,
IDE09771-MAS04136,High side channel 2-Current,0, mA
IDE09771-MAS09022,High side channel 2-PWM value,0.00, %
IDE09771-MAS09326,High side channel 2-Function,Cover for low beam headlight,
IDE09772-MAS04136,High side channel 3-Current,0, mA
IDE09772-MAS09022,High side channel 3-PWM value,0.00, %
IDE09772-MAS09326,High side channel 3-Function,Side-marker light,
IDE09774-MAS03835,Number of activations-Parking light,1575,
IDE09774-MAS09325,Number of activations-Daytime running lights,6494,
IDE09774-MAS09330,Number of activations-Cover for low beam headlight,281,
IDE09774-MAS09332,Number of activations-Turn signal,143900,
IDE09774-MAS09333,Number of activations-Side-marker light,1575,
IDE09774-MAS09334,Number of activations-Parking light,0,
IDE09775-MAS09336,High temperature operating times for control unit-°C,95.94, H
IDE09775-MAS09337,High temperature operating times for control unit-between 105°C and 115°C,63.10, H
IDE09775-MAS09338,High temperature operating times for control unit-over 115°C,52.73, H
IDE09795-MAS09342,Operating times for motor of headlight range adjustment-between 0% and 30%,0.00, %
IDE09795-MAS09343,Operating times for motor of headlight range adjustment-between 30% and 60%,0.00, %
IDE09795-MAS09344,Operating times for motor of headlight range adjustment-over 60%,0.00, %
IDE09828-MAS00890,Head lamp variant-via CAN,E0 3D,
IDE09828-MAS01155,Head lamp variant-Control module,E0 3D,
IDE09916-MAS09563,Data set names-Number of data set names,01,
IDE09916-MAS09564,Data set names-Data set ID,28929,
IDE09916-MAS09565,Data set names-Data set name,Q5NFXENSWSAE,
IDE10175,Capturing statistic data: status,active,
IDE10301-MAS01155,Number of excess temp. protection activations-Control module,0,
IDE10301-MAS03835,Number of excess temp. protection activations-Parking light,7,
IDE10301-MAS09325,Number of excess temp. protection activations-Daytime running lights,255,
IDE10301-MAS09332,Number of excess temp. protection activations-Turn signal,0,
IDE11124-MAS12195,Headlight beam adjusting motor-Reference run status,not performed,
IDE11124-MAS12196,Headlight beam adjusting motor-Fault position,not approached,
IDE11124-MAS12199,Headlight beam adjusting motor-Adjustment speed,normal,
IDE11124-MAS12206,Headlight beam adjusting motor-Motor position (percent of max. adjustment stroke),0.00, %
IDE11124-MAS12207,Headlight beam adjusting motor-Low beam inclination,-607.00, mm
IDE11125-MAS12195,Dynamic cornering light adjusting motor-Reference run status,not performed,
IDE11125-MAS12196,Dynamic cornering light adjusting motor-Fault position,not approached,
IDE11125-MAS12199,Dynamic cornering light adjusting motor-Adjustment speed,normal,
IDE11125-MAS12206,Dynamic cornering light adjusting motor-Motor position (percent of max. adjustment stroke),0.00, %
IDE11125-MAS12209,Dynamic cornering light adjusting motor-Swivel angle,Unknown,
IDE11276-MAS01482,Power output stage for headlamp aux. functions-Hardwareversion,not installed,
IDE11276-MAS01483,Power output stage for headlamp aux. functions-Softwareversion,not installed,
IDE11276-MAS12381,Power output stage for headlamp aux. functions-Software subversion,0F,
IDE11276-ENG14244,Power output stage for headlamp aux. functions-Software_sub_version_Textual,Not available,
IDE11347-MAS12195,Variable headlamp positioning motor-Reference run status,not performed,
IDE11347-MAS12196,Variable headlamp positioning motor-Fault position,not approached,
IDE11347-MAS12199,Variable headlamp positioning motor-Adjustment speed,normal,
IDE11347-MAS12212,Variable headlamp positioning motor-Calibrated light index setting,Unknown,
Elapsed Time: 00:03
adpmap-29-80A-907-397-A
;Friday,12,July,2019,16:11:37:64285
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not activated ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not activated ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not activated ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not activated ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not activated ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not activated ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not activated ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not activated ,1
IDE01550-Service position,not active ,1
Elapsed Time: 00:01
blockmap-36-4M1-959-760
;SW:4M1-959-760   HW:4M1-959-760 ---  Seat Mem. Drvr
;Component:MEM-FS        008 0031, Coding:005C1B000000B0010000010101010000000000000000000000000000000000
;EV_SCMDriveSideCONTIAU736,006009,EV_SCMDriveSideCONTIAU736_AU49.rod
;Friday,12,July,2019,16:11:41:64285
;VCID: F6AFE598493CA0FF33-80A2
IDE00019-MAS00043,Voltage terminal 30-Supply voltage: Terminal 30,14.20, V
IDE00102,Control Module temperature,49,
IDE00787,Cause for cancellation,none,
IDE01277-IDE09268,Counter of compressor activations-Switch on occurrences of compressor,0, counts
IDE01277-MAS06166,Counter of compressor activations-Current operation time,0, s
IDE01457,Energy management deactivation stage,Deactivation stage 0,
IDE05738-MAS12801,Subssystem diagnosis classes-DK0 systems supported,DK0 systems not supported,
IDE05738-MAS12803,Subssystem diagnosis classes-DK1 systems supported,DK1 systems not supported,
IDE05738-MAS12805,Subssystem diagnosis classes-DK2/DK2F systems supported,DK2/DK2F systems not supported,
IDE05738-MAS12807,Subssystem diagnosis classes-DK3 or DK4 high/low systems supported,DK3 or DK4 high/low systems not supported,
IDE06510-MAS01390,Backrest inclination adjustment-Block 1,34348,
IDE06510-MAS01391,Backrest inclination adjustment-Block 2,32765,
IDE06510-MAS02282,Backrest inclination adjustment-Position,33026,
IDE06510-MAS02955,Backrest inclination adjustment-Engine temperature,25, °C
IDE06510-MAS03129,Backrest inclination adjustment-Reset counter,250,
IDE06510-MAS04160,Backrest inclination adjustment-Load change,742,
IDE06510-MAS04337,Backrest inclination adjustment-Engine current,0, A
IDE06510-MAS05370,Backrest inclination adjustment-Direction of movement,not activated,
IDE06510-MAS05563,Backrest inclination adjustment-Norming,normed,
IDE06510-MAS05719,Backrest inclination adjustment-Maximum travel,1583,
IDE06510-MAS12838,Backrest inclination adjustment-Standardization flag,normed,
IDE06511-MAS01390,Seat height adjustment-Block 1,33334,
IDE06511-MAS01391,Seat height adjustment-Block 2,32751,
IDE06511-MAS02282,Seat height adjustment-Position,33180,
IDE06511-MAS02955,Seat height adjustment-Engine temperature,25, °C
IDE06511-MAS03129,Seat height adjustment-Reset counter,19,
IDE06511-MAS04160,Seat height adjustment-Load change,619,
IDE06511-MAS04337,Seat height adjustment-Engine current,0, A
IDE06511-MAS05370,Seat height adjustment-Direction of movement,not activated,
IDE06511-MAS05563,Seat height adjustment-Norming,normed,
IDE06511-MAS05719,Seat height adjustment-Maximum travel,583,
IDE06511-MAS12838,Seat height adjustment-Standardization flag,normed,
IDE06512-MAS01390,Seat forward/back position adjustment-Block 1,33472,
IDE06512-MAS01391,Seat forward/back position adjustment-Block 2,32758,
IDE06512-MAS02282,Seat forward/back position adjustment-Position,33461,
IDE06512-MAS02955,Seat forward/back position adjustment-Engine temperature,25, °C
IDE06512-MAS03129,Seat forward/back position adjustment-Reset counter,10,
IDE06512-MAS04160,Seat forward/back position adjustment-Load change,1249,
IDE06512-MAS04337,Seat forward/back position adjustment-Engine current,0, A
IDE06512-MAS05370,Seat forward/back position adjustment-Direction of movement,not activated,
IDE06512-MAS05563,Seat forward/back position adjustment-Norming,normed,
IDE06512-MAS05719,Seat forward/back position adjustment-Maximum travel,714,
IDE06512-MAS12838,Seat forward/back position adjustment-Standardization flag,normed,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not active,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not active,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not active,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not active,
IDE06614-MAS01601,Memory seat adjustment control head-save,not active,
IDE06683-MAS01390,Seat inclination adjustment-Block 1,32798,
IDE06683-MAS01391,Seat inclination adjustment-Block 2,32551,
IDE06683-MAS02282,Seat inclination adjustment-Position,32708,
IDE06683-MAS02955,Seat inclination adjustment-Engine temperature,25, °C
IDE06683-MAS03129,Seat inclination adjustment-Reset counter,14,
IDE06683-MAS04160,Seat inclination adjustment-Load change,554,
IDE06683-MAS04337,Seat inclination adjustment-Engine current,0, A
IDE06683-MAS05370,Seat inclination adjustment-Direction of movement,not activated,
IDE06683-MAS05563,Seat inclination adjustment-Norming,normed,
IDE06683-MAS05719,Seat inclination adjustment-Maximum travel,247,
IDE06683-MAS12838,Seat inclination adjustment-Standardization flag,normed,
IDE06684-MAS01390,Lumbar support height adjustment-Block 1,0,
IDE06684-MAS01391,Lumbar support height adjustment-Block 2,0,
IDE06684-MAS02282,Lumbar support height adjustment-Position,0,
IDE06684-MAS02955,Lumbar support height adjustment-Engine temperature,0, °C
IDE06684-MAS03129,Lumbar support height adjustment-Reset counter,0,
IDE06684-MAS04160,Lumbar support height adjustment-Load change,0,
IDE06684-MAS04337,Lumbar support height adjustment-Engine current,0, A
IDE06684-MAS05370,Lumbar support height adjustment-Direction of movement,not activated,
IDE06684-MAS05563,Lumbar support height adjustment-Norming,not normed,
IDE06684-MAS05719,Lumbar support height adjustment-Maximum travel,0,
IDE06684-MAS12838,Lumbar support height adjustment-Standardization flag,never normed,
IDE06685-MAS01390,Lumbar support longitudinal position adjustment-Block 1,0,
IDE06685-MAS01391,Lumbar support longitudinal position adjustment-Block 2,0,
IDE06685-MAS02282,Lumbar support longitudinal position adjustment-Position,0,
IDE06685-MAS02955,Lumbar support longitudinal position adjustment-Engine temperature,0, °C
IDE06685-MAS03129,Lumbar support longitudinal position adjustment-Reset counter,0,
IDE06685-MAS04160,Lumbar support longitudinal position adjustment-Load change,0,
IDE06685-MAS04337,Lumbar support longitudinal position adjustment-Engine current,0, A
IDE06685-MAS05370,Lumbar support longitudinal position adjustment-Direction of movement,not activated,
IDE06685-MAS05563,Lumbar support longitudinal position adjustment-Norming,not normed,
IDE06685-MAS05719,Lumbar support longitudinal position adjustment-Maximum travel,0,
IDE06685-MAS12838,Lumbar support longitudinal position adjustment-Standardization flag,never normed,
IDE06871-IDE06510,Seat adjustment control head-Backrest inclination adjustment,not activated,
IDE06871-IDE06511,Seat adjustment control head-Seat height adjustment,not activated,
IDE06871-IDE06512,Seat adjustment control head-Seat forward/back position adjustment,not activated,
IDE06871-IDE06683,Seat adjustment control head-Seat inclination adjustment,not activated,
IDE06871-IDE06684,Seat adjustment control head-Lumbar support height adjustment,not activated,
IDE06871-IDE06685,Seat adjustment control head-Lumbar support longitudinal position adjustment,not activated,
IDE06871-IDE08989,Seat adjustment control head-Seat depth adjustment,not activated,
IDE06871-IDE08990,Seat adjustment control head-Backrest top adjustment,not activated,
IDE06871-IDE08991,Seat adjustment control head-Belt height adjustment,not activated,
IDE06871-IDE11024,Seat adjustment control head-Headrest height adjustment,not activated,
IDE06871-IDE11025,Seat adjustment control head-Headrest length adjustment,not activated,
IDE07159,Control module switch-off: counter,0,
IDE07347-IDE06510,Memory setting 1 for seat adjustment-Backrest inclination adjustment,33223,
IDE07347-IDE06511,Memory setting 1 for seat adjustment-Seat height adjustment,33213,
IDE07347-IDE06512,Memory setting 1 for seat adjustment-Seat forward/back position adjustment,33161,
IDE07347-IDE06683,Memory setting 1 for seat adjustment-Seat inclination adjustment,32653,
IDE07347-IDE06684,Memory setting 1 for seat adjustment-Lumbar support height adjustment,0,
IDE07347-IDE06685,Memory setting 1 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07347-IDE08989,Memory setting 1 for seat adjustment-Seat depth adjustment,0,
IDE07347-IDE08990,Memory setting 1 for seat adjustment-Backrest top adjustment,0,
IDE07347-IDE08991,Memory setting 1 for seat adjustment-Belt height adjustment,0,
IDE07347-IDE11024,Memory setting 1 for seat adjustment-Headrest height adjustment,0,
IDE07348-IDE06510,Memory setting 2 for seat adjustment-Backrest inclination adjustment,33192,
IDE07348-IDE06511,Memory setting 2 for seat adjustment-Seat height adjustment,32931,
IDE07348-IDE06512,Memory setting 2 for seat adjustment-Seat forward/back position adjustment,32854,
IDE07348-IDE06683,Memory setting 2 for seat adjustment-Seat inclination adjustment,32596,
IDE07348-IDE06684,Memory setting 2 for seat adjustment-Lumbar support height adjustment,0,
IDE07348-IDE06685,Memory setting 2 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07348-IDE08989,Memory setting 2 for seat adjustment-Seat depth adjustment,0,
IDE07348-IDE08990,Memory setting 2 for seat adjustment-Backrest top adjustment,0,
IDE07348-IDE08991,Memory setting 2 for seat adjustment-Belt height adjustment,0,
IDE07348-IDE11024,Memory setting 2 for seat adjustment-Headrest height adjustment,0,
IDE07349-IDE06510,Memory setting 3 for seat adjustment-Backrest inclination adjustment,0,
IDE07349-IDE06511,Memory setting 3 for seat adjustment-Seat height adjustment,0,
IDE07349-IDE06512,Memory setting 3 for seat adjustment-Seat forward/back position adjustment,0,
IDE07349-IDE06683,Memory setting 3 for seat adjustment-Seat inclination adjustment,0,
IDE07349-IDE06684,Memory setting 3 for seat adjustment-Lumbar support height adjustment,0,
IDE07349-IDE06685,Memory setting 3 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07349-IDE08989,Memory setting 3 for seat adjustment-Seat depth adjustment,0,
IDE07349-IDE08990,Memory setting 3 for seat adjustment-Backrest top adjustment,0,
IDE07349-IDE08991,Memory setting 3 for seat adjustment-Belt height adjustment,0,
IDE07349-IDE11024,Memory setting 3 for seat adjustment-Headrest height adjustment,0,
IDE07350-IDE06510,Memory setting 4 for seat adjustment-Backrest inclination adjustment,0,
IDE07350-IDE06511,Memory setting 4 for seat adjustment-Seat height adjustment,0,
IDE07350-IDE06512,Memory setting 4 for seat adjustment-Seat forward/back position adjustment,0,
IDE07350-IDE06683,Memory setting 4 for seat adjustment-Seat inclination adjustment,0,
IDE07350-IDE06684,Memory setting 4 for seat adjustment-Lumbar support height adjustment,0,
IDE07350-IDE06685,Memory setting 4 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07350-IDE08989,Memory setting 4 for seat adjustment-Seat depth adjustment,0,
IDE07350-IDE08990,Memory setting 4 for seat adjustment-Backrest top adjustment,0,
IDE07350-IDE08991,Memory setting 4 for seat adjustment-Belt height adjustment,0,
IDE07350-IDE11024,Memory setting 4 for seat adjustment-Headrest height adjustment,0,
IDE07351-IDE06510,Memory setting 1: remote master key for seat adjustment-Backrest inclination adjustment,0,
IDE07351-IDE06511,Memory setting 1: remote master key for seat adjustment-Seat height adjustment,0,
IDE07351-IDE06512,Memory setting 1: remote master key for seat adjustment-Seat forward/back position adjustment,0,
IDE07351-IDE06683,Memory setting 1: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07351-IDE06684,Memory setting 1: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07351-IDE06685,Memory setting 1: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07351-IDE08989,Memory setting 1: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07351-IDE08990,Memory setting 1: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07351-IDE08991,Memory setting 1: remote master key for seat adjustment-Belt height adjustment,0,
IDE07351-IDE11024,Memory setting 1: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07352-IDE06510,Memory setting 2: remote master key for seat adjustment-Backrest inclination adjustment,33025,
IDE07352-IDE06511,Memory setting 2: remote master key for seat adjustment-Seat height adjustment,33180,
IDE07352-IDE06512,Memory setting 2: remote master key for seat adjustment-Seat forward/back position adjustment,33461,
IDE07352-IDE06683,Memory setting 2: remote master key for seat adjustment-Seat inclination adjustment,32708,
IDE07352-IDE06684,Memory setting 2: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07352-IDE06685,Memory setting 2: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07352-IDE08989,Memory setting 2: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07352-IDE08990,Memory setting 2: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07352-IDE08991,Memory setting 2: remote master key for seat adjustment-Belt height adjustment,0,
IDE07352-IDE11024,Memory setting 2: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07353-IDE06510,Memory setting 3: remote master key for seat adjustment-Backrest inclination adjustment,0,
IDE07353-IDE06511,Memory setting 3: remote master key for seat adjustment-Seat height adjustment,0,
IDE07353-IDE06512,Memory setting 3: remote master key for seat adjustment-Seat forward/back position adjustment,0,
IDE07353-IDE06683,Memory setting 3: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07353-IDE06684,Memory setting 3: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07353-IDE06685,Memory setting 3: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07353-IDE08989,Memory setting 3: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07353-IDE08990,Memory setting 3: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07353-IDE08991,Memory setting 3: remote master key for seat adjustment-Belt height adjustment,0,
IDE07353-IDE11024,Memory setting 3: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07354-IDE06510,Memory setting 4: remote master key for seat adjustment-Backrest inclination adjustment,0,
IDE07354-IDE06511,Memory setting 4: remote master key for seat adjustment-Seat height adjustment,0,
IDE07354-IDE06512,Memory setting 4: remote master key for seat adjustment-Seat forward/back position adjustment,0,
IDE07354-IDE06683,Memory setting 4: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07354-IDE06684,Memory setting 4: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07354-IDE06685,Memory setting 4: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07354-IDE08989,Memory setting 4: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07354-IDE08990,Memory setting 4: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07354-IDE08991,Memory setting 4: remote master key for seat adjustment-Belt height adjustment,0,
IDE07354-IDE11024,Memory setting 4: remote master key for seat adjustment-Headrest height adjustment,0,
IDE08989-MAS01390,Seat depth adjustment-Block 1,0,
IDE08989-MAS01391,Seat depth adjustment-Block 2,0,
IDE08989-MAS02282,Seat depth adjustment-Position,0,
IDE08989-MAS02955,Seat depth adjustment-Engine temperature,0, °C
IDE08989-MAS03129,Seat depth adjustment-Reset counter,0,
IDE08989-MAS04160,Seat depth adjustment-Load change,0,
IDE08989-MAS04337,Seat depth adjustment-Engine current,0, A
IDE08989-MAS05370,Seat depth adjustment-Direction of movement,not activated,
IDE08989-MAS05563,Seat depth adjustment-Norming,not normed,
IDE08989-MAS05719,Seat depth adjustment-Maximum travel,0,
IDE08989-MAS12838,Seat depth adjustment-Standardization flag,never normed,
IDE08990-MAS01390,Backrest top adjustment-Block 1,0,
IDE08990-MAS01391,Backrest top adjustment-Block 2,0,
IDE08990-MAS02282,Backrest top adjustment-Position,0,
IDE08990-MAS02955,Backrest top adjustment-Engine temperature,0, °C
IDE08990-MAS03129,Backrest top adjustment-Reset counter,0,
IDE08990-MAS04160,Backrest top adjustment-Load change,0,
IDE08990-MAS04337,Backrest top adjustment-Engine current,0, A
IDE08990-MAS05370,Backrest top adjustment-Direction of movement,not activated,
IDE08990-MAS05563,Backrest top adjustment-Norming,not normed,
IDE08990-MAS05719,Backrest top adjustment-Maximum travel,0,
IDE08990-MAS12838,Backrest top adjustment-Standardization flag,never normed,
IDE08991-MAS01390,Belt height adjustment-Block 1,0,
IDE08991-MAS01391,Belt height adjustment-Block 2,0,
IDE08991-MAS02282,Belt height adjustment-Position,0,
IDE08991-MAS02955,Belt height adjustment-Engine temperature,0, °C
IDE08991-MAS03129,Belt height adjustment-Reset counter,0,
IDE08991-MAS04160,Belt height adjustment-Load change,0,
IDE08991-MAS04337,Belt height adjustment-Engine current,0, A
IDE08991-MAS05370,Belt height adjustment-Direction of movement,not activated,
IDE08991-MAS05563,Belt height adjustment-Norming,not normed,
IDE08991-MAS05719,Belt height adjustment-Maximum travel,0,
IDE08991-MAS12838,Belt height adjustment-Standardization flag,never normed,
IDE09081-MAS08291,Seat switch module-Plate: vertical actuation direction,not activated,
IDE09081-MAS08292,Seat switch module-Plate: horizontal actuation direction,not activated,
IDE09081-MAS08293,Seat switch module-Rocker,not activated,
IDE09082,Massage button,not activated,
IDE09083-MAS08294,Entry assistance button-Entry assistance button: actuation direction forward,not activated,
IDE09083-MAS08295,Entry assistance button-Entry assistance button: actuation direction backward,not activated,
IDE09084-MAS08296,Backrest lock switch-Switch state normally closed,operated,
IDE09084-MAS08297,Backrest lock switch-Switch state normally open,not activated,
IDE09085,Backrest limit switch,not activated,
IDE10995-IDE06510,Calibrating the motors: status-Backrest inclination adjustment,normed,
IDE10995-IDE06511,Calibrating the motors: status-Seat height adjustment,normed,
IDE10995-IDE06512,Calibrating the motors: status-Seat forward/back position adjustment,normed,
IDE10995-IDE06683,Calibrating the motors: status-Seat inclination adjustment,normed,
IDE10995-IDE06684,Calibrating the motors: status-Lumbar support height adjustment,not normed,
IDE10995-IDE06685,Calibrating the motors: status-Lumbar support longitudinal position adjustment,not normed,
IDE10995-IDE08989,Calibrating the motors: status-Seat depth adjustment,not normed,
IDE10995-IDE08990,Calibrating the motors: status-Backrest top adjustment,not normed,
IDE10995-IDE08991,Calibrating the motors: status-Belt height adjustment,not normed,
IDE10995-MAS11869,Calibrating the motors: status-Headrest adjustment: horizontal,not normed,
IDE10995-MAS11890,Calibrating the motors: status-Headrest adjustment: vertical,not normed,
IDE10996-MAS11891,Excessive force limit: status-Seat forward/back position adjustment: forwards,Not adapted,
IDE10996-MAS11892,Excessive force limit: status-Seat forward/back position adjustment: backwards,Not adapted,
IDE10996-MAS11895,Excessive force limit: status-Backrest inclination adjustment: forwards,Not adapted,
IDE10996-MAS11896,Excessive force limit: status-Backrest inclination adjustment: backwards,Not adapted,
IDE10996-MAS11959,Excessive force limit: status-Seat height adjustment higher,Not adapted,
IDE10996-MAS11960,Excessive force limit: status-Seat height adjustment lower,Not adapted,
IDE11024-MAS01390,Headrest height adjustment-Block 1,0,
IDE11024-MAS01391,Headrest height adjustment-Block 2,0,
IDE11024-MAS02282,Headrest height adjustment-Position,0,
IDE11024-MAS02955,Headrest height adjustment-Engine temperature,0, °C
IDE11024-MAS03129,Headrest height adjustment-Reset counter,0,
IDE11024-MAS04160,Headrest height adjustment-Load change,0,
IDE11024-MAS04337,Headrest height adjustment-Engine current,0, A
IDE11024-MAS05370,Headrest height adjustment-Direction of movement,not activated,
IDE11024-MAS05563,Headrest height adjustment-Norming,not normed,
IDE11024-MAS05719,Headrest height adjustment-Maximum travel,0,
IDE11024-MAS12838,Headrest height adjustment-Standardization flag,never normed,
IDE11025-MAS01390,Headrest length adjustment-Block 1,0,
IDE11025-MAS01391,Headrest length adjustment-Block 2,0,
IDE11025-MAS02282,Headrest length adjustment-Position,0,
IDE11025-MAS02955,Headrest length adjustment-Engine temperature,0, °C
IDE11025-MAS03129,Headrest length adjustment-Reset counter,0,
IDE11025-MAS04160,Headrest length adjustment-Load change,0,
IDE11025-MAS04337,Headrest length adjustment-Engine current,0, A
IDE11025-MAS05370,Headrest length adjustment-Direction of movement,not activated,
IDE11025-MAS05563,Headrest length adjustment-Norming,not normed,
IDE11025-MAS05719,Headrest length adjustment-Maximum travel,0,
IDE11025-MAS12838,Headrest length adjustment-Standardization flag,never normed,
IDE11957-MAS01390,Display unit adjustment-Block 1,0,
IDE11957-MAS01391,Display unit adjustment-Block 2,0,
IDE11957-MAS02282,Display unit adjustment-Position,0,
IDE11957-MAS02955,Display unit adjustment-Engine temperature,0, °C
IDE11957-MAS03129,Display unit adjustment-Reset counter,0,
IDE11957-MAS04160,Display unit adjustment-Load change,0,
IDE11957-MAS04337,Display unit adjustment-Engine current,0, A
IDE11957-MAS05370,Display unit adjustment-Direction of movement,not activated,
IDE11957-MAS05563,Display unit adjustment-Norming,not normed,
IDE11957-MAS05719,Display unit adjustment-Maximum travel,0,
IDE11957-MAS12838,Display unit adjustment-Standardization flag,never normed,
IDE11969-MAS01390,Adjustment of foot rest-Block 1,0,
IDE11969-MAS01391,Adjustment of foot rest-Block 2,0,
IDE11969-MAS02282,Adjustment of foot rest-Position,0,
IDE11969-MAS02955,Adjustment of foot rest-Engine temperature,0, °C
IDE11969-MAS03129,Adjustment of foot rest-Reset counter,0,
IDE11969-MAS04160,Adjustment of foot rest-Load change,0,
IDE11969-MAS04337,Adjustment of foot rest-Engine current,0, A
IDE11969-MAS05370,Adjustment of foot rest-Direction of movement,not activated,
IDE11969-MAS05563,Adjustment of foot rest-Norming,not normed,
IDE11969-MAS05719,Adjustment of foot rest-Maximum travel,0,
IDE11969-MAS12838,Adjustment of foot rest-Standardization flag,never normed,
IDE11986-MAS01390,Adjustment 2 of visual display unit-Block 1,0,
IDE11986-MAS01391,Adjustment 2 of visual display unit-Block 2,0,
IDE11986-MAS02282,Adjustment 2 of visual display unit-Position,0,
IDE11986-MAS02955,Adjustment 2 of visual display unit-Engine temperature,0, °C
IDE11986-MAS03129,Adjustment 2 of visual display unit-Reset counter,0,
IDE11986-MAS04160,Adjustment 2 of visual display unit-Load change,0,
IDE11986-MAS04337,Adjustment 2 of visual display unit-Engine current,0, A
IDE11986-MAS05370,Adjustment 2 of visual display unit-Direction of movement,not activated,
IDE11986-MAS05563,Adjustment 2 of visual display unit-Norming,not normed,
IDE11986-MAS05719,Adjustment 2 of visual display unit-Maximum travel,0,
IDE11986-MAS12838,Adjustment 2 of visual display unit-Standardization flag,never normed,
IDE12083-MAS13890,Switch for lateral backrest support adjustment-Adjustment for lateral support backrest,not activated,
IDE12083-MAS13891,Switch for lateral backrest support adjustment-Adjustment for lateral support seat cushion,not activated,
MAS12838-IDE06510,Standardization flag-Backrest inclination adjustment,normed,
MAS12838-IDE06511,Standardization flag-Seat height adjustment,normed,
MAS12838-IDE06512,Standardization flag-Seat forward/back position adjustment,normed,
MAS12838-IDE06683,Standardization flag-Seat inclination adjustment,normed,
MAS12838-IDE06684,Standardization flag-Lumbar support height adjustment,never normed,
MAS12838-IDE06685,Standardization flag-Lumbar support longitudinal position adjustment,never normed,
MAS12838-IDE08989,Standardization flag-Seat depth adjustment,never normed,
MAS12838-IDE08990,Standardization flag-Backrest top adjustment,never normed,
MAS12838-IDE08991,Standardization flag-Belt height adjustment,never normed,
MAS12838-MAS11869,Standardization flag-Headrest adjustment: horizontal,never normed,
MAS12838-MAS11890,Standardization flag-Headrest adjustment: vertical,never normed,
ENG08879-IDE06510,Account_1-Backrest inclination adjustment,0,
ENG08879-IDE06511,Account_1-Seat height adjustment,0,
ENG08879-IDE06512,Account_1-Seat forward/back position adjustment,0,
ENG08879-IDE06683,Account_1-Seat inclination adjustment,0,
ENG08879-IDE06684,Account_1-Lumbar support height adjustment,0,
ENG08879-IDE06685,Account_1-Lumbar support longitudinal position adjustment,0,
ENG08879-IDE08989,Account_1-Seat depth adjustment,0,
ENG08879-IDE08990,Account_1-Backrest top adjustment,0,
ENG08879-IDE08991,Account_1-Belt height adjustment,0,
ENG08879-IDE11024,Account_1-Headrest height adjustment,0,
ENG08880-IDE06510,Account_2-Backrest inclination adjustment,33025,
ENG08880-IDE06511,Account_2-Seat height adjustment,33180,
ENG08880-IDE06512,Account_2-Seat forward/back position adjustment,33461,
ENG08880-IDE06683,Account_2-Seat inclination adjustment,32708,
ENG08880-IDE06684,Account_2-Lumbar support height adjustment,0,
ENG08880-IDE06685,Account_2-Lumbar support longitudinal position adjustment,0,
ENG08880-IDE08989,Account_2-Seat depth adjustment,0,
ENG08880-IDE08990,Account_2-Backrest top adjustment,0,
ENG08880-IDE08991,Account_2-Belt height adjustment,0,
ENG08880-IDE11024,Account_2-Headrest height adjustment,0,
ENG08881-IDE06510,Account_3-Backrest inclination adjustment,0,
ENG08881-IDE06511,Account_3-Seat height adjustment,0,
ENG08881-IDE06512,Account_3-Seat forward/back position adjustment,0,
ENG08881-IDE06683,Account_3-Seat inclination adjustment,0,
ENG08881-IDE06684,Account_3-Lumbar support height adjustment,0,
ENG08881-IDE06685,Account_3-Lumbar support longitudinal position adjustment,0,
ENG08881-IDE08989,Account_3-Seat depth adjustment,0,
ENG08881-IDE08990,Account_3-Backrest top adjustment,0,
ENG08881-IDE08991,Account_3-Belt height adjustment,0,
ENG08881-IDE11024,Account_3-Headrest height adjustment,0,
ENG08882-IDE06510,Account_4-Backrest inclination adjustment,0,
ENG08882-IDE06511,Account_4-Seat height adjustment,0,
ENG08882-IDE06512,Account_4-Seat forward/back position adjustment,0,
ENG08882-IDE06683,Account_4-Seat inclination adjustment,0,
ENG08882-IDE06684,Account_4-Lumbar support height adjustment,0,
ENG08882-IDE06685,Account_4-Lumbar support longitudinal position adjustment,0,
ENG08882-IDE08989,Account_4-Seat depth adjustment,0,
ENG08882-IDE08990,Account_4-Backrest top adjustment,0,
ENG08882-IDE08991,Account_4-Belt height adjustment,0,
ENG08882-IDE11024,Account_4-Headrest height adjustment,0,
ENG08883-IDE06510,Account_5-Backrest inclination adjustment,0,
ENG08883-IDE06511,Account_5-Seat height adjustment,0,
ENG08883-IDE06512,Account_5-Seat forward/back position adjustment,0,
ENG08883-IDE06683,Account_5-Seat inclination adjustment,0,
ENG08883-IDE06684,Account_5-Lumbar support height adjustment,0,
ENG08883-IDE06685,Account_5-Lumbar support longitudinal position adjustment,0,
ENG08883-IDE08989,Account_5-Seat depth adjustment,0,
ENG08883-IDE08990,Account_5-Backrest top adjustment,0,
ENG08883-IDE08991,Account_5-Belt height adjustment,0,
ENG08883-IDE11024,Account_5-Headrest height adjustment,0,
ENG08884-IDE06510,Account_6-Backrest inclination adjustment,0,
ENG08884-IDE06511,Account_6-Seat height adjustment,0,
ENG08884-IDE06512,Account_6-Seat forward/back position adjustment,0,
ENG08884-IDE06683,Account_6-Seat inclination adjustment,0,
ENG08884-IDE06684,Account_6-Lumbar support height adjustment,0,
ENG08884-IDE06685,Account_6-Lumbar support longitudinal position adjustment,0,
ENG08884-IDE08989,Account_6-Seat depth adjustment,0,
ENG08884-IDE08990,Account_6-Backrest top adjustment,0,
ENG08884-IDE08991,Account_6-Belt height adjustment,0,
ENG08884-IDE11024,Account_6-Headrest height adjustment,0,
ENG08885-IDE06510,Account_7-Backrest inclination adjustment,0,
ENG08885-IDE06511,Account_7-Seat height adjustment,0,
ENG08885-IDE06512,Account_7-Seat forward/back position adjustment,0,
ENG08885-IDE06683,Account_7-Seat inclination adjustment,0,
ENG08885-IDE06684,Account_7-Lumbar support height adjustment,0,
ENG08885-IDE06685,Account_7-Lumbar support longitudinal position adjustment,0,
ENG08885-IDE08989,Account_7-Seat depth adjustment,0,
ENG08885-IDE08990,Account_7-Backrest top adjustment,0,
ENG08885-IDE08991,Account_7-Belt height adjustment,0,
ENG08885-IDE11024,Account_7-Headrest height adjustment,0,
ENG08878-IDE06510,BAP_Seat_Adjustment_Button_Status-Backrest inclination adjustment,not activated,
ENG08878-IDE06511,BAP_Seat_Adjustment_Button_Status-Seat height adjustment,not activated,
ENG08878-IDE06512,BAP_Seat_Adjustment_Button_Status-Seat forward/back position adjustment,not activated,
ENG08878-IDE06683,BAP_Seat_Adjustment_Button_Status-Seat inclination adjustment,not activated,
ENG08878-IDE06684,BAP_Seat_Adjustment_Button_Status-Lumbar support height adjustment,not activated,
ENG08878-IDE06685,BAP_Seat_Adjustment_Button_Status-Lumbar support longitudinal position adjustment,not activated,
ENG08878-IDE08989,BAP_Seat_Adjustment_Button_Status-Seat depth adjustment,not activated,
ENG08878-IDE08990,BAP_Seat_Adjustment_Button_Status-Backrest top adjustment,not activated,
ENG08878-IDE08991,BAP_Seat_Adjustment_Button_Status-Belt height adjustment,not activated,
ENG08878-IDE11024,BAP_Seat_Adjustment_Button_Status-Headrest height adjustment,not activated,
ENG08878-IDE11025,BAP_Seat_Adjustment_Button_Status-Headrest length adjustment,not activated,
ENG08878-IDE11957,BAP_Seat_Adjustment_Button_Status-Display unit adjustment,not activated,
ENG08878-IDE11969,BAP_Seat_Adjustment_Button_Status-Adjustment of foot rest,not activated,
ENG08878-IDE11986,BAP_Seat_Adjustment_Button_Status-Adjustment 2 of visual display unit,not activated,
ENG08878-ENG09596,BAP_Seat_Adjustment_Button_Status-backrest_side_bolster,not activated,
ENG08878-ENG09597,BAP_Seat_Adjustment_Button_Status-footmat,not activated,
ENG08878-ENG09595,BAP_Seat_Adjustment_Button_Status-side_bolster,not activated,
ENG05253-ENG101098,crash_precrash-Crash,not active,
ENG05253-ENG00891,crash_precrash-Precrash,not active,
ENG05258-ENG05268,Entnormierursache-Axis_1,Normierroutine,
ENG05258-ENG05277,Entnormierursache-Axis_10,Achse decodiert,
ENG05258-ENG05269,Entnormierursache-Axis_2,Normierroutine,
ENG05258-ENG05270,Entnormierursache-Axis_3,Normierroutine,
ENG05258-ENG05271,Entnormierursache-Axis_4,Normierroutine,
ENG05258-ENG05272,Entnormierursache-Axis_5,Achse decodiert,
ENG05258-ENG05273,Entnormierursache-Axis_6,Achse decodiert,
ENG05258-ENG05274,Entnormierursache-Axis_7,Achse decodiert,
ENG05258-ENG05275,Entnormierursache-Axis_8,Achse decodiert,
ENG05258-ENG05276,Entnormierursache-Axis_9,Achse decodiert,
ENG116729-ENG117054,info_developer-ax_da,82 B5 7F F6 82 C0 00 07 81 02 7F FD 86 2C 00 07 81 9C 7F EF 82 36 00 07 7F C4 7F 27 80 1E 00 07 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A,
ENG116729-ENG117006,info_developer-gl_lo,34 4D 31 39 35 39 37 36 30 20 20 00 00 00 00 00 30 30 33 31 00 00 00 00 31 32 30 31 00 00 00 00 53 43 51 35 53 54 41 4E 44 41 52 44 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116729-ENG116875,info_developer-gl_pr,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 04 04 04 00 00 00 00,
ENG116729-ENG117035,info_developer-pne,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116729-ENG116968,info_developer-so_deb,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG05278-ENG05354,key_memory_activated-mmi_key_memory_activated,active,
ENG05251-IDE06842,Memory_ID_CAN_1-Status - Button 1,not active,
ENG05251-IDE06843,Memory_ID_CAN_1-Status - Button 2,not active,
ENG05251-IDE06844,Memory_ID_CAN_1-Status - Button 3,not active,
ENG05251-IDE06845,Memory_ID_CAN_1-Status - Button 4,not active,
ENG05251-ENG123088,Memory_ID_CAN_1-FFB_Close_Button,not active,
ENG05251-ENG123087,Memory_ID_CAN_1-FFB_Open_Button,not active,
ENG05251-ENG123089,Memory_ID_CAN_1-FT_lock,not active,
ENG05251-ENG123090,Memory_ID_CAN_1-FT_locked,not active,
ENG05252-MAS03679,Memory_ID_CAN_2-Terminal 15 status,active,
ENG05252-ENG123091,Memory_ID_CAN_2-DoorContact_more_than_10min_opened,active,
ENG05252-ENG123092,Memory_ID_CAN_2-DoorContact_NotActive_Active,active,
ENG05252-ENG09278,Memory_ID_CAN_2-FFB_HDF_Button,not active,
ENG05252-ENG05263,Memory_ID_CAN_2-Hardware_onoff,active,
ENG05252-ENG123093,Memory_ID_CAN_2-Memory_Adjustment,not active,
ENG05252-ENG123094,Memory_ID_CAN_2-MemoryButton_Pressed,not active,
ENG05252-ENG116986,Memory_ID_CAN_2-v_signal_less_v_threshold,active,
ENG26976-MAS03760,missing_pre_conditions-Wind deflector position,not active,
ENG26976-ENG116860,missing_pre_conditions-_reserviert,0,
ENG26976-ENG30399,missing_pre_conditions-backrest_locked,active,
ENG26976-ENG30400,missing_pre_conditions-backrest_unlocked,active,
ENG26976-ENG30434,missing_pre_conditions-button_pressed,not active,
ENG26976-ENG30644,missing_pre_conditions-coded_axes_not_normalized,not active,
ENG26976-ENG32216,missing_pre_conditions-other_adjustment_already_active,not active,
ENG26976-ENG100589,missing_pre_conditions-Reserviert 2,0,
ENG26976-ENG32451,missing_pre_conditions-reset_problem,not active,
ENG26976-ENG32661,missing_pre_conditions-speed_above_5kmh,not active,
ENG26976-ENG28397,missing_pre_conditions-Voltage_supply,not active,
ENG05256-ENG05265,pwm_generator-pwm_generator_group_1_overload,not active,
ENG05256-ENG05266,pwm_generator-pwm_generator_group_2_overload,not active,
ENG05254-ENG99389,Resets-Resetcounter,2,
ENG05257-ENG05267,sbc-sbc_overload,not active,
ENG05279-ENG05366,Seat_Actual_Positions-Current_Position_fsv,32768,
ENG05279-ENG05362,Seat_Actual_Positions-Current_Position_ghv,32768,
ENG05279-ENG05369,Seat_Actual_Positions-Current_Position_kks,32768,
ENG05279-ENG05365,Seat_Actual_Positions-Current_Position_ksv_x,32768,
ENG05279-ENG05359,Seat_Actual_Positions-Current_Position_ksv_z,32768,
ENG05279-ENG05364,Seat_Actual_Positions-Current_Position_ldh,32768,
ENG05279-ENG05363,Seat_Actual_Positions-Current_Position_ldw,32768,
ENG05279-ENG05361,Seat_Actual_Positions-Current_Position_lkv,32768,
ENG05279-ENG05356,Seat_Actual_Positions-Current_Position_lnv,33026,
ENG05279-ENG05367,Seat_Actual_Positions-Current_Position_rse1,32768,
ENG05279-ENG05368,Seat_Actual_Positions-Current_Position_rse2,32768,
ENG05279-ENG05357,Seat_Actual_Positions-Current_Position_shv,33180,
ENG05279-ENG05355,Seat_Actual_Positions-Current_Position_slv,33461,
ENG05279-ENG05358,Seat_Actual_Positions-Current_Position_snv,32708,
ENG05279-ENG05360,Seat_Actual_Positions-Current_Position_stv,32768,
ENG123054-ENG05349,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_1,not active,
ENG123054-ENG05350,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_2,not active,
ENG123054-ENG05351,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_3,not active,
ENG123054-ENG05352,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_4,not active,
ENG123054-ENG05353,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_SET,not active,
ENG123054-ENG123084,Seat_Adjustment_Memory_Info_CAN-MMB_glob_Stop,not active,
ENG123054-ENG123077,Seat_Adjustment_Memory_Info_CAN-MMB_storage_0,not active,
ENG123054-ENG123078,Seat_Adjustment_Memory_Info_CAN-MMB_storage_1,not active,
ENG123054-ENG123079,Seat_Adjustment_Memory_Info_CAN-MMB_storage_2,not active,
ENG123054-ENG123080,Seat_Adjustment_Memory_Info_CAN-MMB_storage_3,not active,
ENG123054-ENG123083,Seat_Adjustment_Memory_Info_CAN-MMB_store,not active,
ENG123054-ENG123082,Seat_Adjustment_Memory_Info_CAN-MMB_tast,not active,
ENG123054-ENG123081,Seat_Adjustment_Memory_Info_CAN-MMB_tipp,not active,
ENG123055-ENG123086,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Active_Remote_Control_Key,Key 2,
ENG123055-ENG123085,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Remote_Control_Key_Signal,Key 2,
ENG123053-ENG05345,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Head_Movement,not active,
ENG123053-ENG05340,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Inclination_Movement,not active,
ENG123053-ENG05346,Seat_Adjustment_State_Info_CAN-FSM_Belt_Height_Movement,not active,
ENG123053-ENG05343,Seat_Adjustment_State_Info_CAN-FSM_Headrest_Movement,not active,
ENG123053-ENG123076,Seat_Adjustment_State_Info_CAN-FSM_KD_Error,not active,
ENG123053-ENG05348,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Height_Movement,not active,
ENG123053-ENG05347,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Longitudial_Movement,not active,
ENG123053-ENG05344,Seat_Adjustment_State_Info_CAN-FSM_Seat_Depth_Movement,not active,
ENG123053-ENG05341,Seat_Adjustment_State_Info_CAN-FSM_Seat_Height_Movement,not active,
ENG123053-ENG05342,Seat_Adjustment_State_Info_CAN-FSM_Seat_Inclination_Movement,not active,
ENG123053-ENG05339,Seat_Adjustment_State_Info_CAN-FSM_Seat_Longitudial_Movement,not active,
ENG123053-ENG123075,Seat_Adjustment_State_Info_CAN-FSM_SeatMovement,not active,
ENG27116-IDE06510,Seat_Position_Memory_Remote_Control_5-Backrest inclination adjustment,0,
ENG27116-IDE06511,Seat_Position_Memory_Remote_Control_5-Seat height adjustment,0,
ENG27116-IDE06512,Seat_Position_Memory_Remote_Control_5-Seat forward/back position adjustment,0,
ENG27116-IDE06683,Seat_Position_Memory_Remote_Control_5-Seat inclination adjustment,0,
ENG27116-IDE06684,Seat_Position_Memory_Remote_Control_5-Lumbar support height adjustment,0,
ENG27116-IDE06685,Seat_Position_Memory_Remote_Control_5-Lumbar support longitudinal position adjustment,0,
ENG27116-IDE08989,Seat_Position_Memory_Remote_Control_5-Seat depth adjustment,0,
ENG27116-IDE08990,Seat_Position_Memory_Remote_Control_5-Backrest top adjustment,0,
ENG27116-IDE08991,Seat_Position_Memory_Remote_Control_5-Belt height adjustment,0,
ENG27116-IDE11024,Seat_Position_Memory_Remote_Control_5-Headrest height adjustment,0,
ENG27117-IDE06510,Seat_Position_Memory_Remote_Control_6-Backrest inclination adjustment,0,
ENG27117-IDE06511,Seat_Position_Memory_Remote_Control_6-Seat height adjustment,0,
ENG27117-IDE06512,Seat_Position_Memory_Remote_Control_6-Seat forward/back position adjustment,0,
ENG27117-IDE06683,Seat_Position_Memory_Remote_Control_6-Seat inclination adjustment,0,
ENG27117-IDE06684,Seat_Position_Memory_Remote_Control_6-Lumbar support height adjustment,0,
ENG27117-IDE06685,Seat_Position_Memory_Remote_Control_6-Lumbar support longitudinal position adjustment,0,
ENG27117-IDE08989,Seat_Position_Memory_Remote_Control_6-Seat depth adjustment,0,
ENG27117-IDE08990,Seat_Position_Memory_Remote_Control_6-Backrest top adjustment,0,
ENG27117-IDE08991,Seat_Position_Memory_Remote_Control_6-Belt height adjustment,0,
ENG27117-IDE11024,Seat_Position_Memory_Remote_Control_6-Headrest height adjustment,0,
ENG27118-IDE06510,Seat_Position_Memory_Remote_Control_7-Backrest inclination adjustment,0,
ENG27118-IDE06511,Seat_Position_Memory_Remote_Control_7-Seat height adjustment,0,
ENG27118-IDE06512,Seat_Position_Memory_Remote_Control_7-Seat forward/back position adjustment,0,
ENG27118-IDE06683,Seat_Position_Memory_Remote_Control_7-Seat inclination adjustment,0,
ENG27118-IDE06684,Seat_Position_Memory_Remote_Control_7-Lumbar support height adjustment,0,
ENG27118-IDE06685,Seat_Position_Memory_Remote_Control_7-Lumbar support longitudinal position adjustment,0,
ENG27118-IDE08989,Seat_Position_Memory_Remote_Control_7-Seat depth adjustment,0,
ENG27118-IDE08990,Seat_Position_Memory_Remote_Control_7-Backrest top adjustment,0,
ENG27118-IDE08991,Seat_Position_Memory_Remote_Control_7-Belt height adjustment,0,
ENG27118-IDE11024,Seat_Position_Memory_Remote_Control_7-Headrest height adjustment,0,
ENG05255-ENG116986,Source_Last_Reset-Low_Voltage,not active,
ENG05255-ENG123073,Source_Last_Reset-Low_Voltage_At_Run_Up,active,
ENG05255-ENG123072,Source_Last_Reset-Power_On_Reset,not active,
ENG05255-ENG123071,Source_Last_Reset-Software_Reset_by_diagnosis,not active,
ENG05255-ENG110107,Source_Last_Reset-Watchdog_reset,not active,
ENG05255-ENG123074,Source_Last_Reset-Watchdog_Reset_At_Run_Up,not active,
Elapsed Time: 00:21
adpmap-36-4M1-959-760
;Friday,12,July,2019,16:12:03:64285
IDE00001-MAS10850-Production mode-Deactivate massage function,not active ,3
IDE00001-MAS18842-Production mode-Assembly mode,not active ,3
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE02854-Resetting standardization,all ,3
IDE03066-Reset counter for compressor for multicontour seat,Activate ,1
IDE06869-installation position,Memory seat driver side ,1
ENG123066-vehicle_velocity_monitoring,active ,1
Elapsed Time: 00:17
blockmap-39-80A-907-397-A
;SW:80A-907-397-A   HW:80A-907-397-A ---  Right Light
;EV_LCMRightCONTIAU426,001009,EV_LCMLeftCONTIAU426_VW41.rod
;Friday,12,July,2019,16:12:22:64285
IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,14.10, V
IDE08742-MAS01155,Operating time-Control module,693.65, H
IDE08742-MAS03835,Operating time-Parking light,272.31, H
IDE08742-MAS09325,Operating time-Daytime running lights,362.73, H
IDE08742-MAS09332,Operating time-Turn signal,13.21, H
IDE08742-MAS09333,Operating time-Side-marker light,272.31, H
IDE09492-MAS01155,Temperatures-Control module,74.00, °C
IDE09492-MAS09339,Temperatures-extern. temperature sensor 1,88.00, °C
IDE09768-MAS09022,LED channel 1-PWM value,91.50, %
IDE09774-MAS03835,Number of activations-Parking light,1566,
IDE09774-MAS09325,Number of activations-Daytime running lights,6479,
IDE09774-MAS09332,Number of activations-Turn signal,120030,
IDE09774-MAS09333,Number of activations-Side-marker light,1566,
IDE09775-MAS09336,High temperature operating times for control unit-°C,112.04, H
IDE09775-MAS09337,High temperature operating times for control unit-between 105°C and 115°C,76.62, H
IDE09775-MAS09338,High temperature operating times for control unit-over 115°C,25.84, H
IDE10301-MAS03835,Number of excess temp. protection activations-Parking light,0,
IDE10301-MAS09325,Number of excess temp. protection activations-Daytime running lights,111,
Elapsed Time: 00:03
adpmap-39-80A-907-397-A
;Friday,12,July,2019,16:12:25:64285
Elapsed Time: 00:01
DrPeter
16.4905° S, 151.7375° W
Maps [42] - [5F]
Maps con't....
blockmap-42-8W1-959-593
;SW:8W1-959-593   HW:8W1-959-593 ---  Door Elect, Driver
;Component:TSG FS001 0737, Coding:001F0B005E00148000010002
;EV_DCU2DriveSideMAXHKLO,001010,EV_DCU2DriveSideMAXHCONT_VW37.rod
;Friday,12,July,2019,16:12:29:64285
;VCID: 88539B6033C8A60F51-80DC
IDE00310,Outside air temperature,33.00, °C
IDE01766-MAS02248,Distance impulses-Signal state,Not available,
IDE01992-MAS12276,Installation list: current installations-Front door control module,can be reached,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,can be reached,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver side door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Driver side rear door control module,
IDE02262,synchronous mirror adjustment,not installed,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,14.10, V
IDE02384-MAS12276,Status of event memory-Front door control module,ERROR,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,Sleep mode,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,not activated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,not activated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,not activated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,not activated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,not activated,
IDE04220,Driver power window button,not activated,
IDE04343-MAS03180,Bus identification-Local data bus,assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Busmaster,
IDE04411,Child Safety Lock Switch,not activated,
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,32, %
IDE04539-MAS02229,Mirror memory-Y coordinate,39, %
IDE04539-MAS02476,Mirror memory-install,installed,
IDE04540,Mirror adjustment (X/Y-direction),Position center,
IDE04580,Dimming of inside door handle lighting,10, %
IDE04581,Dimming for interior ambient lighting,0, %
IDE04586,Mirror fold-in activation,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,not activated,
IDE05720-IDE04214,Front driver side door status-Key switch in door lock,not activated,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,87, %
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,No,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,No,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,OFF,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not activated,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Power window control standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Idle condition,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not activated,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not activated,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not activated,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,23.00, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,7.00, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.50, %
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,33, °C
IDE07543,Vehicle speed,0.00, km/h
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE09335,Mirror fold-in: current consumption,0.00, A
IDE09798,Play protection: mirror fold-in,not active,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,automatic day/night exterior mirror-Status,not active,
IDE10164-MAS03691,automatic day/night exterior mirror-Dimming,0, %
IDE12422-IDE02266,Driver side front door control head-Passenger side rear power window button,not activated,
IDE12422-IDE04220,Driver side front door control head-Driver power window button,not activated,
IDE12422-IDE04411,Driver side front door control head-Child Safety Lock Switch,not installed,
IDE12422-IDE04540,Driver side front door control head-Mirror adjustment (X/Y-direction),Position bottom,
IDE12422-IDE06621,Driver side front door control head-Driver side rear power window button,not activated,
IDE12422-IDE06872,Driver side front door control head-Front passenger power window button,not activated,
IDE12422-IDE10158,Driver side front door control head-Window lift: switch-over from front to rear,not installed,
IDE12422-IDE11140,Driver side front door control head-Mirror folding position,Driving setting,
IDE12422-MAS14179,Driver side front door control head-Child safety lock rear driver side: status,not active,
IDE12422-MAS14180,Driver side front door control head-Child safety lock rear passenger side: status,not active,
IDE12422-MAS15309,Driver side front door control head-Mirror selector switch: left,not activated,
IDE12422-MAS15310,Driver side front door control head-Mirror selection switch: right,not activated,
IDE12422-MAS15311,Driver side front door control head-Button: open rear lid,not activated,
IDE12422-MAS15312,Driver side front door control head-Close rear lid button,not installed,
IDE12422-MAS15313,Driver side front door control head-Bus signal: open rear lid,not activated,
IDE12422-MAS15314,Driver side front door control head-Close rear lid bus signal,not activated,
MAS01872,Rear lid remote release button,not activated,
MAS02101,Child safety,not active,
MAS06010,Ambient light,0, %
Elapsed Time: 00:07
adpmap-42-8W1-959-593
;Friday,12,July,2019,16:12:36:64285
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
IDE09067-Side window shade: service mode,Deactivating ,1
Elapsed Time: 00:03
blockmap-44-4M0-909-144-H
;SW:4M0-909-144-H   HW:4M0-909-144-B ---  Steering Assist
;Component:EPS_MLBEVO1BS H22 0005, Coding:90002001000100
;EV_EPSVWBSAU736,009023,EV_EPSVWBSAU736_009.rod
;Friday,12,July,2019,16:12:42:64285
;VCID: B42B1F901FC0F2EFCD-80E0
IDE00102-MAS02954,Control Module temperature-Temperature model value,51.59, °C
IDE00102-MAS02955,Control Module temperature-Engine temperature,51.40, °C
IDE00102-MAS02956,Control Module temperature-Magnet Temperature,51.05, °C
IDE00102-MAS04448,Control Module temperature-Output stage temperature,55.39, °C
IDE00609-IDE10203,Communication status of data bus 1-Audi drive select: drive program,Communications link,
IDE00609-MAS00772,Communication status of data bus 1-Battery Monitoring Control Module,Communications link,
IDE00609-MAS00795,Communication status of data bus 1-Diagnostic interface for data bus,Communications link,
IDE00609-MAS00796,Communication status of data bus 1-Engine Control Module (ECM),Communications link,
IDE00609-MAS00802,Communication status of data bus 1-Control module for distance control,Communications link,
IDE00609-MAS00805,Communication status of data bus 1-Directional stabilization assistance control module,Communications link,
IDE00609-MAS00807,Communication status of data bus 1-Parallel parking assistance control module,Communications link,
IDE00609-MAS00811,Communication status of data bus 1-Active steering control module,Communications link,
IDE00609-MAS00821,Communication status of data bus 1-Central ctrl. unit for comfort system,Communications link,
IDE00609-MAS00824,Communication status of data bus 1-Steering column electronics control module,Communications link,
IDE00609-MAS00830,Communication status of data bus 1-Towing recognition control module,No communication,
IDE00609-MAS01172,Communication status of data bus 1-Development messages,No communication,
IDE00609-MAS08787,Communication status of data bus 1-Maneuvering assistant,Communications link,
IDE00609-MAS09196,Communication status of data bus 1-Rear Axle Steering,No communication,
IDE00609-MAS11240,Communication status of data bus 1-ABS Control Module,Communications link,
IDE00609-MAS13015,Communication status of data bus 1-Routing assistant with park-steering system,Communications link,
IDE00609-MAS13018,Communication status of data bus 1-Front sensor system for driver assistance systems,Communications link,
IDE00609-MAS13019,Communication status of data bus 1-Chassis Control,Communications link,
IDE00924-MAS02125,Steering angle-Steering wheel angle speed,0.00, °/s
IDE00924-MAS02126,Steering angle-Steering angle sensor: status,System OK,
IDE00924-MAS02961,Steering angle-Engine angle,276.50, °
IDE00924-MAS02981,Steering angle-Overlay angle,409.40, °
IDE00924-MAS02983,Steering angle-Steering wheel angle,4.60, °
IDE00924-MAS02984,Steering angle-Steering angle speed,-0.57, °/s
IDE00924-MAS13060,Steering angle-Steering pinion angle: offset corrected,4.44, °
IDE02068-MAS00106,Time stamp-Year,2019, yr
IDE02068-MAS00107,Time stamp-Month,7, m
IDE02068-MAS00108,Time stamp-Day,12, d
IDE02068-MAS00109,Time stamp-Hours,16, H
IDE02068-MAS00110,Time stamp-Minutes,12, min
IDE02068-MAS00111,Time stamp-Seconds,39, s
IDE02068-MAS00711,Time stamp-Odometer reading,34677, km
IDE03008-MAS05361,Stop process prevented-Manual steering torque too large,not active,
IDE03008-MAS05409,Stop process prevented-Calculated steering angle too large,not active,
IDE03008-MAS14902,Stop process prevented-Limp home mode active,not active,
IDE03010-MAS05361,Number of prevented stop processes-Manual steering torque too large,0,
IDE03010-MAS05409,Number of prevented stop processes-Calculated steering angle too large,76,
IDE03010-MAS14902,Number of prevented stop processes-Limp home mode active,0,
IDE03011-ENG08103,Number of requested start processes-Frequency_counter_values_Restart,18,
IDE03471-IDE10940,Vehicle configuration-Steering assist. without eng. running,not active,
IDE03471-MAS01891,Vehicle configuration-Lane assistant,Not coded,
IDE03471-MAS02145,Vehicle configuration-ESP ADS coding,Active steering not coded,
IDE03471-MAS02672,Vehicle configuration-Start-stop,coded,
IDE03471-MAS03400,Vehicle configuration-Audi drive select,coded,
IDE03471-MAS08071,Vehicle configuration-Hybrid drive,Not coded,
IDE03471-MAS08201,Vehicle configuration-Trailer positioning assistant,Not coded,
IDE03471-MAS08786,Vehicle configuration-Parallel Parking Assistance,No
