Audi 09 B8 All kinds of issues all at once out of no where
Audi S-4
C?ID=303575
So I drive my B8 2009 Audi Avant 2.0T to work the other day and I get just about every light on the dash on and my radio is cutting in and out plus my HVAC is doing the same thing. No turn signals but the car is driving ok with normal power. I thought my car just got possessed by a demon or something. ABS, Traction control, Steering, EPC were all on. Engine light already on have a race cat and need to do APR Stage 2 yet. Anyway I keep going to work because halfway there and I turn off the MMI. This stops the radio issue and HVAC issue of going on and off. It was like a short or something. It did rain that last night. So right before I get to work I turn on MMI again and it is fine HVAC is fine ABS light goes off and turn signals work again. SO I made it to work. Going home all drove well but Traction control, Steering, and EPC light remain. Below is my scan of what was on there and it is long. I cleared and rescaned. I have not driven it really been driving my other Audi. So what I get from this is my steering module but there could be other things brewing in this mess so if any one might know what to fix first I would be glad to know. A little overwhelming and if it is not the steering module would be great since they are around 400 new.
Thanks for your help!
Tuesday,09,July,2019,09:20:03:01898
VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
VIN: WAUXF78K49A064039   License Plate: JMW6290
Mileage: 249560km-155069mi   Repair Order: 5
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 07 08 09 0E 0F 10 14 15 16 17 19 1B 1E 36 37 3C
          42 46 47 52 53 55 56 62 65 67 6C 6D 72 77
VIN: WAUXF78K49A064039   Mileage: 249560km-155069miles
05-Acc/Start Auth. -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Sporadic communication error 1000
0E-Media Player 1 -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Cannot be reached 1100
1B-Active Steering -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Sporadic communication error 1000
65-Tire Pressure -- Status: Malfunction 1010
67-Voice Control -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 1010
6D-Trunk Elect. -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H12 0001
   Revision: E1H12---
   Coding: 010C010A190F0160
   Shop #: WSC 06449 444 84029
   ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
   ROD: EV_ECM20TFS0118K2907115AL.rod
   VCID: 79BA3080F8DE388C60-802C
10 Faults Found:
          U1113 00 [047] - -
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:56
                    Engine speed: 1873.00 /min
                    Normed load value: 40.0 %
                    Vehicle speed: 92 km/h
                    Coolant temperature: 79 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 13.617 V
          U1113 00 [047] - -
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:56
7135 - Body Control Module (Central Electric)
          U0140 00 [168] - No Communications
                    Fault Frequency: 50
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:52
                    Engine speed: 1694.00 /min
                    Normed load value: 27.5 %
                    Vehicle speed: 83 km/h
                    Coolant temperature: 78 °C
                    Voltage terminal 30: 13.640 V
5558 - Body Control Module (Central Electric 2)
          U0141 00 [040] - No Communications
                    Fault Frequency: 17
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:56
5615 - Door Control Module - Driver's Door
          U0199 00 [040] - No Communications
                    Fault Frequency: 90
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:51
                    Engine speed: 1736.00 /min
                    Normed load value: 33.3 %
                    Vehicle speed: 80 km/h
                    Coolant temperature: 77 °C
                    Voltage terminal 30: 13.735 V
7150 - Please Check DTC Memory of Steering Wheel Electronics
          P1698 00 [040] - -
                    Fault Frequency: 63
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:56:02
                    Engine speed: 1594.00 /min
                    Normed load value: 4.3 %
                    Vehicle speed: 78 km/h
                    Coolant temperature: 81 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 13.782 V
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [040] - -
                    Fault Frequency: 154
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:51
                    Engine speed: 1723.00 /min
                    Normed load value: 32.9 %
4720 - Body Control Module (Central Electric 2)
                    Fault Frequency: 95
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:50
                    Engine speed: 1675.00 /min
                    Normed load value: 30.6 %
                    Vehicle speed: 79 km/h
4025 - Oxygen (Lambda) Sensor B1 S2
          P0140 00 [104] - No Activity
                    Fault Frequency: 80
                    Mileage: 246933 km
                    Date: 2019.04.08
                    Time: 23:26:11
                    Engine speed: 3099.50 /min
                    Normed load value: 27.8 %
                    Vehicle speed: 122 km/h
                    Coolant temperature: 94 °C
                    Voltage terminal 30: 13.923 V
4201 - Fuel Level too Low
          P1250 00 [096] - -
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 C    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H04 0020
   Revision: --H04---
   Coding: 001002
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: 3620FBBC894017F4CD-8062
2505 - Torque Management Feedback Signal A
          P2637 00 [040] - -
                    Fault Frequency: 38
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:56:26
                    Engine speed: 1927.00 /min
                    Transmission input speed: 1885 /min
                    Transmission output speed: 1649 /min
                    Engine torque: 60 Nm
                    Transmission fluid temperature: 34 °C
                    Accelerator position: 10.0 %
                    Clutch status: 1
4774 - Body Control Module (Central Electric 2)
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:51
                    Engine speed: 1673.00 /min
                    Transmission input speed: 1652 /min
                    Transmission output speed: 2391 /min
                    Engine torque: 112 Nm
                    Transmission fluid temperature: 32 °C
                    Accelerator position: 16.4 %
                    Clutch status: 2
   Part No SW: 8K0 907 379 AD    HW: 8K0 907 379 AD
   Component: ESP8 quattro  H04 0060
   Coding: 152500
   VCID: 7BB62A88FAE20A9C72-802E
10 Faults Found:
                    Fault Status: 00101101
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:51
                    Hex Value: 0x4F00
                    Hex Value: 0x4006
                    Hex Value: 0x1216
                    Hex Value: 0x02AE
                    Hex Value: 0x00FF
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:56
                    Hex Value: 0x5C00
                    Hex Value: 0x4006
                    Hex Value: 0x1226
                    Hex Value: 0x7AAD
                    Hex Value: 0x00FF
00457 - Control Module for Network (J519)
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:56
                    Hex Value: 0x5C00
                    Hex Value: 0x4006
                    Hex Value: 0x1245
                    Hex Value: 0x62AD
                    Hex Value: 0x00FF
03110 - Active Steering Control Module (J792)
                    Fault Status: 01101101
                    Reset counter: 227
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:57
                    Hex Value: 0x5C00
                    Hex Value: 0x4206
                    Hex Value: 0x120C
                    Hex Value: 0x16AB
                    Hex Value: 0x00FF
                    Fault Frequency: 8
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:56:02
                    Hex Value: 0x5000
                    Hex Value: 0x4206
                    Hex Value: 0x120A
                    Hex Value: 0x46AE
                    Hex Value: 0x00FF
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:56:30
                    Hex Value: 0x3E40
                    Hex Value: 0x6206
                    Hex Value: 0x121A
                    Hex Value: 0x33AE
                    Hex Value: 0x00FF
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:56
                    Hex Value: 0x5C00
                    Hex Value: 0x4006
                    Hex Value: 0x1226
                    Hex Value: 0x7AAD
                    Hex Value: 0x00FF
                    Reset counter: 10
                    Mileage: 249513 km
                    Date: 2019.06.07
                    Time: 09:59:42
                    Hex Value: 0x0600
                    Hex Value: 0x4202
                    Hex Value: 0x0226
                    Hex Value: 0x23A3
                    Hex Value: 0x00FF
                    Reset counter: 10
                    Mileage: 249513 km
                    Date: 2019.06.07
                    Time: 09:59:43
                    Hex Value: 0x0900
                    Hex Value: 0x6202
                    Hex Value: 0x021A
                    Hex Value: 0x1BA3
                    Hex Value: 0x00FF
01794 - Control Module - Incorrect Chassis (VIN) Number
            000 -  -  - Intermittent - MIL ON
                    Fault Status: 10100000
                    Reset counter: 10
                    Mileage: 249513 km
                    Date: 2019.06.07
                    Time: 09:59:45
                    Hex Value: 0x0D00
                    Hex Value: 0x4202
                    Hex Value: 0x123C
                    Hex Value: 0x13A3
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 AH    HW: 8K0 907 064 AH
   Component: BCM2 1.1      H71 0134
   Coding: 0D0200
   VCID: 76A03BBCC1C057F40D-8022
   Component: ELVAUDIB8  H35 0039
   Serial number: 0208000025573003
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Reset counter: 167
                    Mileage: 246915 km
                    Date: 2019.04.05
                    Time: 11:26:38
03286 - Sensor for Contact with Door Handle; Front Right
                    Fault Status: 00101011
                    Reset counter: 4
                    Mileage: 246915 km
                    Date: 2019.04.05
                    Time: 15:33:30
03285 - Sensor for Contact with Door Handle; Front Left
                    Fault Status: 00100111
                    Reset counter: 235
                    Mileage: 246920 km
                    Date: 2019.04.08
                    Time: 09:40:13
                    Reset counter: 4
                    Mileage: 248551 km
                    Date: 2019.05.19
                    Time: 10:15:45
00956 - Key 2
                    Reset counter: 5
                    Mileage: 248964 km
                    Date: 2019.05.27
                    Time: 10:02:11
                    Fault Frequency: 63
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:56
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 M    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 340EO087506824
   Coding: 0001003
   VCID: 43C692680292B25C7A-8016
   Subsystem 1 - Part No: 8T0 919 609 D
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000104612
   Subsystem 3 - Serial number: 0124.06.080000000100010680ÿ
   Subsystem 4 - Serial number: 010680ÿ
                    Reset counter: 11
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:58
                    Reset counter: 11
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:58
            000 -  -
                    Reset counter: 166
                    Mileage: 246915 km
                    Date: 2019.04.05
                    Time: 09:36:13
                    Bin. Bits: 00111110 10000010
                    Bin. Bits: 00000100 10000001
                    Bin. Bits: 00000000 00000000
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0140
   Revision: C1000000    Serial number: 0127.06.081044
   Coding: 64002000
   VCID: 72A807ACADA84BD421-8026
                    Reset counter: 11
00898 - Control Circuit A/C compressor
                    Current: 0.000 A
                    Current: 0.510 A
                    Voltage: 13.70 V
                    Reset counter: 11
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000069120
   Coding: 26001091063CAF311F00080300003D0D0F9CC64800010161000000
   VCID: 302CCDA4632439C497-8064
   Subsystem 1 - Part No SW: 8K1 955 119     HW: 8T1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 260608  H06 0060
   Serial number: SWFBIE 0000143
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10171098
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000000507081035
   Subsystem 4 - Part No SW: 8K0 907 410 A    HW: 8K0 907 410 A
   Component: UGDO HL US  H04 0060
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
   Component: MP3-Changer     H42 0390
   Revision: 00042002    Serial number: AUZ5ZBH8483029
   VCID: 2A18DFCC85F8431459-807E
02261 - Data Medium
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 183
                    Mileage: 247667 km
                    Date: 2019.04.19
                    Time: 13:34:03
                    Text: 00000000
                    Reset counter: 11
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:56:18
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7H0355295
   Coding: 0000100
   VCID: 312AC8A0A82E30CC98-8064
            000 -  -
                    Reset counter: 173
                    Mileage: 247010 km
                    Date: 2019.04.10
                    Time: 07:32:37
Address 10: Park/Steer Assist
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8K0 907 364     HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H08 0052
   Revision: 00000000    Serial number: 04060800280003
   Coding: 050181
   Shop #: WSC 06449 444 54051
   VCID: 70AC0DA4A3A479C4D7-8024
                    Fault Frequency: 15
                    Reset counter: 11
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:51
                    Bin. Bits: 00000000 00000010
                    Fault Frequency: 33
                    Reset counter: 11
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:56:01
                    Bin. Bits: 00000000 00000001
03155 - Functionality limited due to Initialization
                    Fault Frequency: 23
                    Reset counter: 11
                    Mileage: 249511 km
                    Date: 2019.06.07
                    Time: 09:57:00
                    Bin. Bits: 00000001 00000000
   Part No SW: 8K0 959 655 C    HW: 8K0 959 655 C
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0039GD126BEW
   Coding: 303836354230303030304A55304C384B3053
   VCID: 3D32E490AC76C4AC0C-8068
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Serial number: 5810000R0800000J90
   Serial number: 6334MSME32070B130
   Serial number: 6344MSME32063205
   Serial number: 6352QSME6A563253H
   Serial number: 6362QSME722E470FT
   Serial number: 63732SME770B1C6BB
   Serial number: 63832SME6B72310B+
12670208 - Body Control Module (Central Electric)
          U0140 00 [008] - No Communications
                    Reset counter: 11
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:52
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H12 0013
   Revision: --------    Serial number: 90315HEV0000M
   Coding: 000017
   VCID: 3E30E39CA970DFB415-806A
                    Fault Frequency: 14
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:49
                    Fault Frequency: 50
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:49
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:49
                    Fault Frequency: 44
                    Reset counter: 10
                    Fault Status: 00100101
                    Reset counter: 10
                    (no units): 44.0
                    Text: 2C8FFFFFFFFF00C0FF
                    Ign. Timing: 323.9°
                    Raw, Index/Key Err.: 255 255 000
                    Text: 1E82FFFF2920FE1700
                    Current: 25.400 A
                    Charge: 8414 Ah
                    Duty Cycle: 0.0 %
                    Fault Status: 00101110
   Part No SW: 8K0 920 980 A    HW: 8K0 920 980 A
   Component: KOMBIINSTR.   H15 0221
   Revision: 00200000    Serial number: 7BW34FM58
   Coding: 8B1611003300D705020000
7 Faults Found:
                    Fault Frequency: 46
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:52
                    Fault Frequency: 18
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:56
                    Fault Frequency: 27
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:56
                    Reset counter: 10
                    Mileage: 249513 km
                    Date: 2019.06.07
                    Time: 09:59:31
                    Reset counter: 10
                    Mileage: 249513 km
                    Date: 2019.06.07
                    Time: 09:59:31
00471 - Control Module for Elect. Regulated Dampers (J250)
                    Reset counter: 10
                    Mileage: 249513 km
                    Date: 2019.06.07
                    Time: 09:59:31
                    Reset counter: 10
                    Mileage: 249513 km
                    Date: 2019.06.07
                    Time: 09:59:32
   Part No SW: 8T0 907 468 L    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0092
   Revision: FB402044    Serial number: 4400F0851981FE
   Coding: 000303
   VCID: 4AD8BF4CE5B86314B9-801E
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 18029CAF140608
17 Faults Found:
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 166
                    Mileage: 246915 km
                    Date: 2019.04.05
                    Time: 09:24:13
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 230
                    Mileage: 248110 km
                    Date: 2019.05.10
                    Time: 15:57:00
                    Fault Frequency: 60
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:51
                    Fault Frequency: 105
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:51
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Fault Frequency: 84
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:51
                    Fault Frequency: 92
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:51
                    Fault Frequency: 156
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:51
                    Fault Frequency: 92
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:51
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:51
00456 - Control Module for Access and Start Control (J518)
                    Fault Frequency: 55
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:52
                    Fault Frequency: 46
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:52
00317 - Rear Lid Control Module (J605)
                    Fault Frequency: 91
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:52
                    Reset counter: 10
                    Mileage: 249530 km
                    Date: 2019.06.07
                    Time: 10:12:25
                    Fault Frequency: 78
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:54
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:54
                    Fault Frequency: 27
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:55
                    Fault Frequency: 160
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:53
   Part No SW: 8K0 907 144 B    HW: 8K0 907 144 B
   Component: DYNAMIKLENK.  H05 0490
   Revision: 50000003    Serial number: --------------
   Coding: 0C0000
   Shop #: WSC 06334 000 00000
   VCID: 2E10D3DC79102F3485-807A
                    Fault Frequency: 68
                    Reset counter: 11
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:56
                    Count: 41
                    Count: 1
                    Hex Value: 0x0287
                    Hex Value: 0x8808
                    Hex Value: 0x0500
                    Hex Value: 0x9404
                    Fault Frequency: 65
                    Reset counter: 11
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:57
                    Count: 47
                    Count: 52
                    Hex Value: 0x0284
                    Hex Value: 0x850B
                    Hex Value: 0x3100
                    Hex Value: 0xFFFF
                    Fault Frequency: 63
                    Reset counter: 11
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:56:02
                    Count: 40
                    Count: 1
                    Hex Value: 0x05D4
                    Hex Value: 0x05D0
                    Hex Value: 0x1399
                    Hex Value: 0x8800
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:56:02
                    Count: 56
                    Count: 1
                    Hex Value: 0x0088
                    Hex Value: 0x8912
                    Hex Value: 0x0100
                    Hex Value: 0xFFFF
                    Reset counter: 11
                    Mileage: 249513 km
                    Date: 2019.06.07
                    Time: 09:59:42
                    Count: 81
                    Count: 1
                    Hex Value: 0x027E
                    Hex Value: 0x801A
                    Hex Value: 0xFFFF
                    Hex Value: 0xFFFF
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H15 0850
   Revision: 00000000
   Coding: 020000
   VCID: 2B16DAC84A025A1CA2-807E
   Part No SW: 8K0 959 760     HW: 8K0 959 760
   Component: MEM-FS        H05 0043
   Revision: AA000000    Serial number: 00001001101844
   Coding: 00581B00000000000000
   VCID: 77BE36B8C6CA2EFC16-8022
                    Fault Frequency: 157
                    Reset counter: 11
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:49
                    Fault Frequency: 8
                    Reset counter: 11
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:56:34
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H51 1100
   Revision: 00000000    Serial number: 341FI087509120
   Shop #: WSC 06342 000 00000
   VCID: 383CF5844B54E184DF-806C
   Part No SW: 8K0 907 566 B    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0040
   Revision: 00H01000    Serial number: 6PZ 009 014-13
   Coding: 0000002
   VCID: 3620FBBC414017F4CD-8062
   Subsystem 1 - Part No: 8K0 907 568 B
   Component: J0770_SWA_Slave_H01 0040
   Subsystem 2 - Serial number: 6PZ 009 014-33
   Subsystem 3 - Serial number: 5F09.07.0800H010003CD10270ÿ
   Subsystem 4 - Serial number: D10270ÿ
01024 - Rain Sensor (G213)
                    Fault Frequency: 51
                    Reset counter: 11
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:52
                    Fault Frequency: 30
                    Reset counter: 11
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:52
                    Fault Frequency: 28
                    Reset counter: 11
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:56:08
   Part No SW: 8K0 959 793 B    HW: 8K0 959 793
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007395592
   Coding: 011C13204E00410001
   VCID: 3FCE9E98AE7AD6BC1E-806A
                    Fault Frequency: 145
                    Reset counter: 11
                    Fault Frequency: 115
                    Reset counter: 11
                    Fault Frequency: 66
                    Reset counter: 11
                    Fault Frequency: 74
                    Reset counter: 11
                    Fault Frequency: 13
                    Reset counter: 11
   Revision: 00002001    Serial number: 0112218012
   Coding: 0126023A207A741500B002
   Component: GTO BF  H06 0040
   Serial number: 00000000000000037994
   Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS127  H06 0037
   Subsystem 4 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J394 PS221  H06 0037
11 Faults Found:
02771 - Bulb for Left Brake / Turn Signal / Tail Lamp (M69)
                    Fault Status: 11101100
                    Reset counter: 166
                    Mileage: 246915 km
                    Date: 2019.04.05
                    Time: 09:27:10
02772 - Bulb for Right Brake / Turn Signal / Tail Lamp (M70)
                    Reset counter: 189
                    Mileage: 246915 km
                    Date: 2019.04.05
                    Time: 09:27:12
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 167
                    Mileage: 246915 km
                    Date: 2019.04.05
                    Time: 09:42:14
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 198
                    Mileage: 246915 km
                    Date: 2019.04.05
                    Time: 11:13:45
                    Reset counter: 10
                    Mileage: 249520 km
                    Date: 2019.06.07
                    Time: 10:06:07
                    Fault Frequency: 59
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:56
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:56
                    Fault Frequency: 11
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:56:34
                    Reset counter: 10
                    Mileage: 249511 km
                    Date: 2019.06.07
                    Time: 09:57:18
                    Reset counter: 10
                    Mileage: 249511 km
                    Date: 2019.06.07
                    Time: 09:57:18
                    Reset counter: 10
                    Mileage: 249523 km
                    Date: 2019.06.07
                    Time: 10:07:54
   Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
   Component: DSP Prem      H14 0400
   Revision: 00H14003    Serial number: 34814005010101
   Coding: 030101
   Shop #: WSC 12336 024 394758
00003 - Control Module
            014 - Defective
                    Date: 2064.00.00
                    Time: 00:03:32
                    Voltage: 13.70 V
                    Temperature: 28.0°C
                    Temperature: 28.0°C
                    Bin. Bits: 00000100
                    Bin. Bits: 00000100
                    Bin. Bits: 00000000
                    Reset counter: 11
                    Mileage: 249515 km
                    Date: 2019.06.07
                    Time: 10:01:32
                    Voltage: 13.90 V
                    Temperature: 32.0°C
                    Temperature: 33.0°C
                    Bin. Bits: 00000100
   Part No SW: 8K0 959 792 B    HW: 8K0 959 792
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000007399202
                    Fault Frequency: 8
                    Reset counter: 249
                    Mileage: 246915 km
                    Date: 2019.04.05
                    Time: 09:42:14
                    Fault Frequency: 134
                    Reset counter: 11
                    Fault Frequency: 159
                    Reset counter: 11
                    Fault Frequency: 21
                    Reset counter: 11
                    Fault Frequency: 26
                    Reset counter: 11
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 10000000054830
   VCID: 312AC8A0682E30CC98-8064
                    Fault Frequency: 107
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:56:03
                    Voltage: 13.90 V
                    Count: 58
                    Speed: 76.0 km/h
                    Hex Value: 0x0270
                    Hex Value: 0x0004
                    Hex Value: 0x0101
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:51
                    Voltage: 13.90 V
                    Count: 86
                    Speed: 80.0 km/h
                    Hex Value: 0x0270
                    Hex Value: 0x0004
                    Hex Value: 0x0101
                    Fault Frequency: 53
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:51
                    Voltage: 13.90 V
                    Count: 68
                    Speed: 78.0 km/h
                    Hex Value: 0x0260
                    Hex Value: 0x0004
                    Hex Value: 0x0101
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000005
   VCID: 3424C1B4573C05E4F3-8060
                    Reset counter: 11
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:54
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 357EQ087505243
   Coding: 0000002
   Part No SW: 8K0 959 795     HW: 8K0 959 795
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000007388581
   Coding: 010C13204000210001
   VCID: 7F4EDE98EEFA16BC5E-802A
Address 65: Tire Pressure (J502)       Labels:. 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 12926780826357
   Coding: 0CD154
                    Reset counter: 12
                        Not Recogn.
                    Bin. Bits: 00001000 00100101
                    Voltage: 14.00 V
                    Text:   -50°C;n.erkannt;     n.erkannt
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H46 0630
   Revision: 00000000    Serial number: 00000806240066
                    Fault Status: 00110100
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:57
                    Fault Status: 00110000
                    Reset counter: 10
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:57
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J889143
   Coding: 1000006
   Shop #: WSC 02145 785 00200
   VCID: 373EF6B8464AEEFCD6-8062
                    Reset counter: 11
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:49
                        Reverse OFF
                    Count: 3
   Part No SW: 8K9 827 851     HW: 8K9 827 851
   Component: J605  Master  H24 0220
   Revision: --------    Serial number: 8K9827851
   Subsystem 1 - Part No SW: 8K9 827 852     HW: 8K9 827 852
   Component: J756  Slave  H24 0220
   Serial number: 8K9827852
16347 - Control Module - EEPROM Error
            014 - Defective
                    Reset counter: 166
                    Mileage: 246915 km
                    Date: 2019.04.05
                    Time: 09:25:59
                    Fault Frequency: 38
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:49
                    Fault Frequency: 28
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:49
                    Mileage: 249510 km
                    Date: 2019.06.07
                    Time: 09:55:49
                    Fault Frequency: 162
   Part No SW: 8K0 959 794     HW: 8K0 959 795
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000007350547
   VCID: 7EB0239CE9F01FB455-802A
   Part No SW: 4F0 910 336 G    HW: 4E0 862 335
   Component: Handyvorb2      H20 1120
   Revision: 00000000    Serial number: 00000005046533
   Coding: 0010900
   VCID: 271E26F896EA7E7C46-8072
End----------(Elapsed Time: 02:37, VBatt start/end: 12.1V/12.1V)-----------
After clearing codes I get this.
Thursday,11,July,2019,01:20:46:01898
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN:    License Plate: REDAUDI
                Address 01: Engine       Labels: 06H-907-115-CAB.clb
Control Module Part Number: 8K2 907 115 AL    HW: 8K2 907 115 D
  Component and/or Version: 2.0l R4/4V TF H12 0001
           Software Coding: 010C010A190F0160
            Work Shop Code: WSC 06449 444 84029
              ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001 (AU48)
                      VCID: 79BA3080F8DE3887DE-802C
          U1113 00 [039] - -
                    Mileage: 249561 km
                    Date: 2019.06.10
                    Time: 00:32:43
                    Engine speed: 0.00 /min
                    Coolant temperature: 25 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 12.015 V
          U1113 00 [039] - -
                    Mileage: 249561 km
                    Date: 2019.06.10
                    Time: 00:32:43
          U0140 00 [038] - No Communications
                    Mileage: 249561 km
                    Date: 2019.06.10
                    Time: 01:08:13
                    Voltage terminal 30: 11.921 V
          U0199 00 [038] - No Communications
                    Mileage: 249561 km
                    Date: 2019.06.10
                    Time: 01:08:12
          U0164 00 [038] - -
                    Mileage: 249561 km
                    Date: 2019.06.10
                    Time: 01:08:11
          U0141 00 [038] - No Communications
                    Mileage: 249561 km
                    Date: 2019.06.10
                    Time: 01:08:11
Readiness: 1110 0101
                Address 16: Steering wheel       Labels: 8K0-953-568.clb
Control Module Part Number: 8K0 953 568 G    HW: 8K0 953 568 G
  Component and/or Version: Lenks.Modul   H12 0013
           Software Coding: 000017
            Work Shop Code: WSC 06335 000 00000
                      VCID: 3E30E39CA970DFBFAB-806A
                    Reset counter: 11
                    Mileage: 249561 km
                    Date: 2019.06.10
                    Time: 01:08:10
                    Reset counter: 11
                    Mileage: 249561 km
                    Date: 2019.06.10
                    Time: 01:08:10
                    Reset counter: 11
                    Mileage: 249561 km
                    Date: 2019.06.10
                    Time: 01:08:10
                    Reset counter: 11
My money is on some kind of power problem, perhaps a power supply relay being wonky. But I don't see enough of a pattern to be able to narrow it down much. If it were mine, I would start by investigating why module 10-Park/Steer Assist is off-line completely.
Audi S-4
C?ID=303575
Ok I will look into this tomorrow. I am very green with the VCDS but will give it a go!
