Audi RS4 AFS Removal/Delete Coding
Mark Hudson
C?ID=290534
Hi, I am looking for some advice on a vehicle which should have AFS headlamps installed however they have been replaced with non-AFS units after accident damage. The instrument panel currently displays "Audi Adaptive lights Malfunction", I would like to code out the AFS thus removing the error. I would be grateful if anyone could advise me on how to do this correctly, I have attached an Autoscan of the vehicle, please bear in mind that this is a facelift B8.5 and thus doesn't have the separate headlamp range control module (55) and it is instead part of the Central Electrics Control Module (09) which has an extremely long long coding...
Thursday,11,July,2019,20:53:42:21133
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
Dealer/Shop Name: Jon-Son Motors
Workshop Code: 210 01642 000002
VIN: WUAZZZ8K6DA900167   License Plate: RS4
Mileage: 52080km-32361mi   Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 1B 22 30 42 44 46 47 52 53
          56 5F 62 72
VIN: WUAZZZ8K6DA900167   Mileage: 52080km-32361miles
Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
   Part No SW: 8T2 907 560     HW: 8T1 907 560
   Component: 4.2l V8HDZ /  H04 0003
   Revision: NAH04---
   Coding: 1225003225A6080A2000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM42FSI0118T2907560 001006
   ROD: EV_ECM42FSI0118T2907560.rod
   VCID: 79BA3E4DF88BDF87DE-802C
4366 - ROD - Unknown Error Code
          - 00 [032]
                    Mileage: 52087 km
                    Date: 2019.07.09
                    Time: 17:02:22
                    Engine speed: 1631.50 /min
                    Normed load value: 63.9 %
                    Coolant temperature: 29 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 13.075 V
                    CAN status - engine control module-Bits 0-7: 00000000
                    CAN status - transmission control module-Bits 0-7: 00000000
                    CAN status - brake control module 1-Bits 0-7: 00000000
                    CAN status - brake control module 2-Bits 0-7: 00000000
                    selected gear-Bits 0-7: 00000010
                    Cruise control switch actuation-Bits 0-7: 00000000
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [040] - -
                    Fault Frequency: 8
                    Mileage: 51985 km
                    Date: 2019.06.27
                    Time: 22:27:38
                    Engine speed: 1935.50 /min
                    Normed load value: 29.8 %
                    Coolant temperature: 45 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 11.449 V
                    Unlearning counter according OBD: 35
                    AFS dm: 34.3 kg/h
                    Median injection timing: 0.581 ms
                    Engine operating condition-Channel 87: Idling
                    Relative load value: 13.36 %
                    Tumg: 18.8 °C
                    Psr w: 306.41 hPa
                    Engine torque: 30.3 Nm
Readiness: 0010 0000
   Part No SW: 8K5 927 156     HW: 0B5 927 156 J
   Component: 0B5 42 FSIRdW H01 0003
   Revision: --H01---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001010
   ROD: EV_TCMDL501021.rod
   VCID: 76A03571C995B0FFB3-8022
17598 - Selector Lever Sensor
          P179E 00 [032] - Electrical Malfunction
                    Reset counter: 34
                    Mileage: 52056 km
                    Date: 2019.06.29
                    Time: 22:31:09
                    Engine speed: 4820 /min
                    Transmission input speed: 4820 /min
                    Transmission output speed: 939 /min
                    Engine torque: -92 Nm
                    Transmission fluid temperature: 93 °C
                    Accelerator position: 0.0 %
                    Clutch status: Kupplung 2 kann Moment übertragen
                    Unlearning counter according OBD: 34
   Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
   Component: ESP8 quattro  H09 0100
   Coding: 346D6A
   VCID: 45C282BDCCF36B67EA-8010
02214 - Tire Pressure Warning
                    Reset counter: 92
                    Mileage: 52050 km
                    Date: 2019.06.29
                    Time: 22:22:01
                    Hex Value: 0x1A00
                    Hex Value: 0x4006
                    Hex Value: 0x1223
                    Hex Value: 0x18B3
                    Hex Value: 0x0000
                    Reset counter: 98
                    Mileage: 52087 km
                    Date: 2019.07.09
                    Time: 16:16:19
                    Hex Value: 0x0000
                    Hex Value: 0x00A2
                    Hex Value: 0x0021
                    Hex Value: 0x4093
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 GE    HW: 8K0 907 064 FE
   Component: BCM2 2.0      H11 0621
   Coding: 01924000000000000000
   VCID: 79BA3E4DF08BDF87DE-802C
   Subsystem 1 - Part No SW: 8K0 959 754 CD    HW: 8K0 959 754 CD
   Serial number: 0512000079101009
   Serial number: 2312000126463013
   Part No SW: 8K2 820 043 T    HW: 8K2 820 043 T
   Revision: D1000000    Serial number: 01050720120314
   Coding: 4804000000
   VCID: 3A38E141B50D149F97-806E
                    Reset counter: 94
                    Mileage: 51945 km
                    Date: 2019.06.26
                    Time: 11:17:20
                    Temperature: 24.0°C
                    Temperature: 100.0°C
                    Absolute Pres.: 1.2 bar
                    RPM: 640 /min
                    Current: 0.000 A
                    Temperature: 27.0°C
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000444855201
   Coding: 260000108034AFC00081400300001D0D0F1D438827090201000008004400030200000034000000
   Shop #: WSC 01642 210 00002
   VCID: 7AB82141F58DD49FD7-802E
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 110712  H06 0080
   Serial number: SWF12070115447
   Coding: 00FD11
   Serial number: 20409522
   Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002506120085
   Serial number: F2688936000000000001
03977 - Local Data Bus 5
                    Reset counter: 58
                    Mileage: 52087 km
                    Date: 2019.07.11
                    Time: 20:30:51
02658 - Power Output Stage for Left Headlight (J667); Incorrectly Coded
                    Reset counter: 58
                    Mileage: 52087 km
                    Date: 2019.07.11
                    Time: 20:50:14
02659 - Power Output Stage for Right Headlight (J668); Incorrectly Coded
                    Reset counter: 58
                    Mileage: 52087 km
                    Date: 2019.07.11
                    Time: 20:50:14
02233 - Left Headlight Power Output Stage (J667)
                    Reset counter: 58
                    Mileage: 52087 km
                    Date: 2019.07.11
                    Time: 20:50:17
02234 - Right Headlight Power Output Stage (J668)
                    Reset counter: 58
                    Mileage: 52087 km
                    Date: 2019.07.11
                    Time: 20:50:17
Address 14: Susp. Elect.        Labels: None
   Part No SW: 8T0 907 376     HW: 8T0 907 376 A
   Component: J250 DRC FahrwerH01 0020
   Revision: 00000000    Serial number: 00875000259800
   Coding: 0000000
   Shop #: WSC 05912 003 1048576
   VCID: 7CB427593FB9EAAFC5-8028
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD949GNQ
   Coding: 30544435363030303030554A3052384B3053
   Shop #: WSC 57638 001 1048576
   VCID: 48DC8B89F3E1760F11-801C
   Serial number: 6334MSME423C6C3CR
   Serial number: 6344MSME71436B006
   Serial number: 6352QSME1D1B3668Q
   Serial number: 6362QSME001A3972A
   Serial number: 63732SME5F5F1C7CS
   Serial number: 63832SME5D5F1E5CR
          B1006 1B [137] - Resistance Too High
                    Mileage: 51945 km
                    Date: 2019.06.26
                    Time: 11:17:24
9438491 - Igniter for Driver head airbag
          B1005 1B [137] - Resistance Too High
                    Mileage: 51945 km
                    Date: 2019.06.26
                    Time: 11:17:24
9438235 - Igniter for Front passenger's Head Curtain Airbag
          B1004 1B [137] - Resistance Too High
                    Mileage: 51945 km
                    Date: 2019.06.26
                    Time: 11:17:24
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20120716000406
   Coding: 000037
   VCID: 51EAA6ED08BBB7C746-8004
   Component: E221 - MFL  H03 0003
   Part No SW: 8K0 920 982 J    HW: 8K0 920 982 J
   Component: KOMBIINSTR.   H35 0553
   Revision: 00000000    Serial number: RBZ394C7D
   Coding: 33AF1100B3012600010000
   VCID: 3B36E445BA372D978C-806E
   Part No SW: 8R0 907 468 H    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0051
   Revision: 1Y050025    Serial number: 2541Y127020419
   Coding: 80E3031600
   VCID: 44C49FB9C7C9526FFD-8010
   Serial number: 5532867701
                    Reset counter: 98
                    Mileage: 52087 km
                    Date: 2019.07.11
                    Time: 19:10:46
                    Bin. Bits:    10111
                    Voltage: 11.60 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Part No SW: 8K0 907 144 J    HW: 8K0 907 144 J
   Component: DYNAMIKLENK.  H06 0690
   Revision: 52001005    Serial number: --------------
   Coding: 030000
   VCID: 3620F5718115F0FF73-8062
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H13 0100
   Serial number: 000107120001000
   VCID: 2F2EC015764FC13730-807A
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440 B    HW: 8K0 907 440
   Component: STS           H04 0020
   Revision: S0H04000    Serial number: 00000000063191
   Coding: 01010101000000000001000102
   VCID: 2D12DA1D7443B32702-8078
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C02205C21410001
   VCID: 56E055F12155D0FF93-8002
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0029547542
   Coding: 010000010001
   Shop #: WSC 06324 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3424CF799F69E2EF4D-8060
   Revision: 00002001    Serial number: 0180054560
   Coding: 013B062220B908808030023280000000
   Revision: 00005001    Serial number: 94813004601102
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000033966898
   VCID: 4ED0BD911985A83F5B-801A
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 20000000116374
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 383CFB498301068F61-806C
   Part No SW: 4G0 035 061 E    HW: 4G0 035 061
   Component: Radio U DAB   H60 0099
   Revision: AB001007    Serial number: 109G-0C7571641
   Coding: 010103010000000001
   VCID: 1F0E30D50EEF51B780-804A
   Part No SW: 8R2 035 670 C    HW: 8R2 035 670 C
   Component: H-BNT-EU      H44 0524
   Revision: --------    Serial number: 208GU0C7501570
   Coding: 120101010306A1FF05808B5E00000403040000000000000000
   VCID: 3424CF799769E2EF4D-8060
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130G80CS209382
   Subsystem 3 - Part No SW: 8T0 919 611 H    HW: 8T0 919 611 H
   Component: E0380 Bedient  H02 0020
   Serial number: 00000001206095
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
                    Reset counter: 98
                    Mileage: 52087 km
                    Date: 2019.07.11
                    Time: 20:30:20
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 10000000
   Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000034133757
   Coding: 010C02204021210001
   VCID: 43C69CA5C2C75557C4-8016
                    Reset counter: 91
                    Mileage: 52030 km
                    Date: 2019.06.28
                    Time: 18:48:39
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HR        H07 0305
   VCID: 59FA5ECD504BFF87BE-800C
End----(Elapsed Time: 01:56, VBatt start/end: 11.5V/11.5V. VIgn 11.6V)-----
Thanks In Advance
Mark
NEtech
Denmark
C?ID=56995
Try if this should work, remove Bit 1 Byte 31 in [09]
260000108034AFC00081400300001D0D0F1D438827090201000008004400030000000034000000
Mark Hudson
C?ID=290534
Thanks, that seems to have done the trick however the lights do not auto level anymore, is this how they are now and there is no way to get the auto level working again?
Mark
NEtech
Denmark
C?ID=56995
Okay, does it maybe change if you try this:
[09] > Adaptation > Channel 18
I guess you have the value 255
What happens if you save: 253
or 252
Mark Hudson
C?ID=290534
or 252
I tried this it still didn't make the lights move up and down on startup (auto level motor check) which i presume means the auto level is still not operational. Channel 18 did have 255 stored as you anticipated. I have also discovered that there is now an error stored in the ABS module which is as follows:
                Address 03: ABS Brakes       Labels: 8K0-907-379-V1.clb
Control Module Part Number: 8T0 907 379 F    HW: 8T0 907 379 F
  Component and/or Version: ESP8 quattro  H09 0100
           Software Coding: 346D6A
            Work Shop Code: WSC 01642 210 00002
                    Reset counter: 59
                    Mileage: 52086 km
                    Date: 2019.07.13
                    Time: 19:20:04
                    Hex Value: 0x0000
                    Hex Value: 0x07A2
                    Hex Value: 0x0021
                    Hex Value: 0x4091
                    Hex Value: 0x0000
Please let me know if you have any other ideas.
Thanks Again
Mark
NEtech
Denmark
C?ID=56995
Reverse the Coding in Byte 19 and leave 253 in Channel 18
Mark Hudson
C?ID=290534
Sorry for the delay in reply... Could you clarify what you mean by 'reverse the coding in byte 19?
Mark
NEtech
Denmark
C?ID=56995
This was your original:
This was the changed
Go back and use the original, with 02 in Byte 31.
The Byte 19 was an typo, sorry.
Mark Hudson
C?ID=290534
Ok, I have reverted the coding and tried with both 253 and 252 in channel 18 but the lights do not perform the auto level test on start up still and the error for the adaptive lights has re-appeared on the dash...
Mark
I wonder if you may need to use Basic Settings 011 in conjunction with the suggestions from NEtech. For instance, if a this car was repaired with factory headlights it wouldn't be uncommon to have
.. prior to Xenon Basic Settings in BCM1/09-Cent. Elect. (J519) controller:
http://wiki.ross-tech.com/wiki/inde...ngs_in_BCM1/09-Cent._Elect._(J519)_controller
For that reason it may require BS before the new settings function properly?
