Golf MK7 UK Car ABS Coding (MK100IPB)
Dr Sheldon
Windsor UK
HC433554 (2nd hand?)
As you can see from the scan this has been through the wars.
Lots of faults but my job is to just code the ABS. It may have had a new module but I'm not sure.
Strange thing the coding is set at all Zero's
Can anyone help me with this.
thanks.
Thursday,11,July,2019,15:51:27:36704
VCDS Version: 19.6.1.0 (x64)  HEX-V2 CB: 0.4505.4
VIN: WVWZZZAUZGW047602   License Plate: DG65RXF
Mileage: 104232km-64766mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZGW047602   Mileage: 104232km-64766miles
44-Steering Assist -- Status: Cannot be reached 0100
Address 01: Engine (2D2D2-CXXB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 CL    HW: 04L 907 445 B
   Component: R4 1.6l TDI   H06 2370
   Revision: 22004001
   Coding: 0111401243451D092000
   ASAM Dataset: EV_ECM16TDI03004L906056CL 002005
   ROD: EV_ECM16TDI03004L906056_002_VW37.rod
   VCID: 79AF11A11951A4CF8D7-802C
25807 - No Communication with ABS Brake Control Module
          U0121 00 [163] - -
          [Lost Communication WithAnti-Lock Brake System (ABS) Control Module]
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:07
                    Engine speed: 0.00 /min
                    Coolant temperature: 24 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 12.500 V
                    Accelerator pedal travel: raw value: 0.00 %
                    Cruise Control System (CCS): status: ERROR
                    selected gear: Shifting process active
25809 - Power Steering Control Module
          U101D 00 [035] - No Communication
          [Power steering control moduleNo communication]
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:07
14095 - Implausible Data Received from Parking Brake Control Module
          U0417 00 [035] - -
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:06
                    Camshaft speed (RPM): 0 /min
                    Camshaft adaptation intake bank 1: phase position: -0.4 °
23902 - Diesel Particle Filter
          P2463 00 [163] - Excessive Soot Accumulation
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:07
                    Voltage terminal 30: 12.492 V
                    Counter for regeneration time of diesel particle filter: 4082 s
                    Particle filter: kilometers since last regeneration: 6553.5
                    Particle filter: soot mass measured: 0.43 g
                    Particle filter: soot mass calculated: 59.99 g
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: -1.8 mbar
                    Particle filter: field regeneration lock status: 0
Readiness: N/A
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 61755000001691
   Shop #: WSC 00078 790 12345
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
11 Faults Found:
0166 - Steering angle sensor
          B1168 31 [137] - No Signal
                    Reset counter: 14
                    Date: 2019.07.10
                    Time: 00:43:05
0195 - Control module not coded
          U1013 00 [137] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 14
                    Date: 2019.07.10
                    Time: 00:43:05
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 14
                    Date: 2019.07.10
                    Time: 00:43:05
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 14
                    Date: 2019.07.10
                    Time: 00:43:05
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 14
                    Date: 2019.07.10
                    Time: 00:43:05
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 14
                    Date: 2019.07.10
                    Time: 00:43:05
4161 - Coding invalid
          U10DA 00 [008] - -
          [mismatch between VIN on CAN and VIN in coding word]
                    Reset counter: 54
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:45:43
8306 - Databus
          U1122 00 [137] - Implausible Message
          [FCAN: Unplausible VIN number]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:10
8308 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
                    Reset counter: 14
                    Date: 2019.07.10
                    Time: 00:43:05
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [009] - -
          [FCAN: Coding of ESP and TSK does not fit together]
                    Reset counter: 14
                    Date: 2019.07.10
                    Time: 00:43:05
32848 - Control Module for Electric Parking Brake
          C10E2 F1 [137] - Switches/Motors Detected
                    Reset counter: 14
                    Date: 2019.07.10
                    Time: 00:43:05
   Part No SW: 5G0 907 426 T    HW: 5G0 907 426 T
   Component: AC Manuell    H02 1001
   Revision: 00001K06
   Coding: 00120104202100001000000000000002
   VCID: 3C21C8B556E351E7D61-8068
   Part No SW: 5Q0 937 084 AQ    HW: 5Q0 937 084 AL
   Component: BCM MQBAB M   H24 0173
   Serial number: 01061517302012
   Coding: 03000842C241027B0BA44080B10403281000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 074B67595FA5C23F8B3-8052
   Component: WWS    150610  042 0551
   Serial number:         150617010331
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y15M06D29H16M55S41
   Coding: 90A8DD
   Component: Sensor, DWA  006 0326
   Serial number: 000000000ZY151392L95
   Serial number: 00000000000032653150
555285 - Databus
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:49:35
556053 - Databus
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:49:35
   Revision: --------    Serial number: 39391517504168
   Coding: 0071051001
   VCID: 43D3B3492B1D2E1F97B-8016
12658704 - Databus
          [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:05
13637426 - Databus
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:05
13638913 - Databus
          [Steuergerät für Lenkhilfe-J500 - LH_EPS_03 - kein Signal/keine Kommunikation]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:05
13638914 - Databus
          [Steuergerät für Lenkhilfe-J500 - LWI_01 - kein Signal/keine Kommunikation]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:05
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 23051503212853
   Coding: 00000300FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3A2DCEAD5CD76FD7C4D-806E
1071 - Databus
          [FAULT_CIS_AXV_INVALID]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:04
                    Control Module temperature: 31 °C
                    Voltage terminal 15: 12.1 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:04
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:04
0261 - Databus
          [FAULT_CIM_TIMEOUT_EPB_01]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:04
0275 - Databus
          [FAULT_CIM_TIMEOUT_LWI_01]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:04
1043 - Automatic Distance Control
          B10E7 F0 [009] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:04
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    015 0388
   Serial number: 003MLR0W7V2G
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F5BFFB907758AFFB33-802A
   Belt Pretensioner left:
   Serial number: 34169677B29061541029
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676B29061511418
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 306 15
   Serial number: 35767000000FF821351Z
   Subsystem 4 - Part No SW: -----------    HW: 480 002 306 15
   Serial number: 358670000006CA4DF418
   Subsystem 5 - Part No SW: -----------    HW: 480 402 306 15
   Serial number: 3516502991A14CC3E04F
   Subsystem 6 - Part No SW: -----------    HW: 480 402 306 15
   Serial number: 3526502AD1C52F3303FJ
   Subsystem 7 - Part No SW: -----------    HW: 480 401 706 15
   Serial number: 3556502BB1B5A872D15P
          B13BC F2 [137] - No function
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:49:53
1049093 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Querbeschleunigung]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:49:53
1050112 - Databus
          [NWD: 0x086 LWI_01 Timeout]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:49:53
1049094 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:49:53
1049095 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Gierrate]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:49:53
   Part No SW: 5Q0 953 507 GK    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 24061504400249
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 05576D5165A9D02FF9F-8050
   Part No SW: 5G1 920 941 A    HW: 5G1 920 941 A
   Component: KOMBI         207 7640
   Coding: 27A41A002780260001882A011400000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009005
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: 270B07D9BF65E23FAB3-8072
16776967 - Databus
          [EPB_02 keine Kommunikation]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:04
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:04
16776978 - Databus
          [LH_EPS_01 keine Kommunikation]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:43:05
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1224
   Revision: --------    Serial number: 0003649936
   Coding: 030100041F087300FB00005C080F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 75B71D913549C0AFE9F-8020
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150001335990025264
   Coding: 2CFFFF
   Serial number: 2411587003
131602 - Power Steering Control Module
          U101D 00 [009] - No Communication
          [Timeout Knoten 0x12 / 44 - Steuergerät für Lenkhilfe]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:47:47
                    Supply voltage: Terminal 30: 12.3 V
                    Terminal 15: On
   Serial number: 040615BF20771A
   Coding: 00310220D001048000001000
   Serial number: 00000000000001499227
   Coding: 1D0000
Address 44: Steering Assist
   Serial number: 260615BFQ05425
   Coding: 00310020DE01048000801000
   VCID: 42DDB64D340727179CD-8016
   Serial number: 00000000000006538310
   Coding: 150000
   Part No SW: 3Q0 035 820 A    HW: 3Q0 035 820 A
   Component: MU-S-D-ER     523 0627
   Coding: 02730000FF00000051111101008808001F0100C60120010001
   ROD: EV_MUStd4CDELP_VW37.rod
   Subsystem 1 - Part No SW: 3G0 919 605     HW: 3G0 919 605
   Component: ABT_Std-2  H52 1031
   Serial number: VWZ8Z9REL005NB
          U1111 00 [009] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:47:13
                    Voltage terminal 30: 12.4 V
                    BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 14
                    Mileage: 104232 km
                    Date: 2019.07.10
                    Time: 00:47:13
End----------(Elapsed Time: 01:29, VBatt start/end: 12.5V/12.5V)-----------
Dr Sheldon
Windsor UK
Is it possible to get any direction with this please.
United States
Hi George,
We received your email however I cannot build that coding for you. Although you will eventually need 03-ABS coding I'm concerned with the extended DTC info which includes
[FCAN: Unplausible VIN number]​
Those make me suspect someone swapped Immo/VIN related modules at one point in time. Make sure the diagnostic VINs shown under the Advanced ID function in both 01-Engine and 17-Instruments match the car. If they don't that will need to be addressed before ABS coding is possible.
