08 Autohvac malfunction (Air Quality Sensor)
Chiefegghead
C?ID=184246
Hello please could someone tell me is this fault which is coming up is anything to worry about as when I clear it it come back on.
Thanks.
Thursday,11,July,2019,15:25:32:05033
VIN: WVGZZZ5NZGW812109   License Plate: MD16LYU
Mileage: 25283km-15710mi   Repair Order: Getting autohvac fault
Chassis Type: 5N-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 42 44 52 55
          5F 6C 6D 82 A5 BB BC CA D6 D7
VIN: WVGZZZ5NZGW812109   Mileage: 25283km-15710miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 EH    HW: 04L 907 309 M
   Component: R4 2.0l TDI   H23 2950
   Revision: B4H23---
   Coding: 0125003203671D083000
   ASAM Dataset: EV_ECM20TDI01104L906026EH 004002
   ROD: EV_ECM20TDI01104L906026EF_004.rod
   VCID: 74B1DD4B1E3A1537DE1-8020
   Part No SW: 0DL 300 011 A    HW: 0DE 927 711
   Component: GSG DQ500     H12 1406
   Revision: 00H12V32
   VCID: 2615F703986637A7905-8072
   Part No SW: 5Q0 614 517 BH    HW: 5Q0 614 517 AD
   Component: ESC           H25 0507
   Revision: 00000000    Serial number: 60956000001281
   Coding: 0AEE929A34210B6E4778670062CC4950492CD0E2E646927D38625078C22A02
   VCID: 78A9E97B02527157F29-802C
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0710
   Revision: 00036000    Serial number: 0401705353
   Coding: 030C0C0F03
   VCID: 3A2D33737CDEA347C4D-806E
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98025967
   Part No SW: 5NC 907 044     HW: 5NC 907 044
   Component: AC Automat    H34 3902
   Revision: 20K07000    Serial number: 00000B00101934
   Coding: 00120124202110011105100C0010110A
   ASAM Dataset: EV_ACClimaPrehVW37X 002013
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 7EA5FF6320764F67B85-802A
   Subsystem 1 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
   Component: E265KlimaHeck  H02 0201
263425 - Air Quality Sensor
          B10AF 04 [009] - Internal System Fault
                    Reset counter: 193
                    Mileage: 25272 km
                    Date: 2019.07.11
                    Time: 13:29:23
                    Outside air temperature: 19.5 °C
                    Voltage terminal 30: 14.3 V
                    System run time-Engine running time: 253 s
                    Air quality status: ERROR
   Part No SW: 5Q0 937 084 BQ    HW: 5Q0 937 084 BQ
   Component: BCM MQBAB H   H32 0212
   Serial number: 00021611100453
   Coding: 03D11E46C24112FB17844094B11C172C1880000000000000000000000000
   ASAM Dataset: EV_BCMMQB 016001
   ROD: EV_BCMBOSCH_016_VW37.rod
   VCID: 084999BB72B201D7829-805C
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 160319  033 0372
   Serial number: 00000001603160302585
   Component: RLHS  037 0059
   Serial number: S4Y16M04D28H11M25S16
   Coding: 00A8DD
   Serial number: 000000000ZY1608213BL
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000065695698
   Part No SW: 3Q0 919 298     HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0152
   Serial number: 002004167478070
   Coding: 0331263851
   ASAM Dataset: EV_EPHBO2CVW3260000 010015
   ROD: EV_EPHBO2CVW3260000.rod
   VCID: 7AADF3733C5E634784D-802E
   Part No SW: 2Q0 907 572 H    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0155
   Coding: 320147C358FF8728749C806D304085
   ASAM Dataset: EV_ACCMRRCONTIVW376 001010
   ROD: EV_ACCMRRCONTIVW376_001.rod
   VCID: 392F2C7F79D8A85FCD7-806C
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2HR82%
   Coding: 98CCC0C00C0000005C5400CF008800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 1079B1DB0AE249175A9-8044
   Belt Pretensioner left:
   Serial number: 5NC857705C0113Q01277
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 5NC857706C0112Q00388
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 002 004 16
   Serial number: 357000000002F25C9A1S
   Subsystem 4 - Part No SW: -----------    HW: 480 002 304 16
   Serial number: 358000000008F7BCBA15
   Subsystem 5 - Part No SW: -----------    HW: 480 402 004 16
   Serial number: 3510001B9209F101055P
   Subsystem 6 - Part No SW: -----------    HW: 480 402 004 16
   Serial number: 3520001B9209F105344V
   Subsystem 7 - Part No SW: -----------    HW: 480 402 004 16
   Serial number: 3550001C520A94F4232$
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 504 16
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001B72080C23B85$
   Subsystem 9 - Part No SW: -----------    HW: 480 402 504 16
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001BB2080C21D5D6
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 480 402 504 16
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001BB2080C21939V
   Subsystem 11 - Part No SW: -----------    HW: 480 001 104 16
   Serial number: I0M00000000A80348A1+
   Subsystem 12 - Part No SW: -----------    HW: 480 001 104 16
   Serial number: I0N00000000633F06A1%
   Part No SW: 3Q0 953 521 AN    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0205
   Revision: FF034034    Serial number: 20160413501553
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7CA1F56B366A5D77961-8028
   Part No SW: 5NA 920 791     HW: 5NA 920 791
   Component: KOMBI         119 1443
   Coding: 27A50018EF84260001886B031401000000000000
   VCID: 55F780CFF5806C3FC9F-8000
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004784583
   Coding: 030500041F087300FB03225E1E0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 79AFEC7F3958685F8D7-802C
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 0981609395901168AP2B
   Coding: 2F0000
   Subsystem 3 - Part No SW: 5QA 915 181 B    HW: 5QA 915 181 B
   Component: J367-BDMHella  H10 9052
   Serial number: 8278749903
   Serial number: HA1-00009.03.16
   Coding: 0101
   VCID: 4ACD63B32C3E33C754D-801E
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH05 0012
   VCID: 45D7508F0520DCBFB9F-8010
   Serial number: 16000078756014
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD45F6128201F357-8024
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 220316ECJ10115
   Coding: 003F1A20D001048000001000
   VCID: 43D34E970B14E28F97B-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   Serial number: 020416ED130411
   Coding: 003F1020DE01048000001000
   VCID: 42DD4B93140EEB879CD-8016
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0051
   Coding: 08AE00104B210201
   ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
   VCID: 41DF449F1108F09F857-8014
   Part No SW: 3G0 035 020 C    HW: 3G0 035 020
   Component: MU-H-ND-EU    H50 0343
   Serial number: A682D0GB020222
   Coding: 02730601FF00000051111101008808001F0100E6012000009F
   VCID: 176BCAC72F0C9E2F1B3-8042
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL00Q1Y
   Subsystem 2 - Part No SW: V03 959 800 QT    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Compact Disc Database:
   Component: Gracenote2  --- 1012
   Part No SW: 5Q0 907 556 A    HW: 5Q0 907 556
   Component: Areaview 2    H11 0422
   Serial number: C854706JG015035
   Coding: 01230601A20F200000204014
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 005013
   ROD: EV_CamSysRVAV2ARCE2MQBAB_005_VW37.rod
   VCID: 372B2A474FCCBE2F3B3-8062
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30636838400000
   Coding: 0A08
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   VCID: 3FDB426767FC866FF33-806A
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 5NA 919 608 A    HW: 5NA 919 608 A
   Component: HeadupDisplay 015 0207
   Coding: 574060
   ASAM Dataset: EV_HeadUpDisplContiVW481 001013
   ROD: EV_HeadUpDisplContiVW481.rod
   VCID: 46D557833826D7A7B05-8012
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0220
   Serial number: 19041611P22768
   Coding: 000307060000040100022344C050A10094000E200040
   Serial number: 110316EC90271C
   Coding: 002A10200100048000001000
   Serial number: 100316EC90233C
   Part No SW: 4M0 907 594 D    HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Coding: 308040732602
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 1675C7C32806A727005-8042
   Component: LED1R         H09 0003
   ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 02:09, VBatt start/end: 12.9V/12.9V)-----------
IMO, no, that's not a serious problem. I think that all this sensor is used for is to switch from outside air to recirculated air if it determines the air quality is poor.
Chiefegghead
C?ID=184246
Thanks appreciate the reply put my mind at rest.
