Audi Q7 2012. 3.0 TDi 245hk
Nebrot
Norway
C?ID=337027
Hello!
Wondering if you could help me with these codes?
Also preheat (Glow plug light) is flashing.
Do you have any idea?
Saturday,06,July,2019,13:34:44:04159
VCDS Version: Releasen 19.6.1 (x64) Running on Windows 10 x64
                Address 02: Auto Trans       Labels: 0C8-927-750.clb
Control Module Part Number: 0C8 927 750 AL    HW: 0C8 927 750 AL
  Component and/or Version: AL1000 AISIN  001 1977
           Software Coding: 001578
            Work Shop Code: WSC 31414 790 00001
              ASAM Dataset: EV_TCMAL991031 001001 (AU56)
                       ROD: EV_TCMAL991031_001_AU56.rod
                      VCID: 76B51AAC18463E47E05-8022
12782 - Transmission Range Sensor (F125)
          P0706 00 [032] - Implausible Signal
                    Reset counter: 32
                    Engine speed: 690.0 /min
                    Transmission input speed: 630 /min
                    Engine torque: -12 Nm
                    Transmission fluid temperature: 58 °C
                    Accelerator position: 0.0 %
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Open
                    EOP failure status 2: Normalcy
                    EOP target revolution: 0 /min
                    EOP actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    EOP failure status with EOP without HV 1: Motor normal stop
                    EOP target current: 65278 mA
12753 - Valve for Transmission Fluid Cooler
          P2755 00 [237] - Short to Plus
                    Reset counter: 43
                    Engine speed: 1800.0 /min
                    Transmission input speed: 1800 /min
                    Transmission output speed: 1470 /min
                    Engine torque: 120 Nm
                    Transmission fluid temperature: 34 °C
                    Accelerator position: 22.8 %
                    Clutch_C1: Close
                    Clutch_C2: Close
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Close
Have you checked wiring diagrams to see what the Transmission Range Sensor (F125) and the Valve for Transmission Fluid Cooler have in common?
Nebrot
Norway
C?ID=337027
Do you know where I can find wiring diagrams for my car?
Nebrot
Nebrot
Norway
C?ID=337027
Coolant leak from solenoid valve through the electrical wires. The car wouldn’t start at the end. Tried to clean, and dry it but only more alarms. Sendt it to Audi. Wonder how much this gonna cost me???
