Tuesday,09,July,2019,13:48:50:55272
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 19.6.1.0 (x64)
VIN: WAUZZZ4G8FN068483 License Plate:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 3B 42 44 46 52 53 55 5F 62
69 6C 6D 72 85 8E AC
VIN: WAUZZZ4G8FN068483 Mileage: 109829km-68244miles
03- Brakes -- Status: Malfunction 0010
05-/Start Auth. -- Status: OK 0000
17-Instruments -- Status: Cannot be reached 0100
3B-Sensor Elect. -- Status: Malfunction 0010
85-On Board Cam. -- Status: Malfunction 0010
Address 01: Engine (J623-CRTD) Labels:. 059-907-401-V2.clb
Part No SW: 4G2 907 401 B HW: 4G2 907 401
Component: 3.0TDI EDC17 H33 0001
Revision: 92H33---
Coding: 12254012052601030000
Shop #: 02391 785 00200
Dataset: EV_ECM30TDI0114G2907401B 001001
ROD: EV_ECM30TDI0114G2907311C.rod
VCID: 244720EF2F0C176FDD-8070
Part No SW: 4G0 927 166 C HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0007
Revision: --H03---
Coding: 100001
Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 2D51C5CB7CC6D62702-8078
Address 03: Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 17A69E41E86579829B00
Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3F8D8F83A6AA54B7A0-806A
130816 - Function Restriction due to Faults in Other Modules
U1113 00 [173] - -
[New feature! Extended fault detail is only supported by current gen. interfaces]
Mileage: 109829 km
Date: 2019.07.09
Time: 12:48:13
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 22
Bit Info 4: 1F
Uz: AA
131328 - Function Restriction due to Faults in Other Modules
U1113 00 [173] - -
Mileage: 109829 km
Date: 2019.07.09
Time: 12:48:13
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 22
Bit Info 4: 1F
Uz: AA
131840 - Function Restriction due to Faults in Other Modules
U1113 00 [173] - -
Mileage: 109829 km
Date: 2019.07.09
Time: 12:48:13
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 22
Bit Info 4: 1F
Uz: AA
Address 05: /Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0560
Coding: 01B9704E000000000000
VCID: 7AFB3E97F508B19FD7-802E
Component: J764 ELV H40 0046
Serial number: 3215000011387005
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 12021500040194
Coding: 36A21178250000
Dataset: EV_AirCondiComfoUDS 003008
VCID: 63C563F36A825057E4-8036
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001008344002
Coding: 0105001440349FE041014083000018000F9DE7082F08020100000894E100130200400035030000
Shop #: 53920 001 104857
VCID: 71E919BBA87EF2C766-8024
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 150111 H37 0080
Serial number: 150126014513
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23730186
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - H07 0044
Serial number: 13 02 2015 00000883
Serial number: F818C297000000000001
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 242
Mileage: 109829 km
Date: 2019.07.09
Time: 12:48:18
Revision: -------- Serial number: 003P100390YW
Coding: 30333130313730323737554A305234473053
Dataset: EV_AirbaAU10BPAAU64X 001014
VCID: 3B75FB93B2B248978C-806E
Serial number: 3575HRB401G52UQM71L
Serial number: 3585HRB405133PKM68CD
Serial number: 3515JRB40145358SI2AU
Serial number: 3525JRB40145358SP91-
Serial number: 3554VRB400Q534069H6.
Serial number: 3564VRB400M5340670PY
B13BC F2 [137] - No function
Mileage: 109829 km
Date: 2019.07.09
Time: 12:48:29
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Revision: -------- Serial number: 90372OBC00036
Coding: 0004F5
VCID: 387FE49F8B84638F61-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 06 01 2015 C0007902
Part No SW: 4G8 920 985 L HW: 4G8 920 985 L
Component: TDieGb H08 0043
Revision: 04001037 Serial number: 658180215596026
Coding: 33A601000B552600010400
Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 408F8C7FDB542B4FD9-8014
Part No SW: 4G8 907 468 HW: 4G8 907 468
Revision: -------- Serial number: 00000001729380
Coding: C0CD078118
Dataset: EV_GatewPkoUDS 001024
VCID: 75E12DABD416DEE7BA-8020
Serial number: 1900125603
Voltage stabilizer:
Serial number: 1412100000000000044B
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 14021500040455
Coding: 22
Dataset: EV_ClimaContrUnitRearUDS 003004
VCID: 3D71F58BACA646A7B2-8068
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA8208ZJ6T
Shop #: 00000 000 00000
Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3663EAA7899095FF73-8062
5242880 - No Basic Setting
B2010 00 [009] - -
Reset counter: 242
Mileage: 109829 km
Date: 2019.07.09
Time: 12:48:13
DCU_Internal_DTC: 50 00 00
Ignition Cycle Count: 29789
DCU Temperature: 31 ∞C
Voltage terminal 30: 13.1 V
Voltage VBG 22: 2.5 V
VIN received: WAUZZZ4G8FN068483
Debug Data: 00 00 00 00 00 00 00 00
Component: FA H04 0507
Coding: 011C1E015001620002080002
VCID: 45819D6BCC760E67EA-8010
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0016426092
Coding: 101001010001
Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
VCID: 3365D3B39AE280D754-8066
Revision: 00002001 Serial number: 0360799116
Coding: 013B0622A0B93080C320090420010F470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Component: BACKUP HO H05 1501
Part No SW: 4G8 959 792 H HW: 4G8 959 792 F
Component: BF H04 0507
VCID: 4487806FC74C376FFD-8010
Component: -4 H04 0015
Revision: -------- Serial number: 00000001368405
Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
463616 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
Reset counter: 242
Mileage: 109829 km
Date: 2019.07.09
Time: 12:49:14
Voltage terminal 30: 13.8 V
Internal Fault ID: 185
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
: not active
: not active
HTR: not active
: not active
requested apply: not active
Auto Adjust: not active
Internal Parking Brake state: static
Status ParkingBrake left: Open
Status ParkingBrake right: Open
Part No SW: 4H4 907 357 D HW: 7P6 907 357 B
Component: - 001 0081
Coding: 04FE02202A130200
Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
Coding: E01F00
Coding: E01F00
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo li. H03 0031
Coding: E01F00
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo re. H03 0031
Coding: E01F00
13705999 - Databus
Reset counter: 242
Mileage: 109829 km
Date: 2019.07.09
Time: 12:48:15
Address 5F: Information Electr. (J794) Labels:* 4G1-035--HGH2.clb
Part No SW: 4G1 035 021 D HW: 4G1 035 021
Component: MU-H-LND-EU 041 0389
Serial number: A588B0F7505471
Coding: 017502010000000013111102000A00132F0006E7F1700100DF
Dataset: EV_MUHig6C3Gen2HBAS 001115
VCID: 1B351B13127228976C-804E
Subsystem 1 - Part No SW: V03 959 801 FD HW: -----------
Component: ECE 2017/2018 --- 0161
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9EY800PTF
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Serial number: 90349OBD0006Q
Compact Disc Database:
Component: Gracenote2 --- 1012
3086 - Antenna for Telephone Mount
B1564 01 [008] - Electrical Failure
Reset counter: 27
Mileage: 109829 km
Date: 2019.07.09
Time: 13:40:51
Voltage terminal 30: 11.7 V
Status of telephone-Antenna diagnostic: OK
Status of telephone-Telephone baseplate diagnostic: not connected
Status of telephone-Handset in handset holder (cradle): not selected
Status of telephone-Handset holder (cradle): not connected
7961 - Control module
B2001 00 [008] - Incorrect software version
Reset counter: 27
Mileage: 109829 km
Date: 2019.07.09
Time: 12:48:25
Voltage terminal 30: 13.6 V
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 D HW: 4G8 959 795
Component: HL H03 0212
Coding: 01081C004001620000080002
Shop #: 02312 785 00200
VCID: 43858373C2423057C4-8016
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: Anhaenger H14 0113
Serial number: 0000454261
Coding: 0100000202000000
Dataset: EV_TrailFunctGener2Hella 001005
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H04--- Serial number: 525 PA8J1XG2SO
Coding: 1030005
Shop #: 98765 666 38384
VCID: 26433AE79130E57FC3-8072
03006 - Back-up Camera System not calibrated
Reset counter: 242
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0150
Revision: 14005001 Serial number: 030500754
Coding: 093205C010
Dataset: EV_HDSGAu572 001022
ROD: EV_HDSGAu571.rod
Address 72: Door, Rear Right (J389) Labels: None
Component: HR H03 0212
Shop #: 28100 141 104456
Component: DPC-SG H27 0081
Coding: 71140000
Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C57C8CF47DCDF2F15-8078
0730 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 242
Mileage: 109829 km
Date: 2019.07.09
Time: 12:48:14
Outside air temperature: -39.0 ∞C
Voltage terminal 15: 13.2 V
Control Module temperature: 48.0 ∞C
0773 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 242
Mileage: 109829 km
Date: 2019.07.09
Time: 12:48:15
Component: BV-SG H33 0090
Serial number: 005000621903157
Coding: 044229040111
Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0028 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 242
Mileage: 109829 km
Date: 2019.07.09
Time: 12:48:14
Outside air temperature: 22.5 ∞C
Voltage terminal 15: 13.3 V
Control Module temperature: 33.0 ∞C
0049 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 242
Mileage: 109829 km
Date: 2019.07.09
Time: 12:48:29
Outside air temperature: 22.0 ∞C
Voltage terminal 15: 13.5 V
0057 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 242
Mileage: 109829 km
Date: 2019.07.09
Time: 12:48:13
0116 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 242
Mileage: 109829 km
Date: 2019.07.09
Time: 12:48:13
0091 - Function Limitation due to Missing Video Data
C1108 00 [009] - -
Reset counter: 242
Mileage: 109829 km
Date: 2019.07.09
Time: 12:48:13
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 150210145
Dataset: EV_RDCMA00100 008040
ROD: EV_RDCMA00100_008.rod
End-------------------------(Elapsed Time: 05:54)--------------------------
