I am repairing this car for my neighbor, we trade back and forth and she is going to watch my house, feed my animals while I am on vacation in Colorado.
Most of the lights on the dash are on. ABS, Brake, Tire pressure, traction control. The EPC and steering wheel lights where on when I first got the car this morning. I did an Autoscan that is posted below. Then I cleared all codes and drove the car. Drives good EXCEPT when heavy acceleration takes places the fuel gauge drops to E and the car loses power. I suspect this is a different problem than the lights on the dash issue. After is drove the car and did another autoscan, the steering wheel and epc lights are out. My car (a 2006 Jetta TDI) always has those two lights when the battery is disconnected and they clear almost the minute the car gets rolling.
Anyway I will post the autoscan from before I cleared the codes. I also have another autoscan that I took about 4 months ago when I first looked at the car. Similar codes. I can post it too if it would help.
Any input will be much appreciated!
Tuesday,09,July,2019,10:07:35:58999
VCDS Version: 19.6.1.0 (x64)
VIN: 3VWRX7AJ9AM158710 License Plate: ELAINE
Mileage: 103900km-64560mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72 77
VIN: 3VWRX7AJ9AM158710 Mileage: 103900km-64560miles
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 AJ HW: 07K 906 055 M
Component: 2,5l R5/4V G 5782
Revision: G6H04--- Serial number:
Coding: 0000071
Shop #: WSC 00066 000 00000
VCID: 76E35D9201214AFFB3-8022
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 -
Mileage: 101893 km
Date: 2019.01.18
Time: 00:11:14
Load: 0.0 %
Temperature: 37.0°C
Temperature: 18.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.811 V
050197 - Implausible Data Received from ABS Control Module
U0415 - 000 - - Intermittent - MIL ON
Fault Status: 10100000
Mileage: 101899 km
Date: 2019.01.18
Time: 19:44:29
RPM: 1465 /min
Load: 25.9 %
Speed: 255.0 km/h
Temperature: 11.0°C
Temperature: 8.0°C
Voltage: 14.351 V
U1017 - 000 - - Intermittent
Fault Frequency: 118
Mileage: 102223 km
Date: 2019.02.17
Time: 21:27:09
RPM: 1211 /min
Load: 29.4 %
Temperature: 32.0°C
Temperature: 24.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
Fault Frequency: 40
Mileage: 102594 km
Date: 2019.03.02
Time: 22:01:47
RPM: 1390 /min
Load: 21.2 %
Speed: 255.0 km/h
Temperature: 34.0°C
Temperature: 25.0°C
Voltage: 13.970 V
001281 - Vehicle Speed Sensor
P0501 - 000 - Implausible Signal - Intermittent
Mileage: 103644 km
Date: 2019.06.07
Time: 19:16:23
RPM: 1728 /min
Load: 11.8 %
Temperature: 45.0°C
Temperature: 28.0°C
Voltage: 14.097 V
Part No SW: 1K0 907 379 AS HW: 1K0 907 379 AS
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 114B400C49270002881202E592190041300000
VCID: 0305344682F36F5784-8056
10 Faults Found:
03840 - RPM Sensor Front Right: Incorrect Signal
Fault Frequency: 14
Reset counter: 80
Mileage: 103208 km
Date: 2019.05.07
Time: 04:23:27
Count: 3
Count: 12288
Count: 55
Count: 36864
Count: 4352
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Fault Status: 00100011
Fault Frequency: 31
Reset counter: 85
Mileage: 103177 km
Date: 2019.05.06
Time: 20:32:36
Count: 1
Count: 4608
Count: 35
Count: 50176
Count: 65530
Count: 64000
Reset counter: 87
Mileage: 103848 km
Date: 2019.07.06
Time: 00:24:26
Count: 16391
Count: 2
Count: 12288
Count: 128
Count: 41472
Count: 12800
00285 - ABS Wheel Speed Sensor; Front Right (G45)
Fault Frequency: 14
Reset counter: 87
Mileage: 3604480 km
Date: 2009.01.08
Time: 00:01:00
Count: 256
Count: 32855
Count: 256
Count: 49
Count: 128
Count: 12340
Count: 56576
Fault Frequency: 6
Reset counter: 92
Mileage: 103890 km
Date: 2019.07.07
Time: 04:31:23
Count: 7
Count: 4608
Count: 67
Count: 50176
Count: 62701
Count: 64000
Fault Frequency: 27
Reset counter: 92
Mileage: 327946 km
Date: 2002.04.03
Time: 16:32:05
Count: 1540
Count: 83
Count: 23552
Count: 51
Count: 1536
Count: 17152
Count: 55
Count: 20494
03841 - RPM Sensor Rear Left: Incorrect Signal
Reset counter: 92
Mileage: 103849 km
Date: 2019.07.06
Time: 02:01:43
Count: 1
Count: 12800
Count: 71
Count: 43264
Fault Status: 00101100
Fault Frequency: 52
Reset counter: 52
Mileage: 102753 km
Date: 2019.03.14
Time: 17:53:13
Count: 7
Count: 12288
Count: 64
Count: 37632
Count: 8448
Count: 256
Fault Frequency: 221
Reset counter: 52
Mileage: 102821 km
Date: 2019.03.17
Time: 23:52:19
Count: 16391
Count: 16896
Count: 48
Count: 45056
Fault Status: 01101100
Fault Frequency: 80
Reset counter: 36
Mileage: 103112 km
Date: 2019.05.02
Time: 04:08:22
Count: 16391
Count: 16896
Count: 32
Count: 43776
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00185
ROD: EV_ClimaBasis_VW36.rod
VCID: 75E15A9ED42741E7BA-8020
13701904 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 92
Mileage: 102678 km
Date: 2019.03.09
Time: 22:29:43
Address 09: Cent. Elect. Labels: None
VCID: 55A13A1EBCE721E79A-FFFE
No Faults Found
Part No SW: 1K0 909 605 AD HW: 1K0 909 605 AD
Component: 04 AIRBAG VW8R 036 8900
Revision: 06036000 Serial number: 003EVM038X8-
Coding: 0012340
VCID: 6ED375F27971723F7B-803A
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME520545653
Subsystem 3 - Serial number: 6342MSME53107A0CA
Subsystem 4 - Serial number: 6351HSME217B415A8
Subsystem 5 - Serial number: 6361HSME217B4B419
Subsystem 6 - Serial number: 63727SME21576A1A2
Subsystem 7 - Serial number: 63827SME21441629X
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0000031
VCID: 020B31425DE9665F8F-8056
Part No SW: 5M0 920 960 E HW: 5M0 920 960 E
Component: KOMBI H14 0112
Revision: X0014004 Serial number:
Coding: 270700
Shop #: WSC 00066 000 00148
ASAM Dataset: EV_KombiUDSMM9RM10 A04102
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
VCID: 3169AE8E60CF2DC726-8064
13631488 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 73
Mileage: 103700 km
Date: 2019.06.12
Time: 18:17:47
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 0602
Revision: H27 Serial number: 29061001211335
Coding: E9807F0700060200001002
VCID: 6DD172FE7477892742-8038
Part No SW: 5K0 953 234 HW: 5M0 920 960 E
Component: IMMO H14 0112
ASAM Dataset: EV_ImmoUDSMM9RM10 A01102
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6ADB79E28D999E1F27-803E
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0001124478
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide_VW36.rod
VCID: 275D40D65E0B6377F8-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005035503
Coding: 000490
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 3169AE8EA8CF2DC726-8064
01316 - ABS Control Module
013 - Check DTC Memory
Fault Status: 01101101
Fault Frequency: 248
Reset counter: 51
Mileage: 103890 km
Date: 2019.07.08
Time: 20:41:47
Voltage: 13.75 V
DU
Temperature: 36.0°C
RPM: 1069 /min
Speed: 3.0 km/h
Speed: 3.0 km/h
Fault Status: 00101101
Fault Frequency: 255
Reset counter: 92
Mileage: 103903 km
Date: 2019.07.09
Time: 19:53:24
Voltage: 13.88 V
DU
Temperature: 29.0°C
RPM: 752 /min
Address 46: Central Conv.
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0001110711
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide_VW32.rod
VCID: 285F43EA53156C0FF1-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005053700
Coding: 000490
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 D HW: 1K0 035 161 D
Component: Radio DE2 020 0023
Revision: 00020000 Serial number: VWZ4Z7K6501480
Coding: 0042401
VCID: 204F5BCAF325944FB9-8074
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Part No SW: 5K0 937 085 L HW: 5K0 937 085 L
Component: RDK 111 0821
Coding: 018704
Shop #: WSC 05073 444 16936
VCID: 3C778FBABF8DD0AF85-8068
02903 - Hard Warning 2
Fault Status: 01100010
Mileage: 102678 km
Date: 2019.03.09
Time: 21:38:51
Text: 3452378702
Pressure: 0.10 bar
Pressure: 2.30 bar
Temperature: 9.2°C
Text: 80
02214 - Tire Pressure Warning
Mileage: 102678 km
Date: 2019.03.09
Time: 21:38:51
Text: 3452378702
Pressure: 0.10 bar
Pressure: 2.30 bar
Temperature: 9.2°C
Text: 80
Mileage: 102678 km
Date: 2019.03.09
Time: 21:38:51
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000A07764373
Coding: 401100
VCID: 2A5BB9E245195E1FE7-807E
End-------------------------(Elapsed Time: 02:35)--------------------------
