Help for multiple lights on dash, is any of this known issues?
Mtnman
C?ID=53726
I am repairing this car for my neighbor, we trade back and forth and she is going to watch my house, feed my animals while I am on vacation in Colorado.
Most of the lights on the dash are on. ABS, Brake, Tire pressure, traction control. The EPC and steering wheel lights where on when I first got the car this morning. I did an Autoscan that is posted below. Then I cleared all codes and drove the car. Drives good EXCEPT when heavy acceleration takes places the fuel gauge drops to E and the car loses power. I suspect this is a different problem than the lights on the dash issue. After is drove the car and did another autoscan, the steering wheel and epc lights are out. My car (a 2006 Jetta TDI) always has those two lights when the battery is disconnected and they clear almost the minute the car gets rolling.
Anyway I will post the autoscan from before I cleared the codes. I also have another autoscan that I took about 4 months ago when I first looked at the car. Similar codes. I can post it too if it would help.
Any input will be much appreciated!
Tuesday,09,July,2019,10:07:35:58999
VCDS Version: 19.6.1.0 (x64)
VIN: 3VWRX7AJ9AM158710   License Plate: ELAINE
Mileage: 103900km-64560mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72 77
VIN: 3VWRX7AJ9AM158710   Mileage: 103900km-64560miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 AJ    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   5782
   Revision: G6H04---    Serial number:
   Coding: 0000071
   Shop #: WSC 00066 000 00000
   VCID: 76E35D9201214AFFB3-8022
               U1017 - 000 -
                    Mileage: 101893 km
                    Date: 2019.01.18
                    Time: 00:11:14
                    Temperature: 37.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.811 V
050197 - Implausible Data Received from ABS Control Module
               U0415 - 000 -  - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 101899 km
                    Date: 2019.01.18
                    Time: 19:44:29
                    RPM: 1465 /min
                    Load: 25.9 %
                    Speed: 255.0 km/h
                    Temperature: 11.0°C
                    Temperature: 8.0°C
                    Voltage: 14.351 V
               U1017 - 000 -  - Intermittent
                    Fault Frequency: 118
                    Mileage: 102223 km
                    Date: 2019.02.17
                    Time: 21:27:09
                    RPM: 1211 /min
                    Load: 29.4 %
                    Temperature: 32.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.970 V
                    Fault Frequency: 40
                    Mileage: 102594 km
                    Date: 2019.03.02
                    Time: 22:01:47
                    RPM: 1390 /min
                    Load: 21.2 %
                    Speed: 255.0 km/h
                    Temperature: 34.0°C
                    Temperature: 25.0°C
                    Voltage: 13.970 V
001281 - Vehicle Speed Sensor
               P0501 - 000 - Implausible Signal - Intermittent
                    Mileage: 103644 km
                    Date: 2019.06.07
                    Time: 19:16:23
                    RPM: 1728 /min
                    Load: 11.8 %
                    Temperature: 45.0°C
                    Temperature: 28.0°C
                    Voltage: 14.097 V
   Part No SW: 1K0 907 379 AS    HW: 1K0 907 379 AS
   Component: ESP MK60EC1   H30 0105
   Revision: 00H30001
   Coding: 114B400C49270002881202E592190041300000
   VCID: 0305344682F36F5784-8056
10 Faults Found:
03840 - RPM Sensor Front Right: Incorrect Signal
                    Fault Frequency: 14
                    Reset counter: 80
                    Mileage: 103208 km
                    Date: 2019.05.07
                    Time: 04:23:27
                    Count: 3
                    Count: 12288
                    Count: 55
                    Count: 36864
                    Count: 4352
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                    Fault Status: 00100011
                    Fault Frequency: 31
                    Reset counter: 85
                    Mileage: 103177 km
                    Date: 2019.05.06
                    Time: 20:32:36
                    Count: 1
                    Count: 4608
                    Count: 35
                    Count: 50176
                    Count: 65530
                    Count: 64000
                    Reset counter: 87
                    Mileage: 103848 km
                    Date: 2019.07.06
                    Time: 00:24:26
                    Count: 16391
                    Count: 2
                    Count: 12288
                    Count: 128
                    Count: 41472
                    Count: 12800
                    Fault Frequency: 14
                    Reset counter: 87
                    Mileage: 3604480 km
                    Date: 2009.01.08
                    Time: 00:01:00
                    Count: 256
                    Count: 32855
                    Count: 256
                    Count: 49
                    Count: 128
                    Count: 12340
                    Count: 56576
                    Reset counter: 92
                    Mileage: 103890 km
                    Date: 2019.07.07
                    Time: 04:31:23
                    Count: 7
                    Count: 4608
                    Count: 67
                    Count: 50176
                    Count: 62701
                    Count: 64000
                    Fault Frequency: 27
                    Reset counter: 92
                    Mileage: 327946 km
                    Date: 2002.04.03
                    Time: 16:32:05
                    Count: 1540
                    Count: 83
                    Count: 23552
                    Count: 51
                    Count: 1536
                    Count: 17152
                    Count: 55
                    Count: 20494
03841 - RPM Sensor Rear Left: Incorrect Signal
                    Reset counter: 92
                    Mileage: 103849 km
                    Date: 2019.07.06
                    Time: 02:01:43
                    Count: 1
                    Count: 12800
                    Count: 71
                    Count: 43264
                    Fault Status: 00101100
                    Fault Frequency: 52
                    Reset counter: 52
                    Mileage: 102753 km
                    Date: 2019.03.14
                    Time: 17:53:13
                    Count: 7
                    Count: 12288
                    Count: 64
                    Count: 37632
                    Count: 8448
                    Count: 256
                    Fault Frequency: 221
                    Reset counter: 52
                    Mileage: 102821 km
                    Date: 2019.03.17
                    Time: 23:52:19
                    Count: 16391
                    Count: 16896
                    Count: 48
                    Count: 45056
                    Fault Status: 01101100
                    Fault Frequency: 80
                    Reset counter: 36
                    Mileage: 103112 km
                    Date: 2019.05.02
                    Time: 04:08:22
                    Count: 16391
                    Count: 16896
                    Count: 32
                    Count: 43776
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Revision: 00009001
   Coding: 0000001002
   Shop #: WSC 00066 000 00185
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75E15A9ED42741E7BA-8020
13701904 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 92
                    Mileage: 102678 km
                    Date: 2019.03.09
                    Time: 22:29:43
Address 09: Cent. Elect.        Labels: None
   VCID: 55A13A1EBCE721E79A-FFFE
No Faults Found
   Part No SW: 1K0 909 605 AD    HW: 1K0 909 605 AD
   Component: 04 AIRBAG VW8R  036 8900
   Revision: 06036000    Serial number: 003EVM038X8-
   Coding: 0012340
   VCID: 6ED375F27971723F7B-803A
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME520545653
   Subsystem 3 - Serial number: 6342MSME53107A0CA
   Subsystem 4 - Serial number: 6351HSME217B415A8
   Subsystem 5 - Serial number: 6361HSME217B4B419
   Subsystem 6 - Serial number: 63727SME21576A1A2
   Subsystem 7 - Serial number: 63827SME21441629X
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0000031
   VCID: 020B31425DE9665F8F-8056
   Part No SW: 5M0 920 960 E    HW: 5M0 920 960 E
   Component: KOMBI         H14 0112
   Revision: X0014004    Serial number:
   Coding: 270700
   Shop #: WSC 00066 000 00148
   ASAM Dataset: EV_KombiUDSMM9RM10 A04102
   ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
   VCID: 3169AE8E60CF2DC726-8064
13631488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 73
                    Mileage: 103700 km
                    Date: 2019.06.12
                    Time: 18:17:47
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 0602
   Revision:   H27       Serial number: 29061001211335
   Coding: E9807F0700060200001002
   VCID: 6DD172FE7477892742-8038
   Part No SW: 5K0 953 234     HW: 5M0 920 960 E
   Component: IMMO          H14 0112
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01102
   VCID: 6ADB79E28D999E1F27-803E
   Part No SW: 3C0 959 701 B    HW: 3C0 959 793
   Component: TUER-SG FT    002 0307
   Revision: 13101005    Serial number: 0001124478
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU42BroseDriveSide_VW36.rod
   VCID: 275D40D65E0B6377F8-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1401
   Serial number: 00000005035503
   Coding: 000490
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 69     3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 3169AE8EA8CF2DC726-8064
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 248
                    Reset counter: 51
                    Mileage: 103890 km
                    Date: 2019.07.08
                    Time: 20:41:47
                    Voltage: 13.75 V
                        DU
                    Temperature: 36.0°C
                    RPM: 1069 /min
                    Speed: 3.0 km/h
                    Speed: 3.0 km/h
                    Fault Status: 00101101
                    Fault Frequency: 255
                    Reset counter: 92
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 19:53:24
                    Voltage: 13.88 V
                        DU
                    Temperature: 29.0°C
                    RPM: 752 /min
Address 46: Central Conv.
   Part No SW: 3C0 959 702 B    HW: 3C0 959 792
   Component: TUER-SG BT    002 0307
   Revision: 15101005    Serial number: 0001110711
   Coding: 0004B4
   ROD: EV_DCU52BrosePasseSide_VW32.rod
   VCID: 285F43EA53156C0FF1-807C
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1401
   Serial number: 00000005053700
   Coding: 000490
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
   Component: Radio DE2       020 0023
   Revision: 00020000    Serial number: VWZ4Z7K6501480
   Coding: 0042401
   VCID: 204F5BCAF325944FB9-8074
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Part No SW: 5K0 937 085 L    HW: 5K0 937 085 L
   Component: RDK           111 0821
   Coding: 018704
   Shop #: WSC 05073 444 16936
   VCID: 3C778FBABF8DD0AF85-8068
02903 - Hard Warning 2
                    Fault Status: 01100010
                    Mileage: 102678 km
                    Date: 2019.03.09
                    Time: 21:38:51
                    Text: 3452378702
                    Pressure: 0.10 bar
                    Pressure: 2.30 bar
                    Temperature: 9.2°C
                    Text: 80
02214 - Tire Pressure Warning
                    Mileage: 102678 km
                    Date: 2019.03.09
                    Time: 21:38:51
                    Text: 3452378702
                    Pressure: 0.10 bar
                    Pressure: 2.30 bar
                    Temperature: 9.2°C
                    Text: 80
                    Mileage: 102678 km
                    Date: 2019.03.09
                    Time: 21:38:51
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000A07764373
   Coding: 401100
   VCID: 2A5BB9E245195E1FE7-807E
End-------------------------(Elapsed Time: 02:35)--------------------------
Mtnman
C?ID=53726
2010 VW Jetta 2.5 manual transmission.
Just realized that I didn't say what the car is, oops!
NostraJackAss
Component: 2,5l R5/4V G 5782 <<<<<<<<<<<<<<<<<<<<<<<<<<< FIRMWARE UPDATE?
Coding: 0000071
Doesn't this pretty much say it all below?
Time to RTFB and JPPSG
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
Please post OBD2 data sir.
0x33 MODES 01-01, 03, 07, 09
How's your battery health and charging system connections doing?
Mtnman
C?ID=53726
Ok, heres my update.
I did service the battery and cables first thing as well as charge the battery, I have a VW, know the drill a little bit I guess.
Just drove the car a couple times. First test drive, speedometer isn't working, gas gas fluctuates when you accelerate. Hooked up VCDS, ran measuring blocks for speedo, it reads 0 kph, mph no matter how fast I drove. Looked up what I could in the service information that I have on hand and got out the (I call it) mostly useless, expensive Bentley manual I bought for my Jetta, then tried to figure out where the VSS is. Seems like they use the wheel speed sensors, through the ABS system to measure the vehicle speed. So I did another test drive, now with the VCDS in the ABS module, monitoring the four wheel speed sensors. I went ahead and graphed it so I could drive and see any anomalies quickly. First thing I noticed before I even moved an inch is that the left rear sensor was reading all over the place, big huge spikes on the graph, 0 to 230 kmh, wow, bad sensor or probably wiring. So I drive and the left front always reads zero, the right front and rear read road speed. But now THE SPEEDOMETER IS WORKING, hmmm... I head back to my barn and pull in, now the left rear is reading correct, no spikes on the graph, left front still zero. Its is just plain ol erratic.
So, here is my question..
Any idea what the ABS module is in charge of on this car? I suspect it to be compromised. Is it in charge of the VSS signal? More than likely the ABS module is involved in ESP/ASR stuff.
Are these ABS modules known to fail?
Again, any help is appreciated.
Mr Jack, I will run an OBD scan and another autoscan after I eat and I will post it in a bit. Thanks again.
Yes, these ABS modules have been known to fail. Look at all the threads here with MK60EC1 in the subject. Most of them are coding requests due to the controller having been replaced. But before you condemn it, double check powers and grounds to it. I say that because of the "00668 - Supply Voltage Terminal 30 -- Lower Limit Exceeded" fault.
NostraJackAss
OP
Report failure of ABS module if so to NHTSA and check to see if free repair under campaign recall.
Also you must JPPSG because this car is under useful life warranty.
Absolutely get the forum the OBD2 data please it will help us help you.
vehicle Identification No. 3VWRX7AJ9AM158710
Model Jetta
JEM
Date of production 07.07.2010
Model year 2010
Sales type 1K22S1
Engine Code CBTA
Transmission Code KPF
Emission standard 7GJ Emission standard TIER 2
Mtnman
C?ID=53726
Sounding better all the time. I will definitely check the powers and grounds, maybe get lucky.
I appreciate the input!
I tied to get the OBD scan but not sure how, with VCDS ? I kinda tried to do it but the OBD option didn't come up with much, how do I access the 0x33, 01-01. 03, 07, 09 area?
Be a couple days now. Another question for Jack, can I access that build date, sales type, vehicle id information somewhere or is that dealer info?
NostraJackAss
Sure build data it's in the car right on the data plate sir.
Microfiche and as I aforementioned.
OBD2
Please go to main VCDS screen and click the button labeled 0x33 & OBDII then save data like auto scan in each mode. Start with button mode 01-1 then 3, 7 & 9 and post that data.
So is your check engine light or MIL ON?
Mtnman
C?ID=53726
Check engine light is not on and has not been on. ABS, traction and brake lights are what I have it down to now.
NostraJackAss
U0415 - 000 - - Intermittent - MIL ON<<<<<<< WTF?
Fault Frequency: 254<<<<< WTF!
Mileage: 101899 km
Date: 2019.01.18
Time: 19:44:29
What was this?
These requests are to seek answers as to document if a useful life warranty exists; you do realize that any non related subsystem that causes an MIL to be illuminated is cause to be repaired or replaced free of charge or reimbursable & even if those mechanical ABS sensors by the OEM caused it too, right for SMOG CARB CAA?
Mtnman
C?ID=53726
Update and a few more questions
Ok guys, here is my update. Powers and grounds test out good, I looked at the speed sensors and wiring physically and can't find any damage, mouse chewing or anything else. With the erratic codes and the way the sensors react when I check them in measuring blocks I am condemning the ABS computer.
I did get those OBD scans per Jacks request and they are posted below. Also the latest Autoscan is there in case you want to see it.
Here are my new questions. Does anyone know if I have to go back with the exact same part number of the MK60EC1 brake module? There are a lot of them in the junkyards with very similar part numbers.
The part number I think I need is: 1K0 907 379AS.
I am finding 1K0 907 379AC and 1k0 907 379AN
I am wondering if it is just coding that is different or is there a way to find out what part numbers will fit the car?
Can I recode a used module with VCDS?
Thanks again
Here is the latest autoscan
Friday,12,July,2019,15:39:20:58999
Mileage: 103960km-64597mi   Repair Order:
VIN: 3VWRX7AJ9AM158710   Mileage: 103960km-64597miles
   Coding: 0000071
               U1017 - 000 -
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 00:13:02
                    Temperature: 39.0°C
                    Temperature: 35.0°C
                    Voltage: 12.192 V
                    Fault Frequency: 17
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 00:18:45
                    RPM: 1853 /min
                    Load: 21.2 %
                    Speed: 255.0 km/h
                    Temperature: 42.0°C
                    Temperature: 35.0°C
                    Voltage: 13.970 V
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 01:05:15
                    RPM: 851 /min
                    Load: 20.4 %
                    Speed: 6.0 km/h
                    Temperature: 85.0°C
                    Temperature: 51.0°C
                    Voltage: 13.716 V
Readiness: 0000 0100
   Revision: 00H30001
9 Faults Found:
                    Reset counter: 97
                    Mileage: 103910 km
                    Date: 2019.07.09
                    Time: 23:57:38
                    Count: 3
                    Count: 4608
                    Count: 293
                    Count: 50432
                    Count: 1280
                    Reset counter: 97
                    Mileage: 103930 km
                    Date: 2019.07.10
                    Time: 17:38:42
                    Count: 3
                    Count: 4608
                    Count: 49
                    Count: 50945
                    Count: 256
                    Reset counter: 98
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 01:05:13
                    Count: 3
                    Count: 4608
                    Count: 71
                    Count: 49666
                    Count: 514
                    Reset counter: 100
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 00:19:52
                    Count: 7
                    Count: 4608
                    Count: 67
                    Count: 50688
                    Count: 254
                    Reset counter: 100
                    Mileage: 103907 km
                    Date: 2019.07.09
                    Time: 19:04:43
                    Count: 3
                    Count: 4608
                    Count: 51
                    Count: 50432
                    Count: 2058
                    Count: 2048
                    Fault Frequency: 8
                    Reset counter: 100
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 00:13:11
                    Count: 3
                    Count: 2
                    Count: 28672
                    Count: 56
                    Count: 44032
                    Reset counter: 100
                    Mileage: 395268 km
                    Date: 2000.12.02
                    Time: 16:04:11
                    Count: 1792
                    Count: 48
                    Count: 25600
                    Count: 35
                    Count: 2048
                    Count: 14336
                    Count: 32
                    Count: 13569
                    Reset counter: 53
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 00:18:45
                    Count: 3
                    Count: 4
                    Count: 4608
                    Count: 40
                    Count: 50432
                    Count: 256
                    Reset counter: 60
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 00:21:19
                    Count: 7
                    Count: 4608
                    Count: 64
                    Count: 50688
                    Count: 256
   Revision: 00009001
   Coding: 0000001002
          U1113 00 [008] - -
                    Fault Frequency: 20
                    Reset counter: 100
                    Mileage: 103907 km
                    Date: 2019.07.09
                    Time: 17:42:36
   Component: BCM PQ35 B++  111 0135
   Revision: BI111001
   Coding: 2D200B1E902F3EE480000085600000040100008651008D605C8020000000
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 30061  23  0512
   Coding: 009795
02092 - Enabling Heated Seat
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 39
                    Reset counter: 60
                    Mileage: 103905 km
                    Date: 2019.07.09
                    Time: 03:04:46
                    Voltage: 13.80 V
   Coding: 0012340
   Coding: 0000031
   Coding: 270700
   Coding: 0004B5
   Slave Driver:
   Coding: 000490
66304 - Switch for Drivers Side Window Regulator
          B11F0 29 [008] - Signal Implausible
                    Reset counter: 100
                    Mileage: 103932 km
                    Date: 2019.07.11
                    Time: 04:58:59
   Revision: 00H17000
                    Fault Frequency: 8
                    Reset counter: 100
                    Mileage: 103968 km
                    Date: 2019.07.12
                    Time: 00:42:30
                    Voltage: 12.13 V
                        DD
                    Temperature: 43.0°C
                    Fault Frequency: 17
                    Reset counter: 100
                    Mileage: 103936 km
                    Date: 2019.07.11
                    Time: 19:01:04
                    Voltage: 13.88 V
                        DU
                    Temperature: 51.0°C
                    RPM: 2304 /min
                    Speed: 72.0 km/h
                    Speed: 72.0 km/h
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0042401
   Coding: 018704
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 00:16:14
                    Text: 3452378702
                    Pressure: 0.00 bar
                    Pressure: 2.30 bar
                    Temperature: 52.4°C
                    Text: 00
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 00:16:14
                    Text: 3452378702
                    Pressure: 0.00 bar
                    Pressure: 2.30 bar
                    Temperature: 52.4°C
                    Text: 00
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 00:16:14
   Coding: 401100
End-------------------------(Elapsed Time: 02:28)--------------------------
Address 03: DTCs clearedFriday,12,July,2019,16:14:23:58999
   Coding: 0000071
               U1017 - 000 -
                    Mileage: 103968 km
                    Date: 2019.07.12
                    Time: 00:53:24
                    Temperature: 64.0°C
                    Temperature: 50.0°C
                    Voltage: 11.938 V
Readiness: 1110 0101
   Revision: 00H30001
9 Faults Found:
                    Reset counter: 97
                    Mileage: 103910 km
                    Date: 2019.07.09
                    Time: 23:57:38
                    Count: 3
                    Count: 4608
                    Count: 293
                    Count: 50432
                    Count: 1280
                    Reset counter: 97
                    Mileage: 103930 km
                    Date: 2019.07.10
                    Time: 17:38:42
                    Count: 3
                    Count: 4608
                    Count: 49
                    Count: 50945
                    Count: 256
                    Reset counter: 98
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 01:05:13
                    Count: 3
                    Count: 4608
                    Count: 71
                    Count: 49666
                    Count: 514
                    Reset counter: 100
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 00:19:52
                    Count: 7
                    Count: 4608
                    Count: 67
                    Count: 50688
                    Count: 254
                    Reset counter: 100
                    Mileage: 103907 km
                    Date: 2019.07.09
                    Time: 19:04:43
                    Count: 3
                    Count: 4608
                    Count: 51
                    Count: 50432
                    Count: 2058
                    Count: 2048
                    Fault Frequency: 8
                    Reset counter: 100
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 00:13:11
                    Count: 3
                    Count: 2
                    Count: 28672
                    Count: 56
                    Count: 44032
                    Reset counter: 100
                    Mileage: 395524 km
                    Date: 2000.12.02
                    Time: 16:04:10
                    Count: 1792
                    Count: 48
                    Count: 25600
                    Count: 35
                    Count: 2048
                    Count: 14336
                    Count: 32
                    Count: 13569
                    Reset counter: 60
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 00:21:19
                    Count: 7
                    Count: 4608
                    Count: 72
                    Count: 50688
                    Count: 256
                    Reset counter: 53
                    Mileage: 103903 km
                    Date: 2019.07.09
                    Time: 00:18:45
                    Count: 3
                    Count: 4
                    Count: 4608
                    Count: 40
                    Count: 50432
                    Count: 256
   Revision: 00009001
   Coding: 0000001002
   Revision: BI111001
   Coding: 009795
                    Fault Frequency: 46
                    Reset counter: 60
                    Mileage: 103905 km
                    Date: 2019.07.09
                    Time: 03:04:46
                    Voltage: 13.80 V
   Coding: 0012340
   Coding: 0000031
   Coding: 270700
   Coding: 0004B5
   Slave Driver:
   Coding: 000490
          B11F0 29 [009] - Signal Implausible
                    Reset counter: 60
                    Mileage: 103968 km
                    Date: 2019.07.12
                    Time: 01:01:50
   Revision: 00H17000
                    Reset counter: 60
                    Mileage: 103968 km
                    Date: 2019.07.12
                    Time: 00:58:09
                    Voltage: 13.50 V
                        DU
                    Temperature: 45.0°C
                    RPM: 701 /min
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0042401
   Coding: 018704
                    Mileage: 103968 km
                    Date: 2019.07.12
                    Time: 00:54:26
                    Text: 3452378702
                    Pressure: 0.10 bar
                    Pressure: 2.30 bar
                    Temperature: 32.0°C
                    Text: 80
                    Mileage: 103968 km
                    Date: 2019.07.12
                    Time: 00:54:26
                    Text: 3452378702
                    Pressure: 0.10 bar
                    Pressure: 2.30 bar
                    Temperature: 32.0°C
                    Text: 80
                    Mileage: 103968 km
                    Date: 2019.07.12
                    Time: 00:54:26
   Coding: 401100
End-------------------------(Elapsed Time: 02:38)--------------------------
And here is the OBD info
Friday,12,July,2019,16:17:44:58999
Mode 03: Emission related fault codes
Address 7E8: No fault code found.
Mode 01 - PID 01 : Readiness  --  Address 7E8
Number of DTCs stored: 0  --  MIL Status: MIL OFF
Misfire monitoring:  Passed
Fuel System:  Passed
Comprehensive Components:  Passed
Catalyst monitoring:  Failed or Incomplete
Heated catalyst monitoring: Not installed.
Evaporative system monitoring:  Failed or Incomplete
Secondary air system monitoring: Not installed.
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring:  Failed or Incomplete
Oxygen sensor heater monitoring:  Failed or Incomplete
Exhaust Gas Recirculation:  Failed or Incomplete
Mode 07: Pending emission related fault codes
Friday,12,July,2019,16:19:14:58999
Type 02 - VIN : 3VWRX7AJ9AM158710 (Address E8)
Type 04 - Calibration ID : 07K906055AJ 5782 (Address E8)
Type 06 - Calibration Verification Number : 87892BE9 (Address E8)
Mtnman
C?ID=53726
Just a quick update, the car is away from me for a while so I am working on getting a used ABS computer for a reasonable deal. In the future when I do the repair and program the new (used) computer I will update this thread with the part numbers I found and the results. Thanks all for the help so far!
