Overwriting changes to return to original code
Mrdeli
C?ID=165159
Before making any changes I have seen that it is best practice to copy the modules code.
If I make and save a number of changes and then decide that I want to revert to the original code, can I:
1. Simply copy in the original block of code in one go
or
2. Am I better to invidiually change back each item I have changed (and after this check that the code matches the original)
Thank you Mark
South Molton, UK
2. Return each coding/adaptation value one at a time.
There's no facility to return multiple coding/adaptation values to their previous settings.
An Auto-Scan will have all the original codings. A full set of channel maps also can't hurt. :)
