Tiguan TDI conversion ABS help needed
vwztips
C?ID=189
Looking for some guidance.
Just installed a CJAA/DSG (FWD) from a 2012 Jetta into a 2012 Tiguan (TSI/4mo automatic).
Malone did the tune. Engine is working fine with the exception of a P0381 code which I cannot find on Wiki. Have checked for power and signal wires from ECU. Only thought on this would be that I have the gasser instrument cluster installed. I have a cluster from a Euro Tig TDI but have not installed it yet.
My second issue is with ABS coding. The tig was a 4 motion with Aisin 6 speed automatic. I removed prop shaft and disconnected the Haldex unit.
I have tried all the codes from this list and the closest I come to getting rid of the errors is 5185. The scan is with the 5185 code.
Any advice, pointers, direction, would be much appreciated on either the P0381 or the ABS coding
engine and transmission combination: 4096
1029 - 1.4tsi 75 - 100kW front-wheel drive manual transmission 1029 5125
1032 - 1.4tsi 75 - 100kW front-wheel drive manual transmission (China) 1032 5128
1035 - 1.4tsi 101 - 130kW front-wheel drive manual transmission 1035 5131
1038 - 1.4tsi 101 - 130kW manual transmission 4Motion 1038 5134
1041 - 1.8tsi 105 - 130kW front-wheel drive manual transmission (China) 1041 5137
1044 - 1.8tsi 105 - 130kW front-wheel drive automatic (China) 1044 5140
1047 - 1.8tsi 105 - 130kW automatic transmission 4Motion (China) 1047 5143
1050 - 2.0tsi 125 - 160kW automatic transmission 4Motion (China) 1050 5146
1053 - 1.4tsi 101 - 130kW DSG front-wheel drive (NAR) 1053 5149
1056 - 2.0tsi 125 - 160kW DSG 4Motion (CCZD motor 132kW) 1056 5152
1059 - 2.0tsi 125 - 160kW front-wheel drive manual transmission (NAR) 1059 5155
1062 - 2.0tsi 125 - 160kW front-wheel drive automatic (NAR) 1062 5158
1065 - 2.0tsi 125 - 160kW automatic transmission 4Motion (NAR) 1065 5161 original
1068 - 2.0tsi 125 - 160kW manual transmission 4Motion 1068 5164
1071 - 2.0tsi 125 - 160kW DSG 4Motion 1071 5167
1074 - 2.0tsi 125 - 160kW automatic transmission 4Motion 1074 5170
1077 - 2.0tsi 125 - 160kW front-wheel drive manual transmission (NAR) 1077 5173
1080 - 2.0tdi 70 - 90kW front-wheel drive manual transmission 1080 5176
1083 - 2.0tdi 91 - 110kW front-wheel drive manual transmission 1083 5179
1086 - 2.0tdi 91 - 110kW manual transmission 4Motion 1086 5182
1089 - 2.0tdi 91 - 110kW DSG 4Motion 1089 5185
1092 - 2.0tdi 91 - 110kW automatic transmission 4Motion 1092 5188
1095 - 2.0tdi 111 - 130kW DSG 4Motion 1095 5191
1098 - 2.0tdi 111 - 130kW manual transmission 4Motion 1098 5194
1101 - 1.4tsi 101 - 130kW DSG front-wheel drive 1101 5197
 Monday,08,July,2019,23:11:59:45329
VCDS Version: 19.6.0.4 (x64)
VIN: 3VWJL7AJXAM022708   License Plate:
Mileage: 196150km-121881mi   Repair Order: 7-8-19 Tiguan TDI
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 4F 52 53 56 62 72
VIN: 3VWJL7AJXAM022708   Mileage: 196150km-121881miles
25-Immobilizer -- Status: Not registered 0001
   Part No SW: 03L 906 019 CM    HW: 03L 906 022 TS
   Component: R4 2,0L EDC G000AG  9971
   Revision: 12H02---    Serial number:
   Coding: 0350078
   Shop #: WSC 26214 051 00000
   VCID: 78F4F3A30B625A8FAF-802C
000897 - Glow Plug/Heater Indicator Circuit
               P0381 - 000 - Implausible Signal
                    Mileage: 196158 km
                    Date: 2013.11.28
                    Time: 00:26:32
                    Temperature: 27.9°C
                    Voltage: 12.31 V
                    Bin. Bits: 00000000
                    Torque: 219.0 Nm
                    Temperature: 42.3°C
   Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2705
   Revision: 05351112    Serial number: 00001011130184
   Coding: 0000024
   Shop #: WSC 01286 386 08256
   VCID: 1736D01F263CB5F746-8042
   Part No SW: 5N0 614 109 AP    HW: 5N0 614 109 AP
   Component: J104   C6 450M VDE2 0005
   Revision: --H07---    Serial number: 00000005590526
   Coding: 0005185
   VCID: 79F2F6A730684387D0-802C
                    Reset counter: 226
                    Mileage: 196158 km
                    Date: 2013.11.28
                    Time: 01:33:08
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 215
                    Hex Value: 0x0000
                    Reset counter: 226
                    Mileage: 196158 km
                    Date: 2013.11.28
                    Time: 01:33:08
01324 - Control Module for All Wheel Drive (J492)
                    Reset counter: 226
                    Mileage: 196158 km
                    Date: 2013.11.28
                    Time: 01:33:08
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0404
   Revision: 00001018
   Coding: 0000001002
   VCID: 00049B439BB2124F97-8054
          B10AB F0 [009] - Too Low
                    Reset counter: 226
                    Mileage: 196155 km
                    Date: 2019.07.08
                    Time: 04:22:08
   Part No SW: 5K0 937 086 N    HW: 5K0 937 086 N
   Component: BCM PQ35 M    021 0064
   Revision: BJ021001
   Coding: 6F180A1B80232EC4008800C11000854448010086524D8D60648040000040
   VCID: 3F8658BFAECCADB7AE-806A
   Subsystem 1 - Part No: 5N1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS 030412 03  32  0010
   Coding: 009795
                    Reset counter: 226
                    Mileage: 196158 km
                    Date: 2013.11.28
                    Time: 01:40:32
                    Voltage: 12.00 V
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 226
                    Mileage: 196158 km
                    Date: 2013.11.28
                    Time: 00:25:43
                    Voltage: 12.30 V
   Part No SW: 5N0 959 655 S    HW: 5N0 959 655 S
   Component: J234__20G VW10 HI   2118
   Revision: 24017000    Serial number: 003L6P5XHBJB
   Coding: 0012359
   VCID: 4D9A7277D4600F272C-8018
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 00000000008A6T
   Subsystem 3 - Serial number: 0005.03.120000300000650055ÿ†63
   Subsystem 4 - Serial number: 650055ÿ†6332MTS635430842 ÿ†63
   Subsystem 5 - Serial number: 30842 ÿ†6342MTS665450852 ÿ†63
   Subsystem 6 - Serial number: 50852 ÿ†6351HTS6FJI51AKR ÿ†63
   Subsystem 7 - Serial number: 51AKR ÿ†6361HTS6RFPF1AKR ÿ†63
   Subsystem 8 - Serial number: F1AKR ÿ†63727TS65Q7U0AKR ÿ†63
   Subsystem 9 - Serial number: U0AKR ÿ†63827TS6JIOSMAKJ ÿ
   Subsystem 10 - Serial number: SMAKJ ÿ
03551 - Functional Restriction of Seat Occupied Recognition
            000 - - - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 18
                    Mileage: 196155 km
                    Date: 2013.11.28
                    Time: 00:35:36
   Part No SW: 5K0 953 501 AT    HW: 5K0 953 569 H
   Revision: FF010041    Serial number: 20120410301432
   Coding: 198A140000
   VCID: 7CFCEFB3F75A76AFCB-8028
   Component: E221__MFL-TAS  H31 0033
   Coding: 820000
617735 - Selector Lever Park Position Lock Switch
          B1162 11 [008] - Short to Ground
                    Fault Frequency: 17
                    Reset counter: 11
                    Mileage: 196155 km
                    Date: 2019.07.08
                    Time: 00:01:31
   Part No SW: 5N0 920 972 E    HW: 5N0 920 972 E
   Component: KOMBI         H04 0617
   Coding: 211F00
   VCID: 356A3A9794F067E774-8060
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 260312F2000812
   Coding: 356002
   VCID: 3D7A22B7A4C0BFA7BC-8068
                    Mileage: 196158 km
                    Date: 2013.11.28
                    Time: 01:38:19
   Component: IMMO          H04 0617
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD0D9EB8DCEF81F29-803E
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H35 0265
   Serial number: VWZAZ2M4214383
   Coding: 0400040104000C000000100A
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 234EF4CF2A64E957AA-8076
   Component: NAR_V2  0002
1048629 - Aux IN Socket
          B1104 13 [009] - Open Circuit
                    Reset counter: 226
                    Mileage: 196155 km
                    Date: 2019.07.08
                    Time: 04:24:40
1048652 - Telephone Microphone
          B1048 13 [009] - Open Circuit
                    Reset counter: 226
                    Mileage: 196155 km
                    Date: 2019.07.08
                    Time: 04:24:40
          B11CF 53 [009] - Deactivated
                    Reset counter: 226
                    Mileage: 196155 km
                    Date: 2019.07.08
                    Time: 04:24:40
1048642 - Internal Control Module Memory Check Sum Error
          B2000 42 [009] - General memory failure
                    Mileage: 196158 km
                    Date: 2019.07.08
                    Time: 01:18:56
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0503
   Revision: 13110009    Serial number: 0004683325
   Coding: 0004B4
   VCID: 387433A383E29A8F6F-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1504
   Serial number: 00000006629752
   Coding: 000490
          B11EC 54 [009] - Missing Calibration / Basic Setting
131584 - Motor for Rear Window Regulator
          B11EE 54 [009] - Missing Calibration / Basic Setting
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.286 1002
   Revision: 1AH03836    Serial number: 00120870104201
   Coding: 0000258
   VCID: 3C7C2FB37FDAB6AF8B-8068
   Component: EZE_2         H40 1623
   Coding: 050B0500
   VCID: 6FE6C8FFBE2C1D377E-803A
   Component: J245EE20SKB13  H03 0220
   Component: J394EE20SKB13  H03 0220
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0004672738
   Coding: 0004B4
   VCID: 397236A7B8E8838790-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1504
   Serial number: 00000006662726
   Coding: 000490
   Revision:   H19       Serial number: 00000000097111
   Coding: 0026156
   VCID: 36683D9B41F66CFF7D-8062
                    Fault Status: 01110000
                    Reset counter: 226
                    Voltage: 11.90 V
                    Count: 101
                    Hex Value: 0x1270
                    Hex Value: 0x0082
                    Hex Value: 0x0101
End-------------------------(Elapsed Time: 02:36)--------------------------
I would guess that the gasoline cluster is the reason behind the P0381 code. That cluster likely has no provision for diesel-specific warning light (the "glow plug" light). I'm skeptical that there's actually a physical circuit for this. I would guess it's more likely a virtual circuit implemented via CAN messages, but the net result is the same: The ECU knows it can't turn that warning light on.
Spacewalker
Poland
C?ID=159607
100 % not cluster issue
you can install Petrol cluster to Diesel , and in reverse way ...no problem with that
First - your GW show incorrect coding
2nd - what VIN you keep in ECU ?
Did you adapt that ECU to your VIN, or just did IMMO OFF? to start engine
3rd - not use if Jetta talk good with EPB as she never see that in PQ35 , and you also have issue in EPB
Some errors will go if you write proper VIN to new ECU,.
similar is with PQ35 ABS , when VIN is a part of coding , and Engine type too
Even if ABS is use Cluster VIN, ECU still broadcasting VIN
If VIN is mismach - ABS can freak out because it see different platform
at the end .... if you not fix it , better use Passat ECU ...or Sharan , but B6/CC Passat with EPB, not NMS Passat US....
they use TRW ABS system and EPB
you can definitely stay away from cluster , this only "display "
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
@Spacewalker
P0381 Glow Plug/Heater Indicator Circuit Malfunction
UWE you are correct , Cluster is problem because missing Glow plug signal in cluster . I told him this last time that cluster has to be modified to work with TDI ECU when he did other Tiguan conversion few years ago.
As far as VIN you can see since he has VIN form Jetta so ABS will complain about this .Most likely he has Immo off
Spacewalker
Poland
C?ID=159607
Did hundreds of cluster swap, some Petrol have no LED for DPF , and they working after SW conversion to diesel, and ECU not show any error
dont think so
I am almost 100% sure LED is on the PCB, just need proper EEprom from Diesel , so is much easier to play with that cluster , just with proper SW
vwztips
C?ID=189
@Spacewalker
Thank you Jetta, 97 and Spacewalker for your replies. It seems like you are contradicting each other on the cluster. The last conversion Jetta, 97 combined parts of the donor Golf IC with the Tig IC as they were fairly common to each other. On this conversion the donor Jetta's cluster was very basic and did not look the same. That's why I picked up a cluster from a Euro Tig TDI. My thinking is that would solve issues with the dual gas tank senders, have the correct tach and the GP light.
Changing the VIN in the ECU makes since to try and clear up the GW and possibly the ABS. Will the cluster need the VIN correction too?
Jetta 97
C?ID=81680
dont think so
Correct, but still have Gasoline Sw in it , that why I said need to be MODIFIED.
Jetta 97
C?ID=81680
5N0 920 972 E is Gasoline cluster form your Scan.
vwztips
C?ID=189
Just a follow up to my issues. Marin (Jetta, 97 helped me work through the issues and now everything is working and talking to each other as they should.
Just a few notes:
Needed Tiguan VIN # in donor Jetta ECU
Used stock Tiguan IC which Marin reworked with Passat TDI foils, so the tach and GP lights are correct. Also required some internal coding to work with the electronic brake
Coded ABS module with 5185 code
Now it is all good. Just have to get used to driving a DSG...…...
