2011 Tiguan - Cylinder Misfire
ronin4740
C?ID=227579
Need help/suggestions on fix..
VagCom Dump below. Coil pack maybe? Thanks in advance
Monday,08,July,2019,07:55:36:35695
VCDS Version: 18.9.0.2 (x64)
VIN: WVGBV7AX7BW525616   License Plate: RCPLT000
Mileage: 244070km-151658mi   Repair Order: 0000887
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 2E 37 42 44 46 4F 52 53 56
          62 65 69 72 77
VIN: WVGBV7AX7BW525616   Mileage: 244070km-151658miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 027 R    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 01 7786
   Revision: P3H06---    Serial number:
   Coding: 0423010A190F0160
   VCID: 3A7B178575D4F69ADB-806E
               P0300 - 000 -
                    Mileage: 244071 km
                    Date: 2013.11.28
                    Time: 07:37:23
                    RPM: 3361 /min
                    Load: 82.3 %
                    Speed: 80.0 km/h
                    Temperature: 81.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 850.0 mbar
                    Voltage: 14.224 V
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected - MIL ON
                    Fault Status: 11100000
                    Mileage: 244071 km
                    Date: 2013.11.28
                    Time: 07:37:23
                    RPM: 3361 /min
                    Load: 82.3 %
                    Speed: 80.0 km/h
                    Temperature: 81.0°C
                    Temperature: 21.0°C
                    Voltage: 14.224 V
004874 - Cylinder Disabling
               P130A - 000 -  - Intermittent
                    Mileage: 244072 km
                    Date: 2013.11.28
                    Time: 07:37:31
                    RPM: 3077 /min
                    Load: 52.1 %
                    Speed: 79.0 km/h
                    Temperature: 85.0°C
                    Temperature: 21.0°C
                    Voltage: 14.351 V
   Part No SW: 09G 927 750 LQ    HW: 09G 927 750 LQ
   Component: AQ 250 6F           1771
   Revision: 00H90000    Serial number:
   Coding: 0000840
   VCID: 0B1582416ACE3F12B0-805E
Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
   Part No SW: 5N0 614 109 Q    HW: 5N0 614 109 Q
   Component: J104    C4 450 V2C4 0006
   Revision: --H28---    Serial number: 00000003349576
   Coding: 0002336
   VCID: 3979088970D2FD82D2-806C
   Part No SW: 7N0 907 426 L    HW: 7N0 907 426 L
   Component: AC Manuell    H17 0202
   Revision: 00012001
   Coding: 0000001002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 3D711C99ACFAC1A2FE-8068
   Part No SW: 5K0 937 087 Q    HW: 5K0 937 087 Q
   Component: BCM PQ35 H+   111 0148
   Revision: BL111001
   Coding: 6D580A3F80232EC4808800859000050440015186524D8D605C8000000040
   Shop #: WSC 26105 444 85824
   VCID: 43856A61C21EB75288-8016
   Subsystem 1 - Part No: 5N1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS 261010 03  32  0010
   Coding: 009795
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 0
                    Mileage: 226597 km
                    Date: 2013.02.04
                    Time: 06:40:07
                        Term 15 Off
                    Voltage: 12.30 V
                    Fault Status: 00101010
                    Fault Frequency: 21
                    Reset counter: 208
                    Mileage: 241601 km
                    Date: 2013.10.20
                    Time: 20:29:55
                    Voltage: 13.95 V
   Part No SW: 5N0 959 655 P    HW: 5N0 959 655 P
   Component: J234__204 VW10 HI   1918
   Revision: 22014000    Serial number: 003GJPKRPJC.
   Coding: 0012340
   VCID: 4A9B47452534661A4B-801E
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 00000000001ZJ2
   Subsystem 3 - Serial number: 0029.09.100000300000630098ÿ†63
   Subsystem 4 - Serial number: 630098ÿ†6332MTS617252860 ÿ†63
   Subsystem 5 - Serial number: 52860 ÿ†6342MTS610762870 ÿ†63
   Subsystem 6 - Serial number: 62870 ÿ†6351HTS61P8RF9KJ ÿ†63
   Subsystem 7 - Serial number: RF9KJ ÿ†6361HTS6JI0HG9KR ÿ†63
   Subsystem 8 - Serial number: HG9KR ÿ†63727TS6QKR0G9KR ÿ†63
   Subsystem 9 - Serial number: 0G9KR ÿ†63827TS6RD01G9KJ ÿ
   Subsystem 10 - Serial number: 1G9KJ ÿ
   Part No SW: 5K0 953 501 AT    HW: 5K0 953 569 H
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101029300456
   Coding: 198A140000
   VCID: 7CF7D19DF76008AA89-8028
   Component: E221__MFL-TAS  H07 0013
   Coding: 820000
   Part No SW: 5N0 920 972 B    HW: 5N0 920 972 B
   Coding: 210F00
   VCID: 326B3FA565A40EDA13-8066
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 231010F1002600
   Coding: 356002
   VCID: 316930A968A235C26A-8064
   Part No SW: 0AY 907 554 D    HW: 0AY 907 554 D
   Component: Haldex 4Motion      0042
   Coding: 0000005
   VCID: 4C97415D2F40782A79-8018
   Component: IMMO          H20 0420
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADBE7C58DF4861A6B-803E
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668860609
   Coding: 020000
   VCID: 275DDEF156667B72B4-8072
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H53 0319
   Serial number: VWZAZ2M4237898
   Coding: 0401042104000C000000100A
   ROD: EV_RNS315NARV2UDS_VW32.rod
   VCID: 2541D4F9246A696286-8070
   Component: NAR_V3_(0037)  0037
1048625 - Front Left Audio Signal Output
          B1105 F0 [008] - Short Circuit Between Poles
                    Reset counter: 235
                    Mileage: 225599 km
                    Date: 2018.08.25
                    Time: 07:23:05
1048626 - Front Right Audio Signal Output
          B1106 F0 [009] - Short Circuit Between Poles
                    Reset counter: 196
                    Mileage: 224767 km
                    Date: 2018.08.10
                    Time: 06:49:16
   Part No SW: 5N0 959 701 D    HW: 5N0 959 701 D
   Component: Tuer-SG         009 2101
   Coding: 0001205
   VCID: 366303B541CC12FA3F-8062
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.286 0802
   Revision: 1AH03831    Serial number: 00102990065601
   Coding: 0000258
   Shop #: WSC 00000 028 00001
   VCID: 3B7512817AEECF92C0-806E
   Component: EZE_2         H35 0614
   Coding: 050B0500
   VCID: 6FEDF6D1BE1663323C-803A
   Component: J245EE20SKB13  H02 0220
   Part No SW: 5N0 959 702 D    HW: 5N0 959 702 D
   Coding: 0001204
   VCID: 377D0EB146C6EBF224-8062
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000020761
   Coding: 0023057
   VCID: 33653AA152BE07D218-8066
   Part No SW: 5N0 959 703 E    HW: 5N0 959 703 E
   Component: Tuer-SG         007 2102
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           111 0821
   Coding: 018704
   Shop #: WSC 26105 444 100088
02903 - Hard Warning 2
                    Mileage: 229944 km
                    Date: 2013.04.08
                    Time: 07:06:02
                    Text: 3454809797
                    Pressure: 1.90 bar
                    Pressure: 2.30 bar
                    Temperature: -6.0°C
                    Text: 00
                    Speed: 34.0 km/h
   Component: Anhaenger     H12 0100
   Revision: 3A001001    Serial number: 00000426625905
   Coding: 030D000100000000
   Shop #: WSC 01357 444 00001
   VCID: 306F35AD63A83CCA65-8064
   Part No SW: 5N0 959 704 E    HW: 5N0 959 704 E
   Coding: 0001168
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663952338
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A7B1785BDD4F69ADB-806E
End-------------------------(Elapsed Time: 03:05)--------------------------
It certainly couldn't hurt to swap the #2 coil pack with one from a different cylinder to see if the problem moves with it, but at 151,000 miles, I wonder: When was the last time this engine got new spark plugs? How badly carboned up are the intake valves?
ronin4740
C?ID=227579
It got spark plugs within the past 10 days. Had carbon walnut blasted out at around 90K miles... Intakes are probably pretty carboned up again and I'll start to set aside the $$$ to get that job done as it's not something I think I can accomplish in my garage with the limited tools I have on hand.
I'll try swapping the coil pack from #2 to #1 when I get home and see if the problem follows the coil pack or stays put.
Thanks Uwe!
ronin4740
C?ID=227579
I swapped the coil packs - 2 to 3 and 3 to 2, cleared the codes, cycled power to the car, started it and observed that the misfire fault followed the coil pack to cylinder 3.
Ordered coil packs. Should be here today and will hopefully fix the issue.
NostraJackAss
Excellent........ OP
Be sure to verify the grounds to the coil packs are good otherwise you will burn up another one.
ronin4740
C?ID=227579
NostraJackAss
Chinese Replacement Auto Parts! :rolleyes:
Some Chinese stuff is good just like some German stuff that is re-boxed on the German port & being purported in some shipping container on the dock and called "Made like technology in Germany that used to be produced" is absolute shit typically or of origin unknown or sometimes China's sloppiest work!
Beware many German & US companies are now owned OUTRIGHT by the Chinese.
Thanks Jack. I presume I can do that with an Volt meter on ohm setting and testing continuity from the housing to the engine block?
For reference these are the coil packs I purchased.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
This will be the third set in the Tiguan with the second set being installed at around 80K miles.
Nope load light or be sure the tracks can carry current........beep beep tests are not worth a shit outside finding a track.
All true. But read the reviews on Amazon for that item.
ronin4740
C?ID=227579
True - reviews are crappy. I was in a hurry to get them and while I think I might have looked at the over all rating I didn't read the reviews. *chuckle* I still have three good old ones which I'll stick in a bag where the spare tire goes in case one of them goes poof in the next few weeks.
ronin4740
C?ID=227579
Prepare to have a nice little chuckle. I lost one of the new CP's this morning on the way into work. Car was up to temperature and I goosed it going up a hill towards the highway. Engine started running rough, ECP light came on, CEL came on and was flashing and car went into limp mode. Fortunately I was close to my house and had the VagCom on hand.
The CP that died was also in Cylinder 2. So now I have to think that even though the coil packs I bought were the cheap Chinese knock offs if I were to lose one its less likely I'd lose the SAME one that I lost previously and more likely I'd lose one in Cylinders 1, 3 or 4.
So what other things can I replace which might cause the coil pack in this cylinder to stop dying? The spark plug? The wiring connector? The wiring harness? Does this indicate a more serious problem with the engine? Should I take it into the local VW repair shop and just let them fix it at this point?
I can buy a dozen coil packs and keep swapping them out but that seems kind of inefficient...
ronin4740
C?ID=227579
Thanks. I guess I need to find the other end of that harness and push some current through it. is it modular under the hood or does it combine back into some other connector somewhere else?
NostraJackAss
or
Couldn't you circumvent that travesty and run new additional ground overlays to each coil directly and tie it into a bus bar & back to ground on the battery using WD and connections that would qualify?
:rolleyes:
ronin4740
C?ID=227579
*chuckle* Thanks for that suggestion Jack but I'd rather keep the wiring as close to OEM as I can.
NostraJackAss
That's the point, the OEM is crap and insufficient & not what is wanted and if kept that way it will only be a problem and or expensive, there are ways to do stuff without a butcher job look but I understand your thought process for a cosmetic & respect it.
I like stuff to look nice too and function.
Be creative!
