Audi A6 C7/4G Facelift : Enabling Green Menu with VCDS
Wajahat
C?ID=355991
I'm posting this query again as a new thread. There are already a few threads about the issue of activating the green menu by activating the developer mode in the control module 5F. The solution was always privately shared by the VCDS staff to the original posters in the form of a lbl file. When i tried the solution shared to me by one of the kind fellow forum members, I still couldn't get security access to the control module. I think this happens because the lbl file is most probably adapted to the specific part number and is not generic.
I'm posting my full VCDS scan below:
Friday,05,July,2019,20:17:16:08519
VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
Dealer/Shop Name: Ross-Tech LLC.
Workshop Code: 444 03743 000001
VIN: WAUZZZ4G6FN06XXXX  License Plate: ACTW_9351
Mileage: 92224km-57305mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 28 36 3B 3C 42 44 46 52 53
          55 5F 62 6C 6D 72 85 8B 8E 8F 90 AC
VIN: WAUZZZ4G6FN06XXXX   Mileage: 92224km-57305miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FQ    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 0655
   Revision: 85H23---
   Coding: 12254012234401080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021FQ 002002
   ROD: EV_ECM20TDI01104L906021FQ_002.rod
   VCID: 79AE1876395B46BF8DB-802C
   Part No SW: 4G0 927 153 L    HW: 0CK 927 156 Q
   Component: 0CK 20TDI RdW H01 0002
   Revision: --H01---    Serial number: 0000000192
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002014
   ROD: EV_TCMDL382021_AU57.rod
   VCID: 323CEF5AA4AD75E70C1-8066
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 06A29E49604579929B00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3FDAB66E67FFA88FF3F-806A
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 01A9700E000000000000
   VCID: 7AAC077A3CDD4DA7841-802E
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 10021500040856
   Coding: 340209782D0000
   VCID: 63925A1EABD7AC6FB77-8036
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00001007965701
   Coding: 0105001440349FE2C101408380001800CF9CC7082E08020100000894E10112020040003D030000
   VCID: 71BE205661AB0EFF35B-8024
   Component: WWS57X 150128  H37 0080
   Serial number:         150203202021
   Coding: 0045F7
   Serial number: 23712486
   Coding: 0200FD
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 06 02 2015  00001605
   Serial number: D499C297000000000001
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0053
   Coding: 7E04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
   VCID: 290E0836897B363FBDB-807C
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P10038096
   Coding: 30333130313630323437554A304C34473053
   VCID: 3B22C27E73E7B4AFDF7-806E
   Serial number: 3575HRB405V34OD489EM
   Serial number: 3585HRB405133HNG68KA
   Serial number: 3515JRB40085358S7OPG
   Serial number: 3525JRB406335IMMF1BA
   Serial number: 3554VRB400652RDA4PAK
   Serial number: 3564VRB4006533VUBHQ8
   Revision: --------    Serial number: 90372OBB00019
   Coding: 0000DD
   VCID: 372ADE4E4F4F90CF3BF-8062
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Serial number: 27 01 2015  E0078995
   Part No SW: 4G8 920 933 F    HW: 4G8 920 933 F
   Component: TDieRdwAcc    H08 0043
   Revision: 04001037    Serial number: 658140215592001
   Coding: 138612000F550008000000
   Shop #: WSC 38916 002 1048576
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 3332EA5E5BB77CEF077-8066
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Revision: --------    Serial number: 00000001734972
   Coding: C0CD074418
   VCID: 75B61446154322DFE93-8020
   Serial number: 5347185803
   Voltage stabilizer:
   Serial number: 14120200000000000421
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 12021500041832
   Coding: 20
   VCID: 3D26CC666DF3BA9FE13-8068
   Revision: AA000000    Serial number: 00000134977168
   Coding: 0058130000006001000001010101102030303232203232
   VCID: 77AA1E4E0FCF50CFFBF-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA8208Z64E
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3634D34A48C569C7209-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H06 0060
   Serial number: 0360468980
   Coding: 040311
   VCID: 392ED87679DB86BFCDB-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0060
   Serial number: 0360399313
   Coding: 040311
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F17015E00628002080013
   VCID: 45D6A48605A3F25FB93-8010
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0004380674
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0359956359
   Coding: 0100063820B93094C32009040E010F470000000000000000000000000000
   Subsystem 1 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS20.403  H03 0004
   Serial number: 0000FST0004DFC800000
   Coding: 901F00
   Subsystem 2 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS20.403  H03 0004
   Serial number: 0000FST0004DCUN00000
   Coding: 801F00
   Component: TSG BF        H03 0507
   Coding: 011F17015E00628002080002
   VCID: 46D4A38A38A5F947B09-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001357850
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D06FC26BD932A1F513-8078
   Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0081
   Coding: 04FA02202A170200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
   Coding: E01F00
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
   Part No SW: 4G1 035 019     HW: 4G1 035 020
   Component: MU-H-ND-EU    041 0924
   Serial number: A590B0F7501530
   Coding: 017502010000000013111102000A00032F0006E5F17001009F
   Shop #: WSC 17616 002 1048576
   VCID: 5EE46BEA80B58187989-800A
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9EY800Q3X
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349OBA000OJ
   Compact Disc Database:
   Component: Gracenote2  --- 1012
0014 - Connection between Antenna Amp 1 for Digital Radio and Antenna
          B1274 13 [009] - Open Circuit
                    Reset counter: 32
                    Mileage: 92167 km
                    Date: 2019.07.03
                    Time: 13:48:28
                    Voltage terminal 30: 12.3 V
                    Status of digital radio antenna 1-Antenna current: 0 mA
                    Status of digital radio antenna 1-Connection between radio and antenna amplifier: Electrical OK
                    Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Open circuit
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 16.777215
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 16.777215
   Component: TSG HL        H03 0507
   Coding: 010F15004000628002080002
   VCID: 49CEA8B629BB163F5DB-801C
   Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
   Component: D4-PA RVC Mid H07 0050
   Coding: 027502010201000300
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914_VW51.rod
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0150
   Revision: 14005001    Serial number: 027500152
   Coding: 093205C010
   ROD: EV_HDSGAu571.rod
   Component: TSG HR        H03 0507
   Component: DPC-SG        H27 0081
   Coding: 6A160000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C00F1228689231746D-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
   VCID: 270A0E0E9F6F004FABF-8072
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000621102157
   Coding: 04C0B9181111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313EE056A1AB4EFF75B-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 150160316
   ROD: EV_RDCMA00100_008.rod
End----------(Elapsed Time: 02:04, VBatt start/end: 12.2V/12.2V)-----------
Would immensely appreciate any help from VCDS staff as the fix at the moment appears to be a customized label file based on corresponding part number.
Thank you.
P.S. BTW, my car is a European (German reg) model if that matters to help with part numbers
Wajahat
C?ID=355991
Thank you for your swift response TBAx! I'll try out later today when I'm back home.
Wajahat
C?ID=355991
So its a partial success. I could enable the developer mode in the module 5F, thanks to the file TBAx shared with me but sadly despite numerous tries the green screen is still not enabled. I've tried to press the buttons 'Car' + 'Menu' together numerous times but no Green menu.
I also noticed that i can't even access the Engineering menu (Red menu) that was previously accessible with the key combination of 'Car' + 'Back' buttons.
I had my firmware updated by Audi last week as i was having reception problems with DAB+. My firmware was upgraded from "MHI2_ER_AU57x_K2570" to "MHI2_ER_AU57x_S2570". Refer to the image below:
https://www.dropbox.com/s/ct08wmn7ik68b2g/20190703_232745.jpg?dl=0
Don't even know what the 'S' stands for as i've only came across P and K characters in the Audi firmware nomenclature. Can someone enlighten me on what the 'S' stands for as Audi dealer has been quite tight lipped and only said that a MMI firmware is available for my car that addresses radio reception issues and didn't disclose further details. Don't even know if it's possible for me to request them to revert back to the K2570 version as the new version doesn't do anything noticeably better.
Any further tips on any extra procedures that must be carried out in terms of adaptation to enable the hidden menus?
Wajahat
C?ID=355991
So guys, it is apparent that the new firmware has probably locked down hidden menus as I cannot access both the red menu which was previously accessible without any tweaks with VCDS and the green menu which continues to be inaccessible even after enabling the developer mode in the 5F control module.
The reason why I want to enable the green menu is to be able to tweak the settings to activate 'Audi Connect' services. Now that this menu is not visible anymore, can the VCDS gurus probably guide me to the various adaptations that would be necessary in the 5F control module?
Thanks in advance for any further insights.
TBAx
DE
C?ID=287144
The green hidden menu is accessed in another way on the newer/facelifted cars:
NAV/MAP (or CAR) + RADIO
For the red engineering menu it's:
NAV/MAP (or CAR) + MEDIA
Note: first press NAV/MAP (or CAR) and then press the second button (MEDIA/RADIO). Hold both for about five seconds and then let go. Menu should start.
IndianaMuscle
Banned
NO ASS no cert no worries
C?ID=368009
May I ask what value these menus are to you(us)?
TBAx
DE
C?ID=287144
In the green menu you can:
  • export screenshots
  • view status information (GPS, etc)
  • see the "real" car speed determined by the GPS
  • change when, during active navigation, a shorter route is considered (default it switches routes if the new one is 4+ minutes faster)
  • show "additional map cursors"
  • change how and when zooming occurs on the map
  • change the after-run (ignition off) time of the MMI
...maybe more.
Wajahat
C?ID=355991
Thank you for the tip! I'll give this a try over the weekend.
IndianaMuscle
Banned
C?ID=368009
...maybe more.
Wow. Nice.
santti
Finland
C?ID=379770
Having a same problem than described in the first message in this thread. Could anyone help?
Thursday,21,November,2019,16:01:27:43746
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64(VMWare)
VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4G7FN09XXXX   License Plate: XXX-333
Mileage: 98656km-61301mi   Repair Order:
Scan: 01 02 03 05 08 09 13 15 16 17 18 19 28 34 3B 3C 42 44 46 52
          53 55 5F 62 69 6C 6D 72 82 85 8B 8E 8F 90 AC
VIN: WAUZZZ4G7FN098204   Mileage: 98656km-61301miles
17-Instruments -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRTD)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G2 907 401 B    HW: 4G2 907 401
   Component: 3.0TDI EDC17  H34 0007
   Revision: 92H34---
   Coding: 1225401A057601030000
   Shop #: WSC 41314 002 1048576
   ASAM Dataset: EV_ECM30TDI0114G2907401B 001007
   ROD: EV_ECM30TDI0114G2907311C.rod
   VCID: 2411EC549E5151078DF-8071
   Part No SW: 4G0 927 166 C    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0007
   Revision: --H03---
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 2D070970CD9B904F521-8079
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 17A6DE49E8657B92BB00
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 41DF45C06103642F869-8015
   VCID: 7AADF22C4CD5F7F7873-802F
   Serial number: 06051500042303
   Coding: 36121178350000
   VCID: 6393AF48DBDF163FB45-8037
   Revision: 15020001    Serial number: 00001066307202
   Coding: 0105801440348FE2C901408300001800CF9CE708AE08022100000894E10117020040003D030000
   VCID: 71BFD50011A3B4AF369-8025
   Component: WWS57X 150412  H37 0080
   Serial number:         150427123019
   Coding: 0045F7
   Serial number: 23949418
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
   Serial number: 27 04 2015  00001658
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R5DZ902
03608 - Humidity Sensor in Fresh Air Intake Duct
                    Fault Status: 01100101
                    Reset counter: 229
                    Mileage: 98656 km
                    Date: 2019.11.21
                    Time: 15:56:06
   Coding: 7F04010202
   VCID: 290FFD60F9738C6FBE9-807D
   Revision: --------    Serial number: 003P1004K6HX
   Coding: 30333130313730323536554A304C34473053
   VCID: 3B23372803EF0EFFDC5-806F
   Serial number: 3575HRB405R36CAO3OH
   Serial number: 3585HRB405F36RT428MT
   Serial number: 3515JRB400U54R1AA1UL
   Serial number: 3525JRB405L36OUMNGV%
   Serial number: 3554VRB400S54R1CDGH+
   Serial number: 3564VRB401654R1CA9UO
   Revision: --------    Serial number: 90372ODN00055
   Coding: 0000DD
   VCID: 372B2B183F472A9F38D-8063
   Serial number: 24 04 2015  C0077017
   Revision: 04001037    Serial number: 658060515596029
   Coding: 038612001F550008000000
   VCID: 33331F082BBFC6BF045-8067
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 G    HW: 4H0 265 105 G
   Component: Standheizung  H24 0260
   Revision: 66006006    Serial number: 20141113132105
   Coding: 553F01
   VCID: 2615F65CE8EDA31793B-8073
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000001840286
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUDS 001028
   Serial number: 9594616303
   Voltage stabilizer:
   Serial number: 150307000000000002E2
   Serial number: 07051500042317
   Coding: 21
   VCID: 3D2739301DFB00CFE21-8069
   Coding: 008003
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3B1378C797E25F60D-807B
   Revision: --------    Serial number: EJ1BPA8209FDGE
   ROD: EV_SARA2.rod
   VCID: 3635261C38CDD39723B-8063
   Serial number: 0367657459
   Coding: 040321
   VCID: 392F2D2009D33CEFCE9-806D
   Serial number: 0367833189
   Coding: 040321
   Coding: 011F17015C00628002080013
   VCID: 45D751D075AB480FBA1-8011
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0027760348
   ASAM Dataset: EV_RCEPS 009013
   Revision: 00002001    Serial number: 0367646693
   Coding: 0100063820B97080C32009842C010F470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000346953
   Subsystem 2 - Part No SW: 4G0 947 135 C    HW: 4G0 947 135
   Serial number: 0000000AP00050946433
   VCID: 46D556DC48AD4317B3B-8013
   Revision: --------    Serial number: 00000001457659
   VCID: 34311C142EB1C1871DF-8061
   Coding: E01F00
   Coding: E01F00
   Coding: E01F00
   Coding: E01F00
   Part No SW: 4G1 035 043 S    HW: 4G1 035 043
   Component: MU-H-N-EU     041 0389
   Serial number: A591E0F7532010
   Coding: 017502010000000213110002000A00032F0006E5F17001009F
   VCID: 2E050E7CC09DEB576BB-807B
   Subsystem 1 - Part No SW: V03 959 801 PR    HW: -----------
   Component: ECE 2018  --- 0166
   Serial number: AUZ8Z9FY8010XU
   Serial number: 90349OE40007Q
          U1014 00 [009] - -
                    Reset counter: 229
                    Mileage: 98656 km
                    Date: 2019.11.21
                    Time: 15:56:11
                    Voltage terminal 30: 11.9 V
                    Byte_Coding_Condition-byte_7_condition: ERROR
   VCID: 49CF5DE059B3AC6F5E9-801D
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 7B001002    Serial number: 0367834132
   Coding: 0100000202000000
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H09 0361
   Revision: 11001001    Serial number: 82330JG0157099
   Coding: 0213000001010102010102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
9617993 - Proximity Camera
          B145C 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 229
                    Mileage: 98656 km
                    Date: 2019.11.21
                    Time: 15:56:09
                    Voltage terminal 30: 11.5 V
                    Terminal 15 status: Terminal 15 on
9616786 - Surroundings Camera Front
          B127C F0 [009] - Calibration Failed
                    Reset counter: 229
                    Mileage: 98656 km
                    Date: 2019.11.21
                    Time: 15:56:08
10489856 - No Basic Setting
          B2010 00 [009] - -
          [TopView system not calibrated]
                    Reset counter: 229
                    Mileage: 98656 km
                    Date: 2019.11.21
                    Time: 15:56:08
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number: 114500981
   Coding: 093205C011
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 M    HW: 4G0 919 604 M
   Component: HeadUpDisplay H07 0304
   Coding: 470000
   ASAM Dataset: EV_HUDContiC7 001025
   ROD: EV_HUDContiC7.rod
   VCID: 3537211025CBD88F2A1-8061
   Coding: EA160000
   VCID: 2C010474F681994745F-8079
   Coding: 7F04010202
   VCID: 270BFB58EF67BA1FA8D-8073
   Serial number: 005000620205157
   Coding: 04C0BB1C1111
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
   VCID: 313F1500D1A3F4AF769-8065
   ROD: EV_RGS_R.rod
   VCID: 323D1A0CD4A5CFB70F3-8067
   Revision: 00000000    Serial number: 151050916
End----(Elapsed Time: 02:06, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
TBAx
DE
C?ID=287144
@santti: Please try this Redirect-Label - https://ufile.io/f2kaqxbf
It should be placed in your C:\Ross-Tech\VCDS\Labels\User directory.
It redirects all module 5F part numbers that start with
  • 4G1-035-020
  • 4G1-035-021
  • 4G1-035-024
  • 4G1-035-025
  • 4G1-035-034
  • 4G1-035-043
  • 4G1-035-044
  • 4G1-035-046
  • 4G1-035-047
  • 4G1-035-049
to the 4G1-035-MIB-HGH2.CLB label, which contains the required logic to switch to the engineering session.
P.S.: File is available for 30 days, so grab it while it's there.
santti
Finland
C?ID=379770
Using the redirect label and new security access code I was able to set 'developer mode' to activated. Thanks a lot @TBAx! :) Even the green menu should be activated now, a was unable to access to the menu. I tried all known combinations (menu + car, nav + radio, car + radio) but no success. Three finger salute to mmi works fine and rebooted mmi before trying access to green menu.
santti
Finland
C?ID=379770
Finally found correct key combination to enter the green menu. In my case it was 'back - lower left softkey'. In comparison to older ones (mmi 3gp) the functionality seems very limited, so couldn't find what I was looking for.
rhunter92
New York, USA
C?ID=348409
Hey I have a c7.5 and im having the same problem .. cant seem to access the green menu .. any help would be great .. I got as far as 5F on VCDS but its asking me to pick from a list of channels I cant just pick channel 6 like what is shown in youtube videos
TBAx
DE
C?ID=287144
There is no channel 6 in your 5F, but rather one named "Developer Mode".
rhunter92
New York, USA
C?ID=348409
Thanks im going to try that today .. I see you helped alot of ppl on this post .. much appreciated !!
backspace
Verified VCDS-Lite User
C?ID=25077
I also had a problem with enabling the developer menu, got "request of of range" on a 2016 RS6. I then just renamed 4G1-035-MIB-HGH2.CLB file to match the 5F partnumber that I had on my car "4G1-035-020", e.g. renamed 4G1-035-MIB-HGH2.CLB to 4G1-035-020.CLB. Then no problem setting 5F > Adaptoion > Developer mode to Active and it works fine.
rs5iswicked
C?ID=116247
Anyone found any other tricks in these menus?????
