Audi A4 Avant B8.5 Side Assist and Trailer Hitch retrofit - some errors
XPepino
Czech Republic
C?ID=91614
Hello
i retrofited in Audi A4 Avant 2013+ B8 where is ACC and Lane Assist - Side Assist and Trailer Hitch.
Made someone coding on similar car ? In Acc is original coding here.
Thank you!
In VCDS is no label for ACC and this write error:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 18 19 3C 42 44 46 52 53 56 5C
          5F 62 69 6C 72
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 JJ    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9978
   Revision: 45H25---
   Coding: 1203401A235401080000
   Shop #: WSC 33521 002 104857
   ASAM Dataset: EV_ECM20TDI01103L906018JJ 003010
   ROD: EV_ECM20TDI01103L906018JJ.rod
   VCID: 7BB60362F2D5C097CC-802E
4330 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 130901 km
                    Date: 2019.07.06
                    Time: 23:38:15
                    Engine speed: 902.00 /min
                    Normed load value: 35.7 %
                    Coolant temperature: 31 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 13.300 V
                    ACC target acceleration: 0.007 m/s˛
                    ACC control module received status-Bits 0-7: 7
                    Active brake system error status-Bits 0-7: 1
                    Status of ACC/CCS acceleration interface-Bits 0-7: 4
                    Acceleration: 0.000 m/s˛
                    Engine status: COENG_RUNNING
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K9 927 155 B    HW: 0AW 927 156 K
   Component: 0AW_20TDI_RdW H08 0002
   Revision: --H08---    Serial number: 0000000169
   Coding: 000002
   Shop #: WSC 39696 001 1048576
   ASAM Dataset: EV_TCMVL381 A02433
   ROD: EV_TCMVL381.rod
   VCID: 3B36C362B25500978C-806E
   Part No SW: 8K0 907 379 CH    HW: 8K0 907 379 CH
   Component: ESP8 front    H09 0100
   Coding: 179D4C
   Shop #: WSC 06335 000 00000
   VCID: 014A718A9839AA4796-8054
   Part No SW: 8K0 907 064 GD    HW: 8K0 907 064 FD
   Component: BCM2 2.0      H11 BCM2 2.0      H11 06210621
   Coding: 01A24040000000000000
   VCID: 78BC1C6ECBE3EB8FA1-802C
   Subsystem 1 - Part No: 8K0 959 754 H
   Component: FBSAUDIB8 IDG
No Faults Found
   Part No SW: 8K1 820 043 AJ    HW: 8K1 820 043 AJ
   Revision: C1000000    Serial number: 01160820120273
   Coding: 342800A080
   VCID: 70AC244EA393B3CF69-8024
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000466721201
   Coding: 260000118034AFE20181408300001D0D0F9CE70826090201000008004401000200020034000000
   Shop #: WSC 11111 111 111111
   VCID: 7AB80666F5EFF99FD7-802E
   Component: WWS 240812  H07 0080
   Serial number: SWF12080240485
   Coding: 00FD11
   Serial number: 20510568
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000108120124
   Subsystem 4 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: E408C346000000000001
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561 B    HW: 8K0 907 561 B
   Component: ACC3          H09 0100
   Coding: 00F6C0
   VCID: 312AE14A6819FAC726-8064
                    Reset counter: 9
                    Mileage: 130901 km
                    Date: 2019.07.06
                    Time: 23:38:10
                    Temperature: 36.0°C
                    Voltage: 13.18 V
                    Hex Value: 0x005D
                    Lateral Accel.: 0.00 m/s^2
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD952MX-
   Coding: 30514435363030303030554A304C384B3053
   VCID: 48DCACAEF3835B0F11-801C
   Serial number: 6334MSME7011601A%
   Serial number: 6344MSME6F23444FR
   Serial number: 6352QSME691C1D42P
   Serial number: 6362QSME6B1C284AW
   Serial number: 63732SME2F193270
   Serial number: 63832SME4B1B4070
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372LH30007C
   Coding: 0000DF
   VCID: 44C4B89EC7AB7F6FFD-8010
   Component: E221 - MFL  H03 0003
   Part No SW: 8K0 920 931 M    HW: 8K0 920 931 M
   Component: KOMBIINSTR.   H35 0553
   Revision: 00000000    Serial number: RBT373V8D
   Coding: 03F610004F010008020001
   VCID: 383CDC6E8B632B8F61-806C
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 E    HW: 4H0 265 105 E
   Component: Standheizung  H24 0260
   Revision: 66006006    Serial number: 20120711000709
   Coding: 5D2401
   VCID: 2404181E27EB5F6FDD-8070
   Part No SW: 8R0 907 468 J    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0051
   Revision: 1Z090025    Serial number: 2541Z128100121
   Coding: 80CF07FF00
   VCID: 46C0A296F1974D7FE3-8012
   Serial number: 1845318001
   Serial number: 12229000784011200181
   Part No SW: 8T0 907 566 A    HW: 8T0 907 566
   Component: SWA Master    H16 0040
   Serial number: 0168734764
   Coding: 010321
   Shop #: WSC 06345 128 28888
   VCID: 3E30CA76A14715BFAB-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 A    HW: 8T0 907 568
   Component: SWA Slave  H16 0040
   Serial number: 0163162133
   Coding: 010321
   Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000036999752
   Coding: 011C02204000410001
   VCID: 4DD29DBA14E1BE2722-8018
   Part No SW: 8K0 909 144 J    HW: 8K0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0030463366
   Coding: 100001010001
   Shop #: WSC 03136 002 1048576
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 383CDC6E83632B8F61-806C
   Component: BCM2 2.0      H11 0621
   Revision: 00002001    Serial number: 0182358149
   Coding: 0100062020B9000081200236A400000F
   Shop #: WSC 06335 123 12345
   Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000037011120
   VCID: 4CD490BEEFFBB72F35-8018
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 00000001165315
   ROD: EV_ParkiBrake_AU48.rod
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227HY0C7626240
   Coding: 010003020100000001
   VCID: 2600021651D7AD7FC3-8072
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 60021280700060
   Coding: 0022001
   VCID: 373EDF52467D24F768-8062
   Part No SW: 8R1 035 666 L    HW: 8R1 035 666 C
   Component: H-BN-EU       H44 1036
   Revision: --------    Serial number: 205HY0C7529404
   Coding: 0F0100010106ABEF3DA0CF5E00000403E40100020000000000
   VCID: 41CAB18AD8B96A47D6-8014
   Subsystem 1 - Part No: 8R0 060 884 ED
   Component: EUR 2017  2402
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130HM0C2521462
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000001249586
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
03623 - Invalid Security/Release Code
                    Reset counter: 9
                    Mileage: 130901 km
                    Date: 2019.07.06
                    Time: 23:38:14
                    Hex Value: 0x0004
                    Hex Value: 0x000B
                    Count: 6
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000037463431
   Coding: 010C02204000210001
Address 69: Trailer        Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: Anhaenger     H07 0070
   Coding: 0100000000000000
   VCID: 3620D2568177DDFF73-8062
   Revision: --H07---    Serial number: 525PA8-J2694AA
   Coding: 1030007
   VCID: 383CDC6E4B632B8F61-806C
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000037462359
hadez16
C?ID=289891
New Coding Unit 13: 00F6B9
