Air-con not cold... fault codes.
vw754
C?ID=52227
hi all,just brought this car for my son.
the fault codes in the EnginE ANYTHING FOR CONCERN?
aLSO THE AIR-CON NOT WORKING....AC light comes on.....but blowing warm....?
Friday,05,July,2019,18:01:53:07086
VCDS Version: 19.6.0.6 (x64)
VIN: WAUZZZ8X5CB039627   License Plate: A1 61 PLATE TDI
Mileage: 219220km-136216mi   Repair Order:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F
VIN: WAUZZZ8X5CB039627   Mileage: 219220km-136216miles
   Part No SW: 03L 906 023 KQ    HW: 03L 906 023 KP
   Component: R4 1.6l TDI   H63 9978
   Revision: --H63---    Serial number:
   Coding: 00114016030501080000
   Shop #: WSC 00046 790 00000
   ASAM Dataset: EV_ECM16TDI02103L906023KQ 003015
   ROD: EV_ECM16TDI02103L906023KG.rod
   VCID: 7F0710B2E6E6D2B7EC-802A
10116 - Fuel Rail/System Pressure
          P0087 00 [096] - Too Low
                    Mileage: 218826 km
                    Date: 2019.05.14
                    Time: 17:31:09
                    Engine speed: 1911.75 /min
                    Vehicle speed: 102 km/h
                    Coolant temperature: 95 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 14.456 V
                    Unlearning counter according OBD: 27
                    Fuel high pressure: actual value-FUP_FIL: 72.083 MPa
                    Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
                    Fuel level-FTL_CAN: 14 l
                    Fuel temperature-TFU: 62 °C
                    Fuel Metering Valve-VCV: 19.775 %
                    Fuel Pressure Regulator Valve-PCV: 38.029 %
                    Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 79931.641 kPa
10117 - Fuel Pressure Regulation Valve 2 Control Difference
          P229B 00 [104] - Pressure too High
                    Fault Frequency: 60
                    Mileage: 213452 km
                    Date: 2018.11.19
                    Time: 13:18:55
                    Engine speed: 892.75 /min
                    Normed load value: 27.5 %
                    Vehicle speed: 3 km/h
                    Coolant temperature: 58 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 14.118 V
                    Unlearning counter according OBD: 15
                    Fuel high pressure: actual value-FUP_FIL: 48.187 MPa
                    Engine status-SF_ENG_STATE: PL
                    Fuel temperature-TFU: 6 °C
                    Fuel Metering Valve-VCV: 27.116 %
                    Fuel Pressure Regulator Valve-PCV: 0.000 %
                    Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 31555.176 kPa
Readiness: 0 1 0 0 0
   Part No SW: 6R0 907 379 BB    HW: 6R0 907 379 AH
   Component: ESP8.2i front H07 0001
   Revision: --------
   Coding: 330448E9437000BBCC2B12E4C2D800920C00
   Shop #: WSC 00046 000 00000
   VCID: 7F0710B2EAE6D2B7EC-802A
   Part No SW: 8X0 820 045 A    HW: 8X0 820 045 A
   Component: J255 Klima Manuell  0140
   Revision: 0000707S    Serial number: 03030005858844
   VCID: 346D0F9E5720C1EF41-8060
                    Reset counter: 162
                    Mileage: 218708 km
                    Date: 2019.05.12
                    Time: 07:55:43
   Part No SW: 8X0 907 063 G    HW: 8X0 907 063 G
   Component: BCM PQ35  M   110 0655
   Revision: 00110 AE
   Coding: 0E000A2CA805F100201841E020000154538B6C0A01CF4122DC0887830045
   VCID: 4085534ED3986D4FD5-8014
   Subsystem 1 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
   Part No SW: 8X0 959 655 A    HW: 8X0 959 655 A
   Component: Airbag10.41   H04 0008
   Revision: --------    Serial number: 003JJ0039CR6
   Coding: 30314539303330303034554A305238583053
   ASAM Dataset: EV_Airba1041BPAAU210 001015
   ROD: EV_Airba1041BPAAU210.rod
   VCID: 48954B6EF3A8550F1D-801C
   Serial number: 3554VRB40570M8GC60TN
   Serial number: 3575HRB405J0OPMG2OOP
   Serial number: 3585HRB40510N3MG8OFP
   Rear Impact Crash Sensor:
   Serial number: 3515ZRB405B0MFP6I0U8
   Part No SW: 8X0 953 501 B    HW: 5K0 953 569 H
   Revision: FF010016    Serial number: 20110913100937
   Coding: 1184004000
   VCID: 39733EAAB8423C8792-806C
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H08 0009
   Part No SW: 8X0 920 980 D    HW: 8X0 920 980 D
   Component: KOMBI_MEDIUM  H03 0179
   Coding: 41DE00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
   VCID: 4085534EDB986D4FD5-8014
   Part No SW: 8U0 907 468 A    HW: 8U0 907 468 A
   Component: GAT 4CAN 1L M H10 0044
   Revision: 1P040023    Serial number: 2341P119180144
   Coding: FBCF005A000100010153
   Subsystem 1 - Part No SW: 8K0 915 181 H    HW: 8K0 915 181 H
   Component: J367-BDM  H07 0171
   Serial number: 00000000007100549523
   Serial number: 11278001482021200181
   Component: IMMO          H03 0179
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8X0 959 793 D    HW: 8X0 959 793 D
   Component: TSG FA        H09 0409
   Coding: 011E02200101000100
   VCID: 4E997D7619CC8B3F57-801A
   Part No: 6R0 423 156 B
   Coding: 11251
   Shop #: WSC 00046
   VCID: 2F6700F2EA06E2373C-807A
   Part No SW: 8X0 959 792 D    HW: 8X0 959 792 D
   Component: TSG BF        H09 0409
   VCID: 4D9B7A7A14CAB0272E-8018
02123 - Door Warning Light / Entry Light
                    Fault Status: 00101100
                    Reset counter: 165
                    Mileage: 218732 km
                    Date: 2019.05.13
                    Time: 18:00:59
   Part No SW: 8X0 035 183 E    HW: 8X0 035 183 C
   Component: RMC Cnct      H51 0775
   Coding: 01010001008051070023000103010000010000
   VCID: 39733EAAB0423C8792-806C
   Subsystem 1 - Part No SW: 8X0 919 603     HW: 8X0 919 603
   Component: DU6 Basic  H42 0084
   Serial number: 9462IW0B0139570
End-------------------------(Elapsed Time: 02:41)--------------------------
plugged vcds in got these fault codes,ive deleted them, started the car got no codes come back.....apart from the air-con one, do i need replace something or is it simply just a re-gas?
                    Reset counter: 162
                    Mileage: 218708 km
                    Date: 2019.05.12
                    Time: 07:55:43
Seem to me the next step would be to put some pressure gauges on the AC system to find out what's actually going on.
vw754
C?ID=52227
OK thanks, I'll take it for a regas, see what happens.
