2015 Passat TDI with 3x Coolant Pump Faults
Rembrant
Canada
C?ID=230053
Good day gentlemen,
A good friend of mine has some codes popping up on his 2015 Passat TDI regarding the coolant pump. Autoscan below.
Has anybody run into this one before?
Can anybody confirm where this pump is located?
By the looks of the 3 codes it almost looks like it has come unplugged/disconnected electrically...or that the plug is corroded, etc.
Just looking for any additional info and advice before getting under the car;). Thanks for the help.
Wednesday,03,July,2019,09:15:16:24871
VCDS Version: 19.6.0.2 (x64)
VIN: 1VWCV7A34FC016626   License Plate:
Mileage: 98360km-61118mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 77
VIN: 1VWCV7A34FC016626   Mileage: 98360km-61118miles
Address 01: Engine (J623-CVCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 016 D    HW: 04L 907 309 K
   Component: R4 2.0l TDI   X20 9466
   Revision: 8AX20---
   Coding: 011D0012832410089000
   ASAM Dataset: EV_ECM20TDI01104L997016D 004002
   ROD: EV_ECM20TDI01104L997016D.rod
   VCID: 346733879F5A48EF45-8060
28389 - Coolant Pump 3
          P26F7 00 [175] - Supply Voltage Malfunction
                    Mileage: 98324 km
                    Date: 2019.07.02
                    Time: 16:18:11
                    Engine speed: 1672.50 /min
                    Normed load value: 61.2 %
                    Vehicle speed: 24 km/h
                    Coolant temperature: 45 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 14.320 V
                    Heater support pump 1 bank 1 second.circuit: activat.: 94.79 %
                    Extern.temp.sens.1 bank 1: raw value: 20.0 °C
                    Shut-off timer: last engine shut-off time: 7444 s
28386 - Coolant Pump 3
          P26F5 00 [032] - Short to GND
                    Mileage: 98362 km
                    Date: 2019.07.03
                    Time: 06:33:49
                    Engine speed: 833.50 /min
                    Normed load value: 49.4 %
                    Coolant temperature: 24 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 14.120 V
                    Heater support pump 1 bank 1 second.circuit: activat.: 53.77 %
                    Extern.temp.sens.1 bank 1: raw value: 16.0 °C
                    Shut-off timer: last engine shut-off time: 32827 s
28388 - Coolant Pump 3
          P26F4 00 [032] - Electrical Malfunction / Open Circuit
                    Fault Frequency: 8
                    Mileage: 98344 km
                    Date: 2019.07.02
                    Time: 16:50:26
                    Engine speed: 907.00 /min
                    Normed load value: 38.0 %
                    Coolant temperature: 25 °C
                    Voltage terminal 30: 14.340 V
                    Heater support pump 1 bank 1 second.circuit: activat.: 10.00 %
Readiness: 1 1 0 1 0
   Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 4518
   Revision: 05652104    Serial number: 00001406011268
   Shop #: WSC 09003 957 00200
   VCID: 2541DEC3EC802167C2-8070
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -  - Intermittent
                    Reset counter: 39
                    Mileage: 98362 km
                    Date: 2019.07.03
                    Time: 06:33:46
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: C54BC0F549230000A31103E6921F0042A1100012
   VCID: 7EF3D1AFE99652BFE3-802A
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0340172772
   Coding: 130C0C
   VCID: 377D048B8E2CA3F760-8062
   Part No SW: 561 907 044 AP    HW: 561 907 044 AP
   Component: Climatronic   H03 0707
   Revision: 00001K01
   Coding: 0010019012
   VCID: 65C19EC36400E16702-8030
   Part No SW: 5K0 937 087 AE    HW: 5K0 937 087 AE
   Component: BCM PQ35 H+   122 0174
   Revision: BL122001
   Coding: EF200E3BEC2B2AD408880201360081C802F1A08645A005B064806000BC70
   VCID: 78FFC7B7CBB26C8FA9-802C
   Component: RLS 300514 05  54  0403
   Coding: 06300A
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD0199Y$
   Coding: 00004D34
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 72EBF59FA5CE06DF97-8026
   Serial number: 6940000Y14000176WY09
   Coding: 303047
   Serial number: 3572MSME27652D45ZZZ.
   Serial number: 3582MSME3F336A45ZZZ0
   Serial number: 3516KSME0943262FZZZU
   Serial number: 3526KSME295D262FZZZ1
   Serial number: 3556LSME0777182FZZZ+
   Serial number: 3566LSME595E182FZZZB
   Part No SW: 1K5 953 521 BR    HW: 5K0 953 569 AH
   Revision: FF010042    Serial number: 20140505300166
   Coding: 0002140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7EF3D1AFE19652BFE3-802A
   Coding: E20000
   Part No SW: 561 920 870 E    HW: 561 920 870 E
   Component: KOMBI         H04 0813
   Coding: 331E01
   VCID: 1B35F83B12C4E79764-804E
   Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1653
   Revision:   H55       Serial number: 24061403000105
   Coding: 461000
   VCID: 000FAF579362244F91-8054
   Component: IMMO          H04 0813
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADBEDFF8D1ECE1F2F-803E
   Revision: 00000000    Serial number: 14000144473003
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 306F3F976B4274CF21-8064
Address 2E: Media Player 3
   Part No SW: 561 959 760 B    HW: 561 959 760 B
   Component: MEM-FS        H04 0182
   Revision: AA000000    Serial number: 00000105455408
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 224BC5DF3DAED65FA7-8076
   Part No SW: 3C0 035 684 Q    HW: 3C0 035 684 N
   Component: RNS-MID       H26 5382
   Revision: AB001001    Serial number: VWZ6Z7P5182018
   Coding: 24090042010000A4000B
   VCID: 31693A9368487DC72E-8064
   Subsystem 1 - Part No: 7L6 919 859
   Component: NAR V12  8534
                    Reset counter: 142
                    Mileage: 90792 km
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Revision: 12110009    Serial number: 0008685814
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1C37FB2717CAE0AF6D-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14102630140721214854
   Coding: 800000
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 215    3501
   Revision: 00H22000
   VCID: 397902B37038B58796-806C
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H08 6815
   Revision: --------    Serial number: EAA098A0155191
   ROD: EV_AudioVerst10KanalSTT3.rod
   VCID: 2643D9CF59862A7FCB-8072
   Component: EZE_2         H55 1653
   Coding: 01030108
   VCID: 6FEDFCEBBEFC2B3778-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011407703793
   Coding: 181100
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Revision: 14110009    Serial number: 0008646629
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D31F6230CD0E9A79A-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14102631140729190133
   Coding: 800000
                    Reset counter: 142
                    Mileage: 90792 km
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0592
   Revision: 1B001001    Serial number: 00007666010661
   Coding: 0A10030080010110
   Shop #: WSC 00237 002 1048576
   ROD: EV_UHVUMI.rod
   VCID: 2E5321EF7176623F33-807A
End-------------------------(Elapsed Time: 03:39)--------------------------
Wednesday,03,July,2019,09:21:56:24871
          52 56 62 72 77
   Revision: 8AX20---
                    Mileage: 98324 km
                    Date: 2019.07.02
                    Time: 16:18:11
                    Mileage: 98362 km
                    Date: 2019.07.03
                    Time: 06:33:49
                    Fault Frequency: 8
                    Mileage: 98344 km
                    Date: 2019.07.02
                    Time: 16:50:26
                    Reset counter: 39
                    Mileage: 98362 km
                    Date: 2019.07.03
                    Time: 06:33:46
   Revision: 00H46001
   Coding: 130C0C
   Revision: 00001K01
   Coding: 0010019012
   Revision: BL122001
   Coding: 06300A
   Coding: 00004D34
   Coding: 303047
   Coding: 0002140000
   Coding: E20000
   Coding: 331E01
   Coding: 461000
   Coding: 000007
                    Reset counter: 142
                    Mileage: 98368 km
   Coding: 0405FD
   Slave Driver:
   Coding: 800000
   Revision: 00H22000
   Coding: 01030108
   Coding: 181100
   Coding: 0405FC
   Slave Passenger:
   Coding: 800000
                    Reset counter: 142
                    Mileage: 98368 km
   ROD: EV_UHVUMI.rod
End-------------------------(Elapsed Time: 03:26)--------------------------
NostraJackAss
Coolant pump 3 is most likely in possible failure and should be determined for location by RTFB and observed WD.
This way you will know where it is and what tracks to test or fuse to address. Watch out!, pumps can and do catch on fire without blowing a fuse!
