2003 A6 Quattro Central locking unit flooded.
   #21
tultalk
Looking into flooding. 4" water in battery compartment and power brake area. Since I can't redo this wonderful German design, where are all the drains located that prevent filling up these areas? I will tak eout battery tomorrow. Are there drains in other locations?
   #22
tultalk
Found info.
   #23
tultalk
Cabin air filter seems to be vulnerable to water entry. No cover. Water running down windshield is supposed to be deflected/routed where?
   #24
tultalk
Seriously need some help. As above. installed replacement central lock controller I cleared all codes and ran again. Cleaned up. I pulled battery while cleaning out drains (source of flooding).
Hooked battery back up and thought everything would reboot. Matched keys etc.
Sun roof will not respond. Half way down window will not respond. Radio comes on no sound, remote trunk latch does not work
Interior lights (reading etc) do not work. Runs, remotes work, turn flasher/emergency flasher work
I have some switches unplugged: Memory seats, folding mirror switch a few other things. Figure that would not effect anything.
I need some guidance as to what steps to follow to get all these items on line again.
Thanks.
   #25
HMC
C?ID=28246
Hi tultalk,
A full Autoscan is the place to start.
Regards HMC
   #26
siLc
Tallinn, Estonia
C?ID=330192
Yes, post a new autoscan as we don't know what new comfort module you had installed and if any DTC-s are stored according to the functions not working.
   #27
tultalk
This is scan after I replaced Central Locking module (4B0 962 258M) with one from eBay and cleared all the old DTC codes from it. 2 scans to make sure.
Wednesday,10,July,2019,20:22:34:29746
VCDS Version: 19.6.1.0 (x64)
VIN: WAUML64B43N104356   License Plate:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
          75 76 77
   Part No: 4D0 907 560 CL
   Component: 4.2L V8/5V      G   0001
   Coding: 07752
   Shop #: WSC 02325
   VCID: 72EBF47B3EDB13DF9F-5124
   WAUML64B43N104356     AUZ7Z0C2386232
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 01L-927-156.lbl
   Part No: 4B0 927 156 FG
   Component: AG5 01L 4.2l5V  USA 1014
   Coding: 01002
   Shop #: WSC 02325
   VCID: 71E9FB773BDD28C766-5140
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 H
   Component: ABS/ESP allrad      3428
   Coding: 06397
   Shop #: WSC 02325
   VCID: 2643D82BC2933F7FC3-5124
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AM
   Component: A6-Klimavollautomat 0105
   Coding: 00010
   Shop #: WSC 02325
   VCID: 65C19F27FF15F4670A-257A
            27-00 - Implausible Signal
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4B0 959 655 Q
   Component: Airbag 8.4EP        2001
   Coding: 0000607
   Shop #: WSC 02325 785 00200
   VCID: 3E73104B6A0387BFAB-5140
Address 16: Steering wheel        Labels: 4B0-907-487.lbl
   Part No: 4B0 907 487 F
   Component: Lenkradelektronik   D01
   Coding: 01005
   Shop #: WSC 02325
   VCID: 2F6D3D0FED697E3730-5140
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 981 P
   Component: KOMBI+WEGFAHRS. VDO D12
   Coding: 03283
   Shop #: WSC 02805
   VCID: 3365317F01415AD754-5140
Address 35: Centr. Locks        Labels: 4B0-962-258.clb
   Part No: 4B0 962 258 M
   Component: Central Lock/Alarm  D38
   Coding: 15885
   Shop #: WSC 02116
   VCID: 3365317F01415AD754-4F22
   Part No: 4B0 959 760 B
   Component: Sitzmemory R1 F     0102
   Coding: 00001
   VCID: 2C572A03DC7F052F15-4AE8
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00050
   Shop #: WSC 02325
   VCID: 0407A2A3146F2D6FBD-4B1A
00776 - Level Control System Sensor; Left Front (G78)
            31-00 - Open or Short to Ground
   Part No: 4B0 035 195 S
   Component: symphony II NP2    0011
   Coding: 00225
   Shop #: WSC 02101
   VCID: 306F3E73F05761CF29-4E96
Address 75: Telematics        Labels: 8E0-035-616.lbl
   Part No SW: 8E0 035 616 A    HW: 8E0 035 616 A
   Component: Telematik USA1
   Coding: 0002303
   VCID: 2345C13FE1A1CA57A4-5140
End-------------------------(Elapsed Time: 05:47)--------------------------
          75 76 77
   Coding: 07752
   Shop #: WSC 02325
   VCID: 72EBF47B3EDB13DF9F-5140
Readiness: 0010 1101
   Coding: 01002
   Shop #: WSC 02325
   Coding: 06397
   Shop #: WSC 02325
   Coding: 0000607
   Coding: 01005
   Shop #: WSC 02325
   VCID: 2F6D3D0FED697E3730-5124
   Coding: 03283
   Shop #: WSC 02805
Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
   Coding: 15885
   Shop #: WSC 02116
   Coding: 00001
   VCID: 2C572A03DC7F052F15-4B00
   Coding: 00050
   Shop #: WSC 02325
   VCID: 0407A2A3146F2D6FBD-4B00
   Coding: 00225
   Shop #: WSC 02101
   Coding: 0002303
End-------------------------(Elapsed Time: 05:22)--------------------------
tultalk
Temp repair using wire nut on cleaned previously corroded splice V 37.
No DTC except this
Coding: 00225
Shop #: WSC 02101
00856 - Radio Antenna
36-00 - Open Circuit
But radio works fine both am and fm
Strange, my previous scan showed no fault here:
Coding: 00225
Shop #: WSC 02101
