Newbie with lots of issues!
Ignorantman
Ireland
C?ID=374443
I have a 2013 VW CC 2.0 tdi. Since owner ship i have noticed that the headlights only work if you hold the stalk back manually, the windscreen washers dont work (motor is fine), the rear fog light doest work (bulb fine), reverse lights dont work (bulb fine), front fogs dont work (bulbs fine), parking sensors dont come on when reverse selected (button needs to be manually pressed)
I have a suspicion that someone has had a mess around with some coding and now i have all the above issues.
Any help on the matter would be greatly appreciated.
here is a scan of the vehicle
 Wednesday,03,July,2019,22:20:02:60782
VCDS Version: 19.6.1.0 (x64)
VIN: WVWZZZ3CZDE556052   License Plate:
Mileage: 122750km-76273mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53
          55 56 61 62 72
VIN: WVWZZZ3CZDE556052   Mileage: 122750km-76273miles
Address 01: Engine (J623-CFGC)       Labels: None
   Part No SW: 03L 906 018 TL    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   X28 9978
   Revision: 41X28---    Serial number: 00000000000000
   Coding: 00190012042501080000
   Shop #: WSC 00604 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018TL 003002
   ROD: EV_ECM20TDI01103L906018RK.rod
   VCID: 071C101FBEC05A77D8-8052
Readiness: 0 0 0 0 X
   Part No SW: 3AA 614 109 AQ    HW: 3AA 614 109 AQ
   Component: J104   C2 450M VDE2 0030
   Revision: --H07---    Serial number: 00000006661433
   Coding: 0004025
   Shop #: WSC 05311 000 00000
   VCID: 7CF67FF33F0609AFC5-8028
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Frequency: 26
                    Reset counter: 226
                    Mileage: 122407 km
                    Date: 2013.11.19
                    Time: 18:19:51
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 185
                    Hex Value: 0x0000
03841 - RPM Sensor Rear Left: Incorrect Signal
                    Fault Frequency: 18
                    Reset counter: 9
                    Mileage: 122407 km
                    Date: 2013.11.19
                    Time: 18:19:52
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 156
                    Hex Value: 0x0000
                    Fault Frequency: 20
                    Reset counter: 9
                    Mileage: 122407 km
                    Date: 2013.11.19
                    Time: 18:20:02
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 191
                    Hex Value: 0x0000
   Part No SW: 3AA 907 044 AK    HW: 3AA 907 044 AK
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0018004849
   Shop #: WSC 00015 115 12345
   VCID: 79F866E7F8343C87DE-802C
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
   Component: BCM PQ47 H++  421 0465
   Revision: BD421001
   Coding: 00080000000000000098008C95002B242375008862228720E48C4E2000C1
   Shop #: WSC 05311 123 12345
   VCID: 4188CE07D864A447D6-8014
   Subsystem 1 - Part No SW: 3C8 955 119 G    HW: 3C8 955 119 G  Labels: 1KX-955-119.CLB
   Component: WWS464 121012  010 0604
   Serial number: 121012
   Coding: 00B795
   Component: RLFS  024 0042
   Serial number: Y13M02D05H00M50S17S4
   Coding: 0228DD
02723 - Control Circuit for Power Supply Relay (Terminal 50)
                    Fault Status: 01101100
                    Reset counter: 220
                    Mileage: 122407 km
                    Date: 2013.11.19
                    Time: 17:39:06
                        Term 15 Off
                    Voltage: 12.35 V
03395 - Control Module for High Beam Assistant
                    Reset counter: 216
                    Mileage: 122407 km
                    Date: 2013.11.19
                    Time: 17:26:31
                    Voltage: 12.20 V
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0018
   Revision: --------    Serial number: 28261301503773
   Coding: 108004
   ASAM Dataset: EV_EPHVA18VW47X0000 001006
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 3F8CC8FFA690D2B7A0-806A
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 21011304280002
   Coding: 010180
   Shop #: WSC 05314 000 00000
   VCID: 275C709F56007A77F8-8072
   Component: J234__70J VW10 HI   2118
   Revision: 25018000    Serial number: 003L7P21G3JB
   Coding: 0012362
   Subsystem 1 - Serial number: 6332MTS664260073
   Subsystem 2 - Serial number: 6342MTS614450073
   Subsystem 3 - Serial number: 6351HTS6JGR7LBKJ
   Subsystem 4 - Serial number: 6361HTS607PQIBKR
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
            008 - Implausible Signal - Intermittent - MIL ON
                    Fault Status: 10101000
                    Mileage: 122446 km
                    Date: 2013.11.20
                    Time: 14:11:20
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
   Revision: FF010041    Serial number: 20130122301758
   Coding: 0182270002
   Shop #: WSC 00015 115 00000
   VCID: 72EA51CBA5424FDF9F-8026
   Component: E221__MFL-TK6  H07 0022
   Coding: E20000
   Part No SW: 3C8 920 971 A    HW: 3C8 920 971 A
   Component: KOMBI         H05 0705
   Coding: 440D00
   Shop #: WSC 05314 115 12345
   VCID: 2B548CAF42E85E171C-807E
   Part No SW: 7N0 907 530 AJ    HW: 7N0 907 530 AJ
   Component: J533  Gateway H51 1634
   Revision:   H51       Serial number: 091212F2003281
   Coding: 469007
   VCID: 78FE63E3CB3E258FA1-802C
   Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
   Component:    IMMO         043 0404
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 387EA3E34BBEE58F61-806C
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664219504
   Coding: 020100
   VCID: 2A5A89AB4512471FE7-807E
   Part No SW: 3C8 035 279 B    HW: 3C8 035 279 B
   Component: RNS315-EU   H59 0319
   Serial number: VWZAZ2N0097367
   Coding: 0400040104000F0000019002
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 2A5A89AB4D12471FE7-807E
   Component: EUR_W_V4  0050
1048595 - Rear Left Bass Speaker
          B1065 13 [009] - Open Circuit
                    Reset counter: 226
                    Mileage: 122533 km
                    Date: 2019.07.01
                    Time: 17:36:12
1048596 - Rear Right Bass Speaker
          B1067 13 [009] - Open Circuit
                    Reset counter: 218
                    Mileage: 122407 km
                    Date: 2019.06.29
                    Time: 17:26:42
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0556
   Revision: 12110009    Serial number: 0006426221
   Coding: 0012BF
   Shop #: WSC 05311 115 12345
   VCID: 6DD042B7BC7C902742-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000003309688
   Coding: 010090
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 207    3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 377CA0DF46A0EAF768-8062
                    Fault Status: 00101101
                    Reset counter: 9
                    Mileage: 122407 km
                    Date: 2013.11.19
                    Time: 18:19:52
                    Voltage: 12.00 V
                        DD
                    Temperature: 31.0°C
   Component:    KSG PQ47 ELV 043 0638
   Coding: 01910A0001860E763604941570085FCE105C04
   Component: Neigungssensor  004 0611
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AJ
   Component: EZE_2         H51 1634
   Coding: 00000008
   VCID: 6FEC58BFBE70623770-803A
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0004
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0556
   Revision: 14110009    Serial number: 0006405215
   Coding: 0013BF
   VCID: 6ED245BBB17A6B3F7B-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000003314751
   Coding: 010090
66821 - Position Sensor for Mirror Adjustment
          B11FA 29 [009] - Signal Implausible
                    Reset counter: 216
                    Mileage: 122407 km
                    Date: 2019.06.29
                    Time: 17:26:57
   Revision:   H19       Serial number: 00000000739745
   Coding: 0022167
   VCID: 3662ADDB41AA13FF73-8062
                    Fault Frequency: 109
                    Reset counter: 8
                    Mileage: 121657 km
                    Date: 2013.11.08
                    Time: 08:30:56
                    Voltage: 14.70 V
                    Count: 104
                    Speed: 54.0 km/h
                    Hex Value: 0x1268
                    Hex Value: 0x8004
                    Hex Value: 0x0101
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357 B    HW: 6R0 907 357 A
   Component: LWR-ECU       005 0030
   Coding: 079A020001000000
   ASAM Dataset: EV_HeadlRegulVWLWRCC 002004
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3978A6E7B8B4FC879E-806C
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 226
                    Mileage: 122752 km
                    Date: 2019.07.03
                    Time: 21:57:00
5256213 - Front Left Ride-Height Sensor
          C1034 15 [137] - Open or Short to Plus
                    Reset counter: 226
                    Mileage: 122752 km
                    Date: 2019.07.03
                    Time: 21:57:00
5256725 - Rear Left Ride-Height Sensor
          C1036 15 [137] - Open or Short to Plus
                    Reset counter: 226
                    Mileage: 122752 km
                    Date: 2019.07.03
                    Time: 21:57:00
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AJ
   Component: Batt.regelung H51 1634
   Coding: 030F1859
   VCID: 71E85EC7A84474C766-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000001490746284
End-------------------------(Elapsed Time: 03:20)--------------------------
Ignorantman
Ireland
C?ID=374443
Can any one help please?
Mike@Gendan
Swansea, UK
C?ID=57030
You've picked a bad time to ask as most of America is closed for the Independence Day holiday - expect more replies next week :)
Given this fault code:
Combined with the fact that there doesn't seem to be an HBA module in this car (or if there is, I'm missing it), you might try un-ticking the bit for "High Beam Assist (HBA/FLA) installed" in your BCM's coding. Hint: It's in Byte 11 and it's fully documented in the Long Coding Helper.
grant@gendan
The parking sensors not activating and the reverse lights not working are probably linked.
Has the transmission electrical switch failed for the reversing light?
Can you see reverse being activated in Measuring Blocks?
Ignorantman
Ireland
C?ID=374443
55 - headlight range, but there is no HIGH BEAM ASSIST. When i go in to the long code helper there isnt a Byte 11 either.
Ignorantman
Ireland
C?ID=374443
I think you might be right. Can see it in the measuring blocks but it is doing nothing when reverse selected. I will investigate the wiring plug and switch itself.
Ignorantman
Ireland
C?ID=374443
The front and rear fog lights are activated when switched on in the measuring blocks but no physical light coming from the bulbs
I wrote: "in your BCM's coding", and your BCM certainly does have a Byte 11. ;)
Ignorantman
Ireland
C?ID=374443
I went back in and changed the setting, still only headlights when manually hold back the stalk.
Ignorantman
Ireland
C?ID=374443
I removed the reverse light switch and it is working fine. Had a new one, so put it in anyway. Had another look in the measuring blocks (09 - cent. Elect) row 2 group 055 shows ON when i engage reverse but no light at bulbs and parking sensors until manual button press.
Its like someone has erased the codes for the items i am having problems with. The headlight washers work fine but the windowscreen washer dont work at all? No fog lights front or rear.
I did notice when looking in the measuring blocks (09 - cent.Elect) in the second row, group 047. When i turn on to side lights it shows right rear fog light @ 66,7%, thought this was unusual as fogs not even on.
Is there any way of telling codes have been tampered with or deleted by accident?
Ignorantman
Ireland
C?ID=374443
HELLLPPPP PLEASSSEEEE
Hi, me again, after some advice. Is there anyway my BCM could be giving trouble? Would it be worth changing it? Will the second hand unit need coded in?
Ps. I noticed yesterday that my headlights stay on now when the switch is put to off position!
siLc
Tallinn, Estonia
C?ID=330192
All those things not working are driven by the BCM. A replacement one would be needed indeed coded to match your car's installed features.
Weren't there Output Test in BCM one could use to turn on various lights one by one?
Ignorantman
Ireland
C?ID=374443
Thanks for your reply. If i get the get a BCM is much involved in coding it?
grant@gendan
Here is an example coding value from another 2013 VW CC (09) Central Electric module:
0008000000000000008800809400294023570088402205206484C7200040
Make sure you save your original code (shown in the scan on the first page of this thread if needed) but try dropping in this code and see if anything changes.
If not, revert back to your original code.
If some lights start to work correctly, then it could be all due to messed-up coding on the car and not a faulty module.
Unless anyone can suggest a reason not to try this.....
Ignorantman
Ireland
C?ID=374443
Finally got to the bottom of these faults! (thanks grant@gendan)
So it looks like my suspicions from the start were right. Someone messed up the coding which caused all said problems. I used the code grant@gendan posted and just like magic, i had everything working again. One thing to note, i had no wipers when i put new code in (i had wipers prior to entering new code). So i changed the last two digits in grant@gendan's code (40) to (C1) from the original code and the wipers worked again. Thanks everyone
