2011 CAEB fault 4113 (p0341)
hans j
Utah
C?ID=60436
I'm trying to find more information on this fault. I know I have seen a chart that explains the [104] before, but I'm finding little information on the 4113 fault.
Car comes in last week with the fault and a concern for having a hesitation in stop and go traffic when he goes to accelerate. I drive it and am able to repeat the concern. I scope the cam sensor and it's dropping out completely while it's running. Replace the cam sensor and the hesitation is gone, but the fault code remains.
I scope it again and find a split second drop out in the signal and then it picks back up. There is no timing change when this happens. I caught the drop out during an acceleration period at about 1370 rpm, and it's pretty random, although it happens often.
You can see the glitch in this photo:
https://ibb.co/Fn12t4Q
I looked up the fault in my autoscans and turns out I do have a friend who had the exact same fault with his 2011 Q5. The dealer did a bunch of work when it was in for an oil consumption recall, including replacing the intake cam. I'm trying hard not to condemn the camshaft because to me it looks like an electrical fault.
So I'm wondering if anyone has any more ideas on things I can test before recommending a camshaft!
Thursday,27,June,2019,15:25:34:05
VCDS Version: 18.9.1.0 (x64)
Dealer/Shop Name: hans j
VIN: WAUFFAFL7BN007465   License Plate:
Mileage: 186040km-115599mi   Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 5F 62
          6C 72
VIN: WAUFFAFL7BN007465   Mileage: 186040km-115599miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AD    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H17 0002
   Revision: E1H17---
   Coding: 0104010A290F0160
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_ECM20TFS0118K2907115AD 001005
   ROD: EV_ECM20TFS0118K2907115AD.rod
   VCID: F1AA955A20BFFCC2A2-80A4
4113 - Camshaft Position Sensor (G40)
          P0341 00 [104] - Implausible Signal
                    Fault Frequency: 61
                    Mileage: 185780 km
                    Date: 2010.12.23
                    Time: 12:17:29
                    Engine speed: 1256.00 /min
                    Normed load value: 11.4 %
                    Vehicle speed: 82 km/h
                    Coolant temperature: 84 °C
                    Intake air temperature: 27 °C
                    Ambient air pressure: 800 mbar
                    Voltage terminal 30: 14.182 V
   Part No SW: 8K0 927 158 K    HW: 0BK 927 156 N
   Component: 0BK 20TFSIUSA H08 0004
   Revision: --H08---
   Coding: 001102
   ASAM Dataset: EV_TCMAL551211 001012
   ROD: EV_TCMAL551211_001.rod
   VCID: BE307E66216153BA6F-80EA
   Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
   Component: ESP8 quattro  H04 0050
   Coding: 1D0518
   Shop #: WSC 02391 823 56573
   VCID: 8248CA961D19F75A4B-80D6
   Part No SW: 8K0 907 064 CF    HW: 8K0 907 064 CF
   Component: BCM2 2.0      H04 0430
   Coding: 090100
   Shop #: WSC 02399 823 56573
   VCID: F6A0A64641D1DBFA77-80A2
   Subsystem 1 - Part No SW: 8K0 959 754 B    HW: 8K0 959 754 B
   Serial number: 0815000041109008
   Serial number: 0210000102478004
   Revision: C1000000    Serial number: 01110620101773
   Coding: 64102000
   VCID: 804CC09E1315E54A5D-80D4
   Component: BCM1 1.0      H29 0392
   Revision: 10029001    Serial number: 00000000568161
   Coding: 26001091063CAF010000000300003D0D0F1C520802010161000000
   VCID: BC34746E3F7D41AA41-80E8
   Component: WWS 150610  H06 0070
   Serial number: SWF10060150429
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10948698
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001406100445
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 80
                    Mileage: 176119 km
                    Date: 2010.08.10
                    Time: 14:50:00
   Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0070
   Revision: 11001001    Serial number: 51231017005444
   Coding: 200103
   VCID: C7DE1B8276BB1272DC-8092
   Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GLD0G6UN%
   Coding: 303837354230303030304A55304C384B3053
   Shop #: WSC 02135 785 00200
   VCID: C5C2118A44B700622E-8090
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1000000ACW
   Serial number: 6334MSME5511234A4
   Serial number: 6344MSME55112779B
   Serial number: 6352QSME5F533F04R
   Serial number: 6362QSME6457083EP
   Serial number: 63732SME634A3A7CB
   Serial number: 63832SME4D64413A2
   Revision: --------    Serial number: 90315JFH0005W
   Coding: 000016
   VCID: BD32796A246748A276-80E8
   Component: E221 - MFL  H02 0010
No Faults Found
   Part No SW: 8K0 920 981 C    HW: 8K0 920 981 C
   Component: KOMBIINSTR.   H21 0258
   Revision: 00000000    Serial number: EJB40U76A
   Coding: 8B1709000200D705020000
   VCID: B3265F5212238ED290-80E6
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0117
   Revision: EC000056    Serial number: 5600E1060703C4
   Coding: 00C303
   VCID: 8346CF920203FE5240-80D6
   Component: J367-BDM  H07 0170
   Serial number: 100204DE150610
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 251
                    Mileage: 185360 km
                    Date: 2010.12.13
                    Time: 18:36:00
            000 -  -  - Intermittent
                    Reset counter: 249
                    Mileage: 185360 km
                    Date: 2010.12.13
                    Time: 22:36:00
                    Bin. Bits:    00000
                    Voltage: 12.40 V
                    Count: 17
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1401
   Coding: 011C03204000410001
   VCID: D3E63FD2B2E3AED2B0-8086
   Revision: 00002001    Serial number: 0131953813
   Coding: 0106023A00FA040480B0013200000000
   VCID: F6AA52E5D8C6DBD7341-FFFE
   Component: LIN BACKUP HO  1501
No Faults Found
Thursday,27,June,2019,16:57:41:05734
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4505.4
                Address 01: Engine  (8K2 907 115 AD)
16:57:33
  IDE00584   Distance driven since erasing DTC memory 671 km
  IDE00585   Dist. driven with exh. Malfunction Indicator Lamp activated 187 km
Fredrick Awuor
Kenya
C?ID=309834
          6C 72
   Revision: E1H17---
                    Fault Frequency: 61
                    Mileage: 185780 km
                    Date: 2010.12.23
                    Time: 12:17:29
   Revision: --H08---
   Coding: 001102
   Coding: 1D0518
   Coding: 090100
   Coding: 64102000
   Coding: 00FD11
   Coding: 025028
                    Reset counter: 80
                    Mileage: 176119 km
                    Date: 2010.08.10
                    Time: 14:50:00
   Coding: 200103
   Coding: 000016
No Faults Found
   Coding: 00C303
                    Reset counter: 251
                    Mileage: 185360 km
                    Date: 2010.12.13
                    Time: 18:36:00
                    Reset counter: 249
                    Mileage: 185360 km
                    Date: 2010.12.13
                    Time: 22:36:00
                    Bin. Bits:    00000
                    Voltage: 12.40 V
                    Count: 17
No Faults Found
16:57:33
I once had to battle a similar code on an A4 8K CDHB motor after the previous garage had replaced G40 twice,engine oil and ...etc,we went for a test drive,logged misfire counters....found out misfires would come,but below MIL triggering threshold,and G40 error would appear during the episode.....we replaced all coil packs,the error went away for good
hans j
Utah
C?ID=60436
I never got to check the oil pressure due to time issues. The oil change had 5000 miles on it according to carfax. It was at minimum and a little dark, but didn't smell like fuel. We ended up changing the oil since it was due and used BG EPR and MOA along with it. The fault stayed away after several test drives! And theories on why it could cause that drop out in the signal? Maybe camshaft thrust? I measured the cam signal and it was pretty much right on compared to the next one in the engine revolution, so no timing change happened.
I've also heard of a metallurgy issue in the reluctor that causes a drop out. That will be my next check if they decide to do anything on this salvage title car.
