2018 Audi TT RS - Address 09 Cent Elect - 526359 Control Module Incorrectly Coded
Rapture
Milwaukee, USA
C?ID=356886
Hi,
I am trying to determine what this Fault code is related to. It is a NA car which I have installed the ROW OLED's into. I'm not sure but I don't believe that required a coding change, they are working correctly. I have also made some coding changes to remove the brake lights flashing with the turn signals, low beams off on coming home, and a few other LED lighting changes.
Can anyone help me determine what this fault code may be related to?
526359 - Control Module Incorrectly Coded
U1014 00 [009] - -
[Steuergerät falsch codiert->Keine Anzeige]
Reset counter: 130
Mileage: 3324 km
Date: 2019.07.01
Time: 15:50:20
Thanks very much,
Tuesday,02,July,2019,15:31:46:62813
VIN: WUACSAFV5J1903145   License Plate:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 3C 42 44 47 52 55 5F
          65 6C
VIN: WUACSAFV5J1903145   Mileage: 3324km-2065miles
Address 01: Engine (------DAZA)       Labels: None
   Part No SW: 8S0 907 404 G    HW: 07K 907 309 E
   Component: R5 2.5l TFSI  H22 0004
   Revision: 53H22000
   Coding: 1A250032242600053620
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM25TFS0118S0907404G 001004
   ROD: EV_ECM25TFS0118S0907404G.rod
   VCID: 3A2D306D1CD0CC07C4D-806E
Readiness: 1110 0101
   Part No SW: 0DL 300 012 H    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2111
   Revision: 00H06V07
   VCID: 2E050C3DD09810A7685-807A
   Part No SW: 8S0 907 379 J    HW: 8S0 907 379 J
   Component: ESC           H42 0050
   Revision: 00000000    Serial number: 60828000000264
   Coding: 99AAF08D6A9915AC009208680396900635990F56A80010C00960AC
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 061007
   ROD: EV_Brake1UDSContiMK100IPB_061.rod
   VCID: 48C95AA5523CAE97429-801C
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0477034741
   Coding: 030C0C1720
   VCID: 3E253C7D00F8E027F85-806A
   Part No SW: 8S0 820 043     HW: 8S0 820 043
   Component: AC Automat    H05 0040
   Revision: 20010000    Serial number: 18140000009000
   Coding: 400050100001041100
   ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
   ROD: EV_AirCondiVAPrehAU33x.rod
   VCID: 6C81C6352604A2B7061-8038
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: DF02942900PAG0MUFU03
   Operating and display unit 1 for air conditioning:
   Subsystem 2 - Part No SW: 8S0 820 373 A    HW: 8S0 820 373 A
   Component: E774 BuA_1  H07 0020
   Serial number: 00000000000000048934
   Operating and display unit 2 for air conditioning:
   Subsystem 3 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H07 0020
   Operating and display unit 3 for air conditioning:
   Subsystem 4 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H07 0020
   Operating and display unit 4 for air conditioning:
   Subsystem 5 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H07 0020
   Operating and display unit 5 for air conditioning:
   Subsystem 6 - Part No SW: 8S0 820 373 B    HW: 8S0 820 373 B
   Component: E778 BuA_5  H07 0020
   Part No SW: 5Q0 937 085 BP    HW: 5Q0 937 085 BG
   Component: BCM MQBAB HNA H36 0253
   Serial number: 01001810200214
   ROD: EV_BCMBOSCH_018.rod
   VCID: 08499AA512BC6E97829-805C
   Subsystem 1 - Part No SW: 8S1 955 119 B    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
   Component: 43x LL 180312  038 0371
   Serial number: 00000001803080302574
   Coding: 1BC7F7
   Serial number: 63301075
   Coding: 00005D
   Serial number: 25 01 2018  00001918
   Subsystem 4 - Part No SW: 4N0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600350Z005502
   Coding: 150000
   Garage Door Opener Operating Unit:
   Subsystem 5 - Part No SW: 8S0 959 719     HW: 8S0 959 719
   Component: GTO BF  H05 0010
   Serial number: 20180302122806 00635
   Subsystem 6 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000099639407
   Valve Block 1 In Driver Side Front Seat:
   Subsystem 7 - Part No SW: 8S0 907 182     HW: 8S0 907 182
   Component: N475 VB1 FSv  H07 0021
   Serial number: 7008173235E180200182
   Coding: 810500
   Valve Block 1 In Passenger Side Front Seat:
   Subsystem 8 - Part No SW: 8S0 907 182     HW: 8S0 907 182
   Component: N477 VB1 BFSv  H07 0021
   Serial number: 7008173235E180200201
   Coding: 810500
          U1014 00 [009] - -
                    Reset counter: 130
                    Mileage: 3324 km
                    Date: 2019.07.01
                    Time: 15:50:20
   Revision: --------    Serial number: 39361808801303
   Coding: 0070150011
   VCID: 43D34D896B1A8DCF97B-8016
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 H    HW: 8V0 907 376 F
   Component: DAEMPFUNGS-SG H11 0083
   Serial number:       070418041
   ASAM Dataset: EV_AudiMagneRide 003007
   ROD: EV_AudiMagneRide_003.rod
   VCID: 46D5549D5828B8E7B05-8012
   Part No SW: 5Q0 959 655 R    HW: 5Q0 959 655 R
   Serial number: 003M9R00947
   Coding: BFCCF0C000800000A000001FC24800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4FFB71B9B75279AF033-801A
   Occupant Detection:
   Subsystem 1 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000000000094TJJ/
   Coding: 303333
   Subsystem 2 - Part No SW: -----------    HW: 480 001 604 18
   Serial number: 35700000000B34418D2I
   Subsystem 3 - Part No SW: -----------    HW: 480 001 604 18
   Serial number: 35800000000434418D2C
   Subsystem 4 - Part No SW: -----------    HW: 480 012 203 18
   Component: SideSensor_Dr  005 0108
   Serial number: 351001A0D34181023E3T
   Subsystem 5 - Part No SW: -----------    HW: 480 402 003 18
   Serial number: 3550002B1252D864D14%
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 003 18
   Serial number: 3560002B5252D860824$
   Part No SW: 8S0 907 129 AS    HW: 8S0 907 129 AS
   Component: Lenks. Modul  H07 0150
   Revision: --------    Serial number: 91335RD302603
   Coding: 2058
   ASAM Dataset: EV_SMLSKLOMQB 050001
   ROD: EV_SMLSKLOMQB_050.rod
   VCID: 0B43A5A903CA058FAFB-805E
   Part No SW: 8S0 920 890 C    HW: 8S0 920 890 C
   Component: FBenUSA       H42 0325
   Coding: 086F10C1388AD7060322ECC49800801000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001027
   ROD: EV_DashBoardBOSCHAU33X.rod
   Part No SW: 8S0 907 468 G    HW: 8S0 907 468 E
   Component: GW MQB TT3    022 0323
   Serial number: 05041810801350
   Coding: 0301000424025D004B008028B80B00000000000000000000000000000001
   ASAM Dataset: EV_GatewContiAU33X 013005
   ROD: EV_GatewContiAU33X_013.rod
   VCID: 44D14E956E148AF7AE1-8010
   Subsystem 2 - Part No SW: 8S0 951 523 K    HW: 8S0 951 523 K
   Component: J453 MFL  H01 0002
   Serial number: 20180326170824 00591
   Subsystem 3 - Part No SW: 8W0 915 181     HW: 8W0 915 181
   Serial number: 8783516904
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7762
   Serial number: HA1-00012.03.18
   Coding: 0701
   VCID: 4DC76BB1BD5E4BBF71F-8018
   Part No SW: 8S0 907 566     HW: 4H0 907 566 F
   Component: SWA Master    H08 0060
   Serial number: 0462809446
   Coding: 030311
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 7CA1F67556643237961-8028
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8S0 907 568     HW: 4H0 907 568 F
   Component: SWA Slave  H08 0060
   Serial number: 0475385763
   Coding: 030311
   Serial number: 300318ECT11946
   Coding: 001F53225C00040100000402
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 811E0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3B23356913EAF50FDFB-806E
   Part No SW: 8S0 035 466 A    HW: 8S0 035 466
   Component: MIB2_amp_P_TT H10 0440
   Revision: 00000001    Serial number: AUZ8ZAJ5C00ATF3
   Coding: 0133040000AA2A2AAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
   ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
   VCID: 34311E553EB43A771E1-8060
   Serial number: 310318ECU2950A
   Coding: 001F53225E00040100000402
   VCID: 42DD488D740084C79CD-8016
Address 55: Headlight Range (J745)       Labels:* None
   Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0115
   Coding: 0362001123200400
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
   VCID: 3635245D28C82867205-8062
   Coding: E01800
   Coding: E01800
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01800
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01800
   Part No SW: 8S0 035 025 K    HW: 8S0 035 025 B
   Component: MU-H-LNS-US   054 1173
   Serial number: A707D0JS003516
   Coding: 013364020000000011220002041A00102F0000E1007000047E
   VCID: 3537235135CE237F29F-8060
   Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8S0 919 614 M    HW: 8S0 919 614 M
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK102031800010144
   Compact Disc Database:
   Component: Gracenote2  --- 3012
          B11CF 53 [009] - Deactivated
                    Reset counter: 130
                    Mileage: 3324 km
                    Date: 2019.07.02
                    Time: 15:10:21
                    Voltage terminal 30: 12.6 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 8S0 907 273     HW: 4M0 907 273 B
   Component: RDKHUFAU736   H05 0002
   Serial number: 30000000006637
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: 77ABE9596F42116FFB3-8022
   Coding: 0233640102002001000040
   VCID: 392F2F6119D6C71FCD7-806C
End----------(Elapsed Time: 01:34, VBatt start/end: 12.3V/12.3V)-----------
Since this is a new-style BCM wil coding of all zeros, meaning everything that used to be in Coding is now in some of the several thousand Adaptation channels, I'm going to suggest you post an Adaptation Map of that module.
PS: Moved to Retrofits
Rapture
Milwaukee, USA
C?ID=356886
Okay, thanks I will try to do that in the next day or so.
I do not know if this has anything to do with the OLED's, I just provided that for additional information.
hadez16
C?ID=289891
What OLEDs??
Can you provide a CSV Adaptation Map of your BCM?
Rapture
Milwaukee, USA
C?ID=356886
What OLEDs??
Hi Hadez,
I installed the OEM OLED's that were an option, in our market though they were only available as part of an "package" which had other items I was not interested in so I waited until they became available and others confirmed they were "plug n play". I don't know if they have anything to do with the fault code but thought I would mention it.
I am going to go and try to obtain the adaptation map, I've not tried that yet.
Thanks,
Rapture
Milwaukee, USA
C?ID=356886
Well, here is the Adaptation map (I think). I posted this as I did the Scan, not sure if you would like it in a different format as it did not retail the Excel columns.
;SW:5Q0-937-085-BP   HW:5Q0-937-085-BG ---  Cent. Elect.
;Component:BCM MQBAB HNA H36 0253	 Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB	18001	EV_BCMBOSCH_018.rod
;Thursday	4	July	2019	10:53:49:62813
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: 08499AA512BC6E97829-805C
IDE00001-ENG99061-Production mode-Access control	not active 	3
IDE00001-ENG115730-Production mode-Exterior lighting	not active 	3
IDE00001-ENG112304-Production mode-Heckwischer	not active 	3
IDE00001-ENG98647-Production mode-Interior lighting	not active 	3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active 	3
IDE00001-ENG115731-Production mode-Virtuel_pedal	not active 	3
IDE00002-Transport mode	active 	1
IDE00820-Activating and deactivating all development messages	not active 	1
IDE01550-Service position	163.999837 °	2
IDE02152-Characteristics in production mode	2000 ms	4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate 	10
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active 	10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	active 	10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active 	10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	active 	10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	normal 	10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active 	10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active 	10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	not active 	10
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active 	10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	not active 	10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit	200 ms	10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit	200 ms	10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit	200 ms	10
IDE02332-Deactivate production mode	0	3
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active 	8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active 	8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	8 s	8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	16 s	8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer	not installed 	8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active 	8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active 	8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	3 s	8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	1 s	8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	5 s	8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	5 s	8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	not active 	8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer	Keine_Spannungsanforderung 	8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	not active 	8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck	0 ms	8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-0.3 °	16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s	16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	OFF 	16
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h	16
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C	16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C	16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	90 °	16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C	16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	30 °	16
IDE03638-ENG116676-static AFS light-Upper speed threshold	32.0 km/h	16
IDE03638-ENG116674-static AFS light-Vorschrift	OFF 	16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht	15 min	16
IDE03787-Activate left/right hand drive switch-over	No_Menue 	1
IDE04927-IDE01446-Window heater-Running time of heated front window	600 s	11
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.0 °C	11
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.0 °C	11
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer	0 s	11
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt	not installed 	11
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus	not installed 	11
IDE04927-ENG126845-Window heater-FSH Automatik	not active 	11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	600 s	11
IDE04927-ENG141955-Window heater-heizbare Heckscheibe	installed 	11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe	not installed 	11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	not active 	11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	active 	11
IDE04927-ENG141962-Window heater-Waschduesenheizung	installed 	11
IDE04927-ENG154810-Window heater-window heating front activation time pause	240 s	11
IDE04928-MAS01577-Anti-theft device-Parking heater	not installed 	8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active 	8
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated 	8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system	active 	8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick	not_active 	8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI	not_active 	8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	not active 	8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active 	8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder	Sounder_verbaut 	8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor	installed 	8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet	No 	8
IDE04928-ENG142249-Anti-theft device-OBD Alarm	activ 	8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm	not_active 	8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)	Yes 	8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung	No 	8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	1 Alarm 	8
IDE04928-ENG142008-Anti-theft device-tilt_sensor	No 	8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active 	8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung 	8
IDE05144-Read parameter address	00 00 00 	3
IDE05145-Light configuration	21 34 00 14 02 00 7F 03 00 00 00 00 00 00 00 00 21 3E 00 15 04 00 7F 05 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 06 00 9E 08 09 1C 1E 00 1C 04 4C 00 4C 14 00 64 07 00 9E 08 0A 1C 1E 00 1C 01 48 00 49 14 00 64 06 00 00 08 09 64 1E 00 64 01 4C 00 4B 14 00 64 07 00 00 08 0A 64 1E 00 64 05 36 00 1A 0B 00 7F 1E 00 80 00 00 00 00 00 00 05 40 00 1B 0C 00 7F 1E 00 80 00 00 00 00 00 00 05 36 00 5D 28 00 7F 1E 00 7F 00 00 00 00 00 00 05 40 00 5E 28 00 7F 1E 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 62 3F 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	224
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN	Heizmatten am BCM 	30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s	30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C	30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	20.00 °C	30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	18.00 °C	30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	20.00 °C	30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	18.00 °C	30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	32.00 °C	30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	30.00 °C	30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	32.00 °C	30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	30.00 °C	30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	45.00 °C	30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	43.00 °C	30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	45.00 °C	30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	43.00 °C	30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI	Sollspannungsanforderung 14.7 	30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO	Keine_Spannungsanforderung 	30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe	not installed 	30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75	15.7 V	30
IDE06425-Roller test bench mode: functional	not active 	1
IDE06507-MAS13125-Button in center console-Function of button 1	not coded/not installed 	8
IDE06507-MAS13129-Button in center console-Function of button 2	Offroad 	8
IDE06507-MAS13132-Button in center console-Function of button 3	NOT-DEFINED 	8
IDE06507-MAS13135-Button in center console-Function of button 4	not coded/not installed 	8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED	LED not installed 	8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich	active 	8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt	not active 	8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige	active 	8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik	active 	8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active 	8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start	not installed 	8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung	active 	8
IDE07356-Position during interval mode	41.494464 °	2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten nach der Nachlaufzeit 	6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min	6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein	not active 	6
IDE08577-Garage door opener: use of GPS data	not active 	1
IDE08578-Garage door opener: bi-directional communic.	active 	1
IDE08580-Garage door opener: increasing transm. power	not active 	1
IDE08583-Garage door opener: no. of channels	3 channels 	1
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A	not active 	2
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B	not active 	2
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C	not active 	2
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D	not active 	2
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E	not active 	2
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F	not active 	2
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G	not active 	2
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H	not active 	2
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I	not active 	2
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J	not active 	2
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K	not active 	2
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I	not active 	2
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II	not active 	2
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III	not active 	2
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV	not active 	2
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB	not active 	2
IDE08585-Garage door opener: activation via remote key	not active 	1
IDE08778-Garage door opener: surround. target area	30 m	1
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active 	9
IDE08786-ENG141956-Assistance light functions-Humidity sensor	installed 	9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal 	9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	active 	9
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion	not active 	9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor	LIN_REGEN_LICHT_SENSOR 	9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor	not installed 	9
IDE09377-IDE00761-Multicontour seat: driver's side-After-run time	600 s	5
IDE09377-IDE03006-Multicontour seat: driver's side-Running time of massage function	600 s	5
IDE09377-IDE03007-Multicontour seat: driver's side-Installation location	Driver side 	5
IDE09377-IDE03099-Multicontour seat: driver's side-Characteristics for manual seat adjustment	Open circuit 	5
IDE09377-IDE03100-Multicontour seat: driver's side-Characteristics for seat adjustment using memory	Open circuit 	5
IDE09378-IDE00761-Multicontour seat frt.pass. side-After-run time	600 s	5
IDE09378-IDE03006-Multicontour seat frt.pass. side-Running time of massage function	600 s	5
IDE09378-IDE03007-Multicontour seat frt.pass. side-Installation location	Frt. pass. side 	5
IDE09378-IDE03099-Multicontour seat frt.pass. side-Characteristics for manual seat adjustment	Open circuit 	5
IDE09378-IDE03100-Multicontour seat frt.pass. side-Characteristics for seat adjustment using memory	Open circuit 	5
IDE09546-Multicontour seat on driver's side: reset compressor counter	not active 	1
IDE09547-Multicontour seat on frt. pass. side: reset compressor counter	not active 	1
IDE09548-Multicontour seat on driver's side: reset adaptation	not active 	1
IDE09549-Multicontour seat on frt. pass. side: reset adaptation	not active 	1
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual	2	19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation	not active 	19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung	not active 	19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default	not active 	19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.00 s	19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	0	19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	0	19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	0	19
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	0%	19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	0	19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum	0%	19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	0%	19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer	0%	19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn	0%	19
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	not active 	19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	not active 	19
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen	not active 	19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten	not active 	19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light	Keine_Spannungsanforderung 	19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM	not active 	19
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht	not installed 	19
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active 	19
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel	not installed 	19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel	not installed 	19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G	not installed 	19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active 	19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default	0	5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI	not active 	5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed 	5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	installed 	5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	installed 	5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	active 	5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active 	5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	installed 	5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed 	5
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed 	5
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed 	5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed 	5
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI	not active 	5
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active 	5
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed 	5
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed 	5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%	17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25%	17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%	17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25%	17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58%	17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53%	17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58%	17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53%	17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85%	17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80%	17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85%	17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%	17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung	not installed 	17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar	not installed 	17
IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik	installed 	17
IDE10298-Alternating park position 1	29.999970 °	2
IDE10299-Alternating park position 2	33.494472 °	2
IDE10308-Garage door opener: support door name	not active 	1
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode	not active 	1
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1	not active 	1
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2	not active 	1
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3	not active 	1
IDE10350-Garage door opener: programming antenna	Internal antenna 	1
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	1	256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	1	256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	1	256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	1	256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	1	256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	1	256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	1	256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	1	256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0	256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0	256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0	256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0	256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0	256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0	256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0	256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0	256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1	256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1	256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0	256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0	256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	100%	256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	100%	256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	100%	256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	100%	256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	100%	256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	100%	256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	100%	256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	100%	256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	100%	256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	100%	256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100%	256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	100%	256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	100%	256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100%	256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	100%	256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100%	256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100%	256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	100%	256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	100%	256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100%	256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	100%	256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	100%	256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100%	256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	100%	256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100%	256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100%	256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	100%	256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	100%	256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100%	256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	100%	256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	100%	256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%	256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	100%	256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%	256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100%	256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	100%	256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	100%	256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100%	256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	100%	256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	100%	256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	100%	256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100%	256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	100%	256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	100%	256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126%	256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	126%	256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	126%	256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%	256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	126%	256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%	256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126%	256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126%	256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	126%	256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	100%	256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	100%	256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	100%	256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	100%	256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	100%	256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100%	256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	100%	256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	100%	256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100%	256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	100%	256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100%	256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100%	256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	100%	256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	100%	256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	100%	256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	100%	256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100%	256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	100%	256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	100%	256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	100%	256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100%	256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	100%	256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	100%	256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100%	256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	100%	256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	100%	256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%	256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	100%	256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%	256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100%	256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	100%	256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	100%	256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte	200 ms	256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0.0 s	256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0.0 s	256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0.0 s	256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0.0 s	256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0.0 s	256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0.0 s	256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0.0 s	256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0.0 s	256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	0.0 s	256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0.0 s	256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0.0 s	256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	0.0 s	256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0.0 s	256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0.0 s	256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0.0 s	256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0.0 s	256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0.0 s	256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0.0 s	256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0.0 s	256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0.0 s	256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0.0 s	256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0.0 s	256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0.0 s	256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0.0 s	256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0.0 s	256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0.0 s	256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0.0 s	256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0.0 s	256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0.0 s	256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0.0 s	256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0.0 s	256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0.0 s	256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0.0 s	256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0.0 s	256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0.0 s	256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0.0 s	256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0.0 s	256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0.0 s	256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0.0 s	256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0.0 s	256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0.0 s	256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0.0 s	256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0	256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1	0	30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10	0	30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2	0	30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3	0	30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4	0	30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5	0	30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6	0	30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7	0	30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8	0	30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9	0	30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1	0	30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10	0	30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2	0	30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3	0	30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4	0	30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5	0	30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6	0	30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7	0	30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8	0	30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9	0	30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1	0	30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10	0	30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2	0	30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3	0	30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4	0	30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5	0	30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6	0	30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7	0	30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8	0	30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9	0	30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung	not installed 	3
IDE11944-ENG141948-Keyless access and start authorization-Kessy	installed 	3
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen	not active 	3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen	active 	3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung	active 	3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung	active 	3
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin	0	30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin	0	30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin	0	30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin	0	30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin	0	30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin	0	30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin	0	30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin	0	30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin	0	30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin	0	30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin	0	30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin	0	30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin	0	30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin	0	30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin	0	30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin	0	30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin	0	30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin	0	30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin	0	30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin	0	30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin	0	30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin	0	30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin	0	30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin	0	30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin	0	30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin	0	30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin	0	30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin	0	30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin	0	30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin	0	30
IDE80001-ENG125667-Analysis 1-EE_pMax_LM_MSG_Px_Iy	110 hPa	15
IDE80001-ENG125666-Analysis 1-EE_pMax_LO_MSG_Px_Iy	110 hPa	15
IDE80001-ENG125668-Analysis 1-EE_pMax_LU_MSG_Px_Iy	110 hPa	15
IDE80001-ENG125673-Analysis 1-EE_tEnt_LM_MSG_Px_Iy	5000 ms	15
IDE80001-ENG125672-Analysis 1-EE_tEnt_LO_MSG_Px_Iy	5000 ms	15
IDE80001-ENG125674-Analysis 1-EE_tEnt_LU_MSG_Px_Iy	5000 ms	15
IDE80001-ENG125670-Analysis 1-EE_tHalte_LM_MSG_Px_Iy	0 ms	15
IDE80001-ENG125669-Analysis 1-EE_tHalte_LO_MSG_Px_Iy	0 ms	15
IDE80001-ENG125671-Analysis 1-EE_tHalte_LU_MSG_Px_Iy	0 ms	15
IDE80001-ENG125676-Analysis 1-EE_tWarte_LM_MSG_Px_Iy	0 ms	15
IDE80001-ENG125675-Analysis 1-EE_tWarte_LO_MSG_Px_Iy	0 ms	15
IDE80001-ENG125677-Analysis 1-EE_tWarte_LU_MSG_Px_Iy	0 ms	15
IDE80001-ENG125664-Analysis 1-EE_Upumpe_LM_MSG_Px_Iy	80 ms	15
IDE80001-ENG125663-Analysis 1-EE_Upumpe_LO_MSG_Px_Iy	80 ms	15
IDE80001-ENG125665-Analysis 1-EE_Upumpe_LU_MSG_Px_Iy	80 ms	15
IDE80002-ENG125667-Analysis 2-EE_pMax_LM_MSG_Px_Iy	160 hPa	15
IDE80002-ENG125666-Analysis 2-EE_pMax_LO_MSG_Px_Iy	160 hPa	15
IDE80002-ENG125668-Analysis 2-EE_pMax_LU_MSG_Px_Iy	160 hPa	15
IDE80002-ENG125673-Analysis 2-EE_tEnt_LM_MSG_Px_Iy	6000 ms	15
IDE80002-ENG125672-Analysis 2-EE_tEnt_LO_MSG_Px_Iy	6000 ms	15
IDE80002-ENG125674-Analysis 2-EE_tEnt_LU_MSG_Px_Iy	6000 ms	15
IDE80002-ENG125670-Analysis 2-EE_tHalte_LM_MSG_Px_Iy	0 ms	15
IDE80002-ENG125669-Analysis 2-EE_tHalte_LO_MSG_Px_Iy	0 ms	15
IDE80002-ENG125671-Analysis 2-EE_tHalte_LU_MSG_Px_Iy	0 ms	15
IDE80002-ENG125676-Analysis 2-EE_tWarte_LM_MSG_Px_Iy	0 ms	15
IDE80002-ENG125675-Analysis 2-EE_tWarte_LO_MSG_Px_Iy	0 ms	15
IDE80002-ENG125677-Analysis 2-EE_tWarte_LU_MSG_Px_Iy	0 ms	15
IDE80002-ENG125664-Analysis 2-EE_Upumpe_LM_MSG_Px_Iy	80 ms	15
IDE80002-ENG125663-Analysis 2-EE_Upumpe_LO_MSG_Px_Iy	80 ms	15
IDE80002-ENG125665-Analysis 2-EE_Upumpe_LU_MSG_Px_Iy	80 ms	15
IDE80003-ENG125667-Analysis 3-EE_pMax_LM_MSG_Px_Iy	210 hPa	15
IDE80003-ENG125666-Analysis 3-EE_pMax_LO_MSG_Px_Iy	210 hPa	15
IDE80003-ENG125668-Analysis 3-EE_pMax_LU_MSG_Px_Iy	210 hPa	15
IDE80003-ENG125673-Analysis 3-EE_tEnt_LM_MSG_Px_Iy	7000 ms	15
IDE80003-ENG125672-Analysis 3-EE_tEnt_LO_MSG_Px_Iy	7000 ms	15
IDE80003-ENG125674-Analysis 3-EE_tEnt_LU_MSG_Px_Iy	7000 ms	15
IDE80003-ENG125670-Analysis 3-EE_tHalte_LM_MSG_Px_Iy	0 ms	15
IDE80003-ENG125669-Analysis 3-EE_tHalte_LO_MSG_Px_Iy	0 ms	15
IDE80003-ENG125671-Analysis 3-EE_tHalte_LU_MSG_Px_Iy	0 ms	15
IDE80003-ENG125676-Analysis 3-EE_tWarte_LM_MSG_Px_Iy	0 ms	15
IDE80003-ENG125675-Analysis 3-EE_tWarte_LO_MSG_Px_Iy	0 ms	15
IDE80003-ENG125677-Analysis 3-EE_tWarte_LU_MSG_Px_Iy	0 ms	15
IDE80003-ENG125664-Analysis 3-EE_Upumpe_LM_MSG_Px_Iy	80 ms	15
IDE80003-ENG125663-Analysis 3-EE_Upumpe_LO_MSG_Px_Iy	80 ms	15
IDE80003-ENG125665-Analysis 3-EE_Upumpe_LU_MSG_Px_Iy	80 ms	15
IDE80004-ENG125667-Analysis 4-EE_pMax_LM_MSG_Px_Iy	140 hPa	15
IDE80004-ENG125666-Analysis 4-EE_pMax_LO_MSG_Px_Iy	140 hPa	15
IDE80004-ENG125668-Analysis 4-EE_pMax_LU_MSG_Px_Iy	140 hPa	15
IDE80004-ENG125673-Analysis 4-EE_tEnt_LM_MSG_Px_Iy	5000 ms	15
IDE80004-ENG125672-Analysis 4-EE_tEnt_LO_MSG_Px_Iy	5000 ms	15
IDE80004-ENG125674-Analysis 4-EE_tEnt_LU_MSG_Px_Iy	5000 ms	15
IDE80004-ENG125670-Analysis 4-EE_tHalte_LM_MSG_Px_Iy	2000 ms	15
IDE80004-ENG125669-Analysis 4-EE_tHalte_LO_MSG_Px_Iy	2000 ms	15
IDE80004-ENG125671-Analysis 4-EE_tHalte_LU_MSG_Px_Iy	2000 ms	15
IDE80004-ENG125676-Analysis 4-EE_tWarte_LM_MSG_Px_Iy	6000 ms	15
IDE80004-ENG125675-Analysis 4-EE_tWarte_LO_MSG_Px_Iy	6000 ms	15
IDE80004-ENG125677-Analysis 4-EE_tWarte_LU_MSG_Px_Iy	6000 ms	15
IDE80004-ENG125664-Analysis 4-EE_Upumpe_LM_MSG_Px_Iy	80 ms	15
IDE80004-ENG125663-Analysis 4-EE_Upumpe_LO_MSG_Px_Iy	80 ms	15
IDE80004-ENG125665-Analysis 4-EE_Upumpe_LU_MSG_Px_Iy	80 ms	15
IDE80005-ENG125667-Analysis 5-EE_pMax_LM_MSG_Px_Iy	190 hPa	15
IDE80005-ENG125666-Analysis 5-EE_pMax_LO_MSG_Px_Iy	190 hPa	15
IDE80005-ENG125668-Analysis 5-EE_pMax_LU_MSG_Px_Iy	190 hPa	15
IDE80005-ENG125673-Analysis 5-EE_tEnt_LM_MSG_Px_Iy	6000 ms	15
IDE80005-ENG125672-Analysis 5-EE_tEnt_LO_MSG_Px_Iy	6000 ms	15
IDE80005-ENG125674-Analysis 5-EE_tEnt_LU_MSG_Px_Iy	6000 ms	15
IDE80005-ENG125670-Analysis 5-EE_tHalte_LM_MSG_Px_Iy	2000 ms	15
IDE80005-ENG125669-Analysis 5-EE_tHalte_LO_MSG_Px_Iy	2000 ms	15
IDE80005-ENG125671-Analysis 5-EE_tHalte_LU_MSG_Px_Iy	2000 ms	15
IDE80005-ENG125676-Analysis 5-EE_tWarte_LM_MSG_Px_Iy	7000 ms	15
IDE80005-ENG125675-Analysis 5-EE_tWarte_LO_MSG_Px_Iy	7000 ms	15
IDE80005-ENG125677-Analysis 5-EE_tWarte_LU_MSG_Px_Iy	7000 ms	15
IDE80005-ENG125664-Analysis 5-EE_Upumpe_LM_MSG_Px_Iy	80 ms	15
IDE80005-ENG125663-Analysis 5-EE_Upumpe_LO_MSG_Px_Iy	80 ms	15
IDE80005-ENG125665-Analysis 5-EE_Upumpe_LU_MSG_Px_Iy	80 ms	15
IDE80006-ENG125667-Analysis 6-EE_pMax_LM_MSG_Px_Iy	240 hPa	15
IDE80006-ENG125666-Analysis 6-EE_pMax_LO_MSG_Px_Iy	240 hPa	15
IDE80006-ENG125668-Analysis 6-EE_pMax_LU_MSG_Px_Iy	240 hPa	15
IDE80006-ENG125673-Analysis 6-EE_tEnt_LM_MSG_Px_Iy	7000 ms	15
IDE80006-ENG125672-Analysis 6-EE_tEnt_LO_MSG_Px_Iy	7000 ms	15
IDE80006-ENG125674-Analysis 6-EE_tEnt_LU_MSG_Px_Iy	7000 ms	15
IDE80006-ENG125670-Analysis 6-EE_tHalte_LM_MSG_Px_Iy	2000 ms	15
IDE80006-ENG125669-Analysis 6-EE_tHalte_LO_MSG_Px_Iy	2000 ms	15
IDE80006-ENG125671-Analysis 6-EE_tHalte_LU_MSG_Px_Iy	2000 ms	15
IDE80006-ENG125676-Analysis 6-EE_tWarte_LM_MSG_Px_Iy	8000 ms	15
IDE80006-ENG125675-Analysis 6-EE_tWarte_LO_MSG_Px_Iy	8000 ms	15
IDE80006-ENG125677-Analysis 6-EE_tWarte_LU_MSG_Px_Iy	8000 ms	15
IDE80006-ENG125664-Analysis 6-EE_Upumpe_LM_MSG_Px_Iy	80 ms	15
IDE80006-ENG125663-Analysis 6-EE_Upumpe_LO_MSG_Px_Iy	80 ms	15
IDE80006-ENG125665-Analysis 6-EE_Upumpe_LU_MSG_Px_Iy	80 ms	15
IDE80007-ENG125682-Analysis 7-s_GrobleckerkennungDauer	30 s	5
IDE80007-ENG125680-Analysis 7-s_LatenzzeitHaengenderTaster	60 s	5
IDE80007-ENG125681-Analysis 7-s_Leckageerkennung	3	5
IDE80007-ENG125678-Analysis 7-s_UeberspannungsSschwelle	16 V	5
IDE80007-ENG125679-Analysis 7-s_UnterspannungsSchwelle	9 V	5
IDE80008-ENG125684-Analysis 8-s_DruckschwelleNachlauf	50 hPa	30
IDE80008-ENG126855-Analysis 8-s_Maximaldruck_LRD_m	0 hPa	30
IDE80008-ENG126854-Analysis 8-s_Maximaldruck_LRD_o	280 hPa	30
IDE80008-ENG126856-Analysis 8-s_Maximaldruck_LRD_u	260 hPa	30
IDE80008-ENG126857-Analysis 8-s_Maximaldruck_Sitzlehnenwangen	350 hPa	30
IDE80008-ENG126863-Analysis 8-s_Maximaldruck_Ueberlastschutz	500 hPa	30
IDE80008-ENG126862-Analysis 8-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck	5 hPa	30
IDE80008-ENG126859-Analysis 8-s_Minimaldruck_LRD_m	0 hPa	30
IDE80008-ENG126858-Analysis 8-s_Minimaldruck_LRD_o	15 hPa	30
IDE80008-ENG126860-Analysis 8-s_Minimaldruck_LRD_u	15 hPa	30
IDE80008-ENG126864-Analysis 8-s_Minimaldruck_Massage	22 hPa	30
IDE80008-ENG126861-Analysis 8-s_MinimaldruckSitzlehnenwangen	15 hPa	30
IDE80008-ENG125683-Analysis 8-s_ZieldruckDerSitzlehnenwangenBeiPreCrash	330 hPa	30
IDE80009-ENG125687-Analysis 9-s_AnzahlDruckmessungenIntervallerhoehung	2 counts	5
IDE80009-ENG125689-Analysis 9-s_AussendruckschwelleNachregelung	100 hPa	5
IDE80009-ENG125685-Analysis 9-s_BasismessintervallNachregelung	2 min	5
IDE80009-ENG125688-Analysis 9-s_BlasendruckschwelleNachregelung	10 hPa	5
IDE80009-ENG125686-Analysis 9-s_ErhoehungsintervallNachregelung	5 min	5
IDE80011-ENG125667-Analysis 11-EE_pMax_LM_MSG_Px_Iy	240 hPa	15
IDE80011-ENG125666-Analysis 11-EE_pMax_LO_MSG_Px_Iy	240 hPa	15
IDE80011-ENG125668-Analysis 11-EE_pMax_LU_MSG_Px_Iy	240 hPa	15
IDE80011-ENG125673-Analysis 11-EE_tEnt_LM_MSG_Px_Iy	7000 ms	15
IDE80011-ENG125672-Analysis 11-EE_tEnt_LO_MSG_Px_Iy	7000 ms	15
IDE80011-ENG125674-Analysis 11-EE_tEnt_LU_MSG_Px_Iy	7000 ms	15
IDE80011-ENG125670-Analysis 11-EE_tHalte_LM_MSG_Px_Iy	2000 ms	15
IDE80011-ENG125669-Analysis 11-EE_tHalte_LO_MSG_Px_Iy	2000 ms	15
IDE80011-ENG125671-Analysis 11-EE_tHalte_LU_MSG_Px_Iy	2000 ms	15
IDE80011-ENG125676-Analysis 11-EE_tWarte_LM_MSG_Px_Iy	8000 ms	15
IDE80011-ENG125675-Analysis 11-EE_tWarte_LO_MSG_Px_Iy	8000 ms	15
IDE80011-ENG125677-Analysis 11-EE_tWarte_LU_MSG_Px_Iy	8000 ms	15
IDE80011-ENG125664-Analysis 11-EE_Upumpe_LM_MSG_Px_Iy	80 ms	15
IDE80011-ENG125663-Analysis 11-EE_Upumpe_LO_MSG_Px_Iy	80 ms	15
IDE80011-ENG125665-Analysis 11-EE_Upumpe_LU_MSG_Px_Iy	80 ms	15
IDE80012-ENG125693-Analysis 12-s_DauerFuerGrobleckerkennung	30 s	5
IDE80012-ENG125680-Analysis 12-s_LatenzzeitHaengenderTaster	60 s	5
IDE80012-ENG125681-Analysis 12-s_Leckageerkennung	3	5
IDE80012-ENG125678-Analysis 12-s_UeberspannungsSschwelle	16 V	5
IDE80012-ENG125679-Analysis 12-s_UnterspannungsSchwelle	9 V	5
IDE80013-ENG126871-Analysis 13-s_Druckschwelle_Nachlauf	50 hPa	30
IDE80013-ENG126855-Analysis 13-s_Maximaldruck_LRD_m	0 hPa	30
IDE80013-ENG126854-Analysis 13-s_Maximaldruck_LRD_o	280 hPa	30
IDE80013-ENG126856-Analysis 13-s_Maximaldruck_LRD_u	260 hPa	30
IDE80013-ENG126857-Analysis 13-s_Maximaldruck_Sitzlehnenwangen	350 hPa	30
IDE80013-ENG126863-Analysis 13-s_Maximaldruck_Ueberlastschutz	500 hPa	30
IDE80013-ENG126870-Analysis 13-s_Maximaler_Differenzdruck_LRD_VorZurueck	5 hPa	30
IDE80013-ENG126859-Analysis 13-s_Minimaldruck_LRD_m	0 hPa	30
IDE80013-ENG126858-Analysis 13-s_Minimaldruck_LRD_o	15 hPa	30
IDE80013-ENG126860-Analysis 13-s_Minimaldruck_LRD_u	15 hPa	30
IDE80013-ENG126864-Analysis 13-s_Minimaldruck_Massage	22 hPa	30
IDE80013-ENG126869-Analysis 13-s_Minimaldruck_Sitzlehnenwangen	15 hPa	30
IDE80013-ENG125683-Analysis 13-s_ZieldruckDerSitzlehnenwangenBeiPreCrash	330 hPa	30
IDE80014-ENG125687-Analysis 14-s_AnzahlDruckmessungenIntervallerhoehung	2 counts	5
IDE80014-ENG125689-Analysis 14-s_AussendruckschwelleNachregelung	100 hPa	5
IDE80014-ENG125685-Analysis 14-s_BasismessintervallNachregelung	2 min	5
IDE80014-ENG125688-Analysis 14-s_BlasendruckschwelleNachregelung	10 hPa	5
IDE80014-ENG125686-Analysis 14-s_ErhoehungsintervallNachregelung	5 min	5
IDE80015-ENG126865-Analysis 15-s_Kompressorleistung_Manuelle_Befuellung_LRD	100%	6
IDE80015-ENG126867-Analysis 15-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen	100%	6
IDE80015-ENG126866-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_LRD	100%	6
IDE80015-ENG126868-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen	100%	6
IDE80015-ENG125690-Analysis 15-s_VerzoegerungszeitKompressoranlauf	120 ms	6
IDE80016-Analysis 16	10 s	1
IDE80017-ENG133471-Analysis 17-Offset_PB1_LM	0 hPa	50
IDE80017-ENG133470-Analysis 17-Offset_PB1_LO	0 hPa	50
IDE80017-ENG133472-Analysis 17-Offset_PB1_LU	0 hPa	50
IDE80017-ENG133473-Analysis 17-Offset_PB1_SH	0 hPa	50
IDE80017-ENG133475-Analysis 17-Offset_PB2_LM	0 hPa	50
IDE80017-ENG133474-Analysis 17-Offset_PB2_LO	0 hPa	50
IDE80017-ENG133476-Analysis 17-Offset_PB2_LU	0 hPa	50
IDE80017-ENG133477-Analysis 17-Offset_PB2_SH	0 hPa	50
IDE80017-ENG133483-Analysis 17-Offset_PV1_LM	0 ms	50
IDE80017-ENG133482-Analysis 17-Offset_PV1_LO	0 ms	50
IDE80017-ENG133484-Analysis 17-Offset_PV1_LU	0 ms	50
IDE80017-ENG133485-Analysis 17-Offset_PV1_SH	0 ms	50
IDE80017-ENG133486-Analysis 17-Offset_PV2_LO	0 ms	50
IDE80017-ENG133488-Analysis 17-Offset_PV2_LU	0 ms	50
IDE80017-ENG133489-Analysis 17-Offset_PV2_SH	0 ms	50
IDE80017-ENG133480-Analysis 17-OffsetPP1	0%	50
IDE80017-ENG133481-Analysis 17-OffsetPP2	0%	50
IDE80017-ENG133487-Analysis 17-OffsetPV2_LMy	0 ms	50
IDE80017-ENG133478-Analysis 17-OffsetT1	0 °C	50
IDE80017-ENG133479-Analysis 17-OffsetT2	0 °C	50
IDE80017-ENG133490-Analysis 17-p_function_feedback_timeout	200 ms	50
IDE80017-ENG133491-Analysis 17-p_longpush_time	500 ms	50
IDE80017-ENG133497-Analysis 17-p_stoesselSchaltschwelle_eins	11%	50
IDE80017-ENG133498-Analysis 17-p_stoesselSchaltschwelle_zwei	22%	50
IDE80017-ENG133494-Analysis 17-p_tasterSchaltschwelle_drei	42%	50
IDE80017-ENG133492-Analysis 17-p_tasterSchaltschwelle_eins	10%	50
IDE80017-ENG133496-Analysis 17-p_tasterSchaltschwelle_fuenf	62%	50
IDE80017-ENG133495-Analysis 17-p_tasterSchaltschwelle_vier	46%	50
IDE80017-ENG133493-Analysis 17-p_tasterSchaltschwelle_zwei	32%	50
IDE80017-ENG133458-Analysis 17-s_Beruhigungszeit_Befuellen	250 ms	50
IDE80017-ENG133460-Analysis 17-s_Beruhigungszeit_Druckmessung	250 ms	50
IDE80017-ENG133459-Analysis 17-s_Beruhigungszeit_Entlueften	250 ms	50
IDE80017-ENG133469-Analysis 17-s_Faktor_Druck_Entlueftung_Seitenhalt	100	50
IDE80017-ENG133464-Analysis 17-s_IntervallUmgebungsbedingungen	10 min	50
IDE80017-ENG133465-Analysis 17-s_MaxIntervall	30 min	50
IDE80017-ENG133461-Analysis 17-s_Messdauer_Initialisierung	5 ms	50
IDE80017-ENG133462-Analysis 17-s_Messdauer_Kurzzeitmessung	30 min	50
IDE80017-ENG133463-Analysis 17-s_Messdauer_Langzeitmessung	30 min	50
IDE80017-ENG133468-Analysis 17-s_Sitzvariante	variant_2 	50
IDE80017-ENG133467-Analysis 17-s_Timeout_Befuell_Linearbereich	10 s	50
IDE80017-ENG133466-Analysis 17-s_Timeout_Befuell_Startbereich	10 s	50
IDE80017-ENG133457-Analysis 17-s_Uebernahmedruck_P_u	75%	50
IDE80017-ENG133456-Analysis 17-s_Uebernahmedruck_PUe_o	20%	50
IDE80018-ENG133471-Analysis 18-Offset_PB1_LM	0 hPa	50
IDE80018-ENG133472-Analysis 18-Offset_PB1_LU	0 hPa	50
IDE80018-ENG133473-Analysis 18-Offset_PB1_SH	0 hPa	50
IDE80018-ENG133475-Analysis 18-Offset_PB2_LM	0 hPa	50
IDE80018-ENG133474-Analysis 18-Offset_PB2_LO	0 hPa	50
IDE80018-ENG133476-Analysis 18-Offset_PB2_LU	0 hPa	50
IDE80018-ENG133477-Analysis 18-Offset_PB2_SH	0 hPa	50
IDE80018-ENG133483-Analysis 18-Offset_PV1_LM	0 ms	50
IDE80018-ENG133482-Analysis 18-Offset_PV1_LO	0 ms	50
IDE80018-ENG133484-Analysis 18-Offset_PV1_LU	0 ms	50
IDE80018-ENG133485-Analysis 18-Offset_PV1_SH	0 ms	50
IDE80018-ENG133486-Analysis 18-Offset_PV2_LO	0 ms	50
IDE80018-ENG133488-Analysis 18-Offset_PV2_LU	0 ms	50
IDE80018-ENG133489-Analysis 18-Offset_PV2_SH	0 ms	50
IDE80018-ENG133534-Analysis 18-OffsetPB1_LO	0 hPa	50
IDE80018-ENG133480-Analysis 18-OffsetPP1	0%	50
IDE80018-ENG133481-Analysis 18-OffsetPP2	0%	50
IDE80018-ENG133487-Analysis 18-OffsetPV2_LMy	0 ms	50
IDE80018-ENG133478-Analysis 18-OffsetT1	0 °C	50
IDE80018-ENG133479-Analysis 18-OffsetT2	0 °C	50
IDE80018-ENG133490-Analysis 18-p_function_feedback_timeout	200 ms	50
IDE80018-ENG133491-Analysis 18-p_longpush_time	500 ms	50
IDE80018-ENG133497-Analysis 18-p_stoesselSchaltschwelle_eins	11%	50
IDE80018-ENG133498-Analysis 18-p_stoesselSchaltschwelle_zwei	22%	50
IDE80018-ENG133494-Analysis 18-p_tasterSchaltschwelle_drei	42%	50
IDE80018-ENG133492-Analysis 18-p_tasterSchaltschwelle_eins	10%	50
IDE80018-ENG133496-Analysis 18-p_tasterSchaltschwelle_fuenf	62%	50
IDE80018-ENG133495-Analysis 18-p_tasterSchaltschwelle_vier	46%	50
IDE80018-ENG133493-Analysis 18-p_tasterSchaltschwelle_zwei	32%	50
IDE80018-ENG133458-Analysis 18-s_Beruhigungszeit_Befuellen	250 ms	50
IDE80018-ENG133460-Analysis 18-s_Beruhigungszeit_Druckmessung	250 ms	50
IDE80018-ENG133459-Analysis 18-s_Beruhigungszeit_Entlueften	250 ms	50
IDE80018-ENG133469-Analysis 18-s_Faktor_Druck_Entlueftung_Seitenhalt	100	50
IDE80018-ENG133464-Analysis 18-s_IntervallUmgebungsbedingungen	10 min	50
IDE80018-ENG133465-Analysis 18-s_MaxIntervall	30 min	50
IDE80018-ENG133461-Analysis 18-s_Messdauer_Initialisierung	5 ms	50
IDE80018-ENG133462-Analysis 18-s_Messdauer_Kurzzeitmessung	30 min	50
IDE80018-ENG133463-Analysis 18-s_Messdauer_Langzeitmessung	30 min	50
IDE80018-ENG133468-Analysis 18-s_Sitzvariante	variant_2 	50
IDE80018-ENG133467-Analysis 18-s_Timeout_Befuell_Linearbereich	10 s	50
IDE80018-ENG133466-Analysis 18-s_Timeout_Befuell_Startbereich	10 s	50
IDE80018-ENG133532-Analysis 18-s_Uebernahmedruck_PUe_u	20%	50
IDE80018-ENG133533-Analysis 18-s_UebernahmedruckP_u	75%	50
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung	active 	5
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation	Energy management active 	5
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug	not installed 	5
MAS01490-ENG141950-Energy management-Hybrid vehicle	No 	5
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement	not active 	5
MAS01490-ENG141978-Energy management-Recuperation	not active 	5
MAS01490-ENG142037-Energy management-Zweitbatterie	not installed 	5
MAS05055-lower turn position	42.494463 °	2
MAS05056-upper turn position	171.494335 °	2
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze	1200 lx	24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	2200 lx	24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle	1000 lx	24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO	600 lx	24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten	1200 lx	24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten	2200 lx	24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	00 50 	24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell	4000 lx	24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway	not active 	24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain	not active 	24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity	frueh 	24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF	not active 	24
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe	not active 	24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung	4500 mV	24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke	6000 lx	24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung	2000 mV	24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke	0 lx	24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung	2	24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status	not active 	9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC	00 00 00 	9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC	First_dtc 	9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active 	4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active 	4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler	feststehender Spoiler 	4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11	0	60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12	0	60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13	0	60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14	0	60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15	0	60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16	0	60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17	0	60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18	0	60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19	0	60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20	0	60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21	0	60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22	0	60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23	0	60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24	0	60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25	0	60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26	0	60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27	0	60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28	0	60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29	0	60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30	0	60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11	0	60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12	0	60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13	0	60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14	0	60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15	0	60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16	0	60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17	0	60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18	0	60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19	0	60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20	0	60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21	0	60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22	0	60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23	0	60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24	0	60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25	0	60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26	0	60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27	0	60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28	0	60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29	0	60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30	0	60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11	0	60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12	0	60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13	0	60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14	0	60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15	0	60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16	0	60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17	0	60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18	0	60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19	0	60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20	0	60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21	0	60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22	0	60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23	0	60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24	0	60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25	0	60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26	0	60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27	0	60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28	0	60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29	0	60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30	0	60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin	0	60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin	0	60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin	0	60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin	0	60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin	0	60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin	0	60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin	0	60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin	0	60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin	0	60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin	0	60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin	0	60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin	0	60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin	0	60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin	0	60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin	0	60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin	0	60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin	0	60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin	0	60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin	0	60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin	0	60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin	0	60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin	0	60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin	0	60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin	0	60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin	0	60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin	0	60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin	0	60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin	0	60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin	0	60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin	0	60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin	0	60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin	0	60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin	0	60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin	0	60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin	0	60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin	0	60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin	0	60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin	0	60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin	0	60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin	0	60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin	0	60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin	0	60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin	0	60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin	0	60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin	0	60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin	0	60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin	0	60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin	0	60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin	0	60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin	0	60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin	0	60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin	0	60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin	0	60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin	0	60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin	0	60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin	0	60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin	0	60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin	0	60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin	0	60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin	0	60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	0	30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	0	30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	0	30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	0	30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	0	30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	0	30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	0	30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	0	30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	0	30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	0	30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	0	30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	0	30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	0	30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	0	30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	0	30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	NOT-DEFINED 	30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	NOT-DEFINED 	30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	NOT-DEFINED 	30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	NOT-DEFINED 	30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	NOT-DEFINED 	30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	NOT-DEFINED 	30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	NOT-DEFINED 	30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	NOT-DEFINED 	30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	NOT-DEFINED 	30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	NOT-DEFINED 	30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	NOT-DEFINED 	30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	NOT-DEFINED 	30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	NOT-DEFINED 	30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	NOT-DEFINED 	30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	NOT-DEFINED 	30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed 	30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed 	30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed 	30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed 	30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed 	30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed 	30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed 	30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed 	30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed 	30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed 	30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed 	30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed 	30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed 	30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed 	30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed 	30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0	60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0	60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0	60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0	60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0	60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0	60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0	60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0	60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0	60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0	60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0	60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0	60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0	60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0	60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0	60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0	60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0	60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0	60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0	60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0	60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0	60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0	60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0	60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0	60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0	60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0	60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0	60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0	60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0	60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0	60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0	60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0	60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0	60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0	60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0	60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0	60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0	60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0	60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0	60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0	60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed 	60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed 	60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed 	60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed 	60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed 	60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed 	60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed 	60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed 	60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed 	60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed 	60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed 	60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed 	60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed 	60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed 	60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed 	60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed 	60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed 	60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed 	60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed 	60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed 	60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente	Sollspannungsanforderung 13.5 	23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0	1	23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1	1	23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10	1	23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11	1	23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12	1	23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13	1	23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14	1	23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15	1	23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2	1	23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3	1	23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4	1	23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5	1	23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6	1	23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7	1	23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8	1	23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9	1	23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken	active 	10
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken	not active 	10
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger	separte 	10
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing	not active 	10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken	active 	10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung	active 	10
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10	not active 	10
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay	50 ms	10
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken	not active 	10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen	Warnblinke_zulaessig 	10
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken	active 	10
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen	3	10
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken	not active 	10
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2	not active 	10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing	active 	10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS	PreCrash_passiv 	10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links	active 	10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts	active 	10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken	active 	10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing	active 	10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	active 	10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken	active 	10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz	not active 	10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS	active 	10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN	active 	10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf	active 	10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu	active 	10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp	H7 	9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze	350 km/h	9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze	350 km/h	9
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag	Daytime running lights 	9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL	4 km/h	9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich	not active 	9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	active 	9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument	not active 	9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut	not installed 	9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht	not active 	9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	active 	9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	not active 	9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO	not active 	9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active 	9
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte	not active 	9
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit	active 	9
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active 	9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren	limitieren 	9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht	No 	5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit	60 km/h	5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA	not active 	5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion	active 	5
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe	not installed 	5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights	installed 	18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung	abschaltbar über Energiemanagement 	18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung	abschaltbar über Energiemanagement 	18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht	bewusste Aktivierung Fahrer Dauerhaft 	18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten	Low beam 	18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus	automatic 	18
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis	Driver door 	18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach	not active 	18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig	Hinweis_in_LDS-Stellung_Null_und_SL 	18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer	Faktor fuer x1 Stunden 	18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH	Keine_Spannungsanforderung 	18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light	Keine_Spannungsanforderung 	18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung	6400 lx	18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung	12 lx	18
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige	No 	18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht	separate 	18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker	false 	18
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL	Yes 	18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht	Yes 	18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht	Yes 	18
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung	Yes 	18
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus	Enabled 	18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)	LIN 	18
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten	klemmenabhaengig 	18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module	not installed 	18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam	Keine_Spannungsanforderung 	18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO	Menuesteuerung aktivieren 	18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome	20 seconds 	18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP	60 seconds 	18
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung	active 	18
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP	active 	18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert	not active 	18
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus	active 	18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht	active 	18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit	8 s	18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal	Keine_Spannungsanforderung 	18
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte	not active 	18
ENG126647-ENG98399-debug_light_function-Activation	0	11
ENG126647-ENG101417-debug_light_function-Adresse	0	11
ENG126647-ENG126820-debug_light_function-Bitmask	0	11
ENG126647-ENG126821-debug_light_function-Divisor	0	11
ENG126647-ENG98827-debug_light_function-Offset	0	11
ENG126647-ENG126822-debug_light_function-Polaritaet	0	11
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0	0.00%	6
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1	50.00%	6
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2	100.00%	6
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0	0.00%	6
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1	50.00%	6
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2	100.00%	6
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD	100%	6
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen	100%	6
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD	100%	6
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen	100%	6
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf	120 ms	6
ENG133364-ENG133507-Driver_multi-contour_seat_Error_Mask-ERROR_CODE_PIN	0 bit	66
ENG133364-ENG133526-Driver_multi-contour_seat_Error_Mask-ERROR_EEPROM	31743 bit	66
ENG133364-ENG133528-Driver_multi-contour_seat_Error_Mask-ERROR_HW_VERSION	31743 bit	66
ENG133364-ENG133500-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK	0 bit	66
ENG133364-ENG133499-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK	0 bit	66
ENG133364-ENG133502-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK	0 bit	66
ENG133364-ENG133501-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK	0 bit	66
ENG133364-ENG133504-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK	0 bit	66
ENG133364-ENG133503-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK	0 bit	66
ENG133364-ENG133511-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK	31743 bit	66
ENG133364-ENG133508-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN	31743 bit	66
ENG133364-ENG133509-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND	31743 bit	66
ENG133364-ENG133510-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB	31743 bit	66
ENG133364-ENG133524-Driver_multi-contour_seat_Error_Mask-ERROR_RAM	31743 bit	66
ENG133364-ENG133525-Driver_multi-contour_seat_Error_Mask-ERROR_ROM	31743 bit	66
ENG133364-ENG133506-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK	0 bit	66
ENG133364-ENG133505-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK	0 bit	66
ENG133364-ENG133531-Driver_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE	0 bit	66
ENG133364-ENG133512-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1	0 bit	66
ENG133364-ENG133515-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2	0 bit	66
ENG133364-ENG133518-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3	0 bit	66
ENG133364-ENG133521-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4	0 bit	66
ENG133364-ENG133513-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1	0 bit	66
ENG133364-ENG133516-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2	0 bit	66
ENG133364-ENG133519-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3	0 bit	66
ENG133364-ENG133522-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4	0 bit	66
ENG133364-ENG133514-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1	0 bit	66
ENG133364-ENG133517-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2	0 bit	66
ENG133364-ENG133520-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3	0 bit	66
ENG133364-ENG133523-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4	0 bit	66
ENG133364-ENG133529-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH	0 bit	66
ENG133364-ENG133530-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW	0 bit	66
ENG133364-ENG133527-Driver_multi-contour_seat_Error_Mask-ERROR_WDT	31743 bit	66
ENG122934-erase_error_table	00 00 00 	3
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP	present 	6
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung	AFS: Fernlicht ueber AFS 	6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset	active 	6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent	Not Present 	6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung	Not Present 	6
ENG141685-Front_wash_function	10	2
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA	active 	6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung	500 ms	6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm	active 	6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf	not active 	6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig	Keine_Spannungsanforderung 	6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition	not active 	6
ENG141682-ENG141966-Front_wiper-Frontwischertyp	LIN 	6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active 	6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer	active 	6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer	2000 ms	6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren	Deactivating 	6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay	300 ms	6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz	active 	6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status	active 	6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung	not active 	6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant	not active 	6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube	not active 	6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus	not active 	6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube	active 	6
ENG99457-ENG117394-Head area heater-blower_speed	0	2
ENG99457-ENG98971-Head area heater-Temperature	-3	2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid	installed 	8
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid	installed 	8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant	installed 	8
ENG141645-MAS00214-HW_Verbau-Brake pad wear	installed 	8
ENG141645-ENG142026-HW_Verbau-Druckklappe	not installed 	8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv	not active 	8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung	not installed 	8
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor	installed 	8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube	installed 	8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung	not installed 	8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer	not installed 	8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15	not active 	8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung	not active 	8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0	0.00%	30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1	-0.50%	30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2	-1.00%	30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3	-1.50%	30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4	-2.00%	30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5	-2.50%	30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6	-3.00%	30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7	-3.5	30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8	-4.00%	30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9	-4.50%	30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0	100.00%	30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1	90.00%	30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2	80.00%	30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3	70.00%	30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4	60.00%	30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5	50.00%	30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6	40.00%	30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7	30.00%	30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8	15.00%	30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9	0.00%	30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize 	16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize 	16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize 	16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	127	16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0	16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0	16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0	16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14	16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34	16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	33 - LED-Modul Blinkleuchten 	16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always 	16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase 	16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active 	16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	Blinken links Dunkelphase 	16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active 	16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active 	16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active 	16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active 	16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active 	16
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15	maximize 	16
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15	maximize 	16
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15	maximize 	16
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15	100	16
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15	0	16
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15	0	16
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15	0	16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15	63	16
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15	0	16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15	41 - LED Kleinleistung 	16
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15	Always 	16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15	Unknown (76)	16
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15	not active 	16
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15	not active 	16
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15	not active 	16
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15	not active 	16
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15	not active 	16
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15	not active 	16
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15	not active 	16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize 	16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize 	16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize 	16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	0	16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0	16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0	16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0	16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	0	16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	0	16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	not active 	16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always 	16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	not active 	16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	not active 	16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active 	16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active 	16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active 	16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active 	16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active 	16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active 	16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize 	16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize 	16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize 	16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	127	16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0	16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0	16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0	16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	62	16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	0	16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	2 - Shutter: Diagnosesensierung für 'LED low' 	16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always 	16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken 	16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	not active 	16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active 	16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active 	16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active 	16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active 	16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active 	16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active 	16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize 	16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize 	16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize 	16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	0	16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0	16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0	16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0	16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	0	16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	0	16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	not active 	16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always 	16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	not active 	16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	not active 	16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active 	16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active 	16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active 	16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active 	16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active 	16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active 	16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize 	16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize 	16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize 	16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	0	16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0	16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0	16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0	16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	0	16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	0	16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	not active 	16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always 	16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	not active 	16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	not active 	16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active 	16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active 	16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active 	16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active 	16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active 	16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active 	16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	minimize 	16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize 	16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize 	16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	127	16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0	16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0	16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	127	16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	0B 	16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0	16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	36 - LED Kleinleistung 	16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always 	16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	Klemme 30G 	16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active 	16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	Heckdeckel geschlossen 	16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	Klemme 15 mit Nachlauf bis Fahrzeugstillstand 	16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active 	16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active 	16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	Luggage compartment light 	16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active 	16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize 	16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize 	16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize 	16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	100	16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0	16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0	16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0	16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	4	16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0	16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	46 - LED Kleinleistung 	16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always 	16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	Ambientelicht 2 	16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active 	16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active 	16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active 	16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active 	16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active 	16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active 	16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active 	16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize 	16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize 	16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize 	16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	127	16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0	16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0	16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0	16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	16	16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	8	16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	33 - LED-Modul Blinkleuchten 	16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always 	16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	Blinken links Hellphase 	16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active 	16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	Blinken links Dunkelphase 	16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active 	16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active 	16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active 	16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active 	16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active 	16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize 	16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize 	16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize 	16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	127	16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0	16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0	16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0	16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	18	16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	18	16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	33 - LED-Modul Blinkleuchten 	16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always 	16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	Blinken rechts Hellphase 	16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active 	16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	Blinken rechts Dunkelphase 	16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active 	16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active 	16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active 	16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active 	16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active 	16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize 	16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize 	16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize 	16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	127	16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0	16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0	16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0	16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15	16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E 	16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	33 - LED-Modul Blinkleuchten 	16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always 	16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase 	16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active 	16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	Blinken rechts Dunkelphase 	16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active 	16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active 	16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active 	16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active 	16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active 	16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	minimize 	16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize 	16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize 	16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	127	16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	0	16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	0	16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0	16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	3F 	16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	13	16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	35 - kombinierte LED Blink-Bremsleuchten 	16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always 	16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light 	16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	Brake light 	16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	not active 	16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	not active 	16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	not active 	16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active 	16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active 	16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active 	16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	minimize 	16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize 	16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize 	16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	127	16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	0	16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	0	16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0	16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	40	16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	23	16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	35 - kombinierte LED Blink-Bremsleuchten 	16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always 	16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light 	16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	Brake light 	16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	not active 	16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	not active 	16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	not active 	16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active 	16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active 	16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active 	16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize 	16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize 	16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize 	16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	100	16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	5	16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0	16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0	16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C 	16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29	16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte 	16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always 	16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light 	16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	not active 	16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active 	16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active 	16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active 	16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active 	16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active 	16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize 	16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize 	16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize 	16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	100	16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	100	16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0	16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0	16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29	16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A 	16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	40 - allgemeine LED 	16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	Always 	16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	Coming Home oder Leaving Home aktiv 	16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	Daytime running lights 	16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active 	16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active 	16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active 	16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active 	16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize 	16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize 	16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize 	16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	100	16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	100	16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0	16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0	16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A 	16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A 	16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	40 - allgemeine LED 	16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	Always 	16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	Coming Home oder Leaving Home aktiv 	16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	Parking light right 	16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	Daytime running lights 	16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active 	16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active 	16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active 	16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active 	16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize 	16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize 	16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize 	16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	100	16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0	16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	100	16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0	16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30	16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28	16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED 	16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always 	16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	Coming Home oder Leaving Home aktiv 	16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active 	16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active 	16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	beidseitiges Dauerparklicht 	16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active 	16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active 	16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active 	16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	minimize 	16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize 	16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize 	16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	60	16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0	16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	100	16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0	16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	2E 	16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	0C 	16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	43 - allgemeine LED 	16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always 	16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Brake light 	16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	Brake light 	16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active 	16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active 	16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	Nebelschlusslicht wenn kein Anhaenger gesteckt 	16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active 	16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active 	16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active 	16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	minimize 	16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize 	16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize 	16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	60	16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0	16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	100	16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0	16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	2F 	16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	1C 	16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	43 - allgemeine LED 	16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always 	16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	Brake light 	16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	Brake light 	16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	not active 	16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active 	16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	Nebelschlusslicht wenn kein Anhaenger gesteckt 	16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active 	16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active 	16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active 	16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize 	16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize 	16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize 	16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	100	16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0	16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0	16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0	16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31	16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B 	16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	40 - allgemeine LED 	16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always 	16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht 	16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active 	16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active 	16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active 	16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active 	16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active 	16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active 	16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active 	16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize 	16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize 	16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize 	16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	100	16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0	16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0	16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0	16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32	16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B 	16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	40 - allgemeine LED 	16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	Always 	16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht 	16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active 	16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active 	16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active 	16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active 	16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active 	16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active 	16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active 	16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	minimize 	16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize 	16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize 	16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	100	16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	30	16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	28	16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	28	16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	4A 	16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	48	16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal 	16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always 	16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Daytime running lights 	16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active 	16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	Blinken links aktiv (beide Phasen) 	16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	not active 	16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	Coming Home oder Leaving Home aktiv 	16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active 	16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize 	16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize 	16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize 	16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	100	16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0	16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0	16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0	16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2	16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0	16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	46 - LED Kleinleistung 	16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always 	16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light 	16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active 	16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active 	16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active 	16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active 	16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active 	16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active 	16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active 	16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize 	16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize 	16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize 	16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	100	16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0	16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0	16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0	16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	3	16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0	16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active 	16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always 	16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	Ambientelicht 1 	16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active 	16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active 	16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active 	16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active 	16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active 	16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active 	16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active 	16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize 	16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize 	16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize 	16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	100	16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0	16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0	16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0	16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	4	16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0	16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active 	16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always 	16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	Ambientelicht 2 	16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active 	16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active 	16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active 	16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active 	16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active 	16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active 	16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active 	16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize 	16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize 	16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize 	16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	100	16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0	16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0	16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0	16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	5	16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0	16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active 	16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always 	16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	Ambientelicht 3 	16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active 	16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active 	16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active 	16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active 	16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active 	16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active 	16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active 	16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize 	16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize 	16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize 	16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	100	16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0	16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0	16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0	16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	6	16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0	16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active 	16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always 	16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	Ambientelicht 4 	16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active 	16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active 	16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active 	16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active 	16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active 	16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active 	16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active 	16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	minimize 	16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize 	16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize 	16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	100	16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	30	16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	28	16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	28	16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	4C 	16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	4C 	16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal 	16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always 	16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Daytime running lights 	16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active 	16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	Blinken rechts aktiv (beide Phasen) 	16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	not active 	16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	Parking light right 	16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	Coming Home oder Leaving Home aktiv 	16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active 	16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	maximize 	16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize 	16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize 	16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	100	16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	0	16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	100	16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	100	16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	49	16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	48	16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung 	16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always 	16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	Daytime running lights 	16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active 	16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	Blinken links aktiv (beide Phasen) 	16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active 	16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	Coming Home oder Leaving Home aktiv 	16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active 	16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	maximize 	16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize 	16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize 	16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	100	16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	0	16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	100	16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	100	16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	4B 	16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	4C 	16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung 	16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always 	16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	Daytime running lights 	16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active 	16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	Blinken rechts aktiv (beide Phasen) 	16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active 	16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	Parking light right 	16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	Coming Home oder Leaving Home aktiv 	16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active 	16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	minimize 	16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize 	16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize 	16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	127	16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0	16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0	16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0	16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A 	16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36	16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	5 - LED Abblendlicht 	16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always 	16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links 	16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	not active 	16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	Coming Home oder Leaving Home aktiv 	16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active 	16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active 	16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active 	16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active 	16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active 	16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	minimize 	16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize 	16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize 	16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	127	16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0	16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0	16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0	16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B 	16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40	16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	5 - LED Abblendlicht 	16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always 	16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts 	16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	not active 	16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	Coming Home oder Leaving Home aktiv 	16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active 	16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active 	16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active 	16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active 	16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active 	16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize 	16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize 	16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize 	16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	127	16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	127	16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0	16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0	16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	5D 	16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	36	16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	5 - LED Abblendlicht 	16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always 	16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Klemme 15 mit Nachlauf bis Fahrzeugstillstand 	16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	not active 	16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	Coming Home oder Leaving Home aktiv 	16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	not active 	16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active 	16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active 	16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active 	16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active 	16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize 	16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize 	16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize 	16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	127	16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	127	16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0	16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0	16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	5E 	16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	40	16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	5 - LED Abblendlicht 	16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always 	16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Klemme 15 mit Nachlauf bis Fahrzeugstillstand 	16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	not active 	16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	Coming Home oder Leaving Home aktiv 	16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	not active 	16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active 	16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active 	16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active 	16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active 	16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck	21 08 00 16 02 00 7F 03 00 00 00 00 00 00 00 00 21 18 00 18 04 00 7F 05 00 00 00 00 00 00 00 00 23 13 00 3F 18 18 7F 00 00 80 00 00 00 00 00 00 23 23 00 40 18 18 7F 00 00 80 00 00 00 00 00 00 2A 29 00 2C 18 00 64 08 00 05 00 00 00 00 00 00 28 0A 00 29 08 1E 64 09 14 64 00 00 00 00 00 00 28 1A 00 2A 08 1E 64 0A 14 64 00 00 00 00 00 00 2B 28 00 30 08 1E 64 00 00 00 3A 00 64 00 00 00 2B 0C 00 2E 18 18 3C 00 00 80 1A 00 64 00 00 00 2B 1C 00 2F 18 18 3C 00 00 80 1A 00 64 00 00 00 28 0B 00 31 19 00 64 00 00 00 00 00 00 00 00 00 28 1B 00 32 19 00 64 00 00 00 00 00 00 00 00 00 	192
ENG141662-Leuchtenkonfiguration_Sonstiges	24 00 00 0B 25 00 7F 22 28 80 00 00 00 2A 00 7F 2E 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 2E 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 64 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 64 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 64 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 	128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR	1-Sensor_LWR 	62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges	2700 mm	62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe	not active 	62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze	90.00%	62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze	10.00%	62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung	-127.0 ms	62
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz	15%	62
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe	10.0 s	62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1	5.00 mm/%	62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2	5.00 mm/%	62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3	5.00 mm/%	62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1	3.00 mm/%	62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2	3.00 mm/%	62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3	3.00 mm/%	62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante	Variante_1 	62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR	100.00%	62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf	0.03 Hz	62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung	normal 	62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal	Negative 	62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1	0 mm	62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2	0 mm	62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3	0 mm	62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4	0 mm	62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand	550 mm	62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe	680 mm	62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle	47.50%	62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle	12.50%	62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr	0 km/h	62
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr	100 Hz	62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung	0.03 Hz	62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte	BCM 	62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed	not installed 	62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht	not active 	62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese	20.00%	62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart	not active 	62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad	5.0 %/s	62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht	-100.00%	62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut	not installed 	62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR	10.00 s	62
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1	not active 	1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2	not active 	1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active 	1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	not active 	1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	not active 	1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6	not active 	1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ	not active 	1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%	12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%	12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%	12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%	12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110	12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5	12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%	12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%	12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%	12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%	12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%	12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%	12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0	-3.71%	20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1	-2.96%	20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2	-2.04%	20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3	-1.48%	20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4	-0.37%	20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0	-0.2	20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1	-0.1	20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2	-0.05	20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3	-0.01	20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4	0	20
ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband	60 hPa	12
ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck	110 hPa	12
ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte	0 s	12
ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben	7 s	12
ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten	7 s	12
ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen	7 s	12
ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1	60%	12
ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2	60%	12
ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3	0%	12
ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation	10 °C	12
ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband	60 hPa	12
ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck	110 hPa	12
ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte	0 s	12
ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben	7 s	12
ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten	7 s	12
ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen	7 s	12
ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1	60%	12
ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2	60%	12
ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3	0%	12
ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation	10 °C	12
ENG122979-ENG141954-Networking-A/C electronics	installed 	8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet	not installed 	8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet	installed 	8
ENG122979-ENG141953-Networking-Getriebesteuergeraet	installed 	8
ENG122979-ENG99457-Networking-Head area heater	not installed 	8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG	not installed 	8
ENG122979-ENG141969-Networking-UGDO	installed 	8
ENG124714-ENG142044-OCU-DWA_push	not active 	8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare	not active 	8
ENG124714-OCU-	not installed 	8
ENG124714-ENG142261-OCU-Remote HuF Abbruch	0 km/h	8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz	0 Hz	8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1	0 s	8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3	0 ms	8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock	not_active 	8
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy	110 hPa	15
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I	110 hPa	15
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy	110 hPa	15
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy	5000 ms	15
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy	5000 ms	15
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy	5000 ms	15
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy	0 ms	15
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy	0 ms	15
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy	0 ms	15
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy	0 ms	15
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy	0 ms	15
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy	0 ms	15
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy	80 ms	15
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy	80 ms	15
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy	80 ms	15
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy	160 hPa	15
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy	160 hPa	15
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy	160 hPa	15
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy	6000 ms	15
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy	6000 ms	15
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy	6000 ms	15
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy	0 ms	15
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy	0 ms	15
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy	0 ms	15
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy	0 ms	15
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy	0 ms	15
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy	0 ms	15
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy	80 ms	15
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy	80 ms	15
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy	80 ms	15
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy	210 hPa	15
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy	210 hPa	15
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy	210 hPa	15
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy	7000 ms	15
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy	7000 ms	15
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy	7000 ms	15
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy	0 ms	15
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy	0 ms	15
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy	0 ms	15
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy	0 ms	15
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy	0 ms	15
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy	0 ms	15
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I	80 ms	15
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy	80 ms	15
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy	80 ms	15
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy	140 hPa	15
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy	140 hPa	15
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy	140 hPa	15
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy	5000 ms	15
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy	5000 ms	15
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy	5000 ms	15
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy	2000 ms	15
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy	2000 ms	15
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy	2000 ms	15
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy	6000 ms	15
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy	6000 ms	15
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy	6000 ms	15
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy	80 ms	15
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy	80 ms	15
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy	80 ms	15
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy	190 hPa	15
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy	190 hPa	15
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy	190 hPa	15
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy	6000 ms	15
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy	6000 ms	15
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy	6000 ms	15
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy	2000 ms	15
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy	2000 ms	15
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy	2000 ms	15
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy	7000 ms	15
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy	7000 ms	15
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy	7000 ms	15
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy	80 ms	15
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy	80 ms	15
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy	80 ms	15
ENG133367-ENG133507-Passenger_multi-contour_seat_Error_Mask-ERROR_CODE_PIN	0 bit	66
ENG133367-ENG133526-Passenger_multi-contour_seat_Error_Mask-ERROR_EEPROM	31743 bit	66
ENG133367-ENG133528-Passenger_multi-contour_seat_Error_Mask-ERROR_HW_VERSION	31743 bit	66
ENG133367-ENG133500-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK	0 bit	66
ENG133367-ENG133499-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK	0 bit	66
ENG133367-ENG133502-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK	0 bit	66
ENG133367-ENG133501-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK	0 bit	66
ENG133367-ENG133504-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK	0 bit	66
ENG133367-ENG133503-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK	0 bit	66
ENG133367-ENG133511-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK	31743 bit	66
ENG133367-ENG133508-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN	31743 bit	66
ENG133367-ENG133509-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND	31743 bit	66
ENG133367-ENG133510-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB	31743 bit	66
ENG133367-ENG133524-Passenger_multi-contour_seat_Error_Mask-ERROR_RAM	31743 bit	66
ENG133367-ENG133525-Passenger_multi-contour_seat_Error_Mask-ERROR_ROM	31743 bit	66
ENG133367-ENG133506-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK	0 bit	66
ENG133367-ENG133505-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK	0 bit	66
ENG133367-ENG133531-Passenger_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE	0 bit	66
ENG133367-ENG133512-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1	0 bit	66
ENG133367-ENG133515-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2	0 bit	66
ENG133367-ENG133518-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3	0 bit	66
ENG133367-ENG133521-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4	0 bit	66
ENG133367-ENG133513-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1	0 bit	66
ENG133367-ENG133516-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2	0 bit	66
ENG133367-ENG133519-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3	0 bit	66
ENG133367-ENG133522-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4	0 bit	66
ENG133367-ENG133514-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1	0 bit	66
ENG133367-ENG133517-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2	0 bit	66
ENG133367-ENG133520-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3	0 bit	66
ENG133367-ENG133523-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4	0 bit	66
ENG133367-ENG133529-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH	0 bit	66
ENG133367-ENG133530-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW	0 bit	66
ENG133367-ENG133527-Passenger_multi-contour_seat_Error_Mask-ERROR_WDT	31743 bit	66
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar	not active 	16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten	0	16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung	not active 	16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	not active 	16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv	not active 	16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion	profiles_inactive 	16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	not active 	16
ENG98831-ENG142030-Personalization-Profil_Variante	Schluessel 	16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1	not active 	16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2	not active 	16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3	not active 	16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4	not active 	16
ENG141646-MAS01065-Querschnitts_funktionen-Brand	Audi 	5
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll	active 	5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung	not active 	5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung	not active 	5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21	active 	5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus	Pin A31 	5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe	Sollspannungsanforderung 13.5 	5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben	active 	5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme	installed 	5
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem	not active 	5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment	Left 	5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side	Right 	5
ENG122927-RLS_close_glazing	2.0 s	1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off	120 s	3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on	10 s	3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off	65 km/h	3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on	140 km/h	3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle	6000 lx	2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high	12	2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low	6	2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht	30 s	2
ENG122929-RLS_LIN_Communication	4 s	1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn	100 lx	1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day	200 lx	1
ENG122930-RLS_tunel_gateway_recognize	5 s	1
ENG122935-RLS_Washer_Front	15 s	1
ENG122926-RLS_wiper_position_parking	15 s	1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	8	10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system	not installed 	10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel	active 	10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit	1000 ms	10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit	1200 ms	10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit	1000 ms	10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit	1000 ms	10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit	1200 ms	10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen	Sollspannungsanforderung 13.5 	10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor	Not available 	6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor	Not available 	6
ENG141684-SFT271875-Slave_systems_identification-Light switch	Not available 	6
ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module	Not available 	6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit	Not available 	6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System	Not available 	6
ENG141684-SFT271896-Slave_systems_identification-Alarm horn	Not available 	6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof	Not available 	6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module	Not available 	6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind	Not available 	6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender	Not available 	6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left	Not available 	6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right	Not available 	6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left	Not available 	6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left	Not available 	6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right	Not available 	6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right	Not available 	6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker	SMLS 	4
ENG116588-Sonderfunktionen-	not enabled 	4
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1	not installed 	4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen	not active 	5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus	by look command via remote control key 	5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen	active 	5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung	active 	5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung	not active 	5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel	not active 	5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung	active 	5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt	active 	5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung	not active 	5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron	not active 	5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt	250	10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel	10 km/h	10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter	CAN 	10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel	10.0 min	10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen	40 ms	10
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0	0.0 lx	10
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1	8.0 lx	10
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2	50.0 lx	10
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3	80.0 lx	10
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4	100.0 lx	10
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0	6	10
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1	6	10
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2	20	10
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3	50	10
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4	100	10
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0	0.0 lx	10
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1	8.0 lx	10
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2	50.0 lx	10
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3	80.0 lx	10
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4	100.0 lx	10
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0	6	10
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1	6	10
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2	20	10
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3	50	10
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4	100	10
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0	0 ms	22
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1	200 ms	22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10	2000 ms	22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2	400 ms	22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3	600 ms	22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4	800 ms	22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5	1000 ms	22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6	1200 ms	22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7	1400 ms	22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8	1600 ms	22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9	1800 ms	22
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0	100.00%	22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1	100.00%	22
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10	0.00%	22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2	95.00%	22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3	80.00%	22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4	40.00%	22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5	20.00%	22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6	10.00%	22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7	5.00%	22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8	3.00%	22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9	1.00%	22
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM	0.00 s	21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM	0.00 s	21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM	0.00 s	21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM	0.00 s	21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM	0.00 s	21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung	Potentiometer 	21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen	0.0 s	21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen	0.0 s	21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe	not active 	21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten	active 	21
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung	active 	21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS	5	21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM	0.00 s	21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert	50%	21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl	Fotosensor_Kombi 	21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung	Always active 	21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor	0.248	21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert	1.00%	21
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0	0	22
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1	50	22
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10	0	22
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2	100	22
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3	200	22
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4	253	22
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5	0	22
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6	0	22
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7	0	22
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8	0	22
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9	0	22
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0	0 lx	22
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1	50 lx	22
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10	0 lx	22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2	100 lx	22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3	200	22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4	500	22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5	0	22
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6	0 lx	22
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7	0 lx	22
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8	0 lx	22
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9	0 lx	22
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0	0 ms	22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1	200 ms	22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10	2000 ms	22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2	400 ms	22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3	600 ms	22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4	800 ms	22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5	1000 ms	22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6	1200 ms	22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7	1400 ms	22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8	1600 ms	22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9	1800 ms	22
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0	0.00%	22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1	1.00%	22
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10	100.00%	22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2	3.00%	22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3	5.00%	22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4	11.00%	22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5	22.00%	22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6	40.00%	22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7	80.00%	22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8	95.00%	22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9	100.00%	22
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0	0 lx	8
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1	8 lx	8
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2	50 lx	8
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3	500 lx	8
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0	100	8
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1	100	8
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2	100	8
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3	100	8
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0	0 lx	8
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1	8 lx	8
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2	50 lx	8
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3	500 lx	8
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0	6	8
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1	6	8
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2	100	8
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3	100	8
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0	0.00%	12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1	6.00%	12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2	16.00%	12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3	30.00%	12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4	60.00%	12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5	100.00%	12
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0	10	12
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1	10	12
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2	100	12
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3	150	12
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4	220	12
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5	253	12
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0	0 lx	10
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1	8 lx	10
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2	200 lx	10
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3	300 lx	10
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4	500 lx	10
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0	16	10
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1	16	10
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2	100	10
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3	100	10
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4	100	10
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0	0 lx	10
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1	8 lx	10
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2	220 lx	10
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3	300 lx	10
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4	500 lx	10
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0	6	10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1	6	10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2	100	10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3	100	10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4	100	10
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0	0	12
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1	10	12
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2	100	12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3	150	12
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4	220	12
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5	253	12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0	6.00%	12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1	6.00%	12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2	16.00%	12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3	30.00%	12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4	60.00%	12
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5	100.00%	12
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0	0 lx	8
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1	8 lx	8
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2	50 lx	8
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3	500 lx	8
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0	6	8
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1	6	8
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2	100	8
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3	100	8
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0	0 lx	8
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1	8 lx	8
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2	50 lx	8
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3	500 lx	8
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0	100	8
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1	100	8
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2	100	8
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3	100	8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0	0.00%	6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1	50.00%	6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2	100.00%	6
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0	0.00%	6
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1	50.00%	6
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2	100.00%	6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0	0 lx	12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1	200 lx	12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2	400 lx	12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3	600 lx	12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4	800 lx	12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5	1020 lx	12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0	0	12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1	84	12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2	166	12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3	250	12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4	370	12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5	500	12
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0	0 ms	10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1	2000 ms	10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2	3000 ms	10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3	4000 ms	10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4	5100 ms	10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0	1.00%	10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1	5	10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2	15	10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3	40	10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4	100	10
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen	active 	4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen	active 	4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen	tilting 	4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1	not installed 	4
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3	not installed 	4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo	not installed 	4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule	LIN 	4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck	not_installed 	9
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck	not active 	9
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv	not active 	9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb	not active 	9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close	not installed 	9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global	active 	9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen	active 	9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen	active 	9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf	active 	9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen	not active 	9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung	Always 	9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden	nur wenn freigegeben 	9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit	not installed 	9
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach	not active 	9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung	not active 	9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy	not active 	9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder	active 	9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung	not active 	9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy	active 	9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder	active 	9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal	not active 	9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba	not active 	9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau	not installed 	9
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00 	20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00 	20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00 	20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00 	20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00 	20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00 	20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00 	20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00 	20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00 	20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00 	20
ENG124901-Wischer_Fehlermaske_Mitsuba_Entw	0 bit	4
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute	42	3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute	62	3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute	30	3
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB	not active 	7
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern	not active 	7
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active 	7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein	active 	7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein	not active 	7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt	not installed 	7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster	not installed 	7
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion	not active 	7
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung	active 	7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion	not active 	7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung	not active 	7
ENG141651-ENG141957-ZV allgemein-Radio freq.	315MHz 	7
ENG141651-ENG141958-ZV allgemein-Tankschloss	Bidirectional 	7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum	Freigabe_Softtouch 	7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung	Einzeltuerentriegelung 	7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion	installed 	7
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck	active 	3
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln	active 	3
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit	active 	3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR	active 	3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active 	3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock	adjustable 	3
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active 	4
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen	active 	4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash	active 	4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels	active 	7
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active 	7
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active 	7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster	via_CAN 	7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung	not active 	7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen	active 	7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste	Yes 	7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung	Pulse control 	7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster	0.0 s	7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	active 	7
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang	No 	7
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel	active 	7
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen	not active 	7
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp	1 or 2 notch rear actuator 	7
ENG141681-IDE02021-ZV Komfort-Comfort closing	active 	8
ENG141681-IDE02022-ZV Komfort-Comfort opening	not active 	8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten	No 	8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen	not active 	8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen	not active 	8
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit	600 s	8
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus	active 	8
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen	active 	8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen	active 	8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen	active 	8
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global	active 	8
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer	not active 	8
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar	adjustable 	8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen	not active 	8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art	once 	8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus	not active 	8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen	active 	8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen	active 	8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss	Tuersteuergeraet im Fond verbaut oder keine Fondtuer 	5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal	nicht invertiert 	5
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite	not installed 	5
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite	not installed 	5
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links	No 	5
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts	No 	5
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter	not installed 	5
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM	Driver side 	5
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active 	5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR	Yes 	5
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer	No 	5
Elapsed Time: 04:17
Rapture:that's a very interesting admap -thanks for posting. Rather than plow through the mega-list of channels -perhaps you could help us narrow down our search by telling us what (if anything) you were doing to the car on 1st July 2019 @ about 3:50 PM (it was last Monday).
If you can't remember - go to the Ross-Tech/VCDS/Debug sub-directory on the laptop that you run VCDS software and open Adplog.CSV with something like MS Excel and look for any changes made around this date/time. If you use the BETA version VCDS software, do the same for Ross-Tech/VCDS-Beta/Debug sub-directory.
Reason I ask is because your DTC is date stamped with these details - so it seems logical (to me at least) to start the diagnostic search with this information -I think
Rapture
Milwaukee, USA
C?ID=356886
Hello, and thanks.
I did not do anything that day other than take a scan. This fault has been there for a few months.
Rapture
Milwaukee, USA
C?ID=356886
I'm not really sure what I should be looking for within the Adaption Map.
Can anyone assist in what I should be looking for within the map?
flg
C?ID=53517
I've a US spec 2019 TT RS and I'm getting the exact same fault code "526359 - Control Module Incorrectly Coded" for Control Unit 09.
I've not replaced the LED taillights with OLEDs like the op, but I've changed the coding for the rear turn signals as he did, therefore this must be what is causing this fault code and help narrow down what we should look at. So, apparently this thread doesn't belong here in Retrofits. I cannot erase this fault code with a clear DTCs, maybe that's expected anyway, not sure.
My vehicle scans look pretty much like the ones that have already been posted (at least on what relates to these coding mods).
Here is a list of what I've done to my car, all under Control Unit 09:
1) I followed these instructions, and they worked perfectly, apart from this fault code now:
" -rear brake & fog lights stop blinking with the turn indicator
Control Unit 09 (Central Electronics)
security access 31347
Adaption
Find in the menu:
(Left Brake Light)
Leuchte20BR LA71-Lichtfunktion A 20 leave Brake Light
Leuchte20BR LA71-Lichtfunktion B 20 change to Brake Light
Leuchte20BR LA71-Lichtfunktion C 20 change to Not Active
(Right Brake Light)
Leuchte21BR RC8-Lichtfunktion A 21 leave Brake Light
Leuchte21BR RC8-Lichtfunktion B 21 change to Brake Light
Leuchte21BR RC8-Lichtfunktion C 21 change to Not Active
(Left Fog Light)
Leuchte26NSL LA72-Lichtfunktion A 26 leave Brake Light
Leuchte26NSL LA72-Lichtfunktion B 26 change to Brake Light
Leuchte26NSL LA72-Lichtfunktion C 26 change to Not Active
(Right Fog Light)
Leuchte27NSL RC6-Lichtfunktion A 27 leave Brake Light
Leuchte27NSL RC6-Lichtfunktion B 27 change to Brake Light
Leuchte27NSL RC6-Lichtfunktion C 27 change to Not Active"
2) I also did these three coding mods, again they worked perfectly, but I'm not sure if somehow they could be the cause of this fault code:
"1 - Not sure why my Canadian TTRS does not have the option to bring the front wipers into service position in the MMI menu, but if you want to have the option do this via MMI, do this:
Control Unit (09) Central Electronics -> Front_wiper -> Menuesteuerung Frontwischer -> change to active
2 - In North American, due to safety reasons, you can only open both windows with the remote when press and hold unlock, but NOT close both windows when press and hold lock. You can only close both windows by touching and holding the sensor on either door handle.
To enable remote close both windows by press and hold the lock button, do this:
Control Unit (09) Central Electronics -> ZV Komfort -> Funk Komfort schliessen -> change to active
3 - By default, your remote key fob buttons are disabled after you press the engine start button once or engine is running. If you want to enable the use of your remote buttons while engine is on (this can be useful if you want to keep the vehicle running when the driver needs to step out), do this:
Control Unit (09) Central Electronics -> ZV allgemein -> Funk bei Klemme 15 ein -> change to active"
Hope this info helps, and please help me. :)
Thank you.
Rapture
Milwaukee, USA
C?ID=356886
Thanks FLG,
It appears you believe that changing the coding to stop the brake and fog lights from blinking with the turn signals is what caused this fault code to appear.
Based on that knowledge would anyone on the forum be able to help with what may need to be done to retain this coding but not receive the fault?
flg
C?ID=53517
Thanks FLG,
Yes, what is causing the fault code "526359 - Control Module Incorrectly Coded" for Control Unit 09 are the changed values for the left and right brake lights 20 B and 21 B (leuchte 20 B and 21 B). I've tried all the logical options, but they all cause this module incorrectly coded error. There doesn't seem to be any side effects to this "526359 - Control Module Incorrectly Coded" fault, but I would also like to know the real reason why we are getting this fault.
At the Audizine forums someone has suggested this: "My educated guess to why it throws that fault is based on the coding for the module for the safety protocol on the brake lights.", I also believe this may indeed be the cause of this fault.
Could there really be a safety protocol programmed at the factory for the US bound vehicles that attempts to prevent us from changing the way the rear turn signals work together with the brake lights?
flg
C?ID=53517
Please move this thread back to Tweaks, this really has nothing to do with Retrofits. Could someone please do it to see if we possibly get an answer or solution to this fault, it gets generated by:
1) Modifying Light 20 (left rear brake light) (Leuchte 20 Lichtfunktion 20 B) to anything other than Blinken Links Dunkelphase
or by
2) Modifying Light 21 (right rear brake light) (Leuchte 21 Lichtfunktion 21 B) to anything other than Blinken Rechts Dunkelphase
Why is this happening, any solution?
flg
C?ID=53517
Huh? The OP clearly did a retrofit:
Hello Uwe,
Very old customer of your wonderful interfaces here.
Yes, indeed he did, and the original move was indeed correct when it was done.
After further discussion, mostly at a related thread in Audizine, this "526359 - Control Module Incorrectly Coded" for Control Unit 09 has been identified to be exclusively related to the mod that the OP, myself, and others have done in our 2019 Audi TT RS, related to stopping the way the rear brake lights flash in sync with the rear turn signals here in the US. This is why it now should be moved back.
What I posted in my previous post is what is causing this fault, not that he replaced the LED taillights with the OLEDs.
Thank you.
OK, moving to Tweaks.
Reactions: flg
darkchina811
ITALY
C?ID=333184
it might just be a USA requirement so that's how lights should be coded, and if they are not, the module will complain.
