2019 Passat R-Line (A3)
biffwell
C?ID=54690
I've been with Ross-Tech for many years but this is my first post, hello everyone.
I just leased a VW 2019 Passat R-Line (A3 chassis) and I also upgraded to the HEX-V2 interface running the 19.6 software on a Windows 7 Toshiba machine.
One of the first things I do with a new car is run the Auto-Scan and then turn off the seat belt warning, unfortunately I cannot find where to make that seat belt change. I have search the forum and only found older versions to make this change and don't seem to find it on my code 17 instrument section. If there is already instructions for this please reply with the link and hopefully I'm not being so dumb that is was right in front of my face :)
Thanks for your help,
Gregg
Sunday,30,June,2019,01:37:17:34676
VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
Dealer/Shop Name: Biffwell Productions
VIN: 1VWMA7A30KC001230   License Plate: 336
Mileage: 2240km-1391mi   Repair Order: 06302019
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 25 2B 3C 42 44 46 47 4F
          52 5F 61 62 72 75 A5
VIN: 1VWMA7A30KC001230   Mileage: 2240km-1391miles
Address 01: Engine (J623-DDSA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 016 D    HW: 06K 907 309
   Component: R4 2.0l TSI   H31 6243
   Revision: 1EH31000
   Coding: 411A00922444000F9000
   Shop #: WSC 06050 062 00200
   ASAM Dataset: EV_ECM20TFS01106K906016D 003003
   ROD: EV_ECM20TFS01106K906016D.rod
   VCID: 2B0307BCB38D471F4F7-807E
   Part No SW: 09G 927 158 DQ    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3517
   Coding: 010200000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW31.rod
   VCID: 0557910475A9516FF93-8050
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: C54BC0F5492200FBA30D03E79219004100F0F01A
   VCID: 75B7E1C425C941EFE93-8020
   Part No SW: 5K0 959 434 K    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1403
   Revision: 00093000    Serial number: 0473393844
   Coding: 132C0C
   VCID: 3D2739E45DF9D9AFE13-8068
   Part No SW: 561 907 044 BD    HW: 561 907 044 BD
   Component: Climatronic   H08 0910
   Revision: 00001K05
   Coding: 0050019092
   VCID: 5AED9278AC970E97E41-800E
9496609 - Sunlight Photo Sensor
          B10E8 11 [009] - Short to Ground
                    Reset counter: 90
                    Mileage: 24 km
                    Date: 2019.05.17
                    Time: 11:26:20
   Part No SW: 5K0 937 087 AS    HW: 5K0 937 087 AS
   Component: BCM PQ35 H++  122 0193
   Revision: BN122001
   Coding: EF200E1B982B08D4098806013400044800F1000645A00DB0E4806200BC70
   VCID: 06559608482F5A77F09-8052
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 170718 05  50  0106
   Coding: 0038DD
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 55501822913730
   Coding: 0071155011
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 372B2BCC7FC5F3FF3BF-8062
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Serial number: 2108187453A157
   Coding: 01001002FE0739
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 363526C878CF0AF7209-8062
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    008 0210
   Serial number: 003RXM0G0F7.
   Coding: 8CCCCC00000000005000001A020800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411_VW41.rod
   VCID: 6393AF9C9BDDCF5FB77-8036
   Serial number: IBH00000000000A51EKA
   Coding: 30324C
   Subsystem 2 - Part No SW: -----------    HW: 480 003 006 18
   Serial number: 357000000006B4F8803R
   Subsystem 3 - Part No SW: -----------    HW: 480 003 006 18
   Serial number: 3580000000001A74EE2P
   Subsystem 4 - Part No SW: -----------    HW: 480 022 804 18
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001C9298DB428215
   Subsystem 5 - Part No SW: -----------    HW: 480 021 207 18
   Component: SideSensor_Pr  004 0148
   Serial number: 3520001062B7224203CJ
   Subsystem 6 - Part No SW: -----------    HW: 480 022 905 18
   Component: FrontSensor_D  000 0189
   Serial number: 3550001B1267FA34A658
   Subsystem 7 - Part No SW: -----------    HW: 480 022 905 18
   Component: FrontSensor_P  000 0189
   Serial number: 3560001B1267FA365263
   Part No SW: 1K5 953 521 CS    HW: 5K0 953 569 BF
   Revision: FF010042    Serial number: 20180722200131
   Coding: 2012C40008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 005980106A8B7447CA5-8054
   Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 1941804412900386AE1B
   Coding: 2D0000
   Part No SW: 561 920 981 D    HW: 561 920 981 D
   Component: KOMBI         H03 2030
   Coding: 221E010000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
   VCID: 1D67D964FD39B9AFC13-8048
   Part No SW: 7N0 907 530 BQ    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1691
   Revision:   H56       Serial number: 19081803000038
   Coding: 461010
   VCID: 005980106A0B7447CA5-8054
   Component: IMMO          H03 2030
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC2B87CF79E17741-803E
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 18000227600001
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 313F15D491A12DCF75B-8064
   Serial number: 0486102438
   Coding: 02011102
   ROD: EV_HREntryHella_VW27.rod
   VCID: 3C2134E046E3D0A7D6D-8068
   Lane Change Assistant 2:
   Serial number: 0489833856
   Coding: 020111
   Part No SW: 561 959 701 C    HW: 3C0 959 793 J
   Component: TUER-SG FT    002 0637
   Revision: 12100010    Serial number: 0011137050
   Coding: 0404BD
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1E65DE68F03FA2B7D89-804A
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 C    HW: 561 959 811 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  022 1472
   Serial number: 14102746180730134253
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 313    3501
   Revision: 00H22000
   Shop #: WSC 19460 666 12345
   VCID: 392F2DF44551E58FCDB-806C
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H09 6831
   Revision: --------    Serial number: EAA098C0162588
   ROD: EV_AudioVerst10KanalSTT3.rod
   VCID: 2809F8B0A27B6C07A25-807C
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1691
   Coding: 01030100
   VCID: 6FBBD3AC47957B3F23F-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011815400291
   Coding: 181100
   Part No SW: 561 959 702 C    HW: 3C0 959 792 J
   Component: TUER-SG BT    002 0637
   Revision: 14100010    Serial number: 0011131013
   Coding: 0405BC
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1F1BE36CF735ABBFD3F-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 C    HW: 561 959 812 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  022 1472
   Serial number: 14102747180723075727
   Part No SW: 5C0 035 684 D    HW: 5C0 035 684 D
   Component: MU-S-NS-US    H42 0472
   Serial number: VWZAZ2U0992674
   Coding: 02140102AA00000041220003001808009F0106D400200105C6
   ROD: EV_MUStd4CTSAT_VW41.rod
   VCID: 2615F688A86F7A77909-8072
   Subsystem 1 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
6720 - Rear View Camera
          B1102 31 [008] - No Signal
                    Reset counter: 120
                    Mileage: 504 km
                    Date: 2019.05.31
                    Time: 09:31:18
                    Voltage terminal 30: 12.3 V
   Component: Batt.regelung H56 1691
   Coding: E1200859
   VCID: 71BFD5D451A16DCF35B-8024
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     024 0160
   Serial number: 000003554140568
   Coding: 02140102C24232107F1606000000
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 1471BC400EF3F8E77ED-8040
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 1272
   Serial number: 07051841K22859
   Coding: 0004010100010201002213468080480080000E200100
   ROD: EV_MFKBoschMQBB_001_VW27.rod
   VCID: 0849983042BB4C07825-805C
End----------(Elapsed Time: 01:26, VBatt start/end: 13.4V/13.5V)-----------
It's in the 17-Instruments, Coding -> Long Coding Helper.
Byte 1 (the second byte) should have a bit labelled "Seatbelt Warning active/installed".
biffwell
C?ID=54690
And just like that the Seat Belt warning is gone, thank you for the assist, I'm not use to this section of the program.
Another question:
Can the 'the vehicle is moving so settings can't be changed' be made to go away. That (to me) is so stupid of a thing. There is so much other things to adjust and change while the car is moving but the settings screen is locked out (along with the Sirius settings section) while the car is moving. Just dumb.
thanks again,
Gregg
TBAx
C?ID=287144
Not possible via coding or adaption. There are people however, who can make it go. I don’t know, if they modify the EEPROM or whatever...
biffwell
C?ID=54690
Thx for the update about the 'moving cant change the settings' thing, this car is a lease so I don't want to go that far to mess with the EEPROMS but I'll keep a look out for something.
Thx
Gregg
