HI folks,
This is my first post here and I hope I have done it correctly. I"m an old guy just getting used to this tech stuff. I'm just a shade tree mechanic. Usually perform most maintenance myself however, this is now well above my pay grade for diagnostics.
Any help would be much appreciated.
2012 VW CC R-line
All stock
Been having a time with occasional dash lights going crazy. At times car would not start with all interior lights flashing, clock resetting, etc.. Just recently it did it again and the negative batt cable was extremely hot to touch. Disconnected batt and let set for few minutes - reconnected and car started. Just got VCDS this week.
2012 VW CC R-line
All stock
Friday,28,June,2019,14:39:51:59694
VCDS Version: 19.6.0.6 HEX-V2 CB: 0.4505.4
VIN: WVWMN7AN5CE500071 License Plate:
Chassis Type: AN-VW46 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 53 56 62
65 72 77
VIN: WVWMN7AN5CE500071 Mileage: 134780km-83748miles
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 906 027 FE HW: 06J 907 309 B
Component: MED17.5.2 TFSI 2 3952
Revision: PAH04--- Serial number: VWZCZ000000000
Coding: 0404010A1C070160
Shop #: WSC 05110 444 99599
VCID: 73B3DFEAE7BBBA7FC77-8026
U1017 - 000 -
Readiness: 1110 0101
Part No SW: 02E 300 058 N HW: 02E 927 770 AL
Component: GSG DSG AG6 511 3522
Revision: 05351112 Serial number: 00001010021281
Shop #: WSC 44551 111 44551
VCID: 2517F1B219EF94CF993-8070
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 M HW: 3AA 614 109 M
Component: J104 C2 450M V4DB 0005
Revision: --H07--- Serial number: 00000003294873
Coding: 0000399
Shop #: WSC 05311 000 00000
VCID: 372B2BFAB343165F3BF-8062
Part No SW: 7N0 907 426 L HW: 7N0 907 426 L
Component: AC Manuell H17 0202
Revision: 00012001
Coding: 0000001002
Shop #: WSC 00015 115 00000
ROD: EV_ClimaBasis_VW46.rod
VCID: 3D2739D29DFF3C0FE13-8068
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 B HW: 3AA 937 087 B
Component: BCM PQ47 H+ 413 0452
Revision: BC413001
Coding: 0000000000000000009802259400840440517C8840600D605C8060200040
VCID: 392F2DC28957002FCDB-806C
Subsystem 1 - Part No SW: 3C8 955 119 D HW: 3C8 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 07101 10 0603
Coding: 00B795
Component: RLS 221010 05 54 0403
Coding: 0330ED
01598 - Drive Battery Voltage
Part No SW: 5N0 959 655 Q HW: 5N0 959 655 Q
Component: J234__30S VW10 HI 1918
Revision: 22014000 Serial number: 003JZPL6YMXQ
Coding: 0012371
VCID: 4BC3670ADFCB82BF6F7-801E
Subsystem 1 - Part No: 3C8 959 339 A
Subsystem 2 - Serial number: 00000000001XS4
Subsystem 3 - Serial number: 0025.09.100000300000850063ÿ†63
Subsystem 4 - Serial number: 850063ÿ†6332MTS659692770 ÿ†63
Subsystem 5 - Serial number: 92770 ÿ†6342MTS605672780 ÿ†63
Subsystem 6 - Serial number: 72780 ÿ†6351HTS610D7F6KJ ÿ†63
Subsystem 7 - Serial number: 7F6KJ ÿ†6361HTS6UOIHF9KR ÿ†63
Subsystem 8 - Serial number: HF9KR ÿ†63727TS649OFE9KR ÿ†63
Subsystem 9 - Serial number: FE9KR ÿ†63827TS67SPDF9KR ÿ
Subsystem 10 - Serial number: DF9KR ÿ
03551 - Functional Restriction of Seat Occupied Recognition
000 - - - MIL ON
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BG HW: 5K0 953 569 T
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101025300307
Coding: 098A270000
VCID: 6B83C78AB30B62BF0F7-803E
Component: E221__MFL-TK6 H06 0022
Coding: E20000
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
136194 - Supply voltage
147464 - Terminal 15
B1148 29 [008] - Signal Implausible
Part No SW: 3C8 920 970 Q HW: 3C8 920 970 Q
Component: KOMBI H20 0420
Coding: 240F00
Shop #: WSC 05314 115 00000
VCID: 3A2D32CE8CD10B37C41-806E
13635840 - Supply voltage
[Supply voltage too low]
Part No SW: 7N0 907 530 G HW: 1K0 907 951
Component: J533 Gateway H41 1614
Revision: H41 Serial number: 201010F2000883
Coding: 469006
Shop #: WSC 05314 000 00000
VCID: 34311CF6AE35FD471ED-8060
Part No SW: 3C8 919 965 HW: 3C8 919 965
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1614128R28N603
Coding: 0000002
VCID: 75B7E1F2E9CFA44FE93-8020
Part No SW: 3AA 959 433 A HW: 3AA 959 433 A
Component: IMMO 042 0399
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 27291 002 1048576
Component: ELV 029 0380
3C0905861J ELV 029 0380
02827 - Wake-Up request via ESP
02861 - Electronic Steering Column Lock Check Sum Error
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
02813 - Function of Steering Column Lock Limited due to Insufficient Voltage
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Revision: A1001003 Serial number: 7668799122
VCID: 270BFBBA6FE386DFABF-8072
Part No SW: 1T0 959 701 AG HW: 3C0 959 793 A
Component: TUER-SG FT 002 0307
Revision: 12101005 Serial number: 0001694035
Coding: 0004B7
Shop #: WSC 05311 115 00000
ROD: EV_DCU42BroseDriveSide_VW36.rod
VCID: 7CA1F4D6C665F50796D-8028
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 703 C HW: 3C0 959 795 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0401
Serial number: 00000001731247
Coding: 000490
B11EC 54 [008] - Missing Calibration / Basic Setting
65793 - Supply voltage
[Front DCU undervoltage]
131329 - Rear Door Control Module
B11ED F0 [008] - Supply Voltage too Low
131584 - Motor for Rear Window Regulator
B11EE 54 [008] - Missing Calibration / Basic Setting
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.303 0802
Revision: 1AH03729 Serial number: 00102930274701
Coding: 0000258
VCID: 3B2337CA8F6B323FDF7-806E
Component: KSG PQ47 ELV 042 0631
Coding: 13910F8001862E521204141FF08A0F0E085801
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1614
Coding: 00000008
VCID: 6FBBD39A87939E9F23F-803A
Subsystem 1 - Part No SW: 3AA 919 204 HW: 3AA 919 204
Component: Analoguhr 003 0003
Part No SW: 1T0 959 702 AC HW: 3C0 959 792 A
Component: TUER-SG BT 002 0307
Revision: 14101005 Serial number: 0001690119
Coding: 0004B6
ROD: EV_DCU52BrosePasseSide_VW32.rod
VCID: 79AFEDC2C957C02F8DB-802C
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 704 C HW: 3C0 959 794 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0401
Serial number: 00000001709702
Coding: 000490
Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
Component: J540 EPB4 VW-55183 0007
Revision: H18 Serial number: 00000000002777
Coding: 0022057
VCID: 33331FEAA73BFA7F077-8066
Part No SW: 1K0 035 180 AD HW: 1K0 035 180 AD
Component: Radio Prem-8 H04 0013
Revision: -----12S Serial number: VWZ4Z7K1159009
Coding: 0100040004
VCID: 629DAAAE444123F7BC1-8036
Part No SW: 3AA 907 273 B HW: 3AA 907 273 B
Component: RDKBERU30 H08 0008
Serial number: 10000000005316
ASAM Dataset: EV_RDKBERU30 003010
ROD: EV_RDKBERU30_003.rod
VCID: 33331FEAABBBFA7F077-8066
8397570 - Rear Left TPMS Sensor
C1052 31 [009] - No Signal
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668789619
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 323D1AEE54A1F3770C1-8066
End------(Elapsed Time: 01:38, VBatt start/end: 12.0V/12.0V, udsna)--------
