Tuesday,02,July,2019,21:58:04:13686
VCDS Version: 19.6.0.6 HEX-V2 CB: 0.4505.4
VIN: WVWZZZAUZGW147296 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 52 55
5F A9
VIN: WVWZZZAUZGW147296 Mileage: 49489km-30751miles
Address 01: Engine (J623-CJXB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 F HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00122466050B3004
ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
ROD: EV_ECM20TFS0205G0906259F.rod
VCID: 313F14F7C1AA0DEF75B-8064
Readiness: 1110 0000
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4911
Revision: 06253104 Serial number: TFK01509211648
ROD: EV_TCMDQ250021.rod
VCID: 53F37E7F9B761FFF277-8006
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 62665000000441
Coding: 01FA93A1542429730779070941C96980C92A94E0E08296F7184250B8C209
VCID: 7AADF3DB5C5C0EB7841-802E
Revision: 00021000 Serial number: 0382103910
Coding: 030C0C
VCID: 3A2D33DB1CDCCEB7C41-806E
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00120004200100001005000012101402
VCID: 6A8DC39B2CFCBE37741-803E
Air quality sensor:
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061527902828
Coding: 03011A46C24122F30BA44080B10C07281800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 094F9C1709BA152F9DB-805C
Component: WWS 150820 042 0551
Serial number: 150922125759
Component: RLHS 037 0059
Serial number: S5Y15M10D13H10M36S50
Coding: 06A8DD
Serial number: 000000000ZY152363GME
Serial number: 00000000000063621735
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 206
Mileage: 49489 km
Date: 2019.07.01
Time: 18:38:14
Revision: -------- Serial number: 39331528100210
Coding: 0071155011
VCID: 43D34E3F6B168F7F977-8016
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 23081503212727
Coding: 001C1300FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
1043 - Automatic Distance Control
B10E7 F0 [008] - Disconnected
[FAULT_CIS_TSK_IRREV_FAIL]
Reset counter: 220
Mileage: 49166 km
Date: 2019.06.22
Time: 13:11:48
Control Module temperature: 17 °C
Voltage terminal 15: 12.6 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 09101541350449
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 372B2AEF2FCED3DF3BF-8062
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number: 003MLR138CZ3
Coding: 98CCC000000000005C00000000C800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 7F5B02CF477E2B9FB3F-802A
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34169677B07101540181
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34169676B06101590769
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 809 15
Serial number: 3576700000054790B61S
Subsystem 4 - Part No SW: ----------- HW: 480 002 809 15
Serial number: 35867000000D5941961Y
Subsystem 5 - Part No SW: ----------- HW: 480 403 009 15
Serial number: 3516502C31CF2D7141EL
Subsystem 6 - Part No SW: ----------- HW: 480 403 009 15
Serial number: 3526502B91CF2DA4030H
Subsystem 7 - Part No SW: ----------- HW: 480 403 009 15
Serial number: 3556502AB1CF2D75030J
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 03101504220493
Coding: 0C10
ROD: EV_SMLSKLOMQB_010_VW37.rod
Part No SW: 5G1 920 758 A HW: 5G1 920 758 A
Component: KOMBI 302 6420
Coding: 272D08183F88000801886A095400000000000000
VCID: 2D070887DD92690F513-8078
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1223
Revision: -------- Serial number: 0004017225
Coding: 030100043F085900FB00027E9C0F00010001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 75B7E0E7754261CFE93-8020
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0040
Serial number: 29150001765000105382
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 7462318003
Serial number: HA1-00014.08.15
Coding: 0001
VCID: 4ACD631B4C3C5E37541-801E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000219118010
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 34311DE33EB838C71ED-8060
Component: HRE_Master H11 0071
Serial number: 0381851243
Coding: 02011203
ROD: EV_HREntryHella_VW37.rod
VCID: 3C2135C316E8F087D6D-8068
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H11 0071
Serial number: 0381863340
Coding: 020112
Component: TSG FS 020 0041
Serial number: 220915BIL04483
Coding: 003E12208001048000001000
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000007600373
Coding: 0D0000
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8103
VCID: 392F2CD719DAC5AFCDB-806C
Component: TSG BFS 020 0041
Serial number: 250915BIO13175
Coding: 003E10208E01048000801000
VCID: 42DD4B3B740C86779C1-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000007468013
Coding: 150000
Component: AFS-ECU H07 0090
Coding: 02A602000B000200
VCID: 40D941337A0094678A5-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 3Q0 035 846 HW: 3Q0 035 846
Component: MU-S-N-ER 820 0627
Coding: 02730008FF00000051510001000828001F0307D601200100C7
Shop #: WSC 12345 123 12345
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 6E85CF8B10145217289-803A
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H43 4064
Serial number: VWZ6Z9R2790762
Subsystem 2 - Part No SW: 3G0 919 866 K HW: -----------
Component: MRM2 2015/16 --- 0420
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 150908201126
VCID: 2F3B128FD79E1B1F63F-807A
End----(Elapsed Time: 01:45, VBatt start/end: 11.9V/11.7V. VIgn 11.8V)-----
