Charge Air Pressure Issue
Mika Rummukainen
Canberra, AU
I have a Golf R 7 with stage 3 hardware and recently the car has started running super rich and the EPC light comes on when a moderate amount of boost is used. The light has gradually started coming on earlier and earlier from startup over the last few weeks.
VCDS is reading the actual charge air pressure static at just about 1 bar, even though the specified value changes as it should. If I disconnect the lower MAP sensor the actual starts measuring as it should, but this process triggers the engine light. It continues measuring correctly if I plug the sensor back in but reverts to flatline 1 bar if I clear the fault or restart the car.
What on earth is going on?
Could someone also help me out with what the two MAP sensors actually do, and which of these is measuring the Actual Charge Air Pressure?
Mika Rummukainen
Canberra, AU
Below is the scan, this is before the car was run today and no unplugging of sensors etc. The EPC light was triggered on the previous drive.
The car is a 2016 Golf R with BOSS 600 turbo, dump pipe and high flow cat, standard mufflers and rear exhaust, upgraded HPFP, intake pipes, intercooler and custom tune to 25psi boost and 275kW atw.
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 52 55
5F A9
VIN: WVWZZZAUZGW147296 Mileage: 49489km-30751miles
Address 01: Engine (J623-CJXB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 F HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00122466050B3004
ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
ROD: EV_ECM20TFS0205G0906259F.rod
VCID: 313F14F7C1AA0DEF75B-8064
14846 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [109] - Implausible Signal
Mileage: 49412 km
Date: 2019.06.29
Time: 15:11:00
Engine speed: 3657.00 /min
Normed load value: 23.9 %
Vehicle speed: 30 km/h
Coolant temperature: 93 °C
Intake air temperature: 33 °C
Ambient air pressure: 940 mbar
Voltage terminal 30: 14.101 V
Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000001
Charge air pressure control valve uncond voltage sensor: 4.5386 V
Charge air pressure control valve position: target value: 0.00 %
Charge air pressure control valve position: actual value: 0.00 %
Charge air pressure control valve activation pulse duty factor: -20.15 %
Charge air pressure control valve voltage: position closed: 4.4482 V
STATE_BPA[0]: AD
Readiness: 0010 0000
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4911
Revision: 06253104 Serial number: TFK01509211648
ROD: EV_TCMDQ250021.rod
VCID: 53F37E7F9B761FFF277-8006
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 62665000000441
Coding: 01FA93A1542429730779070941C96980C92A94E0E08296F718 4250B8C209
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 7AADF3DB5C5C0EB7841-802E
Revision: 00021000 Serial number: 0382103910
Coding: 030C0C
VCID: 3A2D33DB1CDCCEB7C41-806E
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00120004200100001005000012101402
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 6A8DC39B2CFCBE37741-803E
Air quality sensor:
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061527902828
Coding: 03011A46C24122F30BA44080B10C0728180000000000000000 0000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 094F9C1709BA152F9DB-805C
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150820 042 0551
Serial number: 150922125759
Component: RLHS 037 0059
Serial number: S5Y15M10D13H10M36S50
Coding: 06A8DD
Serial number: 000000000ZY152363GME
Serial number: 00000000000063621735
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331528100210
Coding: 0071155011
VCID: 43D34E3F6B168F7F977-8016
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 23081503212727
Coding: 001C1300FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
1043 - Automatic Distance Control
B10E7 F0 [008] - Disconnected
[FAULT_CIS_TSK_IRREV_FAIL]
Reset counter: 220
Mileage: 49166 km
Date: 2019.06.22
Time: 13:11:48
Control Module temperature: 17 °C
Voltage terminal 15: 12.6 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 09101541350449
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 372B2AEF2FCED3DF3BF-8062
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number: 003MLR138CZ3
Coding: 98CCC000000000005C00000000C800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 7F5B02CF477E2B9FB3F-802A
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34169677B07101540181
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34169676B06101590769
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 809 15
Serial number: 3576700000054790B61S
Subsystem 4 - Part No SW: ----------- HW: 480 002 809 15
Serial number: 35867000000D5941961Y
Subsystem 5 - Part No SW: ----------- HW: 480 403 009 15
Serial number: 3516502C31CF2D7141EL
Subsystem 6 - Part No SW: ----------- HW: 480 403 009 15
Serial number: 3526502B91CF2DA4030H
Subsystem 7 - Part No SW: ----------- HW: 480 403 009 15
Serial number: 3556502AB1CF2D75030J
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 03101504220493
Coding: 0C10
ROD: EV_SMLSKLOMQB_010_VW37.rod
Part No SW: 5G1 920 758 A HW: 5G1 920 758 A
Component: KOMBI 302 6420
Coding: 272D08183F88000801886A095400000000000000
VCID: 2D070887DD92690F513-8078
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1223
Revision: -------- Serial number: 0004017225
Coding: 030100043F085900FB00027E9C0F0001000105000000000000 0000000000
ROD: EV_GatewLear_013.rod
VCID: 75B7E0E7754261CFE93-8020
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0040
Serial number: 29150001765000105382
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 7462318003
Serial number: HA1-00014.08.15
Coding: 0001
VCID: 4ACD631B4C3C5E37541-801E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000219118010
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 34311DE33EB838C71ED-8060
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0381851243
Coding: 02011203
ROD: EV_HREntryHella_VW37.rod
VCID: 3C2135C316E8F087D6D-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H11 0071
Serial number: 0381863340
Coding: 020112
Component: TSG FS 020 0041
Serial number: 220915BIL04483
Coding: 003E12208001048000001000
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000007600373
Coding: 0D0000
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8103
VCID: 392F2CD719DAC5AFCDB-806C
Component: TSG BFS 020 0041
Serial number: 250915BIO13175
Coding: 003E10208E01048000801000
VCID: 42DD4B3B740C86779C1-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000007468013
Coding: 150000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 02A602000B000200
VCID: 40D941337A0094678A5-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 3Q0 035 846 HW: 3Q0 035 846
Component: MU-S-N-ER 820 0627
Coding: 02730008FF00000051510001000828001F0207D601200102C7
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 6E85CF8B10145217289-803A
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H43 4064
Serial number: VWZ6Z9R2790762
Subsystem 2 - Part No SW: 3G0 919 866 K HW: -----------
Component: MRM2 2015/16 --- 0420
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 150908201126
VCID: 2F3B128FD79E1B1F63F-807A
End----------(Elapsed Time: 04:09, VBatt start/end: 12.1V/12.0V)-----------
NostraJackAss
Clear faults and then immediately re-post the scan please.
Repair harness or check/clean/change G31
NostraJackAss
You would think that someone which is to modify a car to "Stage III dog dukers" would have a better understanding of what or how their car operates.
OP in addition to RTFB I recommend you read SSP on this engine for design and function.
It will illustrate in simple detail things you should know.
If they did it themselves, sure. But what if the just took the car (and a big wad of money) to a tuner and said: "Make it really fast!" ?? I'd suppose there are also some in-between scenarios.
NostraJackAss
Well sure but all the same if OP is asking this stuff, SSP will be very informative crash course.
Mika Rummukainen
Canberra, AU
Hi guys, thanks for your help. I did put the hardware in myself but I am certainly no genius with tinkering with the electronics! Chucking it all in is easy, anything after that is waaaay beyond me!
Are your RTFB and WD and SSP text supposed to be links? it does come up with text when hovering but don't lead anywhere if clicked. I have Googled the Fine Book and somehow found a link to Erwin, I then registered and found the wiring diagram link but it then asks for payment. Happy to pay if this is obviously the right path I'm going down, though it seems there is something obvious that I'm missing.
Yes, I am a complete noob, but it really is difficult to learn all of this stuff with literally no experience of electronics and programming etc... don't hurt me!
Is the G31 the top sensor or the lower one?
Mika Rummukainen
Canberra, AU
I cleared the faults and did an Auto-Scan,here are the results:
Tuesday,02,July,2019,21:58:04:13686
VCDS Version: 19.6.0.6  HEX-V2 CB: 0.4505.4
VIN: WVWZZZAUZGW147296   License Plate:
          5F A9
   Revision: --H13---
Readiness: 1110 0000
   Coding: 01FA93A1542429730779070941C96980C92A94E0E08296F7184250B8C209
   Coding: 030C0C
   Revision: 00001K08
   Air quality sensor:
   Coding: 03011A46C24122F30BA44080B10C07281800000000000000000000000000
   Coding: 06A8DD
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 206
                    Mileage: 49489 km
                    Date: 2019.07.01
                    Time: 18:38:14
   Coding: 0071155011
                    Reset counter: 220
                    Mileage: 49166 km
                    Date: 2019.06.22
                    Time: 13:11:48
   Coding: 333135
   Coding: 333135
   Coding: 0C10
   Coding: 030100043F085900FB00027E9C0F00010001050000000000000000000000
   Coding: 2DFFFF
   Coding: 0001
   Coding: 02011203
   Coding: 020112
   Coding: 0D0000
   Coding: 8103
   Coding: 150000
   Coding: 2E0000
   Coding: 2E0000
   Coding: 02730008FF00000051510001000828001F0307D601200100C7
End----(Elapsed Time: 01:45, VBatt start/end: 11.9V/11.7V. VIgn 11.8V)-----
NostraJackAss
This means you are running deletes and the stack is effectively corrupted due to lazy tuner.
Mika Rummukainen
Canberra, AU
Wow, thanks mate, that's really handy. I've tried googling MAP sensor etc and looked into dozens of forums but found nothing, the links you've given are awesome. I've cleaned the G71 sensor and will clean the G31 sensor, now that I know where it is.
What does it mean that I am running deletes? Is that the turbo muffler delete?
NostraJackAss
The tuning code in your engine controller is modified and impaired to false present a readiness status, in addition this means fault codes or thresholds are vacated.
This is only done to perform a nefarious act and not inspirit of real Motorsports.
It means that the MIL may not illuminate when needed & to warn you of a possible error.
In cases like this and due to lazy tuners it will or may make diagnosis procedure's harder & since if controller doesn't report, than VCDS won't see in these cases either.
This is why it will be essential to know mechanicals and how things should operate in addition to manual test methods RTFB and SSP.
A second stock controller also may aid you for things like this too & make VCDS a stronger tool for you in combination.
Mika Rummukainen
Canberra, AU
Thanks mate, though the second scan with no faults was done after the faults were cleared and prior to starting and driving the car. The EPC light always comes on when a modest amount of boost is used after starting, it makes sense to me that a fault is not triggered prior to boost being generated. The fault is present in the log after driving and the EPC light being triggered.
I'm not too sure that it's a case of fault codes being hidden as the fault does arise when the car is made to boost and realises there is a discreapancy between the expected signal and the actual. Prior to that there is no discrepancy, hence no fault.
NostraJackAss
It's a generalization....
Did you check wiring as per known TSB for the TV harness being in error?
