- Jun 26, 2019
- 26
- 4
- California, USA
- C?ID=349997
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRZ71K99M0xxxxx Mileage: 200150km-124367miles
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 M HW: 07K 906 055 M
Component: 2,5l R5/4V G 9203
Revision: G6H02--- Serial number: VWX7Z0HN2431AD
Coding: 0000075
Shop #: WSC 00066 000 00000
VCID: 38292B354E583907321-806C
Readiness: 0000 0100
Part No SW: 09G 927 750 JE HW: 09G 927 750 JE
Component: AQ 250 6F 1377
Revision: 00H76000 Serial number:
Coding: 0000072
VCID: 7DA7FA2121FADC2FA17-8028
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 113B400D492A0000880E02E6921E00413000
Shop #: WSC 36555 002 104857
VCID: 7EA5FD2D20FCC737B8D-802A
Fault Status: 00100011
Reset counter: 100
Mileage: 200084 km
Count: 12800
Count: 83
Count: 50184
Reset counter: 100
Mileage: 200084 km
Count: 12800
Count: 67
Count: 50184
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
VCID: 78A9EB350ED8F907F21-802C
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000001126957
Coding: 14058E234004100007140000001400000008730B5C000120000000000000
Shop #: WSC 00066 123 12345
VCID: 323D191DA824D3570C5-8066
Component: Wischer 111108 021 0501
Coding: 00038805
Shop #: WSC 00066
Reset counter: 103
Mileage: 200087 km
Voltage: 10.50 V
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0474413
Coding: 0000100
VCID: 33331C19573EDA5F073-8066
Fault Frequency: 9
Reset counter: 57
Mileage: 200012 km
Time: 23:05:21
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M07MLDJ
Coding: 0013889
VCID: 6C81C7654A8045A7069-8038
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME41145001U
Subsystem 3 - Serial number: 6342MSME3F645540E
Subsystem 4 - Serial number: 6351HSME184928504
Subsystem 5 - Serial number: 6361HSME184970478
Subsystem 6 - Serial number: 63727SME19085068/
Subsystem 7 - Serial number: 63827SME19084108Z
Part No SW: 1K0 953 549 BR HW: 1K0 953 549 BR
Component: J0527 051 0101
Coding: 0010021
VCID: 03538CD9471EAADFD73-8056
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Part No SW: 1K0 920 954 S HW: 1K0 920 954 S
Component: KOMBIINSTRUMENT 3HL 1222
Revision: V0003000 Serial number: VWX7Z0HN2431AD
Coding: 0023203
VCID: 3C2137257A601527D69-8068
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 220908F2000138
Coding: ED807F070003021002
Shop #: WSC 11111 123 12345
VCID: 35372201594AC46F297-8060
Component: IMMO 3HL 1222
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000766589028
Coding: 0001205
VCID: 6FBBD0697B96BEBF23B-803A
Fault Status: 01111000
Reset counter: 64
Mileage: 190135 km
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Fault Status: 01101000
Reset counter: 64
Mileage: 190135 km
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A0D017D80F49B97B45-807E
Fault Status: 00101101
Reset counter: 110
Mileage: 200084 km
Time: 17:17:05
Voltage: 14.00 V
DU
Temperature: 35.0°C
RPM: 688 /min
Speed: 9.0 km/h
Speed: 9.0 km/h
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DCA0
VCID: 04518FC54210ADE7EE9-8050
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08100814090904
Coding: 0001204
VCID: 70B9D31566A8A1473A1-8024
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: MIB2-S-R-CN 036 0317
Revision: -----001 Serial number: VWZ6Z2R7301947
Coding: 1600040004000A
Shop #: WSC 00081 790 00120
VCID: 46D555CD38AC5FF7B0D-8012
7 Faults Found:
00856 - Radio Antenna
Fault Status: 00100111
Reset counter: 57
Mileage: 191377 km
Time: 07:30:31
Reset counter: 45
Mileage: 15 km
Date: 2003.14.26
Time: 05:20:26
Reset counter: 45
Mileage: 14 km
Date: 2003.14.26
Time: 08:20:45
00877 - Treble Speaker Rear Right (R16)
Fault Status: 00101011
Reset counter: 35
Mileage: 2 km
Date: 2000.14.00
Time: 02:16:09
Reset counter: 35
Mileage: 2 km
Date: 2000.14.00
Time: 02:16:09
00875 - Treble Speaker Front Right (R22)
Reset counter: 35
Mileage: 2 km
Date: 2000.14.00
Time: 02:16:09
Reset counter: 35
Mileage: 2 km
Date: 2000.14.00
Time: 02:16:09
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003626568
Coding: 0001168
VCID: 76B5E50D04CC8F77E0D-8022
Component: RDK 0450
Coding: 0100100
Reset counter: 3
Mileage: 199154 km
Time: 14:14:37
00625 - Vehicle Speed Signal
Reset counter: 102
Mileage: 200087 km
Time: 11:22:28
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003588487
Coding: 0001168
VCID: 77ABE80903C6F67FFBB-8022
End----------(Elapsed Time: 01:22, VBatt start/end: 11.8V/12.2V)-----------
Does anyone know why I get an error when trying to perform Auto Trans 02 -
063 Kick-Down Alignment (Automatic Transmission)?
