New user with problems with greyed out areas
den9112
C?ID=362794
Hi,new user here that thought i would be able to do a few home repairs on my car using the cable and software ..I have gone through the config and registreed etc ,all fine with that with a conformation email but when i came to use the cable and software to prime the fuel after a filter change i had no option to do this ,not good as i need to use the car ,next was i wanted to check my injector values and coded numbers again i could not use this as both measuring blocks and coding was greyed out ...These are the main reasons for purchasing the cable which now looks a waste of time for me ..Or am i doing something wrong as all the videos of the coding online especialy with the same car and engine i have was a straightforward procedure ....
Viking
C?ID=151455
Just curious really, where did you buy your cable from?
Second thing, can you post an Autoscan from the car you're working on?
den9112
C?ID=362794
Unplugged the cable now as I have had to go back to work but will try a copy and paste tonight if the weather holds out ...I purchased the cable from Gendan Ltd UK...Ok just noticed that I am a UDS on my car and found a tutorial on how to get to do it,it seems I have been looking at non UDS tutorials just need to find one on checking injector codes now ..
den9112
C?ID=362794
Wednesday,26,June,2019,18:32:55:04136
VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
VIN: TRUZZZ8P1B1004211   License Plate:
Chassis Type: 8P-AU35 (8P0)
Scan: 01 03 08 09 10 15 16 17 19 25 26 42 44 46 52 56 61 62 72 77
VIN: TRUZZZ8P1B1004211   Mileage: 127220km-79050miles
   Part No SW: 03L 906 023 M    HW: 03L 906 023 L
   Component: 1,6l R4 CR td H23 9973
   Revision: --H23---    Serial number: AUX7Z0J8FN70SN
   Coding: 00114034030501080000
   Shop #: WSC 01236 785 00200
   ASAM Dataset: EV_ECM16TDI02103L906023M 003014
   ROD: EV_ECM16TDI02103L997557R.rod
   VCID: 303911D20AA251077A5-8064
Readiness: 0100 0000
   Revision: 00H31001
   Coding: 13422012092200FEC80D04E5901A0091380800
   Shop #: WSC 01236 758 00200
   VCID: 76B5E7CAA8C63F37E09-8022
   Part No SW: 8P0 820 047 E    HW: 8P0 820 047 E
   Component: J255  Klima Man H08 0060
   Revision: 00H08004    Serial number: 00000000000000
   VCID: 323D1BDA082E63170C1-8066
   Part No SW: 8P0 907 063 F    HW: 8P0 907 063 F
   Component: BCM PQ35  B   107 0615
   Revision: 00107 AF
   Coding: 46000A2FAA13F140207060E00000004C53325CAA0000C522E4008F000055
   VCID: 372B2ACEEF4C863F3BF-8062
   Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H11 0050
   Coding: 00DD13
   Subsystem 2 - Part No: 8P7 951 177
   Component: DWA-Sensor H0  H03 0050
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 G    HW: 8P0 919 475
   Component: PARKHILFE 4K  H06 0120
   Revision: 11001001    Serial number: 93631028726473
   VCID: 42DD4B1AB48ED3979C1-8016
Address 15: Airbags        Labels: 8P7-959-655.clb
   Part No SW: 8P7 959 655     HW: 8P7 959 655
   Component: SR Airbag 9.43  H01 0020
   Revision: 93H01002    Serial number: 003BS0015N0S
   Coding: 0021330
   VCID: 0655970AD4262FB7F09-8052
   Subsystem 1 - Serial number: 6332DRB40CEB8CB3B
   Subsystem 2 - Serial number: 6342DRB40CED95262
   Subsystem 3 - Serial number: 63747RB405E00EE6-
   Subsystem 4 - Serial number: 63847RB405E012FAV
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0003011
   VCID: 46D5570A94A6EFB7B09-8012
   Component: E0221           H04 0100
   Part No SW: 8P0 920 982 H    HW: 8P0 920 982 H
   Component: KOMBIINSTR. VDO H01 0090
   Revision: D0H01003    Serial number: 2248J003006189
   Coding: 0260418
   VCID: 3E253FEACC76B777F89-806A
00003 - Control Module
                    Fault Status: 01100101
                    Mileage: 127200 km
                    Date: 2019.06.26
                    Time: 12:55:40
   Part No SW: 8P0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H33 5304
   Revision:   H33       Serial number: 071010F1001261
   Coding: E9A07F2600060204009101
   VCID: 313F14D60D28580F75B-8064
   Revision: D0H01003    Serial number: AUX7Z0J8FN70SN
Address 26: Auto Roof        Labels: Redir Fail!
   Part No: 8P7 959 255 B
   Component: VSG AUDI A3     H14 0130
   VCID: 44D14D02A29ADDA7AED-8010
Address 42: Door Elect, Driver        Labels: None
   Part No SW: 8P7 959 801 G    HW: 8P7 959 801 G
   Component: Tuer-SG         H04 0103
   Coding: 0131764
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 233    3001
   Revision: 00H17000
   Part No SW: 8P7 959 802 F    HW: 8P7 959 802 F
   Coding: 0019092
   Part No SW: 8P0 035 152 F    HW: 8P0 035 152 F
   Component: R Chorus2+      H02 0293
   Revision: 00H02000    Serial number: AUZ1Z2K1413171
   Coding: 0620221
   VCID: 2E050FAA1C1647F7689-807A
   Part No SW: 8P0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H33 5304
   Coding: 030B085A
   VCID: 74B1DDC2BEBA2D27DED-8020
   Subsystem 1 - Part No SW: 1K0 915 181 E    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650408099
   Part No SW: 8P7 959 811 B    HW: 8P7 959 811 B
   Component: Tuer-SG         H01 0054
   Coding: 0131216
   VCID: 42DD4B1AB88ED3979C1-8016
   Part No SW: 8P7 959 812 B    HW: 8P7 959 812 B
   Coding: 0131216
   Shop #: WSC 01236 785 1012552
   VCID: 43D34E1EA794DA9F977-8016
   Part No SW: 8P1 862 335     HW: 8P1 862 335
   Component: FSE_256x BT     H41 0650
   Revision: 00000000    Serial number: 00000005237980
   Coding: 0001202
   VCID: 74B1DDC2B2BA2D27DED-8020
End----------(Elapsed Time: 01:24, VBatt start/end: 12.4V/12.4V)-----------
den9112
C?ID=362794
Ok..I have done a autoscan of the car ....My first job i would like to do is check my inject numbers to make sure they correspond with the ecu and also that they are all coded..Now on the non uds i can do this but with uds i am not sure of the steps to go through ,any help or advice on how to achieve this would be apreciated.Thanks
NEtech
Denmark
C?ID=56995
For injection numbers, go to [01-Engine] > [Adaptation - 10] see the stored value in the first 4 channels.
For the prime fuelfilter, please try and explain the steps you are trying to do now.
grant@gendan
To run the fuel pump, have you tried:
[01 - Engine] > [Basic Settings - 04] > Select 'Fuel Supply Pump Activation' from drop down list.
or
[01 - Engine] > [Output Tests - 03] > Select 'Fuel Pump Electronics' from drop down list.
den9112
C?ID=362794
Thanks all for the help i found it under tail lift pump...I also found the injector coding numbers and the live deviation check of all four injectors,i also spotted the coding page for changing codes for new injectors,i did notice that all the injectors corresponded with the ones in ecu but they all had a zero added at the end ,i presume it would be the same with new injector coding
grant@gendan
Conti injectors with 6 character code need an additional zero added at the end
den9112
C?ID=362794
*New Sealed* 4 X Continental VDO Diesel Fuel Injector A2C9626040080 VW AUDI BMW just ordered 4 of these so I presume zero at the end
den9112
C?ID=362794
Managed to fit the new injectors and the new clamp bolts which I can understand how people snap them as correct torque is a must,also found using vcds was a breeze especially for a beginner
