Received Instrument cluster and ECU. I installed both. Hooked battery. Attempted to start. IC displays proper mileage, then goes to SAFE. Tried unsuccessfully with all three keys to start. Immobilizer appears to prevent. Also, all of the original issues with the original cluster are back. No HVAC, No convertible roof operation or light in the IC, no turn signal indicators in the dash, no dash lighting. Not sure about what to do from your statement from an earlier post " 0x17-10- gateway settings need to be reestablished upon installation or power down!"
Any ideas?
Posted below is a scan
Any ideas?
Friday,19,July,2019,11:26:54:41616
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUAT48H74K015115 License Plate:
Mileage: 115910km-72023mi Repair Order: 0719
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
63 65 67 73 75 76 77
VIN: WAUAT48H74K015115 Mileage: 115910km-72023miles
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 L HW: 8E0 909 059
Component: 3.0L V6/5V G 0020
Coding: 0016584
Shop #: WSC 03738 444 38140
VCID: 3E253F152C6D9CF7F85-5160
18043 - Powertrain Data Bus
P1635 - 008 - Missing Message from A/C Controller
18107 - Powertrain Data Bus
P1699 - 008 - Missing Message from Steering Wheel Electronics
18010 - Power Supply Terminal 30
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 -
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E2 910 156 HW: 01J 927 156 JK
Component: V30 01J 3.0l 5V USA 3261
Revision: 00000008 Serial number: 00000002100924
Coding: 0000001
Shop #: WSC 04940 001 00001
VCID: 6597B079E97BEF2F59F-5160
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04499
Shop #: WSC 00672
VCID: 6597B079EC7BEF2F59F-51F2
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AC
Component: A4 Klimaautomat 1323
Coding: 00100
Shop #: WSC 00672
VCID: 629DAB65FD559817BCD-5160
49-00 - No Communications
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 00672
VCID: 353720391C5B5FAF29F-4B00
57-00 - Electric Circuit Failure
01502 - Bulb for Rear Fog; Left (L46)
79-00 - Please Check Fault Codes
Address 15: Airbags Labels: 8H0-959-655-84.lbl
Part No: 8H0 959 655 B
Component: Airbag 8.4EC 2015
Coding: 0010105
Shop #: WSC 00672 785 00200
VCID: 392F2C093543BBCFCD7-5184
01218 - Side Airbag Igniter; Passenger Side (N200)
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 02041
Shop #: WSC 00672
VCID: 3E253F15296D9CF7F85-4B00
01304 - Radio
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8H0 920 950 HX
Component: KOMBI+WEGFAHRS. NJA D22
Coding: 00231
Shop #: WSC 03738
VCID: 094F9CC920236B4F9D7-5160
WAUAT48H74K015115 AUZ6Z0C0421820
17 Faults Found:
00771 - Fuel Level Sensor (G)
30-00 - Open or Short to Plus
01128 - Immobilizer Pickup Coil (D2)
35-00 - -
00830 - Convertible Top Control Module (J256)
01304 - Radio
Address 26: Auto Roof Labels: 8H0-959-255.lbl
Part No: 8H0 959 255
Component: VSG B6 CABRIO 6286
VCID: 73B3DE2157AF019FC7B-5160
Part No: 8H0 959 760
Component: Sitzmemory EE H05 X014
Coding: 00002
Shop #: WSC 00065
VCID: 74B1DD3D579106A7DE1-4B1E
02010 - Left Entry Assistance Control Module (J572)
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8H0 959 433 C
Component: Komfortgerát T7B 1412
Coding: 11788
Shop #: WSC 00672
VCID: 34311D3D172146A71E1-4B00
Subsystem 1 - Part No: 8H1959801
Component: Tõrsteuer.FS BRM 0001
Subsystem 2 - Part No: 8H1959802
Component: Tõrsteuer.BF BRM 0001
Subsystem 3 - Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 0001
Subsystem 4 - Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 0001
Address 63: Entry Assist,D Labels: None
Part No: 8H0 959 760 A
Component: EasyEntry F M H12 X024
Coding: 00006
Shop #: WSC 00065
VCID: 353720391C6B5FAF29F-4B1E
Address 73: Entry Assist, P Labels: None
Component: EasyEntry BF H12 X024
Coding: 00005
Shop #: WSC 00065
End----------(Elapsed Time: 05:55, VBatt start/end: 12.0V/12.0V)-----------
