2004 Audi A4 Cabriolet 3.0 no Dash illumination No AC No convertible top op
   #21
wthompso81
GA, USA
C?ID=371607
Received Instrument cluster and ECU. I installed both. Hooked battery. Attempted to start. IC displays proper mileage, then goes to SAFE. Tried unsuccessfully with all three keys to start. Immobilizer appears to prevent. Also, all of the original issues with the original cluster are back. No HVAC, No convertible roof operation or light in the IC, no turn signal indicators in the dash, no dash lighting. Not sure about what to do from your statement from an earlier post " 0x17-10- gateway settings need to be reestablished upon installation or power down!"
Any ideas?
Posted below is a scan
	Friday,19,July,2019,11:26:54:41616
VIN: WAUAT48H74K015115   License Plate:
Mileage: 115910km-72023mi   Repair Order: 0719
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
          63 65 67 73 75 76 77
VIN: WAUAT48H74K015115   Mileage: 115910km-72023miles
Address 01: Engine        Labels: 06C-909-559-ASN.lbl
   Part No SW: 8E0 909 559 L    HW: 8E0 909 059
   Component: 3.0L V6/5V      G   0020
   Coding: 0016584
   Shop #: WSC 03738 444 38140
   VCID: 3E253F152C6D9CF7F85-5160
18043 - Powertrain Data Bus
            P1635 - 008 - Missing Message from A/C Controller
18107 - Powertrain Data Bus
            P1699 - 008 - Missing Message from Steering Wheel Electronics
18010 - Power Supply Terminal 30
17978 - Engine Start Blocked by Immobilizer
            P1570 - 008 -
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 8E2 910 156     HW: 01J 927 156 JK
   Component: V30 01J 3.0l 5V USA 3261
   Revision: 00000008    Serial number: 00000002100924
   Coding: 0000001
   Shop #: WSC 04940 001 00001
   VCID: 6597B079E97BEF2F59F-5160
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517
   Component: ABS/ESP front       3429
   Coding: 04499
   Shop #: WSC 00672
   VCID: 6597B079EC7BEF2F59F-51F2
            35-00 - -
   Part No: 8E0 820 043 AC
   Component:   A4 Klimaautomat   1323
   Coding: 00100
   Shop #: WSC 00672
   VCID: 629DAB65FD559817BCD-5160
            49-00 - No Communications
            27-00 - Implausible Signal
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  USA 0517
   Coding: 01013
   Shop #: WSC 00672
   VCID: 353720391C5B5FAF29F-4B00
            57-00 - Electric Circuit Failure
01502 - Bulb for Rear Fog; Left (L46)
            79-00 - Please Check Fault Codes
Address 15: Airbags        Labels: 8H0-959-655-84.lbl
   Part No: 8H0 959 655 B
   Component: Airbag 8.4EC        2015
   Coding: 0010105
   Shop #: WSC 00672 785 00200
   VCID: 392F2C093543BBCFCD7-5184
01218 - Side Airbag Igniter; Passenger Side (N200)
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0611
   Coding: 02041
   Shop #: WSC 00672
   VCID: 3E253F15296D9CF7F85-4B00
01304 - Radio
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8H0 920 950 HX
   Component: KOMBI+WEGFAHRS. NJA D22
   Coding: 00231
   Shop #: WSC 03738
   VCID: 094F9CC920236B4F9D7-5160
   WAUAT48H74K015115     AUZ6Z0C0421820
17 Faults Found:
00771 - Fuel Level Sensor (G)
            30-00 - Open or Short to Plus
01128 - Immobilizer Pickup Coil (D2)
            35-00 - -
00830 - Convertible Top Control Module (J256)
01304 - Radio
Address 26: Auto Roof        Labels: 8H0-959-255.lbl
   Part No: 8H0 959 255
   Component:  VSG  B6 CABRIO     6286
   VCID: 73B3DE2157AF019FC7B-5160
   Part No: 8H0 959 760
   Component: Sitzmemory EE H05   X014
   Coding: 00002
   Shop #: WSC 00065
   VCID: 74B1DD3D579106A7DE1-4B1E
02010 - Left Entry Assistance Control Module (J572)
   Part No: 8H0 959 433 C
   Component: Komfortgerát T7B    1412
   Coding: 11788
   Shop #: WSC 00672
   VCID: 34311D3D172146A71E1-4B00
   Subsystem 1 - Part No: 8H1959801
   Component: Tõrsteuer.FS BRM 0001
   Subsystem 2 - Part No: 8H1959802
   Component: Tõrsteuer.BF BRM 0001
   Subsystem 3 - Part No: 8H0959801A
   Component: Tõrsteuer.HL BRM 0001
   Subsystem 4 - Part No: 8H0959802A
   Component: Tõrsteuer.HR BRM 0001
Address 63: Entry Assist,D        Labels: None
   Part No: 8H0 959 760 A
   Component: EasyEntry F M H12   X024
   Coding: 00006
   Shop #: WSC 00065
   VCID: 353720391C6B5FAF29F-4B1E
Address 73: Entry Assist, P        Labels: None
   Component: EasyEntry BF  H12   X024
   Coding: 00005
   Shop #: WSC 00065
End----------(Elapsed Time: 05:55, VBatt start/end: 12.0V/12.0V)-----------
   #22
NostraJackAss
Let's start with clearing all faults codes in each module and see what DTC's in scan reappear, then lets count out and set the adaption as described in captions for gateway list in cluster & also do an adaptation in the HVAC to the immobilizer.
NostraJackAss
Okay as per phone call follow up here are links in wiki to these tasks too.
MAIN ROUTE OF 8H
http://wiki.ross-tech.com/wiki/index.php/Audi_A4/S4/RS4/Cabriolet_(8E/8H)
HVAC
http://wiki.ross-tech.com/wiki/index.php/Audi_A4_(8E)_Heating/Air_Conditioning#Adaptation
Coding
  • 00?xx: Chassis
    • 0 = Sedan/Avant
    • 1 = Cabrio
  • 00x?x: Heated Windshield
    • 0 = Heated Windshield not installed
    • 1 = Heated Windshield installed
  • 00xx?: Sunroof
    • 0 = No Sunroof OR Normal Sunroof
    • 1 = Sunroof with Solar Cells
Adaptation
Channel 081: Vehicle Data Learning
To start the process for vehicle data (VIN) learning, enter/save 26467 as new value.
GATEWAY
http://wiki.ross-tech.com/wiki/index.php/Audi_A4_(8E)_Instrument_Cluster_(8EC/8ED/8HE)#Adaptation
Channel 060: CAN-Databus Powertrain (Installation List)
  • +00001 = Engine (Standard)
  • +00002 = Automatic Transmission (Optional)
  • +00004 = Brake (Standard)
  • +00016 = Airbag (Standard)
  • +01024 = Instrument Cluster (Standard)
Channel 061: CAN-Databus Comfort (Installation List)
  • +00001 = Central Electronics (Standard)
  • +00002 = Comfort System (Standard)
  • +00064 = Trailer (Optional)
  • +00128 = Convertible Top (Optional)
  • +00256 = Instrument Cluster (Standard)
  • +00512 = Tire Pressure Control (Optional)
  • +01024 = Steering Column Electronics (Standard)
  • +02048 = Climate Control (Standard)
  • +32768 = Auxiliary Heating (Optional)
Channel 062: CAN-Databus Infotainment (Installation List)
  • +00001 = Radio (Optional)
  • +00002 = Telephone (Optional)
  • +00004 = Navigation (Optional)
  • +00008 = Telematics (Optional)
  • +00016 = Intrument Cluster (Standard - only coded with 2nd Component)
Channel 099: Transport Mode
  • 0 = inactive
  • 1 = active
   #24
wthompso81
GA, USA
C?ID=371607
Ran auto scan
Cleared codes
Turned off key for a couple of minutes
Tried to start
no luck
Ran auto scan
Friday,19,July,2019,13:53:12:41616
Mileage: 115910km-72023mi   Repair Order: 07192
   Coding: 0016584
            P1570 - 008 -
   Coding: 0000001
   Coding: 04499
   Shop #: WSC 00672
            35-00 - -
   Coding: 00100
   Shop #: WSC 00672
   VCID: 629DAB65FD559817BCD-513C
   Coding: 01013
   Shop #: WSC 00672
   Coding: 0010105
   Coding: 02041
   Shop #: WSC 00672
01304 - Radio
   Coding: 00231
   Shop #: WSC 03738
17 Faults Found:
            35-00 - -
01304 - Radio
02000 - Switch Position
   Coding: 00002
   Shop #: WSC 00065
   Coding: 11788
   Shop #: WSC 00672
00955 - Key 1
            35-10 - - - Intermittent
   Coding: 00006
   Shop #: WSC 00065
   Coding: 00005
   Shop #: WSC 00065
End----------(Elapsed Time: 05:45, VBatt start/end: 12.1V/12.0V)-----------
Cleared codes
Disconnected both terminals of battery for 15 min
Reconnected and tried to start
no luck
Ran auto scan
Friday,19,July,2019,14:44:01:41616
Mileage: 115910km-72023mi   Repair Order: 07193
   Coding: 0016584
            P1570 - 008 -
   Coding: 0000001
   Coding: 04499
   Shop #: WSC 00672
            35-00 - -
   Coding: 00100
   Shop #: WSC 00672
   Coding: 01013
   Shop #: WSC 00672
   Coding: 0010105
   Coding: 02041
   Shop #: WSC 00672
01304 - Radio
   Coding: 00231
   Shop #: WSC 03738
18 Faults Found:
            35-00 - -
01176 - Key
            65-10 - Unauthorized - Intermittent
01304 - Radio
   Coding: 00002
   Shop #: WSC 00065
   Coding: 11788
   Shop #: WSC 00672
00955 - Key 1
   Coding: 00006
   Shop #: WSC 00065
   Coding: 00005
   Shop #: WSC 00065
End----------(Elapsed Time: 05:46, VBatt start/end: 12.1V/12.1V)-----------
Tried to code HVAC Coding looked correct
adaptation on 081 showed Bus not ok in top left box entered 26467 in new value. Hit test showed error in the bottom box. grayed out save button Error message went away before i could capture.
Turned off key for a couple of minutes then tried to start.
no luck
Tried adding values in instrument cluster adaptation which all added to the proper amount. didnt change any but saved
turned off key for a couple of minutes
Tried to start.
no luck
Ran auto scan
Friday,19,July,2019,15:11:25:41616
Mileage: 115910km-72023mi   Repair Order: 07194
   Coding: 0016584
            P1570 - 008 -
   Coding: 0000001
   Coding: 04499
   Shop #: WSC 00672
            35-00 - -
   Coding: 00100
   Shop #: WSC 00672
   Coding: 01013
   Shop #: WSC 00672
   Coding: 0010105
   Coding: 02041
   Shop #: WSC 00672
01304 - Radio
   Coding: 00231
   Shop #: WSC 03738
18 Faults Found:
            35-00 - -
01176 - Key
01304 - Radio
   Coding: 11788
   Shop #: WSC 00672
00955 - Key 1
   Coding: 00006
   Shop #: WSC 00065
   Coding: 00005
   Shop #: WSC 00065
End----------(Elapsed Time: 05:43, VBatt start/end: 12.1V/12.1V)-----------
not sure if I did something wrong
Getting tired, will have to work on it another day
Maybe hvac module has an issue.
   #25
NostraJackAss
I'm thinking something on the twisted CAN pair is bad in car or there is a blown fuse or loose ground.
This stuff all talked and qualified on bench and so does old cluster I double checked today, just out of curiosity.
An immo defeat would indeed wake the engine up and so it can at least be moved until addressed.
I will do this for free if you like, just freight & I'm happy to hold your hand through the CAN bus testing.
NostraJackAss
After doing the aforementioned.
Please lets isolate & start with unplugging all modules on CAN & other than ( engine, trans, cluster )
Been here below and watch the videos too in AC it's crazy hot today?
https://forums.ross-tech.com/showth...you-should-have-a-baseline-understanding-of-!
This code bothers me & look for water ingress.....it is a convertible!
wthompso81
GA, USA
C?ID=371607
Thanks for the offer Jack. I will probably take you up on that but I want to pull the aftermarket radio and HVAC module early next week to see if any issues are behind that radio. The radio has been in there for 3 years with no problem but who knows. Thanks again. I will keep you updated. Sorry to be such a pain. Was this car before can bus and is it a single line or pair. Maybe a stupid question.
Hope you have a great weekend
   #28
NostraJackAss
This car is K line and CAN internal W with a twisted high/low.....
It's not a dumb question because it shows me you have not RTFB the WD and that is what's dumb! :p
Codes in your scans show interference for top communications in both and maybe not in cluster initially because it wasn't saved in sleep mode yet.
   #29
NostraJackAss
Wayne
Hope you are feeling better, please let me know when you are ready to tackle the WD of the CAN on this car.
wthompso81
GA, USA
C?ID=371607
Jack
Thanks for checking in. Had a tough weekend. Chemo again today. Enjoyed the treats.
Yesterday did a little. Pulled after market radio, hvac module, disconnected complete rear tail light assembly to isolate electric circuit failure. Still had electric circuit failure on left rear bulbs. Took trunk lid apart. That is the only slight amount of water ingress that I have seen on the car. Cleaned and reinstalled ground wires. I am thinking that Central Electric module under the dash could possibly be the culprit. I will try to get that unplugged later in the week to see if can reestablish communication.. I will touch base when I am able to move forward.
   #32
NostraJackAss
I just ground and perked that coffee you sent Wayne.
Real smooth man good stuff!
Hope you are feeling better!
   #33
wthompso81
GA, USA
C?ID=371607
Jack Glad you enjoyed the coffee. Thanks for your good wishes. Hoping to feel better this week. Have to get daughter back to school this week. Not sure how much I can get to the car this week. Back to chemo next week.
I was curious if my old cluster would still work with the original keys or if your mating of the keys to the new cluster eliminated that option. Sending the old cluster back if it will still bring the car to life short term might be easier than sending the ecu back for immobilizer delete. Just a thought. Have not given up on getting this problem figured out.
Still need to go over the info you sent last week to start more testing on the car.
Thanks for your help
Wayne
   #34
NostraJackAss
Sending the old cluster is not possible for two reasons.
No dual identities unless a strip is done.
The problem is not cluster related it seems to me and CAN related in wiring or other faulty component.
   #35
wthompso81
GA, USA
C?ID=371607
Hi Jack
Got a little time and energy this morning.
Hvac module and radio disconnected and laying in the floor.
I pulled the panel below the steering wheel and disconnected the light colored plug on the central electric module. cleared codes then tried adaptation on instrument cluster 060,061,062. turned off key for a few minutes. tried to start.
Same issues
Then disconnected all plugs from central electric module. auto scanned. Cleared codes. tried adaptation to instrument cluster 060,061,062. This seemed to take several other modules offline. turned off key and left for a few minutes. still no luck
Steering wheel module was still showing up so pulled that fuse. It eliminated from the scan but was not sure where to unplug module without pulling steering wheel.
Ran autoscan cleared codes, tried adaptation on instrument cluster 060,061,062 turned off key for a few minutes. Tried to start. No luck
Ran Auto scan
Below is last autoscan.
 Wednesday,31,July,2019,12:51:09:41616
Mileage: 115910km-72023mi   Repair Order: 07314
   Coding: 0016584
18036 - Powertrain Data Bus
            P1628 - 008 - Missing Message from Steering Angle Sensor
            P1570 - 008 -
   Coding: 0000001
   Coding: 04499
   Shop #: WSC 00672
            P1628 - 35-00 - Missing Message from Steering Angle Sensor
   Coding: 0010105
   Coding: 00231
   Shop #: WSC 03738
14 Faults Found:
            35-00 - -
01304 - Radio
   Coding: 00002
   Shop #: WSC 00065
   Coding: 00006
   Shop #: WSC 00065
   Coding: 00005
   Shop #: WSC 00065
End----------(Elapsed Time: 06:24, VBatt start/end: 12.4V/12.4V)-----------
Does this give us any idea for next steps?
Can I eliminate entry assist modules from the bus if I pull those fuses or do I need to pull door panels to unplug? That was what I did with the steering module.
   #36
NostraJackAss
I would pull cluster since it contains the gateway and I would separate the twisted pairs at harness and remove the CAN connections observing the WD and take pictures and count pins to be exact.
I would only leave power-train to CAN on cluster hooked up, than I'd clear codes and see if it wakes up.
If not while systems are separated physically, I'd than start unplugging steering, ABS, than TCU and Air bag until it fires.
If it still wouldn't fire I'd run an overlay twisted pair from cluster to Engine ECU and sort each twisted pair one by one.
Something is taking down the CAN and it must be isolated for short or faulty termination.
Most importantly........ you must make sure that power, switched power terminal 15 and ground are correct to the cluster!
   #37
wthompso81
GA, USA
C?ID=371607
Woo hoo
Small success
Disconnected cluster then just decided to plug back in before moving on tried to start and it came to life.
Weird but happy, at least can move the car around.
Ran auto scan and cleared
currently
hvac out
radio out
central electric all 3 plugs unplugged
steering module fuse removed
Started and did autoscan while running
 Wednesday,31,July,2019,15:26:29:41616
Mileage: 115910km-72023mi   Repair Order: 0731running
   Coding: 0016584
            P1570 - 008 -  - Intermittent
16955 - Brake Switch (F)
            P0571 - 008 - Implausible Signal
   Coding: 0000001
17087 - Brake Switch (F)
            P0703 - 000 - Electrical Malfunction
                    RPM: 96 /min
                    (no units): 1.0
                    Torque: 262.0 Nm
                    Temperature: 28.0°C
                    T.B. Angle: 0.0°
                    Bin. Bits: 0101 0 1
   Coding: 04499
   Shop #: WSC 00672
   Coding: 0010105
   Coding: 00231
   Shop #: WSC 03738
15 Faults Found:
01304 - Radio
   Coding: 00002
   Shop #: WSC 00065
   VCID: 74B1DD3D579106A7DE1-4B3C
   Coding: 00006
   Shop #: WSC 00065
   VCID: 353720391C6B5FAF29F-4B3C
   Coding: 00005
   Shop #: WSC 00065
End----------(Elapsed Time: 06:23, VBatt start/end: 13.9V/13.9V)-----------
Not sure of next steps
I'm wondering which modules to begin to plug in first to see what I get back
   #38
NostraJackAss
Woo hoo
Small success
currently
hvac out
radio out
Yay! :p
Now here is where you should check the pins at the cluster connectors for corrosion and consider the Stabilant 22A
http://www.stabilant.com/sizes.html
   #39
wthompso81
GA, USA
C?ID=371607
Thanks Jack
Ordered some stabilant 22a and crc electronics cleaner. Should be here Friday. Will clean and treat all plugs as I put it back together. At this point, I want to give everything the best option for good connections
Thanks so much! Will keep you updated.:)
   #40
wthompso81
GA, USA
C?ID=371607
Jack
Thanks so much for your continued help!
Received the stabilant 22a
Dabbed on all of the connections, put it back together
All worked after resetting the roof.
Still have a few little issues but all the systems are talking
Need to replace coolant sensor. already have it.
Plastic coil connectors on a few cylinders need to be replaced.
Still a little bulb issue on the left side. will have to figure that one out
Also need to do airbag plug bypass on passenger seat.
Small problems after the major ones
autoscan and dtc clear below
Friday,02,August,2019,17:06:48:41616
Mileage: 115920km-72029mi   Repair Order: 08023
VIN: WAUAT48H74K015115   Mileage: 115920km-72029miles
   Coding: 0016584
16684 - Random/Multiple Cylinder Misfire Detected
            P0300 - 008 -
16685 - Cylinder 1
            P0301 - 008 - Misfire Detected
16688 - Cylinder 4
            P0304 - 008 - Misfire Detected
16687 - Cylinder 3
            P0303 - 008 - Misfire Detected
16686 - Cylinder 2
            P0302 - 008 - Misfire Detected
16502 - Engine Coolant Temp. Sensor (G62)
            P0118 - 002 - Signal too High - Intermittent
Readiness: 0010 1101
   Coding: 0000001
   Coding: 04499
   Shop #: WSC 00672
   Coding: 00100
   Shop #: WSC 00672
   Coding: 01013
   Shop #: WSC 00672
   Coding: 0010105
   Coding: 02041
   Shop #: WSC 00672
01304 - Radio
   Coding: 00231
   Shop #: WSC 03738
01304 - Radio
   Coding: 00002
   Shop #: WSC 00065
   Coding: 11788
   Shop #: WSC 00672
00955 - Key 1
   Coding: 00006
   Shop #: WSC 00065
   Coding: 00005
   Shop #: WSC 00065
End----------(Elapsed Time: 06:02, VBatt start/end: 12.2V/12.5V)-----------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 25: DTCs cleared
Address 26: DTCs cleared
Address 36: DTCs cleared
Address 46: DTCs cleared
Address 63: DTCs cleared
Address 73: DTCs cleared
   Coding: 0016584
   Coding: 0000001
   Coding: 04499
   Shop #: WSC 00672
   Coding: 00100
   Shop #: WSC 00672
   Coding: 01013
   Shop #: WSC 00672
   Coding: 0010105
   Coding: 02041
   Shop #: WSC 00672
   Coding: 00231
   Shop #: WSC 03738
   Coding: 00002
   Shop #: WSC 00065
   Coding: 11788
   Shop #: WSC 00672
   Coding: 00006
   Shop #: WSC 00065
   Coding: 00005
   Shop #: WSC 00065
End----------(Elapsed Time: 06:33, VBatt start/end: 12.5V/12.5V)-----------
Thanks again for your patience
Wayne
