Passat 3C lost ABS and EPB coding
totaltuning
C?ID=255206
Passat 3C, other shop fitted new EPB without making a note of the old codings, they have tried some other codings without luck. Attached autoscan, if someone has coding I can try it's much appreciated!
VIN: WVWZZZ3CZ8E054331   License Plate:
Mileage: 252690km-157014mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ8E054331   Mileage: 252690km-157014miles
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 AS    HW: 03G 906 018 AS
   Component: R4 2.0l PPD1.2      9971
   Revision: --H42---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 00591 210 83198
   VCID: 76E3B117019C3DFAF7-8022
               P1653 - 008 -  - Intermittent
                    Mileage: 252676 km
                    Time: 14:26:58
                    Torque: 144.0 Nm
                        0.00 %
                    Voltage: 12.32 V
                    Bin. Bits: 00000100
                    Torque: 1016.0 Nm
Readiness: N/A
   Part No SW: 3C0 614 109 C    HW: 3C0 614 109 C
   Component: J104    C4 440 V1   0003
   Revision: --020---    Serial number: 00000775843338
   Coding: 0000282
   Shop #: WSC 05311 000 00000
   VCID: 1E3389B7C9ECD5BACF-804A
            000 -  -
                    Fault Priority: 9
                    Reset counter: 45
                    Mileage: 252690 km
                    Time: 09:19:05
                    Hex Value: 0x0000
                    Voltage: 14.25 V
                    Bin. Bits: 00011110
                    Count: 228
            000 -  -
                    Reset counter: 45
                    Mileage: 252690 km
                    Time: 09:19:05
                    Hex Value: 0x0000
                    Voltage: 14.25 V
                    Bin. Bits: 00011110
                    Count: 149
                    Reset counter: 45
                    Mileage: 252690 km
                    Time: 09:19:05
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 BT    HW: 3C0 907 044 BT
   Component: ClimatronicPQ46 122 0707
   Revision: 00122021    Serial number: 00000000000000
   VCID: 74E78B1F17E02FEAC9-8020
                    Fault Status: 00111110
                    Fault Frequency: 9
                    Reset counter: 85
                    Mileage: 252676 km
                    Time: 13:32:23
   Revision: 00H54000    Serial number: 01000007353195
   Coding: E1800F0700041A00470A00000F00000000085D435C000100000000000000
   Shop #: WSC 05124 000 00000
   VCID: 71E9820B68F21AC222-8024
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 190707 022  0601
   Coding: 00046997
   Shop #: WSC 05124
   Component: RLS     180707 046  0204
   Coding: 00208933
   Shop #: WSC 05124
   Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
   Component: 0C AIRBAG VW8   032 2522
   Revision: 12032000    Serial number: 003B1PEBRGYD
   Coding: 0012355
   VCID: 306F470FA37853CA6D-8064
   Subsystem 1 - Serial number: 6332MSME18636956
   Subsystem 2 - Serial number: 6342MSME1C0D485E
   Subsystem 3 - Serial number: 6351HTS618LCSMK6
   Subsystem 4 - Serial number: 6361HTS618LCM5N6
   Part No SW: 3C0 953 549 J    HW: 3C0 953 549 J
   Component: Lenksäulenmodul 006 0010
   Revision: 00006000    Serial number: 3C5953507BC
   Coding: 0000003
   VCID: 33654803526E68D210-8066
   Part No SW: 3C0 920 960 N    HW: 3C0 920 960 N
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007405
   Shop #: WSC 00591 067 57207
   VCID: 2E535977B94C453A7F-807A
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P077180947
   Coding: F9807F060002021003
   VCID: 2345B843E28EF852E0-8076
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Shop #: WSC 00488 210 01865
   VCID: 39797A2B70029282DA-806C
   Component: J386  TUER-SG FT    1132
   Revision: 32008001    Serial number: 00000513678801
   Coding: 0000693
   VCID: 3B7560237A3EA092C8-806E
                    Fault Status: 00100101
                    Reset counter: 85
                    Mileage: 252676 km
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   Shop #: WSC 00591 210 71797
   VCID: 36637117411C7DFA37-8062
02546 - Steering Limit Stop
                    Mileage: 252680 km
                    Temperature: 28.0°C
                    Voltage: 12.30 V
                    Voltage: 12.10 V
   Component:    KSG PQ46 ELV 042 0472
   Coding: 01910A0001860E763004941570085FCE107CA0
   Component: LIN BACKUP HORN H07 9001
   Component: Neigungssensor  004 0611
   Component: J387  TUER-SG BT    1132
   Revision: 32008001    Serial number: 00000028378717
   Coding: 0000692
   VCID: 3C77633F7F30A7AAC1-8068
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H21       Serial number: 00000000156805
   Coding: 0021156
   VCID: 387F7F2F4B088B8A25-806C
03194 - Incompatible Interface
            000 -  -
                    Reset counter: 45
                    Mileage: 252690 km
                    Voltage: 14.00 V
                    Count: 95
                    Hex Value: 0x1263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
            000 -  -
                    Fault Status: 01110000
                    Reset counter: 45
                    Voltage: 13.90 V
                    Count: 41
                    Hex Value: 0x0140
                    Hex Value: 0x0082
                    Hex Value: 0x4040
   Part No: 1K0 035 186 AD
   Component: Radio GR0       033 0033
   Revision: 0003303S    Serial number: VWZ2Z2G2133720
   Coding: 0040400
   Shop #: WSC 05314 000 00000
   VCID: 68DFEF6F5B28DB0A75-803C
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1118
   Revision: 11006001    Serial number: 00000002091642
   Coding: 0000144
   VCID: 3D716E3B642AAEA2F6-8068
                    Fault Status: 01101000
                    Reset counter: 45
                    Mileage: 252690 km
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1118
   Revision: 11006001    Serial number: 00000002080438
   Coding: 0000144
   VCID: 3E736937692CB5BAEF-806A
DrPeter
16.4905° S, 151.7375° W
Based on the information you have provided and the VIN, the [03-ABS Brakes] (J104) coding should be as follows:
Coding: [0001306]
Follow the Basic Setting procedure found on the Ross-Tech wiki page linked below for the G85-Steering Angle Sensor.
http://wiki.ross-tech.com/wiki/index.php/VW_Tiguan_(5N)_Brake_Electronics
Also you will need to perform the Function Test in the [53-Parking Brake]
If you have any faults left or other concerns, post up a new Auto-Scan so we can see what is going on, thanks.
Hope this helps,
drp
Jef
HQ
Vehicle Identification No. WVWZZZ3CZ8E054331
Model passat sedan
PA
Date of production 24.08.2007
Model year 2008
Sales type 3C2272
Engine Code BMR
Transmission Code KDS
As per the VIN info, I come up with the same values, ABS coding of 0001306 and EPB coding of 0021156... but you can also try for the EPB coding 0021056.
Just to verify, the ABS module is still the factory installed original unit?
totaltuning
C?ID=255206
Thanks guys, all sorted now, ABS coding 0001306 was correct. I had to change the EPB coding to 0021056 as Jef suggested (with the 0021156 coding I still had the dtc 03194 - Incompatible Interface and the yellow P lamp lit on the dash). Cheers again!
DrPeter
Cool,
Did you try activating the EPB button on/off/on/off, switch the ignition off, lock the vehicle and wait about 5 minutes... Then start the vehicle and recheck for codes..
Also make sure you switch ignition off for about 45 seconds after any EPB coding changes.
Let us know if this helps,
drpeter
