Parking Brake Problems
Gmickey
C?ID=354933
Hello All,
My daughter's Passat was having some intermittent parking brake problems about a year ago. It seemed power related and a new battery made the problem go away.
The problem is back now, my daughter is convinced that it is hot weather related (only happens when it's really hot out and the car has been in the direct sun). That seems unlikely to me. Yesterday it would not disengage, I hooked up my battery charger thinking it was power related and put the unit in 10A boost mode. The brake still would not disengage. Autoscan below:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 53 56 62
          65 72
VIN: WVWAK93C26P03XXXX   Mileage: 212830km-132246miles
   Part No SW: 3C0 907 115 F    HW: 3C0 907 115 G
   Revision: --H10---    Serial number: VWZCZ000000000
   Coding: 0404010A19070160
   Shop #: WSC 22595 444 53395
   VCID: 2313EDC877DF5E1FF73-8076
   Part No SW: 09G 927 750 CJ    HW: 09G 927 750 CJ
   Component: AQ 250 6F           0736
   Revision: 00H38000    Serial number:
   Coding: 0000072
   Shop #: WSC 00028 028 00001
   VCID: 7BA3F5A8AFEFC6DF9F3-802E
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 N    HW: 3C0 614 095 N
   Component: ESP 440 C2     H015 0001
   Revision:  H015       Serial number: 0657810824
   Coding: 0013755
   Shop #: WSC 22595 444 85712
   VCID: 2D070BF0211B986F517-8078
   Part No: 1K0 820 047 DK
   Component: Climatic PQ35   090 0505
   VCID: 70B9D284F6A9B5873A1-8024
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000003366421
   Coding: 148C0F0340041A00000A00000F00000000285D435C
   VCID: 2B0305E81F0F965F4F3-807E
   Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00065493
   Shop #: WSC 00028
                    Fault Status: 00111100
                    Fault Frequency: 17
                    Reset counter: 104
                    Mileage: 205792 km
                    Date: 2019.02.27
                    Time: 07:51:00
                    Voltage: 12.50 V
                    Fault Status: 01111100
                    Fault Frequency: 182
                    Reset counter: 73
                    Mileage: 201826 km
                    Date: 2018.12.16
                    Time: 17:23:00
                    Voltage: 14.15 V
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0080
   Revision: 00000000    Serial number: AUZ4Z7E4026668
                    Fault Frequency: 39
                    Reset counter: 106
                    Mileage: 187340 km
                    Date: 2017.11.04
                    Time: 10:53:04
01304 - Radio
                    Fault Status: 01101000
                    Reset counter: 143
                    Mileage: 192757 km
                    Date: 2018.06.14
                    Time: 00:01:06
   Part No SW: 3C0 909 605 G    HW: 3C0 909 605 G
   Component: 0B AIRBAG VW8R  029 2421
   Revision: 09029000    Serial number: 0039VSDEQ1KG
   Coding: 0012354
   VCID: 2A0D00EC10F58F57B45-807E
   Subsystem 1 - Part No: 3C0 959 339
   Component: BF-Gewichtsens. 006 0001
   Subsystem 2 - Serial number: 000000000333NT
   Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME0B0A24716ÿ†63
   Subsystem 5 - Serial number: A24716ÿ†6342MSME0B1217251ÿ†63
   Subsystem 6 - Serial number: 217251ÿ†6351HTS604FIP2N2Cÿ†63
   Subsystem 7 - Serial number: IP2N2Cÿ†6361HTS604FMA9M28ÿ†63
   Subsystem 8 - Serial number: MA9M28ÿ†63727TS604F6S6P22ÿ†63
   Subsystem 9 - Serial number: 6S6P22ÿ†63827TS604F6KOQ2Eÿ
   Subsystem 10 - Serial number: 6KOQ2Eÿ
   Part No SW: 3C0 953 549 H    HW: 3C0 953 549 H
   Component: J0527               0015
   Revision: 00005000    Serial number: 3C5953507R
   Coding: 0002013
   VCID: 313F17803D23FC8F75F-8064
   Part No SW: 3C0 920 970 H    HW: 3C0 920 970 H
   Component: KOMBIINSTRUMENT VD1 3938
   Revision: X0032000    Serial number: 00000000000000
   Coding: 0007205
   Shop #: WSC 22116 067 57207
   VCID: 290FFFE015F3844FBDF-807C
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C056170198
   Coding: 3FFD0E14D31002
   VCID: 211FE7C06DC34C0FE5F-8074
01304 - Radio
                    Reset counter: 143
                    Mileage: 192757 km
                    Date: 2018.06.14
                    Time: 00:00:05
   Part No SW: 3C0 919 965     HW: 3C0 919 965
   Component: Kompass         005 0002
   Revision: 00002000    Serial number: 1166279TN62P04
   VCID: 6D87CBF0E19B586F117-8038
   Part No SW: 3C0 959 433 Q    HW: 3C0 959 433 Q
   Component:    IMMO         051 0383
   Revision: 00051000    Serial number: VWZCZ000000000
   Shop #: WSC 27776 002 1048576
   VCID: 38292AA4DE592DC7321-806C
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2359
   Coding: 0001205
   VCID: 3635249CD44DDBB720D-8062
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.12      1502
   VCID: 303912843629F5877A1-8064
00573 - Steering Torque Sensor (G269)
   Component:    KSG PQ46 RDK 051 0218
   Coding: 1B910F8801862E521804151FF00A0F0E081800
                    Reset counter: 102
                    Mileage: 212395 km
                    Date: 2019.06.13
                    Time: 17:07:33
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 3C0 035 456 A    HW: 3C0 035 456 A
   Component: DSP 10 Kanal        0008
   Revision: 00008000    Serial number: 00000000003842
   VCID: 1E65DC3C5CBD73F7D8D-804A
                    Reset counter: 101
                    Mileage: 172582 km
                    Date: 2016.12.15
                    Time: 19:19:06
                    Reset counter: 73
                    Mileage: 173721 km
                    Date: 2017.01.07
                    Time: 20:08:58
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 73
                    Mileage: 174402 km
                    Date: 2017.01.20
                    Time: 08:11:43
                    Fault Status: 00101011
                    Fault Frequency: 202
                    Reset counter: 112
                    Mileage: 179414 km
                    Date: 2017.03.21
                    Time: 19:02:04
   Part No: 1K0 959 702 K
   Coding: 0001204
   VCID: 372B2998D34722BF3BB-8062
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Revision:   013
   Coding: 0000013
02443 - Control Head
                    Fault Status: 00111000
                    Reset counter: 112
                    Mileage: 212584 km
                    Date: 2019.06.18
                    Time: 18:22:26
                    Voltage: 13.66 V
                    Count: 46
Address 56: Radio
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2417
   Coding: 0000144
   Component:    RDK              0420
   Coding: 0100100
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 323D188C3825C7970C5-8066
00935 - Electric Window Motor; Rear Right (V27)
End----(Elapsed Time: 01:33, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
Fredrick Awuor
Kenya
C?ID=309834
Hello All,
I think button for parking brake faulty,so common on Passat 3C....worth checking wiring from /to it.....,check here as well.... http://wiki.ross-tech.com/wiki/index.php/02443
Agreed. That "control head" is the combination switch/light for the parking brake.
