Hi I'm trying to access the the security part on body control module but the built in security codes don't seem to work.I'm trying to access auto rain closing but need to use the adaption and put the security code in but don't seem to work.I've had a quick google and apparently this is a common problem with this module.
Please find enclosed my auto scan.
Saturday,22,June,2019,17:19:58:05033
VCDS Version: 19.6.0.6 (x64) HEX-V2 CB: 0.4505.4
Saturday,22,June,2019,17:17:55:05033
VIN: WVGZZZ5NZGW812109 License Plate: MD16LYU
Mileage: 24895km-15469mi Repair Order: 3
Chassis Type: 5N-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 42 44 52 55
5F 6C 6D 82 A5 BB BC CA D6 D7
VIN: WVGZZZ5NZGW812109 Mileage: 24895km-15469miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFGA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 EH HW: 04L 907 309 M
Component: R4 2.0l TDI H23 2950
Revision: B4H23---
Coding: 0125003203671D083000
ASAM Dataset: EV_ECM20TDI01104L906026EH 004002
ROD: EV_ECM20TDI01104L906026EF_004.rod
VCID: 74B1DD4B1E3A1537DED-8020
Part No SW: 0DL 300 011 A HW: 0DE 927 711
Component: GSG DQ500 H12 1406
Revision: 00H12V32
VCID: 2615F703986637A7909-8072
Part No SW: 5Q0 614 517 BH HW: 5Q0 614 517 AD
Component: ESC H25 0507
Revision: 00000000 Serial number: 60956000001281
Coding: 0AEE929A34210B6E4778670062CC4950492CD0E2E646927D38625078C22A02
VCID: 78A9E97B02527157F25-802C
Part No SW: 3Q0 959 435 C HW: 3Q0 959 435 C
Component: VWKESSYMQB 036 0710
Revision: 00036000 Serial number: 0401705353
Coding: 030C0C0F03
VCID: 3A2D33737CDEA347C41-806E
Subsystem 1 - Part No SW: 3G0 962 243 A HW: 3G0 962 243 A
Component: GEB.F.Heckoef H17 0903
Serial number: 98025967
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 5NC 907 044 HW: 5NC 907 044
Component: AC Automat H34 3902
Revision: 20K07000 Serial number: 00000B00101934
Coding: 00120124202110011105100C0010110A
ASAM Dataset: EV_ACClimaPrehVW37X 002013
ROD: EV_ACClimaPrehVW37X.rod
VCID: 7EA5FF6320764F67B89-802A
Subsystem 1 - Part No SW: 3G0 907 049 E HW: 3G0 907 049 E
Component: E265KlimaHeck H02 0201
263425 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Reset counter: 204
Mileage: 24862 km
Date: 2019.06.22
Time: 09:15:50
Outside air temperature: 17.0 °C
Voltage terminal 30: 14.4 V
System run time-Engine running time: 253 s
Air quality status: ERROR
Part No SW: 5Q0 937 084 BQ HW: 5Q0 937 084 BQ
Component: BCM MQBAB H H32 0212
Serial number: 00021611100453
Coding: 03D11E46C24112FB17844094B11C172C1880000000000000000000000000
ASAM Dataset: EV_BCMMQB 016001
ROD: EV_BCMBOSCH_016_VW37.rod
VCID: 084999BB72B201D7825-805C
Subsystem 1 - Part No SW: 5NC 955 119 HW: 5NC 955 119 Labels: 1KX-955-119.CLB
Component: 326 RL 160319 033 0372
Serial number: 00000001603160302585
Component: RLHS 037 0059
Serial number: S4Y16M04D28H11M25S16
Coding: 00A8DD
Serial number: 000000000ZY1608213BL
Serial number: 00000000000065695698
204546 - Remote key 2
B147A 18 [009] - Current Too Low
Reset counter: 163
Mileage: 24845 km
Date: 2019.06.21
Time: 14:46:18
262912 - Sensor for Anti-Theft Alarm System
B1330 F5 [008] - Alert Emergency Activation Stage 1
Reset counter: 204
Mileage: 24845 km
Date: 2019.06.21
Time: 14:46:18
Part No SW: 3Q0 919 298 HW: 3Q0 919 298
Component: PLA 3.0 12K H09 0152
Serial number: 002004167478070
Coding: 0331263851
ASAM Dataset: EV_EPHBO2CVW3260000 010015
ROD: EV_EPHBO2CVW3260000.rod
VCID: 7AADF3733C5E6347841-802E
Part No SW: 2Q0 907 572 H HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0155
Coding: 320147C358FF8728749C806D304085
ASAM Dataset: EV_ACCMRRCONTIVW376 001010
ROD: EV_ACCMRRCONTIVW376_001.rod
VCID: 392F2C7F79D8A85FCDB-806C
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR2HR82%
Coding: 98CCC0C00C0000005C5400CF008800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 1079B1DB0AE249175A5-8044
Belt Pretensioner left:
Serial number: 5NC857705C0113Q01277
Coding: 80000D
Belt Pretensioner right:
Serial number: 5NC857706C0112Q00388
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 002 004 16
Serial number: 357000000002F25C9A1S
Subsystem 4 - Part No SW: ----------- HW: 480 002 304 16
Serial number: 358000000008F7BCBA15
Subsystem 5 - Part No SW: ----------- HW: 480 402 004 16
Serial number: 3510001B9209F101055P
Subsystem 6 - Part No SW: ----------- HW: 480 402 004 16
Serial number: 3520001B9209F105344V
Subsystem 7 - Part No SW: ----------- HW: 480 402 004 16
Serial number: 3550001C520A94F4232$
Pedestrian Protection Driver:
Subsystem 8 - Part No SW: ----------- HW: 480 402 504 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001B72080C23B85$
Subsystem 9 - Part No SW: ----------- HW: 480 402 504 16
Component: PedP_Sensor_P 000 6149
Serial number: 2290001BB2080C21D5D6
Pedestrian Protection Center:
Subsystem 10 - Part No SW: ----------- HW: 480 402 504 16
Component: PedP_Sensor_C 000 6149
Serial number: 2300001BB2080C21939V
Subsystem 11 - Part No SW: ----------- HW: 480 001 104 16
Serial number: I0M00000000A80348A1+
Subsystem 12 - Part No SW: ----------- HW: 480 001 104 16
Serial number: I0N00000000633F06A1%
Part No SW: 3Q0 953 521 AN HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0205
Revision: FF034034 Serial number: 20160413501553
Coding: 0C10
ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 7CA1F56B366A5D7796D-8028
Part No SW: 5NA 920 791 HW: 5NA 920 791
Component: KOMBI 119 1443
Coding: 27A40018EF84260001886B031401000000000000
VCID: 55F780CFF5806C3FC93-8000
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 F
Component: GW MQB High 128 1244
Revision: -------- Serial number: 0004784583
Coding: 030500041F087300FB03225E1E0F00010001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 79AFEC7F3958685F8DB-802C
Subsystem 2 - Part No SW: 5TA 959 442 B HW: 5TA 959 442 B Labels: 3C8-959-537.CLB
Serial number: 0981609395901168AP2B
Coding: 2F0000
Subsystem 3 - Part No SW: 5QA 915 181 B HW: 5QA 915 181 B
Component: J367-BDMHella H10 9052
Serial number: 8278749903
Serial number: HA1-00009.03.16
Coding: 0101
VCID: 4ACD63B32C3E33C7541-801E
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH05 0012
VCID: 45D7508F0520DCBFB93-8010
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000078756014
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BFD45F6128201F35B-8024
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Component: TSG FS 020 0041
Serial number: 220316ECJ10115
Coding: 003F1A20D001048000001000
VCID: 43D34E970B14E28F977-8016
Component: EPS_MQB_ZFLS 128 1072
Coding: 9307
ROD: EV_SteerAssisMQB_013.rod
Component: TSG BFS 020 0041
Serial number: 020416ED130411
Coding: 003F1020DE01048000001000
VCID: 42DD4B93140EEB879C1-8016
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0051
Coding: 08AE00104B210201
ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
VCID: 41DF449F1108F09F85B-8014
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 020 C HW: 3G0 035 020
Component: MU-H-ND-EU H50 0343
Serial number: A682D0GB020222
Coding: 02730601FF00000051111101008808001F0100E6012000009F
VCID: 176BCAC72F0C9E2F1BF-8042
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL00Q1Y
Subsystem 2 - Part No SW: V03 959 800 QT HW: -----------
Component: ECE 2018/2019 --- 0169
Compact Disc Database:
Component: Gracenote2 --- 1012
Part No SW: 5Q0 907 556 A HW: 5Q0 907 556
Component: Areaview 2 H11 0422
Serial number: C854706JG015035
Coding: 01230601A20F200000204014
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 005013
ROD: EV_CamSysRVAV2ARCE2MQBAB_005_VW37.rod
VCID: 372B2A474FCCBE2F3BF-8062
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30636838400000
Coding: 0A08
ASAM Dataset: EV_DeckLidCONTIAU736 001012
VCID: 3FDB426767FC866FF3F-806A
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 5NA 919 608 A HW: 5NA 919 608 A
Component: HeadupDisplay 015 0207
Coding: 574060
ASAM Dataset: EV_HeadUpDisplContiVW481 001013
ROD: EV_HeadUpDisplContiVW481.rod
VCID: 46D557833826D7A7B09-8012
Part No SW: 3Q0 980 654 F HW: 3Q0 980 654
Component: MQB_B_MFK H06 0220
Serial number: 19041611P22768
Coding: 000307060000040100022344C050A10094000E200040
Component: TSG HFS 020 0041
Serial number: 110316EC90271C
Coding: 002A10200100048000001000
Component: TSG HBFS 020 0041
Serial number: 100316EC90233C
Part No SW: 4M0 907 594 D HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Coding: 308040732602
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 1675C7C32806A727009-8042
Component: LED1R H09 0003
ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 02:08, VBatt start/end: 12.2V/12.2V)-----------
