ABS Fault 00285
betterimp
C?ID=370791
I'm new to the forum, and to VCDS, so there is a lot I don't know. I appreciate any help I can get with this diagnosis. It appears that there are several issues with my car. I've included 2 scans here. The first one is immediately after clearing the codes, the second one is before clearing the codes.
My main concern right now is the ABS/Slip light that is activated.
With the scans I did today, I see a new error about communication with the ABS Brake Module. I did not see that on my previous scan a few days ago.
I purchased a new ABS sensor for the front right wheel, and replaced it last week, but it did not clear the error. I also attempted to measure voltage at the sensor while I moved the wheel to see if the sensor was working, but that test came back negative. Not sure I was able to get a good connection to the sensor, so inconclusive right now. It doesn't make sense that a brand new sensor would be bad.
I visually inspected the wire and the connector, and no obvious damage.
What would be a good way to test the harness? Does anyone have a diagram of the connector to show where to test the sensor wires for continuity? How do I determine if sensor, harness, abs module are good or bad?
fyi-measure blocks show measurement for the other 3 wheels. Nothing for the right front.
Excerpt from full scan:
049441 - No Communication with ABS Brake Control Module
               U0121 - 008 -  - Intermittent
                    Mileage: 251679 km
                    Temperature: 29.0°C
                    Temperature: -40.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.192 V
   Part No: 1K0 907 379 P
   Coding: 0017025
   Shop #: WSC 01279 785 00200
   VCID: 3FDB42265B75F50FF3B-806A
Saturday,22,June,2019,09:47:22:33951
VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
VIN: WVWAA71K38W240338   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 65
VIN: WVWAA71K38W240338   Mileage: 252350km-156803miles
Address 01: Engine (CBT)       Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 BK    HW: 07K 906 032 Q
   Component: 2,5l R5/4V      G   1568
   Revision: 1NH01---    Serial number: VWX7Z0H03NL95V
   Coding: 0000001
   VCID: 73B3DE1627BD616FC73-8026
006481 - Radiator Fan 2 (V177)
               P1951 - 002 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 9
                    Mileage: 251659 km
                    Time: 06:30:15
                    RPM: 1312 /min
                    Load: 36.1 %
                    Speed: 10.0 km/h
                    Temperature: 90.0°C
                    Temperature: 34.0°C
                    Voltage: 13.970 V
001152 - Coolant Fan Control Circuit 1
               P0480 - 004 - Electrical Malfunction - Intermittent
                    Mileage: 251659 km
                    Time: 06:30:29
                    RPM: 2174 /min
                    Load: 17.2 %
                    Speed: 83.0 km/h
                    Temperature: 85.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.097 V
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 002 - Signal too High - Intermittent
                    Mileage: 251679 km
                    Time: 02:20:30
                    Temperature: 27.0°C
                    Voltage: 12.319 V
000258 - Mass Air Flow Sensor (G70)
               P0102 - 002 - Signal too Low - Intermittent
                    Mileage: 251679 km
                    Time: 02:20:49
                    RPM: 184 /min
                    Load: 78.4 %
                    Temperature: 27.0°C
                    Voltage: 10.795 V
                    Mileage: 251679 km
                    Temperature: 29.0°C
                    Voltage: 12.192 V
   Coding: 0017025
   Part No SW: 1K0 820 047 HJ    HW: 1K0 820 047 HJ
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   Revision: 00H54000    Serial number: 00000007947775
   Coding: 108D8F214004150047140000001400000008730B5C000100000000000000
   Shop #: WSC 09460 444 53328
   VCID: 71BFD41E5DA1537F35F-8024
   Component: Wischer 180108 021  0501
   Coding: 00038805
   Shop #: WSC 09460
                    Fault Status: 00101100
                    Reset counter: 127
                    Mileage: 251664 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.40 V
   Component: 6K AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0ADA2P
   Coding: 0013899
   Shop #: WSC 01269 785 00200
   VCID: 6C81C56A7A83BE97069-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME3802486BD
   Subsystem 3 - Serial number: 6342MSME327361330
   Subsystem 4 - Serial number: 6352QSME4C77273DW
   Subsystem 5 - Serial number: 6362QSME45334E01C
   Subsystem 6 - Serial number: 63727SME12764F465
   Subsystem 7 - Serial number: 63827SME12765619+
   Part No SW: 1K0 953 549 BN    HW: 1K0 953 549 BN
   Component: J0527           051 0100
   Coding: 0000042
   VCID: 7F5B02261BF5350FB3B-802A
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1K0 920 974 J    HW: 1K0 920 974 J
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0H03NL95V
   Coding: 0007203
   Shop #: WSC 00000 067 57207
   VCID: 3537200E69493F5F297-8060
                    Reset counter: 120
                    Mileage: 251679 km
                    Time: 02:30:07
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K081230695
   Coding: E9801F070002020000
   VCID: 3039111A962B1A777A1-8064
                    Reset counter: 120
                    Mileage: 251679 km
                    Time: 02:30:07
   Component: IMMO            VDD 1216
   Component: Tuer-SG         006 1207
   Coding: 0001077
   VCID: 3829293A7E5BC237321-806C
00105 - Signal Central Locking SAVE/LOCK Drivers Side
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.135 H08 1901
   Shop #: WSC 00028 028 00001
00625 - Vehicle Speed Signal
                    Mileage: 251660 km
                    Temperature: 23.0°C
                    Voltage: 12.10 V
                    Voltage: 11.90 V
   Coding: 139006885103281B0904058FB0080A04889C00
   Shop #: WSC 00000 785 00200
   VCID: 04518DCA721356D7EE9-8050
   Coding: 0001076
   VCID: 392F2C3E4551DB3FCDF-806C
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 C    HW: 1K0 035 161 C
   Component: Radio DE2       015 0019
   Revision: 00015000    Serial number: VWZ4Z7G6309362
   Coding: 0040402
   VCID: 1F1BE2A6FBB5950FD3B-804A
   Coding: 0100101
                    Fault Status: 00111000
                    Reset counter: 120
                    Mileage: 251679 km
                    Time: 02:30:08
End----------(Elapsed Time: 00:59, VBatt start/end: 12.1V/12.1V)-----------
Been here?
http://wiki.ross-tech.com/wiki/index.php/00285
PS: That fault is not "P00285". "P" codes are SAE/ISO standardized Powertain faults. This is a VAG specific/proprietary 00285 fault. On newer cars, there might be a "C" code equivalent (C being chassis). I've fixed the thread tile.
NostraJackAss
Hello and welcome to the VCDS forum OP
Verify wiring from sensor to ABS module using DVOM and test overlay using WD by RTFB.
Load test the circuits.
Check charging system and battery or change due to being weak.
JPPSG
betterimp
C?ID=370791
plug diagram?
JPPSG
I was able to find the electrical drawings on erwin, but I don't see plug detail.
I need more info for inexperienced person.
NostraJackAss
Okay great OP.
See the T26 designation?
That's the plug at ABS module known as AKA J104 or in VCDS as hex address word 0x03
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl ( J104 )
Fault Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45) <<<<<<<<<<<<<<<<<< See that in WD G45 that's the sensor
Don't worry about the D186 or 187 & commence a check with DVOM and load light to ABS connector T26a PIN 5 & 6 and should correlate to PIN's 1 & 2 at ABS G45 sensor, understand?
betterimp
C?ID=370791
Okay great OP.
I see...pin 5 and pin 6...duh. I should have figured that out.
I want to check continuity from pin 5 to #1 and pin 6 to #2, right?
NostraJackAss
Yeah it's only two wires ya dope :p
Not just continuity,,,,,,nein! because one stand of copper can make a tone and not carry the current needed for the controller to read the voltage of wheel speed, that is why load light!
Meet MR. 123 LOAD LIGHT's in this 2 min video....
betterimp
C?ID=370791
I was expecting a diagram of the plug to know which pins to check....got it now.
Thank you for the information about how to load test the wire. I need that.
I will check it out next opportunity. Thanks.
