Status: Malfunction 0010 but No fault code found.
B5NUT
C?ID=30047
So scanned my car today and found a couple of faults, one of which is more than confusing! My gateway says the 5F module has a fault but when I check for a fault code there is none :confused:
Anyone had this before, is it a VCDS bug?
Thursday,20,June,2019,17:54:52:07337
VCDS Version: 19.6.0.6 (x64)  HEX-NET CB: 0.4505.4
VIN: WAUZZZ4G2HN000000  License Plate: A6-MMI
Mileage:  Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 28 36 3B 42 44 46 52 53
          55 5F 62 6C 6D 72 AC
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 BP    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 1661
   Revision: 85H23---
   Coding: 12254012242601080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021BP 002006
   ROD: EV_ECM20TDI01104L906021BP_002.rod
   VCID: 74A407EADFA786EF81-8020
   Part No SW: 4G0 927 166 N    HW: 0B5 927 156 K
   Component: 0B5 20 TDIRdW H03 0004
   Revision: --H03---
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001022
   ROD: EV_TCMDL501021.rod
   VCID: 383CF3DA834F228F6D-806C
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 06A69E41606579829B00
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 41CA9E3ED0956347DA-8014
   Part No SW: 4H0 907 064 HP    HW: 4H0 907 064 HP
   Component: BCM2 2.0      H61 0825
   Coding: 05B96F4E000000000000
   VCID: 7EB025C2E9EBDCBFE7-802A
   Serial number: 3216000167335007
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 05091600040372
   Coding: 34220978290000
   VCID: 638674B66A491157E8-8036
   Part No SW: 4H0 907 063 GG    HW: 4H0 907 063 AG
   Component: BCM1 2.0      H20 0368
   Revision: 14020001    Serial number: 00001457652402
   Coding: 0105001440349FE041014083A0001800CF9DC7082F08020100000894E100150200400010010000
   VCID: 73A604F6D2A981D798-8026
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 160622  H38 0080
   Serial number:         160701112852
   Coding: 0045F7
   Serial number: 62226079
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 31 08 2016  00000886
   Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: 26E8C54800PAG0MUFU03
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4G0 919 475 H    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0080
   Revision: --------    Serial number: 56261624900270
   Coding: B81318
   ASAM Dataset: EV_EPHVA2CAU64X0000 001014
   ROD: EV_EPHVA2CAU64X0000.rod
   VCID: 3620FDE2895BD4FF7F-8062
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P100B3TC+
   Coding: 30333130313630323639554A305234473053
   VCID: 3B36ECD6B279099780-806E
   Serial number: 3575HRB405F45CG8H11Y
   Serial number: 3585HRB405P45HVK68F1
   Serial number: 3515JRB401I5752G998Q
   Serial number: 3525JRB400U5752ICIAB
   Serial number: 3554VRB4002577407P7P
   Serial number: 3564VRB400457740B1JK
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 91560PGR00033
   Coding: 000035
   VCID: 3B36ECD6BA79099780-806E
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 26 04 2016  E0084281
   Part No SW: 4G8 920 987 R    HW: 4G8 920 987 R
   Component: TDieGb        H14 0225
   Revision: 11001108    Serial number: 658290816596010
   Coding: 33A715000B412600010000
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K_AU57.rod
   VCID: 48DC831AF3AF520F1D-801C
   Part No SW: 4G8 907 468 H    HW: 4G8 907 468
   Revision: --------    Serial number: 00000002360987
   Coding: C0CD074418
   VCID: 3D32E2CEAC6D07A7BE-8068
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 9454011404
   Voltage stabilizer:
   Serial number: 160622000000000003CE
12290 - Quiescent Current
          U1406 00 [009] - Too High
                    Reset counter: 232
                    Mileage: 00000 km
                    Date: 2019.06.13
                    Time: 00:24:15
                    Voltage terminal 30: 12.2 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 14 °C
                    System status: LIN_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 679E60A696717D7734-8032
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 06091600041014
   Coding: 22
   Revision: AA000000    Serial number: 00000216304628
   Coding: 00781B0000006001000001010101102030303232203232
   VCID: 77BE30E6C6D1EDF7A4-8022
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720SUMWT
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3326C4F69A29C1D758-8066
   Component: TSG FA        H03 0511
   Coding: 011F16015E01620002080002
   VCID: 47DE8026F6B15D7714-8012
   Component: RCevo         H54 0202
   Revision: 00000001    Serial number: 0000226657
   Coding: 101100010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A38E9D2BD43309F9B-806E
   Revision: 00002001    Serial number: 0416506173
   Coding: 013B0E22A0B93095C320098400030F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 B
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS20.403  H03 0004
   Serial number: 0000FST0015FLKQ00000
   Coding: 901E00
   Subsystem 4 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
   Serial number: 0000000AP00024350976
   Subsystem 5 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS20.403  H03 0004
   Serial number: 0000FST0015FLMS00000
   Coding: 801E00
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93892967
03128 - Switch 1 for Sunroof
                    Fault Status: 00101100
                    Reset counter: 8
                    Mileage: 00000 km
                    Date: 2019.06.03
                    Time: 13:30:02
00204 - Sunroof Button (E325)
                    Reset counter: 8
                    Mileage: 31706 km
                    Date: 2019.06.03
                    Time: 13:30:02
   Component: TSG BF        H03 0511
   VCID: 46C08D22F1BB447FEF-8012
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001954846
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 312ACEFE6035F3C72A-8064
   Coding: 04FE02102A630200
   VCID: 3424C7EA9F27C6EF41-8060
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 021 F    HW: 4G1 035 021 D
   Component: MU-H-LND-EU   052 0670
   Serial number: A733I0G7510518
   Coding: 017502010000000013111102000A00332F0006E7F1700100DF
   VCID: 1D72024E0CAD67A79E-8048
   Subsystem 1 - Part No SW: V03 959 802 DE    HW: -----------
   Component: ECE 2019  --- 0175
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9GY805ZLB
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349PI2000R3
   Compact Disc Database:
   Component: Gracenote2---  --- 1013
   Component: TSG HL        H03 0511
   Coding: 010F14004001620002080002
   VCID: 49DA861EE0A5AB0702-801C
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0140
   Coding: 0275000102002003000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
   ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
   VCID: 78BC33DAC3CFE28FAD-802C
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number: 231600041
   Coding: 093205C030
   ROD: EV_HDSGAu571.rod
   Component: TSG HR        H03 0511
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 162170756
   ROD: EV_RDCMA00100_008.rod
   VCID: 2F2EC8867601E5373C-807A
End----(Elapsed Time: 02:10, VBatt start/end: 11.7V/11.9V. VIgn 12.0V)-----
Nah, not a VCDS bug. The Gateway reports a status for each control module when VCDS pulls the Installation List from the Gateway. VCDS then queries each module individually. Sometimes the Gateway and an individual module get out of synch.
Try clearing faults directly in 5F, despite the fact that there aren't any, and see if that gets rid of the (apparently bogus) "malfunction" flag in the Gateway.
B5NUT
C?ID=30047
Well cleared all the fault codes but the one of the 5F refuses to clear on the gateway:confused::confused:
O well it's not causing any problems, and it's going into the dealer next week for an aircon service so will get them to take a look as it's under warranty.
Thursday,20,June,2019,22:51:47:07337
VIN: WAUZZZ4G2HN00000   License Plate: A6-MMI2
VIN: WAUZZZ4G2HN00000   Mileage:
   Revision: 85H23---
   Revision: --H03---
   Coding: 100001
   Coding: 0045F7
   Coding: 02006D
   Coding: B81318
   Coding: 000035
   Coding: C0CD074418
   Voltage stabilizer:
   Revision: AA001002
   Coding: 22
   ROD: EV_SARA2.rod
   Coding: 901E00
   Coding: 801E00
   Coding: E01E00
   Coding: E01E00
   Coding: 093205C030
End----------(Elapsed Time: 02:11, VBatt start/end: 12.1V/12.1V)-----------
How exactly did you clear the fault codes?
B5NUT
C?ID=30047
When into each module and cleared the codes.
Try "Clear all DTCs" on the Auto-Scan screen next, and make sure Use CAN command is checked.
You may need to click the [Gateway Installation List] button before you can do that.
B5NUT
C?ID=30047
Just to update this thread, first attempt a "Clear all DTCs" made no difference, however the second attempt cleared the fault on the gateway.
Thanks for your help with this Uwe.
Sometimes you have to hit the mule with a 2x4 more than once before you get its attention! :D
