Codare abs audi a3 8p
bebeadi
New Member
Romania
Buna ziua,
O problemă cu abs ,apare eroarea 16352 modul comanda defect electric ,014 defect intermitent.
A fost codat dar imi apar beculetele de la esp, volan si rana si piuie în bord din cand in cand,nu apar tot timpul.
Pe tester imi apare această eroare.
iichel
Netherlands, eastern part
C?ID=284912
Hi and welcome. Could you please (attempt to) write in English?
And if you want to get proper help from us, and I'm sure many of us are very willing to, could you please post an autoscan? See below on how to do so. Thanks!
bebeadi
New Member
Romania
Ok, modul abs was coding but apare the eror cod 16352-the modul electric defect.
What can i do?
We DO need to see an Auto-Scan of your car to be able to help :thumbs:
bebeadi
New Member
Romania
I don't have , but the mechanic sayd 16352 is the eror and must to replace the modul abs(1k0907379AD),audi a3 8p 2009 BXE.
My VIN is
WAUZZZ8P19BO11400
TTler
C?ID=361767
The 8P from 08-10 got a Problem with the ABS Modul. AUDI send them back to the Dealer and put new Software on the Modul due to Overheat. However The only Thing you can do check the ABS Sensors at the Wheels and in VCDS . Also Check the Wiring from the Sensors. Sometimes they Fails. When you dont find any other Failures on these Items I explained change the ABS Module.
bebeadi
New Member
Romania
Only i need is the login cod for the car , the long coding i have the old .I want to replace the abs esp unit.
