VW Scricco ABS Pump Code lost (MK60EC1)
VAGMAN
C?ID=374246
Hi,
My nephew has recently purchased a 2009 VW Scricco from an auction site, the car runs and drives however it had the ABS, Tracation control and brake light displayed and beeping along with other items. We wanted to resolve the ABS pump issue first for obvious reasons and then work through the other items.
I did some online research and it seems the ABS pumps on these vehicles are prone to fail, we sent the unit off to be repaired however it turns out it that it's beyond repair so we purchased a second hand unit with the same part numbers.
The mechanic said that the original ABS pump does not have a code and therefore he cannot code the second hand unit. I've got the following scan from the car when the original ABS pump was connected and it does show the code to be missing. The car is currently with the mechanic.
Is there anyway of getting the ABS pump coding given where we are with it? let me know if you any other information is required and I'll try to provide that.
thanks in advance!
Friday,10,May,2019,18:32:18:25558
VCDS Version: 18.9.1.0 (x64)
VIN: WVWZZZ13Z9V015910   License Plate:
Mileage: 157570km-97909mi   Repair Order: VW scirroco
Chassis Type: 13 (1K0)
Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 42 44 46 52 56
VIN: WVWZZZ13Z9V015910   Mileage: 157570km-97909miles
Address 01: Engine (CBD)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 KD    HW: 03L 906 022 G
   Component: R4 2.0l TDI 0000SG  9979
   Revision: 13H01---    Serial number: VWX7Z0H93NM1BO
   Coding: 0001072
   Shop #: WSC 55776 001 1048576
   VCID: 71EF931B68CACCC222-8024
008598 - Oxygen (Lambda) Sensor B1 S1
               P2196 - 000 - Signal too High (Rich) - MIL ON
                    Fault Status: 11100000
                    Mileage: 154672 km
                    Time: 17:24:23
                    RPM: 2185 /min
                    Speed: 129.0 km/h
                    Lambda: 51.3 %
                    Mass Air / Rev.: 580.0 mg/str
                    Voltage: 0.375 V
                    (no units): 16.0
                    Voltage: 0.975 V
Readiness: 1 1 0 0 0
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Revision: 00H35001
   Coding: 000000000000000000000000000000000000
   VCID: 76E5A007C1A4EBFAF7-8022
            000 -  -
                    Reset counter: 130
                    Count: 4608
                    Count: 195
                    Count: 43008
   Part No SW: 1K0 820 047 JD    HW: 1K0 820 047 JD
   Component: Climatic PQ35   143 1313
   Revision: 00143033    Serial number: 00000000000000
   VCID: 6FEB95637EFEDA3234-803A
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000008403739
   Coding: EC880F0300041A0067960E001900000000087B075C400124000000000000
   Shop #: WSC 00020 790 00000
   VCID: 326D5C17AD4CB7DA1B-8066
   Subsystem 1 - Part No: 1K8 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 180808 022  0602
   Coding: 00038805
   Shop #: WSC 00020
   Component: RLS     291008 054  0402
   Coding: 00209133
   Shop #: WSC 00020
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475 F    HW: 1K0 919 475 F
   Component: PARKHILFE     005 1506
   Revision: 00005000    Serial number: 0 263 004 300
   Coding: 100001
   VCID: 3567670B9C22A0E23E-8060
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376     HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0069
   Revision: 00000000    Serial number: 16100802910001
   Coding: 000180
   VCID: 66C5F04791041B7A47-8032
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 130
                    Mileage: 157571 km
                    Time: 18:34:25
                    Bin. Bits: 00000000 00001000
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0H AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D00EWZP
   Coding: 0012360
   Subsystem 1 - Serial number: 6332MSME413147584
   Subsystem 2 - Serial number: 6342MSME40304B04+
   Subsystem 3 - Serial number: 6352QSME46104B0EH
   Subsystem 4 - Serial number: 6362QSME46102B3CH
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000004
   VCID: 0303C9D34276CE52C0-8056
   Part No SW: 1K8 920 960 E    HW: 1K8 920 960 E
   Component: KOMBIINSTRUMENT VDD 1244
   Revision: V0003000    Serial number: VWX7Z0H93NM1BO
   Coding: 0003403
   VCID: 336359135256BED210-8066
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533__Gateway   H-- 0210
   Revision:   H--       Serial number: 3400K08A2303B2
   Coding: E9A81F06000212004001
   VCID: 377B6D03462E52F22C-8062
   Component: IMMO            VDD 1244
   Revision: A1001003    Serial number: 7661137131
   Coding: 020000
   Shop #: WSC 00040 040 00001
   VCID: 295FBB7B409AF402AA-807C
            000 -  -
                    Reset counter: 130
                    Mileage: 157571 km
                    Time: 18:37:34
   Part No SW: 1Q0 959 701 F    HW: 1Q0 959 701 F
   Component: Tuer-SG         008 2022
   Coding: 0016949
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 175    2301
   Revision: 00H15000
   VCID: 2A5D4477859CFF1AA3-807E
   Component:    KSG PQ35 G2  020 0205
   Coding: 81900A0002830C7F3F04840570085ACE903CA0
   Component: LIN BACKUP HORN H08 9001
   Subsystem 2 - Part No: 1K8 951 171
   Component: DWA-Sensor      001 0104
   Part No SW: 1Q0 959 702 F    HW: 1Q0 959 702 F
   Coding: 0016948
   VCID: 38796E3F4B305D8A25-806C
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3H3374556
   Coding: 0100040004
   VCID: 65C7F74B6C0210624E-8030
End-------------------------(Elapsed Time: 01:42)--------------------------
OP is now verified. Moving to Car Repair Support.
NostraJackAss
Vehicle Identification No.WVWZZZ13Z9V015910
ModelScirocco 2.0
SCI
Date of production07.11.2008
Model year2009
Sales type13726L
Engine CodeCBDB
Transmission CodeKRM
Part No SW: 03L 906 022 KD HW: 03L 906 022 G <<<<<<<<<<<<<<<<<<<<<<<<<<<< FOD CHECK PASS!
Coding: 0001072
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD <<<<<<<<<<<<<<<<<<<<<<<<< FOD CHECK PASS!
Revision: 00H35001
Coding: 763B00F5092300FF6E1400E5901900000000 VIN STRIP RHD
Coding: 763BC0F5092300FF6E1403E5901900813000 RHD TRY THIS
Welcome OP please try the green and report back .........
[TABLE="class: vinInfoTable, width: 534"]
[TR]
[TH="align: left"]Special editions[/TH]
[TD="class: prCode"]E0A[/TD]
[TD]Without special action equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Lockable wheel bolts[/TH]
[TD="class: prCode"]1PE[/TD]
[TD]Wheel bolts with anti-theft protection
(unlockable)[/TD]
[/TR]
[TR]
[TH="align: left"]Vehicle class differentiation
units/platform components[/TH]
[TD="class: prCode"]7KB[/TD]
[TD]Vehicle class differentiation -130-[/TD]
[/TR]
[TR]
[TH="align: left"]drive-off assistance[/TH]
[TD="class: prCode"]UG0[/TD]
[TD]Without hill start assist/hill descent
control/comfort driving assist[/TD]
[/TR]
[TR]
[TH="align: left"]Emission standard[/TH]
[TD="class: prCode"]7MG[/TD]
[TD]Emission standard EU5[/TD]
[/TR]
[TR]
[TH="align: left"]Trailer hitch[/TH]
[TD="class: prCode"]1D0[/TD]
[TD]without trailer towing[/TD]
[/TR]
[TR]
[TH="align: left"]airbag[/TH]
[TD="class: prCode"]4UF[/TD]
[TD]Airbag for driver and front passenger
with front passenger airbag
deactivation[/TD]
[/TR]
[TR]
[TH="align: left"]Aktivkohlebehälter / Ottopartikelfilter[/TH]
[TD="class: prCode"]1E0[/TD]
[TD]Without activated charcoal canister[/TD]
[/TR]
[TR]
[TH="align: left"]Aerials[/TH]
[TD="class: prCode"]8ZH[/TD]
[TD]Antenna for AM/FM reception, "diversity"[/TD]
[/TR]
[TR]
[TH="align: left"]Exterior mirror setting[/TH]
[TD="class: prCode"]6XN[/TD]
[TD]Exterior mirrors, power-adjustable/
separately heated[/TD]
[/TR]
[TR]
[TH="align: left"]Left exterior mirror[/TH]
[TD="class: prCode"]5SJ[/TD]
[TD]Left exterior mirror, convex[/TD]
[/TR]
[TR]
[TH="align: left"]Right exterior mirror[/TH]
[TD="class: prCode"]5RV[/TD]
[TD]Right exterior mirror, aspherical[/TD]
[/TR]
[TR]
[TH="align: left"]Drive type[/TH]
[TD="class: prCode"]1X0[/TD]
[TD]Front-wheel drive[/TD]
[/TR]
[TR]
[TH="align: left"]"Multimedia"video/DVD/notebook connection[/TH]
[TD="class: prCode"]9WL[/TD]
[TD]Jack for external audio source[/TD]
[/TR]
[TR]
[TH="align: left"]Equipment levels[/TH]
[TD="class: prCode"]A8F[/TD]
[TD]Sports equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Brake type in rear[/TH]
[TD="class: prCode"]1KD[/TD]
[TD]Disc brakes in rear[/TD]
[/TR]
[TR]
[TH="align: left"]batteries[/TH]
[TD="class: prCode"]J0N[/TD]
[TD]Battery 330 A (61 Ah)[/TD]
[/TR]
[TR]
[TH="align: left"]Brake type, front[/TH]
[TD="class: prCode"]1ZE[/TD]
[TD]Disc brakes in front (Geomet D)[/TD]
[/TR]
[TR]
[TH="align: left"]Battery/alternator capacity[/TH]
[TD="class: prCode"]NY0[/TD]
[TD]Standard battery/alternator capacity[/TD]
[/TR]
[TR]
[TH="align: left"]Component part sets with
country-specific design requirements[/TH]
[TD="class: prCode"]B0N[/TD]
[TD]Component parts set, complying with
vehicle type for Great Britain, various
parts[/TD]
[/TR]
[TR]
[TH="align: left"]vehicle tools and jack[/TH]
[TD="class: prCode"]1S1[/TD]
[TD]vehicle tools and jack[/TD]
[/TR]
[TR]
[TH="align: left"]Brake systems[/TH]
[TD="class: prCode"]1AT[/TD]
[TD]Electronic stability control (ESC)[/TD]
[/TR]
[TR]
[TH="align: left"]Owner's manuals[/TH]
[TD="class: prCode"]0VF[/TD]
[TD]Information kit in English[/TD]
[/TR]
[TR]
[TH="align: left"]brake wear indicator[/TH]
[TD="class: prCode"]9U1[/TD]
[TD]brake wear indicator[/TD]
[/TR]
[TR]
[TH="align: left"]Heated washer nozzles[/TH]
[TD="class: prCode"]9T0[/TD]
[TD]Without heated washer nozzles[/TD]
[/TR]
[TR]
[TH="align: left"]CD ROM/DVD/SD card[/TH]
[TD="class: prCode"]7QA[/TD]
[TD]Without CD/DVD for navigation[/TD]
[/TR]
[TR]
[TH="align: left"]CD changer/CD player[/TH]
[TD="class: prCode"]7A0[/TD]
[TD]Without CD changer/CD player[/TD]
[/TR]
[TR]
[TH="align: left"]"Charism"[/TH]
[TD="class: prCode"]2H1[/TD]
[TD]"drive select"[/TD]
[/TR]
[TR]
[TH="align: left"]General operating permit, alterations[/TH]
[TD="class: prCode"]C03[/TD]
[TD]Operating permit, alteration[/TD]
[/TR]
[TR]
[TH="align: left"]Roof insert/convertible top[/TH]
[TD="class: prCode"]3FA[/TD]
[TD]roof without cut out[/TD]
[/TR]
[TR]
[TH="align: left"]Suspension system in rear[/TH]
[TD="class: prCode"]UB7[/TD]
[TD]Rear shock absorption for sports version[/TD]
[/TR]
[TR]
[TH="align: left"]Suspension system in front[/TH]
[TD="class: prCode"]G03[/TD]
[TD]Shock absorption in front[/TD]
[/TR]
[TR]
[TH="align: left"]Insert for the filling up of unleaded
fuel/fuel type[/TH]
[TD="class: prCode"]2G5[/TD]
[TD]Filler neck module 1 without insert[/TD]
[/TR]
[TR]
[TH="align: left"]Installation differentiation for components[/TH]
[TD="class: prCode"]0EN[/TD]
[TD]Installation differentiation for
transmission MQ 350
-- vehicle components --[/TD]
[/TR]
[TR]
[TH="align: left"]Theft protection system[/TH]
[TD="class: prCode"]7AL[/TD]
[TD]Anti-theft alarm system, interior
monitoring, backup horn and towing
protection[/TD]
[/TR]
[TR]
[TH="align: left"]Park distance control[/TH]
[TD="class: prCode"]7X1[/TD]
[TD]Park distance control[/TD]
[/TR]
[TR]
[TH="align: left"]Electric interface for external use[/TH]
[TD="class: prCode"]UF6[/TD]
[TD]Electric interface for external use
(MEDIA-IN jack)[/TD]
[/TR]
[TR]
[TH="align: left"]Manufacturing sequence differentiation[/TH]
[TD="class: prCode"]0FA[/TD]
[TD]Standard manufacturing sequence[/TD]
[/TR]
[TR]
[TH="align: left"]window regulator[/TH]
[TD="class: prCode"]4R4[/TD]
[TD]Power windows with comfort operation and
circuit breaker[/TD]
[/TR]
[TR]
[TH="align: left"]fire extinguisher[/TH]
[TD="class: prCode"]6A0[/TD]
[TD]without fire extinguisher[/TD]
[/TR]
[TR]
[TH="align: left"]Pedal cluster[/TH]
[TD="class: prCode"]VF0[/TD]
[TD]Standard pedal cluster[/TD]
[/TR]
[TR]
[TH="align: left"]Headlight activation[/TH]
[TD="class: prCode"]8K3[/TD]
[TD]Daytime headlights with automatic headlight control
and coming home function[/TD]
[/TR]
[TR]
[TH="align: left"]Vehicle specifications[/TH]
[TD="class: prCode"]F0A[/TD]
[TD]No special purpose vehicle, standard
equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Alternators[/TH]
[TD="class: prCode"]8GU[/TD]
[TD]Alternator 140 A[/TD]
[/TR]
[TR]
[TH="align: left"]Weight category rear axle[/TH]
[TD="class: prCode"]0YA[/TD]
[TD]Weight range 1
installation control only, no
requirement forecast[/TD]
[/TR]
[TR]
[TH="align: left"]Weight category front axle[/TH]
[TD="class: prCode"]L55[/TD]
[TD]Suspension range 55
[/TR]
[TR]
[TH="align: left"]Base engine[/TH]
[TD="class: prCode"]TU3[/TD]
[TD]4-cylinder diesel engine 2.0 l
unit 03L.H[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage netting/pocket on backrest(s)[/TH]
[TD="class: prCode"]4U0[/TD]
[TD]Without luggage nets/pockets
on backrests[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage compartment cover[/TH]
[TD="class: prCode"]3U1[/TD]
[TD]Folding trunk cover[/TD]
[/TR]
[TR]
[TH="align: left"]cruise control system[/TH]
[TD="class: prCode"]8T0[/TD]
[TD]Without cruise control system (CCS)[/TD]
[/TR]
[TR]
[TH="align: left"]Transmission specifications[/TH]
[TD="class: prCode"]G0K[/TD]
[TD]6-speed manual transmission[/TD]
[/TR]
[TR]
[TH="align: left"]handle for hand brake lever[/TH]
[TD="class: prCode"]6PC[/TD]
[TD]handbrake lever grip (leather)[/TD]
[/TR]
[TR]
[TH="align: left"]Rear window wiper and washer system[/TH]
[TD="class: prCode"]8M1[/TD]
[TD]Rear window wiper washer system with
intermittent wipe[/TD]
[/TR]
[TR]
[TH="align: left"]Rear seats[/TH]
[TD="class: prCode"]3KC[/TD]
[TD]Rear bench seat, not split, split backrest, folding[/TD]
[/TR]
[TR]
[TH="align: left"]Heating and air-conditioning system[/TH]
[TD="class: prCode"]9AP[/TD]
[TD]Climatic air-conditioning system (semi-automatic)[/TD]
[/TR]
[TR]
[TH="align: left"]Headlamps[/TH]
[TD="class: prCode"]8BK[/TD]
[TD]Twin headlamps for driving on the left,
with integrated high beam[/TD]
[/TR]
[TR]
[TH="align: left"]Customized installation[/TH]
[TD="class: prCode"]FC0[/TD]
[TD]Without individual installation[/TD]
[/TR]
[TR]
[TH="align: left"]Interior light in footwell[/TH]
[TD="class: prCode"]6T1[/TD]
[TD]Interior light in footwell[/TD]
[/TR]
[TR]
[TH="align: left"]Instrument clusters[/TH]
[TD="class: prCode"]U5B[/TD]
[TD]Instrument insert, mph speedometer
Great Britain[/TD]
[/TR]
[TR]
[TH="align: left"]Breakaway interior rearview mirror[/TH]
[TD="class: prCode"]4L6[/TD]
[TD]Breakaway interior rearview mirror,
auto-dimming[/TD]
[/TR]
[TR]
[TH="align: left"]Sticker (customized or special edition)[/TH]
[TD="class: prCode"]0KA[/TD]
[TD]Without decals and emblems[/TD]
[/TR]
[TR]
[TH="align: left"]Body style[/TH]
[TD="class: prCode"]K8C[/TD]
[TD]Coupe[/TD]
[/TR]
[TR]
[TH="align: left"]coolbox[/TH]
[TD="class: prCode"]1W2[/TD]
[TD]Glove compartment cooling system[/TD]
[/TR]
[TR]
[TH="align: left"]Climatic zones[/TH]
[TD="class: prCode"]0Y1[/TD]
[TD]Standard climatic zones[/TD]
[/TR]
[TR]
[TH="align: left"]Compass/road sign display[/TH]
[TD="class: prCode"]QR0[/TD]
[TD]Without compass/road sign display/
dynamic road sign display[/TD]
[/TR]
[TR]
[TH="align: left"]Head restraints[/TH]
[TD="class: prCode"]3J1[/TD]
[TD]Hight-adjustable head restraints for
front seats[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel quantity for initial filling[/TH]
[TD="class: prCode"]1Z2[/TD]
[TD]Increase in initial standard fuel
filling[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel systems[/TH]
[TD="class: prCode"]0F5[/TD]
[TD]Fuel system for diesel engine[/TD]
[/TR]
[TR]
[TH="align: left"]Body measures[/TH]
[TD="class: prCode"]5C0[/TD]
[TD]Without special body measures[/TD]
[/TR]
[TR]
[TH="align: left"]Rear license plate bracket[/TH]
[TD="class: prCode"]6P1[/TD]
[TD]Rear license plate carrier (ECE)[/TD]
[/TR]
[TR]
[TH="align: left"]Front license plate bracket[/TH]
[TD="class: prCode"]6W1[/TD]
[TD]Front license plate carrier (large)[/TD]
[/TR]
[TR]
[TH="align: left"]Paint preservative/transit coating[/TH]
[TD="class: prCode"]5K5[/TD]
[TD]Transport protection film with
additional transport protection measures[/TD]
[/TR]
[TR]
[TH="align: left"]Steering system arrangement[/TH]
[TD="class: prCode"]L0R[/TD]
[TD]Right-hand drive[/TD]
[/TR]
[TR]
[TH="align: left"]steering[/TH]
[TD="class: prCode"]1N3[/TD]
[TD]Speed-related variable steering assist
(Servotronic)[/TD]
[/TR]
[TR]
[TH="align: left"]Backrest release[/TH]
[TD="class: prCode"]3H9[/TD]
[TD]Backrest release for front seats with
Easy Entry feature[/TD]
[/TR]
[TR]
[TH="align: left"]Lumbar support[/TH]
[TD="class: prCode"]7P0[/TD]
[TD]Without lumbar support
in seat backrests[/TD]
[/TR]
[TR]
[TH="align: left"]steering wheels[/TH]
[TD="class: prCode"]1XU[/TD]
[TD]Leather steering wheel with aluminium trim[/TD]
[/TR]
[TR]
[TH="align: left"]Speaker installation[/TH]
[TD="class: prCode"]8RM[/TD]
[TD]8 speakers (passive)[/TD]
[/TR]
[TR]
[TH="align: left"]Headlight range control[/TH]
[TD="class: prCode"]8Q1[/TD]
[TD]Headlight range control[/TD]
[/TR]
[TR]
[TH="align: left"]Center armrest[/TH]
[TD="class: prCode"]6E3[/TD]
[TD]Center armrest in front[/TD]
[/TR]
[TR]
[TH="align: left"]Multi-function display/trip computer[/TH]
[TD="class: prCode"]9Q1[/TD]
[TD]Multi-function display/trip computer[/TD]
[/TR]
[TR]
[TH="align: left"]Engine cooling[/TH]
[TD="class: prCode"]8Z5[/TD]
[TD]not hot country[/TD]
[/TR]
[TR]
[TH="align: left"]Engine specifications[/TH]
[TD="class: prCode"]D91[/TD]
[TD]4-cyl. turbo diesel engine 2.0 L/103 KW (4 V)
TDI common rail
TG3/TJ3/TU3/TL4/TP4/TM3/TW3/TR4/TS1/TN5[/TD]
[/TR]
[TR]
[TH="align: left"]Left vanity mirror[/TH]
[TD="class: prCode"]4SD[/TD]
[TD]Vanity mirror, left, illuminated[/TD]
[/TR]
[TR]
[TH="align: left"]Right vanity mirror[/TH]
[TD="class: prCode"]4TD[/TD]
[TD]Vanity mirror, right, illuminated[/TD]
[/TR]
[TR]
[TH="align: left"]Navigation device[/TH]
[TD="class: prCode"]7Q0[/TD]
[TD]without navigation system[/TD]
[/TR]
[TR]
[TH="align: left"]rear fog lamp[/TH]
[TD="class: prCode"]8TD[/TD]
[TD]Rear fog light for driving on the left[/TD]
[/TR]
[TR]
[TH="align: left"]Front fog lamp/additional headlamp[/TH]
[TD="class: prCode"]8WA[/TD]
[TD]Without fog lights[/TD]
[/TR]
[TR]
[TH="align: left"]Rear of platform module base[/TH]
[TD="class: prCode"]4P0[/TD]
[TD]Rear floor panel module, type 1[/TD]
[/TR]
[TR]
[TH="align: left"]Platform group class[/TH]
[TD="class: prCode"]7PA[/TD]
[TD]Platform group class 1[/TD]
[/TR]
[TR]
[TH="align: left"]Hubcaps[/TH]
[TD="class: prCode"]1NL[/TD]
[TD]Trims for alloy wheels[/TD]
[/TR]
[TR]
[TH="align: left"]Wheels[/TH]
[TD="class: prCode"]CL9[/TD]
[TD]Alloy wheels 8J x 17[/TD]
[/TR]
[TR]
[TH="align: left"]Radios[/TH]
[TD="class: prCode"]8AI[/TD]
[TD]Radio "RCD510 MP3"[/TD]
[/TR]
[TR]
[TH="align: left"]Smoker's/non-smoker's package[/TH]
[TD="class: prCode"]9JA[/TD]
[TD]Non smoker version[/TD]
[/TR]
[TR]
[TH="align: left"]Tire pressure monitoring system[/TH]
[TD="class: prCode"]7K0[/TD]
[TD]Without tyre pressure monitor[/TD]
[/TR]
[TR]
[TH="align: left"]tire[/TH]
[TD="class: prCode"]HK0[/TD]
[TD]Tires 235/45 R17 97W x1[/TD]
[/TR]
[TR]
[TH="align: left"]Tire suppliers[/TH]
[TD="class: prCode"]V0A[/TD]
[TD]Tires without specification of tire
brand[/TD]
[/TR]
[TR]
[TH="align: left"]Spare wheel/breakdown kit[/TH]
[TD="class: prCode"]1G6[/TD]
[TD]Space-saving spare wheel[/TD]
[/TR]
[TR]
[TH="align: left"]Restraint systems, front[/TH]
[TD="class: prCode"]3QT[/TD]
[TD]3-point seat belts in front, with
tensioner and height adjustment[/TD]
[/TR]
[TR]
[TH="align: left"][/TH]
[TD="class: prCode"]PDD[/TD]
[TD]Adaptive chassis control[/TD]
[/TR]
[TR]
[TD="class: prCode"]PJ1[/TD]
[TD]"Donington" 4 alloy wheels 8J x 17 tires
235/45 R17[/TD]
[/TR]
[TR]
[TD="class: prCode"]PJW[/TD]
[TD]Space and weight saving spare wheel
(16-inch)[/TD]
[/TR]
[TR]
[TD="class: prCode"]PLA[/TD]
[TD]"Lights & Vision" package[/TD]
[/TR]
[TR]
[TD="class: prCode"]RHC[/TD]
[TD]"RCD 510" 4 x 20 W, 8 speakers[/TD]
[/TR]
[TR]
[TD="class: prCode"]WD2[/TD]
[TD]Anti-theft alarm system "Plus" incl.
single door opening[/TD]
[/TR]
[TR]
[TD="class: prCode"]WDI[/TD]
[TD]Multimedia socket MEDIA-IN[/TD]
[/TR]
[TR]
[TH="align: left"]Side airbag[/TH]
[TD="class: prCode"]4X3[/TD]
[TD]Side airbag in front, with curtain
airbag[/TD]
[/TR]
[TR]
[TH="align: left"]Gearshift knob/handle[/TH]
[TD="class: prCode"]6Q2[/TD]
[TD]Gearshift knob/handle in leather[/TD]
[/TR]
[TR]
[TH="align: left"]Special labels/plates[/TH]
[TD="class: prCode"]0SS[/TD]
[TD]Labels in English and French[/TD]
[/TR]
[TR]
[TH="align: left"]Locking mechanism for boot lid/cover
rear[/TH]
[TD="class: prCode"]4E2[/TD]
[TD]Tailgate/trunk lid release
from inside (electrically)[/TD]
[/TR]
[TR]
[TH="align: left"]Front seat, left[/TH]
[TD="class: prCode"]3TG[/TD]
[TD]Sports comfort seat in front, left[/TD]
[/TR]
[TR]
[TH="align: left"]Front seat, right[/TH]
[TD="class: prCode"]3SG[/TD]
[TD]Sports comfort seat, front, right[/TD]
[/TR]
[TR]
[TH="align: left"]Seat belt check[/TH]
[TD="class: prCode"]9P3[/TD]
[TD]Seat belt reminder, electric contact in
buckle[/TD]
[/TR]
[TR]
[TH="align: left"]Outer rear seat belts[/TH]
[TD="class: prCode"]3ZB[/TD]
[TD]3-point seat belts, outer rear with ECE
label[/TD]
[/TR]
[TR]
[TH="align: left"]seat covers[/TH]
[TD="class: prCode"]N3A[/TD]
[TD]Seat trim covers in fabric[/TD]
[/TR]
[TR]
[TH="align: left"]Seat adjustment[/TH]
[TD="class: prCode"]3L3[/TD]
[TD]Manual height adjustment for front seats[/TD]
[/TR]
[TR]
[TH="align: left"]seat heater[/TH]
[TD="class: prCode"]4A0[/TD]
[TD]without seat heater[/TD]
[/TR]
[TR]
[TH="align: left"]Safety head restraint system[/TH]
[TD="class: prCode"]3K0[/TD]
[TD]w/o safety head restraint system[/TD]
[/TR]
[TR]
[TH="align: left"]Horns[/TH]
[TD="class: prCode"]8Y1[/TD]
[TD]Two-tone horn[/TD]
[/TR]
[TR]
[TH="align: left"]Side and rear windows[/TH]
[TD="class: prCode"]4KC[/TD]
[TD]Side and rear windows in heat-insulating
glass[/TD]
[/TR]
[TR]
[TH="align: left"]power outlet[/TH]
[TD="class: prCode"]7B2[/TD]
[TD]12 volt socket in luggage compartment[/TD]
[/TR]
[TR]
[TH="align: left"]Bumper[/TH]
[TD="class: prCode"]2JC[/TD]
[TD]Comfort bumpers[/TD]
[/TR]
[TR]
[TH="align: left"]Rear stabilizer[/TH]
[TD="class: prCode"]0BE[/TD]
[TD]Rear stabilizer[/TD]
[/TR]
[TR]
[TH="align: left"]Front stabilizer bar[/TH]
[TD="class: prCode"]0AD[/TD]
[TD]Front stabilizer bar[/TD]
[/TR]
[TR]
[TH="align: left"]Headlamp washer system[/TH]
[TD="class: prCode"]8X0[/TD]
[TD]Without headlamp washer system[/TD]
[/TR]
[TR]
[TH="align: left"]Windshield wiper intermittent control/
light/rain sensor[/TH]
[TD="class: prCode"]8N3[/TD]
[TD]intermittent windscreen wiper with rain sensor[/TD]
[/TR]
[TR]
[TH="align: left"]Nameplate set[/TH]
[TD="class: prCode"]0ND[/TD]
[TD]Nameplate set "TDI"[/TD]
[/TR]
[TR]
[TH="align: left"]Mass damper for steering wheels[/TH]
[TD="class: prCode"]1Q0[/TD]
[TD]steering wheel without balance weight[/TD]
[/TR]
[TR]
[TH="align: left"]Door and lid locking system[/TH]
[TD="class: prCode"]4K3[/TD]
[TD]Central locking w/ radio remote control,
interior controls and SAFELOCK[/TD]
[/TR]
[TR]
[TH="align: left"]Type approval countries/countries with
special requirements[/TH]
[TD="class: prCode"]B09[/TD]
[TD]Type approval country GB/Northern
Ireland[/TD]
[/TR]
[TR]
[TH="align: left"]Carrier frequency for remote control[/TH]
[TD="class: prCode"]5D1[/TD]
[TD]Carrier frequency 433.92 to 434.42 Mhz[/TD]
[/TR]
[TR]
[TH="align: left"]Partition[/TH]
[TD="class: prCode"]3CA[/TD]
[TD]without partition[/TD]
[/TR]
[TR]
[TH="align: left"]Door and side trim panels[/TH]
[TD="class: prCode"]4AF[/TD]
[TD]Door and side trim panel in foam film
and woven fabric[/TD]
[/TR]
[TR]
[TH="align: left"]doors[/TH]
[TD="class: prCode"]0A1[/TD]
[TD]2 doors[/TD]
[/TR]
[TR]
[TH="align: left"]TV reception/digital radio reception[/TH]
[TD="class: prCode"]QV0[/TD]
[TD]without TV/digital radio reception[/TD]
[/TR]
[TR]
[TH="align: left"]Front underbody guard[/TH]
[TD="class: prCode"]1SA[/TD]
[TD]Without additional front underbody guard[/TD]
[/TR]
[TR]
[TH="align: left"]Identification plates[/TH]
[TD="class: prCode"]1EX[/TD]
[TD]Special identification plate for EU[/TD]
[/TR]
[TR]
[TH="align: left"]Delivery equipment[/TH]
[TD="class: prCode"]2A0[/TD]
[TD]Without delivery equipment[/TD]
[/TR]
[TR]
[TH="align: left"]First aid kit / warning triangle[/TH]
[TD="class: prCode"]1T0[/TD]
[TD]Without first-aid material, without warning triangle[/TD]
[/TR]
[TR]
[TH="align: left"]Telephone / telematics[/TH]
[TD="class: prCode"]9W0[/TD]
[TD]Without car phone preparation/
installation[/TD]
[/TR]
[TR]
[TH="align: left"]LongLife Service Regime[/TH]
[TD="class: prCode"]QG1[/TD]
[TD]LongLife Service Regime[/TD]
[/TR]
[TR]
[TH="align: left"]Heat accumulator system/auxiliary heater[/TH]
[TD="class: prCode"]7E6[/TD]
[TD]electric air additional heater[/TD]
[/TR]
[TR]
[TH="align: left"]Windshield Glass[/TH]
[TD="class: prCode"]4GF[/TD]
[TD]Windshield in heat-insulating glass[/TD]
[/TR]
[TR]
[TH="align: left"]Washer fluid level indicator[/TH]
[TD="class: prCode"]8W0[/TD]
[TD]without washer water level indicator[/TD]
[/TR]
[TR]
[TH="align: left"]Additional tires (snow tires)[/TH]
[TD="class: prCode"]2WA[/TD]
[TD]without spare tyre[/TD]
[/TR]
[TR]
[TH="align: left"]floor mats[/TH]
[TD="class: prCode"]0TA[/TD]
[TD]without floor mats[/TD]
[/TR]
[TR]
[TH="align: left"]Additional child seat anchors[/TH]
[TD="class: prCode"]3B4[/TD]
[TD]Child seat anchors for
child seat system ISOFIX[/TD]
[/TR]
[TR]
[TH="align: left"]Auxiliary heating system[/TH]
[TD="class: prCode"]9M0[/TD]
[TD]Without auxiliary heater/parking heater[/TD]
[/TR]
[/TABLE]
VAGMAN
C?ID=374246
Thank you, I have forwarded the code to the mechanic and will report back with his feedback.
VAGMAN
C?ID=374246
Hi Jack, thanks for the code, unfortunately that didn’t work, are there any other that you suggest for me to try?
Thanks in advance
VAGMAN
C?ID=374246
Can Anyone assist or suggest anything else?
VAGMAN
C?ID=374246
Hi Jack, thanks for replying, I won’t be able to get this unless there is someone else on here with a similar car?
VAGMAN
C?ID=374246
Thank you, I’ve forwarded it to my mechanic, will let you know either way.
VAGMAN
C?ID=374246
Thanks NEtech, however the code did not work.
Is there anyone with a RHD 2009 2.0 tdi CR scirocco that can read out the code from their car? Will be happy to pay a small fee?
NostraJackAss
ModelScirocco 2.0
SCI
Model year2009
Sales type13726L
Engine CodeCBDB
Coding: 0001072
Revision: 00H35001
Coding: 763BC0F5092300FF6E1403E5901900813000 RHD PRIOR FAIL
Coding: 763B40F5492300FF6E1402E5921900823000 NTECH FAIL
Coding: 763B40F5492300FF6E1402E5901900813000 RHD TRY THIS OP
Coding: 763B40F5492300FF6E1403E5901900813000 RHD TRY THIS OP
Coding: 763B40F5492300FF6E1403E5901900823000 RHD TRY THIS OP
VAGMAN
C?ID=374246
Thanks Jack, I’ll come back with feedback once I get a reply from the mechanic.
NostraJackAss
Since this car is from an auction.......... OP
Is the VIN consistent in advanced measuring blocks of immobilizer and engine ECU, is immobilizer status married and is the ( POWER CLASS ) PC set correct in the cluster & to correlate to the engine ECU PC?
VAGMAN
C?ID=374246
I’ve had some feedback from the mechanic, not sure how meaningful this is however he said he receives ‘error code 31’ and it stops there, appreciate this might be enough but I’m finding it difficult to get anymore info.
TIA
VAGMAN
C?ID=374246
Hi, to provide an update to this issue, We had another mechanic look into the issue and he was able to generated the code, all is well with the car and all of the lights and beeping sound has now gone. He mentioned that the code which was accepted had "...B3..." where the ones supplied by Jack had "...B4..".
I have asked him for the actual code and will update the thread once I receive it.
Thanks to all who contributed to the issue.
