8V A3 Tweaks
m_bolc
San José, Costa Rica
C?ID=230356
I'd like to know if it is possible to tweak my car through VCDS to add the following. I've tried finding these in VCDS for hours, and other forums don't have the coding either.
1. Indirect TPMS
2. Enable Drive-select like settings for the steering effort in MMI. Maybe even enable different throttle mapping?
3. Even with the "late" setting my headlamps turn on too early for my taste when in auto mode, can the light sensor sensitivity be altered?
Here is my auto-scan:
Thursday,27,November,2014,18:12:27:29892
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WAUZZZ8V2FA000583   License Plate: TBR043
Mileage: 9198km-5715mi   Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WAUZZZ8V2FA000583   Mileage: 9198km-5715miles
Address 01: Engine (J623-CJZA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 B    HW: 04E 907 309 A
   Component: 1.2l R4 TSI   H08 6387
   Revision: WAH08---
   Coding: 02110012230400082000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM12TFS01104E906016B 001008
   ROD: EV_ECM12TFS01104E906016B.rod
   VCID: 2149CBAF30BD2E29405-8074
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Revision: 00000000    Serial number: 606040000015FD
   Coding: 10F16AA224200A6C017C060841C62508562450806082A4B2002100080608
   VCID: 7BF5D9C7F291A4F93A9-802E
Address 08: Auto HVAC (E87)       Labels: 8V0-820-047.clb
   Part No SW: 8V0 820 047 D    HW: 8V0 820 047 D
   Component: AC Manuell el H11 0052
   Revision: 20021000    Serial number: 00000000054640
   Coding: 00000004100000000000000000000000
   ASAM Dataset: EV_AirCondiFrontManAU37X 008018
   ROD: EV_AirCondiFrontManAU37X.rod
   VCID: 377D05F78E3940999E1-8062
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
   Component: BCM MQBAB M   H16 0124
   Serial number: 00011406500433
   Coding: 04040842C001027D03044004B30407000000000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 79F9C3CFF8AD96E9285-802C
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119
   Component: WWS370 140225  041 0580
   Serial number:         140227184035
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A
   Component: G397_RLS  H06 0002
   Serial number: 20143063
   Coding: 06885D
   Subsystem 3 - Part No SW: 8V0 941 531 Q    HW: 8V0 941 531 Q
   Serial number: 29 11 2013  00001158
   Serial number: 000000000ZY140231TB1
   Serial number: 00000000000058976888
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serial number: 003M2R05LNY8
   Coding: 98CCC000000000005C540000004800000065
   VCID: 4B954907E2B1D479CA9-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 001 702 14
   Serial number: 35767000000685500F0O
   Subsystem 2 - Part No SW: -----------    HW: 480 001 702 14
   Serial number: 35867000000885500F0R
   Subsystem 3 - Part No SW: -----------    HW: 480 400 703 14
   Serial number: 35165029F14D3E72E40M
   Subsystem 4 - Part No SW: -----------    HW: 480 402 802 14
   Serial number: 3526502C112F6291710.
   Subsystem 5 - Part No SW: -----------    HW: 480 400 702 14
   Serial number: 3556502C513013F3D10/
   Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 07031404220752
   Coding: 0408
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 0603B833B953E911557-8053
   Part No SW: 8V0 920 860 E    HW: 8V0 920 860 E
   Component: KOMBI         H02 2220
   Coding: 07850200228000080500BA00100000
   VCID: 3C771ADBB71F63C1733-8069
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 E
   Component: GW MQB Mid    124 1164
   Revision: --------    Serial number: 0001674704
   Coding: 01010008200864005B000208000B00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear.rod
   VCID: 3E7310D3A10371D15D7-806B
   Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
   Serial number: 20 02 2014  B1311502
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 22021403110883
   Coding: 00100E20C100040100001002
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 0102
   ROD: EV_SteerAssisMQB_AU37.rod
   VCID: 41896B2FD0FD0E29205-8014
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 04031403110700
   Coding: 00100620CD00040100001002
   VCID: 3D7117DFAC056AC944D-8068
   Part No SW: 8V0 035 840 B    HW: 8V0 035 840 B
   Component: MU-S--ER      040 0420
   Serial number: A3E00403140672
   Coding: 01730000FF0A000021220001001A00002F0001440100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 346732FB9F4FAB81BB3-8061
   Seat Adjustment Driver Side:
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0013
   Serial number: AUZ8Z9DY301DHC
   Sound System:
   Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000019021400010341
End-------------------------(Elapsed Time: 02:47)--------------------------
DrPeter
16.4905° S, 151.7375° W
1. Indirect TPMS
The TPMS change maybe some where in the ABS coding, if it is at all possible [10F16AA224200A6C017C060841C62508562450806082A4B2002100080608]
- Contrary to popular belief, Audi and Volkswagen does not give us any information on what this coding means. So your guess is as good as mine.
- Each on of these values could be a number from [00 to FF or as we humans understand it 0 to 255] with 30 different bytes, that is a combination of [1,003,101,341,614,529,699,533,217,301,907,014,537,585] different possibilities, that is if my math is correct. C(n,r) = n! / ( r! (n - r)! )
- You may have to give it some time so someone can figure it out, or you can contact Audi with the requests, as they would know, since they designed and built the vehicle. Ross-Tech makes scan tools.
- A ECM Chip tuner could help with re-mapping the throttle, Ross-Tech does not make chip tuning tools.
drpeter
pss.... 1,003,101,341,614,529,699,533,217,301,907,014,537,585 =
one duodecillion, three undecillion, one hundred one decillion, three hundred forty-one nonillion, six hundred fourteen octillion, five hundred twenty-nine septillion, six hundred ninety-nine sextillion, five hundred thirty-three quintillion, two hundred seventeen quadrillion, three hundred one trillion, nine hundred seven billion, fourteen million, five hundred thirty-seven thousand, five hundred eighty-five
This thread contains RoW market 8V (5Q0) MQB TPMS discussion:
http://forums.ross-tech.com/showthread.php?355-Security-Access-ABS-Module
.. but US market VW/Audi models have TPMS factory enabled so you would want feedback from a fellow RoW forum member ... or Sebastian if he happens to have a coding suggestion for this vehicle. We changed the thread title so it receives searchable feedback.
^^^^^ Dana: When you say "This thread contains RoW market 8V (5Q0) MQB TPMS discussion", what exactly do you mean? Is the important point in your suggestion that m_bolc needs to find another RoW. 8V owner, or will any 5Q0 - MQB type vehicle (of RoW persuasion) suffice?
For example, the ABS on my mk7 Golf has TPMS, it's RoW, its (5Q0) MBQ and it has the following details
m_bolcDV52
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Coding: 01FA8AA1202312700377060701C32980510448C0608094F3002A0028C1
Shop #: WSC 00028 028 00025
ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 7DF1154CECFCAFD27A-8028
I note that HW/SW details for both are not dissimilar but the coding string values are worrying! Is this good enough? If so how do I help?
m_bolc
C?ID=230356
Thanks for the feedback DrPeter and Dana.
I am aware of what Ross Tech does, that's why I sought your guys' help. You may have more valuable coding suggestions due to previous experience.
I'll try out the link Dana posted to see if that gets what I want.
- Thanks again, great product!
Hi Don,
First of all I wanted to comment on that /table, very nice! I should experiment with that because it is a very nice and easily readable format.
Based on memory this thread was named something like Need Help from RT employees (or some combination of those words - I may have the order messed up). When I saw the VIN combined with the fact that the title wasn't searchable we changed it. US market vehicles are Federally required to have TPMS as of M.Y. 2008 so the MQBs that rolled out locally are factory enabled.
We do not have any coding information to contribute at this time but it is possible that someone like NEtech or Sebastian may have a suggestion. Because these are different HW/SW numbers ... I'm not sure if there is anything you can do at this time to help.
m_bolc
C?ID=230356
I was able to code indirect TPMS!
Module 5F
Set these to active
(56) vehicle_menu-operation-menu_display_rdk
(13) vehicle_function list BAP; extension-tire_pressure_system_0x07
Module 17
Coding -> Long coding.
Byte 4 check bit 0
Module 03 ABS/Brakes
Coding.
My original coding: 10F16AA224200A6C017C060841C62508562450806082A4B2002100080608
My new coding: 10F16AA224200A6C017C060841C62508562450806082A4B20021000388608
Reset MMI (Menu + OK + Upper right corner button)
Go to Menu, Car, Service & control and voilá! It's there.
m_bolc
C?ID=230356
Hey, would anyone have a coding suggestion for indirect TPMS on this car? It doesn't seem to follow the same coding as my old or current 8Vs
Monday,04,April,2016,18:49:33:29892
VCDS Version: 16.3.0.0 (x64)
Data version: 20160216
VIN: WAUZZZ8V3EA000770   License Plate: MVL100
Mileage: 33125km-20582mi   Repair Order:
Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V3EA000770   Mileage: 33125km-20582miles
   Component: 1.2l R4 TSI   H08 5544
   Revision: WAH08---
   ASAM Dataset: EV_ECM12TFS01104E906016B 001006
   VCID: 2149CBAF30BD2E3480-8074
   Part No SW: 5Q0 907 379 P    HW: 5Q0 907 379 D
   Component: ESC           H75 0434
   Coding: 10F16AA220200A6C037E060701C32508560450C06080A4B30039000805
   Shop #: WSC 05212 002 104857
   VCID: 4999730FE8CDC67438-801C
   Part No SW: 8V0 820 047 B    HW: 8V0 820 047 B
   Component: AC Manuell el H09 0031
   Revision: 20017000    Serial number: 00000000014027
   ASAM Dataset: EV_AirCondiFrontManAU37X 008016
   VCID: 35610FFF9435B2944C-8060
65544 - Button(s) or Switch(es) in Operating Device
          B1312 07 [008] - Mechanical Failure
                    Reset counter: 133
                    Mileage: 32907 km
                    Date: 2016.04.02
                    Time: 09:12:15
                    Voltage terminal 30: 13.7 V
                    Outside air temperature: 30 °C
                    Pressing a button-Recirculating air: not activated
                    Pressing a button-Rear window defogger: not activated
                    Pressing a button-AC: not activated
                    Pressing a button-Left heated seat: not activated
                    Pressing a button-Right heated seat: not activated
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [008] -  -
                    Reset counter: 119
                    Mileage: 32445 km
                    Date: 2016.03.14
                    Time: 09:23:57
                    Voltage terminal 30: 13.9 V
                    Compressor shut-off requirement: Shut-off from Engine Control Module (ECM) via CAN
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011311700298
   Coding: 04000A42C001227D03044000B30C07000000000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 46837833F9D3290CD5-8012
   Slave 1:
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130418  041 0580
   Serial number:         130423140117
   Coding: 0A47F7
   Slave 2:
   Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
   Serial number: 20114803
   Coding: 06885D
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
   Serial number: 16 04 2013  00001858
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY130931L14
   Serial number: 00000000000056638894
          B1263 01 [008] - Electrical Failure
                    Reset counter: 137
                    Mileage: 1048574 km
197904 - Central Locking
          B140A 4B [008] - Over temperature
                    Reset counter: 119
                    Mileage: 32760 km
                    Date: 2016.03.21
                    Time: 11:35:24
267030 - Siren / Alarm Horn for Anti-Theft Alarm System
          U1137 00 [008] - Implausible Message
                    Reset counter: 105
                    Mileage: 31467 km
   Part No SW: 5Q0 959 655 L    HW: 5Q0 959 655 L
   Component: AirbagVW20    009 0349
   Serial number: 003GER00ZWUS
   Subsystem 1 - Part No SW: -----------    HW: 480 002 204 13
   Serial number: 3576700000033C688C0.
   Subsystem 2 - Part No SW: -----------    HW: 480 002 204 13
   Serial number: 3586700000013D688C0.
   Subsystem 3 - Part No SW: -----------    HW: 480 400 904 13
   Serial number: 3516502A90FBDE45B21V
   Subsystem 4 - Part No SW: -----------    HW: 480 400 904 13
   Serial number: 3526502AF0FBDE32738
   Subsystem 5 - Part No SW: -----------    HW: 480 401 403 13
   Serial number: 3556502A10FAE894404J
   Part No SW: 8V0 953 521     HW: 5Q0 953 549 A
   Revision: --------    Serial number: 25041304221057
   Coding: 8408
   VCID: 77FDC5F7CEB980849E-8022
   Part No SW: 8V0 920 860     HW: 8V0 920 860
   Component: KOMBI         H22 0570
   Coding: 078502002A8000080500AA00000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
9582599 - Switches in Instrument Panel
          B1238 07 [008] - Mechanical Failure
                    Reset counter: 122
                    Mileage: 32670 km
                    Date: 2016.03.19
                    Time: 11:44:18
   Part No SW: 5Q0 907 530 J    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1126
   Revision: --------    Serial number: 0000575131
   Coding: 010100F02008640000000200000B00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 008010
   VCID: 387F06CB83274FFC57-806C
   Generator:
   Serial number: 27 04 2013  A1163564
   Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393
   Component: TSG FS        012 0006
   Serial number: 19041301100036
   Coding: 00100E204100040100001002
   VCID: 3D7117DFAC056AD484-8068
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 01
   ROD: EV_SteerAssisMQB_VW37.rod
   Part No SW: 5Q0 959 392 A    HW: 5Q0 959 392
   Component: TSG BFS       012 0006
   Serial number: 08041301100276
   Coding: 001006204500040100001002
   VCID: 3C771ADBB71F63DCB3-8068
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Component: LWR-ECU       005 0070
   Coding: 010A000001000000
   Shop #: WSC 08960 001 1048576
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   VCID: 75E1CFFFD4B5F2948C-8020
Address 5F: Information Electr. (J794)       Labels: 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 840 A    HW: 8V0 035 840
   Component: MU-S--ER      039 0370
   Serial number: A3E00105130061
   ROD: EV_MUStd6C3PASE_AU37.rod
   VCID: 336531E79A41ACA462-8066
   Subsystem 1 - Part No SW: 8V0 919 603 A    HW: 8V0 919 603 A
   Component: DU Std  H47 0013
   Serial number: AUZ8Z9DG600T0N
   Sound System:
   Serial number: C1000013031300020231
0532 - Subwoofer
          B106C 13 [009] - Open Circuit
                    Reset counter: 246
                    Mileage: 31378 km
                    Date: 2016.02.05
                    Time: 08:21:11
6179 - Display Module 1 for Multimedia System
          B1297 F6 [008] - Cable for Video Signal; Open Circuit
                    Reset counter: 115
                    Mileage: 32640 km
                    Date: 2016.03.17
                    Time: 21:20:59
End-------------------------(Elapsed Time: 02:58)--------------------------
m_bloc: Hello again! I occasionally pick-up, or I get sent (via PM) tweaks that are of interest which I keep in a MS-Word database. The instructions below came from that database, but I know nothing further about it. I can't vouch for the veracity of the instructions, but I provide them on this understanding (i.e. entirely untested). However, on my mk7 (which has TPMS active), with the exception of the STG 03 coding (the last 3 bytes on my car are 0028C1), the rest of the instructions are correct!
TPMS Retrofit Instructions (MQB):
STG 03> Coding> replace Last 3 bytes by "30C202" (not sure this is correct?)
STG 5F> Adjustment> ...
>Channel "(13)-Vehicle function list BAP-tire_pressure_system_0x07"> Set value to "activated"
> Channel "(14)-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus"> Set value to " Suspension data bus"
> Channel "(56)-Vehicle menu operation-menu_display_rdk "> Set value to "activated"
> Channel "(58)-Vehicle menu operation-menu_display_rdk_over_threshold_high "> Set value to "activated"
STG 17> Coding> Byte 4>Enable bit 0 ("Indirect Tire Pressure Monitoring System (TPMS)")
Good luck
m_bolc
C?ID=230356
Hello Don!
Great information, it really does look like a different coding suggestion from what I have seen before.
Do you by any chance have the SW/HW information from the source car?
I also noticed that the information data bus is something I have never looked at. The indirect TPMS hasn't been too precise, it triggers the alarm at about -5 psi. Maybe reviewing which data bus I am using will help improve accuracy.
Hello Don!
m_bolc: Alas no -as I said, the instructions are all that I have
m_bolc:I assume that you mean an absolute tire pressure of 5PSI, rather than a loss of tire pressure by 5PSI? That's not good, mine triggers at a much higher pressure (somewhere around 25 PSI assuming a nominal tire pressure of 32 PSI when TMPS is set). One of the good attributes of "differential" monitoring systems like TPMS is finer granularity. You might need to investigate your tweak further!
lala30
Croatia
C?ID=71949
AbS coding for TPMS
byte 27
bit 4,5
byte 28
bit 7
AbS coding for TPMS
byte 27
bit 4,5
byte 28
bit 7
lala: Yes, that makes sense - what you are saying is consistent with m_bolc's changes in post #7: See below
So the changes that you recommend to the auto-scan on post #8 are:
Before tweak >10F16AA220200A6C037E060701C32508560450C06080A4B30039000805
After tweak >10F16AA220200A6C037E060701C32508560450C06080A4B30039003885
This is different to mk7 (Bit27, Bit 5 set, Byte 28, Bit 7 set)
m_bolc
C?ID=230356
I mean the alarm is triggered when the pressure is dropped by 5psi or more, not 5 psi of absolute pressure (that would be a very noticeable flat!).
I will try with the adjusted data bus value, I just varied it to suspension data bus.
Now on to my friend's car: I will report success or failure soon.
m_bolc
C?ID=230356
Hello Don,
Excellent job on that coding suggestion, here is the scan after the tweak of my friend's car.
Monday,18,April,2016,18:14:58:29892
Mileage: 33717km-20950mi   Repair Order:
VIN: WAUZZZ8V3EA000770   Mileage: 33717km-20950miles
   Revision: WAH08---
          B10F0 00 [008] -  -
                    Reset counter: 171
                    Mileage: 32445 km
                    Date: 2016.03.14
                    Time: 09:23:57
   Slave 1:
   Coding: 0A47F7
   Slave 2:
   Coding: 06885D
   Slave 3:
                    Fault Frequency: 13
                    Reset counter: 172
                    Mileage: 1048574 km
   Coding: 8408
   Generator:
   Coding: 01
   Sound System:
0532 - Subwoofer
                    Reset counter: 246
                    Mileage: 31378 km
                    Date: 2016.02.05
                    Time: 08:21:11
                    Reset counter: 156
                    Mileage: 33429 km
                    Date: 2016.04.09
                    Time: 21:18:59
Address 5F:8V0 035 840 A recoded (ADP-(13)-Vehicle function list BAP-tire_pressure_system_0x07) from not activated  to activated
Address 5F:8V0 035 840 A recoded (ADP-(14)-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus) from Comfort data bus  to Suspension data bus
Address 5F:8V0 035 840 A recoded (ADP-(56)-Vehicle menu operation-menu_display_rdk) from not activated  to activated
Address 5F:8V0 035 840 A recoded (ADP-(58)-Vehicle menu operation-menu_display_rdk_over_threshold_high) from not activated  to activated
Address 17:8V0 920 860  recoded (Long Coding) from 078502002A8000080500AA00000000 to 078502002B8000080500AA00000000  (06314/790/00021)
Address 03:5Q0 907 379 P recoded (Long Coding) from 10F16AA220200A6C037E060701C32508560450C06080A4B30039000805 to 10F16AA220200A6C037E060701C32508560450C06080A4B30039003885  (05212/002/104857)
Hello Don,
m_bolc: Happy to hear that all went well, but the true credit should go to lala30. It was his/her suggestion. My role in your success was trivial - I just put numbers to lala30's instructions
Well- done Lala30!!
