2019 Golf GTI S, 7-speed DSG, TSI(DKFA)
satterrfi
C?ID=372187
This is how it came from the dealer. The engine doesn't have a label. Should I post a channel map for it?
Friday,14,June,2019,13:57:21:56301
VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
VIN: 3VW6T7AU9KM014312   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 13 15 17 19 32 3C 42 44 52 5F A9
VIN: 3VW6T7AU9KM014312   Mileage: 864km-536miles
Address 01: Engine (J623-DKFA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Revision: --H13---
   Coding: 092500124424012F0000
   Shop #: WSC 00066 790 00174
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001003
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C21350716E61937D6D-8068
15079 - Cold Start Idle Air Control System
          P050A 00 [096] - Malfunction
                    Mileage: 45 km
                    Date: 2019.05.06
                    Time: 11:06:17
                    Engine speed: 1410.75 /min
                    Normed load value: 7.1 %
                    Coolant temperature: 16 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 12.265 V
                    Unlearning counter according OBD: 20
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 13 s
                    MAP_MES_SAE: 49 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.031 V
                    FAC_TPS_1_SAE: 16.406250 %
                    FUP_H_SAE: 14530.0 kPa
   Part No SW: 0GC 300 020 G    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2404
   Revision: 00H06V07
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: 2615F76FF86AB3E7909-8072
   Part No SW: 5Q0 614 517 DR    HW: 5Q0 614 517 BM
   Component: ESC           H45 0108
   Revision: 00000000    Serial number: 50109000000617
   Coding: 01FA6BA150212170807A020160C56880D60A84014006167610415051D0894B0B0000000012121212B835351919323200
   Shop #: WSC 00066 790 00080
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 04518DE72E96A1F7EED-8050
   Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
   Component: AC Manuell    H03 2001
   Revision: 00001K05
   Coding: 00020004200110001000000000010004
   VCID: 4CC165C74646A9B766D-8018
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C864160119055F
   Shop #: WSC 00066 790 00249
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7BA3F61B5368DE0F9F7-802E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    181119  043 0551
   Serial number: 97022066181130230625
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S3Y18M12D18H05M43S42
   Coding: 00A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521     HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300060220190C202132
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 3500008101FFC728949C810500401600000000000000000004
   VCID: 44D14DE76E1661F7AED-8010
   Serial number: 003GCR0AWHG4
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47CB5AEB5F204AEF4BF-8012
   Occupant Detection:
   Serial number: IBH00000000000AXJZJX
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 000 312 18
   Serial number: 35700000000D4D21263G
   Subsystem 3 - Part No SW: -----------    HW: 480 000 312 18
   Serial number: 35800000000ABC31563O
   Subsystem 4 - Part No SW: -----------    HW: 480 402 109 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001BB2C06193B3D6
   Subsystem 5 - Part No SW: -----------    HW: 480 401 509 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A72C6D4B2D58I
   Subsystem 6 - Part No SW: -----------    HW: 480 400 701 19
   Serial number: 3550001262BFF575B43E
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 701 19
   Component: FrontSensor_P  004 6149
   Serial number: 3560001262BFF57663CJ
   Part No SW: 5G1 920 856 D    HW: 5G1 920 856 D
   Component: KOMBI         351 2700
   Coding: 0BBD090AA188CF0502882A095000000020000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   VCID: 2F3B124BD790F2AF63F-807A
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 45
                    Mileage: 35 km
                    Date: 2019.04.28
                    Time: 18:19:10
   Serial number: 25011900841416
   Coding: 030100047F085900FB0000691C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 6E85CF4F101ABBA7289-803A
   Component: 0-00-0d-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AD    HW: 5G0 959 442 AD  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29180002740510048467
   Coding: 29FFFF
   Serial number: 4425796100
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H55 8043
   Serial number: HA1-00028.11.18
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52FD7BBFA462FF472C1-8006
   Serial number: 0502317260
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D2738030DFC103FE13-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0502568163
   Coding: 010111
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038902300736
   Coding: 003E03200000040000000000
   Shop #: WSC 01383 790 50316
   VCID: 4FFB72CBB75092AF03F-801A
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000001606038
   Coding: 011000
   Part No SW: 5QN 909 144 A    HW: 5QN 909 144 A
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50F971B7AA6E8D571A5-8004
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46035900301842
   VCID: 4EC56FCFB05A9BA7089-801A
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000001517911
   Coding: 091000
   Part No SW: 5G6 035 868     HW: 5G6 035 868
   Component: MU-E--ER      695 8742
   Serial number: 19111800010508
   Coding: 02730000BE00000041220001001000009F0003D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW37.rod
   VCID: 70B9D1370A2EAD573A5-8024
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Serial number: 181012201094
   VCID: 323D1B3FC4A2DF470C1-8066
End----------(Elapsed Time: 01:19, VBatt start/end: 12.5V/12.5V)-----------
Jon
A channel map is not really going to help much with making a label file for a UDS ECU. Measuring Values, Adaptations, and Basic Settings intrinsically have (ostensibly meaningful) names on a UDS ECU even without a label file. So Coding and Security Access are generally the only things in label files for those, and a maps aren't going to help get those.
However: Measuring Value maps both key on / engine off, and engine fully warmed up and running at idle might help someone down the road who's wants to know if the values they're seeing are "normal".
hadez16
C?ID=289891
Do people still exist who order a car without any PDC?
Two things:
1) In the NAR market, we don't get a to choose individual options. We get "packages". This car is a "S' trim, which means it's the least expensive version available.
2) In most places in the US, parallel parking is not common, and the parking spaces in parking lots are big enough for American-sized SUVs and pickup trucks. That means a GTI is relatively small and very easy to park. Like this. :D
