Why not? What do I give up?Yes, VCDS-Mobile will work with any modern browser.
However, VCDS-Mobile should probably not be regarded as a full-function substitute for VCDS.
Of course, the HEX-NET also works with VCDS.
The data in VCDS-Mobile may not be as up-to-date. Whether this is important depends on what car you have.Why not? What do I give up?
Great, thanks. I'll more or less always have internet connectivity, my garage catches my wifi. I'll be using it for: '15 GTI, '14 T-reg, '17 Tiguan, and possibly buddy's '16 Q5. Obv want to be able to run scans, but also some of the usual tweaks and settings. I'm a newbie to this.The data in VCDS-Mobile may not be as up-to-date. Whether this is important depends on what car you have.
Some functions in VCDS-Mobile require internet connectivity. VCDS does not.
See also:
http://wiki.ross-tech.com/wiki/index.php/Functions
OK - so worst case then, I'll still have full functionality if I connect to a Windows PC if need be? Otherwise *most* functionality via VCDS Mobile? I can totally live with that.The data in VCDS-Mobile may not be as up-to-date. Whether this is important depends on what car you have.
See also:
Correct, you can use VCDS running on a PC with your HEX-NET, and connect either via USB or via WiFi.OK - so worst case then, I'll still have full functionality if I connect to a Windows PC if need be? Otherwise *most* functionality via VCDS Mobile? I can totally live with that.
What scanner did you have?I just returned a VCDS scanner because I couldn't find my engine code for my VW GTI 2012 TSI 2.0 L
Since Gendan is a reseller and does not pre-register systems, provided your friend does not register it, you should have no problem.Hi ,
Before I buy this product : https://www.gendan.co.uk/product_VCV2U.html let me have a question.
My friend going to buy this for me who lives in England and he's gonna pay with his credit/debit card. When he receives the package he's gonna forward it to me to Hungary and then I will register it with my computer first time .
I think it should be o.k. according to 3.10 here http://www.ross-tech.com/vag-com/faq_3.php ,so it does not count as a resell or does it ?
I hope it won't make any complication in the registration process either.
Thank you ,
Janos
Beware however, that that it will only be licensed for English language, not Hungarian language.
Please see our VIN-Limited Interface FAQ.what exactly do you mean by 3 VIN or 10VIN?
Is it specific to 3 actual VINs or any number of vehicles under the specified VIN type?
thanks and what about this Available Unlimited-VINYes it can.
I don't understand what you are asking. Can you re-phrase?thanks and what about this Available Unlimited-VIN
Professional Version No in this chart http://www.ross-tech.com/vcds/interfaces.php thanks for good support
