2011 Polo Lost ABS coding after engine swap
xbellx
Australia
C?ID=274333
All the coding has turned to 000000000 after engine swap and prolonged battery disconnect.
Any help would be greatly appreciated to recover the correct coding for the ABS module.
Thanks Dave
Thursday,13,June,2019,14:02:02:30858
VCDS Version: 18.9.1.0 (x64)
VIN: WVWZZZ6RZBU042763   License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 2E 44 56 77
VIN: WVWZZZ6RZBU042763   Mileage: 117840km-73222miles
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 E    HW: 03F 906 070 D
   Component: SIMOS10.20H02 9699
   Revision: --------    Serial number:
   Coding: 002500D6202400080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12TFS02103F906070E 003012
   ROD: EV_ECM12TFS_003_VW25.rod
   VCID: 24479D522FA3756A99-8070
   Part No SW: 0AM 300 060 G    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 4540
   Revision: 00043014    Serial number: CU501402286462
   Shop #: WSC 04940 001 00001
   VCID: 2E537F7ABA6FCF3A7F-5124
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 31414 790 31414
   VCID: 071DEADEB255BE729C-8052
03306 - Coding Not Valid
            000 -  -
                    Reset counter: 245
                    Mileage: 117848 km
                    Date: 2013.11.03
                    Time: 01:13:19
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3209
                    Hex Value: 0x1495
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
            000 -  -
                    Reset counter: 245
                    Mileage: 117848 km
                    Date: 2013.11.03
                    Time: 01:13:19
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3211
                    Hex Value: 0x1495
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6R0 907 044 B    HW: 6R0 907 044 B
   Component: Climatronic   H08 0305
   Revision: V0000000
   VCID: 326B6B0A6D57EBDA1B-8066
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 215
                    Mileage: 116995 km
                    Date: 2013.10.26
                    Time: 02:33:47
00457 - Control Module for Network (J519)
                    Fault Status: 00101101
                    Reset counter: 24
                    Mileage: 117395 km
                    Date: 2013.10.29
                    Time: 07:04:47
   Part No SW: 6R0 937 087 F    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0221
   Revision: BF046001    Serial number: 0345 252102308
   Coding: 24B02BBF08A1000001380000342B0ED000C0410F60040000200000000000
   Shop #: WSC 10551 001 1048576
   VCID: 408F31C2D3FB494A9D-8014
   Component: RLS 200710 05  54  0403
   Coding: 208941
   Subsystem 2 - Part No SW: 6R0 959 802 R    HW: 6R0 959 802 R  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  006 0903
   Serial number: KU0-KU023.09.1016705
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 801 T    HW: 6R0 959 801 T  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  006 0902
   Serial number: KU0-KU024.09.1010225
   Coding: 08BC30
   Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0341897
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Serial number: KU0-KU020.09.1017142
   Coding: 08BC32
   Subsystem 6 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Serial number: KU0-KU019.09.1010471
   Coding: 08BC32
   Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
   Component: VW10Airbag00N H09 0020
   Revision: --------    Serial number: 003GY001MC13
   Coding: 00304E
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4B9516EEE2BD9A1278-801E
   Serial number: 3572SRB40000CB5121B1
   Serial number: 3582SRB40000CBE4895M
   Serial number: 3515RRB405H01NFSCP71
   Serial number: 3525RRB404V02CB84H01
   Part No SW: 6R0 920 860 F    HW: 6R0 920 860 F
   Component: KOMBI         H04 0304
   Coding: 140A00
   VCID: 377D5A1E8E350EF22C-8062
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 0221
   Coding: 002300
   VCID: 70EFA102A3DB99CA2D-8024
   Component: IMMO          H04 0304
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADBB36A8D07631A63-803E
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668396309
   VCID: 275D8A5E56959E72BC-8072
   Part No: 6R0 423 156 B
   Component: LenkhilfeTRW        C277
   Coding: 11230
   Shop #: WSC 31414
   VCID: 2F6D627EEA65C63274-807A
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2K8585562
   Coding: 0500040002
   Shop #: WSC 00000 000 31414
   VCID: 6BD5B66E8AFD7A1218-803E
03138 - Input AUX IN
                    Reset counter: 215
                    Mileage: 116995 km
                    Date: 2013.10.26
                    Time: 02:34:02
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 051 730 D    HW: 1K8 051 730 D
   Component: Telefon       H03 6900
   Revision: 00003000    Serial number: 00000A07838834
   Coding: 402120
   Shop #: WSC 30049 959 91392
   VCID: 285F89625B8B910AB5-807C
End-------------------------(Elapsed Time: 03:26)--------------------------
iichel
Eindhoven, NB, NL
C?ID=284912
Try this please: 230228E3217100B4C42C14E884D400800700
Otherwise 230228E3217100B4C42C14E884D400801700
xbellx
Australia
C?ID=274333
Thanks iichel. I tried both those lines of coding but neither worked it came up with this window
any ideas.
Thanks Dave
xbellx
Australia
C?ID=274333
Sorry tried posting image, wont work for some reason but it says "Coding rejected Error 00: Unknown".
It is a right hand drive car if this makes any difference
iichel
Eindhoven, NB, NL
C?ID=284912
Check if the advanced ID sections of the engine, instruments and immobiliser all contain the same VIN please
xbellx
Australia
C?ID=274333
Checked VIN numbers in all the modules specified and they are all the same vin number.
I have been playing around with inputing some other numbers from a code generator I found online but still no good.
I now get a message displaying "Coding rejected Error:22 condition not correct or request sequence error."
Hope this helps
Thanks Dave
NEtech
Denmark
C?ID=56995
Maybe try: 230228E3417100B4C42C14E882D400801700
Jacek
Poland
C?ID=360566
See if you have an active time delay in abs.
Jef
HQ
So... we cool?
