2006 A4 Avant Quattro, APR stage 2+ 160K miles
Integrityautowerks
C?ID=5636
Good afternoon all, tried to follow instructions as close as possible for new posts. I'm seeking help as a means to learn the VCDS better and diagnose properly. Too busy fixing chevy trucks here in AR to work on my own stuff and learn by myself...need some training.
Car ran fine until recently. Noticed a loss of power and CEL came on for P310B. I know its a common problem but I'm not throwing parts at this. Vehicle came with AutoZone DElphi LPFP which has worked fine for 2 yrs. After code came on, they gave me a new fuel pump. Installed it and now the car only runs for about 10 min then shuts off. Then it becomes hard to start. If it does start, it will only run for a few minutes and shut down. If it sits until cool, it will restart & the process starts all over again.
I'm not replacing parts just bc they aren't OEM. I agreed to some degree aftermarket aren't the best, but that's not an excuse to replace parts...I want to learn this system and actually diagnose this problem. I need to prove a bad part as best as possible.
Tuesday,11,June,2019,13:13:43:19959
VCDS Version: 19.6.0.5 (x64)  HEX-NET CB: 0.4505.4
VIN: WAUKF78E96xxxxx   License Plate:
          67 69 75 76 77
VIN: WAUKF78E96A159082   Mileage: 258470km-160605miles
   Part No SW: 8E0 910 115 M    HW: 8E0 907 115 D
   Component: 2.0l R4/4V TFSI     0070
   Revision: --H10---    Serial number:
   Coding: 010C010A190F0120
   Shop #: WSC 25324 444 54344
   VCID: AB1668C70A48471793-80FE
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage - Intermittent
                    Mileage: 258478 km
                    Temperature: 24.0°C
                    Temperature: 28.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.192 V
012555 - Low Pressure Fuel regulation
               P310B - 008 - Fuel Pressure Outside Specification - MIL ON
                    Fault Status: 11101000
                    Mileage: 258478 km
                    RPM: 949 /min
                    Load: 29.4 %
                    Temperature: 25.0°C
                    Temperature: 27.0°C
                    Voltage: 13.716 V
Readiness: 0000 0101
   Part No SW: 8E1 910 156 C    HW: 09L 927 156 B
   Component: AG6 09L 2.0TFSI USA 0030
   Revision: --H01---    Serial number:        4115320
   Coding: 0000002
   Shop #: WSC 06325 000 00000
   VCID: A71E94F716A0637777-80F2
009783 - Torque Management Feedback Signal A
               P2637 - 000 -  - Intermittent
                    Fault Frequency: 8
                    Reset counter: 39
                    Mileage: 253756 km
                    RPM: 96 /min
                    (no units): 30.0
                    (no units): 25.0
                    Temperature: 48.0°C
                    T.B. Angle: 0.0°
   Part No SW: 8E0 910 517 E    HW: 8E0 614 517 AL
   Component: ESP8 quattro    H05 0120
   Coding: 0004528
   VCID: A91A92CF00B4550761-80FC
18265 - Load Signal
            P1857 - 000 - Error Message from ECU - Intermittent
                    Fault Frequency: 21
                    Hex Value: 0x3500
                    Hex Value: 0x4006
                    Hex Value: 0x0028
                    Hex Value: 0x01A8
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2832
   Coding: 00000
   VCID: ED92A6DFA5DC8927CD-50D0
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  USA 0504
   Coding: 11023
   Shop #: WSC 65536
   VCID: BB365887AB28D79703-4AA4
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H11 3540
   Revision: 91H1135    Serial number: 0036N0016SH+
   Coding: 0032607
   VCID: BC345B9BFF26D0AF0A-80E8
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 363UT
   Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB40275900FLÿ†63
   Subsystem 5 - Serial number: 5900FLÿ†6342DRB40275C98B ÿ†63
   Subsystem 6 - Serial number: 5C98B ÿ†6352ARB400B501436ÿ†63
   Subsystem 7 - Serial number: 501436ÿ†6362ARB400B39287Nÿ†63
   Subsystem 8 - Serial number: 39287Nÿ†63729RB400C57256Kÿ†63
   Subsystem 9 - Serial number: 57256Kÿ†63829RB400C57219Kÿ
   Subsystem 10 - Serial number: 57219Kÿ
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0601
   Coding: 04042
   Shop #: WSC 06325
   VCID: C1CA2A6FC9C4BD4759-4AA4
01304 - Radio
   Part No SW: 8E0 920 982 F    HW: 8E0 920 982 F
   Component: KOMBI+WFS 4     H12 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0023241
   Shop #: WSC 25324 444 84418
   VCID: B12A7AAF29642DC7A9-50F4
01304 - Radio
   Coding: 0023241
   VCID: B12A7AAF29642DC7A9-5118
01304 - Radio
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: F1AABAAFBAE46DC7E9-4B3C
   Part No: 8E0 959 433 BT
   Component: Komfortgerát T7B    3332
   Coding: 12156
   Shop #: WSC 06325
   VCID: 8444E37B9656686F32-4AA4
   Subsystem 1 - Part No: 8E1959801G
   Component: Tõrsteuer.FS BRM 0506
   Subsystem 2 - Part No: 8E1959802E
   Component: Tõrsteuer.BF BRM 0205
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
01572 - Alarm triggered by Door Contact Switch; Passenger Side
            35-00 - -
   Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
   Coding: 0000019
   VCID: A81C97CB1BBE6C0F7E-80FC
   Subsystem 1 - Part No: 8E0 941 329
   Component: AFS-Modul links H03 0020
   Subsystem 2 - Part No: 8E0 941 329
   Component: AFS-Modul rechtsH03 0020
   Part No SW: 8P0 862 335 G    HW: 8P0 862 335 G
   Component: FSE_255x BT     H21 0190
   Revision: 00000001    Serial number: 00000000348880
   Coding: 0001677
   VCID: BA385D83F412EE9F18-50D0
01304 - Radio
                    Reset counter: 158
                    Time Indication: 15
End----------(Elapsed Time: 05:13, VBatt start/end: 12.8V/12.8V)-----------
grant@gendan
Are you seeing sensible live values for Fuel Pressure in Measuring Blocks?
If you click the Advanced Measuring Values button, it should show a list of live data offered and hopefully you can find fuel pressure listed.
Your MAF fault may also be responsible for the engine cutting out.
Integrityautowerks
C?ID=5636
I agree with the MAF issue causing same problem. I slaved in a known good one and came up with same result.
blk 106
field 1 = 50 bar at idle
field 2 = 83.1 at idle. I know that is high. thinking bc its a delphi pump.
after shut down and a heat soak I drop to 3 bar in field 1.
blk 140 hpfp
field 3 = 50 bar
blk 230 field 3 = deviation .01-1
high side seems to be fine
I had the VCDS hooked up when it died this last time but don't know to how retrieve that data...
maybe I need to look at the MAF after it cools down again instead of fuel pressure...i'm not eliminating that as the culprit...It acted the same way the last time it went bad.
btw, I'm trying to get the erWin data but cant seem to figure out how to download the manual I need or get a price for the subscription...
grant@gendan
From your post, it sounds like you may have already seen the Ross-Tech Wiki page on this but here is the link for reference:
http://wiki.ross-tech.com/wiki/index.php/2.0l_TFSI_(AXX/BGB/BPJ/BPY/BWA)#Special_Functions
If you have already tried a different MAF, you can probably rule that out for the moment. Did the MAF fault code go away when you fitted the borrowed sensor?
Before the Fuel Pump was changed, the car ran ok but just threw up pressure faults, is that correct? Or did it have the same cutting-out symptoms as now?
NostraJackAss
Component: 2.0l R4/4V TFSI 0070 <<<<<<<<<<<<<<<<<<<<<<<<<<<< FIRMWARE UPDATE NEEDED!
blk 106
blk 140 hpfp
field 3 = 50 bar
Vehicle Identification No.WAUKF78E96A159082
Modelaudi a4 av. qu. 2,0
A4
Date of production06.12.2005
Model year2006
Sales type8ED5EL
Engine CodeBPG
Transmission CodeJJE
Emission standard7GBEmission standard ULEV 2
OP: Can you clear fault codes and re-post the new auto-scan & with additionally the OBD2 data MODES 1-01, 3, 7 & 9 please?
OP: Have you checked to be sure the integrated FPR in fuel filter is working as specified with new lift pump & for volume using mechanical tests such as gauges and V-metric confirmed delivery?
OP: Did you check the fuel module control unit for proper function ground and ability carry AMP load capacity to lift pump & did you measure the duty cycle with DVOM or observe in VCDS?
OP: Is the mechanical HPP in proper order & stroke of lifter or cam ramp correct?
JPPSG lately?
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Tuning by definition is induced FOD!
Check for ECU water ingress!
Integrityautowerks
C?ID=5636
I did follow that guide and took notes of pressure settings waiting for the engine to die and hopefully capture the cause. The MAF code came on bc I started the engine with the MAF connector disconnected after swapping it and didn't erase it.
So the engine ran ok but at lower power than normal. Stage 2 on this engine is like a bull out of the gates, it began to accelerate slower and took longer to get up to speed. It never cut out though.
Integrityautowerks
C?ID=5636
Ok...first off, Im having no luck getting a service manual for this car. Andy (Rosstech) confirmed to me this morning that Bentley has been superseded by erWin (and doesn't provide good data on the FSI engine) and I cant figure out the website to get the troubleshooting data I need. I'm continuing efforts to get that data...
I will try to start engine, clear codes and repost data requested. Not sure about the OBD2 data modes requested. I'll search for those.
I haven't taken FPFP off yet bc I'm pulling data first. Its on my visual check list though.
I have not checked the FPR in the filter yet. I have not checked volumetric efficiency bc I don't have tech data to tell me what to expect.
VCDS showed 83.1 duty cycle at idle if that's what you're asking.
Jack, I did read your post about FOD in the ecu...I will do an inspection of the part. I've done plenty of FOD walks on the flight line keeping our B52s flying.
Tuesday,11,June,2019,16:49:27:19959
VIN: WAUKF78E96A159082   License Plate:
Mileage: 258470km-160605mi   Repair Order:
          67 69 75 76 77
                    Fault Status: 01101000
                    Mileage: 258479 km
                    RPM: 944 /min
                    Load: 24.7 %
                    Temperature: 36.0°C
                    Temperature: 31.0°C
                    Voltage: 13.843 V
   Coding: 0000002
                    Fault Frequency: 8
                    Reset counter: 39
                    Mileage: 253756 km
                    RPM: 96 /min
                    (no units): 30.0
                    (no units): 25.0
                    Temperature: 48.0°C
                    T.B. Angle: 0.0°
   Coding: 0004528
18265 - Load Signal
                    Fault Frequency: 21
                    Hex Value: 0x3500
                    Hex Value: 0x4006
                    Hex Value: 0x0028
                    Hex Value: 0x01A8
                    Hex Value: 0x0001
   Coding: 00000
   Coding: 11023
   Shop #: WSC 65536
   Coding: 0032607
   Coding: 04042
   Shop #: WSC 06325
01304 - Radio
   Coding: 0023241
01304 - Radio
   Coding: 0023241
01304 - Radio
   Coding: 00002
   Coding: 12156
   Shop #: WSC 06325
            35-00 - -
   Coding: 0000019
   Coding: 0001677
01304 - Radio
                    Reset counter: 158
                    Time Indication: 15
End----------(Elapsed Time: 05:12, VBatt start/end: 14.0V/14.0V)-----------
Tuesday,11,June,2019,16:56:19:19959
VCDS Release 19.6.0 (x64):  Generic OBD2
Mode 01 - PID 01 : Readiness  --  Address 7E8
Number of DTCs stored: 0  --  MIL Status: MIL OFF
Misfire monitoring:  Passed
Fuel System:  Passed
Comprehensive Components:  Passed
Catalyst monitoring:  Failed or Incomplete
Heated catalyst monitoring: Not installed.
Evaporative system monitoring:  Failed or Incomplete
Secondary air system monitoring: Not installed.
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring: Not installed.
Oxygen sensor heater monitoring: Not installed.
Exhaust Gas Recirculation: Not installed.
Tuesday,11,June,2019,16:56:57:19959
Mode 03: Emission related fault codes
Address 7E8: No fault code found.
Address 7E9: No fault code found.
Tuesday,11,June,2019,16:57:34:19959
Mode 07: Pending emission related fault codes
Address 7E8: 1 Fault Found:
P0089 - Valve for Fuel Metering (N290): Implausible Signal
Tuesday,11,June,2019,16:57:55:19959
Type 02 - VIN : WAUKF78E96A159082 (Address E8)
Type 04 - Calibration ID : 8E0910115M  0071 (Address E8)
Type 04 - Calibration ID : 8E1910156C  0030 (Address E9)
Type 06 - Calibration Verification Number : 483FB60A (Address E8)
Type 06 - Calibration Verification Number : D63D83FA (Address E9)
I cleared out codes, started engine and auto scanned. P310B came back immediately.
Also posted OBD2 data for Jack.
NostraJackAss
Nein! Measure using the RTFB & proper tools + specs .....not just a visual!
RTFB can be had here and yes indeed the website works!
https://erwin.audiusa.com/erwin/showHome.do
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
Awesome...... thank you very much!
Integrityautowerks
C?ID=5636
I'm sure the erWin site works...I just cant figure out how to create a log in to get the data. No data means nein on the technical inspection of the HPFP and associated parts.
Integrityautowerks
C?ID=5636
getting back from some life issues...
I decided to check voltage from the FPCM to the fuel pump itself and found 8 volts at idle and 8.5 volts and full throttle. Has anyone ever tested the FPCM in this manner? Couldn't find a proceedure in the Bentley. Additionally, the FPCM is getting 12v from applicable fused source. Not sure of the exact science of the FPCM, but 8 volts feeding a 12v motor sure does seem to lower fuel pressure. Comments...
HMC
C?ID=28246
What did you test it with? Without checking my guess is that this could be PWM that needs testing with a scope.
Regards HMC
Integrityautowerks
C?ID=5636
since the fuel pump operates on DC voltage I used an analog and digital voltmeter. A scope would be nice but I don't have one yet. I have since replaced the FPCM and my voltage went up to 8.3V at idle and 8.7 full throttle.
NostraJackAss
WTF are you thinking, does your DVOM support PWM or TRIG/MS, because some do?
Pulse Width Modulation...............
Injector works same way!
Better watch some how too's!
Integrityautowerks
C?ID=5636
Hi Grant,
Maybe you can help me decipher these fuel values.
Engine runs for 10 minutes then shuts off. All readings are at idle bc I can't rev engine and read blocks at same time.
On initial start up blk 103 = 1.62 bar, 4000 FPR, 1720 ADAPT, OK STATUS
blk 106 = 50.6 bar, 83.1% pump,
blk 140 = 50.6 bar for actual rail pressure
10 later... engine slowly dies
blk 103 = 1.63 bar, 4K, 2237, OK
blk 106 = 2.6 bar, 83.5%
blk 230 = 49.9 bar specified, 2.6 bar actual, 47 bar difference.
So, my fuel pressure in block 103 should be about 6 bar (as I understand it) but the rail pressure still runs about 50 bar initially.
As the engine dies, blk 103 stays the same but blk 106 rail pressure drops to 2.6 and this is too low to keep the engine running.
Isn't the fuel rail pressure controlled by the FPR on the HPFP?
What do I need to look at next?
There are two pressures. The low-pressure supply from the tank, which is controlled by the duty cycle to the electric transfer pump. Then there is the high pressure rail. This is produced by the mechanical high pressure pump and controlled by the FPR. If the rail pressure is dropping off, it could be a problem with the high pressure pump, or the FPR.
NostraJackAss
Hi Grant,
A key thing to observe with FP volume and pressure regardless of HPP or Lift type pumps okay?
As fuel PSI increases, over all flow or capacity decreases, did you know that?
Did you know you can have "air pressure" with nil or no fuel flow and is why volume tests of fuel expelled and measured is mandatory?
Did you know when observing the duty cycle and over all PSI readings of a fuel rail or FPR, they should be used as a guide in VCDS and cross checked to mechanical actual tests, have you done them yet?
You are playing with a modified car with FOD!
Ever consider the reason to do mechanical's first versus rely on such scanner readings and because "someone" might change the base table math to report in the diagnostic stack dictionary, a false number to evade a DTC table and while reporting fake MVB in actual calculated values you maybe observing & to make themselves look less devious than they want people to see?
Mechanical tests and compare of files always shows the FOD even if well hidden!
Integrityautowerks
C?ID=5636
Uwe, I do understand there are 2 fuel systems in this fuel system. My concern is with blk 103. Bentley states the lift pump should be 6 bar. Mine isn't getting over 2 bar while at idle. The high side is within spec the first 8 min of running, then the high side drops off while the low side is a steady 1.6 bar.
My theory is that the fuel rail is full and pressurized on start up. As the engine consumes fuel, the lift pump isn't supplying the needed volume to keep up with the demand. So when the rail gets low on volume the pressure drops off gradually until it dies.
Jack,
I do understand Pascals principal. 21 yrs of hydraulic work on USAF aircraft, I've learned some things. Pressure and flow are inversely proportional. I unfortunately don't have the mechanical fuel pressure tester to test this system. I've considered quite a few thing but I'm stuck with using the tools I own and can afford to justify. I understand your love of FOD based on your posts. The car was running fine for 2 yrs before this issue came up.
NostraJackAss
Checked the fuel filter?
+1 doesn't it have a combined regulator too? :p
https://forums.ross-tech.com/showth...e-2-160K-miles&p=167041&viewfull=1#post167041
Jack,
A regular fuel PSI gauge is not very expensive in comparison to parts costs is it?
Are smooth line pinch pliers that far off on budget?
With your USAF experience couldn't you fabricate a cheap homemade gauge set for HPP?
Thank you for your service to the Country by the way........
