Golf IV Variant 2003
Engine BCB
EPC light lits first - after a while Engine light comes on.
After restart - no MIL.
Fault code: 17950 - Angle Sensor 1 for Throttle Actuator (G187): Implausible Signal
Below I have erased the fault vode - the rest looks like this - after couple of test drives - the MIL on again:
The Throttle body is changed sometime before - VDO.
And Measuring block 062 looks like this with resting accelerator pedal - engine off:
And with pedal on floor
% on both pedal position sensor 1 and 2 are the same! (Throttle position sensors % were moving as they should - this above was measured with engine off)
Is the pedal sensor known to go bad or is there somewhere alse I should take a look before changing the pedal/sensor?
Can the sensor be fixed?
Engine BCB
Monday,10,June,2019,17:16:55:18201
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4436.4
Dealer/Shop Name: Firma Johannes Bruun
Workshop Code: 000 02013 000000
VIN: WVWZZZ1JZ3W270756 License Plate: SDD744ROSSTECH
Mileage: 224990km-139802mi Repair Order:
76
VIN: WVWZZZ1JZ3W270756 Mileage: 224990km-139802miles
Address 01: Engine Labels: 036-906-034-AZD.clb
Part No: 036 906 034 DR
Component: MARELLI 4MV G 5957
Coding: 00031
Shop #: WSC 40150
VCID: 6597B3CE2C75B7BF0DB-4B5C
WVWZZZ1JZ3W270756 VWZ6Z0B0301606
Readiness: 1010 0001
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001025
Shop #: WSC 01266 785 00200
VCID: 33331D96D721190F53F-51A8
Part No: 1C0 909 605 A
Component: 27 AIRBAG VW51 01 0006
Coding: 12855
Shop #: WSC 01266
VCID: 221DE8D27DDB8087A89-5184
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 806 B
Component: KOMBI+WEGFAHRS. RB8 V24
Coding: 05113
VCID: 2615F4C211F37CA7C41-5184
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 01266
VCID: 70B9D29AE3B762176ED-5184
Part No: 1C0 959 799
Component: 1F Komfortgerát HLO 0001
Coding: 00259
Shop #: WSC 01266
VCID: 74B1DE8A97AF5E378A5-4B3C
Component: 1F Tõrsteuer.FS KLO 0004
Component: 1F Tõrsteuer.BF KLO 0004
Component: 1F Tõrsteuer.HL KLO 0004
Component: 1F Tõrsteuer.HR KLO 0004
27-00 - Implausible Signal
End----(Elapsed Time: 05:00, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
17:18:08 Group 062: Electronic Throttle (Sensor Values)
4.9 % Throttle Valve Sensor 1 (G187)
94.4 % Throttle Valve Sensor 2 (G188)
14.0 % Accel. Pedal Pos. Sensor 1 (G79)
14.0 % Accel. Pedal Pos. Sensor 2 (G185)
17:18:08 Group 060: Electronic Throttle (Throttle Body Alignment)
94.0 % Throttle Valve Sensor 2 (G188)
12.0 Throttle Valve Steps Counter
ADP. O.K. Throttle Body Alignment Status
17:18:08 Group 061: Electronic Throttle
0 /min Engine Speed (G28)
Battery Voltage (Terminal 30)
27.1 % Throttle Valve Angle
00000 Operating Condition
17:20:28 Group 062: Electronic Throttle (Sensor Values)
79.0 % Accel. Pedal Pos. Sensor 1 (G79)
78.0 % Accel. Pedal Pos. Sensor 2 (G185)
