O2 Sensor Replaced - MIL on and showing same O2 faults
cdheikkila
C?ID=352193
I just replaced both upstream O2 sensors myself on my 2006 Audi A6 Avant, and I cleared the existing O2 codes after I was done, but they are still there. Does this seem to be something other than the sensors themselves or will these go away after a period of driving again?
Thank you !!
Sunday,09,June,2019,11:57:59:55997
VCDS Version: 19.6.0.4 (x64)  HEX-V2 CB: 0.4505.4
VIN: WAUKG74F76N063701   License Plate:
Mileage: 279240km-173511mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
          53 55 56 61 62 65 67 72 76 77
VIN: WAUKG74F76N063701   Mileage: 279240km-173511miles
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 4F2 910 559 B    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0030
   Revision: --H15---    Serial number:
   Coding: 0000000000000000
   Shop #: WSC 22162 444 53437
   VCID: 2B0305BDFF089B8F4F5-807E
000304 - Oxygen (Lambda) Sensor B1 S1
               P0130 - 006 - Malfunction in Circuit - Intermittent - MIL ON
                    Fault Status: 10100001
                    Fault Frequency: 32
                    Mileage: 279066 km
                    Date: 2019.05.31
                    Time: 15:14:03
                    RPM: 832 /min
                    Mass Air / Rev.: 169.0 mg/str
                    Temperature: 36.0°C
                        Idle
                    Voltage: 13.57 V
                    Bin. Bits: 00000010
008785 - Oxygen (Lambda) Sensor B1 S1: Negative Lead
               P2251 - 007 - Open Circuit - MIL ON
                    Fault Status: 10100010
                    Fault Frequency: 31
                    Mileage: 279066 km
                    Date: 2019.05.31
                    Time: 15:14:09
                    RPM: 832 /min
                    Mass Air / Rev.: 174.4 mg/str
                    Temperature: 37.5°C
                        Idle
                    Time: 76.8 s
                    Bin. Bits: 00000100
004502 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1
               P1196 - 006 - Electrical Malfunction - Intermittent
                    Reset counter: 23
                    Mileage: 279077 km
                    Date: 2019.06.01
                    Time: 10:09:11
                    RPM: 672 /min
                    Mass Air / Rev.: 136.3 mg/str
                    Temperature: 69.0°C
                        Idle
                    Time: 51.2 s
                    Bin. Bits: 00000010
   Part No SW: 4F1 910 156 P    HW: 09L 927 156 A
   Component: AG6 09L 3,2 FSI USA 0030
   Revision: --H01---    Serial number:        4068051
   Coding: 0000002
   Shop #: WSC 02327 785 00200
   VCID: 313F17D5DD24F15F759-8064
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H04 0090
   Coding: 0020895
   VCID: 2D070BA5C11C95BF511-8078
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0240
   Revision: 07020801    Serial number: 10600600229680
   Coding: 0000143
   Shop #: WSC 22162 444 84622
   VCID: 6393AD9DD75813CFB75-8036
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 KSG   H26 0080
   Component: FBSAUDIC6 IDG   H44 0060
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 732 Q    HW: 4E0 035 729
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 303HJ057505560
   Coding: 0001003
   Shop #: WSC 02335 785 00200
   Component: Bedienteil MMIC6H07 0050
   Subsystem 2 - Serial number: 00000000208947
   Subsystem 3 - Serial number: 0129.07.050000000100010125ÿ
   Subsystem 4 - Serial number: 010125ÿ
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 234
                    Mileage: 279241 km
                    Date: 2019.06.09
                    Time: 11:52:51
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043     HW: 4F1 820 043 S
   Component: KLIMABETAETIGUNGH12 0160
   Revision: 00000027    Serial number: 00000000171457
   Coding: 0524582
   VCID: 5BE3957DEF282B0FFF5-800E
   Part No SW: 4F0 910 279 D    HW: 4F0 907 279
   Component: ILM Fahrer      H15 0190
   Coding: 0014123
   VCID: 2A0D00B9F0F28287B43-807E
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBE7216688
   VCID: 1C61D661AAA66C3736F-8048
Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
   Part No SW: 4E0 910 593 G    HW: 4E0 035 593 C
   Component: SDAR XM         H04 0670
   Revision: 00000000    Serial number: AUZ4Z7E2029525
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 66 AIRBAG AUDI8RH29 0300
   Revision: 12H29000    Serial number: 00359D0A1KM/
   Coding: 0013878
   Subsystem 1 - Part No: 4F0 910 339 A
   Component: BF-Gewichtsens. H02 0050
   Subsystem 2 - Serial number: 6332CSME0B1468191
   Subsystem 3 - Serial number: 6342CSME0A775A6CJ
   Subsystem 4 - Serial number: 6352QSME036211796
   Subsystem 5 - Serial number: 6362QSME04522F15C
   Subsystem 6 - Serial number: 63734SME03440C4D+
   Subsystem 7 - Serial number: 63834SME044F41771
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026052070161
   Coding: 0002042
   Shop #: WSC 02323 785 00200
   VCID: 6695B489246A66E750B-8032
   Component: Lenkradmodul    H07 0080
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 A    HW: 4F0 920 980 N
   Component: KOMBIINSTR. M73 H16 0630
   Revision: 00000000    Serial number: 4PY175X75
   Coding: 2129263
   VCID: 211FE7958DC441DFE59-8074
Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H11 0070
   Revision: 11          Serial number: 13008058118151
   Coding: ECFE73CD1B7904
   VCID: 270BF98DE3E0BFEFABD-8072
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082954
   VCID: 619FA795CD4401DFA59-8034
   Part No SW: 4E0 910 887 N    HW: 4E0 919 887 C
   Component: MNS US          H45 0740
   Revision: 00000000    Serial number: 355GS057552228
   VCID: 38292AF13E5E2017327-806C
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
   Component: TSG FA          H12 0080
   Revision: 00-00000
   Coding: 0052971
   Shop #: WSC 98765 666 36911
   VCID: 2C0106A1FA069CB746F-8078
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
   Component: Komfortgeraet   H19 0140
   Revision: 01400019    Serial number: 01006252890000
   Coding: 4618813
   VCID: 2E050CA9CC1AEEA768B-807A
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 A    HW: 4F0 035 223 A
   Component: DSP-High C6     H09 0140
   Revision: PROD_01     Serial number: 00000000702172
   Coding: 0000126
   Shop #: WSC 22162 444 13633
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000005735
   Coding: 0002114
   VCID: 5EE59C69FC3A3E2798B-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
   Component: TSG BF          H12 0080
   Revision: 00-00000
   Coding: 0052971
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0005022
   Shop #: WSC 02334 785 00200
   VCID: 5DE79B65F13C253F811-8008
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Component: AFS 1           H01 0030
   Coding: 0000016
   VCID: 2615F489E4EAA6E790B-8072
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
02626 - Dynamic Cornering Light Motor; Right (V319)
                    Fault Status: 11101010
                    Reset counter: 234
                    Mileage: 279240 km
                    Date: 2019.06.09
                    Time: 11:52:53
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 B
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 394HO057601711
   Coding: 0000002
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H12 0490
   Revision: 00000000    Serial number: 00000000088324
   Shop #: WSC 26107 444 01170
   VCID: 2313ED9D97D853CFF75-8076
   Subsystem 1 - Part No: 4F0 915 105 E
   Component: von VA0  00915105CE
   Coding: 344630393135313035452056413030303931353130354345
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0050
   Coding: 0052778
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273     HW: 4F0 907 273
   Component: Reifendruck 3   H04 0080
   Revision: 00040080    Serial number: 00000900008357
   Coding: 0062221
   VCID: 6099A291C64E08D7AA7-8034
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000508050033
   Shop #: WSC 12336 024 394758
   VCID: 34311EC12236C4771EF-8060
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0050
   Coding: 0052778
   Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
   Component: Parkhilfe 4-Kan H09 0020
   Revision: 00H09000    Serial number: 11720521406897
   Coding: 0001216
Address 77: Telephone
End----------(Elapsed Time: 01:56, VBatt start/end: 13.4V/13.5V)-----------
NostraJackAss
Component: 3.2l V6 FSI 0030 <<<<<<<<<<<<<<<<<<<<<<<<< UPDATE PROGRAMMING NEEDED!
Thank you !!​
Because the car is running emission deletes FOD tuning.........and the sensors could be wrong part numbers, short in wiring harness or the ECU is FUBAR!
JPPSG
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Larry Manton
C?ID=112505
CD, would appear even more definitive, coding indicates negative lead on that sensor.
As Jack stated either At ECU or between, need wire diag and some time or move to a shop.
Bin. Bits: 00000010
Fault Frequency: 31
Mileage: 279066 km
Date: 2019.05.31
Time: 15:14:09
cdheikkila
C?ID=352193
A tad late, but figured I should close out this post regarding the O2 sensor coding. After a short period of driving these codes disappeared a while back.
