2008 VW Tiguan TDI no start
FIS
Norway
C?ID=368573
Hello all
So, I've been fixing up a stock 2008 VW Tiguan with the 2.0TDI CBAB engine and ATX transmission (Not the DSG) which had alot of broken parts.
So the car was driveable and was starting fine before I started fixing it, but after I've replaced and changed the listed parts the car would not start at all.
Here's a list of what was done and replaced:
Timing belt, water pump, auxiliary belt.
Transmission seal/gasket
Every filter (oil, diesel, air etc.)
Oil and antifreeze
Rear differential filter + oil
Brakes (pads, rotors)
DPF was opened and the shit inside was removed (Needs to be repogrammed to fully delete it)
EGR was blocked off (Needs to be repogrammed to fully delete it)
P2015 repair bracket installed
And possibly some other parts that I forgot.
(The parts replaced are not OEM ones. But no electircal part is changed)
So, after the car was put back together, I first messed up the fuel lines for the filter. But after a while I managed to get them put on correctly.
After this the car would not fire up. I did the classic mistake of not firing it up after each part was changed :(
So after diagnosing the basic I've had a P242A (O2 sensor) and P0016 code (crank sensor) but we tapped into the wiring for the Cam sensor and the Crank sensor and found out they both did have a 0 and 5v signal on the signal wire as they should.
After using alot of starter gas the car fired up eventually, the idle was ok but it was hard to get it fired up, VERY.
Let the car run for a while, and it seemed fine. Stopped it and let it sit for a day or two, and still a pain to fire up, but once it was given a ton of starter gas it fired up and ran steady, and the idle was once again fine.
The car was taken for a test drive and it seemed to drive and shift ok. But after a kickdown and the rev got to 3k RPM the car died instantly with yet another no start.
Towed the car back home and gave it a ton of starter gas but this time it was no response. Codes were still P242A and P0016.
Rechecked the timing, which was spot on. and I've checked the wiring a dozen times, every connector is checked and connected and I'm at a total loss now.
I've decided to hook it up to VCDS to get a more detailed log so hopefully you guys can help me sort this issue.
I don't believe the empty DPF or the EGR is the cause of this no start? and I don't think the P0016 is the reason either since the car did start after a while at first, but I am no expert on VW.
Every damn fuse is checked visually and taken out and tested with a multimeter
Car has been charged and tried to start, so this log might show a lov voltage.
Saturday,08,June,2019,13:32:08:31215
VCDS Version: 19.6.0.4 (x64)  HEX-V2 CB: 0.4505.4
VIN: WVGZZZ5NZ9W521446   License Plate: UF40565
Mileage: 294900km-183242mi   Repair Order:
Chassis Type: 5N (1K0)
Scan: 01 02 03 08 09 15 16 17 18 19 22 25 42 44 46 52 53 55 56 62
          72
VIN: WVGZZZ5NZ9W521446   Mileage: 294900km-183242miles
18-Aux. Heat -- Status: Cannot be reached 1100
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 997 016 H    HW: 03L 906 022 G
   Component: R4 2.0l TDI 0000AG  9979
   Revision: 13H01---    Serial number: VWX7Z0H93N88Q8
   Coding: 0000175
   Shop #: WSC 80093 222 71269
   VCID: 372B2A6D734A1A4F3BD-8062
009258 - Exhaust Gas Temperature Sensor; B1 S3
               P242A - 000 - Malfunction
                    Mileage: 294909 km
                    Time: 00:04:44
                    Voltage: 11.70 V
                    Temperature: 7.2°C
                    Temperature: 18.0°C
                    Temperature: 930.0°C
                    Temperature: 6.0°C
               P242A - 000 - Malfunction - MIL ON
                    Fault Status: 11100000
                    Mileage: 294909 km
                    Time: 00:04:48
                    Voltage: 11.70 V
                    Temperature: 7.2°C
                    Temperature: 18.0°C
                    Temperature: 6.0°C
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
               P0016 - 000 - Incorrect Correlation - Intermittent
                    Mileage: 294909 km
                    Time: 00:05:09
                    RPM: 161 /min
                    Load: 83.9 %
                    Voltage: 9.73 V
                    Idle Stabilization: 57.1°KW
                    RPM: 80 /min
                    (no units): 33.0
   Part No SW: 09G 927 750 FD    HW: 09G 927 750 FD
   Component: AQ 250 6F           1124
   Revision: 00H76000    Serial number:
   Coding: 0000328
   VCID: 78A9E9513ED4D537F27-802C
                    Reset counter: 38
                    Mileage: 283072 km
                    Reset counter: 159
Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
   Part No SW: 5N0 614 517 L    HW: 5N0 614 517 L
   Component: J104    C2 450 V2   0006
   Revision: --H12---    Serial number: 00000001509462
   Coding: 0010530
00576 - Terminal 15
                    Reset counter: 13
                    Mileage: 294907 km
                    Time: 00:09:51
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00111110
                    Count: 123
                    Hex Value: 0x0000
                    Reset counter: 13
                    Mileage: 294907 km
                    Time: 00:24:57
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011110
                    Count: 170
                    Hex Value: 0x0000
01201 - ABS Pump Supply Voltage
                    Fault Status: 00101100
                    Reset counter: 229
                    Mileage: 294908 km
                    Time: 19:18:12
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00111110
                    Count: 249
                    Hex Value: 0x0000
                    Reset counter: 229
                    Mileage: 294908 km
                    Time: 19:18:12
   Part No SW: 1K0 907 044 DC    HW: 1K0 907 044 DC
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 6B83C61D7F826EAF0F5-803E
01810 - Actuating Motor for Temperature Flap; Right (V159)
   Revision: 00H54000    Serial number: 00000009022756
   Coding: EE8A8FA3010415004719000014000000000BFB475C400125420000000000
   Shop #: WSC 00000 785 00200
   VCID: 33331E7D6732F66F075-8066
   Subsystem 1 - Part No: 5N1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 011008  012 0203
   Coding: 00038805
   Component: RLS     140708 046  0204
   Coding: 00208933
10 Faults Found:
                    Fault Status: 01111100
                    Reset counter: 229
                    Mileage: 290999 km
                    Voltage: 11.15 V
00156 - Control Circuit for Windshield Washer Pump
                    Fault Status: 00101001
                    Reset counter: 14
                    Mileage: 294908 km
                    Voltage: 12.10 V
02398 - Control Circuit for Rear Windshield Washer Pump
                    Reset counter: 14
                    Mileage: 294908 km
                    Voltage: 12.10 V
00924 - Relay for Headlamp Cleaning System (J39)
                    Reset counter: 12
                    Mileage: 294907 km
                    Voltage: 12.60 V
02071 - Local Databus
                    Reset counter: 12
                    Mileage: 294907 km
                    Voltage: 12.60 V
01516 - Terminal 30; Left
                    Fault Status: 00101011
                    Reset counter: 14
                    Mileage: 294908 km
                    Voltage: 12.10 V
02403 - Terminal 15 for Interior
                    Reset counter: 7
                    Mileage: 294257 km
                    Voltage: 11.65 V
                    Reset counter: 12
                    Mileage: 294907 km
                    Voltage: 12.60 V
00926 - Terminal 30
                    Reset counter: 12
                    Mileage: 294907 km
                    Voltage: 5.00 V
00927 - Terminal 30 (Right)
                    Reset counter: 14
                    Mileage: 294907 km
                    Voltage: 12.55 V
   Component: J234__200 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPL90150
   Coding: 0012336
   VCID: 3B23365D4F623E2FDF5-806E
   Subsystem 1 - Serial number: 6333FTS670172618
   Subsystem 2 - Serial number: 6343FTS624302618
   Subsystem 3 - Serial number: 6353ETS6IVDCVVNR
   Subsystem 4 - Serial number: 6363ETS66E67VVNR
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Coding: 0010012
   VCID: 77ABEA6D33CADA4FFBD-8022
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
   Part No SW: 5N0 920 870 D    HW: 5N0 920 870 D
   Component: KOMBIINSTRUMENT VDD 2420
   Revision: V0004000    Serial number: VWX7Z0H93N88Q8
   Coding: 0007104
   Shop #: WSC 80093 222 69422
   VCID: 313F14759D2EC47F759-8064
                    Reset counter: 12
                    Reset counter: 12
                    Mileage: 294907 km
                    Time: 00:24:57
Address 18: Aux. Heat
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 180808F1000659
   Coding: FD837F06000A026002
   VCID: 353720656946E85F291-8060
                    Fault Status: 00110100
                    Reset counter: 11
                    Mileage: 294907 km
                    Time: 17:26:06
                    Reset counter: 227
                    Mileage: 286716 km
                    Time: 08:38:57
   Part No SW: 0AY 907 554 B    HW: 0AY 907 554 B
   Component: Haldex 4Motion      0039
   Coding: 0000001
   VCID: 4ACD639910B897A7543-801E
02248 - Valve for Controlling Clutch Operating Angle (N373)
                    Fault Status: 11001000
                    Fault Frequency: 34
                    Reset counter: 36
                    Mileage: 3618101 km
                    Time Indication: 4
                    Work Shop Code: 66304
                    Raw, Form. N/A: 000 000 000
                    Fault Frequency: 34
                    Reset counter: 36
                    Mileage: 3618101 km
                    Time Indication: 4
   Component: IMMO            VDD 2420
   Part No SW: 5N0 959 701 B    HW: 5N0 959 701 B
   Component: Tuer-SG         008 2005
   Coding: 0000188
   VCID: 34311D61623CF1571EF-8060
   Part No SW: 5N1 909 144 G    HW: 5N1 909 148 E
   Component: J500__APA-BS KL.098 0401
   Revision: 1AH01251    Serial number: 00082110381002
   Coding: 0000258
   VCID: 363527697440E34720B-8062
01288 - Terminal 30; Steering Assist
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Fault Priority: 9
                    Fault Frequency: 9
                    Reset counter: 229
                    (no units): 2.0
                    Voltage: 10.70 V
                    Fault Status: 11100101
                    Reset counter: 229
                    (no units): 4.0
                    Steering Angle: 0.00°
                        Not OK
                    (no units): 0
   Component:    KSG PQ35 G2  020 0205
   Coding: 80800A0052830C7F3F04840560084F0BE0FC00
   VCID: 03538EBD771286EFD75-8056
00332 - Control Circuit for Tank Flap
                    Fault Status: 00110111
                    Reset counter: 12
                    Reset counter: 12
                    Mileage: 294907 km
                    Time: 17:26:05
   Part No SW: 5N0 959 702 B    HW: 5N0 959 702 B
   Coding: 0000188
   Part No SW: 5N0 907 801 B    HW: 5N0 907 801 B
   Component: J540 EPB3  VW-09384 0005
   Revision:   H09       Serial number: 00000000136376
   Coding: 0000057
   VCID: 2E050F098C10DB8768B-807A
00576 - Terminal 15
                    Reset counter: 227
                    Mileage: 294907 km
                    Voltage: 11.60 V
                    Count: 54
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 11
                    Mileage: 294907 km
                    Voltage: 11.60 V
                    Count: 76
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 11
                    Mileage: 294907 km
                    Voltage: 11.50 V
                    Count: 73
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Component: AFS-Steuergeraet    0136
   Coding: 1361030
   Component: AFS-Lst.-Modul l    S004
   Coding: 00000020
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    S004
   Coding: 00000020
                    Reset counter: 12
                    Mileage: 294907 km
                    Time: 00:24:57
                    Voltage: 11.79 V
                        ABS 1
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  012 0029
   Revision: 00000000    Serial number: VWZ1Z2H5519552
   Coding: 0500040004
   VCID: 6B83C61D73826EAF0F5-803E
03138 - Input AUX IN
                    Reset counter: 26
                    Mileage: 286187 km
                    Time: 19:18:48
   Part No SW: 5N0 959 703     HW: 5N0 959 703
   Component: Tuer-SG         006 1301
   Coding: 0000144
   Shop #: WSC 00000 785 1012552
   VCID: 74B1DD6122BCB157DEF-8020
   Part No SW: 5N0 959 704     HW: 5N0 959 704
   Coding: 0000144
   VCID: 75B7E06529C6A85FE91-8020
End----(Elapsed Time: 01:32, VBatt start/end: 11.3V/11.3V. VIgn 11.3V)-----
Saturday,08,June,2019,13:38:33:31215
          72
   Coding: 0000175
                    Mileage: 294909 km
                    Time: 00:04:44
                    Voltage: 11.70 V
                    Temperature: 7.2°C
                    Temperature: 18.0°C
                    Temperature: 6.0°C
                    Mileage: 294909 km
                    Time: 00:04:48
                    Voltage: 11.70 V
                    Temperature: 7.2°C
                    Temperature: 18.0°C
                    Temperature: 6.0°C
                    Mileage: 294909 km
                    Time: 00:05:09
                    RPM: 161 /min
                    Load: 83.9 %
                    Voltage: 9.73 V
                    RPM: 80 /min
                    (no units): 33.0
   Coding: 0000328
   Coding: 0010530
   Coding: 00038805
   Coding: 00208933
                    Fault Status: 01101100
                    Reset counter: 229
                    Mileage: 294909 km
                    Voltage: 11.10 V
                    Reset counter: 229
                    Mileage: 294909 km
                    Voltage: 11.10 V
   Coding: 0012336
   Coding: 0010012
00576 - Terminal 15
   Coding: 0007104
                    Reset counter: 229
                    Mileage: 294909 km
                    Time: 00:05:36
   Coding: 0000001
   Coding: 0000188
   Coding: 0000258
                    Reset counter: 229
                    Mileage: 294909 km
                    Time: 00:08:07
                    (no units): 4.0
                        Not OK
                    (no units): 6
   Coding: 0000188
   Coding: 0000057
   Coding: 1361030
   Coding: 00000020
   Coding: 00000020
   Coding: 0500040004
   Coding: 0000144
   Coding: 0000144
End----(Elapsed Time: 01:19, VBatt start/end: 11.1V/11.1V. VIgn 11.1V)-----
Hope some of you got some nice tips on what's causing the starting issue.
Cheers.
smokey08
C?ID=120732
Looks to me like you have fitted the crankshaft oil seal incorrectly or the camshaft timing it not correct.
NostraJackAss
Timing belt set incorrectly for offset of tensioner to zero angle.
You should take notes and or pictures before working on stuff and follow an order!
RTFB......
Forced induced FOD for sure!
FIS
Norway
C?ID=368573
Crankshaft oil seal is fitted correctly.
I followed this nice guide on how replacing the timing belt. (https://www.techtips.ie/Contitech/vw-20l-cbdb-common-rail-engines-timing-belt-guide-1.pdf) and I've also checked and doublechecked it since. I even made my own marks on the camshaft, the fuel pump and the teeth's for those marks to be sure the old and the new one was fitted correctly.
I somehow don't believe the P0016 code to be the reason for the no start, I've read that this code can occur if the car simply won't start, but I don't really know.
I'll guess I'll replace the O2, and possibly replace the crank and cam sensor.
FIS
Norway
C?ID=368573
Thanks for stating the obvious, I'm was just looking for help to fix the issue, not getting racked down on.
NostraJackAss
No, however, isn't sometimes the lost item or process you cant find or complete, often in front of most?
I'm trying to convince you & to not commence with this backward process or behavior, you seriously need to correct this before making more mistakes & which are far greater.
Maybe not dismiss advice already given?
P0016 - 000 - Incorrect Correlation - Intermittent <<<<<<<<<<<<<< HERE!
Mileage: 294909 km
Time: 00:05:09
RPM: 161 /min
Load: 83.9 %
Voltage: 9.73 V <<<<<<<<<<<<<<< HERE!
RPM: 80 /min <<<<<<<<<<<<< RPM insufficient for CF combustion!
(no units): 33.0
Additionally voltage & RPM are in the dumper too!
Maybe listen to what DTC's say, rather than try to defend SMOG deletes & your work as not being your reason for failure, I mean seriously you marked the cam for timing belt but not the fuel lines?
FIS
Norway
C?ID=368573
I see what you mean. I'll recharge the battery, and recheck the G40/G28 sensors and the voltage.
What RPM is sufficient for combustion for these engines? The ones I've worked on earlier needed about 500.
NostraJackAss
FIS
Norway
C?ID=368573
So I've tried to find the correct manual for the car as you said, but no luck finding one, except for one with Russian language.
You mentioned the taper gears/pulleys, which is the type this engine has and it's correctly installed if that was what you wanted me to look into. (The timing is spot on)
Anyways so I charged the battery and replaced the starter because it was due anyway. The car would still not start, not even with starterfluid.
Codes are still the same, but the voltage and RPM is much better and should be enough for the car to fire.
Posting a new autoscan that was done before I quited.
Wednesday,12,June,2019,20:05:07:31215
          72
   Coding: 0000175
                    Mileage: 294909 km
                    Time: 00:40:19
                    Voltage: 12.69 V
                    Temperature: 18.9°C
                    Temperature: 18.0°C
                    Temperature: 18.0°C
                    Mileage: 294909 km
                    Time: 00:40:24
                    Voltage: 12.69 V
                    Temperature: 18.9°C
                    Temperature: 18.0°C
                    Temperature: 18.0°C
                    Mileage: 294909 km
                    Time: 00:40:31
                    RPM: 253 /min
                    Voltage: 10.64 V
                    RPM: 125 /min
                    (no units): 33.0
   Coding: 0000328
00258 - Solenoid Valve 1 (N88)
                    Fault Status: 00101010
                    Reset counter: 0
                    Mileage: 294909 km
00268 - Solenoid Valve 6 (N93)
                    Reset counter: 0
                    Mileage: 294909 km
                    Reset counter: 0
                    Mileage: 283072 km
                    Reset counter: 149
   Coding: 0010530
                    Reset counter: 229
                    Mileage: 294909 km
                    Time: 00:23:44
                    Hex Value: 0x0000
                    Voltage: 13.00 V
                    Bin. Bits: 00011110
                    Count: 170
                    Hex Value: 0x0000
                    Reset counter: 229
                    Mileage: 294909 km
                    Time: 00:23:44
   Coding: 00038805
   Coding: 00208933
                    Reset counter: 229
                    Voltage: 12.00 V
                    Reset counter: 14
                    Mileage: 294909 km
                    Voltage: 12.80 V
                    Reset counter: 229
                    Voltage: 12.00 V
   Coding: 0012336
   Coding: 0010012
00576 - Terminal 15
   Coding: 0007104
                    Reset counter: 14
                    Mileage: 294909 km
                    Time: 00:23:44
                    Reset counter: 13
                    Mileage: 294909 km
                    Time: 00:23:46
                    Reset counter: 229
                    Mileage: 294909 km
                    Time: 00:00:02
   Coding: 0000001
                    Fault Priority: 9
                    Fault Frequency: 57
                    Reset counter: 48
                    Mileage: 3618101 km
                    Time Indication: 4
   Coding: 0000188
   Coding: 0000258
                    Fault Priority: 9
                    Reset counter: 14
                    (no units): 2.0
                    Voltage: 10.60 V
                    Reset counter: 229
                    (no units): 4.0
                        Not OK
                    (no units): 10
                    Reset counter: 14
                    Mileage: 294909 km
                    Time: 00:23:44
                    RPM: 1500 /min
                    (no units): 4.0
                    Voltage: 12.90 V
   Coding: 0000188
   Coding: 0000057
                    Reset counter: 13
                    Mileage: 294909 km
                    Voltage: 12.50 V
                    Count: 73
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Coding: 1361030
   Coding: 00000020
   Coding: 00000020
                    Reset counter: 14
                    Mileage: 294909 km
                    Time: 00:23:44
                    Voltage: 12.64 V
                        ABS 1
   Coding: 0500040004
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:25, VBatt start/end: 12.5V/12.7V)-----------
Next on the list is to reverify that the crank and cam sensors have 12v B+, GND and a changing 0-5v signal.
FIS
Norway
C?ID=368573
Tranny was taken out to inspect the crankshaft sensor and ring. Replaced the sensor with a brand new one.
Reverified the timing belt, cam and the pump, cyl 1 is at TDC, timing marks line up perfectly.
Checked the fuel injectors and they all work with no leaks.
Car is getting fuel rail pressure.
Exhaust temp sensor fixed.
No engine codes.
New autoscan:
Tuesday,23,July,2019,20:46:07:31215
Mileage: 294900km-183242mi   Repair Order: 13
          72
   Coding: 0000175
   Coding: 0000328
   Coding: 0010530
   Coding: 00038805
   Coding: 00208933
                    Reset counter: 229
                    Mileage: 294909 km
                    Voltage: 12.30 V
                    Fault Frequency: 21
                    Reset counter: 229
                    Mileage: 294909 km
                    Voltage: 12.25 V
                    Reset counter: 14
                    Mileage: 294909 km
                    Voltage: 8.45 V
   Coding: 0012336
   Coding: 0010012
00576 - Terminal 15
   Coding: 0007104
                    Reset counter: 229
                    Mileage: 294909 km
                    Time: 00:59:13
   Coding: 0000001
   Coding: 0000188
   Coding: 0000258
                    Reset counter: 229
                    (no units): 4.0
                        Not OK
                    (no units): 3
   Coding: 0000188
   Coding: 0000057
   Coding: 1361030
   Coding: 00000020
   Coding: 00000020
   Coding: 0500040004
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:23, VBatt start/end: 12.7V/13.2V)-----------
NostraJackAss
Does it have compression and run on manual fluids administrated in intake, are zyl's flooded with fuel, key-ways or virtual taper key-ways correct?
Is intake and exhaust free form obstruction and are intake shut down flaps supported and if they are opening when needed too during start process?
JPPSG <<<<<<< The entire thread!
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
More information please & why did all work commence to begin with?
Is car FOD for anything?
FIS
Norway
C?ID=368573
I forgot to include that the compression was tested, about 145PSI on each cyl. (Engine cold)
It will not run with starter fluid, but it sounds like it "wants to"
Cylinders have probably been flooded during the testing.
Key-ways or virtual taper key-ways correct? - I asume you mean the key to hold the wheels on the shafts. Yes both the crank and cam was checked. Or else the timing could be off.
Exhaust is free from obstruction, I have not taken the intake off and inspected. And how can I know if the "flaps" are opened during start or not? I have used VCDS to manually test those flaps I believe? Or is that just the throttle body?
What section of the JPPSG are you refering to here?
All the work was done because the car has almost 300k KM on the clock. It didn't pass the EU check we got here and had alot of broken or bad parts. The decision was to fix it and to give it a fresh tune up.
The car is as far as I can tell exactly how it is supposed to be, and I really don't know what else to test now beside the intake manifold.
FIS
Norway
C?ID=368573
I'll check it out, thanks.
Do you know what manual lists the intake manifold and the flaps? I've got the official WSM K0059022320-4 manual but it's trash and can't possible be the right manual for this car?
