Golf mk7.5 halogen to golf mk7.5 led headlights
zebs2005
England
hexa193-00c6c1-d0f19d-a00eeb-unhahh-5f9a
hi everyone i have golf 7.5 2017 with halogen headlights and have purchased genuine golf 7.5 full led headlights
my car does not come with the headlight control module 4b (j745) i would like to retrofit this can anyone shed some light
thankyou very much any info on the wiring 10pin plug to the 14 pin would be a great help:)
darkchina811
ITALY
C?ID=333184
what version of LED headlight did you buy? Golf 7.5 has more than one.
please post a full autoscan of your car.
WD for you VIN you can get on erwin by buying just one hour access.
zebs2005
England
hi mate thanks this is full autoscan of the vehicle i can access wiring diagrams
the part number for the headlights i have purchased is 5G2 941 060
VIN: WVWZZZAUZHW321287   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZHW321287   Mileage: 9481km-5891miles
Address 01: Engine (2D2D2-DDYA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 HE    HW: 04L 907 445 E
   Component: R4 1.6l TDI   H01 3758
   Revision: 22005001
   Coding: 0125401243651D092000
   ASAM Dataset: EV_ECM16TDI03004L906056HE 004005
   ROD: EV_ECM16TDI03004L906056HE_004_VW37.rod
   VCID: 77FDF14FCE3CD9F2EC-8022
25802 - Steering Column Control Module
          U0212 00 [039] - No Communications
                    Mileage: 9481 km
                    Date: 2019.06.04
                    Time: 23:18:18
                    Engine speed: 765.75 /min
                    Normed load value: 25.9 %
                    Coolant temperature: 43 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 14.859 V
                    Accelerator pedal travel: raw value: 0.00 %
                    CAN status - engine control module: 0
                    Cruise Control System (CCS): status: ERROR
                    selected gear: Shifting process active
Readiness: N/A
   Part No SW: 0CW 300 041 D    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1004
   Revision: 00005026    Serial number: CU501701188366
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 36633C4B89B6E0FA37-8062
   Revision: 00000000    Serial number: 60487000000379
   Coding: 01FA8AA12422096D4779060840CA2580512490E26002A4733842F078C202430000000012121212B835351919323200
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [008] - -
                    Reset counter: 27
                    Mileage: 9481 km
                    Date: 2019.06.04
                    Time: 23:17:01
   Part No SW: 5G0 907 426 AQ    HW: 5G0 907 426 AQ
   Component: AC Manuell    H03 1801
   Revision: 00001K06
   Coding: 00120104202110001000000000000002
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 7AFBE87BFD2EC49A93-802E
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 242
                    Mileage: 9481 km
                    Date: 2019.06.04
                    Time: 23:17:00
                    Outside air temperature: 18.0 °C
                    Engine speed: 700 /min
                    Temperature after evaporator: 22.3 °C
                    System run time-Engine running time: 255 s
                    System run time-Terminal 15 on: 255 s
   Part No SW: 5Q0 937 084 CE    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H34 0236
   Serial number: 02001702700020
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7DF1E367EC00F3A2B6-8028
   Component: WWS    170120  042 0551
   Serial number:         170206154322
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  042 0105
   Serial number: S3Y17M02D14H08M10S47
   Coding: 00A8DD
   Serial number: 000000000ZY1701639X9
   Serial number: 00000000000068351803
558100 - Databus
                    Reset counter: 242
                    Mileage: 9481 km
                    Date: 2019.06.04
                    Time: 23:17:05
   Part No SW: 5QA 919 294 A    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0038
   Serial number: 000308418617049
   Coding: 0471051011
   ASAM Dataset: EV_EPHVA18AU3700000 009031
   VCID: 4A9B78BBED4E941A43-801E
   Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
   Coding: 3300678111FFC728949C810580400600000000000000000000
   VCID: 3C772E63B79A3AAAC1-8068
1076 - Databus
                    Reset counter: 242
                    Mileage: 9481 km
                    Date: 2019.06.04
                    Time: 23:17:01
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 14.8 V
2119 - Databus
                    Reset counter: 27
                    Mileage: 9481 km
                    Date: 2019.06.04
                    Time: 23:17:01
1116 - Databus
                    Reset counter: 242
                    Mileage: 9481 km
                    Date: 2019.06.04
                    Time: 23:18:48
                    Control Module temperature: 35 °C
                    Voltage terminal 15: 14.7 V
2068 - Databus
                    Reset counter: 242
                    Mileage: 9481 km
                    Date: 2019.06.04
                    Time: 23:17:01
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2LNUM+
   Coding: 98CCC000000000005C0000CF008800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 102FAAD3CB92EECA4D-8044
   Belt Pretensioner left:
   Serial number: 34169677E10021741078
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676E10021750469
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 802 17
   Serial number: 3570000000002C7C612E
   Subsystem 4 - Part No SW: -----------    HW: 480 001 702 17
   Serial number: 35800000000EA11D212H
   Subsystem 5 - Part No SW: -----------    HW: 480 400 902 17
   Serial number: 3510001BF248E89507DK
   Subsystem 6 - Part No SW: -----------    HW: 480 400 902 17
   Serial number: 3520001A1244A731633M
   Subsystem 7 - Part No SW: -----------    HW: -----------
   Component: FrontSensor_D  --- ----
   Serial number: -------------------$
7 Faults Found:
          B1000 1B [137] - Resistance Too High
                    Mileage: 9481 km
                    Date: 2019.06.04
                    Time: 23:17:01
          B1006 1B [137] - Resistance Too High
                    Mileage: 9481 km
                    Date: 2019.06.04
                    Time: 23:17:01
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 9481 km
                    Date: 2019.06.04
                    Time: 23:17:01
9438491 - Igniter for Driver head airbag
          B1005 1B [137] - Resistance Too High
                    Mileage: 9481 km
                    Date: 2019.06.04
                    Time: 23:17:01
9438235 - Igniter for Front passenger's Head Curtain Airbag
          B1004 1B [137] - Resistance Too High
                    Mileage: 9481 km
                    Date: 2019.06.04
                    Time: 23:17:01
9443861 - Driver's Front Airbag Crash Sensor
          B101A 15 [137] - Open or Short to Plus
                    Mileage: 9481 km
                    Date: 2019.06.04
                    Time: 23:17:04
9447189 - Seat Occupied Sensor; Passenger's Side
          B1027 15 [137] - Open or Short to Plus
                    Mileage: 9481 km
                    Date: 2019.06.04
                    Time: 23:17:02
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 12021708490279
   Coding: 0410
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 020B909B95FE8C5ACB-8056
   Part No SW: 5G1 920 941 B    HW: 5G1 920 941 B
   Component: KOMBI         202 9630
   Coding: 27A42A082780060001882B011400000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009007
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: 285FE2335302860AB5-807C
   Component: GW MQB High   418 4286
   Revision: --------    Serial number: 0005940024
   Coding: 030100045F086800FB00005C1C0F00010001050000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F6D092F76ECD13274-807A
   Subsystem 2 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Serial number: 3548513004
197169 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
                    Reset counter: 242
                    Mileage: 9481 km
                    Date: 2019.06.04
                    Time: 23:17:01
                    Supply voltage: Terminal 30: 14.5 V
                    Terminal 15: On
   Serial number: 250117EAP21114
   Coding: 00310220D001048000001000
   VCID: 4385559FCA64455280-8016
   Serial number: 00000000000013353753
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45814B87C4507B62AE-8010
   Serial number: 280117EAS0739A
   Coding: 00310020DE01048000801000
   VCID: 428B509BD57E4C5A8B-8016
   Serial number: 00000000000013387970
   Coding: 150000
   Part No SW: 3Q0 035 842 B    HW: 3Q0 035 842 B
   Component: MU-S-D-ER     710 0751
   Coding: 02731000FF00000051110101008808001F0500C60120010003
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2C571E2347FAAA2A51-8078
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H41 8074
   Serial number: VWZ6ZET0503061
End-------------------------(Elapsed Time: 03:48)--------------------------
darkchina811
ITALY
C?ID=333184
please do not cut the header from the autoscan, also try clearing DTCs to clean it up a bit.
5G2 941 059 and 5G2 941 060 are the two headlights.
find a car which has those headlights stock and find what is the PR code for headlights. once you know that it's easy to find the correct sheet on the WD.
you have a MID level BCM which might not be enough for the new headlights.
zebs2005
England
hi i will be deleting all error codes sorry ive had all interior out and roof lining so once i have completed that will post a full autoscan along with the vcds version i have thanks for all feedback much appreciated
sopskysalat
Singapore
Just wonder if without connection to BCM and AFS, can LED headlight lights up when power on?
sopskysalat
Singapore
Hi darkchina811, how do we know which BCM will support what features? Check available pin connection physically? Or is there a table from VW? Or we just have to go for High module for safest bet?
darkchina811
ITALY
C?ID=333184
yeah, why bother, just install a HIGH, but only the one that ETKA declares as fit for your VIN.
