Help ! Audi A3 what unit are coded to immobiliser
John ler
C?ID=144693
Hi guys a long story . But after I got my lads car back from been stolen and attempted fire , the car will not start or crank or fuel pump fire up , even when opening door, no noise as before , and when turn key . There’s no pressure what so ever
On fuel ,I’ve scaned car and loads of fault, I think leading from burnt wires shorting modules out, any way I think my ecu is fried and bcm, on my gateway I’m getting no communication to all units , is this saying the gateway is fried to ? , what I’m thinking is I’ve found somebody that is selling a clock set , to inc clocks bcm ignition and keys and locks , so basically hopefully everything that is coded for immobiliser, is this right with what I’ve said is included or are there any other things that are coded together ie gateway coded to the key , I’m on my phone now pulling my hair out while sat in car waiting for the wife . I can’t put a scan up yet, please anyone that can tell what is all linked to the key to start the car please help me, the car is a 2017 Audi A3, we didn’t want to claim on insurance because my lads insurance policy with a claim on it would go up by £5000 a year more, crazy , but he loves his first car, thanks in advance
Please ignore my spellings and gramma, I didn’t learn this when I was young, hard life ,
Start with the gateway. Verify it's getting power and ground. The Gateway should only need five things to talk:
  • Switched power
  • Unswitched power
  • Ground
  • CAN-H -- goes to Pin 6 of the Diagnostic socket
  • CAN-L -- goes to Pin 14 of the Diagnostic socket
John ler
C?ID=144693
Thanks uwe I’ll try that, which units are all connected for the immobiliser,? I no clocks/clusters and bcm and Something to do with key , is there anything else I would need, and would I have any problems transferring all these units from a dona car, into my lads car, asking as all modules are same part number , just to get it to running again if all else fails , thanks for your help again
Depends on how the car is equipped. Keyless entry/start? Automatic transmission?
You wouldn't happen to have a scan of this car from when it was still in running condition, would you? ;)
John ler
C?ID=144693
I’ll get a scan tomorrow uew, yes it’s key and it’s auto , it had wires burnt, I’ve repaired all them, but first I’m getting when putting foot on break firstly no noise when opening door or when putting key in first position , but no crank , full battery , but if putting power to starter solenoid using a power probe , it turns over fine off battery in car, but no fuel pump , I’ve got fault saying accelerator pedal Wichita I’ve tried another one, as I do have a golf at my address same everything apart from manual , tried fuel pump module or what ever it’s called and the pedal, but while getting fault saying accelerator fault, I’ve got both o2 sensors, I understand having faults showing on them, you can get fault on pedal ?? I’m just thinking ecu fealty, fire was so light , and really warm away from engine. Just down right side front around headlight underside , so wires damaged where around that area, but was heat to damage o2 sensor wires at plugs, but I’d say really not enough heat to damage the ecu, this is why I’m thinking a short causing damage to ecu, trouble is, while wires poss touching, power will have been turned on, by recovery and police/garage , I’ll get an up to date scan on tomorrow , I do have on the central electrics, 0000000 all the way along the coding, don’t no how I’ll get the coding back, in insight we should have let insurance have it, but my lad loved the car and I didn’t have the hart to say it was going and insurance was going to cost to much, so he’ll need to drive an old crapper , he had a hard enough time when he saw his car had gone, along with his mum anniversary present TTS , thanks for your help
Sorry about grammar mate I do my best
John ler
C?ID=144693
sorry forgotten how to put a scan up, on the bcm, i have tried to enter a code from a golf i have with the same engine etc, and 9 bcm will accept a code, why would it loses its coding, Im thinking both ecu and bcm have had it,, many thanks for looking, how would I get the coding back for the bcm now its lost,
Thursday,06,June,2019,14:02:52:33601
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ8V1HA093146   License Plate: A3
Mileage: 48778km-30309mi   Repair Order:
                Address 01: Engine       Labels: 04E-907-309-V1.clb
Control Module Part Number: 04E 906 027 HF    HW: 04E 907 309 BJ
  Component and/or Version: R4 1.4l TFS   H23 3545
           Software Coding: 02250012232401082000
            Work Shop Code: WSC 06314 790 00021
              ASAM Dataset: EV_ECM14TFS01104E906027HF 001006 (AU37)
                       ROD: EV_ECM14TFS01104E906027HF.rod
                      VCID: 6FEC560BB61E4D3234-803A
7 Faults Found:
2813 - Accelerator Position Sensor (G79)
          P2122 00 [167] - Signal too Low
                    Mileage: 48778 km
                    Date: 2019.06.06
                    Time: 14:01:22
                    Engine speed: 0.00 /min
                    Coolant temperature: 70 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 0.000 V
                    Outside air temperature: 19 °C
                    Absolute intake pressure: 100 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 6.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 15.9998
                    Intake camshaft bank1 active operating mode-Bits 0-7: 0
                    Overrun cut-off-Bits 0-7: 0
2815 - Accelerator Position Sensor 2 (G185)
          P2127 00 [167] - Signal too Low
                    Mileage: 48778 km
                    Date: 2019.06.06
                    Time: 14:01:22
                    Fuel level: 6.00 l
4239 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
          P2184 00 [039] - Signal too Low
                    Mileage: 48778 km
                    Date: 2019.06.06
                    Time: 14:01:23
                    Fuel level: 6.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.2061
2698 - Fuel Pressure Sensor (G247)
          P0192 00 [167] - Short to GND
                    Mileage: 48778 km
                    Date: 2019.06.06
                    Time: 14:01:23
                    Fuel level: 6.00 l
17129 - Oxygen (Lambda) Sensor B1 S1
          P0131 00 [039] - Signal too Low
                    Mileage: 48778 km
                    Date: 2019.06.06
                    Time: 14:01:30
                    Fuel level: 6.00 l
17143 - Oxygen (Lambda) Sensor B1 S2
          P0137 00 [039] - Signal too Low
                    Mileage: 48778 km
                    Date: 2019.06.06
                    Time: 14:01:30
                    Exh mss flw bef main cat conv bank 1 filtered: 0.0 kg/h
                    Exhaust gas temperature before catalytic converter: 19.49 °C
                    Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120: 0.000 Ohm
                    Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister: 1
                    Test of oxygen sensors bank 1: Delta-Lambda: 0.00000
                    Oxygen sensor 2 bank 1 internal resistance limit value: 131070 Ohm
4263 - System Voltage
          P0560 00 [039] - Malfunction
                    Mileage: 48778 km
                    Date: 2019.06.06
                    Time: 14:01:27
                    Coolant temperature: 71 °C
                    Absolute intake pressure: 101 kPa abs
                    Fuel level: 6.00 l
Readiness: 1110 0001
Sunday,09,June,2019,18:08:11:52681
VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 08 09 15 16 17 19 29 39 42 44 52 55 5F D6 D7
VIN: WAUZZZ8V1HA093146   Mileage: 48778km-30309miles
01-Engine -- Status: Cannot be reached 0100
15-Airbags -- Status: Cannot be reached 0100
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
44-Steering Assist -- Status: Cannot be reached 0100
Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HF    HW: 04E 907 309 BJ
   Component: R4 1.4l TFS   H23 3545
   Revision: R6H23---
   Shop #: WSC 06314 790 00021
   VCID: 6FB8DBB43711D0EF23B-803A
   CAN Converter 01:
7 Faults Found:
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:13
                    Coolant temperature: 34 °C
                    Intake air temperature: 19 °C
                    Outside air temperature: 17 °C
                    Fuel level: 6.00 l
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:13
                    Fuel level: 6.00 l
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:13
                    Coolant temperature: 35 °C
                    Fuel level: 6.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.1775
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:13
                    Fuel level: 6.00 l
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:22
                    Coolant temperature: 36 °C
                    Fuel level: 6.00 l
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:22
                    Exhaust gas temperature before catalytic converter: 17.24 °C
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:18
                    Fuel level: 6.00 l
   Part No SW: 0CW 300 041 B    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1010
   Revision: 00005026    Serial number: CU501612106459
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 343214D81EB7B3371E9-8060
10679 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [047] - -
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:13
                    Engine speed: 18.75 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 57 km/h
                    Control Module temperature: 20 °C
                    CURRENT pressure: -9.5 bar
                    Clutch: primary stat: Driving
                    selected gear: GANG_UNDEFINIERT
                    Accelerator position: 0.0 %
                    DTC memory status: 12032
21223 - No Communications with Power Steering Control Module
          U0131 00 [047] - -
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:13
                    DTC memory status: 25344
21191 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [047] - -
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:13
                    Accelerator position: 0.4 %
                    DTC memory status: 7680
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 63516000001985
   Coding: 10F18AA22429226F89780E0440C928085124449170021472022150748208420000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
   VCID: 78AAE0E8425F9757F21-802C
15 Faults Found:
0056 - Front Right Wheel Speed Sensor
          C101B 01 [137] - Electrical Failure
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:12
0166 - Steering angle sensor
          B1168 31 [137] - No Signal
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:12
8200 - Databus
          [FCAN: Airbag_01 message is not received]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:12
8204 - Databus
          [FCAN: Airbag_02 message is not received]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:17
8206 - Databus
          [FCAN: Airbag_03 message is not received]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:20
8238 - Databus
          U1121 00 [137] - Missing Message
          [FCAN: LH_EPS_01 message is not received]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:12
8242 - Databus
          [FCAN: LH_EPS_03 message is not received]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:12
8246 - Databus
          [FCAN: Motor_Code_01 message is not received]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:20
8250 - Databus
          [FCAN: Motor_07 message is not received]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:20
8252 - Databus
          [FCAN: Motor_11 message is not received]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:12
8254 - Databus
          [FCAN: Motor_12 message is not received]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:12
8256 - Databus
          [FCAN: Motor_14 message is not received]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:12
8258 - Databus
          [FCAN: Motor_20 message is not received]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:12
8264 - Databus
          [FCAN: Tsk_06 message is not received]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:12
32993 - Control Module for Electric Parking Brake
          C10E2 F0 [009] - RPM Sensor Implausble Signal
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:12
   Part No SW: 8V0 820 043 M    HW: 8V0 820 043 M
   Component: AC Automat    H03 0130
   Revision: 20002000    Serial number: 00000001115338
   Coding: 00100004000000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   VCID: 3C223CF836E77B77D69-8068
262658 - High Pressure Sensor
          B10AE 31 [009] - No Signal
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:11
                    Outside air temperature: 17.5 °C
                    Engine speed: Measured value not available
                    Temperature after evaporator: 20.6 °C
                    System run time-Terminal 15 on: 166 s
459009 - Databus
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:11
459023 - Databus
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:10
263682 - Exterior Air Quality/Humidity Sensor
          B137A 31 [009] - No Signal
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:15
                    Voltage terminal 30: 12.4 V
                    System run time-Terminal 15 on: 169 s
   Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H34 0236
   Serial number: 02001634803465
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EA6F6F0607BA967B8D-802A
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 160821  043 0580
   Serial number:         160830183041
   Coding: 0A47F7
   Serial number: 62499239
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 08 10 2016  00000157
   Serial number: 000000000ZY1631436M4
   Serial number: 00000000000037111248
9 Faults Found:
528405 - Databus
          [Airbag_01 Datenbus fehlende Botschaft]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:04:14
541973 - Databus
          [Motor_04 Datenbus fehlende Botschaft]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:04:17
542229 - Databus
          [Motor_14 Datenbus fehlende Botschaft]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:04:17
542485 - Databus
          [Motor_18 Datenbus fehlende Botschaft]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:04:18
555285 - Databus
          [LWI_01_alt aktiv]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:04:17
555541 - Databus
          [Motor_12_alt aktiv]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:04:17
556053 - Databus
          [LH_EPS_02_alt aktiv]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:04:17
558101 - Databus
          [Airbag_02 Datenbus fehlende Botschaft]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:04:17
559125 - Databus
          [Motor_07 Datenbus fehlende Botschaft]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:04:18
Address 15: Airbags
   Part No SW: 8V0 953 521 HB    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 09121604400207
   Coding: A418
   VCID: 015C8D0C1185D69FC5F-8054
   Part No SW: 8V0 920 972 J    HW: 8V0 920 972 J
   Component: KOMBI         H04 8316
   Coding: 27A401082B8026000100E8001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009054
   VCID: 45D4591C452D3ABFB97-8010
16776962 - Databus
          [Airbag_01 keine Kommunikation]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:10
16776971 - Databus
          [Motor_04 keine Kommunikation]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:10
16776978 - Databus
          [LH_EPS_01 keine Kommunikation]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:10
16776988 - Databus
          [TSK_07 keine Kommunikation]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:10
   Component: GW MQB High   515 5286
   Serial number: 03121610520548
   Coding: 030100043F0857005B0002481C0B00000001010000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 2F381BB4F79190EF63B-807A
   Subsystem 2 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
   Component: J453 MFL  H04 0003
   Serial number: 20161128222640 22575
   Serial number: 75410803001612136964
131602 - Power Steering Control Module
          U101D 00 [009] - No Communication
          [Timeout Knoten 0x12 / 44 - Steuergerät für Lenkhilfe]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:11
                    Supply voltage: Terminal 30: 12.4 V
                    Terminal 15: On
131605 - No Communications with Airbag Control Module
          U0151 00 [009] - -
          [Timeout Knoten 0x15 / 15 - Steuergerät für Airbag]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:11
                    Terminal 15: On
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [009] - -
          [Timeout Knoten 0x76 / 01 - Motorsteuergerät]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:11
                    Terminal 15: On
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H06 0016
   ASAM Dataset: EV_LCMLeftCONTIAU426 001008
   VCID: 42DE420054030D879C5-8016
0279 - Databus
          [databus - message missing]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:11
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   ASAM Dataset: EV_LCMRightCONTIAU426 001008
0279 - Databus
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:11
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 261116EKP09088
   Coding: 001C0A204001040100001002
   VCID: 41DC4D0C5105169F85F-8014
458752 - Databus
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:10
458803 - Databus
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:10
Address 44: Steering Assist
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 261116EKQ09304
   Coding: 001C02204001040100001002
   VCID: 40DA48085A0F1F978A1-8014
458752 - Databus
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:10
458803 - Databus
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:10
Address 55: Headlight Range (J745)       Labels:* None
   Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0230
   Coding: 0EDE00102B230200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
   VCID: 3E2636F020FB6967F8D-806A
13705485 - Databus
          [Timeout CAN-Message Airbag_02]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:12
13705474 - Databus
          [LWI_01 Datenbus fehlende Botschaft]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:11
13705475 - Databus
          [Motor_20 Datenbus fehlende Botschaft]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:11
13705986 - Databus
          [Empfangener Fehlerwert im Signal ESP_VR_Radgeschw_02: Message ESP_19]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:12
   Part No SW: 81A 035 192 B    HW: 81A 035 192
   Component: MU-HS-LND-EU  045 0170
   Coding: 01730001FF00000011111101000A00102F002AC601F00100CE
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 201AE888BA4F3F97EA1-8074
   Subsystem 1 - Part No SW: 8W0 919 866 M    HW: -----------
   Component: ECE 2017  --- 0024
   Component: DU High  H49 0014
   Serial number: AUZ8Z9GY2095FF
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
   Component: ControlUnit_B  H50 0103
   Serial number: ALJAL125111600010803
6697 - Databus
          [Airbag: no communication]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:11
                    Network diagnosis-Status: Enabled
6708 - Databus
          [Engine: no communication]
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.06.09
                    Time: 18:02:11
   VCID: 1768C3546F01782F1BB-8042
End----(Elapsed Time: 01:13, VBatt start/end: 12.4V/12.3V. VIgn 0.0V)------
Looks like you got it communicating, but gosh, that car's a mess. I'm not sure where to even start.
John ler
C?ID=144693
Dose that look like engine ecu is ok ? It’s been like that from start, didn’t notice , bcm had no coding, would that make any difference, why would it have no coding uwe, some of the things I understand, , there area that had damage to wiring was only down right hand side of the car under the bonnet/hood , is there any way I could get any coding for that module , that might work , any ideas , thanks appreciate any help , I’ve got live at gateway , and earth , live before ignition switched on and another with it’s on , dose that make any sense, thanks again
John ler
C?ID=144693
Is there anywhere I can find which pins on the ecu plug should be live and earth , have you ever seen a ccm showing no code in it, without it been a new module , thanks
Since it communicates, it's powered up. However, it looks like some of the actuators and sensors connected to it might not be.
I believe an all-zero coding is normal for that BCM. All the things that used to be adjustable via Coding were moved to Adaptation channels.
John ler
C?ID=144693
Many that’s uew, which sensors etc do you see not communicating , thanks
John ler
C?ID=144693
Hi uew , I’ve put a ecu from my lads golf same engine basically same car , but vw golf , same engine code and sane ecu part number , so I tried to change the coding over , because that car is Manual and not dsg, it wouldn’t let me change this over, the fuel pump did turn on, this hasn’t happen since car was stolen, but did t start, short or something on starter realy . this is what is said when not aloud to put the faulty car coding fir ecu
Coding rejected Error 22
I’m now thinking the ecu is part of the fault , but only part of the fault, I’m going to buy a complete set
Clocks
Ecu
Bcm
Key transponder
Steering column
Is there anything else linked to the immobiliser that needs the key code us it SKC thanks again fir your time
Clocks
Ecu
Bcm
Key transponder
Steering column
You can't just swap in a different ECU and expect the car to start. That's been true since the advent of the first immobilizers 20+ years ago.
On an 8V A3, if it has an Auto box, I believe the transmission controller is also tied in, but I'm not 100% certain; it might be "only" Component Protection.
You can't do any immo work on this car with just a PIN/SKC. The Immo uses a challenge/response mechanism. The challenge changes with every key cycle and the only place the response is calculated from the challenge is the server on the corporate mothership.
John ler
C?ID=144693
Can a auto lock smith do this, like they make a new key on the immobiliser side of things. And the component protection that might be on,it, can that be access buy again by the key guy? . I didn’t put the diffrent ecu on expection the car to start, I hoped I’d get the fuel pump prime, which It did and see what other codes it would show, to see if I had same codes as on the original ecu, most the faults didn’t show on the scan, pulse the priming of the fuel pump on opening door and turning the key, and an short to earth on the fuel system was no longer showing, my big thing is, can I change the coding over from an old ecu to the coding from my cars ecu, is this possible, thanks
I do not know what exactly what an automotive locksmith can and can't do on this car.
As for coding the replacement ECU, that depends whether it's truly compatible with the configuration of this car. Some ECUs can be switched between Auto and Manual, while others cannot. I do not know whether this one can or can't. You say it's the same part number, but you haven't posted a scan from it, so I'm not sure what you mean by that. If the full part number "04E-906-027-HF" is the same, then I would think it should be possible. But if by "part number" you only mean "04E-906-027", then all bets are off.
John ler
C?ID=144693
hi got a little further on with the car now, but got fault on engine control unit, 1
fault 17149 check coding of ecu , powertrain data bus and left with mil light on and epc,, cant select any of drive select options, or cruse control, any help would be great im totaly stuck now, ,many thanks
Wednesday,07,August,2019,16:21:50:52681
VIN: WAUZZZ8V1HA093146   License Plate: HARRYS CAR
Mileage: 48779km-30309mi   Repair Order:
VIN: WAUZZZ8V1HA093146   Mileage: 48779km-30309miles
   Component: R4 1.4l TFS   H23 2489
   Revision: R6H23---
   Shop #: WSC 55975 003 1048576
   ASAM Dataset: EV_ECM14TFS01104E906027HF 001005
   CAN Converter 01:
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Mileage: 48779 km
                    Date: 2019.08.07
                    Time: 16:16:20
                    Coolant temperature: 27 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 12.038 V
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 2
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [009] - -
                    Fault Frequency: 12
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.08.05
                    Time: 18:48:08
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 12B8826800PAG0MUFU03
   Coding: 0A47F7
   Coding: 00006C
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2F1D4L
   Coding: 98CCC0000C0000005C5400CA00C800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 107AB8484AEFAF175A1-8044
   Subsystem 1 - Part No SW: -----------    HW: 480 001 612 16
   Serial number: 35700000000D4A2D1D1T
   Subsystem 2 - Part No SW: -----------    HW: 480 001 612 16
   Serial number: 35800000000B7A2D1D1V
   Subsystem 3 - Part No SW: -----------    HW: 480 401 412 16
   Serial number: 3510001AB22CA56634C7
   Subsystem 4 - Part No SW: -----------    HW: 480 401 412 16
   Serial number: 3520001AB22CA563052-
   Subsystem 5 - Part No SW: -----------    HW: 480 401 411 16
   Serial number: 3550002C922E8E118178
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: -----------
   Component: PedP_Sensor_D  --- ----
   Serial number: -------------------$
   Subsystem 7 - Part No SW: -----------    HW: -----------
   Component: PedP_Sensor_P  --- ----
   Subsystem 8 - Part No SW: -----------    HW: 480 000 512 16
   Serial number: I0M00000000449C0EE1C
   Subsystem 9 - Part No SW: -----------    HW: 480 000 512 16
   Serial number: I0N00000000B59C0EE1L
9450005 - Pedestrian Protection Crash Sensor (driver's side)
          B1032 15 [137] - Open or Short to Plus
                    Mileage: 48778 km
                    Date: 2019.08.05
                    Time: 18:48:28
9450261 - Pedestrian Protection Crash Sensor (passenger's side)
          B1033 15 [137] - Open or Short to Plus
                    Mileage: 48778 km
                    Date: 2019.08.05
                    Time: 18:48:28
          U1101 00 [137] - Active
          [ATP Wrong IKA]
                    Mileage: 48778 km
                    Date: 2019.08.05
                    Time: 18:48:24
   Coding: A418
   ROD: EV_GatewNF.rod
          U1101 00 [009] - Active
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.08.05
                    Time: 18:57:08
                    Supply voltage: Terminal 30: 12.5 V
                    Terminal 15: On
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
          B2000 87 [009] - Missing message
                    Reset counter: 152
                    Mileage: 48779 km
                    Date: 2019.08.07
                    Time: 16:19:16
                    Voltage terminal 30: 14.6 V
                    Software module: status-SW_Status_Consistency: 01 00 00
                    Software module: status-SW_Status_Device:
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 152
                    Mileage: 48779 km
                    Date: 2019.08.07
                    Time: 16:19:18
                    Voltage terminal 30: 14.5 V
                    BAP-BAP_Function_ID: 02
End----------(Elapsed Time: 01:14, VBatt start/end: 14.7V/14.7V)-----------
John ler
C?ID=144693
new scan, clearing the airbag faults i knew about, am I putting scan in wrong place, ie quotes ?
Thursday,08,August,2019,12:32:17:52681
   Revision: R6H23---
   CAN Converter 01:
          P1647 00 [167] - -
                    Mileage: 48779 km
                    Date: 2019.08.08
                    Time: 12:25:04
                    Coolant temperature: 23 °C
                    Voltage terminal 30: 11.921 V
          P1612 00 [009] - -
                    Fault Frequency: 23
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.08.05
                    Time: 18:48:08
   Coding: 0A47F7
   Coding: 00006C
   Subsystem 6 - Part No SW: -----------    HW: 480 402 111 16
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001BB231F2C3B356
   Subsystem 7 - Part No SW: -----------    HW: 480 402 111 16
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001BB231F2C54352
          [ATP Wrong IKA]
                    Mileage: 48779 km
                    Date: 2019.08.08
                    Time: 12:24:16
   Coding: A418
   ROD: EV_GatewNF.rod
                    Reset counter: 152
                    Mileage: 48778 km
                    Date: 2019.08.05
                    Time: 18:57:08
                    Terminal 15: On
   Coding: 8107
          U1111 00 [009] - -
                    Reset counter: 152
                    Mileage: 48779 km
                    Date: 2019.08.08
                    Time: 12:27:41
                    Voltage terminal 30: 11.8 V
End----(Elapsed Time: 01:14, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
siLc
Tallinn, Estonia
C?ID=330192
Instead of QUOTE tags, use CODE tags.
You are not seeing any drive modes because something has triggered Component Protection on the CAN gateway. You need to go to the dealer (or someone with a factory diagnostic connection) to get it removed.
John ler
C?ID=144693
Many thanks, it’s the CP causing this is it, will that give me this epic light on dash to, I no reason and about the cp on gateway, because I had to fit a used engine ECU, is it the CP that’s giving me the message (check coding off engine powetrain, ) because the coding is as when it left factory, many thanks for reply, big help,
