VW Passat abs coding
aswe
C?ID=276157
Hi all, I need a ABS code for passat 2008 2.0tdi auto hold. Some other guys changed parking brake control module and lost original code and now I get this car to sort it out, part numbers mach on both units, I find one code which is 0001291 with this code there is no more faults but parking brake fault light still flashes, there is autoscan from before
Thursday,06,June,2019,10:47:39:57164
VCDS Version: 19.6.0.2 (x64)
VIN: WVWZZZ3CZ8E229849   License Plate: YF08KDJ
Mileage: 243710km-151434mi   Repair Order: 321
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 76
VIN: WVWZZZ3CZ8E229849   Mileage: 243710km-151434miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 BL    HW: 03L 907 309
   Component: R4 2,0L EDC G001SG  6221
   Revision: --H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 00377 210 84959
   VCID: 70E86E68637C5FCF61-8024
               U1017 - 000 -
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 16:53:34
                    Voltage: 11.55 V
                    Bin. Bits: 11001010
                    Bin. Bits: 00000000
                    (no units): 0.0
               U1017 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 16:53:39
                    Voltage: 11.55 V
                    Torque: 219.0 Nm
                    Hex Value: 0xFF00
                    Bin. Bits: 11001010
   Part No SW: 3C0 614 109 K    HW: 3C0 614 109 K
   Component: J104    C4 440 V2   0005
   Revision: --020---    Serial number: 00000785497737
   Coding: 0004408
   Shop #: WSC 05311 000 00000
   VCID: 264448309138417FCB-8072
8 Faults Found:
                    Fault Priority: 9
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 17:07:35
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00000000
                    Count: 228
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 17:01:00
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011110
                    Count: 199
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 17:01:00
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011110
                    Count: 149
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 17:01:00
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 17:01:00
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 17:01:00
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 17:01:00
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 17:01:00
   Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
   VCID: 77FA5574061208F7A0-8022
   Revision: 00H54000    Serial number: 01000008249487
   Coding: A8808F0700041A1E470F00000F0000000008594300000100000000000000
   Shop #: WSC 05124 000 00000
   VCID: 71EE6B6C687656C76E-8024
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 280308 022  0601
   Coding: 00046997
   Shop #: WSC 05124
   Component: J234__006 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DP70N8VX
   Coding: 0012342
   VCID: 3B7289447ABAEC9784-806E
   Subsystem 1 - Serial number: 6333FTS650180798
   Subsystem 2 - Serial number: 6343FTS610270708
   Subsystem 3 - Serial number: 6353ETS6R2T1TVNP
   Subsystem 4 - Serial number: 6363ETS6LMC0TVNP
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
                    Fault Status: 11101001
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 16:54:23
   Part No SW: 3C0 953 549 AE    HW: 3C0 953 549 AE
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C5953507AT
   Coding: 0000111
   VCID: 6FEA6D147E42403778-803A
   Part No SW: 3C0 920 971 E    HW: 3C0 920 971 E
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0004405
   Shop #: WSC 00400 067 57207
   VCID: 275A453496325877F0-8072
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P0841203C1
   Coding: F9807F0E0002021003
   VCID: 23425124E20AB457AC-8076
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   VCID: 397E934C7086DE8796-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Component: J386  TUER-SG FT    1132
   Revision: 32008001    Serial number: 00000501488327
   Coding: 0000693
                    Fault Status: 01100101
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 16:54:23
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.134 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 36649870419831FF7B-8062
   Component:    KSG PQ46 ELV 042 0472
   Coding: 01910A0001860E7630049E1F70085FCE107C01
   Component: LIN BACKUP HORN H08 9001
   Component: Neigungssensor  004 0611
   Component: J387  TUER-SG BT    1132
   Revision: 32008001    Serial number: 00000562088319
   Coding: 0000692
   VCID: 3C708A587FB4EBAF8D-8068
   Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-09393 0009
   Revision:   008       Serial number: 00000000372665
   Coding: 0000057
   Shop #: WSC 00028 028 00001
   VCID: 295E430C80266E07E6-807C
                    Fault Status: 11101101
                    Fault Frequency: 8
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 16:54:21
                    Voltage: 11.30 V
                    Count: 71
                    Hex Value: 0x1240
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 00000000    Serial number: VWZ1Z2I6880722
   Coding: 0500040002
   Shop #: WSC 31414 790 31414
   VCID: 6BD279048A5ABC1754-803E
00856 - Radio Antenna
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 16:54:40
03138 - Input AUX IN
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 16:54:27
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0308
   Revision: 41004101    Serial number: 00000000329349
   Coding: 0000144
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0308
   Revision: 41004101    Serial number: 00000000324622
   Coding: 0000144
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 C    HW: 3C0 919 283 C
   Component: Parkhilfe 8-Kan 004 0013
   Revision: 00004000    Serial number: 90640810000579
   Coding: 0000014
End-------------------------(Elapsed Time: 01:50)--------------------------
Address 03: DTCs cleared
Address 03,3C0 614 109 K,recoded (Short coding),from,0004408,to,0000301,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0004408,to,0002412,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0004408,to,0013569,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0004408,to,0000309,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000309,to,0000267,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000267,to,0000266,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000267,to,0000265,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000267,to,0000264,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000264,to,0000263,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000264,to,0000262,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000264,to,0000261,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000261,to,0000258,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000258,to,0000274,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000258,to,0000268,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000258,to,0000269,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000258,to,0000270,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000270,to,0000271,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000270,to,0000272,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000270,to,0000273,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000273,to,0000275,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000273,to,0000276,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000276,to,0000277,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000276,to,0000278,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000276,to,0000279,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000279,to,0000280,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000279,to,0000281,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000279,to,0000282,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000282,to,0002322,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000282,to,0002333,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0000307,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0002415,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0033272,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0029998,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0000293,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0000333,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000333,to,0034125,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000333,to,0004275,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000333,to,0001282,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0001282,to,0001288,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0001288,to,0001298,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0001288,to,0000415,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0001288,to,0000307,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0001288,to,0001291,(05311/000/00000),
Address 01: DTCs cleared
Address 44: DTCs cleared
aswe
C?ID=276157
new autoscan is this
Friday,07,June,2019,10:21:37:57164
Mileage: 243730km-151446mi   Repair Order: 321
VIN: WVWZZZ3CZ8E229849   Mileage: 243730km-151446miles
   Coding: 0000072
   Coding: 0001291
   Coding: 00046997
   Shop #: WSC 05124
   Coding: 0012342
   Coding: 0000111
   Coding: 0004405
   Coding: 0000693
   Coding: 0000692
   Coding: 0000057
   Coding: 0500040002
                    Reset counter: 18
                    Mileage: 243736 km
                    Date: 2019.06.03
                    Time: 22:12:46
                    Reset counter: 18
                    Mileage: 243736 km
                    Date: 2019.06.03
                    Time: 22:12:42
   Coding: 0000144
   Coding: 0000144
   Coding: 0000014
End-------------------------(Elapsed Time: 01:53)--------------------------
Jacek
Poland
C?ID=360566
Hello ; 3C0 614 109 K J104 C4 440 V2 0005 cod 0000285
aswe
C?ID=276157
be trying this no work at all
Hello Andis,
Now that you are registered and a Verified VCDS user I can move this to the Car Repair Support sub-forum. In the meanwhile I'll check into the coding of WVWZZZ3CZ8E229849 and report back in forum (rather than to the e-mail) with any coding suggestions we may have so the answer becomes searchable.
Vehicle Identification No.WVWZZZ3CZ8E229849
Modelpassat sedan
PA
Date of production22.04.2008
Model year2008
Sales type3C2192
Engine CodeCBAB
Transmission CodeKNS
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PEWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components0HGVehicle class differentiation -3C0-
Emission standard7MBEmission standard EU 4 plus
Trailer hitch1D0without trailer towing
airbag4UEdriver and front passanger airbags
Aktivkohlebehälter / Ottopartikelfilter1E0Without activated charcoal canister
Tray areas packageQE2Storage compartment
Aerials8ZHAntenna for AM/FM reception, "diversity"
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Left exterior mirror5SJLeft exterior mirror, convex
Right exterior mirror5RVRight exterior mirror, aspherical
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WCWithout "Multimedia" in vehicle
Equipment levelsA8CComfort equipment
Brake type in rear1KUDisc brakes in rear
batteriesJ0NBattery 330 A (61 Ah)
Brake type, front1LHSilver caliper
Beverage holders4M6Beverage holders
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0NComponent parts set, complying with vehicle type for Great Britain, various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VFInformation kit in English
Operating voltage9Z0Operating voltage 12 V
Heated washer nozzles9T1Heated washer nozzles in front
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
"Charism"2H0Without "drive select"
General operating permit, alterationsC15Operating permit, alteration
Roof rails/roof load rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FAroof without cut out
Suspension system in rear1JARear shock absorption, basic design 1
Suspension system in frontG07Shock absorption in front
Load-through hatch/ski bag3X2Load-through hatch
Insert for the filling up of unleaded fuel/fuel type2G0Without insert for the filling up of fuel
Installation differentiation for components0ENInstallation differentiation for transmission MQ 350 -- vehicle components --
Theft protection system7ALAnti-theft alarm system, interior monitoring, backup horn and towing protection
Inserts7TMDecorative inserts
Scuff plates7M0Plastic scuff plates in door apertures
Park distance control7X2Park distance control in front and rear
Electric interface for external useUF0Without electric interface
Manufacturing sequence differentiation0FAStandard manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL1Extended pedestrian protection measures
Headlight activation8K0Without special driving light switching
Parking brakeUH2Parking brake
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GVAlternator 180 A
Transmission types/gearshift mechanisms0G4Cable gearshift
Weight category rear axle0YDWeight range 4 installation control only, no requirement forecast
Weight category front axleL02Suspension range 02 installation control only, no requirement forecast
Base engineTG34-cylinder diesel engine 2.0 l unit 03L.A
Tie down straps/net/pocket6M0Without tie down straps/net/pocket
cruise control system8T2Electronic cruise control system (CCS)
Garage door openerVC0without Garage door opener
Transmission specificationsG0K6-speed manual transmission
Cruise control system and speed limiter6Y9without cruise control system
Brackets3P0Without bracket for first aid kit and warning triangle
Rear seats3NURear bench seat, not split, split backrest, folding centre armrest
Heating and air-conditioning system9APClimatic air-conditioning system (semi-automatic)
Headlamps8BKTwin headlamps for driving on the left, with integrated high beam
Customized installationFC0Without individual installation
Interior light in footwell6T0Without interior light in footwell
Instrument clustersU5BInstrument insert, mph speedometer Great Britain
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror, dimming
headphone connection, rear8MAno headphone connection in rear
Body styleK8BNotchback
Luggage compartment floor covering6SEFlat needle-punched trunk floor covering
Cassette and CD storage unit4W0without cassette / CD tray
Electronic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Climatic zones0Y1Standard climatic zones
Compass/road sign displayQR0Without compass/road sign display/ dynamic road sign display
Seat ventilation/massage seat4D0Without seat ventilation/massage seat
Fuel quantity for initial filling1Z2Increase in initial standard fuel filling
Fuel systems0F5Fuel system for diesel engine
Body measures5C0Without special body measures
Radiator grille6KARadiator grille
Rear license plate bracket6P1Rear license plate carrier (ECE)
Front license plate bracket6W1Front license plate carrier (large)
Paint preservative/transit coating5K0Without surface protection, with additional transit coating
Paint coatingFB0standard paint coating
Rear cargo area3GAWithout luggage compartment floor
Country codesFE0Without country code (no DVD player in vehicle)
Steering system arrangementL0RRight-hand drive
Reading lamp8S72 reading lights in front
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Load edge protection2P1Plastic loading edge protection
Lumbar support7P8Electrically adjustable lumbar support for right front seat
steering wheels2ZBLeather-wrapped multi-function steering wheel
Speaker installation8RM8 speakers (passive)
Headlight range control8Q1Headlight range control
Center armrest6E3Center armrest in front
Multi-function display/trip computer9Q5Multi-function display with control
center console3I5center console
Engine cooling8Z5not hot country
Engine specificationsD914-cyl. turbo diesel engine 2.0 L/103 KW (4 V) TDI common rail TG3/TJ3/TU3/TL4/TP4/TM3/TW3/TR4/TS1/TN5
Left vanity mirror4SVVanity mirror, left, illuminated
Right vanity mirror4TUVanity mirror, right, illuminated
Navigation device7Q0without navigation system
rear fog lamp8TDRear fog light for driving on the left
Front fog lamp/additional headlamp8WAWithout fog lights
Hubcaps1NLTrims for alloy wheels
WheelsCP4Alloy wheels 7.5J x 17
Radios8AGRadio with CD/MP3
Smoker's/non-smoker's package9JANon smoker version
Tire pressure monitoring system7K0Without tyre pressure monitor
umbrellaNS0Without umbrella(s)
tireHK0Tires 235/45 R17 97W x1
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G3Alloy spare wheel with original equipment tires
Restraint systems, front3QT3-point seat belts in front, with tensioner and height adjustment
RCL"RCD 300" with MP3 replay function, 4 x 20 W, 8 speakers
WD7Anti-theft alarm system "Plus" -Single door opening and comfort locking-EU right-hand drive vehicle
WHLHighline package UK
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Special labels/plates0SSLabels in English and French
Tail lamp assemblies8SKTaillight assemblies with diodes (LED)
Locking mechanism for boot lid/cover rear4E2Tailgate/trunk lid release from inside (electrically)
Front seat, left3TFFront left comfort seat
Front seat, right3SFComfort seat, front right
Seat belt check9P1Seat belt reminder, electric contact in buckle
Outer rear seat belts3ZB3-point seat belts, outer rear with ECE label
Center rear seat belts3C73-point seat belt for center rear seat
seat coversN0XSeat trim covers in part-leather "Sports Grain"
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A3seat heating for front seats separat controlable
Side lights7R3Side turn signal lights (white)
Audio-response system/voice controlQH0without voice control
Side and rear windows4KCSide and rear windows in heat-insulating glass
Protective side molding4B4Protective side molding
Sunroof roller blind for rear/side windows3Y0without roller blind
power outlet7B312-volt outlet(s)
Bumper2JCComfort bumpers
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N4Windshield wiper intermittent control with potentiometer (four speeds)
Special approval measures3M0Without special measures
Nameplate set1DGNameplate set "TDI"
Special alarm systems9A0Without taxi alarm system
Mass damper for steering wheels1Q0steering wheel without balance weight
Door and lid locking system4K3Central locking w/ radio remote control, interior controls and SAFELOCK
Type approval countries/countries with special requirementsB09Type approval country GB/Northern Ireland
Carrier frequency for remote control5D1Carrier frequency 433.92 to 434.42 Mhz
Partition3CAwithout partition
Transit coatingNT0Transit coating (type 1)
Door and side trim panels3LJDoor and side trim panel in foam film, insert in leatherette
TV reception/digital radio receptionQV0without TV/digital radio reception
Assembly parts for engine (drive bearing)1VGAssembly part for 4-cyl. engine
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EXSpecial identification plate for EU
Delivery equipment2A0Without delivery equipment
First aid kit / warning triangle1T0Without first-aid material, without warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone / telematics9W0Without car phone preparation/ installation
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG1LongLife Service Regime
Heat accumulator system/auxiliary heater7E6electric air additional heater
Windshield Glass4GFWindshield in heat-insulating glass
Second battery/battery installation8FAwithout 2nd battery
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Decorative trims4ZBBright decorative trims
Additional child seat anchors3B4Child seat anchors for child seat system ISOFIX
Auxiliary heating system9M0Without auxiliary heater/parking heater
As far as I can tell, 0001291 is the correct 03-ABS coding. Furthermore, 03, 17, 19 and 53 all appear to be coded properly for drive-side, country and UH2 Auto-Hold. Did you try test driving the car, using the EPB a few times and locking the doors for a CAN nap yet .. or perhaps a good-old fashioned battery disconnect to clear confusion?
aswe
C?ID=276157
Yes be trying disconnect battery for 30 min, car be driving now for 2 days in normal use all works fine only this handbrake fault light flashes
Gone But Not Forgotten
Is brake fluid low by any chance or have you jumped out tank sensor to verify function?
Is the parking brake switch the correct part and or any parts in system possibly FOD?
Checking each of the part numbers is advised.
aswe
C?ID=276157
Ok guys, problem solved. So quick explaining after coding abs unit yellow parking brake light still flashes and there no be fault codes as you can see from autoscans, what I did disconnect battery for 3h and after running a parking brake test and light go off for good.
Thanks all
schumy1502
Romania
C?ID=334181
I have same situation today
I resolved the car with basic seting on G200 G201 and G251
