VW Passat abs coding
aswe
C?ID=276157
Hi all, I need a ABS code for passat 2008 2.0tdi auto hold. Some other guys changed parking brake control module and lost original code and now I get this car to sort it out, part numbers mach on both units, I find one code which is 0001291 with this code there is no more faults but parking brake fault light still flashes, there is autoscan from before
Thursday,06,June,2019,10:47:39:57164
VCDS Version: 19.6.0.2 (x64)
VIN: WVWZZZ3CZ8E229849   License Plate: YF08KDJ
Mileage: 243710km-151434mi   Repair Order: 321
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 76
VIN: WVWZZZ3CZ8E229849   Mileage: 243710km-151434miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 BL    HW: 03L 907 309
   Component: R4 2,0L EDC G001SG  6221
   Revision: --H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 00377 210 84959
   VCID: 70E86E68637C5FCF61-8024
               U1017 - 000 -
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 16:53:34
                    Voltage: 11.55 V
                    Bin. Bits: 11001010
                    Bin. Bits: 00000000
                    (no units): 0.0
               U1017 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 16:53:39
                    Voltage: 11.55 V
                    Torque: 219.0 Nm
                    Hex Value: 0xFF00
                    Bin. Bits: 11001010
   Part No SW: 3C0 614 109 K    HW: 3C0 614 109 K
   Component: J104    C4 440 V2   0005
   Revision: --020---    Serial number: 00000785497737
   Coding: 0004408
   Shop #: WSC 05311 000 00000
   VCID: 264448309138417FCB-8072
8 Faults Found:
                    Fault Priority: 9
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 17:07:35
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00000000
                    Count: 228
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 17:01:00
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011110
                    Count: 199
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 17:01:00
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011110
                    Count: 149
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 17:01:00
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 17:01:00
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 17:01:00
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 17:01:00
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 17:01:00
   Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
   VCID: 77FA5574061208F7A0-8022
   Revision: 00H54000    Serial number: 01000008249487
   Coding: A8808F0700041A1E470F00000F0000000008594300000100000000000000
   Shop #: WSC 05124 000 00000
   VCID: 71EE6B6C687656C76E-8024
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 280308 022  0601
   Coding: 00046997
   Shop #: WSC 05124
   Component: J234__006 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DP70N8VX
   Coding: 0012342
   VCID: 3B7289447ABAEC9784-806E
   Subsystem 1 - Serial number: 6333FTS650180798
   Subsystem 2 - Serial number: 6343FTS610270708
   Subsystem 3 - Serial number: 6353ETS6R2T1TVNP
   Subsystem 4 - Serial number: 6363ETS6LMC0TVNP
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
                    Fault Status: 11101001
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 16:54:23
   Part No SW: 3C0 953 549 AE    HW: 3C0 953 549 AE
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C5953507AT
   Coding: 0000111
   VCID: 6FEA6D147E42403778-803A
   Part No SW: 3C0 920 971 E    HW: 3C0 920 971 E
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0004405
   Shop #: WSC 00400 067 57207
   VCID: 275A453496325877F0-8072
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P0841203C1
   Coding: F9807F0E0002021003
   VCID: 23425124E20AB457AC-8076
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   VCID: 397E934C7086DE8796-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Component: J386  TUER-SG FT    1132
   Revision: 32008001    Serial number: 00000501488327
   Coding: 0000693
                    Fault Status: 01100101
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 16:54:23
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.134 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 36649870419831FF7B-8062
   Component:    KSG PQ46 ELV 042 0472
   Coding: 01910A0001860E7630049E1F70085FCE107C01
   Component: LIN BACKUP HORN H08 9001
   Component: Neigungssensor  004 0611
   Component: J387  TUER-SG BT    1132
   Revision: 32008001    Serial number: 00000562088319
   Coding: 0000692
   VCID: 3C708A587FB4EBAF8D-8068
   Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-09393 0009
   Revision:   008       Serial number: 00000000372665
   Coding: 0000057
   Shop #: WSC 00028 028 00001
   VCID: 295E430C80266E07E6-807C
                    Fault Status: 11101101
                    Fault Frequency: 8
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 16:54:21
                    Voltage: 11.30 V
                    Count: 71
                    Hex Value: 0x1240
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 00000000    Serial number: VWZ1Z2I6880722
   Coding: 0500040002
   Shop #: WSC 31414 790 31414
   VCID: 6BD279048A5ABC1754-803E
00856 - Radio Antenna
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 16:54:40
03138 - Input AUX IN
                    Reset counter: 14
                    Mileage: 243713 km
                    Date: 2019.06.03
                    Time: 16:54:27
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0308
   Revision: 41004101    Serial number: 00000000329349
   Coding: 0000144
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0308
   Revision: 41004101    Serial number: 00000000324622
   Coding: 0000144
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 C    HW: 3C0 919 283 C
   Component: Parkhilfe 8-Kan 004 0013
   Revision: 00004000    Serial number: 90640810000579
   Coding: 0000014
End-------------------------(Elapsed Time: 01:50)--------------------------
Address 03: DTCs cleared
Address 03,3C0 614 109 K,recoded (Short coding),from,0004408,to,0000301,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0004408,to,0002412,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0004408,to,0013569,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0004408,to,0000309,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000309,to,0000267,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000267,to,0000266,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000267,to,0000265,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000267,to,0000264,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000264,to,0000263,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000264,to,0000262,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000264,to,0000261,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000261,to,0000258,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000258,to,0000274,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000258,to,0000268,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000258,to,0000269,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000258,to,0000270,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000270,to,0000271,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000270,to,0000272,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000270,to,0000273,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000273,to,0000275,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000273,to,0000276,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000276,to,0000277,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000276,to,0000278,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000276,to,0000279,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000279,to,0000280,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000279,to,0000281,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000279,to,0000282,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000282,to,0002322,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000282,to,0002333,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0000307,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0002415,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0033272,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0029998,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0000293,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0000333,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000333,to,0034125,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000333,to,0004275,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000333,to,0001282,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0001282,to,0001288,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0001288,to,0001298,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0001288,to,0000415,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0001288,to,0000307,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0001288,to,0001291,(05311/000/00000),
Address 01: DTCs cleared
Address 44: DTCs cleared
aswe
C?ID=276157
new autoscan is this
Friday,07,June,2019,10:21:37:57164
Mileage: 243730km-151446mi   Repair Order: 321
VIN: WVWZZZ3CZ8E229849   Mileage: 243730km-151446miles
   Coding: 0000072
   Coding: 0001291
   Coding: 00046997
   Shop #: WSC 05124
   Coding: 0012342
   Coding: 0000111
   Coding: 0004405
   Coding: 0000693
   Coding: 0000692
   Coding: 0000057
   Coding: 0500040002
                    Reset counter: 18
                    Mileage: 243736 km
                    Date: 2019.06.03
                    Time: 22:12:46
                    Reset counter: 18
                    Mileage: 243736 km
                    Date: 2019.06.03
                    Time: 22:12:42
   Coding: 0000144
   Coding: 0000144
   Coding: 0000014
End-------------------------(Elapsed Time: 01:53)--------------------------
Jacek
Poland
C?ID=360566
Hello ; 3C0 614 109 K J104 C4 440 V2 0005 cod 0000285
aswe
C?ID=276157
be trying this no work at all
Hello Andis,
Now that you are registered and a Verified VCDS user I can move this to the Car Repair Support sub-forum. In the meanwhile I'll check into the coding of WVWZZZ3CZ8E229849 and report back in forum (rather than to the e-mail) with any coding suggestions we may have so the answer becomes searchable.
Vehicle Identification No.WVWZZZ3CZ8E229849
Modelpassat sedan
PA
Date of production22.04.2008
Model year2008
Sales type3C2192
Engine CodeCBAB
Transmission CodeKNS
[TABLE="class: vinInfoTable"]
[TR]
[TH]Special editions[/TH]
[TD="class: prCode"]E0A[/TD]
[TD]Without special action equipment[/TD]
[/TR]
[TR]
[TH]Lockable wheel bolts[/TH]
[TD="class: prCode"]1PE[/TD]
[TD]Wheel bolts with anti-theft protection
(unlockable)[/TD]
[/TR]
[TR]
[TH]Vehicle class differentiation
units/platform components[/TH]
[TD="class: prCode"]0HG[/TD]
[TD]Vehicle class differentiation -3C0-[/TD]
[/TR]
[TR]
[TH]Emission standard[/TH]
[TD="class: prCode"]7MB[/TD]
[TD]Emission standard EU 4 plus[/TD]
[/TR]
[TR]
[TH]Trailer hitch[/TH]
[TD="class: prCode"]1D0[/TD]
[TD]without trailer towing[/TD]
[/TR]
[TR]
[TH]airbag[/TH]
[TD="class: prCode"]4UE[/TD]
[TD]driver and front passanger airbags[/TD]
[/TR]
[TR]
[TH]Aktivkohlebehälter / Ottopartikelfilter[/TH]
[TD="class: prCode"]1E0[/TD]
[TD]Without activated charcoal canister[/TD]
[/TR]
[TR]
[TH]Tray areas package[/TH]
[TD="class: prCode"]QE2[/TD]
[TD]Storage compartment[/TD]
[/TR]
[TR]
[TH]Aerials[/TH]
[TD="class: prCode"]8ZH[/TD]
[TD]Antenna for AM/FM reception, "diversity"[/TD]
[/TR]
[TR]
[TH]Exterior mirror setting[/TH]
[TD="class: prCode"]6XN[/TD]
[TD]Exterior mirrors, power-adjustable/
separately heated[/TD]
[/TR]
[TR]
[TH]Left exterior mirror[/TH]
[TD="class: prCode"]5SJ[/TD]
[TD]Left exterior mirror, convex[/TD]
[/TR]
[TR]
[TH]Right exterior mirror[/TH]
[TD="class: prCode"]5RV[/TD]
[TD]Right exterior mirror, aspherical[/TD]
[/TR]
[TR]
[TH]Drive type[/TH]
[TD="class: prCode"]1X0[/TD]
[TD]Front-wheel drive[/TD]
[/TR]
[TR]
[TH]"Multimedia"video/DVD/notebook connection[/TH]
[TD="class: prCode"]9WC[/TD]
[TD]Without "Multimedia" in vehicle[/TD]
[/TR]
[TR]
[TH]Equipment levels[/TH]
[TD="class: prCode"]A8C[/TD]
[TD]Comfort equipment[/TD]
[/TR]
[TR]
[TH]Brake type in rear[/TH]
[TD="class: prCode"]1KU[/TD]
[TD]Disc brakes in rear[/TD]
[/TR]
[TR]
[TH]batteries[/TH]
[TD="class: prCode"]J0N[/TD]
[TD]Battery 330 A (61 Ah)[/TD]
[/TR]
[TR]
[TH]Brake type, front[/TH]
[TD="class: prCode"]1LH[/TD]
[TD]Silver caliper[/TD]
[/TR]
[TR]
[TH]Beverage holders[/TH]
[TD="class: prCode"]4M6[/TD]
[TD]Beverage holders[/TD]
[/TR]
[TR]
[TH]Battery/alternator capacity[/TH]
[TD="class: prCode"]NY0[/TD]
[TD]Standard battery/alternator capacity[/TD]
[/TR]
[TR]
[TH]Component part sets with
country-specific design requirements[/TH]
[TD="class: prCode"]B0N[/TD]
[TD]Component parts set, complying with
vehicle type for Great Britain, various
parts[/TD]
[/TR]
[TR]
[TH]vehicle tools and jack[/TH]
[TD="class: prCode"]1S1[/TD]
[TD]vehicle tools and jack[/TD]
[/TR]
[TR]
[TH]Brake systems[/TH]
[TD="class: prCode"]1AT[/TD]
[TD]Electronic stability control (ESC)[/TD]
[/TR]
[TR]
[TH]Owner's manuals[/TH]
[TD="class: prCode"]0VF[/TD]
[TD]Information kit in English[/TD]
[/TR]
[TR]
[TH]Operating voltage[/TH]
[TD="class: prCode"]9Z0[/TD]
[TD]Operating voltage 12 V[/TD]
[/TR]
[TR]
[TH]Heated washer nozzles[/TH]
[TD="class: prCode"]9T1[/TD]
[TD]Heated washer nozzles in front[/TD]
[/TR]
[TR]
[TH]CD ROM/DVD/SD card[/TH]
[TD="class: prCode"]7QA[/TD]
[TD]Without CD/DVD for navigation[/TD]
[/TR]
[TR]
[TH]CD changer/CD player[/TH]
[TD="class: prCode"]7A0[/TD]
[TD]Without CD changer/CD player[/TD]
[/TR]
[TR]
[TH]"Charism"[/TH]
[TD="class: prCode"]2H0[/TD]
[TD]Without "drive select"[/TD]
[/TR]
[TR]
[TH]General operating permit, alterations[/TH]
[TD="class: prCode"]C15[/TD]
[TD]Operating permit, alteration[/TD]
[/TR]
[TR]
[TH]Roof rails/roof load rack[/TH]
[TD="class: prCode"]3S0[/TD]
[TD]Without roof rails/roof load rack[/TD]
[/TR]
[TR]
[TH]Roof insert/convertible top[/TH]
[TD="class: prCode"]3FA[/TD]
[TD]roof without cut out[/TD]
[/TR]
[TR]
[TH]Suspension system in rear[/TH]
[TD="class: prCode"]1JA[/TD]
[TD]Rear shock absorption, basic design 1[/TD]
[/TR]
[TR]
[TH]Suspension system in front[/TH]
[TD="class: prCode"]G07[/TD]
[TD]Shock absorption in front[/TD]
[/TR]
[TR]
[TH]Load-through hatch/ski bag[/TH]
[TD="class: prCode"]3X2[/TD]
[TD]Load-through hatch[/TD]
[/TR]
[TR]
[TH]Insert for the filling up of unleaded
fuel/fuel type[/TH]
[TD="class: prCode"]2G0[/TD]
[TD]Without insert for the filling up of
fuel[/TD]
[/TR]
[TR]
[TH]Installation differentiation for components[/TH]
[TD="class: prCode"]0EN[/TD]
[TD]Installation differentiation for
transmission MQ 350
-- vehicle components --[/TD]
[/TR]
[TR]
[TH]Theft protection system[/TH]
[TD="class: prCode"]7AL[/TD]
[TD]Anti-theft alarm system, interior
monitoring, backup horn and towing
protection[/TD]
[/TR]
[TR]
[TH]Inserts[/TH]
[TD="class: prCode"]7TM[/TD]
[TD]Decorative inserts[/TD]
[/TR]
[TR]
[TH]Scuff plates[/TH]
[TD="class: prCode"]7M0[/TD]
[TD]Plastic scuff plates in door apertures[/TD]
[/TR]
[TR]
[TH]Park distance control[/TH]
[TD="class: prCode"]7X2[/TD]
[TD]Park distance control in front and rear[/TD]
[/TR]
[TR]
[TH]Electric interface for external use[/TH]
[TD="class: prCode"]UF0[/TD]
[TD]Without electric interface[/TD]
[/TR]
[TR]
[TH]Manufacturing sequence differentiation[/TH]
[TD="class: prCode"]0FA[/TD]
[TD]Standard manufacturing sequence[/TD]
[/TR]
[TR]
[TH]window regulator[/TH]
[TD="class: prCode"]4R4[/TD]
[TD]Power windows with comfort operation and
circuit breaker[/TD]
[/TR]
[TR]
[TH]fire extinguisher[/TH]
[TD="class: prCode"]6A0[/TD]
[TD]without fire extinguisher[/TD]
[/TR]
[TR]
[TH]Pedestrian protection[/TH]
[TD="class: prCode"]VL1[/TD]
[TD]Extended pedestrian protection measures[/TD]
[/TR]
[TR]
[TH]Headlight activation[/TH]
[TD="class: prCode"]8K0[/TD]
[TD]Without special driving light switching[/TD]
[/TR]
[TR]
[TH]Parking brake[/TH]
[TD="class: prCode"]UH2[/TD]
[TD]Parking brake[/TD]
[/TR]
[TR]
[TH]Vehicle specifications[/TH]
[TD="class: prCode"]F0A[/TD]
[TD]No special purpose vehicle, standard
equipment[/TD]
[/TR]
[TR]
[TH]Alternators[/TH]
[TD="class: prCode"]8GV[/TD]
[TD]Alternator 180 A[/TD]
[/TR]
[TR]
[TH]Transmission types/gearshift mechanisms[/TH]
[TD="class: prCode"]0G4[/TD]
[TD]Cable gearshift[/TD]
[/TR]
[TR]
[TH]Weight category rear axle[/TH]
[TD="class: prCode"]0YD[/TD]
[TD]Weight range 4
installation control only, no
requirement forecast[/TD]
[/TR]
[TR]
[TH]Weight category front axle[/TH]
[TD="class: prCode"]L02[/TD]
[TD]Suspension range 02
[/TR]
[TR]
[TH]Base engine[/TH]
[TD="class: prCode"]TG3[/TD]
[TD]4-cylinder diesel engine 2.0 l
unit 03L.A[/TD]
[/TR]
[TR]
[TH]Tie down straps/net/pocket[/TH]
[TD="class: prCode"]6M0[/TD]
[TD]Without tie down straps/net/pocket[/TD]
[/TR]
[TR]
[TH]cruise control system[/TH]
[TD="class: prCode"]8T2[/TD]
[TD]Electronic cruise control system (CCS)[/TD]
[/TR]
[TR]
[TH]Garage door opener[/TH]
[TD="class: prCode"]VC0[/TD]
[TD]without Garage door opener[/TD]
[/TR]
[TR]
[TH]Transmission specifications[/TH]
[TD="class: prCode"]G0K[/TD]
[TD]6-speed manual transmission[/TD]
[/TR]
[TR]
[TH]Cruise control system and speed limiter[/TH]
[TD="class: prCode"]6Y9[/TD]
[TD]without cruise control system[/TD]
[/TR]
[TR]
[TH]Brackets[/TH]
[TD="class: prCode"]3P0[/TD]
[TD]Without bracket for first aid kit and
warning triangle[/TD]
[/TR]
[TR]
[TH]Rear seats[/TH]
[TD="class: prCode"]3NU[/TD]
[TD]Rear bench seat, not split, split backrest, folding
centre armrest[/TD]
[/TR]
[TR]
[TH]Heating and air-conditioning system[/TH]
[TD="class: prCode"]9AP[/TD]
[TD]Climatic air-conditioning system (semi-automatic)[/TD]
[/TR]
[TR]
[TH]Headlamps[/TH]
[TD="class: prCode"]8BK[/TD]
[TD]Twin headlamps for driving on the left,
with integrated high beam[/TD]
[/TR]
[TR]
[TH]Customized installation[/TH]
[TD="class: prCode"]FC0[/TD]
[TD]Without individual installation[/TD]
[/TR]
[TR]
[TH]Interior light in footwell[/TH]
[TD="class: prCode"]6T0[/TD]
[TD]Without interior light in footwell[/TD]
[/TR]
[TR]
[TH]Instrument clusters[/TH]
[TD="class: prCode"]U5B[/TD]
[TD]Instrument insert, mph speedometer
Great Britain[/TD]
[/TR]
[TR]
[TH]Breakaway interior rearview mirror[/TH]
[TD="class: prCode"]4L2[/TD]
[TD]Breakaway interior rearview mirror,
dimming[/TD]
[/TR]
[TR]
[TH]headphone connection, rear[/TH]
[TD="class: prCode"]8MA[/TD]
[TD]no headphone connection in rear[/TD]
[/TR]
[TR]
[TH]Body style[/TH]
[TD="class: prCode"]K8B[/TD]
[TD]Notchback[/TD]
[/TR]
[TR]
[TH]Luggage compartment floor covering[/TH]
[TD="class: prCode"]6SE[/TD]
[TD]Flat needle-punched trunk floor covering[/TD]
[/TR]
[TR]
[TH]Cassette and CD storage unit[/TH]
[TD="class: prCode"]4W0[/TD]
[TD]without cassette / CD tray[/TD]
[/TR]
[TR]
[TH]Electronic map cooling system[/TH]
[TD="class: prCode"]QS0[/TD]
[TD]Without electronic map cooling system[/TD]
[/TR]
[TR]
[TH]Child seats[/TH]
[TD="class: prCode"]QA0[/TD]
[TD]without child seat[/TD]
[/TR]
[TR]
[TH]Climatic zones[/TH]
[TD="class: prCode"]0Y1[/TD]
[TD]Standard climatic zones[/TD]
[/TR]
[TR]
[TH]Compass/road sign display[/TH]
[TD="class: prCode"]QR0[/TD]
[TD]Without compass/road sign display/
dynamic road sign display[/TD]
[/TR]
[TR]
[TH]Seat ventilation/massage seat[/TH]
[TD="class: prCode"]4D0[/TD]
[TD]Without seat ventilation/massage seat[/TD]
[/TR]
[TR]
[TH]Fuel quantity for initial filling[/TH]
[TD="class: prCode"]1Z2[/TD]
[TD]Increase in initial standard fuel
filling[/TD]
[/TR]
[TR]
[TH]Fuel systems[/TH]
[TD="class: prCode"]0F5[/TD]
[TD]Fuel system for diesel engine[/TD]
[/TR]
[TR]
[TH]Body measures[/TH]
[TD="class: prCode"]5C0[/TD]
[TD]Without special body measures[/TD]
[/TR]
[TR]
[TH]Radiator grille[/TH]
[TD="class: prCode"]6KA[/TD]
[TD]Radiator grille[/TD]
[/TR]
[TR]
[TH]Rear license plate bracket[/TH]
[TD="class: prCode"]6P1[/TD]
[TD]Rear license plate carrier (ECE)[/TD]
[/TR]
[TR]
[TH]Front license plate bracket[/TH]
[TD="class: prCode"]6W1[/TD]
[TD]Front license plate carrier (large)[/TD]
[/TR]
[TR]
[TH]Paint preservative/transit coating[/TH]
[TD="class: prCode"]5K0[/TD]
[TD]Without surface protection, with
additional transit coating[/TD]
[/TR]
[TR]
[TH]Paint coating[/TH]
[TD="class: prCode"]FB0[/TD]
[TD]standard paint coating[/TD]
[/TR]
[TR]
[TH]Rear cargo area[/TH]
[TD="class: prCode"]3GA[/TD]
[TD]Without luggage compartment floor[/TD]
[/TR]
[TR]
[TH]Country codes[/TH]
[TD="class: prCode"]FE0[/TD]
[TD]Without country code (no DVD player in
vehicle)[/TD]
[/TR]
[TR]
[TH]Steering system arrangement[/TH]
[TD="class: prCode"]L0R[/TD]
[TD]Right-hand drive[/TD]
[/TR]
[TR]
[TH]Reading lamp[/TH]
[TD="class: prCode"]8S7[/TD]
[TD]2 reading lights in front[/TD]
[/TR]
[TR]
[TH]steering[/TH]
[TD="class: prCode"]1N3[/TD]
[TD]Speed-related variable steering assist
(Servotronic)[/TD]
[/TR]
[TR]
[TH]Backrest release[/TH]
[TD="class: prCode"]3H0[/TD]
[TD]Without backrest release for front seats[/TD]
[/TR]
[TR]
[TH]Load edge protection[/TH]
[TD="class: prCode"]2P1[/TD]
[TD]Plastic loading edge protection[/TD]
[/TR]
[TR]
[TH]Lumbar support[/TH]
[TD="class: prCode"]7P8[/TD]
[TD]Electrically adjustable lumbar support
for right front seat[/TD]
[/TR]
[TR]
[TH]steering wheels[/TH]
[TD="class: prCode"]2ZB[/TD]
[TD]Leather-wrapped multi-function steering
wheel[/TD]
[/TR]
[TR]
[TH]Speaker installation[/TH]
[TD="class: prCode"]8RM[/TD]
[TD]8 speakers (passive)[/TD]
[/TR]
[TR]
[TH]Headlight range control[/TH]
[TD="class: prCode"]8Q1[/TD]
[TD]Headlight range control[/TD]
[/TR]
[TR]
[TH]Center armrest[/TH]
[TD="class: prCode"]6E3[/TD]
[TD]Center armrest in front[/TD]
[/TR]
[TR]
[TH]Multi-function display/trip computer[/TH]
[TD="class: prCode"]9Q5[/TD]
[TD]Multi-function display with control[/TD]
[/TR]
[TR]
[TH]center console[/TH]
[TD="class: prCode"]3I5[/TD]
[TD]center console[/TD]
[/TR]
[TR]
[TH]Engine cooling[/TH]
[TD="class: prCode"]8Z5[/TD]
[TD]not hot country[/TD]
[/TR]
[TR]
[TH]Engine specifications[/TH]
[TD="class: prCode"]D91[/TD]
[TD]4-cyl. turbo diesel engine 2.0 L/103 KW (4 V)
TDI common rail
TG3/TJ3/TU3/TL4/TP4/TM3/TW3/TR4/TS1/TN5[/TD]
[/TR]
[TR]
[TH]Left vanity mirror[/TH]
[TD="class: prCode"]4SV[/TD]
[TD]Vanity mirror, left, illuminated[/TD]
[/TR]
[TR]
[TH]Right vanity mirror[/TH]
[TD="class: prCode"]4TU[/TD]
[TD]Vanity mirror, right, illuminated[/TD]
[/TR]
[TR]
[TH]Navigation device[/TH]
[TD="class: prCode"]7Q0[/TD]
[TD]without navigation system[/TD]
[/TR]
[TR]
[TH]rear fog lamp[/TH]
[TD="class: prCode"]8TD[/TD]
[TD]Rear fog light for driving on the left[/TD]
[/TR]
[TR]
[TH]Front fog lamp/additional headlamp[/TH]
[TD="class: prCode"]8WA[/TD]
[TD]Without fog lights[/TD]
[/TR]
[TR]
[TH]Hubcaps[/TH]
[TD="class: prCode"]1NL[/TD]
[TD]Trims for alloy wheels[/TD]
[/TR]
[TR]
[TH]Wheels[/TH]
[TD="class: prCode"]CP4[/TD]
[TD]Alloy wheels 7.5J x 17[/TD]
[/TR]
[TR]
[TH]Radios[/TH]
[TD="class: prCode"]8AG[/TD]
[TD]Radio with CD/MP3[/TD]
[/TR]
[TR]
[TH]Smoker's/non-smoker's package[/TH]
[TD="class: prCode"]9JA[/TD]
[TD]Non smoker version[/TD]
[/TR]
[TR]
[TH]Tire pressure monitoring system[/TH]
[TD="class: prCode"]7K0[/TD]
[TD]Without tyre pressure monitor[/TD]
[/TR]
[TR]
[TH]umbrella[/TH]
[TD="class: prCode"]NS0[/TD]
[TD]Without umbrella(s)[/TD]
[/TR]
[TR]
[TH]tire[/TH]
[TD="class: prCode"]HK0[/TD]
[TD]Tires 235/45 R17 97W x1[/TD]
[/TR]
[TR]
[TH]Tire suppliers[/TH]
[TD="class: prCode"]V0A[/TD]
[TD]Tires without specification of tire
brand[/TD]
[/TR]
[TR]
[TH]Spare wheel/breakdown kit[/TH]
[TD="class: prCode"]1G3[/TD]
[TD]Alloy spare wheel with original
equipment tires[/TD]
[/TR]
[TR]
[TH]Restraint systems, front[/TH]
[TD="class: prCode"]3QT[/TD]
[TD]3-point seat belts in front, with
tensioner and height adjustment[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]RCL[/TD]
[TD]"RCD 300" with MP3 replay function, 4 x
20 W, 8 speakers[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]WD7[/TD]
[TD]Anti-theft alarm system "Plus" -Single
door opening and comfort locking-EU
right-hand drive vehicle[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]WHL[/TD]
[TD]Highline package UK[/TD]
[/TR]
[TR]
[TH]Side airbag[/TH]
[TD="class: prCode"]4X3[/TD]
[TD]Side airbag in front, with curtain
airbag[/TD]
[/TR]
[TR]
[TH]Gearshift knob/handle[/TH]
[TD="class: prCode"]6Q2[/TD]
[TD]Gearshift knob/handle in leather[/TD]
[/TR]
[TR]
[TH]Special labels/plates[/TH]
[TD="class: prCode"]0SS[/TD]
[TD]Labels in English and French[/TD]
[/TR]
[TR]
[TH]Tail lamp assemblies[/TH]
[TD="class: prCode"]8SK[/TD]
[TD]Taillight assemblies with diodes (LED)[/TD]
[/TR]
[TR]
[TH]Locking mechanism for boot lid/cover
rear[/TH]
[TD="class: prCode"]4E2[/TD]
[TD]Tailgate/trunk lid release
from inside (electrically)[/TD]
[/TR]
[TR]
[TH]Front seat, left[/TH]
[TD="class: prCode"]3TF[/TD]
[TD]Front left comfort seat[/TD]
[/TR]
[TR]
[TH]Front seat, right[/TH]
[TD="class: prCode"]3SF[/TD]
[TD]Comfort seat, front right[/TD]
[/TR]
[TR]
[TH]Seat belt check[/TH]
[TD="class: prCode"]9P1[/TD]
[TD]Seat belt reminder, electric contact in
buckle[/TD]
[/TR]
[TR]
[TH]Outer rear seat belts[/TH]
[TD="class: prCode"]3ZB[/TD]
[TD]3-point seat belts, outer rear with ECE
label[/TD]
[/TR]
[TR]
[TH]Center rear seat belts[/TH]
[TD="class: prCode"]3C7[/TD]
[TD]3-point seat belt for center rear seat[/TD]
[/TR]
[TR]
[TH]seat covers[/TH]
[TD="class: prCode"]N0X[/TD]
[TD]Seat trim covers in part-leather "Sports
Grain"[/TD]
[/TR]
[TR]
[TH]Seat adjustment[/TH]
[TD="class: prCode"]3L3[/TD]
[TD]Manual height adjustment for front seats[/TD]
[/TR]
[TR]
[TH]seat heater[/TH]
[TD="class: prCode"]4A3[/TD]
[TD]seat heating for front seats separat controlable[/TD]
[/TR]
[TR]
[TH]Side lights[/TH]
[TD="class: prCode"]7R3[/TD]
[TD]Side turn signal lights (white)[/TD]
[/TR]
[TR]
[TH]Audio-response system/voice control[/TH]
[TD="class: prCode"]QH0[/TD]
[TD]without voice control[/TD]
[/TR]
[TR]
[TH]Side and rear windows[/TH]
[TD="class: prCode"]4KC[/TD]
[TD]Side and rear windows in heat-insulating
glass[/TD]
[/TR]
[TR]
[TH]Protective side molding[/TH]
[TD="class: prCode"]4B4[/TD]
[TD]Protective side molding[/TD]
[/TR]
[TR]
[TH]Sunroof roller blind for rear/side windows[/TH]
[TD="class: prCode"]3Y0[/TD]
[TD]without roller blind[/TD]
[/TR]
[TR]
[TH]power outlet[/TH]
[TD="class: prCode"]7B3[/TD]
[TD]12-volt outlet(s)[/TD]
[/TR]
[TR]
[TH]Bumper[/TH]
[TD="class: prCode"]2JC[/TD]
[TD]Comfort bumpers[/TD]
[/TR]
[TR]
[TH]Headlamp washer system[/TH]
[TD="class: prCode"]8X0[/TD]
[TD]Without headlamp washer system[/TD]
[/TR]
[TR]
[TH]Windshield wiper intermittent control/
light/rain sensor[/TH]
[TD="class: prCode"]8N4[/TD]
[TD]Windshield wiper intermittent control
with potentiometer (four speeds)[/TD]
[/TR]
[TR]
[TH]Special approval measures[/TH]
[TD="class: prCode"]3M0[/TD]
[TD]Without special measures[/TD]
[/TR]
[TR]
[TH]Nameplate set[/TH]
[TD="class: prCode"]1DG[/TD]
[TD]Nameplate set "TDI"[/TD]
[/TR]
[TR]
[TH]Special alarm systems[/TH]
[TD="class: prCode"]9A0[/TD]
[TD]Without taxi alarm system[/TD]
[/TR]
[TR]
[TH]Mass damper for steering wheels[/TH]
[TD="class: prCode"]1Q0[/TD]
[TD]steering wheel without balance weight[/TD]
[/TR]
[TR]
[TH]Door and lid locking system[/TH]
[TD="class: prCode"]4K3[/TD]
[TD]Central locking w/ radio remote control,
interior controls and SAFELOCK[/TD]
[/TR]
[TR]
[TH]Type approval countries/countries with
special requirements[/TH]
[TD="class: prCode"]B09[/TD]
[TD]Type approval country GB/Northern
Ireland[/TD]
[/TR]
[TR]
[TH]Carrier frequency for remote control[/TH]
[TD="class: prCode"]5D1[/TD]
[TD]Carrier frequency 433.92 to 434.42 Mhz[/TD]
[/TR]
[TR]
[TH]Partition[/TH]
[TD="class: prCode"]3CA[/TD]
[TD]without partition[/TD]
[/TR]
[TR]
[TH]Transit coating[/TH]
[TD="class: prCode"]NT0[/TD]
[TD]Transit coating (type 1)[/TD]
[/TR]
[TR]
[TH]Door and side trim panels[/TH]
[TD="class: prCode"]3LJ[/TD]
[TD]Door and side trim panel in foam film,
insert in leatherette[/TD]
[/TR]
[TR]
[TH]TV reception/digital radio reception[/TH]
[TD="class: prCode"]QV0[/TD]
[TD]without TV/digital radio reception[/TD]
[/TR]
[TR]
[TH]Assembly parts for engine (drive bearing)[/TH]
[TD="class: prCode"]1VG[/TD]
[TD]Assembly part for 4-cyl. engine[/TD]
[/TR]
[TR]
[TH]Front underbody guard[/TH]
[TD="class: prCode"]1SA[/TD]
[TD]Without additional front underbody guard[/TD]
[/TR]
[TR]
[TH]Identification plates[/TH]
[TD="class: prCode"]1EX[/TD]
[TD]Special identification plate for EU[/TD]
[/TR]
[TR]
[TH]Delivery equipment[/TH]
[TD="class: prCode"]2A0[/TD]
[TD]Without delivery equipment[/TD]
[/TR]
[TR]
[TH]First aid kit / warning triangle[/TH]
[TD="class: prCode"]1T0[/TD]
[TD]Without first-aid material, without warning triangle[/TD]
[/TR]
[TR]
[TH]Two-way radio installation preparation[/TH]
[TD="class: prCode"]9D0[/TD]
[TD]without prepared for two way radio system[/TD]
[/TR]
[TR]
[TH]Preparation for rotating beacon/siren
combination[/TH]
[TD="class: prCode"]9F0[/TD]
[TD]Without preparation for rotating
beacon/siren combination[/TD]
[/TR]
[TR]
[TH]Telephone / telematics[/TH]
[TD="class: prCode"]9W0[/TD]
[TD]Without car phone preparation/
installation[/TD]
[/TR]
[TR]
[TH]Additional warning lights[/TH]
[TD="class: prCode"]9TC[/TD]
[TD]Additional retro-reflectors (door area)[/TD]
[/TR]
[TR]
[TH]LongLife Service Regime[/TH]
[TD="class: prCode"]QG1[/TD]
[TD]LongLife Service Regime[/TD]
[/TR]
[TR]
[TH]Heat accumulator system/auxiliary heater[/TH]
[TD="class: prCode"]7E6[/TD]
[TD]electric air additional heater[/TD]
[/TR]
[TR]
[TH]Windshield Glass[/TH]
[TD="class: prCode"]4GF[/TD]
[TD]Windshield in heat-insulating glass[/TD]
[/TR]
[TR]
[TH]Second battery/battery installation[/TH]
[TD="class: prCode"]8FA[/TD]
[TD]without 2nd battery[/TD]
[/TR]
[TR]
[TH]Additional tires (snow tires)[/TH]
[TD="class: prCode"]2WA[/TD]
[TD]without spare tyre[/TD]
[/TR]
[TR]
[TH]floor mats[/TH]
[TD="class: prCode"]0TD[/TD]
[TD]Front and rear floor mats[/TD]
[/TR]
[TR]
[TH]Decorative trims[/TH]
[TD="class: prCode"]4ZB[/TD]
[TD]Bright decorative trims[/TD]
[/TR]
[TR]
[TH]Additional child seat anchors[/TH]
[TD="class: prCode"]3B4[/TD]
[TD]Child seat anchors for
child seat system ISOFIX[/TD]
[/TR]
[TR]
[TH]Auxiliary heating system[/TH]
[TD="class: prCode"]9M0[/TD]
[TD]Without auxiliary heater/parking heater[/TD]
[/TR]
[/TABLE]
As far as I can tell, 0001291 is the correct 03-ABS coding. Furthermore, 03, 17, 19 and 53 all appear to be coded properly for drive-side, country and UH2 Auto-Hold. Did you try test driving the car, using the EPB a few times and locking the doors for a CAN nap yet .. or perhaps a good-old fashioned battery disconnect to clear confusion?
aswe
C?ID=276157
Yes be trying disconnect battery for 30 min, car be driving now for 2 days in normal use all works fine only this handbrake fault light flashes
NostraJackAss
Is brake fluid low by any chance or have you jumped out tank sensor to verify function?
Is the parking brake switch the correct part and or any parts in system possibly FOD?
Checking each of the part numbers is advised.
aswe
C?ID=276157
Ok guys, problem solved. So quick explaining after coding abs unit yellow parking brake light still flashes and there no be fault codes as you can see from autoscans, what I did disconnect battery for 3h and after running a parking brake test and light go off for good.
Thanks all
schumy1502
Romania
C?ID=334181
I have same situation today
I resolved the car with basic seting on G200 G201 and G251
