Don,
Thanks again. Yes I remember that one. I changed it to Short from Normal. I will change back when I get the laptop back.
On another note, I went through the list of available changes and there are so many! Ones that I can understand I will attempt to change them but how do I find the meaning to the list? Is there a link I can source to read?
One I was particularly interested in was the Ride Height. It was set at 368mm.
I will get a link for a photo up soon.
Am I correct in assuming you can drop the ride height?
After adjusting the "New Value" here:
https://www.dropbox.com/s/jdeiuwwunabuk50/2019-12-02 18.01.16.jpg?dl=0
I got this screen next...
What does this mean?
https://www.dropbox.com/s/kwabwtkydi6bfm7/2019-12-02 18.02.00.jpg?dl=0
SORRY IN ADVANCE, I’m not sure how to make it smaller.
If Moderators could help out.....
Monday,02,December,2019,16:49:52:63594
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 19.6.0.6 (x64) HEX-V2 : 0.4505.4
VIN: WUAZZZ8V8GA901285 License Plate:
Mileage: 34249km-21281mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 52 55 5F
6C BB BC
VIN: WUAZZZ8V8GA901285 Mileage: 34249km-21281miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
Address 01: Engine (------CZGB) Labels:. 07K-907-309-V1.clb
Part No SW: 8V0 907 404 HW: 07K 907 309 C
Component: 2.5l R5/4V TF H52 0005
Revision: NKH52---
Coding: 12250032252601033620
Shop #: 29779 002 1048576
Dataset: EV_ECM25TFS0118V0907404 001006
ROD: EV_ECM25TFS0118V0907404.rod
VCID: 76B51A0DF848BB17E09-8022
Part No SW: 0DL 300 011 D HW: 0BH 927 711 F
Component: GSG DQ500 H10 5210
Revision: 00H10V01
Shop #: 00000 000 00000
Dataset: EV_TCMDQ500021 001001
VCID: 290F01717976A4EFBDB-807C
Address 03: Brakes (J104) Labels: None
Part No SW: 8V0 907 379 HW: 8V0 907 379
Component: ESC H42 0020
Revision: 00000000 Serial number: 61345000000176
Coding: 999CF08DBA9915AA4093086C4396920644990F5DA80210C2496022
Shop #: 06314 790 00021
Dataset: EV_Brake1UDSContiMK100IPB 061003
ROD: EV_Brake1UDSContiMK100IPB_061.rod
VCID: 015F79D1A1868CAFC5B-8054
Address 05: /Start Auth. (J518) Labels:| 5Q0-959-435.clb
Revision: 00021000 Serial number: 0370138548
Coding: 030C0C
Dataset: EV_KessyHellaMQBAB 002011
VCID: 3A2DCE3D8CD01F77C41-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000674672
Coding: 03100015110000001000000000001400
Dataset: EV_AirCondiFrontVaAU37X 008020
VCID: 3333E319ABBAEE3F077-8066
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 276884B7000000000001
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: MQBAB H H24 0173
Serial number: 01061516700117
Coding: 07151C46C24106FD03844004B31C07A80800000000000000000000000000
Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 094F61F199B6C4EF9DB-805C
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 150522 042 0580
Serial number: 150616233857
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 24038408
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Component: E1 - H05 0032
Serial number: 30 03 2015 00000515
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY151461H0K
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000032761267
Sun Roof:
Subsystem 6 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST000D2SKR00000
Coding: 901E00
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
B131D F7 [008] - No Release by Immobilizer
Fault Frequency: 64
Reset counter: 254
Mileage: 31418 km
Date: 2019.06.22
Time: 10:50:40
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391517006018
Coding: 0030150011
Dataset: EV_EPHVA18AU3700000 002026
VCID: 43D3B3D9FB1A5EBF977-8016
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 E HW: 8V0 907 376 E
Component: DAEMPFUNGS-SG H09 0072
Serial number: 110615001
Dataset: EV_AudiMagneRide 002003
ROD: EV_AudiMagneRide.rod
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 012 0361
Serial number: 003M2R0VZTS5
Coding: 98CCC000008000005C54000000C800000065
Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 4BC39BF9D34A96FF6F7-801E
Subsystem 1 - Part No SW: ----------- HW: 480 002 306 15
Serial number: 35767000000B6C21351Q
Subsystem 2 - Part No SW: ----------- HW: 480 002 306 15
Serial number: 3586700000077CD0351Y
Subsystem 3 - Part No SW: ----------- HW: 480 401 606 15
Serial number: 35165029F1B5A871C13J
Subsystem 4 - Part No SW: ----------- HW: 480 401 606 15
Serial number: 3526502C31B5A870B218
Subsystem 5 - Part No SW: ----------- HW: 480 402 705 15
Serial number: 3556502C51A14CC3E29P
Part No SW: 8V0 953 521 FB HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 19061504220345
Coding: A418
Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_010_AU37.rod
VCID: 7F5BFF29D772FA5FB3F-802A
Part No SW: 8V0 920 871 L HW: 8V0 920 871 L
Component: KOMBI H02 6420
Coding: 27AD081A3B8800080104EA001000000000000000
Shop #: 12345 123 61029
Dataset: EV_DashBoardVDDMQBAB 009046
VCID: 45D7ADC1F52E608FB93-8010
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW High 128 1223
Revision: -------- Serial number: 0003635673
Coding: 030100043F0860005B000268B80B00000001010000000000000000000000
Dataset: EV_GatewLear 013020
ROD: EV_GatewLear_013.rod
VCID: 75B71D01E54EB00FE93-8020
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 04 04 2015 E0012621
Subsystem 3 - Part No SW: 8S0 915 181 HW: 8S0 915 181
Component: J367-BDMHella H10 9041
Serial number: 3513796803
Part No SW: 0CQ 907 554 C HW: 0CQ 525 130
Component: Haldex4Motion H52 7754
Serial number: HA1-00026.03.15
Coding: 0601
Dataset: EV_AllWheelContrHA1VW37X 002015
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000164676005
Coding: 5D00000000000000
Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 3431E005AEB4E9071ED-8060
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: Master H05 0080
Serial number: 0369838358
Coding: 030312
Dataset: EV_LaneChangAssis 001020
ROD: EV_LaneChangAssis_VW51.rod
VCID: 3829D435B2DC0D67325-806C
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
Component: Slave H05 0080
Serial number: 0370215124
Coding: 030312
Component: FS 020 0041
Serial number: 090615BF805645
Coding: 005D1A205C01040000001002
Dataset: EV_DCUDriveSideEWMAXKLO 006003
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 8103
Dataset: EV_SteerAssisMQB 012140
VCID: 372BD709BFC2021F3BF-8062
Component: BFS 020 0041
Serial number: 270515BEQ18337
Coding: 005D12205E01040000001002
Dataset: EV_DCUPasseSideEWMAXKLO 006003
VCID: 42DDB6DDE40057B79C1-8016
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: - H01 0110
Coding: 01A600002B200200
Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB.rod
VCID: 3FDBBF2997F23A5FF3F-806A
Coding: E00100
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E00100
Part No SW: 8V0 035 022 HW: 8V0 035 022
Component: MU-H-ND-RW H45 0398
Serial number: A628F0F7500714
Coding: 017303080000000021511102000A00002F000326010001005E
Dataset: EV_MUHig6C3HBAS 001040
ROD: EV_MUHig6C3HBAS_AU37.rod
VCID: 6A8D3E7DBCF06FF7741-803E
Subsystem 1 - Part No SW: V03 959 801 PQ HW: -----------
Component: 2018 --- 0068
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9FY203E2Q
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000030041500020193
Compact Disc Database:
Component: Gracenote --- 4006
6697 - Databus
[Airbag: no communication]
Reset counter: 254
Mileage: 27388 km
Date: 2018.12.14
Time: 10:27:55
Voltage terminal 30: 13.0 V
Network diagnosis-Status: Enabled
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: RVC Mid H07 0140
Coding: 027300010201000300
Dataset: EV_2CamSysRearPASE 006016
ROD: EV_2CamSysRearPASE.rod
VCID: 3039EC155AACD5277A5-8064
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: HFS 020 0041
Serial number: 170515BEG18131
Coding: 004D12204001040000001002
Dataset: EV_DCURearDriveMINKLO 006003
Component: HBFS 020 0041
Serial number: 170515BEG18134
Dataset: EV_DCURearPasseMINKLO 006003
End----------(Elapsed Time: 01:44, VBatt start/end: 12.0V/12.0V)-----------
